  4. Adapter Update probleme
adapter update probleme
33 Beiträge 2 Kommentatoren 3.2k Aufrufe 2 Beobachtet
    Motsche1
    so jetzt aber
    pi@haussteuerung:/home/iobroker$ sudo iobroker upgrade
    [sudo] password for pi:
    Update admin from @4.0.9 to @4.0.10
    host.haussteuerung Adapter "system.adapter.admin.0" is stopped.
    NPM version: 6.14.4
    npm install iobroker.admin@4.0.10 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../src/DeviceINQ.h:17,
    from ../src/linux/BluetoothSerialPort.cc:13:
    ../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../src/linux/BluetoothSerialPort.cc: At global scope:
    ../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void
    void InitAll(Handle<Object> exports) {
    ../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
    ../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’
    rand_r
    ../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token
    ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope
    In file included from ../src/linux/BluetoothSerialPort.cc:12:
    ../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope
    NODE_MODULE(BluetoothSerialPort, InitAll)
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
    (node::addon_register_func) (regfunc),
    ../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’
    make: *** [BluetoothSerialPort.target.mk:117: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2
    gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack at ChildProcess.emit (events.js:310:20)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
    gyp ERR! System Linux 4.4.213-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
    gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
    gyp ERR! node -v v12.16.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! node-bluetooth@1.2.6 install: node-gyp configure build
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the node-bluetooth@1.2.6 install script.
    npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_02_56_335Z-debug.log
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    Adapter "admin" updated
    host.haussteuerung Adapter "system.adapter.admin.0" is started
    Adapter "alarm" is not installed.
    Adapter "alexa2" is up to date.
    Adapter "alpha2" is not installed.
    Adapter "amazon-dash" is not installed.
    Adapter "artnet" is not installed.
    Adapter "asterisk" is not installed.
    Adapter "asuswrt" is not installed.
    Adapter "b-control-em" is not installed.
    Adapter "backitup" is up to date.
    Adapter "beckhoff" is not installed.
    Adapter "benq" is not installed.
    Adapter "binance" is not installed.
    Adapter "ble" is not installed.
    Adapter "bmw" is not installed.
    Adapter "bosesoundtouch" is not installed.
    Adapter "botvac" is not installed.
    Adapter "bring" is not installed.
    Adapter "broadlink2" is up to date.
    Adapter "bsblan" is not installed.
    Adapter "bshb" is not installed.
    Adapter "chromecast" is up to date.
    Adapter "cloud" is up to date.
    Adapter "comfoair" is not installed.
    Adapter "contactid" is not installed.
    Adapter "coronavirus-statistics" is not installed.
    Adapter "countdown" is not installed.
    Adapter "cul" is not installed.
    Adapter "daikin" is not installed.
    Adapter "daswetter" is up to date.
    Adapter "deconz" is not installed.
    Adapter "denon" is not installed.
    Adapter "devices" is not installed.
    Adapter "digitalstrom" is not installed.
    Adapter "discovergy" is not installed.
    Update discovery from @2.2.2 to @2.3.5
    NPM version: 6.14.4
    npm install iobroker.discovery@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
    In file included from ../src/./serialport.h:6,
    from ../src/serialport.cpp:1:
    ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
    SerialPortParity NAN_INLINE(ToParityEnum(const v8::Localv8::String& v8str)) {
    ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
    SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:54,
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
    NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
    ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
    NODE_MODULE(serialport, init);
    In file included from ../src/serialport.h:6,
    from ../src/serialport_unix.cpp:2:
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
    snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
    snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    In file included from ../src/poller.cpp:1:
    rand_r
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_04_23_937Z-debug.log
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    Adapter "discovery" updated
    Adapter "ds18b20" is not installed.
    Adapter "dwd" is not installed.
    Adapter "ebus" is not installed.
    Adapter "egigeozone" is not installed.
    Adapter "ekey" is not installed.
    Adapter "email" is not installed.
    Adapter "emby" is not installed.
    Adapter "energymanager" is not installed.
    Adapter "enet" is not installed.
    Adapter "epson_stylus_px830" is not installed.
    Adapter "exchangerates" is not installed.
    Adapter "fakeroku" is not installed.
    Adapter "fb-checkpresence" is up to date.
    Adapter "feiertage" is not installed.
    Adapter "fhem" is not installed.
    Adapter "find-my-iphone" is not installed.
    Adapter "firetv" is not installed.
    Adapter "flot" is not installed.
    Adapter "foobar2000" is not installed.
    Adapter "fritzbox" is up to date.
    Adapter "fritzdect" is not installed.
    Adapter "fronius" is not installed.
    Adapter "fullcalendar" is not installed.
    Adapter "fullybrowser" is not installed.
    Adapter "g-homa" is not installed.
    Adapter "geofency" is not installed.
    Adapter "gruenbeck" is not installed.
