  4. Test Adapter vodafone-speedtest v0.0.x GitHub/Latest
vodafone speedtest
208 Beiträge 43 Kommentatoren 52.4k Aufrufe 33 Beobachtet
    :man-facepalming: Danke
    Aber trotzdem nicht....
    Paket libcurl-dev ist ein virtuelles Paket, das bereitgestellt wird von:
    libcurl4-openssl-dev 7.64.0-4
    libcurl4-nss-dev 7.64.0-4
    libcurl4-gnutls-dev 7.64.0-4
    Sie sollten eines explizit zum Installieren auswählen.
    E: Für Paket »libcurl-dev« existiert kein Installationskandidat.
    $ ./iobroker install vodafone-speedtest
    NPM version: 6.11.3
    npm install iobroker.vodafone-speedtest@0.0.4 --loglevel error --prefix "/opt/iobroker" (System call)
    Could not run curl-config, please make sure libcurl dev package is installed.Output: /bin/sh: 1: curl-config: not foundgyp: Call to 'node /opt/iobroker/node_modules/node-libcurl/tools/curl-config.js --prefix' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error gyp ERR! stack Error: gyp failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:344:16)
    gyp ERR! stack at ChildProcess.emit (events.js:198:13)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node" "--module_name=node_libcurl" "--module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlgyp ERR! node -v v10.17.0gyp ERR! node-gyp -v v5.0.3gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/node-libcurl/lib/binding/node_libcurl.node --module_name=node_libcurl --module_path=/opt/iobroker/node_modules/node-libcurl/lib/binding --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    node-pre-gyp ERR! System Linux 4.19.75-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/node-libcurlnode-pre-gyp ERR! node -v v10.17.0node-pre-gyp ERR! node-pre-gyp -v v0.14.0node-pre-gyp ERR! not ok
    npm ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! node-libcurl@2.1.1 install: node-pre-gyp install --fallback-to-buildnpm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-libcurl@2.1.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-08T12_31_03_537Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.vodafone-speedtest@0.0.4: 1
    peterbaumertP Offline
    peterbaumert
    @tobi83 @dontobi
    apt install libcurl4-openssl-dev
    Ich muss das dann noch in die readme mit aufnehmen. Dachte eigentlich das würde mit curl mit installiert.
    Pete
    • peterbaumertP peterbaumert
      @tobi83 @dontobi das muss wohl an euren namen liegen :P
      Ne quatsch, was habt ihr denn für Betriebssystem?
      apt install libcurl-dev
      sollte dies unter debian und ubuntu beheben.
      @dos1973 Bekommst du auf der Vodafone Speedtest seite oben denn deine "soll" Geschwindigkeit angezeigt?
      @arteck wie oft lässt du den denn laufen? Habe bei Vodafone die Vermutung, wenn man es zu oft macht blockieren die einen, hatte ich während meinen Tests auch.
      Pete
      dos1973
      @peterbaumert sagte in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
      Nein, da steht nichts von „soll“.
      Kann es sein, dass ich ehemals Unitymedia bin?
      Die werte und alles passen gut.
        @tobi83 @dontobi
        Pete
        @peterbaumert
        bei mir musste noch sudo davor dann kam würden Dateien fehlen
        Hab danach apt-get update wie in Konsole stand gemacht und dann nochmal installiert ohne Fehler.
        Hab dann den Adapter installiert, er warf jede Menge Meldungen, war danach noch nicht in den Instanzen, hab dann nochmal den Adapter installiert aber über die Adapter Page und nicht über Info und neue Adapter und dann ging es ohne Fehlermeldungen und der Adapter ist da.....
