  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 636.0k Aufrufe 118 Beobachtet
  • C Coffeelover
    Gibt es denn jemanden hier, bei dem die Karte gerade funktioniert?
    NPM 6.14.x
    NodeJs V12.x
    Kueppert
    #818
    @Coffeelover bei mir auch nicht mehr...schon was her, dass die es tat.
    • C Offline
      Coffeelover
      #819
      Ich hab den Adapter mal auf Debug gestellt. Wenn man dann im Log nach Map sucht, findet sich folgendes:
      2020-05-14 11:07:34.807  - debug: mihome-vacuum.2 (16026) load Map creator... false
      2020-05-14 11:07:35.066  - debug: mihome-vacuum.2 (16026) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1439,"state":8,"battery":100,"clean_time":3240,"clean_area":53147500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":90,"dnd_enabled":0}],"id":1}
      2020-05-14 11:07:36.193  - debug: mihome-vacuum.2 (16026) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
      2020-05-14 11:07:36.391  - debug: mihome-vacuum.2 (16026) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
      2020-05-14 11:07:36.899  - debug: mihome-vacuum.2 (16026) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
      2020-05-14 11:07:36.900  - debug: mihome-vacuum.2 (16026) 0. Mappointer_nomap___retry
      2020-05-14 11:07:37.408  - debug: mihome-vacuum.2 (16026) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
      2020-05-14 11:07:37.409  - debug: mihome-vacuum.2 (16026) 1. Mappointer_nomap___retry
      2020-05-14 11:07:38.990  - debug: mihome-vacuum.2 (16026) sendMsg[1] >>> {"id":26,"method":"get_map_v1"}
      2020-05-14 11:07:38.991  - debug: mihome-vacuum.2 (16026) 2. Mappointer_nomap___retry
      2020-05-14 11:07:38.997  - debug: mihome-vacuum.2 (16026) Receive <<< {"result":["roboroommap%2F64673245%2F1"],"id":26}
      2020-05-14 11:07:38.998  - debug: mihome-vacuum.2 (16026) Mappointer_updated
      2020-05-14 11:07:54.875  - debug: mihome-vacuum.2 (16026) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1440,"state":8,"battery":100,"clean_time":3240,"clean_area":53147500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":90,"dnd_enabled":0}],"id":32}
      2020-05-14 11:07:56.913  - debug: mihome-vacuum.2 (16026) sendMsg[1] >>> {"id":35,"method":"get_map_v1"}
      2020-05-14 11:07:56.919  - debug: mihome-vacuum.2 (16026) Receive <<< {"result":["roboroommap%2F64673245%2F2"],"id":35}
      2020-05-14 11:07:56.921  - debug: mihome-vacuum.2 (16026) Mappointer_updated
      • C Coffeelover
        NPM 6.14.x
        NodeJs V12.x
        #820
        @Coffeelover sagte in Test Adapter mihome-vacuum v2.0.x:
        NPM 6.14.x
        NodeJs V12.x
        ja, hier :-)
        • C Coffeelover
          NPM 6.14.x
          NodeJs V12.x
          DiginixD Offline
          DiginixD Offline
          Diginix
          #821
          @Coffeelover Bei mir funktioniert die Karte auch mit Modell 1S.
          Adapter 2.0.9
          JS-Controller 3.1.4
          nodejs 10.20.1
          ..:: So long! Tom ::..
