  4. Fehler bei der Installation von ioBroker
installationsproblemeinstallationsfehleriobroker installationnpm errunexpected end of json
24 Beiträge 3 Kommentatoren 3.8k Aufrufe 2 Beobachtet
  • K Kruech
    Ich hab jetzt mal in log geschaut welche bei der Installation vom iobroker am Ende steht.
    Da sind einige von diesen Fehlern drinnen. hier nur ein Auszug
    823 http fetch GET 200 https://registry.npmjs.org/callsite 427ms
    824 http fetch GET 200 https://registry.npmjs.org/async-limiter/-/async-limiter-1.0.1.tgz 340ms
    825 silly pacote range manifest for async-limiter@~1.0.0 fetched in 435ms
    826 http fetch GET 200 https://registry.npmjs.org/ms/-/ms-2.1.1.tgz 564ms
    827 silly pacote version manifest for ms@2.1.1 fetched in 1079ms
    828 http fetch GET 200 https://registry.npmjs.org/callsite/-/callsite-1.0.0.tgz 3851ms
    829 silly pacote version manifest for callsite@1.0.0 fetched in 4290ms
    830 http fetch GET 200 https://registry.npmjs.org/@types%2fnode 6071ms
    831 http fetch GET 200 https://registry.npmjs.org/@types/node/-/node-14.0.5.tgz 827ms
    832 silly pacote range manifest for @types/node@* fetched in 6960ms
    833 silly fetchPackageMetaData error for express-fileupload@^1.1.6 Response timeout while trying to fetch https://registry.npmjs.org/express-fileupload (over 30000ms)
    834 silly fetchPackageMetaData error for express-session@^1.17.1 Response timeout while trying to fetch https://registry.npmjs.org/express-session (over 30000ms)
    835 http fetch GET 200 https://registry.npmjs.org/express-fileupload 33471ms
    836 http fetch GET 200 https://registry.npmjs.org/express-session 33747ms
    837 http fetch GET 200 https://registry.npmjs.org/cookie 30589ms
    838 http fetch GET 200 https://registry.npmjs.org/cookie/-/cookie-0.4.0.tgz 109ms
    839 silly pacote version manifest for cookie@0.4.0 fetched in 30709ms
    840 http fetch GET 200 https://registry.npmjs.org/depd/-/depd-1.1.2.tgz 32975ms
    841 silly pacote range manifest for depd@~1.1.2 fetched in 35435ms
    842 http fetch GET 200 https://registry.npmjs.org/proxy-addr 17746ms
    843 http fetch GET 200 https://registry.npmjs.org/proxy-addr/-/proxy-addr-2.0.6.tgz 129ms
    844 silly pacote range manifest for proxy-addr@~2.0.5 fetched in 17890ms
    845 http fetch GET 200 https://registry.npmjs.org/forwarded 84ms
    846 http fetch GET 200 https://registry.npmjs.org/forwarded/-/forwarded-0.1.2.tgz 80ms
    847 silly pacote range manifest for forwarded@~0.1.2 fetched in 176ms
    848 http fetch GET 200 https://registry.npmjs.org/ipaddr.js 209ms
    849 http fetch GET 200 https://registry.npmjs.org/ipaddr.js/-/ipaddr.js-1.9.1.tgz 123ms
    850 silly pacote version manifest for ipaddr.js@1.9.1 fetched in 344ms
    851 silly pacote tag manifest for iobroker.admin@stable fetched in 20ms
    852 silly resolveWithNewModule iobroker.admin@4.0.10 checking installable status
    853 silly pacote tag manifest for iobroker.js-controller@stable fetched in 22ms
    854 silly resolveWithNewModule iobroker.js-controller@2.2.9 checking installable status
    855 http fetch GET 304 https://registry.npmjs.org/iobroker.discovery 110ms (from cache)
    856 silly fetchPackageMetaData error for iobroker.discovery@stable Unexpected end of JSON input while parsing near '...all":"https://registr'
    857 http fetch GET 304 https://registry.npmjs.org/iobroker.info 112ms (from cache)
    858 silly fetchPackageMetaData error for iobroker.info@stable Unexpected end of JSON input while parsing near '...a\nlnA+mVwSqD72a1Wh5l'
    859 timing stage:rollbackFailedOptional Completed in 0ms
    860 timing stage:runTopLevelLifecycles Completed in 223076ms
    @Kruech sagte in Fehler bei der Installation von ioBroker:
    npmjs.org
    So oft wie ich in den letzten Tagen korrupte json Files gesehen habe vermute ich, dass es irgendwo auf npmjs.org klemmt.
    [Edit:] BINGO!
    https://status.npmjs.org/
    Monitoring - We began investigating an issue with the npmjs.com website a short time ago, quickly identified the issue and we are monitoring a fix we have deployed.
    May 29, 06:10 UTC
      Kruech
      Alles klar, dann vielen Dank erstmal, dann bin ich beruhigt das es nicht an mir liegt und dann hilft wohl nur Tee trinken.
