- ioBroker Community Home
- Deutsch
- ioBroker Allgemein
- Adapter Update probleme
@Motsche1 Kannst Spoiler setzen.
iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh -
so jetzt aber
pi@haussteuerung:/home/iobroker$ sudo iobroker upgrade
[sudo] password for pi:
Update admin from @4.0.9 to @4.0.10
host.haussteuerung Adapter "system.adapter.admin.0" is stopped.
NPM version: 6.14.4
npm install iobroker.admin@4.0.10 --loglevel error --prefix "/opt/iobroker" (System call)
In file included from ../src/DeviceINQ.h:17,
from ../src/linux/BluetoothSerialPort.cc:13:
../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
, reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
../src/linux/BluetoothSerialPort.cc: At global scope:
../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void
void InitAll(Handle<Object> exports) {
../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’
rand_r
../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token
../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope
In file included from ../src/linux/BluetoothSerialPort.cc:12:
../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope
NODE_MODULE(BluetoothSerialPort, InitAll)
/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
(node::addon_register_func) (regfunc),
../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’
make: *** [BluetoothSerialPort.target.mk:117: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
gyp ERR! build error
gyp ERR! stack Error:makefailed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:310:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
gyp ERR! System Linux 4.4.213-rockchip64
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
gyp ERR! node -v v12.16.3
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-bluetooth@1.2.6 install:node-gyp configure build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-bluetooth@1.2.6 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_02_56_335Z-debug.log
upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
Adapter "admin" updated
host.haussteuerung Adapter "system.adapter.admin.0" is started
Adapter "alarm" is not installed.
Adapter "alexa2" is up to date.
Adapter "alpha2" is not installed.
Adapter "amazon-dash" is not installed.
Adapter "artnet" is not installed.
Adapter "asterisk" is not installed.
Adapter "asuswrt" is not installed.
Adapter "b-control-em" is not installed.
Adapter "backitup" is up to date.
Adapter "beckhoff" is not installed.
Adapter "benq" is not installed.
Adapter "binance" is not installed.
Adapter "ble" is not installed.
Adapter "bmw" is not installed.
Adapter "bosesoundtouch" is not installed.
Adapter "botvac" is not installed.
Adapter "bring" is not installed.
Adapter "broadlink2" is up to date.
Adapter "bsblan" is not installed.
Adapter "bshb" is not installed.
Adapter "chromecast" is up to date.
Adapter "cloud" is up to date.
Adapter "comfoair" is not installed.
Adapter "contactid" is not installed.
Adapter "coronavirus-statistics" is not installed.
Adapter "countdown" is not installed.
Adapter "cul" is not installed.
Adapter "daikin" is not installed.
Adapter "daswetter" is up to date.
Adapter "deconz" is not installed.
Adapter "denon" is not installed.
Adapter "devices" is not installed.
Adapter "digitalstrom" is not installed.
Adapter "discovergy" is not installed.
Update discovery from @2.2.2 to @2.3.5
NPM version: 6.14.4
npm install iobroker.discovery@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
In file included from ../src/./serialport.h:6,
from ../src/serialport.cpp:1:
../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
../src/serialport.cpp: At global scope:
../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
SerialPortParity NAN_INLINE(ToParityEnum(const v8::Localv8::String& v8str)) {
../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
In file included from ../../../nan/nan.h:54,
/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’
NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
NODE_MODULE(serialport, init);
In file included from ../src/serialport.h:6,
from ../src/serialport_unix.cpp:2:
../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
In file included from ../src/poller.cpp:1:
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_04_23_937Z-debug.log
upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
Adapter "discovery" updated
Adapter "ds18b20" is not installed.
Adapter "dwd" is not installed.
Adapter "ebus" is not installed.
Adapter "egigeozone" is not installed.
Adapter "ekey" is not installed.
Adapter "email" is not installed.
Adapter "emby" is not installed.
Adapter "energymanager" is not installed.
Adapter "enet" is not installed.
Adapter "epson_stylus_px830" is not installed.
Adapter "exchangerates" is not installed.
Adapter "fakeroku" is not installed.
Adapter "fb-checkpresence" is up to date.
Adapter "feiertage" is not installed.
Adapter "fhem" is not installed.
Adapter "find-my-iphone" is not installed.
Adapter "firetv" is not installed.
Adapter "flot" is not installed.
Adapter "foobar2000" is not installed.
Adapter "fritzbox" is up to date.
Adapter "fritzdect" is not installed.
Adapter "fronius" is not installed.
Adapter "fullcalendar" is not installed.
Adapter "fullybrowser" is not installed.
Adapter "g-homa" is not installed.
Adapter "geofency" is not installed.
Adapter "gruenbeck" is not installed.