          • E Offline
            eXectiX
            #822
            @Coffeelover Bei mir funktioniert die Karte ebenso über cloud
            Adapter 2.0.9
            JS-Controller 3.1.4
            nodejs 12.16.3
            Roborock S6
              Kueppert
              schrieb am zuletzt editiert von Kueppert
              #823
              Gibts das? bei misch net :/
              Adapter 2.0.9
              JS-COntroller 3.1.4
              nodejs 12.16.3
              Roborock v1 New generation or new fw(3.5.4,004007) detected
              Lasse gerade den Adapter im Debug laufen. Wenn ich das richtig lese, findet der Mappointer irgendwas. Aber das Objekt für die Map unter Objekte wird bei mir nicht aktualisiert (letztes Update 26.02.2020):
              mihome-vacuum.0	2020-05-14 15:19:37.956	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2171,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
              mihome-vacuum.0	2020-05-14 15:19:37.955	debug	(30087) Receive <<< {"partner_id":"","id":62,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004007","ap":{"ssid":"Unifi_EG","bssid":"18:E8:29:94:F0:F8","rssi":-47},"netif":{"local
              mihome-vacuum.0	2020-05-14 15:19:37.948	debug	(30087) Next WiFi check: 14.05 15:20
              mihome-vacuum.0	2020-05-14 15:19:37.948	debug	(30087) sendMsg[1] >>> {"id":62,"method":"miIO.info"}
              mihome-vacuum.0	2020-05-14 15:19:37.947	debug	(30087) sendMsg[1] >>> {"id":61,"method":"get_status"}
              mihome-vacuum.0	2020-05-14 15:19:17.954	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2170,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
              mihome-vacuum.0	2020-05-14 15:19:17.946	debug	(30087) sendMsg[1] >>> {"id":60,"method":"get_status"}
              mihome-vacuum.0	2020-05-14 15:18:57.952	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2169,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
              mihome-vacuum.0	2020-05-14 15:18:57.944	debug	(30087) sendMsg[1] >>> {"id":59,"method":"get_status"}
              mihome-vacuum.0	2020-05-14 15:18:37.950	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2168,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
              mihome-vacuum.0	2020-05-14 15:18:37.949	debug	(30087) Receive <<< {"partner_id":"","id":58,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004007","ap":{"ssid":"Unifi_EG","bssid":"18:E8:29:94:F0:F8","rssi":-47},"netif":{"local
              mihome-vacuum.0	2020-05-14 15:18:37.943	debug	(30087) Next WiFi check: 14.05 15:19
              mihome-vacuum.0	2020-05-14 15:18:37.943	debug	(30087) sendMsg[1] >>> {"id":58,"method":"miIO.info"}
              mihome-vacuum.0	2020-05-14 15:18:37.942	debug	(30087) sendMsg[1] >>> {"id":57,"method":"get_status"}
              mihome-vacuum.0	2020-05-14 15:18:17.946	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2167,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
              mihome-vacuum.0	2020-05-14 15:18:17.940	debug	(30087) sendMsg[1] >>> {"id":56,"method":"get_status"}
              mihome-vacuum.0	2020-05-14 15:17:57.951	debug	(30087) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2166,"state":8,"battery":100,"clean_time":1957,"clean_area":33345000,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":
              mihome-vacuum.0	2020-05-14 15:17:57.940	debug	(30087) sendMsg[1] >>> {"id":55,"method":"get_status"}
              mihome-vacuum.0	2020-05-14 15:17:53.089	debug	(30087) system.adapter.admin.0: logging true
              mihome-vacuum.0	2020-05-14 15:17:52.649	debug	(30087) Mappointer_updated
              mihome-vacuum.0	2020-05-14 15:17:52.649	debug	(30087) Receive <<< {"result":["roboroommap%2F82487762%2F12"],"id":54}
              mihome-vacuum.0	2020-05-14 15:17:52.643	debug	(30087) 1. Mappointer_nomap___retry
              mihome-vacuum.0	2020-05-14 15:17:52.642	debug	(30087) sendMsg[1] >>> {"id":54,"method":"get_map_v1"}
              mihome-vacuum.0	2020-05-14 15:17:52.140	debug	(30087) Receive <<< {"result":["retry"],"id":53}
              mihome-vacuum.0	2020-05-14 15:17:52.135	debug	(30087) 0. Mappointer_nomap___retry
              mihome-vacuum.0	2020-05-14 15:17:52.134	debug	(30087) sendMsg[1] >>> {"id":53,"method":"get_map_v1"}
              mihome-vacuum.0	2020-05-14 15:17:51.633	debug	(30087) Receive <<< {"result":["retry"],"id":52}
              mihome-vacuum.0	2020-05-14 15:17:51.628	debug	(30087) sendMsg[1] >>> {"id":52,"method":"get_map_v1"}
              • H Offline
                Hyperbit
                #824
                Adapter 2.0.9
                JS-Controller 2.2.9 (warum habt ihr eigentlich da ne Version 3.x?)