        Unten dran die Fehlermeldungen bei der Installation über die Info Page
        Tobias
        NPM version: 6.11.3
        In file included from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type] , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete) ^
        In file included from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:../src/node_libcurl.cc: At global scope:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^../src/node_libcurl.cc:58:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(node_libcurl, Init); ^
        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/node_libcurl.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^
        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:../../nan/nan_object_wrap.h:65:61: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
        In file included from ../src/Easy.h:11, from ../src/Easy.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
        ../src/Easy.cc: In member function ‘void NodeLibcurl::Easy::CallSocketEvent(int, int)’:../src/Easy.cc:241:30: warning: variable ‘returnValueCallback’ set but not used [-Wunused-but-set-variable] Nan::MaybeLocalv8::Value returnValueCallback = asyncResource.runInAsyncScope( ^~~~~~~~~~~~~~~~~~~
        ../src/Easy.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE NodeLibcurl::Easy::GetInfo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/Easy.cc:1640:69: warning: ignoring return value of ‘v8::Maybe<bool> v8::Object::Set(v8::Localv8::Context, uint32_t, v8::Localv8::Value)’, declared with attribute warn_unused_result [-Wunused-result] Nan::Newv8::String(curr->data).ToLocalChecked()); ^
        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Easy.h:11, from ../src/Easy.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:3252:37: note: declared here V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index, ^~~
        /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
        In file included from ../src/Share.h:12, from ../src/Share.cc:8:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Share.h:12, from ../src/Share.cc:8:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
        In file included from ../src/Curl.h:13, from ../src/Multi.h:10, from ../src/Multi.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Multi.h:10, from ../src/Multi.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
        In file included from ../src/Curl.h:13, from ../src/Curl.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Curl.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
        In file included from /usr/include/c++/8/vector:64, from /home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:23, from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/Curl.cc:7:/usr/include/c++/8/bits/stl_vector.h: In constructor ‘std::vector<_Tp, _Alloc>::vector(std::initializer_list<_Tp>, const allocator_type&) [with _Tp = NodeLibcurl::CurlConstant; _Alloc = std::allocatorNodeLibcurl::CurlConstant]’:/usr/include/c++/8/bits/stl_vector.h:515:7: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 vector(initializer_list<value_type> __l, ^~~~~~
        ../src/Curl.cc: In function ‘(static initializers for ../src/Curl.cc)’:../src/Curl.cc:24:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionNotImplemented = { ^~../src/Curl.cc:87:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionInteger = { ^../src/Curl.cc:292:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionString = { ^~../src/Curl.cc:438:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionFunction = { ^~../src/Curl.cc:459:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionLinkedList = { ^~../src/Curl.cc:481:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionHttpPost = { ^~../src/Curl.cc:487:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlOptionSpecific = { ^~../src/Curl.cc:492:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionNotImplemented = { ^../src/Curl.cc:503:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionInteger = { ^~../src/Curl.cc:518:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlMultiOptionStringArray = { ^~../src/Curl.cc:525:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoNotImplemented = { ^~../src/Curl.cc:539:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoString = { ^~../src/Curl.cc:553:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoOffT = { ^~../src/Curl.cc:579:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoDouble = { ^~../src/Curl.cc:595:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoInteger = { ^../src/Curl.cc:631:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoSocket = { ^~../src/Curl.cc:637:33: note: parameter passing for argument of type ‘std::initializer_listNodeLibcurl::CurlConstant’ changed in GCC 7.1 const std::vector<CurlConstant> curlInfoLinkedList = { ^~~~~~~~
        In file included from ../src/Curl.h:13, from ../src/CurlVersionInfo.h:10, from ../src/CurlVersionInfo.cc:7:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
        In file included from /home/iobroker/.cache/node-gyp/10.17.0/include/node/node.h:63, from ../../nan/nan.h:54, from ../src/Curl.h:13, from ../src/CurlVersionInfo.h:10, from ../src/CurlVersionInfo.cc:7:/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:/home/iobroker/.cache/node-gyp/10.17.0/include/node/node_object_wrap.h:84:78: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type] reinterpret_cast<Callback>(callback), type); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
        , typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:../../nan/nan_object_wrap.h:65:61: required from here/home/iobroker/.cache/node-gyp/10.17.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
        ../src/CurlVersionInfo.cc: At global scope:../src/CurlVersionInfo.cc:19:6: warning: ‘void NodeLibcurl::{anonymous}::SetObjPropertyToNullOrValue(v8::Localv8::Object, std::__cxx11::string, TValue) [with TValue = v8::Localv8::Primitive]’ defined but not used [-Wunused-function] void SetObjPropertyToNullOrValue<v8::Localv8::Primitive>(v8::Localv8::Object obj, ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
        host.raspberrypi install adapter vodafone-speedtest
        upload [4] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/words.js words.js application/javascript
        upload [3] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/vodafone-speedtest.png vodafone-speedtest.png image/png
        upload [2] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/style.css style.css text/css
        upload [1] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/index_m.html index_m.html text/html
        upload [0] vodafone-speedtest.admin /opt/iobroker/node_modules/iobroker.vodafone-speedtest/admin/admin.d.ts admin.d.ts video/mp2t
        host.raspberrypi object system.adapter.vodafone-speedtest created/updated
        process exited with code 0
        peterbaumertP A 2 Antworten Letzte Antwort
          @peterbaumert
          Tobias
          NPM version: 6.11.3
          peterbaumert
          @tobi83 super dass es nun geht und danke für die fehlermeldungen etc. muss ich mir in Ruhe mal anschauen.