Update habpanel from @0.3.4 to @0.4.1
NPM version: 6.14.4
npm install iobroker.habpanel@0.4.1 --loglevel error --prefix "/opt/iobroker" (System call)
../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
../src/serialport.cpp:329:96: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
results->Set(Nan::Newv8::String("cts").ToLocalChecked(), Nan::Newv8::Boolean(data->cts));
In file included from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8-internal.h:14,
from /home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:27,
from /home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:67,
/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8.h:3499:22: note: declared here
bool Set(Local<Value> key, Local<Value> value));
/home/iobroker/.cache/node-gyp/12.16.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
declarator attribute((deprecated(message)))
../src/serialport.cpp:330:96: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
results->Set(Nan::Newv8::String("dsr").ToLocalChecked(), Nan::Newv8::Boolean(data->dsr));
../src/serialport.cpp:331:96: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
results->Set(Nan::Newv8::String("dcd").ToLocalChecked(), Nan::Newv8::Boolean(data->dcd));
../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
../src/serialport.cpp:378:106: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
results->Set(Nan::Newv8::String("baudRate").ToLocalChecked(), Nan::Newv8::Integer(data->baudRate));
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_06_23_278Z-debug.log
upload [0] habpanel.admin /opt/iobroker/node_modules/iobroker.habpanel/admin/habpanel.png habpanel.png image/png
upload [1750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/vendor/vendor.js vendor/vendor.js application/javascript
upload [1700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/smarthome-set.list.json assets/icons/smarthome-set.list.json application/json
upload [1650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/yard-fountain.svg assets/icons/freepik-housethings/yard-fountain.svg image/svg+xml
upload [1600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/shower-bathroom-tool.svg assets/icons/freepik-housethings/shower-bathroom-tool.svg image/svg+xml
upload [1550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/livingroom-lamp.svg assets/icons/freepik-housethings/livingroom-lamp.svg image/svg+xml
upload [1500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/house-building.svg assets/icons/freepik-housethings/house-building.svg image/svg+xml
upload [1450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/door-design.svg assets/icons/freepik-housethings/door-design.svg image/svg+xml
upload [1400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-housethings/bedroom-stairs-tool.svg assets/icons/freepik-housethings/bedroom-stairs-tool.svg image/svg+xml
upload [1350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/window-6.svg assets/icons/freepik-household/window-6.svg image/svg+xml
upload [1300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/sofa-17.svg assets/icons/freepik-household/sofa-17.svg image/svg+xml
upload [1250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/mixer-2.svg assets/icons/freepik-household/mixer-2.svg image/svg+xml
upload [1200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/door.svg assets/icons/freepik-household/door.svg image/svg+xml
upload [1150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-household/bookshelf.svg assets/icons/freepik-household/bookshelf.svg image/svg+xml
upload [1100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/synthesizer.svg assets/icons/freepik-gadgets/synthesizer.svg image/svg+xml
upload [1050] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/freepik-gadgets/cs-mixer.svg assets/icons/freepik-gadgets/cs-mixer.svg image/svg+xml
upload [1000] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/wind.svg assets/icons/eclipse-smarthome-classic/wind.svg image/svg+xml
upload [950] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/switch-off.svg assets/icons/eclipse-smarthome-classic/switch-off.svg image/svg+xml
upload [900] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/slider-30.svg assets/icons/eclipse-smarthome-classic/slider-30.svg image/svg+xml
upload [850] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/sewerage-20.svg assets/icons/eclipse-smarthome-classic/sewerage-20.svg image/svg+xml
upload [800] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/qualityofservice.svg assets/icons/eclipse-smarthome-classic/qualityofservice.svg image/svg+xml
upload [750] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_6_3.svg assets/icons/eclipse-smarthome-classic/parents_6_3.svg image/svg+xml
upload [700] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/parents_2_2.svg assets/icons/eclipse-smarthome-classic/parents_2_2.svg image/svg+xml
upload [650] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/man_3.svg assets/icons/eclipse-smarthome-classic/man_3.svg image/svg+xml
upload [600] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/humidity-100.svg assets/icons/eclipse-smarthome-classic/humidity-100.svg image/svg+xml
upload [550] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/garagedoor.svg assets/icons/eclipse-smarthome-classic/garagedoor.svg image/svg+xml
upload [500] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/fire-on.svg assets/icons/eclipse-smarthome-classic/fire-on.svg image/svg+xml
upload [450] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/dimmablelight-40.png assets/icons/eclipse-smarthome-classic/dimmablelight-40.png image/png
upload [400] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/cistern-30.png assets/icons/eclipse-smarthome-classic/cistern-30.png image/png
upload [350] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/boy_4.png assets/icons/eclipse-smarthome-classic/boy_4.png image/png
upload [300] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/icons/eclipse-smarthome-classic/battery-90.png assets/icons/eclipse-smarthome-classic/battery-90.png image/png
upload [250] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/sv.po assets/i18n/widgets/sv.po null
upload [200] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/widgets/ar.json assets/i18n/widgets/ar.json application/json
upload [150] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/main/en.po assets/i18n/main/en.po null
upload [100] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/it.json assets/i18n/admin/it.json application/json
upload [90] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/fi.json assets/i18n/admin/fi.json application/json
upload [80] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/cs.po assets/i18n/admin/cs.po null