                Node 10.20.1
                Roborock V1
                Die Map geht bei mir auch nach ```
                curl -sL http://iobroker.net/fix.sh | bash -
                • M MattinK
                  @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                  @MattinK im Prinzip ist der Adapter unabhängig von der App. Aber ab und an sperrt sich der robbi und ich denke, da muss auch erst wieder eine Beziehung zwischen robbi , App und China hergestellt werden. Aber da können wir nichts machen.
                  Hallo Dirk, weisst du vielleicht, ob die beiden APPs auf die gleiche Cloud bzw. Datenbank zugreifen? So wie es aussieht,
                  sind es wohl unterschiedliche Systeme.
                  Martin
                  D Nicht stören
                  D Nicht stören
                  dirkhe
                  #825
                  @MattinK das sind 2 verschiedene Clouds, glaube ich. Soweit ich weiss, muss man den robbi sogar zurücksetzen, wenn man die App wechselt, bin aber nicht 100% sicher. Ich weiss auch nicht, ob die Karte von der roborock Cloud abgerufen werden kann.
                  • D Nicht stören
                    D Nicht stören
                    dirkhe
                    #826
                    Es könnte aber auch eine Frage der robbi Firmware sein. Da wurde doch jetzt mehretagenreinigung implementiert, kann es sein, dass dass sich die API da geändert hat?
                    • H Hyperbit
                      Adapter 2.0.9
                      Node 10.20.1
                      Roborock V1
                      DiginixD Offline
                      DiginixD Offline
                      Diginix
                      #827
                      @Hyperbit sagte in Test Adapter mihome-vacuum v2.0.x:
                      Weil der JS-Controller im latest repo bereits auf Version 3 ist. Vermutlich bist du auf stable und da ist es noch die 2.2.9.
                      • H Offline
                        Hyperbit
                        #828
                        Also bei mir Funktioniert es wieder.
                        Kann jedoch nicht sagen welche Lösung ich genau angewendet habe.
                        Ich habe folgende schritte gemacht:
                        • JS-Controller von 2.2.8 auf 2.2.9 geupdatet
                        • in Putty folgenden befehl abgesetzt
                        • IOBroker nochmal neustarten
                        • Ruud2019R Offline
                          Ruud2019R Offline
                          Ruud2019
                          schrieb am zuletzt editiert von Ruud2019
                          #829
                          @dirkhe
                          Hi, erstmal vielen Dank für diesen tollen Adapter!
                          Ich habe einen Roborock S5 mit Valetudo RE.
                          Leider funktioniert dort der DP des Wassertanks nicht. Dieser steht dauerhaft auf false.
                          Ist das schon bekannt oder funktioniert das mit dem S5 nicht?
                          D MeistertrM 2 Antworten Letzte Antwort
                          • Ruud2019R Ruud2019
                            @dirkhe
                            D Nicht stören
                            D Nicht stören
                            dirkhe
                            #830
                            @Ruud2019 bei meinem s6 funktioniert der wassertank. Müssen wir dann mal schauen, ob der bei dir anders übertragen wird. Du könntest mal auf Trace stellen und den Wassertank rausnehmen und wieder reinpacken. Aber denke daran, dass die Statusabfrage je nach Einstellungen etwas dauert
                              @dirkhe
                              MeistertrM Offline
                              MeistertrM Offline
                              Meistertr
                              #831
                              @Ruud2019 der S5 unterstützt das noch nicht
                                seppel786
                                #832
                                Hi zusammen,
                                ich habe heute den Standardadapter Version 1.1.5 nun auf die Version 2.0.9 geupdated.
                                Soweit so gut...Die States werden mir in den Objekten richtig dargestellt.