    Update habpanel from @0.3.4 to @0.4.1
    NPM version: 6.14.4
    npm install iobroker.habpanel@0.4.1 --loglevel error --prefix "/opt/iobroker" (System call)
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    ../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    results->Set(Nan::Newv8::String("cts").ToLocalChecked(), Nan::Newv8::Boolean(data->cts));
    In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,
    from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,
    from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here
    bool Set(Local<Value> key, Local<Value> value));
    /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
    declarator attribute((deprecated(message)))
    ../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    results->Set(Nan::Newv8::String("dsr").ToLocalChecked(), Nan::Newv8::Boolean(data->dsr));
    ../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    results->Set(Nan::Newv8::String("dcd").ToLocalChecked(), Nan::Newv8::Boolean(data->dcd));
    ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
    ../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    results->Set(Nan::Newv8::String("baudRate").ToLocalChecked(), Nan::Newv8::Integer(data->baudRate));
    rand_r
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_06_23_278Z-debug.log
    upload [0] habpanel.admin /opt/iobroker/node_modules/iobroker.habpanel/admin/habpanel.png habpanel.png image/png
    upload [1750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/vendor.js vendor/vendor.js application/javascript
    upload [1700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set.list.json assets/icons/smarthome-set.list.json application/json
    upload [1650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/yard-fountain.svg assets/icons/freepik-housethings/yard-fountain.svg image/svg+xml
    upload [1600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/shower-bathroom-tool.svg assets/icons/freepik-housethings/shower-bathroom-tool.svg image/svg+xml
    upload [1550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/livingroom-lamp.svg assets/icons/freepik-housethings/livingroom-lamp.svg image/svg+xml
    upload [1500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/house-building.svg assets/icons/freepik-housethings/house-building.svg image/svg+xml
    upload [1450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/door-design.svg assets/icons/freepik-housethings/door-design.svg image/svg+xml
    upload [1400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/bedroom-stairs-tool.svg assets/icons/freepik-housethings/bedroom-stairs-tool.svg image/svg+xml
    upload [1350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/window-6.svg assets/icons/freepik-household/window-6.svg image/svg+xml
    upload [1300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/sofa-17.svg assets/icons/freepik-household/sofa-17.svg image/svg+xml
    upload [1250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/mixer-2.svg assets/icons/freepik-household/mixer-2.svg image/svg+xml
    upload [1200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/door.svg assets/icons/freepik-household/door.svg image/svg+xml
    upload [1150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/bookshelf.svg assets/icons/freepik-household/bookshelf.svg image/svg+xml
    upload [1100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/synthesizer.svg assets/icons/freepik-gadgets/synthesizer.svg image/svg+xml
    upload [1050] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/cs-mixer.svg assets/icons/freepik-gadgets/cs-mixer.svg image/svg+xml
    upload [1000] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/wind.svg assets/icons/eclipse-smarthome-classic/wind.svg image/svg+xml
    upload [950] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/switch-off.svg assets/icons/eclipse-smarthome-classic/switch-off.svg image/svg+xml
    upload [900] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/slider-30.svg assets/icons/eclipse-smarthome-classic/slider-30.svg image/svg+xml
    upload [850] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/sewerage-20.svg assets/icons/eclipse-smarthome-classic/sewerage-20.svg image/svg+xml
    upload [800] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/qualityofservice.svg assets/icons/eclipse-smarthome-classic/qualityofservice.svg image/svg+xml
    upload [750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_6_3.svg assets/icons/eclipse-smarthome-classic/parents_6_3.svg image/svg+xml
    upload [700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_2_2.svg assets/icons/eclipse-smarthome-classic/parents_2_2.svg image/svg+xml
    upload [650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/man_3.svg assets/icons/eclipse-smarthome-classic/man_3.svg image/svg+xml
    upload [600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/humidity-100.svg assets/icons/eclipse-smarthome-classic/humidity-100.svg image/svg+xml
    upload [550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/garagedoor.svg assets/icons/eclipse-smarthome-classic/garagedoor.svg image/svg+xml
    upload [500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/fire-on.svg assets/icons/eclipse-smarthome-classic/fire-on.svg image/svg+xml
    upload [450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/dimmablelight-40.png assets/icons/eclipse-smarthome-classic/dimmablelight-40.png image/png
    upload [400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/cistern-30.png assets/icons/eclipse-smarthome-classic/cistern-30.png image/png
    upload [350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/boy_4.png assets/icons/eclipse-smarthome-classic/boy_4.png image/png
    upload [300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/battery-90.png assets/icons/eclipse-smarthome-classic/battery-90.png image/png
    upload [250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/sv.po assets/i18n/widgets/sv.po null
    upload [200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/ar.json assets/i18n/widgets/ar.json application/json
    upload [150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/main/en.po assets/i18n/main/en.po null
    upload [100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/it.json assets/i18n/admin/it.json application/json
    upload [90] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/fi.json assets/i18n/admin/fi.json application/json
    upload [80] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/cs.po assets/i18n/admin/cs.po null
    upload [70] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/admin.pot assets/i18n/admin/admin.pot application/vnd.ms-powerpoint
    upload [60] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/slider/slider.widget.js app/widgets/slider/slider.widget.js application/javascript
    upload [50] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/knob/knob.tpl.html app/widgets/knob/knob.tpl.html text/html
    upload [40] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/dummy/dummy.settings.tpl.html app/widgets/dummy/dummy.settings.tpl.html text/html
    upload [30] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/button/button.widget.js app/widgets/button/button.widget.js application/javascript
    upload [20] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.localconfig.controller.js app/settings/settings.localconfig.controller.js application/javascript
    upload [19] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.html app/settings/settings.html text/html
    upload [18] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.controller.js app/settings/settings.controller.js application/javascript
    upload [17] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/translation.service.js app/services/translation.service.js application/javascript
    upload [16] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/speech.service.js app/services/speech.service.js application/javascript
    upload [15] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/services.js app/services/services.js application/javascript
    upload [14] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/persistence.service.js app/services/persistence.service.js application/javascript
    upload [13] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/localfile.service.js app/services/localfile.service.js application/javascript
    upload [12] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/icon.service.js app/services/icon.service.js application/javascript
    upload [11] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/data.service.js app/services/data.service.js application/javascript
    upload [10] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.settings.tpl.html app/menu/menu.settings.tpl.html text/html
    upload [9] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.html app/menu/menu.html text/html
    upload [8] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.controller.js app/menu/menu.controller.js application/javascript
    upload [7] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/drawer.tpl.html app/menu/drawer.tpl.html text/html
    upload [6] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/drawer.controller.js app/menu/drawer.controller.js application/javascript
    upload [5] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/transferwidget.html app/dashboard/transferwidget.html text/html
    upload [4] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.view.html app/dashboard/dashboard.view.html text/html
    upload [3] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.view.controller.js app/dashboard/dashboard.view.controller.js application/javascript
    upload [2] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.edit.html app/dashboard/dashboard.edit.html text/html
    upload [1] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.edit.controller.js app/dashboard/dashboard.edit.controller.js application/javascript
    upload [0] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/app.js app/app.js application/javascript
    Adapter "habpanel" updated
    Adapter "haier" is not installed.