upload [70] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/assets/i18n/admin/admin.pot assets/i18n/admin/admin.pot application/vnd.ms-powerpoint
upload [60] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/slider/slider.widget.js app/widgets/slider/slider.widget.js application/javascript
upload [50] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/knob/knob.tpl.html app/widgets/knob/knob.tpl.html text/html
upload [40] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/dummy/dummy.settings.tpl.html app/widgets/dummy/dummy.settings.tpl.html text/html
upload [30] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/widgets/button/button.widget.js app/widgets/button/button.widget.js application/javascript
upload [20] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.localconfig.controller.js app/settings/settings.localconfig.controller.js application/javascript
upload [19] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.html app/settings/settings.html text/html
upload [18] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/settings/settings.controller.js app/settings/settings.controller.js application/javascript
upload [17] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/translation.service.js app/services/translation.service.js application/javascript
upload [16] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/speech.service.js app/services/speech.service.js application/javascript
upload [15] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/services.js app/services/services.js application/javascript
upload [14] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/persistence.service.js app/services/persistence.service.js application/javascript
upload [13] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/localfile.service.js app/services/localfile.service.js application/javascript
upload [12] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/icon.service.js app/services/icon.service.js application/javascript
upload [11] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/services/data.service.js app/services/data.service.js application/javascript
upload [10] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.settings.tpl.html app/menu/menu.settings.tpl.html text/html
upload [9] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.html app/menu/menu.html text/html
upload [8] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/menu.controller.js app/menu/menu.controller.js application/javascript
upload [7] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/drawer.tpl.html app/menu/drawer.tpl.html text/html
upload [6] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/menu/drawer.controller.js app/menu/drawer.controller.js application/javascript
upload [5] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/transferwidget.html app/dashboard/transferwidget.html text/html
upload [4] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.view.html app/dashboard/dashboard.view.html text/html
upload [3] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.view.controller.js app/dashboard/dashboard.view.controller.js application/javascript
upload [2] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.edit.html app/dashboard/dashboard.edit.html text/html
upload [1] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/dashboard/dashboard.edit.controller.js app/dashboard/dashboard.edit.controller.js application/javascript
upload [0] habpanel /opt/iobroker/node_modules/iobroker.habpanel/www/app/app.js app/app.js application/javascript
Adapter "habpanel" updated
Adapter "haier" is not installed.
Adapter "ham" is not installed.
Adapter "ham-wemo" is not installed.
Adapter "harmony" is up to date.
Adapter "heatingcontrol" is not installed.
Adapter "heytech" is not installed.
Adapter "hid" is not installed.
Update history from @1.8.7 to @1.9.6
NPM version: 6.14.4
npm install iobroker.history@1.9.6 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_12_22_131Z-debug.log
upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/wordsCustom.js wordsCustom.js application/javascript
upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
Adapter "history" updated
Adapter "hm-rega" is not installed.
Adapter "hm-rpc" is not installed.
Adapter "hmip" is not installed.
Adapter "homeconnect" is not installed.
Adapter "homee" is not installed.
Adapter "homepilot" is not installed.
Adapter "hp-ilo" is not installed.
Adapter "hs100" is not installed.
Adapter "hue" is not installed.
Adapter "hue-extended" is not installed.
Adapter "ical" is up to date.
Adapter "icons-addictive-flavour-png" is not installed.
Adapter "icons-fatcow-hosting" is not installed.
Adapter "icons-icons8" is up to date.
Adapter "icons-material-png" is up to date.
Adapter "icons-material-svg" is not installed.
Adapter "icons-mfd-png" is up to date.
Adapter "icons-mfd-svg" is up to date.
Adapter "icons-open-icon-library-png" is not installed.
Adapter "icons-ultimate-png" is up to date.
Adapter "influxdb" is not installed.
Adapter "info" is not installed.
Adapter "innogy-smarthome" is not installed.
Adapter "iogo" is not installed.
Update iot from @1.4.14 to @1.4.18
host.haussteuerung Adapter "system.adapter.iot.0" is stopped.
NPM version: 6.14.4
npm install iobroker.iot@1.4.18 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_13_37_804Z-debug.log
upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js.map static/js/runtime-main.814e5fd0.js.map application/json
upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.814e5fd0.js static/js/runtime-main.814e5fd0.js application/javascript
upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.808a09ba.chunk.js.map static/js/main.808a09ba.chunk.js.map application/json
upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.808a09ba.chunk.js static/js/main.808a09ba.chunk.js application/javascript
upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.19f19876.chunk.js.map static/js/2.19f19876.chunk.js.map application/json
upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.19f19876.chunk.js.LICENSE.txt static/js/2.19f19876.chunk.js.LICENSE.txt text/plain
upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.19f19876.chunk.js static/js/2.19f19876.chunk.js application/javascript
upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css.map static/css/2.b1b16afe.chunk.css.map application/json
upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css static/css/2.b1b16afe.chunk.css text/css
upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.437977870155d308fb2cb10b306e4aed.js precache-manifest.437977870155d308fb2cb10b306e4aed.js application/javascript
upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
Adapter "iot" updated
host.haussteuerung Adapter "system.adapter.iot.0" is started
Adapter "iqontrol" is not installed.
