  4. Iobroker startet nicht mehr...System has not been booted...
iobroker startet nicht mehr
31 Beiträge 3 Kommentatoren 4.1k Aufrufe 2 Beobachtet
  • S SmartesHome
    @Thomas-Braun
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.19.97-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1294 SMP Thu Jan 30 13:21:14 GMT 2020
    [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
    [    0.000000] On node 0 totalpages: 1012736
    [    0.000000]   DMA zone: 1728 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
    [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
    [    0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
    [    0.000000] percpu: Embedded 17 pages/cpu s36928 r8192 d24512 u69632
    [    0.000000] pcpu-alloc: s36928 r8192 d24512 u69632 alloc=17*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M  smsc95xx.macaddr=DC:A6:32:46:B6:62 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 3735564K/4050944K available (8192K kernel code, 687K rwdata, 2408K rodata, 2048K init, 850K bss, 53236K reserved, 262144K cma-reserved, 3264512K highmem)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                       lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                       pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                       modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                         .text : 0x(ptrval) - 0x(ptrval)   (10208 kB)
                         .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
                         .data : 0x(ptrval) - 0x(ptrval)   ( 688 kB)
                          .bss : 0x(ptrval) - 0x(ptrval)   ( 851 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 28692 entries in 85 pages
    [    0.000000] rcu: Hierarchical RCU implementation.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] GIC: Using split EOI/Deactivate mode
    [    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [    0.000005] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [    0.000017] Switching to timer-based delay loop, resolution 18ns
    [    0.000242] Console: colour dummy device 80x30
    [    0.000266] console [tty1] enabled
    [    0.000311] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [    0.000327] pid_max: default: 32768 minimum: 301
    [    0.000598] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000616] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001374] CPU: Testing write buffer coherency: ok
    [    0.001782] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.002433] Setting up static identity map for 0x200000 - 0x20003c
    [    0.002591] rcu: Hierarchical SRCU implementation.
    [    0.003451] smp: Bringing up secondary CPUs ...
    [    0.004260] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.005201] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.006102] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.006239] smp: Brought up 1 node, 4 CPUs
    [    0.006252] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [    0.006261] CPU: All CPU(s) started in HYP mode.
    [    0.006270] CPU: Virtualization extensions available.
    [    0.007064] devtmpfs: initialized
    [    0.017408] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [    0.017617] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.017637] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.025133] pinctrl core: initialized pinctrl subsystem
    [    0.025981] NET: Registered protocol family 16
    [    0.028934] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.030417] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.030427] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.030620] Serial: AMBA PL011 UART driver
    [    0.033685] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [    0.050037] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-02-12 12:36, variant start
    [    0.060052] raspberrypi-firmware soc:firmware: Firmware hash is c3c8dbdf147686fb0c3f32aece709d0653368810
    [    0.103058] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
    [    0.106250] vgaarb: loaded
    [    0.106605] SCSI subsystem initialized
    [    0.106806] usbcore: registered new interface driver usbfs
    [    0.106858] usbcore: registered new interface driver hub
    [    0.106924] usbcore: registered new device driver usb
    [    0.108209] clocksource: Switched to clocksource arch_sys_counter
    [    0.186855] VFS: Disk quotas dquot_6.6.0
    [    0.186940] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.187080] FS-Cache: Loaded
    [    0.187259] CacheFiles: Loaded
    [    0.187778] simple-framebuffer: probe of 0.framebuffer failed with error -12
    [    0.196642] NET: Registered protocol family 2
    [    0.197307] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
    [    0.197333] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.197400] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.197470] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.197593] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.197621] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.197840] NET: Registered protocol family 1
    [    0.198463] RPC: Registered named UNIX socket transport module.
    [    0.198473] RPC: Registered udp transport module.
    [    0.198482] RPC: Registered tcp transport module.