    Adapter "ham" is not installed.
    Adapter "ham-wemo" is not installed.
    Adapter "harmony" is up to date.
    Adapter "heatingcontrol" is not installed.
    Adapter "heytech" is not installed.
    Adapter "hid" is not installed.
    Update history from @1.8.7 to @1.9.6
    NPM version: 6.14.4
    npm install iobroker.history@1.9.6 --loglevel error --prefix "/opt/iobroker" (System call)
    rand_r
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_12_22_131Z-debug.log
    upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/wordsCustom.js wordsCustom.js application/javascript
    upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
    upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
    upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
    upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
    upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
    upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
    Adapter "history" updated
    Adapter "hm-rega" is not installed.
    Adapter "hm-rpc" is not installed.
    Adapter "hmip" is not installed.
    Adapter "homeconnect" is not installed.
    Adapter "homee" is not installed.
    Adapter "homepilot" is not installed.
    Adapter "hp-ilo" is not installed.
    Adapter "hs100" is not installed.
    Adapter "hue" is not installed.
    Adapter "hue-extended" is not installed.
    Adapter "ical" is up to date.
    Adapter "icons-addictive-flavour-png" is not installed.
    Adapter "icons-fatcow-hosting" is not installed.
    Adapter "icons-icons8" is up to date.
    Adapter "icons-material-png" is up to date.
    Adapter "icons-material-svg" is not installed.
    Adapter "icons-mfd-png" is up to date.
    Adapter "icons-mfd-svg" is up to date.
    Adapter "icons-open-icon-library-png" is not installed.
    Adapter "icons-ultimate-png" is up to date.
    Adapter "influxdb" is not installed.
    Adapter "info" is not installed.
    Adapter "innogy-smarthome" is not installed.
    Adapter "iogo" is not installed.
    Update iot from @1.4.14 to @1.4.18
    host.haussteuerung Adapter "system.adapter.iot.0" is stopped.
    NPM version: 6.14.4
    npm install iobroker.iot@1.4.18 --loglevel error --prefix "/opt/iobroker" (System call)
    rand_r
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_13_37_804Z-debug.log
    upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js.map static/js/runtime-main.814e5fd0.js.map application/json
    upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js static/js/runtime-main.814e5fd0.js application/javascript
    upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.808a09ba.chunk.js.map static/js/main.808a09ba.chunk.js.map application/json
    upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.808a09ba.chunk.js static/js/main.808a09ba.chunk.js application/javascript
    upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.19f19876.chunk.js.map static/js/2.19f19876.chunk.js.map application/json
    upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.19f19876.chunk.js.LICENSE.txt static/js/2.19f19876.chunk.js.LICENSE.txt text/plain
    upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.19f19876.chunk.js static/js/2.19f19876.chunk.js application/javascript
    upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
    upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
    upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css.map static/css/2.b1b16afe.chunk.css.map application/json
    upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css static/css/2.b1b16afe.chunk.css text/css
    upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
    upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.437977870155d308fb2cb10b306e4aed.js precache-manifest.437977870155d308fb2cb10b306e4aed.js application/javascript
    upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
    upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
    upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
    upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
    upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
    upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
    upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
    Adapter "iot" updated
    host.haussteuerung Adapter "system.adapter.iot.0" is started
    Adapter "iqontrol" is not installed.
    Update javascript from @4.3.4 to @4.5.1
    NPM version: 6.14.4
    npm install iobroker.javascript@4.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
    rand_r
    gyp ERR! not ok
    npm ERR! errno 1
    npm ERR!
    npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_14_55_352Z-debug.log
    upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/powershell/powershell.js vs/basic-languages/powershell/powershell.js application/javascript
    upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/java/java.js vs/basic-languages/java/java.js application/javascript
    upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/cpp/cpp.js vs/basic-languages/cpp/cpp.js application/javascript
    upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.320f2344.chunk.js.LICENSE.txt static/js/main.320f2344.chunk.js.LICENSE.txt text/plain
    upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/precache-manifest.53aabff70ba6fd6a56045658a4c06c3b.js precache-manifest.53aabff70ba6fd6a56045658a4c06c3b.js application/javascript
    upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
    upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
    upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
    upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
    upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
    upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
    upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
    upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
    upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
    upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
    upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
    upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
    upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
    upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
    upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
    upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
    upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
    upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
    upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
    upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
    upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
    upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
    upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
    upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
    Adapter "javascript" updated
    Adapter "jeelink" is not installed.