Update javascript from @4.3.4 to @4.5.1
NPM version: 6.14.4
npm install iobroker.javascript@4.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_14_55_352Z-debug.log
upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/powershell/powershell.js vs/basic-languages/powershell/powershell.js application/javascript
upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/java/java.js vs/basic-languages/java/java.js application/javascript
upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/basic-languages/cpp/cpp.js vs/basic-languages/cpp/cpp.js application/javascript
upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/main.320f2344.chunk.js.LICENSE.txt static/js/main.320f2344.chunk.js.LICENSE.txt text/plain
upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/precache-manifest.53aabff70ba6fd6a56045658a4c06c3b.js precache-manifest.53aabff70ba6fd6a56045658a4c06c3b.js application/javascript
upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handopen.cur google-blockly/media/handopen.cur null
upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handdelete.cur google-blockly/media/handdelete.cur null
upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/handclosed.cur google-blockly/media/handclosed.cur null
upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.wav google-blockly/media/disconnect.wav audio/wav
upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.ogg google-blockly/media/disconnect.ogg audio/ogg
upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/disconnect.mp3 google-blockly/media/disconnect.mp3 audio/mpeg
upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.mp3 google-blockly/media/delete.mp3 audio/mpeg
upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.wav google-blockly/media/click.wav audio/wav
upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.ogg google-blockly/media/click.ogg audio/ogg
upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/click.mp3 google-blockly/media/click.mp3 audio/mpeg
upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/1x1.gif google-blockly/media/1x1.gif image/gif
upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/javascript_compressed.js google-blockly/javascript_compressed.js application/javascript
upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blocks_compressed.js google-blockly/blocks_compressed.js application/javascript
upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
Adapter "javascript" updated
Adapter "jeelink" is not installed.
Adapter "kecontact" is not installed.
Adapter "klf200" is not installed.
Adapter "km200" is not installed.
Adapter "knmi-weather" is not installed.
Adapter "knx" is not installed.
Adapter "kodi" is up to date.
Adapter "kress" is not installed.
Adapter "lametric" is not installed.
Adapter "landroid" is not installed. -
Adapter "lcn" is not installed.
Adapter "lgtv" is not installed.
Adapter "lgtv-rs" is not installed.
Adapter "lgtv11" is not installed.
Adapter "lifx" is not installed.
Adapter "lightify" is not installed.
Adapter "link" is not installed.
Adapter "linkeddevices" is not installed.
Update lovelace from @0.2.3 to @1.0.16
NPM version: 6.14.4
npm install iobroker.lovelace@1.0.16 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_18_12_319Z-debug.log
upload [5] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/words.js words.js application/javascript
upload [4] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/style.css style.css text/css
upload [3] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/lovelace.png lovelace.png image/png
upload [2] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/js-yaml.min.js js-yaml.min.js application/javascript
upload [1] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/index_m.html index_m.html text/html
upload [0] lovelace.admin /opt/iobroker/node_modules/iobroker.lovelace/admin/custom_m.html custom_m.html text/html
Adapter "lovelace" updated
Adapter "loxone" is not installed.
Adapter "luftdaten" is not installed.
Adapter "lupusec" is not installed.
Adapter "luxtronik1" is not installed.
Update material from @0.12.1 to @0.13.8
NPM version: 6.14.4
npm install iobroker.material@0.13.8 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_19_23_058Z-debug.log
upload [1] material.admin /opt/iobroker/node_modules/iobroker.material/admin/material.svg material.svg image/svg+xml
upload [0] material.admin /opt/iobroker/node_modules/iobroker.material/admin/material.png material.png image/png
upload [60] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-Thin.ttf vendor/fonts/Roboto-Thin.ttf font/ttf
upload [50] material /opt/iobroker/node_modules/iobroker.material/www/vendor/fonts/Roboto-BoldItalic.ttf vendor/fonts/Roboto-BoldItalic.ttf font/ttf
upload [40] material /opt/iobroker/node_modules/iobroker.material/www/static/media/roboto-latin-900.9b3766ef.woff2 static/media/roboto-latin-900.9b3766ef.woff2 font/woff2
upload [30] material /opt/iobroker/node_modules/iobroker.material/www/static/media/roboto-latin-400italic.51521a2a.woff2 static/media/roboto-latin-400italic.51521a2a.woff2 font/woff2