    [    0.198492] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.198507] PCI: CLS 0 bytes, default 64
    [    0.201549] Initialise system trusted keyrings
    [    0.201711] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [    0.210772] FS-Cache: Netfs 'nfs' registered for caching
    [    0.211291] NFS: Registering the id_resolver key type
    [    0.211314] Key type id_resolver registered
    [    0.211323] Key type id_legacy registered
    [    0.211342] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.213602] Key type asymmetric registered
    [    0.213612] Asymmetric key parser 'x509' registered
    [    0.213723] bounce: pool size: 64 pages
    [    0.213766] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
    [    0.213934] io scheduler noop registered
    [    0.213945] io scheduler deadline registered (default)
    [    0.214103] io scheduler cfq registered
    [    0.214114] io scheduler mq-deadline registered (default)
    [    0.214124] io scheduler kyber registered
    [    0.245231] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
    [    0.245250] brcm-pcie fd500000.pcie: could not get clock
    [    0.245311] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [    0.245349] brcm-pcie fd500000.pcie:   MEM 0x600000000..0x603ffffff -> 0xf8000000
    [    0.298239] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
    [    0.298514] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [    0.298531] pci_bus 0000:00: root bus resource [bus 00-01]
    [    0.298547] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
    [    0.298590] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [    0.298729] pci 0000:00:00.0: PME# supported from D0 D3hot
    [    0.301444] PCI: bus0: Fast back to back transfers disabled
    [    0.301462] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [    0.301665] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [    0.301789] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [    0.302106] pci 0000:01:00.0: PME# supported from D0 D3cold
    [    0.304816] PCI: bus1: Fast back to back transfers disabled
    [    0.304832] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
    [    0.304879] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [    0.304898] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [    0.304969] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.304985] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [    0.305200] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [    0.305375] pcieport 0000:00:00.0: Signaling PME with IRQ 53
    [    0.305532] pcieport 0000:00:00.0: AER enabled with IRQ 53
    [    0.305699] pci 0000:01:00.0: enabling device (0140 -> 0142)
    [    0.309783] iproc-rng200 fe104000.rng: hwrng registered
    [    0.310001] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    0.310508] vc-sm: Videocore shared memory driver
    [    0.310898] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [    0.321083] brd: module loaded
    [    0.330664] loop: module loaded
    [    0.331408] Loading iSCSI transport class v2.0-870.
    [    0.333083] libphy: Fixed MDIO Bus: probed
    [    0.333500] bcmgenet fd580000.genet: failed to get enet clock
    [    0.333516] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
    [    0.333533] bcmgenet fd580000.genet: failed to get enet-wol clock
    [    0.333549] bcmgenet fd580000.genet: failed to get enet-eee clock
    [    0.333571] bcmgenet: Skipping UMAC reset
    [    0.333802] unimac-mdio unimac-mdio.-19: DMA mask not set
    [    0.358238] libphy: bcmgenet MII bus: probed
    [    0.398745] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
    [    0.399659] usbcore: registered new interface driver r8152
    [    0.399727] usbcore: registered new interface driver lan78xx
    [    0.399785] usbcore: registered new interface driver smsc95xx
    [    0.400086] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    0.400116] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [    0.402331] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
    [    0.402634] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 54
    [    0.403490] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [    0.403505] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    0.403517] usb usb1: Product: xHCI Host Controller
    [    0.403529] usb usb1: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
    [    0.403540] usb usb1: SerialNumber: 0000:01:00.0
    [    0.404045] hub 1-0:1.0: USB hub found
    [    0.404123] hub 1-0:1.0: 1 port detected
    [    0.404588] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [    0.404610] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [    0.404629] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [    0.404989] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
    [    0.405002] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    0.405014] usb usb2: Product: xHCI Host Controller
    [    0.405025] usb usb2: Manufacturer: Linux 4.19.97-v7l+ xhci-hcd
    [    0.405036] usb usb2: SerialNumber: 0000:01:00.0
    [    0.405512] hub 2-0:1.0: USB hub found
    [    0.405576] hub 2-0:1.0: 4 ports detected
    [    0.406770] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    0.406960] dwc_otg: FIQ enabled
    [    0.406969] dwc_otg: NAK holdoff enabled
    [    0.406977] dwc_otg: FIQ split-transaction FSM enabled
    [    0.406990] Module dwc_common_port init
    [    0.407199] usbcore: registered new interface driver uas
    [    0.407295] usbcore: registered new interface driver usb-storage
    [    0.407476] mousedev: PS/2 mouse device common for all mice
    [    0.408669] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [    0.410104] sdhci: Secure Digital Host Controller Interface driver