    Adapter "kecontact" is not installed.
    Adapter "klf200" is not installed.
    Adapter "km200" is not installed.
    Adapter "knmi-weather" is not installed.
    Adapter "knx" is not installed.
    Adapter "kodi" is up to date.
    Adapter "kress" is not installed.
    Adapter "lametric" is not installed.
    Adapter "landroid" is not installed.
      Motsche1
      Adapter "lcn" is not installed.
      Adapter "lgtv" is not installed.
      Adapter "lgtv-rs" is not installed.
      Adapter "lgtv11" is not installed.
      Adapter "lifx" is not installed.
      Adapter "lightify" is not installed.
      Adapter "link" is not installed.
      Adapter "linkeddevices" is not installed.
      Update lovelace from @0.2.3 to @1.0.16
      NPM version: 6.14.4
      npm install iobroker.lovelace@1.0.16 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_18_12_319Z-debug.log
      upload [5] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/words.js words.js application/javascript
      upload [4] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/style.css style.css text/css
      upload [3] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/lovelace.png lovelace.png image/png
      upload [2] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/js-yaml.min.js js-yaml.min.js application/javascript
      upload [1] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/index_m.html index_m.html text/html
      upload [0] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/custom_m.html custom_m.html text/html
      Adapter "lovelace" updated
      Adapter "loxone" is not installed.
      Adapter "luftdaten" is not installed.
      Adapter "lupusec" is not installed.
      Adapter "luxtronik1" is not installed.
      Update material from @0.12.1 to @0.13.8
      NPM version: 6.14.4
      npm install iobroker.material@0.13.8 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_19_23_058Z-debug.log
      upload [1] material.admin /opt/iobroker/node_modules/iobroker.material/admin/material.svg material.svg image/svg+xml
      upload [0] material.admin /opt/iobroker/node_modules/iobroker.material/admin/material.png material.png image/png
      upload [60] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-Thin.ttf vendor/fonts/Roboto-Thin.ttf font/ttf
      upload [50] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-BoldItalic.ttf vendor/fonts/Roboto-BoldItalic.ttf font/ttf
      upload [40] material /opt/iobroker/node_modules/iobroker.material/www/static/media/roboto-latin-900.9b3766ef.woff2 static/media/roboto-latin-900.9b3766ef.woff2 font/woff2
      upload [30] material /opt/iobroker/node_modules/iobroker.material/www/static/media/roboto-latin-400italic.51521a2a.woff2 static/media/roboto-latin-400italic.51521a2a.woff2 font/woff2
      upload [20] material /opt/iobroker/node_modules/iobroker.material/www/static/media/roboto-latin-100.5cb7edfc.woff static/media/roboto-latin-100.5cb7edfc.woff font/woff
      upload [19] material /opt/iobroker/node_modules/iobroker.material/www/static/media/rgb.5d0e5ef3.png static/media/rgb.5d0e5ef3.png image/png
      upload [18] material /opt/iobroker/node_modules/iobroker.material/www/static/media/apartment.28bae16c.jpg static/media/apartment.28bae16c.jpg image/jpeg
      upload [17] material /opt/iobroker/node_modules/iobroker.material/www/static/js/runtime-main.28bbd470.js.map static/js/runtime-main.28bbd470.js.map application/json
      upload [16] material /opt/iobroker/node_modules/iobroker.material/www/static/js/runtime-main.28bbd470.js static/js/runtime-main.28bbd470.js application/javascript
      upload [15] material /opt/iobroker/node_modules/iobroker.material/www/static/js/main.416e9219.chunk.js.map static/js/main.416e9219.chunk.js.map application/json
      upload [14] material /opt/iobroker/node_modules/iobroker.material/www/static/js/main.416e9219.chunk.js static/js/main.416e9219.chunk.js application/javascript
      upload [13] material /opt/iobroker/node_modules/iobroker.material/www/static/js/2.4ead899c.chunk.js.map static/js/2.4ead899c.chunk.js.map application/json
      upload [12] material /opt/iobroker/node_modules/iobroker.material/www/static/js/2.4ead899c.chunk.js.LICENSE.txt static/js/2.4ead899c.chunk.js.LICENSE.txt text/plain
      upload [11] material /opt/iobroker/node_modules/iobroker.material/www/static/js/2.4ead899c.chunk.js static/js/2.4ead899c.chunk.js application/javascript
      upload [10] material /opt/iobroker/node_modules/iobroker.material/www/static/css/main.bf8ff6b7.chunk.css.map static/css/main.bf8ff6b7.chunk.css.map application/json
      upload [9] material /opt/iobroker/node_modules/iobroker.material/www/static/css/main.bf8ff6b7.chunk.css static/css/main.bf8ff6b7.chunk.css text/css
      upload [8] material /opt/iobroker/node_modules/iobroker.material/www/static/css/2.8c32401a.chunk.css.map static/css/2.8c32401a.chunk.css.map application/json
      upload [7] material /opt/iobroker/node_modules/iobroker.material/www/static/css/2.8c32401a.chunk.css static/css/2.8c32401a.chunk.css text/css
      upload [6] material /opt/iobroker/node_modules/iobroker.material/www/service-worker.js service-worker.js application/javascript
      upload [5] material /opt/iobroker/node_modules/iobroker.material/www/precache-manifest.653e0604b7a9eb0f1afaee23754aec4b.js precache-manifest.653e0604b7a9eb0f1afaee23754aec4b.js application/javascript
      upload [4] material /opt/iobroker/node_modules/iobroker.material/www/manifest.json manifest.json application/json
      upload [3] material /opt/iobroker/node_modules/iobroker.material/www/iob.css iob.css text/css
      upload [2] material /opt/iobroker/node_modules/iobroker.material/www/index.html index.html text/html
      upload [1] material /opt/iobroker/node_modules/iobroker.material/www/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [0] material /opt/iobroker/node_modules/iobroker.material/www/asset-manifest.json asset-manifest.json application/json
      Adapter "material" updated
      Adapter "maxcube" is not installed.