upload [20] material /opt/iobroker/node_modules/iobroker.material/www/static/media/roboto-latin-100.5cb7edfc.woff static/media/roboto-latin-100.5cb7edfc.woff font/woff
upload [19] material /opt/iobroker/node_modules/iobroker.material/www/static/media/rgb.5d0e5ef3.png static/media/rgb.5d0e5ef3.png image/png
upload [18] material /opt/iobroker/node_modules/iobroker.material/www/static/media/apartment.28bae16c.jpg static/media/apartment.28bae16c.jpg image/jpeg
upload [17] material /opt/iobroker/node_modules/iobroker.material/www/static/js/runtime-main.28bbd470.js.map static/js/runtime-main.28bbd470.js.map application/json
upload [16] material /opt/iobroker/node_modules/iobroker.material/www/static/js/runtime-main.28bbd470.js static/js/runtime-main.28bbd470.js application/javascript
upload [15] material /opt/iobroker/node_modules/iobroker.material/www/static/js/main.416e9219.chunk.js.map static/js/main.416e9219.chunk.js.map application/json
upload [14] material /opt/iobroker/node_modules/iobroker.material/www/static/js/main.416e9219.chunk.js static/js/main.416e9219.chunk.js application/javascript
upload [13] material /opt/iobroker/node_modules/iobroker.material/www/static/js/2.4ead899c.chunk.js.map static/js/2.4ead899c.chunk.js.map application/json
upload [12] material /opt/iobroker/node_modules/iobroker.material/www/static/js/2.4ead899c.chunk.js.LICENSE.txt static/js/2.4ead899c.chunk.js.LICENSE.txt text/plain
upload [11] material /opt/iobroker/node_modules/iobroker.material/www/static/js/2.4ead899c.chunk.js static/js/2.4ead899c.chunk.js application/javascript
upload [10] material /opt/iobroker/node_modules/iobroker.material/www/static/css/main.bf8ff6b7.chunk.css.map static/css/main.bf8ff6b7.chunk.css.map application/json
upload [9] material /opt/iobroker/node_modules/iobroker.material/www/static/css/main.bf8ff6b7.chunk.css static/css/main.bf8ff6b7.chunk.css text/css
upload [8] material /opt/iobroker/node_modules/iobroker.material/www/static/css/2.8c32401a.chunk.css.map static/css/2.8c32401a.chunk.css.map application/json
upload [7] material /opt/iobroker/node_modules/iobroker.material/www/static/css/2.8c32401a.chunk.css static/css/2.8c32401a.chunk.css text/css
upload [6] material /opt/iobroker/node_modules/iobroker.material/www/service-worker.js service-worker.js application/javascript
upload [5] material /opt/iobroker/node_modules/iobroker.material/www/precache-manifest.653e0604b7a9eb0f1afaee23754aec4b.js precache-manifest.653e0604b7a9eb0f1afaee23754aec4b.js application/javascript
upload [4] material /opt/iobroker/node_modules/iobroker.material/www/manifest.json manifest.json application/json
upload [3] material /opt/iobroker/node_modules/iobroker.material/www/iob.css iob.css text/css
upload [2] material /opt/iobroker/node_modules/iobroker.material/www/index.html index.html text/html
upload [1] material /opt/iobroker/node_modules/iobroker.material/www/favicon.ico favicon.ico image/vnd.microsoft.icon
upload [0] material /opt/iobroker/node_modules/iobroker.material/www/asset-manifest.json asset-manifest.json application/json
Adapter "material" updated
Adapter "maxcube" is not installed.
Adapter "maxcul" is not installed.
Adapter "mbus" is not installed.
Adapter "mclighting" is not installed.
Adapter "megad" is not installed.
Adapter "megadd" is not installed.
Adapter "megaesp" is not installed.
Adapter "mercedesme" is not installed.
Adapter "mercury" is not installed.
Adapter "meross" is not installed.
Adapter "meteoalarm" is not installed.
Adapter "miele" is not installed.
Adapter "mielecloudservice" is not installed.
Adapter "mihome" is not installed.
Adapter "mihome-lamp" is not installed.
Adapter "mihome-plug" is not installed.
Adapter "mihome-vacuum" is not installed.
Adapter "mikrotik" is not installed.
Adapter "milight" is not installed.
Adapter "milight-smart-light" is not installed.
Adapter "mobile" is up to date.
Adapter "modbus" is not installed.
Adapter "moma" is not installed.
Adapter "mpd" is not installed.
Adapter "mqtt" is not installed.
Adapter "mqtt-client" is not installed.
Adapter "musiccast" is not installed.
Adapter "mysensors" is not installed.
Adapter "nanoleaf-lightpanels" is not installed.
Adapter "nello" is not installed.
Adapter "netatmo" is not installed.
Adapter "nibeuplink" is not installed.
Adapter "nina" is not installed.
Adapter "node-red" is not installed.
Adapter "nuki" is not installed.
Adapter "nuki-extended" is not installed.
Adapter "nut" is not installed.
Adapter "odl" is not installed.
Adapter "oilfox" is up to date.
Adapter "onkyo" is not installed.
Adapter "onvif" is not installed.
Adapter "openhab" is not installed.
Adapter "openligadb" is not installed.
Adapter "openweathermap" is not installed.
Adapter "opi" is not installed.
Adapter "oppoplayer" is not installed.
Adapter "owfs" is not installed.
Adapter "owntracks" is not installed.
Adapter "panasonic-viera" is not installed.
Adapter "parser" is up to date.
Adapter "paw" is not installed.