    [    0.410113] sdhci: Copyright(c) Pierre Ossman
    [    0.410510] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [    0.410909] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.413926] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.414081] hidraw: raw HID events driver (C) Jiri Kosina
    [    0.414201] usbcore: registered new interface driver usbhid
    [    0.414210] usbhid: USB HID core driver
    [    0.414973] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
    [    0.416694] [vc_sm_connected_init]: start
    [    0.425567] [vc_sm_connected_init]: end - returning 0
    [    0.426714] Initializing XFRM netlink socket
    [    0.426743] NET: Registered protocol family 17
    [    0.426830] Key type dns_resolver registered
    [    0.427156] Registering SWP/SWPB emulation handler
    [    0.427745] registered taskstats version 1
    [    0.427761] Loading compiled-in X.509 certificates
    [    0.434766] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [    0.434828] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
    [    0.439894] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [    0.440427] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
    [    0.441061] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [    0.441073] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [    0.467117] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.3
    [    0.467196] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.4
    [    0.488400] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    0.490010] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.491617] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.494496] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    0.496102] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.500909] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
    [    0.503275] of_cfs_init
    [    0.503435] of_cfs_init: OK
    [    0.504045] Waiting for root device PARTUUID=ea7d04d6-02...
    [    0.549495] random: fast init done
    [    0.602831] mmc0: new ultra high speed DDR50 SDXC card at address aaaa
    [    0.604016] mmcblk0: mmc0:aaaa SN64G 59.5 GiB
    [    0.605800] mmc1: new high speed SDIO card at address 0001
    [    0.606208]  mmcblk0: p1 p2
    [    0.620891] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [    0.620902] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [    0.768251] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [    0.950892] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [    0.950907] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [    0.950919] usb 1-1: Product: USB2.0 Hub
    [    0.952550] hub 1-1:1.0: USB hub found
    [    0.952839] hub 1-1:1.0: 4 ports detected
    [    1.040132] EXT4-fs (mmcblk0p2): recovery complete
    [    1.061989] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.062035] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.066182] devtmpfs: mounted
    [    1.073873] Freeing unused kernel memory: 2048K
    [    1.074115] Run /sbin/init as init process
    [    2.936095] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
    [    2.939220] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
    [    2.945129] systemd-udevd[264]: Using default interface naming scheme 'v240'.
    [    2.945900] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
    [    2.947655] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
    [    2.965168] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [    2.967329] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [    2.967344] [vc_sm_connected_init]: start
    [    2.974507] [vc_sm_connected_init]: installed successfully
    [    2.980349] media: Linux media interface: v0.10
    [    3.012069] videodev: Linux video capture interface: v2.00
    [    3.044825] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.063292] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.070903] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.079173] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.098430] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [    3.098465] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [    3.099253] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    3.108142] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [    3.108340] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [    3.109702] bcm2835_audio soc:audio: card created with 8 channels
    [    3.113834] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [    3.113865] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [    3.267791] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    3.316891] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    [    3.316991] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [    3.317775] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
    [    3.317788] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    3.317797] [drm] No driver support for vblank timestamp query.
    [    3.317807] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
    [    3.346854] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [    3.382626] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    3.437355] brcmfmac: F1 signature read @0x18000000=0x15264345
    [    3.449952] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    3.450581] usbcore: registered new interface driver brcmfmac
    [    3.690161] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [    3.703438] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar  2 2020 23:30:41 version 7.45.202 (r724630 CY) FWID 01-72f6ece2
    [    3.761680] systemd-udevd[262]: Using default interface naming scheme 'v240'.