          @dos1973 Ja habe noch nicht so ganz verstanden was genau es ausmacht wann man da infos bekommt. Denke mal hat irgendwas damit zu tun ob Vodafone deine IP/MAC einem Account zuordnen kann 🤷‍♂️
          • Dr. BakteriusD Offline
            Dr. Bakterius
            Leider war ich mit den Ergebnissen auch bei diesem Adapter nicht glücklich. Zwar besser als beim anderen (der aufgrund des Single-Test zu wenig gemessen hat), aber bei Vodafone werden zu optimistische Werte angezeigt. Für eine Tendenz reicht es zwar, aber ich habe mich trotzdem nach einer anderen Lösung umgesehen - und für mich gefunden.
            Ich habe mir mit folgendem Befehl ein speedtest-Skript heruntergeladen und ausführbar gemacht:
            wget -O speedtest https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py
            chmod +x speedtest
            Dann habe ich mir ein Bash-Skript gebastelt, dass den Speedtest zu einem vorgegebenen Server durchführt und das Ergebnis in Datenpunkte von ioBroker schreibt:
            #!/bin/bash
            # Speedtest durchführen
             Erg=$(/usr/local/bin/speedtest --server <SERVERNUMMER> --simple)
            # Ergebnis in Variable schreiben
            # Dabei den Wert korrigieren und runden
             Ping=$(echo "$Erg" | grep "Ping: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2/3+1}')
             DL=$(echo "$Erg" | grep "Download: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2*1.09}')
             UL=$(echo "$Erg" | grep "Upload: " | sed -e 's/ /\ /g' | awk '{printf "%.0f\n", $2}')
            # In Datenpunkte von ioBroker schreiben
             Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_DL>?value=$DL)
             Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_PING>?value=$Ping)
             Erg=$(curl -s http://<IP_IOBROKER>:8082/set/javascript.0.<ORDNER>.<DATENPUNKT_UL>?value=$UL)
            Das Skript lasse ich per cron einmal in der Stunde laufen. Mit den Korrekturen komme ich auf sehr ähnliche Werte wie bei speedtest.net mit meinem PC und somit auf realistische Werte die meinem Produkt entsprechen. Diese lasse ich mir in VIS anzeigen:
            peterbaumertP 1 Antwort Letzte Antwort
              chmod +x speedtest
              #!/bin/bash
              peterbaumert
              @Dr-Bakterius Hey, ja die Werte werden durchaus von Vodafone zum besseren geschönt. Ich wollte aber so nah wie möglich am „Original“ bleiben. Ich kann ja noch zusätzlich meine eigenen Messwerte in einen extra Datenpunkt schreiben. Wäre das interessant?
              Pete
              Dr. BakteriusD 1 Antwort Letzte Antwort
                Pete
                Dr. Bakterius
                #66
                Wie meinst du das? Blicke gerade nicht durch... 🤔
                  Danke @Dr-Bakterius für das Feedback,
                  ja der Adapter und auch Vodafone speedtest Seite haben sehr interessante Messverhalten ;)
                  Es werden x Werte genommen und dann an Vodafone Server gesendet, welcher dir dann deinen Speed ausrechnet und zurückschickt. Ich habe extra nicht selbst ausgerechnet, weil ich das Messverfahren so nah wie möglich am original lassen wollte.
                  Das mit dem Geld und Grün kommt in einer neueren Version dann :)
                  Pete
                  peterbaumert
                  #67
                  @peterbaumert said in Test Adapter vodafone-speedtest v0.0.x GitHub/Latest:
                  Pete
                  @Dr-Bakterius
                  Ich rechne nicht selbst die Geschwindigkeit aus, da ich es 1zu1 so haben wollte wie der Original Vodafone Speedtest. Nun war meine Frage on ich es selbst ausrechnen soll und in einem zusätzlichen Datenpunkt speichern.
                  Pete
                  C Dr. BakteriusD 2 Antworten Letzte Antwort
                    Pete
                    @Dr-Bakterius
                    Pete
                    Coffeelover
                    #68
                    @peterbaumert Ich fände das ja tatsächlich ganz interessant.