Adapter "phantomjs" is not installed.
Adapter "pi-hole" is not installed.
Adapter "piface" is not installed.
Adapter "pimatic" is not installed.
Update ping from @1.3.2 to @1.4.7
NPM version: 6.14.4
npm install iobroker.ping@1.4.7 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_21_09_698Z-debug.log
upload [3] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
upload [2] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index_m.html index_m.html text/html
upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/index.html index.html text/html
Adapter "ping" updated
Adapter "places" is not installed.
Adapter "plex" is not installed.
Adapter "plexconnect" is not installed.
Adapter "pollenflug" is not installed.
Adapter "proxmox" is not installed.
Adapter "proxy" is not installed.
Adapter "pushbullet" is not installed.
Adapter "pushover" is not installed.
Adapter "pushsafer" is not installed.
Adapter "radar2" is up to date.
Adapter "radiohead" is not installed.
Adapter "rflink" is not installed.
Adapter "rickshaw" is not installed.
Adapter "ring" is not installed.
Adapter "robonect" is not installed.
Adapter "roomba" is not installed.
Adapter "rpi2" is not installed.
Adapter "s7" is not installed.
Adapter "samsung" is up to date.
Update sayit from @1.8.2 to @1.9.4
host.haussteuerung Adapter "system.adapter.sayit.0" is stopped.
NPM version: 6.14.4
npm install iobroker.sayit@1.9.4 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_21_53_352Z-debug.log
upload [5] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/words.js words.js application/javascript
upload [4] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/sayit.png sayit.png image/png
upload [3] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/index_m.html index_m.html text/html
upload [2] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/index.html index.html text/html
upload [1] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/engines.js engines.js application/javascript
upload [0] sayit.admin /opt/iobroker/node_modules/iobroker.sayit/admin/blockly.js blockly.js application/javascript
Adapter "sayit" updated
host.haussteuerung Adapter "system.adapter.sayit.0" is started
Adapter "sbfspot" is not installed.
Adapter "scenes" is up to date.
Adapter "schoolfree" is not installed.
Adapter "shelly" is not installed.
Adapter "shuttercontrol" is not installed.
Adapter "sia" is not installed.
Adapter "siegenia" is not installed.
Update simple-api from @2.3.2 to @2.4.5
NPM version: 6.14.4
npm install iobroker.simple-api@2.4.5 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_23_12_240Z-debug.log
upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
Adapter "simple-api" updated
Adapter "smappee" is not installed.
Adapter "smartmeter" is not installed.
Adapter "snips" is not installed.
Adapter "snmp" is not installed.
Update socketio from @3.0.6 to @3.0.7
NPM version: 6.14.4
npm install iobroker.socketio@3.0.7 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_23_53_003Z-debug.log
upload [3] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/words.js words.js application/javascript
upload [2] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/png
upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index_m.html index_m.html text/html
upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/index.html index.html text/html
Adapter "socketio" updated
Adapter "solarlog" is not installed.
Adapter "solarwetter" is not installed.
Adapter "sonnen" is not installed.
Adapter "sonoff" is up to date.
Adapter "sonos" is not installed.
Adapter "sony-bravia" is not installed.
Adapter "spotify-premium" is not installed.
Adapter "sql" is not installed.
Adapter "squeezebox" is not installed.
Adapter "squeezeboxrpc" is not installed.
Adapter "starline" is not installed.
Adapter "statistics" is not installed.
Adapter "stiebel-isg" is not installed.
Adapter "sunnyportal" is not installed.
Adapter "swiss-weather-api" is not installed.
Adapter "systeminfo" is up to date.
Adapter "tahoma" is not installed.
Adapter "tankerkoenig" is up to date.
Adapter "telegram" is not installed.
Adapter "terminal" is not installed.
Adapter "tesla-motors" is not installed.
Adapter "text2command" is not installed.
Adapter "tr-064" is not installed.
Adapter "tradfri" is not installed.
Adapter "trashschedule" is not installed.
Adapter "tunnelbroker-endpoint-updater" is not installed.
Adapter "tuya" is not installed.
Adapter "tvspielfilm" is up to date.
Adapter "unifi" is not installed.
Update upnp from @1.0.11 to @1.0.16
NPM version: 6.14.4
npm install iobroker.upnp@1.0.16 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_24_32_721Z-debug.log
upload [13] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/words.js words.js application/javascript
upload [12] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/upnp.png upnp.png image/png
upload [11] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/index_m.html index_m.html text/html
upload [10] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
upload [9] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
upload [8] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
upload [7] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
upload [6] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
upload [5] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/it/translations.json i18n/it/translations.json application/json
upload [4] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
upload [3] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/es/translations.json i18n/es/translations.json application/json
upload [2] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/en/translations.json i18n/en/translations.json application/json
upload [1] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/i18n/de/translations.json i18n/de/translations.json application/json
upload [0] upnp.admin /opt/iobroker/node_modules/iobroker.upnp/admin/custom_m.html custom_m.html text/html
Adapter "upnp" updated
Adapter "vaillant" is not installed.