      Adapter "maxcul" is not installed.
      Adapter "mbus" is not installed.
      Adapter "mclighting" is not installed.
      Adapter "megad" is not installed.
      Adapter "megadd" is not installed.
      Adapter "megaesp" is not installed.
      Adapter "mercedesme" is not installed.
      Adapter "mercury" is not installed.
      Adapter "meross" is not installed.
      Adapter "meteoalarm" is not installed.
      Adapter "miele" is not installed.
      Adapter "mielecloudservice" is not installed.
      Adapter "mihome" is not installed.
      Adapter "mihome-lamp" is not installed.
      Adapter "mihome-plug" is not installed.
      Adapter "mihome-vacuum" is not installed.
      Adapter "mikrotik" is not installed.
      Adapter "milight" is not installed.
      Adapter "milight-smart-light" is not installed.
      Adapter "mobile" is up to date.
      Adapter "modbus" is not installed.
      Adapter "moma" is not installed.
      Adapter "mpd" is not installed.
      Adapter "mqtt" is not installed.
      Adapter "mqtt-client" is not installed.
      Adapter "musiccast" is not installed.
      Adapter "mysensors" is not installed.
      Adapter "nanoleaf-lightpanels" is not installed.
      Adapter "nello" is not installed.
      Adapter "netatmo" is not installed.
      Adapter "nibeuplink" is not installed.
      Adapter "nina" is not installed.
      Adapter "node-red" is not installed.
      Adapter "nuki" is not installed.
      Adapter "nuki-extended" is not installed.
      Adapter "nut" is not installed.
      Adapter "odl" is not installed.
      Adapter "oilfox" is up to date.
      Adapter "onkyo" is not installed.
      Adapter "onvif" is not installed.
      Adapter "openhab" is not installed.
      Adapter "openligadb" is not installed.
      Adapter "openweathermap" is not installed.
      Adapter "opi" is not installed.
      Adapter "oppoplayer" is not installed.
      Adapter "owfs" is not installed.
      Adapter "owntracks" is not installed.
      Adapter "panasonic-viera" is not installed.
      Adapter "parser" is up to date.
      Adapter "paw" is not installed.
      Adapter "phantomjs" is not installed.
      Adapter "pi-hole" is not installed.
      Adapter "piface" is not installed.
      Adapter "pimatic" is not installed.
      Update ping from @1.3.2 to @1.4.7
      NPM version: 6.14.4
      npm install iobroker.ping@1.4.7 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_21_09_698Z-debug.log
      upload [3] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
      upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
      upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index_m.html index_m.html text/html
      upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html
      Adapter "ping" updated
      Adapter "places" is not installed.
      Adapter "plex" is not installed.
      Adapter "plexconnect" is not installed.
      Adapter "pollenflug" is not installed.
      Adapter "proxmox" is not installed.
      Adapter "proxy" is not installed.
      Adapter "pushbullet" is not installed.
      Adapter "pushover" is not installed.
      Adapter "pushsafer" is not installed.
      Adapter "radar2" is up to date.
      Adapter "radiohead" is not installed.
      Adapter "rflink" is not installed.
      Adapter "rickshaw" is not installed.
      Adapter "ring" is not installed.
      Adapter "robonect" is not installed.
      Adapter "roomba" is not installed.
      Adapter "rpi2" is not installed.
      Adapter "s7" is not installed.
      Adapter "samsung" is up to date.
      Update sayit from @1.8.2 to @1.9.4
      host.haussteuerung Adapter "system.adapter.sayit.0" is stopped.
      NPM version: 6.14.4
      npm install iobroker.sayit@1.9.4 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_21_53_352Z-debug.log
      upload [5] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/words.js words.js application/javascript
      upload [4] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/sayit.png sayit.png image/png
      upload [3] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/index_m.html index_m.html text/html
      upload [2] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/index.html index.html text/html
      upload [1] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/engines.js engines.js application/javascript
      upload [0] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/blockly.js blockly.js application/javascript
      Adapter "sayit" updated
      host.haussteuerung Adapter "system.adapter.sayit.0" is started
      Adapter "sbfspot" is not installed.
