  4. Fehler bei der Installation von ioBroker
installationsproblemeinstallationsfehleriobroker installationnpm errunexpected end of json
24 Beiträge 3 Kommentatoren 3.8k Aufrufe 2 Beobachtet
    Kruech
    Wie gesagt das hatte ich immer so gemacht. Hab das ganze gerade noch einmal von Vorne gemacht und wieder.
    pi@iobroker:~ $ curl -sL https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2020-04-12
        Welcome to the ioBroker installer!
        Installer version: 2020-04-12
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:2 http://archive.raspberrypi.org/debian buster InRelease
    OK:3 https://deb.nodesource.com/node_10.x buster InRelease
    Changing npm registry to https://registry.npmjs.org
    Installed gcc-c++
        Creating ioBroker user and directory (2/4)
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    npm ERR! Unexpected end of JSON input while parsing near '...\r\n\r\nwsFcBAEBCAAQB'
    npm ERR!     /home/pi/.npm/_logs/2020-05-29T12_20_07_476Z-debug.log
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://10.70.90.101:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
    pi@iobroker:~ $ exit
    Abgemeldet
    Session stopped
        - Press <return> to exit tab
        - Press R to restart session
        - Press S to save terminal output to file
    login as: pi
    Last login: Fri May 29 14:25:06 2020 from 192.168.1.2
    pi@iobroker:~ $ iobroker status
    internal/modules/cjs/loader.js:638
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
        at Function.Module._load (internal/modules/cjs/loader.js:562:25)
        at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
        at startup (internal/bootstrap/node.js:283:19)
        at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    • K Kruech
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      Abgemeldet
      Session stopped
      login as: pi
          throw err;
      @Kruech sagte in Fehler bei der Installation von ioBroker:
      ich glaube nur was ich sehe ;-)
      hier geht es schon los:
      Da ist irgendetwas mit dem Download schief gegangen.
        @Homoran sagte in Fehler bei der Installation von ioBroker:
        Ich sehe diese Fehler in den letzten Tagen häufiger. Auch bei aktualisierten Adaptern.
        npm cache löschen und nochmal installieren hilft dann ggf.
        Ist da auf dem Server mit den Repos vielleicht auch irgendwas krumm?
          @Thomas-Braun sagte in Fehler bei der Installation von ioBroker:
          bei npm basierten Infos sicher, da dann neu geladen wird.
          wie das bei einem curl aussieht habe ich leider keine Ahnung, ob man da ein --force oder sonst etwas noch hinzufügen kann, damit es neu heruntergeladen wird
            Kruech
            hmm also den cache löschen geht hier wohl auch nicht so einfach.
            pi@iobroker:/ $ npm cache clean
            npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
            npm ERR!
            npm ERR! If you're sure you want to delete the entire cache, rerun this command with --force.
            npm ERR!     /home/pi/.npm/_logs/2020-05-29T13_05_53_645Z-debug.log
            • K Kruech
              npm ERR!
              @Kruech das muss mit --force gemacht werden
                Kruech
                Ich hab jetzt mal in log geschaut welche bei der Installation vom iobroker am Ende steht.