Adapter "valloxmv" is not installed.
Adapter "vcard" is not installed.
Adapter "velux" is not installed.
Adapter "viessmann" is up to date.
Adapter "virtualpowermeter" is not installed.
Adapter "vis" is up to date.
Adapter "vis-bars" is up to date.
Adapter "vis-canvas-gauges" is not installed.
Adapter "vis-colorpicker" is up to date.
Adapter "vis-fancyswitch" is not installed.
Adapter "vis-google-fonts" is not installed.
Adapter "vis-history" is not installed.
Adapter "vis-hqwidgets" is up to date.
Adapter "vis-inventwo" is not installed.
Adapter "vis-jqui-mfd" is not installed.
Adapter "vis-justgage" is not installed.
Adapter "vis-keyboard" is not installed.
Adapter "vis-lcars" is up to date.
Adapter "vis-map" is not installed.
Adapter "vis-metro" is up to date.
Adapter "vis-players" is up to date.
Adapter "vis-plumb" is not installed.
Adapter "vis-rgraph" is not installed.
Adapter "vis-timeandweather" is up to date.
Adapter "vis-weather" is up to date.
Adapter "vr200" is not installed.
Adapter "vw-connect" is not installed.
Adapter "weatherunderground" is not installed.
Update web from @3.0.7 to @3.0.8
host.haussteuerung Adapter "system.adapter.web.0" is stopped.
NPM version: 6.14.4
npm install iobroker.web@3.0.8 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_25_35_601Z-debug.log
upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/words.js words.js application/javascript
upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index.html index.html text/html
upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_highlight-hard_55_555555_1x100.png image/png
upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png lib/css/themes/jquery-ui/sunny/images/ui-bg_highlight-soft_100_feeebd_1x100.png image/png
upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png lib/css/themes/jquery-ui/redmond/images/ui-icons_469bdd_256x240.png image/png
upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-icons_ffeb33_256x240.png image/png
upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png lib/css/themes/jquery-ui/eggplant/images/ui-icons_ebccce_256x240.png image/png
upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png lib/css/themes/jquery-ui/dark-hive/images/ui-bg_highlight-soft_44_444444_1x100.png image/png
upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png lib/css/themes/jquery-ui/custom-light/images/ui-icons_cd0a0a_256x240.png image/png
upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png lib/css/themes/jquery-ui/custom-light/images/ui-bg_glass_55_fbf9ee_1x400.png image/png
upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png lib/css/themes/jquery-ui/custom-dark/images/ui-bg_highlight-soft_40_62bfe1_1x100.png image/png
upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png lib/css/themes/jquery-ui/cupertino/images/ui-icons_2e83ff_256x240.png image/png
upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png lib/css/themes/jquery-ui/cupertino/images/ui-bg_diagonals-thick_90_eeeeee_40x40.png image/png
upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_glass_55_fbf8ee_1x400.png image/png
upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png lib/css/themes/jquery-ui/black-tie/images/ui-icons_ffcf29_256x240.png image/png
upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_55_1c1c1c_1x400.png image/png
upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_glass_40_111111_1x400.png image/png
upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_flat_65_ffffff_40x100.png image/png
upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png lib/css/themes/jquery-ui/black-tie/images/ui-bg_diagonals-thick_8_333333_40x40.png image/png
upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/style.css lib/css/style.css text/css
upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/materialize.css lib/css/materialize.css text/css
upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ui.jqgrid-4.5.4.css lib/css/jqGrid/ui.jqgrid-4.5.4.css text/css
upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/jqGrid/ellipsis-xbl.xml lib/css/jqGrid/ellipsis-xbl.xml application/xml
upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css.map lib/css/iob/selectID.css.map application/json
upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/iob/selectID.css lib/css/iob/selectID.css text/css
upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min.css lib/css/fancytree/ui.fancytree.min.css text/css
upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.min-win7.css lib/css/fancytree/ui.fancytree.min-win7.css text/css
upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/ui.fancytree.jquery.min.css lib/css/fancytree/ui.fancytree.jquery.min.css text/css
upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/state.png lib/css/fancytree/state.png image/png
upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/loading.gif lib/css/fancytree/loading.gif image/gif
upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/icons.gif lib/css/fancytree/icons.gif image/gif
upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/device.png lib/css/fancytree/device.png image/png
upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/fancytree/channel.png lib/css/fancytree/channel.png image/png
upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/bootstrap.min.css lib/css/bootstrap.min.css text/css
upload [1] web /opt/iobroker/node_modules/iobroker.web/www/index.html index.html text/html
upload [0] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
Adapter "web" updated
host.haussteuerung Adapter "system.adapter.web.0" is started
Adapter "weishaupt-wem" is not installed.
Adapter "wiffi-wz" is not installed.