      Adapter "scenes" is up to date.
      Adapter "schoolfree" is not installed.
      Adapter "shelly" is not installed.
      Adapter "shuttercontrol" is not installed.
      Adapter "sia" is not installed.
      Adapter "siegenia" is not installed.
      Update simple-api from @2.3.2 to @2.4.5
      NPM version: 6.14.4
      npm install iobroker.simple-api@2.4.5 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_23_12_240Z-debug.log
      upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
      upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
      upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
      upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
      Adapter "simple-api" updated
      Adapter "smappee" is not installed.
      Adapter "smartmeter" is not installed.
      Adapter "snips" is not installed.
      Adapter "snmp" is not installed.
      Update socketio from @3.0.6 to @3.0.7
      NPM version: 6.14.4
      npm install iobroker.socketio@3.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_23_53_003Z-debug.log
      upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
      upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
      upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
      upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
      Adapter "socketio" updated
      Adapter "solarlog" is not installed.
      Adapter "solarwetter" is not installed.
      Adapter "sonnen" is not installed.
      Adapter "sonoff" is up to date.
      Adapter "sonos" is not installed.
      Adapter "sony-bravia" is not installed.
      Adapter "spotify-premium" is not installed.
      Adapter "sql" is not installed.
      Adapter "squeezebox" is not installed.
      Adapter "squeezeboxrpc" is not installed.
      Adapter "starline" is not installed.
      Adapter "statistics" is not installed.
      Adapter "stiebel-isg" is not installed.
      Adapter "sunnyportal" is not installed.
      Adapter "swiss-weather-api" is not installed.
      Adapter "systeminfo" is up to date.
      Adapter "tahoma" is not installed.
      Adapter "tankerkoenig" is up to date.
      Adapter "telegram" is not installed.
      Adapter "terminal" is not installed.
      Adapter "tesla-motors" is not installed.
      Adapter "text2command" is not installed.
      Adapter "tr-064" is not installed.
      Adapter "tradfri" is not installed.
      Adapter "trashschedule" is not installed.
      Adapter "tunnelbroker-endpoint-updater" is not installed.
      Adapter "tuya" is not installed.
      Adapter "tvspielfilm" is up to date.
      Adapter "unifi" is not installed.
      Update upnp from @1.0.11 to @1.0.16
      NPM version: 6.14.4
      npm install iobroker.upnp@1.0.16 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_24_32_721Z-debug.log
      upload [13] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/words.js words.js application/javascript
      upload [12] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/upnp.png upnp.png image/png
      upload [11] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/index_m.html index_m.html text/html
      upload [10] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [9] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [8] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [7] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [4] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [3] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [2] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [1] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [0] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/custom_m.html custom_m.html text/html
      Adapter "upnp" updated
      Adapter "vaillant" is not installed.
      Adapter "valloxmv" is not installed.
      Adapter "vcard" is not installed.
      Adapter "velux" is not installed.
      Adapter "viessmann" is up to date.
      Adapter "virtualpowermeter" is not installed.
      Adapter "vis" is up to date.
      Adapter "vis-bars" is up to date.
      Adapter "vis-canvas-gauges" is not installed.
      Adapter "vis-colorpicker" is up to date.
      Adapter "vis-fancyswitch" is not installed.
      Adapter "vis-google-fonts" is not installed.
      Adapter "vis-history" is not installed.
      Adapter "vis-hqwidgets" is up to date.
      Adapter "vis-inventwo" is not installed.
      Adapter "vis-jqui-mfd" is not installed.
      Adapter "vis-justgage" is not installed.
      Adapter "vis-keyboard" is not installed.
      Adapter "vis-lcars" is up to date.
      Adapter "vis-map" is not installed.
      Adapter "vis-metro" is up to date.
      Adapter "vis-players" is up to date.
      Adapter "vis-plumb" is not installed.
      Adapter "vis-rgraph" is not installed.
      Adapter "vis-timeandweather" is up to date.
      Adapter "vis-weather" is up to date.
      Adapter "vr200" is not installed.
      Adapter "vw-connect" is not installed.
      Adapter "weatherunderground" is not installed.
      Update web from @3.0.7 to @3.0.8
      host.haussteuerung Adapter "system.adapter.web.0" is stopped.
      NPM version: 6.14.4
      npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_25_35_601Z-debug.log
      upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
      upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
      upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
      upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
      upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
      upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
      upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
      upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
      upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
      upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
      upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
      upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
      upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
      upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
      upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
      upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
      upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
      upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
      upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
      upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
      upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
      upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
      upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
      upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
      upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
      upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
      upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
      upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
      upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
      upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
      upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
      upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
      upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
      upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
      upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
      upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
      upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
      upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
      Adapter "web" updated
      host.haussteuerung Adapter "system.adapter.web.0" is started
      Adapter "weishaupt-wem" is not installed.
      Adapter "wiffi-wz" is not installed.
      Update wifilight from @0.2.0 to @1.1.0
      NPM version: 6.14.4
      npm install iobroker.wifilight@1.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
      rand_r
      gyp ERR! not ok
      npm ERR! errno 1
      npm ERR!
      npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_27_13_155Z-debug.log
      upload [12] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/words.js words.js application/javascript
      upload [11] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/wifilight.png wifilight.png image/png
      upload [10] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/index.html index.html text/html
      upload [9] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [8] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [7] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [6] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [5] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [4] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [3] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [2] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [1] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [0] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/de/translations.json i18n/de/translations.json application/json
      Adapter "wifilight" updated
      Adapter "windows-control" is not installed.
