  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.3k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.3k Aufrufe 153 Beobachtet
  • Merlin123M Merlin123
    Mein Adapter spinnt mittlerweile auch..... Bin auf dem latest Repositiry und hab entsprechend auch 3.1.4er js-controller.
    Bei mir passiert das:
    homeconnect.0	2020-05-15 18:41:11.580	info	(23456) BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 577 seconds.
    homeconnect.0	2020-05-15 18:41:08.625	info	(23456) BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 580 seconds.
    homeconnect.0	2020-05-15 18:41:03.993	info	(23456) BOSCH-WTYH7701-68A40E2F2657: The rate limit "10 successive error calls in 10 minutes" was reached. Requests are blocked during the remaining period of 584 seconds.
    homeconnect.0	2020-05-15 18:41:02.479	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:41:00.973	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:59.477	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:57.976	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:56.465	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:54.978	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:53.473	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:51.975	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:50.481	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:48.972	info	(23456) BOSCH-WTYH7701-68A40E2F2657: Program currently not available
    homeconnect.0	2020-05-15 18:40:34.021	info	(23456) Accesstoken renewed...
    homeconnect.0	2020-05-15 18:40:33.797	warn	(23456) BOSCH-WAYH2842-68A40E2AA61D is not connected cannot fetch information.
    homeconnect.0	2020-05-15 18:40:33.369	info	(23456) starting. Version 0.0.28 in /opt/iobroker/node_modules/iobroker.homeconnect, node: v10.15.2, js-controller: 3.1.4
    Hat jemand ne Idee?
    Hab auch mal den Adapter gestoppt und erst nach ner halben Stunde neu probiert, geht leider nicht.
    Historie:
    Beim Benachrichtigungen zum Programmende kamen nicht mehr.
    Hab bei den Objekten dann gesehen, dass Waschmaschine und trockner 2x drin waren. Hab den Adapter gestoppt, alle Objekte gelöscht und neu gestartet.
    Dann hatte er Probleme mit den Credentials, also nochmal API Key neu generiert usw.
    Dann ging das einloggen wieder. Die Objekte wurden nach und nach neu generiert.
    Jetzt wirft er aber den Fehler :(
    tombox
    #388
    @Merlin123 Das liegt daran das der Adapter zu oft gestartet wird. Einfach mal für 10min ausschalten und dann normal starten.
    Merlin123M 1 Antwort Letzte Antwort
    • arteckA Offline
      arteckA Offline
      arteck
      #389
      @tombox @dna909
      ich hab gerade noch einen
      darauf hin folgte
      • arteckA arteck
        @tombox @dna909
        darauf hin folgte
        tombox
        #390
        @arteck bitte die version 0.0.30 via github installieren
        • T tombox
          Merlin123M Offline
          Merlin123M Offline
          Merlin123
          schrieb am zuletzt editiert von Merlin123
          #391
          @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
          Wie geschrieben: Hab den auch mal ne halbe Stunde ausgeschaltet. Nach dem Neustart sofort wieder das Gleiche :(
          Hab jetzt mal auf die 0.3.0 aktualisiert, die zeigt das jetzt erstmal nicht mehr. Mal beobachten
          Beta-Tester
          • T tombox
            arteckA Offline
            arteckA Offline
            arteck
            #392
            @tombox gemacht... dann schau ich mal
              marsroth
              #393
              Hallo, ich habe seit ein paar Tagen folgendes Problem: Der Adapter bringt keinen Error, aber er aktualisiert die Werte nicht mehr. Vor allem bekommt der Adapter nicht mit, wenn die WM oder Trockner online geht und startet. Wenn ich den Adapter von Hand neustarte funktioniert eine Zeit lang alles wieder. In der App passt alles. Version 0.0.30 und js-controller 3.1.4.
              T B 2 Antworten Letzte Antwort
              • M marsroth
                tombox
                #394
                @marsroth homeconnect hatte server problem bitte die Woche schauen ob es besser läuft.
                oberfraggerO 1 Antwort Letzte Antwort
                • T tombox
                  oberfraggerO Offline
                  oberfragger
                  #395
                  @tombox Das läuft nun bei mir seit Tagen ganz gut. Also kein Api-Limut Fehler mehr. Schauen wir mal...
                  • M marsroth
                    beckerpa
                    #396
                    @marsroth @tombox
                    Kann das Problem von @marsroth nachvollziehen.
                    Wenn Waschmaschine und / oder Trockner ausgeschaltet werden, werden diese Geräte vom WLAN getrennt.
                    Beim Einschalten dieser Geräte verbinden diese sich direkt mit WLAN - im Adapter kommt das allerdings nicht an.
                    Ich habe das nun eine Weile getestet, das einzige was hilft ist ein Neustart des Adapters.
                    Das hat allerdings in einer sehr frühen Version des Adapters (kann ich leider nicht mehr nachvollziehen) funktioniert.
                    Einziger log-Eintrag, der kommt nachdem (in diesem Beispiel) die Waschmaschine eingeschaltet wurde:
                    beckerpa
                    T D 2 Antworten Letzte Antwort
                    • B beckerpa
                      @marsroth @tombox
                      beckerpa
                      tombox
                      #397
                      @beckerpa ich habe in der aktuellen github version noch ein paar zusätzliche warnings eingebaut um das problem einzugrenzen. Ich kann es leider gerade nicht testen weil die api down ist.
                      Bitte neuinstalliern via github und das log im auge behalten.