Update wifilight from @0.2.0 to @1.1.0
NPM version: 6.14.4
npm install iobroker.wifilight@1.1.0 --loglevel error --prefix "/opt/iobroker" (System call)
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/iobroker/.npm/_logs/2020-05-22T15_27_13_155Z-debug.log
upload [12] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/words.js words.js application/javascript
upload [11] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/wifilight.png wifilight.png image/png
upload [10] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/index.html index.html text/html
upload [9] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
upload [8] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
upload [7] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
upload [6] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
upload [5] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
upload [4] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/it/translations.json i18n/it/translations.json application/json
upload [3] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
upload [2] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/es/translations.json i18n/es/translations.json application/json
upload [1] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/en/translations.json i18n/en/translations.json application/json
upload [0] wifilight.admin /opt/iobroker/node_modules/iobroker.wifilight/admin/i18n/de/translations.json i18n/de/translations.json application/json
Adapter "wifilight" updated
Adapter "windows-control" is not installed.
Adapter "wled" is up to date.
Adapter "wm-bus" is not installed.
Adapter "wolf" is not installed.
Adapter "worx" is not installed.
Adapter "xbox" is not installed.
Adapter "xs1" is not installed.
Adapter "yahka" is not installed.
Adapter "yamaha" is not installed.
Adapter "yeelight-2" is not installed.
Adapter "youtube" is not installed.
Adapter "yr" is not installed.
Adapter "zigbee" is not installed.
Adapter "zont" is not installed.
Adapter "zwave" is not installed.
pi@haussteuerung:/home/iobroker$
musste es teilen war zu viel
NPM version: 6.14.4
In file included from ../src/DeviceINQ.h:17,
from ../src/linux/BluetoothSerialPort.cc:13:
../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../node_modules/nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
, reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
../src/linux/BluetoothSerialPort.cc: At global scope:
../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void
void InitAll(Handle<Object> exports) {
../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’
rand_r
../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token
../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope
In file included from ../src/linux/BluetoothSerialPort.cc:12:
../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope
NODE_MODULE(BluetoothSerialPort, InitAll)
/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
(node::addon_register_func) (regfunc),
../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’
make: *** [BluetoothSerialPort.target.mk:117: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
gyp ERR! build error
gyp ERR! stack Error:makefailed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:310:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
gyp ERR! System Linux 4.4.213-rockchip64
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
gyp ERR! node -v v12.16.3
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! node-bluetooth@1.2.6 install:node-gyp configure build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the node-bluetooth@1.2.6 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.npm ERR! A complete log of this run can be found in:
NPM version: 6.14.4
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
NPM version: 6.14.4
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
NPM version: 6.14.4
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
NPM version: 6.14.4
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
NPM version: 6.14.4
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
NPM version: 6.14.4
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
NPM version: 6.14.4
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
NPM version: 6.14.4
rand_r
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
@Motsche1 Von sudo hatte ich nichts geschrieben!
iob_diag: curl -sLf -o diag.sh https://iobroker.net/diag.sh && bash diag.sh -
@Motsche1 Nein.
Als user:groupsLinux-Werkzeugkasten:
@Motsche1
'root' wird gar nicht benutzt und sudo nur dann wenn es notwendig ist.Linux-Werkzeugkasten:
@Motsche1 Versuch mal
cd /opt/iobroker node-gyp configure buildLinux-Werkzeugkasten:
pi@haussteuerung:~$ node-gyp configure build Command 'node-gyp' not found, but can be installed with: sudo apt install node-gyplsb_release -a nodejs -v && node -v && npm -v which nodejs && which node && which npmLinux-Werkzeugkasten:
pi@haussteuerung:~$ sudo apt install node-gyp Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: node-gyp : Depends: libnode-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages. -
pi@haussteuerung:~$ sudo apt install node-gyp Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: node-gyp : Depends: libnode-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages.@Motsche1 Hatte ich gesagt, dass du das installieren sollst?
Tu doch bitte was dir gesagt wird und mach keinen Kram nebenher.Linux-Werkzeugkasten:
pi@haussteuerung:~$ cd /home/iobroker pi@haussteuerung:/home/iobroker$ lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster pi@haussteuerung:/home/iobroker$ nodejs -v && node -v && npm -v v12.16.3 v12.16.3 6.14.4 pi@haussteuerung:/home/iobroker$ which nodejs && which node && which npm /usr/bin/nodejs /usr/bin/node /usr/bin/npm pi@haussteuerung:/home/iobroker$ -
pi@haussteuerung:~$ cd /home/iobroker pi@haussteuerung:/home/iobroker$ lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster pi@haussteuerung:/home/iobroker$ nodejs -v && node -v && npm -v v12.16.3 v12.16.3 6.14.4 pi@haussteuerung:/home/iobroker$ which nodejs && which node && which npm /usr/bin/nodejs /usr/bin/node /usr/bin/npm pi@haussteuerung:/home/iobroker$sudo apt update apt policy nodejs sudo apt install nodejs --reinstallLinux-Werkzeugkasten:
@Motsche1 Nee, ich habe 'ne Glaskugel... :-D
@Motsche1 Ja, die ist allerdings gerade in der Spülmaschine. Musste halt doch die Ausgaben hier posten.