      Adapter "wled" is up to date.
      Adapter "wm-bus" is not installed.
      Adapter "wolf" is not installed.
      Adapter "worx" is not installed.
      Adapter "xbox" is not installed.
      Adapter "xs1" is not installed.
      Adapter "yahka" is not installed.
      Adapter "yamaha" is not installed.
      Adapter "yeelight-2" is not installed.
      Adapter "youtube" is not installed.
      Adapter "yr" is not installed.
      Adapter "zigbee" is not installed.
      Adapter "zont" is not installed.
      Adapter "zwave" is not installed.
      pi@haussteuerung:/home/iobroker$
      musste es teilen war zu viel
      • M Motsche1
        NPM version: 6.14.4
        In file included from ../src/DeviceINQ.h:17,
        from ../src/linux/BluetoothSerialPort.cc:13:
        ../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
        ../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
        , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        ../src/linux/BluetoothSerialPort.cc: At global scope:
        ../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void
        void InitAll(Handle<Object> exports) {
        ../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
        ../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’
        rand_r
        ../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token
        ../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope
        In file included from ../src/linux/BluetoothSerialPort.cc:12:
        ../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope
        NODE_MODULE(BluetoothSerialPort, InitAll)
        /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
        (node::addon_register_func) (regfunc),
        ../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’
        make: *** [BluetoothSerialPort.target.mk:117: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
        gyp ERR! build error
        gyp ERR! stack Error: make failed with exit code: 2
        gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack at ChildProcess.emit (events.js:310:20)
        gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
        gyp ERR! System Linux 4.4.213-rockchip64
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
        gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
        gyp ERR! node -v v12.16.3
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! node-bluetooth@1.2.6 install: node-gyp configure build
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the node-bluetooth@1.2.6 install script.
        NPM version: 6.14.4
        rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        NPM version: 6.14.4
        rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        NPM version: 6.14.4
        rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        NPM version: 6.14.4
        rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        NPM version: 6.14.4
        rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        NPM version: 6.14.4
        rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        NPM version: 6.14.4
        rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        NPM version: 6.14.4
        rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        @Motsche1 Von sudo hatte ich nichts geschrieben!
          Motsche1
          als pi user gehts nur so
          soll ich es also root machen
          • M Motsche1
            @Motsche1 Nein.
            Als user:
            groups
              Motsche1
              ups geht ja doch
              • M Motsche1
                ups geht ja doch
                @Motsche1
                'root' wird gar nicht benutzt und sudo nur dann wenn es notwendig ist.
                • M Motsche1
                  ups geht ja doch
                  @Motsche1 Versuch mal
                  cd /opt/iobroker
                    Motsche1
                    pi@haussteuerung:~$ node-gyp configure build
                    Command 'node-gyp' not found, but can be installed with:
                    sudo apt install node-gyp
                    • M Motsche1
                      @Motsche1
                      lsb_release -a
                      nodejs -v && node -v && npm -v
                      which nodejs && which node && which npm
                        Motsche1
                        pi@haussteuerung:~$ sudo apt install node-gyp
                        Reading package lists... Done
                        Building dependency tree
                        Some packages could not be installed. This may mean that you have
                        requested an impossible situation or if you are using the unstable
                        distribution that some required packages have not yet been created
                        or been moved out of Incoming.
                        The following information may help to resolve the situation:
                        The following packages have unmet dependencies:
                         node-gyp : Depends: libnode-dev but it is not going to be installed
                        E: Unable to correct problems, you have held broken packages.
                        • M Motsche1
                          @Motsche1 Hatte ich gesagt, dass du das installieren sollst?
                          Tu doch bitte was dir gesagt wird und mach keinen Kram nebenher.
                            Motsche1
                            pi@haussteuerung:~$ cd /home/iobroker
                            pi@haussteuerung:/home/iobroker$ lsb_release -a
                            No LSB modules are available.
                            Distributor ID: Debian
                            Description:    Debian GNU/Linux 10 (buster)
                            Release:        10
                            Codename:       buster
                            pi@haussteuerung:/home/iobroker$ nodejs -v && node -v && npm -v
                            v12.16.3
                            v12.16.3
                            6.14.4
                            pi@haussteuerung:/home/iobroker$ which nodejs && which node && which npm
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            • M Motsche1
                              Release:        10
                              Codename:       buster
                              v12.16.3
                              v12.16.3
                              6.14.4
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              @Motsche1
                              sudo apt update
                              apt policy nodejs
                              sudo apt install nodejs --reinstall
                                Motsche1
                                brauchst da auch die ausgaben?
                                • M Motsche1
                                  @Motsche1 Nee, ich habe 'ne Glaskugel... :-D
                                    Motsche1
                                    Ach ECHT 😳
                                    • M Motsche1
                                      Ach ECHT 😳
                                      @Motsche1 Ja, die ist allerdings gerade in der Spülmaschine. Musste halt doch die Ausgaben hier posten.
