  2. English
  3. Visualization
  4. Read oid in VIS HTML
Geplant Angeheftet Gesperrt Verschoben Visualization
vis
15 Beiträge 3 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • CrunkFXC CrunkFX
    @Gunthervc So doing it with a table will be a bit tricky but not impossible. I tried finding a way without using scripts for that.
    First goto your VIS FileManager and Create an new folder with a custom nameScreenshot (22).png
    then open the created folder and upload your images to itScreenshot (21).png
    then put the actual states of your switched element into the names ( in my case true and false).
    After that you can close the window and goto the HTML Table and put the following line into it:
    <img src= /vis.0/test/img/lamp1/{0_userdata.0.yourlamporwhatever}.png height=100 width=100>
    This is the Path we created earlier:
    This is the actual State(true, false,1,0,whatever):
    The rest of the filename so if you use jpg put in .jpg:
    .png
    That should do the Trick.
    I´ll be available for any questions
    Kind regards
    CrunkFX
    GunthervcG Offline
    GunthervcG Offline
    Gunthervc
    @CrunkFX This is awesone!
    Search this for a long time.
    Is it also possible to make these images to toggle (false/true) on click?
    I appreciate your help.
    CrunkFXC 1 Antwort Letzte Antwort
    • GunthervcG Gunthervc
      CrunkFXC Offline
      CrunkFXC Offline
      CrunkFX
      Forum Testing
      @Gunthervc There's Dome was of creating a Button Image. I'll take a Look at IT.
      • GunthervcG Offline
        GunthervcG Offline
        Gunthervc
        schrieb am zuletzt editiert von Gunthervc
        Is there some limitation on creating objects in 1 table?
        After 10 rows the latest image won't be showing.
        When adding 1 more (11rows) all table are gone and showing code.
        CrunkFXC 2 Antworten Letzte Antwort
          CrunkFXC Offline
          CrunkFXC Offline
          CrunkFX
          Forum Testing
          schrieb am zuletzt editiert von CrunkFX
          @Gunthervc We got that issue already. I'll try top find the Thread but i don't Know If There's was a workaround
          we kunnen ook gewoon nederlands praten als dat makkelijker is
            CrunkFXC Offline
            CrunkFXC Offline
            CrunkFX
            Forum Testing
            @Gunthervc Could you try to use div's instead of Tables?
            GunthervcG 1 Antwort Letzte Antwort
            • CrunkFXC CrunkFX
              GunthervcG Offline
              GunthervcG Offline
              Gunthervc
              @CrunkFX thanks for the effort.
              if you can find the topic please let me know.
              i will try div instead of tables.
              Ja in het nederlands zou makkelijker zijn maar weet niet of het is toegelaten op dit forum.
              Je heb me al heel hard geholpen met aantal problemen.
              Ik ben graag met deze zaken bezig maar schiet te kort in het schrijven van code. Het uitlezen is geen probleem maar kan ze nooit zelf bedenken.
              Dit alles is begonnen met mijn simatic S7 waar ik momenteel alles mee doe.
              • CrunkFXC Offline
                CrunkFXC Offline
                CrunkFX
                Forum Testing
                @Gunthervc
                u kunt ook gebruik maken van het nederlandse forum hier https://forum.iobroker.net/category/40/nederlands
                het topic ging niet over html maar ik dacht dat wel.
                er zijn hier scripts die het mogelijk maken om grote html-tabellen te maken, dus dit moet mogelijk zijn. Ik zal deze scripts uitvoeren en zien wat ze anders doen
                Groeten
                CrunkFX
                  CrunkFXC Offline
                  CrunkFXC Offline
                  CrunkFX
                  Forum Testing
                  @Gunthervc kunt u hier uw html-script als code plaatsen of via directe chat?
                  • O Offline
                    O Offline
                    oliverthom707
                    schrieb am zuletzt editiert von oliverthom707
                    Is it also possible to make these images to toggle (false/true) on click?.
                    • O oliverthom707
                      CrunkFXC Offline
                      CrunkFXC Offline
                      CrunkFX
                      Forum Testing
                      @oliverthom707 Of course, it is possible, but somehow not very effective to build. I would consider doing it with a Material Table by Scrounger or just using Buttons in VIS. If created by hand we can´t get big HTML Tables to work properly.
