  2. English
  3. Visualization
  4. Read oid in VIS HTML
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
15 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • GunthervcG
    GunthervcG
    Gunthervc
    Could someone help me to get the image in my table instead of true/false text.
    In VIS i placed a HTML widget .
    Is it possible to read image instead of text and also is it possible to change the status like the bulb on/off widget in a table?
    <table class="mytable">
    <tr>
    <td width="20%">{sonoff.0.Lamp.POWER}</td>
    <td width="80%">{sonoff.0.Lamp.INFO.Hostname}</td>
    </tr>
    </table>
    thank you
    CrunkFXC 1 Antwort Letzte Antwort
    • GunthervcG Gunthervc
      <tr>
      </tr>
      </table>
      thank you
      CrunkFXC
      CrunkFXC
      CrunkFX
      Forum Testing
      @Gunthervc Why are you using a Table for that?
      • GunthervcG
        GunthervcG
        Gunthervc
        @CrunkFX To make a better and proper align on vis html.
        CrunkFXC 2 Antworten Letzte Antwort
          CrunkFXC
          CrunkFXC
          CrunkFX
          Forum Testing
          @Gunthervc OK i'll take a Look at IT later
            CrunkFXC
            CrunkFXC
            CrunkFX
            Forum Testing
            @Gunthervc So doing it with a table will be a bit tricky but not impossible. I tried finding a way without using scripts for that.
            First goto your VIS FileManager and Create an new folder with a custom nameScreenshot (22).png
            then open the created folder and upload your images to itScreenshot (21).png
            then put the actual states of your switched element into the names ( in my case true and false).
            After that you can close the window and goto the HTML Table and put the following line into it:
            <img src= /vis.0/test/img/lamp1/{0_userdata.0.yourlamporwhatever}.png height=100 width=100>
            This is the Path we created earlier:
            This is the actual State(true, false,1,0,whatever):
            The rest of the filename so if you use jpg put in .jpg:
            .png
            That should do the Trick.
            I´ll be available for any questions
            Kind regards
            CrunkFX
            GunthervcG 1 Antwort Letzte Antwort
            • CrunkFXC CrunkFX
              .png
              Kind regards
              CrunkFX
              GunthervcG
              GunthervcG
              Gunthervc
              @CrunkFX This is awesone!
              Search this for a long time.
              Is it also possible to make these images to toggle (false/true) on click?
              I appreciate your help.
                CrunkFXC
                CrunkFXC
                CrunkFX
                Forum Testing
                @Gunthervc There's Dome was of creating a Button Image. I'll take a Look at IT.
                • GunthervcG
                  GunthervcG
                  Gunthervc
                  schrieb am zuletzt editiert von Gunthervc
                  Is there some limitation on creating objects in 1 table?
                  After 10 rows the latest image won't be showing.
                  When adding 1 more (11rows) all table are gone and showing code.
                    CrunkFXC
                    CrunkFXC
                    CrunkFX
                    Forum Testing
                    schrieb am zuletzt editiert von CrunkFX
                    @Gunthervc We got that issue already. I'll try top find the Thread but i don't Know If There's was a workaround
                    we kunnen ook gewoon nederlands praten als dat makkelijker is
                      CrunkFXC
                      CrunkFXC
                      CrunkFX
                      Forum Testing
                      @Gunthervc Could you try to use div's instead of Tables?
                      • CrunkFXC CrunkFX
                        GunthervcG
                        GunthervcG
                        Gunthervc
                        @CrunkFX thanks for the effort.
                        if you can find the topic please let me know.
                        i will try div instead of tables.
                        Ja in het nederlands zou makkelijker zijn maar weet niet of het is toegelaten op dit forum.
                        Je heb me al heel hard geholpen met aantal problemen.
                        Ik ben graag met deze zaken bezig maar schiet te kort in het schrijven van code. Het uitlezen is geen probleem maar kan ze nooit zelf bedenken.
                        Dit alles is begonnen met mijn simatic S7 waar ik momenteel alles mee doe.
                        • CrunkFXC
                          CrunkFXC
                          CrunkFX
                          Forum Testing
                          @Gunthervc
                          u kunt ook gebruik maken van het nederlandse forum hier https://forum.iobroker.net/category/40/nederlands
                          het topic ging niet over html maar ik dacht dat wel.
                          er zijn hier scripts die het mogelijk maken om grote html-tabellen te maken, dus dit moet mogelijk zijn. Ik zal deze scripts uitvoeren en zien wat ze anders doen
                          Groeten
                          CrunkFX
                            CrunkFXC
                            CrunkFXC
                            CrunkFX
                            Forum Testing
                            @Gunthervc kunt u hier uw html-script als code plaatsen of via directe chat?
                            • O
                              O
                              oliverthom707
                              schrieb am zuletzt editiert von oliverthom707
                              Is it also possible to make these images to toggle (false/true) on click?.
                              • O oliverthom707
                                CrunkFXC
                                CrunkFXC
                                CrunkFX
                                Forum Testing
                                @oliverthom707 Of course, it is possible, but somehow not very effective to build. I would consider doing it with a Material Table by Scrounger or just using Buttons in VIS. If created by hand we can´t get big HTML Tables to work properly.
                                33.2k
                                84.3k