                Da sind einige von diesen Fehlern drinnen. hier nur ein Auszug
                823 http fetch GET 200 https://registry.npmjs.org/callsite 427ms
                824 http fetch GET 200 https://registry.npmjs.org/async-limiter/-/async-limiter-1.0.1.tgz 340ms
                825 silly pacote range manifest for async-limiter@~1.0.0 fetched in 435ms
                826 http fetch GET 200 https://registry.npmjs.org/ms/-/ms-2.1.1.tgz 564ms
                827 silly pacote version manifest for ms@2.1.1 fetched in 1079ms
                828 http fetch GET 200 https://registry.npmjs.org/callsite/-/callsite-1.0.0.tgz 3851ms
                829 silly pacote version manifest for callsite@1.0.0 fetched in 4290ms
                830 http fetch GET 200 https://registry.npmjs.org/@types%2fnode 6071ms
                831 http fetch GET 200 https://registry.npmjs.org/@types/node/-/node-14.0.5.tgz 827ms
                832 silly pacote range manifest for @types/node@* fetched in 6960ms
                833 silly fetchPackageMetaData error for express-fileupload@^1.1.6 Response timeout while trying to fetch https://registry.npmjs.org/express-fileupload (over 30000ms)
                834 silly fetchPackageMetaData error for express-session@^1.17.1 Response timeout while trying to fetch https://registry.npmjs.org/express-session (over 30000ms)
                835 http fetch GET 200 https://registry.npmjs.org/express-fileupload 33471ms
                836 http fetch GET 200 https://registry.npmjs.org/express-session 33747ms
                837 http fetch GET 200 https://registry.npmjs.org/cookie 30589ms
                838 http fetch GET 200 https://registry.npmjs.org/cookie/-/cookie-0.4.0.tgz 109ms
                839 silly pacote version manifest for cookie@0.4.0 fetched in 30709ms
                840 http fetch GET 200 https://registry.npmjs.org/depd/-/depd-1.1.2.tgz 32975ms
                841 silly pacote range manifest for depd@~1.1.2 fetched in 35435ms
                842 http fetch GET 200 https://registry.npmjs.org/proxy-addr 17746ms
                843 http fetch GET 200 https://registry.npmjs.org/proxy-addr/-/proxy-addr-2.0.6.tgz 129ms
                844 silly pacote range manifest for proxy-addr@~2.0.5 fetched in 17890ms
                845 http fetch GET 200 https://registry.npmjs.org/forwarded 84ms
                846 http fetch GET 200 https://registry.npmjs.org/forwarded/-/forwarded-0.1.2.tgz 80ms
                847 silly pacote range manifest for forwarded@~0.1.2 fetched in 176ms
                848 http fetch GET 200 https://registry.npmjs.org/ipaddr.js 209ms
                849 http fetch GET 200 https://registry.npmjs.org/ipaddr.js/-/ipaddr.js-1.9.1.tgz 123ms
                850 silly pacote version manifest for ipaddr.js@1.9.1 fetched in 344ms
                851 silly pacote tag manifest for iobroker.admin@stable fetched in 20ms
                852 silly resolveWithNewModule iobroker.admin@4.0.10 checking installable status
                853 silly pacote tag manifest for iobroker.js-controller@stable fetched in 22ms
                854 silly resolveWithNewModule iobroker.js-controller@2.2.9 checking installable status
                855 http fetch GET 304 https://registry.npmjs.org/iobroker.discovery 110ms (from cache)
                856 silly fetchPackageMetaData error for iobroker.discovery@stable Unexpected end of JSON input while parsing near '...all":"https://registr'
                857 http fetch GET 304 https://registry.npmjs.org/iobroker.info 112ms (from cache)
                858 silly fetchPackageMetaData error for iobroker.info@stable Unexpected end of JSON input while parsing near '...a\nlnA+mVwSqD72a1Wh5l'
                859 timing stage:rollbackFailedOptional Completed in 0ms
                860 timing stage:runTopLevelLifecycles Completed in 223076ms
                • K Kruech
                  npmjs.org
                  So oft wie ich in den letzten Tagen korrupte json Files gesehen habe vermute ich, dass es irgendwo auf npmjs.org klemmt.
                  [Edit:] BINGO!
                  https://status.npmjs.org/
                  Monitoring - We began investigating an issue with the npmjs.com website a short time ago, quickly identified the issue and we are monitoring a fix we have deployed.
                  May 29, 06:10 UTC
                    Kruech
                    Alles klar, dann vielen Dank erstmal, dann bin ich beruhigt das es nicht an mir liegt und dann hilft wohl nur Tee trinken.
                      Kruech
                      So trotz das bei https://status.npmjs.org/ wieder alles grün ist habe ich immer noch die gleichen Probleme. Hat jemand ne weitere Idee?
                      • K Kruech
                        @Kruech
                        Zuerst musst du mal schauen, ob node sauber installiert ist:
                        which nodejs && nodejs -v && which node && node -v && which npm && npm -v
                        Dann als user, der auch die Installation durchführt:
                        npm cache clean --force
                        Und dann nochmal den Installer anhauen.