                                        Motsche1
                                        pi@haussteuerung:/home/iobroker$ sudo apt update
                                        [sudo] password for pi:
                                        Get:1 file:/var/cache/openmediavault/archives  InRelease
                                        Ign:1 file:/var/cache/openmediavault/archives  InRelease
                                        Get:2 file:/var/cache/openmediavault/archives  Release
                                        Ign:2 file:/var/cache/openmediavault/archives  Release
                                        Get:3 file:/var/cache/openmediavault/archives  Packages
                                        Ign:3 file:/var/cache/openmediavault/archives  Packages
                                        Get:4 file:/var/cache/openmediavault/archives  Contents (deb)
                                        Ign:4 file:/var/cache/openmediavault/archives  Contents (deb)
                                        Get:5 file:/var/cache/openmediavault/archives  Contents (deb)
                                        Ign:5 file:/var/cache/openmediavault/archives  Contents (deb)
                                        Get:6 file:/var/cache/openmediavault/archives  Contents (deb)
                                        Ign:6 file:/var/cache/openmediavault/archives  Contents (deb)
                                        Hit:7 http://security.debian.org buster/updates InRelease
                                        Hit:8 http://httpredir.debian.org/debian buster InRelease
                                        Hit:9 http://packages.openmediavault.org/public usul InRelease
                                        Hit:10 http://linux.teamviewer.com/deb stable InRelease
                                        Hit:11 http://download.virtualbox.org/virtualbox/debian buster InRelease
                                        Hit:12 http://packages.openmediavault.org/public usul-proposed InRelease
                                        Get:13 http://httpredir.debian.org/debian buster-updates InRelease [49.3 kB]
                                        Hit:14 https://download.docker.com/linux/debian buster InRelease
                                        Hit:16 https://openmediavault.github.io/packages usul InRelease
                                        Get:17 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
                                        Hit:18 https://deb.nodesource.com/node_12.x buster InRelease
                                        Ign:19 https://dl.bintray.com/openmediavault-plugin-developers/usul buster InRelease
                                        Ign:20 https://dl.bintray.com/openmediavault-plugin-developers/usul-testing buster InRelease
                                        Ign:21 https://dl.bintray.com/openmediavault-plugin-developers/usul-extras buster InRelease
                                        Get:22 https://dl.bintray.com/openmediavault-plugin-developers/usul buster Release [4363 B]
                                        Get:23 https://dl.bintray.com/openmediavault-plugin-developers/usul-testing buster Release [3538 B]
                                        Get:24 https://dl.bintray.com/openmediavault-plugin-developers/usul-extras buster Release [3538 B]
                                        Hit:15 https://apt.armbian.com buster InRelease
                                        Get:25 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
                                        Get:26 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
                                        Get:27 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
                                        Get:28 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
                                        Get:29 http://httpredir.debian.org/debian buster-backports/main arm64 Packages 2020-05-22-1409.45.pdiff [390 B]
                                        Get:30 http://httpredir.debian.org/debian buster-backports/main armhf Packages 2020-05-22-1409.45.pdiff [394 B]
                                        Get:31 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) 2020-05-22-1409.45.pdiff [101 B]
                                        Get:32 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) 2020-05-22-1409.45.pdiff [100 B]
                                        Fetched 220 kB in 7s (30.7 kB/s)
                                        All packages are up to date.
                                        N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://linux.teamviewer.com/deb stable InRelease' doesn't support architecture 'arm64'
                                        N: Skipping acquire of configured file 'contrib/binary-armhf/Packages' as repository 'http://download.virtualbox.org/virtualbox/debian buster InRelease' doesn't support architecture 'armhf'
                                        N: Skipping acquire of configured file 'contrib/binary-arm64/Packages' as repository 'http://download.virtualbox.org/virtualbox/debian buster InRelease' doesn't support architecture 'arm64'
                                        pi@haussteuerung:/home/iobroker$ apt policy nodejs
                                        nodejs:
                                          Installed: 12.16.3-1nodesource1
                                          Candidate: 12.16.3-1nodesource1
                                          Version table:
                                         *** 12.16.3-1nodesource1 500
                                                500 https://deb.nodesource.com/node_12.x buster/main arm64 Packages
                                             10.19.0~dfsg1-1 500
                                                500 http://httpredir.debian.org/debian buster/main arm64 Packages
                                                500 http://security.debian.org buster/updates/main arm64 Packages
                                        pi@haussteuerung:/home/iobroker$ sudo apt install nodejs --reinstall
                                        0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
                                        Need to get 0 B/17.2 MB of archives.
                                        After this operation, 0 B of additional disk space will be used.
                                        (Reading database ... 74383 files and directories currently installed.)
                                        Preparing to unpack .../nodejs_12.16.3-1nodesource1_arm64.deb ...
                                        Detected old npm client, removing...
                                        Unpacking nodejs (12.16.3-1nodesource1) over (12.16.3-1nodesource1) ...
                                        Setting up nodejs (12.16.3-1nodesource1) ...
                                        Processing triggers for man-db (2.8.5-2) ...
                                        • M Motsche1
                                          nodejs:
                                            Version table:
                                               10.19.0~dfsg1-1 500
                                          @Motsche1
                                          Bei der Gemischtwarenladen an Repos bin ich raus. Das kannste nicht mehr warten.
                                          Da spukt auch noch irgendein Kram von armbian drin rum, das passt aber ganz garantiert nicht zu deinem Raspberry. Ist doch ein Pi, oder?