        Kruech
        So trotz das bei https://status.npmjs.org/ wieder alles grün ist habe ich immer noch die gleichen Probleme. Hat jemand ne weitere Idee?
        • K Kruech
          @Kruech
          Zuerst musst du mal schauen, ob node sauber installiert ist:
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v
          Dann als user, der auch die Installation durchführt:
          npm cache clean --force
          Und dann nochmal den Installer anhauen.
          curl -sL https://iobroker.net/install.sh | bash -
            Kruech
            schrieb am zuletzt editiert von Kruech
            @Thomas-Braun
            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v
            /usr/bin/nodejs
            v10.20.1
            /usr/bin/node
            v10.20.1
            /usr/bin/npm
            6.14.4
            Cache clean und neu installiert habe ich auch schon probiert. Trotzdem immer
            library: loaded
            Library version=2020-04-12
                Welcome to the ioBroker installer!
                Installer version: 2020-04-12
                You might need to enter your password a couple of times.
                Installing prerequisites (1/4)
            OK:1 http://archive.raspberrypi.org/debian buster InRelease
            OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:3 https://deb.nodesource.com/node_10.x buster InRelease
            Changing npm registry to https://registry.npmjs.org
            Installed gcc-c++
                Creating ioBroker user and directory (2/4)
            Directory /opt/iobroker created
                Installing ioBroker (3/4)
            npm ERR! Unexpected end of JSON input while parsing near '...sk":"^1.0.6","@iobrok'
            npm ERR!     /home/pi/.npm/_logs/2020-06-02T18_53_21_120Z-debug.log
                Finalizing installation (4/4)
            Enabling autostart...
            Autostart enabled!
              Kruech
              in der log-Datei von der IoBroker installation hab ich immer paar mal nen timeout.
              1051 silly fetchPackageMetaData error for engine.io@~3.4.0 Response timeout while trying to fetch https://registry.npmjs.org/engine.io (over 30000ms)
              es sind aber nicht immer die gleichen Pakete.
              • K Kruech
                npm install npm@latest -g
                  Kruech
                  Ich geh kaputt. jetzt hat das wenigstens schon mal soweit geklappt des der IoBroker installiert wurde und ich per Browser drauf komme.
                  Es sind sehr viele "warnings" bei der Installation aufgelaufen.
                  In file included from ../src/main.cpp:3:
                  ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                  ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                       , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                  In file included from ../../nan/nan.h:56,
                  ../src/main.cpp: At global scope:
                  /home/pi/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                         (node::addon_register_func) (regfunc),                          \
                  /home/pi/.cache/node-gyp/10.20.1/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
                     NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(diskusage, Init)
                  In file included from /home/pi/.cache/node-gyp/10.20.1/include/node/node.h:63,
                  /home/pi/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                  /home/pi/.cache/node-gyp/10.20.1/include/node/node_object_wrap.h:84:78:   required from here
                  /home/pi/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                  reinterpret_cast<Callback>(callback), type);
                  /home/pi/.cache/node-gyp/10.20.1/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
                  ../../nan/nan_object_wrap.h:65:61:   required from here
                  /home/pi/.cache/node-gyp/10.20.1/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                  In file included from ../src/unix_dgram.cc:5:
                  ../src/unix_dgram.cc: At global scope:
                  ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(unix_dgram, Initialize)
                  In file included from ../src/./serialport.h:6,
                                   from ../src/serialport.cpp:1:
                  ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                  ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’}  -Wcast-function-type]
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
                  ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
                  ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                     uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
                  ../src/serialport.cpp: At global scope:
                  ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
                   SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                  ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
                   SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
                  In file included from ../../../nan/nan.h:56,
                  /home/pi/.cache/node-gyp/10.20.1/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                  ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
                   NODE_MODULE(serialport, init);
                  ../../../nan/nan_object_wrap.h:65:61:   required from here
                  In file included from ../src/serialport.h:6,
                                   from ../src/serialport_unix.cpp:2:
                  ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                  ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                       snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
                  ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                  ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                  ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                       snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
                  ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                  In file included from ../src/poller.cpp:1:
                  • K Kruech
                    @Kruech
                    rm -rf /home/pi/.cache/*
                    Und dann würde ich dir eigentlich auch Version 12 von node empfehlen.
                    Zu guter Letzt wirf noch ein
                    iobroker stop
                    iobroker fix
                    hinterher.
                      Kruech
                      @Thomas-Braun
                      Vielen Dank für die Hilfe. Dann werde ich jetzt den ganzen Pi nochmal aufsetzten mit Version 12 damit das sauberer ist als wie jetzt. Ich weis gar nicht mehr was ich jetzt alles rumprobiert habe.
                      • K Kruech
                        @Thomas-Braun
                        @Kruech
                        Wenn es ansonsten läuft...
                        Aber wie du meinst.
                        Der springende Punkt ist bei dir aus irgendwelchen Gründen die Version von npm.
                        Die musst du vor der Installation des ioBrokers (und nach der Installation von nodejs) auf >=6.14.5 bringen.