                      Pete
                      @Dr-Bakterius
                      Pete
                      Dr. Bakterius
                      #69
                      Kommt darauf an wie realistisch der Wert dann ist. In meinem Skript passe ich die gemessenen Werte ja auch an. So ist der Downspeed den ich auf meinem PC erreiche rund 9% höher als ihn das speedtest-Skript misst. Und der Ping nur etwas mehr als ein Drittel dessen. Wenn das so konstant ist, kann man das natürlich leicht anpassen. Allerdings weiß ich nicht, ob diese Korrektur auf einem anderen Rechner auch so passen würde...
                        ChaotC Offline
                        ChaotC Offline
                        Chaot
                        #70
                        @Dr-Bakterius Das wird nichts nutzen.
                        Der Speedtest von Vodafone funktioniert bei jeder Bandbreite scheinbar anders.
                        Früher bei 200er Leitung hat er dauernd leich erhöhte Werte angezeigt.
                        Bei der 400er Leitung waren die Werte meist minimal niedriger,
                        aber jetzt bei der Gigabit Leitung zeigt er ständig zu wenig an.
                        Ich habe als Referenz immer http://breitbandmessung.de verwendet. Die scheinen schnelle Server zu haben die auch die Gigabit Leitungen korrekt ausmessen.
                          dos1973
                          #71
                          @peterbaumert
                          bei mir beendet sich der adapter nicht mehr, sonst war der nur für die Dauer des Test ca. 20 Sekunden alive.
                          system.adapter.vodafone-speedtest.0.uptime: 14000 seconds
                          es hilft auch nicht den adapter zu stoppen
                          der Wert
                          system.adapter.vodafone-speedtest.0.alive
                          bleibt permanent auf true
                          • D dos1973
                            @peterbaumert
                            der Wert
                            peterbaumert
                            #72
                            @dos1973 Ich überprüfe nochmal alle timeouts, eigentlich sollte das nicht passieren.
                            @Dr-Bakterius naja realistisch ist es wenn du etwas anpasst auch nicht mehr :D aber so ist das eben mit dem Internet du wirst da nie konstant immer genau das angezeigt bekommen, was du auch wirklich gebucht hast. In so eine vollkommenen Welt leben wir nicht ;)
                            @Coffeelover ich bau das mal ein
                            Pete
                              Pete
                              Dr. Bakterius
                              #73
                              Darum geht es ja auch nicht. Aber wenn ich auf meinem PC einen Speedtest mache und dann auf dem NUC zum selben Server, sollte etwa der selbe Wert angezeigt werden. Wenn das dann bei mehreren Test so ist, passt die Korrektur.
                              So sehe ich jetzt in der Primetime, dass es einen Einbruch gibt - so wie auch mit meinem PC auf speedtest.net. Beim Vodafone-Test kommen aber praktisch immer die gleichen (zu hohen) Werte an. Wenn ich 250/50 gebucht habe, sind 265/65 auch bei optimalen Verhältnissen einfach unrealistisch. Wobei das eher an Vodafone liegt als am Adapter.
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #74
                                @Dr-Bakterius also bei mit passt .. ok zumindest fast immer
                                • O Offline
                                  O Offline
                                  oxident
                                  schrieb am zuletzt editiert von oxident
                                  #75
                                  Hallo!
                                  Danke für den Adapter. Nur mal kurz als Info: Ich wollte ihn auf einem RPi4 installieren und bekam erstmal die Fehlermeldung, dass "libcurl dev" (speziell curl-config) fehlte.
                                  Ein simples "sudo apt install libcurl4-openssl-dev" brachte dann den Erfolg.
                                  Vielleicht kann dies beim Installieren des Adapters gleich erledigt werden?
                                  • O Offline
                                    O Offline
                                    oxident
                                    #76
                                    Sorry, vielleicht blöde Frage: Macht es überhaupt Sinn, den Adapter auf einem RPi4 an einem 500/50-Anschluss laufen zu lassen?
                                    Ich meine, würde es der Raspberry überhaupt packen, die Leitung (trotz GbE-Anschluss) auszulasten?
                                    • O oxident
                                      Hallo!
                                      #77
                                      @oxident
                                      Siehe ein paar Posts über deinem
                                      • peterbaumertP Offline
                                        peterbaumert
                                        #78
                                        Hi all,
                                        also die 0.0.5 ist nun raus. Sind ein paar timeout Fehler weniger, hoffe dass er nun nicht mehr hängen bleibt.
                                        Außerdem wird ping nun auch ausgegeben und die von mir mit den raw Werten berechneten Datenpunkte gibts nun auch.
                                          Hi all,
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          #79
                                          @peterbaumert
                                          also die 0.0.5
                                          hab ich
                                          aber
                                          kommt in jeden intervall vor