                                Nur im Ordner map bleiben alle Felder leer. Valetudo ist soweit im Adapter aktiviert und liefert in der App auch die Map.
                                Anbei noch das Log zum Adapter:
                                mihome-vacuum.0	2020-05-16 17:39:38.730	warn	(26286) Could not receive Mappointer, giving up
                                mihome-vacuum.0	2020-05-16 17:30:48.293	info	(26286) set nächster Timer: Nicht verfügbar
                                mihome-vacuum.0	2020-05-16 17:30:47.854	info	(26286) Connected
                                mihome-vacuum.0	2020-05-16 17:30:47.835	info	(26286) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:30:47.807	info	(26286) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                                mihome-vacuum.0	2020-05-16 17:30:47.785	info	(26286) Cloud control disabled
                                mihome-vacuum.0	2020-05-16 17:30:47.784	info	(26286) Expert mode enabled, states created
                                mihome-vacuum.0	2020-05-16 17:30:47.759	info	(26286) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                                mihome-vacuum.0	2020-05-16 17:30:44.975	info	(26226) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                mihome-vacuum.0	2020-05-16 17:30:44.975	info	(26226) terminating
                                mihome-vacuum.0	2020-05-16 17:30:44.975	info	(26226) Got terminate signal TERMINATE_YOURSELF
                                mihome-vacuum.0	2020-05-16 17:28:20.841	warn	(26226) Could not receive Mappointer, giving up
                                mihome-vacuum.0	2020-05-16 17:28:15.541	info	(26226) create state for carpet_mode
                                mihome-vacuum.0	2020-05-16 17:28:14.535	info	(26226) Connected
                                mihome-vacuum.0	2020-05-16 17:28:09.516	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:27:49.515	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:27:29.517	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:27:09.515	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:26:49.527	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:26:29.513	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:26:09.512	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:25:49.510	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:25:29.508	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:25:09.508	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:24:50.890	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:24:30.010	info	(26226) set nächster Timer: Nicht verfügbar
                                mihome-vacuum.0	2020-05-16 17:24:29.551	info	(26226) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:24:29.525	info	(26226) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                                mihome-vacuum.0	2020-05-16 17:24:29.499	info	(26226) Cloud control disabled
                                mihome-vacuum.0	2020-05-16 17:24:29.499	info	(26226) Expert mode enabled, states created
                                mihome-vacuum.0	2020-05-16 17:24:29.446	info	(26226) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                                mihome-vacuum.0	2020-05-16 17:24:26.151	info	(26211) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                mihome-vacuum.0	2020-05-16 17:24:26.151	info	(26211) terminating
                                mihome-vacuum.0	2020-05-16 17:24:26.150	info	(26211) Got terminate signal TERMINATE_YOURSELF
                                mihome-vacuum.0	2020-05-16 17:24:11.812	warn	(26211) Could not receive Mappointer, giving up
                                mihome-vacuum.0	2020-05-16 17:24:06.568	info	(26211) create state for carpet_mode
                                mihome-vacuum.0	2020-05-16 17:24:05.978	info	(26211) set nächster Timer: Nicht verfügbar
                                mihome-vacuum.0	2020-05-16 17:24:05.561	info	(26211) Connected
                                mihome-vacuum.0	2020-05-16 17:24:05.528	info	(26211) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-05-16 17:24:05.494	info	(26211) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                                mihome-vacuum.0	2020-05-16 17:24:05.470	info	(26211) Cloud control disabled
                                mihome-vacuum.0	2020-05-16 17:24:05.469	info	(26211) Expert mode enabled, states created
                                mihome-vacuum.0	2020-05-16 17:24:05.443	info	(26211) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                                mihome-vacuum.0	2020-05-16 17:24:02.121	info	(24195) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                mihome-vacuum.0	2020-05-16 17:24:02.121	info	(24195) terminating
                                mihome-vacuum.0	2020-05-16 17:24:02.120	info	(24195) Got terminate signal TERMINATE_YOURSELF
                                mihome-vacuum.0	2020-05-16 17:22:16.758	warn	(24195) Could not receive Mappointer, giving up
                                An was könnte das liegen?
