  2. English
  3. Visualization
  4. Read oid in VIS HTML
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
15 Beiträge 3 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • GunthervcG Offline
    GunthervcG Offline
    Gunthervc
    @CrunkFX To make a better and proper align on vis html.
    CrunkFXC 2 Antworten Letzte Antwort
    • GunthervcG Gunthervc
      CrunkFXC Offline
      CrunkFXC Offline
      CrunkFX
      Forum Testing
      @Gunthervc OK i'll take a Look at IT later
        CrunkFXC Offline
        CrunkFXC Offline
        CrunkFX
        Forum Testing
        @Gunthervc So doing it with a table will be a bit tricky but not impossible. I tried finding a way without using scripts for that.
        First goto your VIS FileManager and Create an new folder with a custom nameScreenshot (22).png
        then open the created folder and upload your images to itScreenshot (21).png
        then put the actual states of your switched element into the names ( in my case true and false).
        After that you can close the window and goto the HTML Table and put the following line into it:
        <img src= /vis.0/test/img/lamp1/{0_userdata.0.yourlamporwhatever}.png height=100 width=100>
        This is the Path we created earlier:
        This is the actual State(true, false,1,0,whatever):
        The rest of the filename so if you use jpg put in .jpg:
        .png
        That should do the Trick.
        I´ll be available for any questions
        Kind regards
        CrunkFX
        GunthervcG 1 Antwort Letzte Antwort
        • CrunkFXC CrunkFX
          .png
          Kind regards
          CrunkFX
          GunthervcG Offline
          GunthervcG Offline
          Gunthervc
          @CrunkFX This is awesone!
          Search this for a long time.
          Is it also possible to make these images to toggle (false/true) on click?
          I appreciate your help.
          CrunkFXC 1 Antwort Letzte Antwort
            CrunkFXC Offline
            CrunkFXC Offline
            CrunkFX
            Forum Testing
            @Gunthervc There's Dome was of creating a Button Image. I'll take a Look at IT.
              GunthervcG Offline
              Gunthervc
              schrieb am zuletzt editiert von Gunthervc
              Is there some limitation on creating objects in 1 table?
              After 10 rows the latest image won't be showing.
              When adding 1 more (11rows) all table are gone and showing code.
                CrunkFXC Offline
                CrunkFXC Offline
                CrunkFX
                Forum Testing
                schrieb am zuletzt editiert von CrunkFX
                @Gunthervc We got that issue already. I'll try top find the Thread but i don't Know If There's was a workaround
                we kunnen ook gewoon nederlands praten als dat makkelijker is
                  CrunkFXC Offline
                  CrunkFXC Offline
                  CrunkFX
                  Forum Testing
                  @Gunthervc Could you try to use div's instead of Tables?
                  • CrunkFXC CrunkFX
                    GunthervcG Offline
                    GunthervcG Offline
                    Gunthervc
                    @CrunkFX thanks for the effort.
                    if you can find the topic please let me know.
                    i will try div instead of tables.
                    Ja in het nederlands zou makkelijker zijn maar weet niet of het is toegelaten op dit forum.
                    Je heb me al heel hard geholpen met aantal problemen.
                    Ik ben graag met deze zaken bezig maar schiet te kort in het schrijven van code. Het uitlezen is geen probleem maar kan ze nooit zelf bedenken.
                    Dit alles is begonnen met mijn simatic S7 waar ik momenteel alles mee doe.
                    • CrunkFXC Offline
                      CrunkFXC Offline
                      CrunkFX
                      Forum Testing
                      @Gunthervc
                      u kunt ook gebruik maken van het nederlandse forum hier https://forum.iobroker.net/category/40/nederlands
                      het topic ging niet over html maar ik dacht dat wel.
                      er zijn hier scripts die het mogelijk maken om grote html-tabellen te maken, dus dit moet mogelijk zijn. Ik zal deze scripts uitvoeren en zien wat ze anders doen
                      Groeten
                      CrunkFX
                        CrunkFXC Offline
                        CrunkFXC Offline
                        CrunkFX
                        Forum Testing
                        @Gunthervc kunt u hier uw html-script als code plaatsen of via directe chat?
                        • O Offline
                          O Offline
                          oliverthom707
                          schrieb am zuletzt editiert von oliverthom707
                          Is it also possible to make these images to toggle (false/true) on click?.
                          • O oliverthom707
                            CrunkFXC Offline
                            CrunkFXC Offline
                            CrunkFX
                            Forum Testing
                            @oliverthom707 Of course, it is possible, but somehow not very effective to build. I would consider doing it with a Material Table by Scrounger or just using Buttons in VIS. If created by hand we can´t get big HTML Tables to work properly.