                          Kruech
                          schrieb am zuletzt editiert von Kruech
                          @Thomas-Braun
                          pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v
                          /usr/bin/nodejs
                          v10.20.1
                          /usr/bin/node
                          v10.20.1
                          /usr/bin/npm
                          6.14.4
                          Cache clean und neu installiert habe ich auch schon probiert. Trotzdem immer
                          library: loaded
                          OK:1 http://archive.raspberrypi.org/debian buster InRelease
                          OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Installed gcc-c++
                          npm ERR! Unexpected end of JSON input while parsing near '...sk":"^1.0.6","@iobrok'
                          npm ERR!     /home/pi/.npm/_logs/2020-06-02T18_53_21_120Z-debug.log
                          Autostart enabled!
                            Kruech
                            in der log-Datei von der IoBroker installation hab ich immer paar mal nen timeout.
                            1051 silly fetchPackageMetaData error for engine.io@~3.4.0 Response timeout while trying to fetch https://registry.npmjs.org/engine.io (over 30000ms)
                            es sind aber nicht immer die gleichen Pakete.
                            • K Kruech
                              npm install npm@latest -g
                                Kruech
                                Ich geh kaputt. jetzt hat das wenigstens schon mal soweit geklappt des der IoBroker installiert wurde und ich per Browser drauf komme.
                                Es sind sehr viele "warnings" bei der Installation aufgelaufen.
                                In file included from ../src/main.cpp:3:
                                ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                                In file included from ../../nan/nan.h:56,
                                ../src/main.cpp: At global scope:
                                /home/pi/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                       (node::addon_register_func) (regfunc),                          \
                                /home/pi/.cache/node-gyp/10.20.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
                                   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                                 NODE_MODULE(diskusage, Init)
                                In file included from /home/pi/.cache/node-gyp/10.20.1/include/node/node.h:63,
                                /home/pi/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                                /home/pi/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78:   required from here
                                /home/pi/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                                reinterpret_cast<Callback>(callback), type);
                                /home/pi/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
                                ../../nan/nan_object_wrap.h:65:61:   required from here
                                /home/pi/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                In file included from ../src/unix_dgram.cc:5:
                                ../src/unix_dgram.cc: At global scope:
                                ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                                 NODE_MODULE(unix_dgram, Initialize)
                                In file included from ../src/./serialport.h:6,
                                                 from ../src/serialport.cpp:1:
                                ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                                ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’}  -Wcast-function-type]
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                                ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                                ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                                ../src/serialport.cpp: At global scope:
                                ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                                 SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                                 SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                                In file included from ../../../nan/nan.h:56,
                                /home/pi/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
                                 NODE_MODULE(serialport, init);
                                ../../../nan/nan_object_wrap.h:65:61:   required from here
                                In file included from ../src/serialport.h:6,
                                                 from ../src/serialport_unix.cpp:2:
                                ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                                ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                                     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                                ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                                ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                                ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                                     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                                ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                                In file included from ../src/poller.cpp:1:
                                • K Kruech
                                  @Kruech
                                  rm -rf /home/pi/.cache/*
                                  Und dann würde ich dir eigentlich auch Version 12 von node empfehlen.
                                  Zu guter Letzt wirf noch ein
                                  iobroker stop
                                  iobroker fix
                                  hinterher.
                                    Kruech
                                    @Thomas-Braun
                                    Vielen Dank für die Hilfe. Dann werde ich jetzt den ganzen Pi nochmal aufsetzten mit Version 12 damit das sauberer ist als wie jetzt. Ich weis gar nicht mehr was ich jetzt alles rumprobiert habe.
                                    • K Kruech
                                      @Thomas-Braun
                                      @Kruech
                                      Wenn es ansonsten läuft...
                                      Aber wie du meinst.
                                      Der springende Punkt ist bei dir aus irgendwelchen Gründen die Version von npm.
                                      Die musst du vor der Installation des ioBrokers (und nach der Installation von nodejs) auf >=6.14.5 bringen.