                                Danke für Eure Hilfe und noch einen schönen Samstag,
                                Seppel
                                • D dirkhe
                                  MattinK
                                  #833
                                  Ja das muss man machen... zurücksetzen und das ist das Nervige an der Sache. Da ich die Roborock App angenehmer finde, würde ich diese auch weiter nutzen wollen. Problem ist dann nur, dass der Adapter den Saugi nicht mehr findet.
                                  Meine Frage an dich, könntest du mal schauen ob du den Zugriff auf die anderer Cloud hinbekommst. Das wäre cool. Somit könnte man die MiHome App und die Roborock App nutzen.
                                  • M MattinK
                                    DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    #834
                                    @MattinK Für was nutzt du denn die App im Alltag noch?
                                    Seit mein Sauger komplett in ioBroker inkl Karte integriert ist, nutze ich die App gar nicht mehr.
                                    Üblicherweise starte ich ihn per Alexa oder über MaterialUI am Smartphone.
                                    • D Nicht stören
                                      D Nicht stören
                                      dirkhe
                                      #835
                                      Ist bei mir auch so, ich habe die App nur genutzt, um die Räume einzuteilen. Die Karte habe ich mir auch nur einmal runtergeladen, damit ich hinter mal in die Karte klicken kann, um ihn an eine bestimmte Stelle zu schicken, ist aber noch nicht fertig... Daher darf der robbi auch nicht mehr ins Internet
                                        TemPeck
                                        #836
                                        Hat es schon jemand hinbekommen bzw. ist es überhaupt möglich, die Räume des zweiten Geschosses (bei neuer Firmware und Mehretagenmodus) auch integrieren zu können?
                                        Ich habe bei mir über iobroker ein Reinigungsscript nach Anwesenheit erstellt, damit er jeden Tag ausgewählte Räume im Erdgeschoss säubert. Nachdem er einmal im Obergeschoss gewesen ist und dementsprechend die zweite Karte geladen war, ist er beim Reinigen über das Scrip nur umher geirrt und hat sich nicht mehr zurecht gefunden.
                                        Es wäre daher zumindest gut, wenn man per Befehl eine bestimmte Karte laden könnte...
                                        • O Offline
                                          O Offline
                                          ompi
                                          schrieb am zuletzt editiert von ompi
                                          #837
                                          ich habe einen Roborock S5 max und verbinde den gerade mit dem mihome-vacuum Adapter V2.0.9 vom GIT. Bei den Räumen ist mir aufgefallen, dass wenn ich über den roomClean-Button die Raumreinigung starte und ich das Feld "roomFanPower" leer lasse. Stürzt der Adapter ab. Debug-Log-File habe ich angehängt. Die Raumreinigung startet trotzdem und nach ner halben Minute ist das Adapter neugestartet.
                                          mihome-vacuum.0	2020-05-18 21:40:54.007	info	(11511) Connected
                                          mihome-vacuum.0	2020-05-18 21:40:53.998	debug	(11511) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                          mihome-vacuum.0	2020-05-18 21:40:53.996	debug	(11511) Receive <<< {"result":[{"msg_ver":2,"msg_seq":3746,"state":18,"battery":100,"clean_time":30,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":3,"in_returning":0,"in_fresh_state":0,"
                                          mihome-vacuum.0	2020-05-18 21:40:53.989	debug	(11511) sendMsg[1] >>> {"id":1,"method":"get_status"}
                                          mihome-vacuum.0	2020-05-18 21:40:53.911	debug	(11511) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                          mihome-vacuum.0	2020-05-18 21:40:53.911	info	(11511) connecting, this can take up to 10 minutes ...