                      • T tombox
                        beckerpa
                        schrieb am zuletzt editiert von beckerpa
                        #398
                        @tombox
                        Moin, sry, hat bisschen länger gedauert.
                        Die Datenpunkte von Waschmaschine und Trockner werden, sobald sie wieder angeschaltet wurden, aktualisiert.
                        Bis auf den Datenpunkt BSH_Common_Setting_PowerState (Energiezustand).
                        Wenn der Datenpunkt auf Aus gesetzt wird, gehen die Maschinen auch aus (wird natürlich nicht mehr bestätigt mit true, da die Geräte keine Rückmeldung mehr geben beim Ausschalten). Beim Einschalten der Geräte verbleibt der Datenpunkt allerdings auf Aus.
                        Fehlermeldungen im log gibt es keine mehr!
                        Einzige log Einträge (vermutlich von der Kaffeemaschine Siemens beim Ausschalten):
                        beckerpa
                        • arteckA Offline
                          arteckA Offline
                          arteck
                          #399
                          ich hab da mal wieder was
                          kannst du das abfangen ..
                          • arteckA arteck
                            tombox
                            #400
                            @arteck ja alles über fehler 500 liegt an der homeconnect api die nich erreichbar ist
                            arteckA T 2 Antworten Letzte Antwort
                            • T tombox
                              arteckA Offline
                              arteckA Offline
                              arteck
                              #401
                              @tombox ja ist schon klar aber das kan man abfangen und eine schicke Fehlermeldung rauswerfen.
                              • T tombox
                                tombox
                                #402
                                @tombox ist doch abgefangen steht doch da das homeconnect api nicht available ist
                                • T tombox
                                  arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #403
                                  @tombox ja aber...
                                  ein "Api nicht erreichbar" würde vollkommen reichen im LOG.. ich hab den Adapter auf INFO stehen..
                                  bei Error bekomme ich eine Telegramm Nachricht.. und werde zugespamt
                                  • B beckerpa
                                    @marsroth @tombox
                                    beckerpa
                                    dtp
                                    #404
                                    @beckerpa sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
                                    Sehr schade, dass das immer noch nicht funktioniert. Diese Funktion ist für mich eigentlich die wichtigste des Adapters, um die Restlaufzeit der Waschmaschine in vis angezeigt zu bekommen.
                                    P 1 Antwort Letzte Antwort
                                    • U Offline
                                      U Offline
                                      UHT
                                      #405
                                      Vielen Dank für den Adapter!
                                      Ich komme irgendwie mit dem enum nicht klar. Wie kann ich den OperationState vernüftig (und am besten auf deutsch) in VIS darstellen?
                                        SSenn
                                        #406
                                        Hallo zusammen
                                        Ich bin noch recht neu in diesem Thema und bin momentan mehr am lesen als am Ergebnisse erzielen, aber wenn dann wieder einmal etwas funktioniert freue ich mich umso mehr.
                                        Spielte bis jetzt etwas mit Licht, Bewegungsmelder und Musikboxen herum aber nur alles auf recht tiefem Stand…
                                        Jetzt habe ich es zwar hinbekommen meine Kaffeemaschine mit dem homeconnect Adapter zu verbinden, jedoch weiss ich nicht wie ich mit den States etwas anstellen kann (in Blockly).
                                        Bei den Instanzen --> Konfiguration --> unter Benutzung steht „Mit den states in settings kannst du das Gerät ein oder ausschalten.“
                                        Wenn ich dann bei der Kaffeemaschine unter „settings“ schaue habe ich folgende:
                                        BSH.Common.EnumType.PowerState.Standby
                                        BSH.Common.EnumType.PowerState.On
                                        Sobald ich mit der Smartphone App die Maschine einschalte wechselt in ioBroker (unter Objekte) der Status auch von „Standby“ auf „On“.
                                        Jetzt möchte ich gerne ein Blockly Skript welches:
                                        „Wenn Bewegungsmelder ist war“ --> Setze Status von „BSH.Common.EnumType.PowerState.Standby“ auf „BSH.Common.EnumType.PowerState.On“
                                        Ich dachte in etwa so aber das funktioniert nicht.
                                        Blockly.JPG Das wäre eigentlich schon alles nur bekomme ich das einfach nicht hin. Könnte mir jemand sagen welche Blöcke ich da nehmen muss?
                                        Die Maschine schaltet sich dann wieder automatisch aus, das kann man dort einstellen.
                                        Folgendes ist bei mir im Einsatz:
                                        Raspberrypi 4, ioBroker und Adapter sind alle auf den aktuellen Stand.
                                        Js-controller ist noch auf 3.1.4 und Node.js auf v12.18.0 sofern diese Informationen wichtig sind.
                                        Besten Dank im Voraus für eure Unterstützung.
                                        • S SSenn
                                          Hallo zusammen
                                          beckerpa
                                          #407
                                          @SSenn
                                          nimm mal in deinem Block steuere Energiezustand den Folgeblock "Wert vom Objekt ID "BSH..." raus und ersetze das einfach durch ein Textfeld in dem steht "BSH.Common.EnumType.PowerState.On".
                                          Dann funktioniert es:
                                          beckerpa
                                          P.S.: Ich würde noch eine Abfrage einbauen, ob die Kaffeemaschine aus ist. Sonst wird jedesmal, auch wenn die Kaffeemaschine schon eingeschaltet ist, wieder eingeschaltet. Das könnte dir die API von homeconnect eventuell übel nehmen und für 10 Minuten sperren... muss aber nicht.