                                          mihome-vacuum.0	2020-05-18 21:40:53.910	warn	(11511) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                          mihome-vacuum.0	2020-05-18 21:40:53.910	debug	(11511) Receive <<< Helo <<< 2131002000000000132d559d5ec2e4c6ffffffffffffffffffffffffffffffff
                                          mihome-vacuum.0	2020-05-18 21:40:53.898	info	(11511) New generation or new fw(3.5.8,0780) detected, create new states goto and zoneclean
                                          mihome-vacuum.0	2020-05-18 21:40:53.868	debug	(11511) server started on 0.0.0.0:53421
                                          mihome-vacuum.0	2020-05-18 21:40:53.858	info	(11511) Create state clean_home for controlling by cloud adapter
                                          mihome-vacuum.0	2020-05-18 21:40:53.858	info	(11511) Expert mode enabled, states created
                                          mihome-vacuum.0	2020-05-18 21:40:53.848	debug	(11511) Xiaomi Cloud: Logging in
                                          mihome-vacuum.0	2020-05-18 21:40:53.846	debug	(11511) load Map creator... true
                                          mihome-vacuum.0	2020-05-18 21:40:53.716	info	(11511) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.20.1
                                          mihome-vacuum.0	2020-05-18 21:40:51.680	debug	(11511) statesDB connected
                                          mihome-vacuum.0	2020-05-18 21:40:51.679	debug	(11511) States connected to redis: 127.0.0.1:9000
                                          mihome-vacuum.0	2020-05-18 21:40:51.638	debug	(11511) States create System PubSub Client
                                          mihome-vacuum.0	2020-05-18 21:40:51.636	debug	(11511) States create User PubSub Client
                                          mihome-vacuum.0	2020-05-18 21:40:51.612	debug	(11511) Redis States: Use Redis connection: 127.0.0.1:9000
                                          mihome-vacuum.0	2020-05-18 21:40:51.609	debug	(11511) objectDB connected
                                          mihome-vacuum.0	2020-05-18 21:40:51.604	debug	(11511) Objects connected to redis: 127.0.0.1:9001
                                          mihome-vacuum.0	2020-05-18 21:40:51.544	debug	(11511) Objects client initialize lua scripts
                                          mihome-vacuum.0	2020-05-18 21:40:51.543	debug	(11511) Objects create User PubSub Client
                                          mihome-vacuum.0	2020-05-18 21:40:51.542	debug	(11511) Objects create System PubSub Client
                                          mihome-vacuum.0	2020-05-18 21:40:51.539	debug	(11511) Objects client ready ... initialize now
                                          mihome-vacuum.0	2020-05-18 21:40:51.076	debug	(11511) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          mihome-vacuum.0	2020-05-18 21:40:18.877	info	(31264) Terminated (NO_ERROR): Without reason
                                          mihome-vacuum.0	2020-05-18 21:40:18.875	info	(31264) terminating
                                          mihome-vacuum.0	2020-05-18 21:40:18.864	error	at process._tickCallback (internal/process/next_tick.js:68:7)
                                          mihome-vacuum.0	2020-05-18 21:40:18.864	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                                          mihome-vacuum.0	2020-05-18 21:40:18.864	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                                          mihome-vacuum.0	2020-05-18 21:40:18.864	error	at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:572:33)
                                          mihome-vacuum.0	2020-05-18 21:40:18.864	error	at /opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:177:68
                                          mihome-vacuum.0	2020-05-18 21:40:18.864	error	(31264) TypeError: Cannot read property 'val' of null
                                          mihome-vacuum.0	2020-05-18 21:40:18.862	error	(31264) uncaught exception: Cannot read property 'val' of null
                                          mihome-vacuum.0	2020-05-18 21:40:18.832	debug	(31264) sendMsg[1] >>> {"id":764,"method":"app_segment_clean","params":[18]}
                                          mihome-vacuum.0	2020-05-18 21:40:18.831	info	(31264) trigger cleaning segment 18
                                          mihome-vacuum.0	2020-05-18 21:40:18.824	debug	(31264) sendTo "cleanSegments" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                          mihome-vacuum.0	2020-05-18 21:40:18.821	debug	(31264) stateChange mihome-vacuum.0.rooms.756001011138.roomClean {"val":true,"ack":false,"ts":1589830818817,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1589815704045}
                                          ompi