    [    4.766319] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    4.963239] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    6.366433] i2c /dev entries driver
    [    7.505825] random: dd: uninitialized urandom read (512 bytes read)
    [    8.826878] 8021q: 802.1Q VLAN Support v1.8
    [    9.007806] brcmfmac: power management disabled
    [  103.608311] random: crng init done
    [  103.704231] bcmgenet: Skipping UMAC reset
    [  103.798630] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
    [  104.264335] NET: Registered protocol family 10
    [  104.265051] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [  104.265144] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [  104.265363] Segment Routing with IPv6
    [  104.444195] Bluetooth: Core ver 2.22
    [  104.444232] NET: Registered protocol family 31
    [  104.444236] Bluetooth: HCI device and connection manager initialized
    [  104.444246] Bluetooth: HCI socket layer initialized
    [  104.444254] Bluetooth: L2CAP socket layer initialized
    [  104.444273] Bluetooth: SCO socket layer initialized
    [  104.485786] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [  104.485792] Bluetooth: BNEP filters: protocol multicast
    [  104.485802] Bluetooth: BNEP socket layer initialized
    [  104.808304] bcmgenet fd580000.genet eth0: Link is Down
    [  106.378022] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [  108.968489] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
    [  108.968533] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [  110.479143] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    MOD-Edit: Code in code-tags gesetzt!
    @SmartesHome Soweit nix auffälliges vom Kernel.
    Was passiert bei
    iobroker status
    • S SmartesHome
      @paul53 Also vom PC aus sehe ich diesen Ordner nicht :(
      SmartesHome
      @paul53 Über WINSCP komme ich nun in die Verzeichnisse und könnte Dateien sichern.Ich müsste nur wissen, was ich sichern muss und wie ich sie im Fall des Falles wiederherstellen kann.
        Was passiert bei
        iobroker status
        SmartesHome
        @Thomas-Braun
        iobroker is not running on this host.
        No iobroker host is running.
        Objects type: file
        States  type: file
        • S SmartesHome
          @SmartesHome
          mount
          Da stimmt glaube ich was mit der SD-Karte nicht.
            @SmartesHome
            mount
            SmartesHome
            @Thomas-Braun
            /dev/mmcblk0p2 on / type ext4 (rw,noatime)
            devtmpfs on /dev type devtmpfs (rw,relatime,size=1867780k,nr_inodes=117763,mode=755)
            sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
            tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=399976k,mode=755)
            tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
            proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
            configfs on /sys/kernel/config type configfs (rw,relatime)
            tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=799940k)
            devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
            /dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
            • S SmartesHome
              @Thomas-Braun
              @SmartesHome Passt. Kann es sein, dass du die Kiste unlängst mal nicht sauber heruntergefahren hast (hart vom Strom genommen)?
              iobroker start
              bringt die obige Meldung, vermute ich?
                iobroker start
                SmartesHome
                @Thomas-Braun
                Eigentlich nicht möglich, dass der Pi hart vom Strom genommen wurde, da er aneiner USV hängt. Die Meldung kam nachdem ich heute mit einem OTA-Flashtool für Tasmota gearbeitet habe.
                Dann kommt die Eingangsmeldung:
                System has not been booted with systemd as init system (PID 1). Can't operate.
                Failed to connect to bus: Der Rechner ist nicht aktiv
                Ich denke, ichsollte die Karte saber formatieren und das System neu aufsetzen...Habe ja nun Zugriff auf die Dateien und kopiere gerade erstmal das iobroker-data verzeichnis. Ich weiß nur nicht, ob ichdie Dateien später einfach wieder drüber kopieren muss oder wie und welche ichwieder integrieren sollte.
                • S SmartesHome
                  @Thomas-Braun
                  SmartesHome
                  @Thomas-Braun ...und vor allem wo ich die Dateien der Visualisierung finde?
                  • S SmartesHome
                    @SmartesHome Keine Ahnung, hab kein vis.
                    systemctl status iobroker
                      SmartesHome
                      @Thomas-Braun Da kommt wieder die Eingangsmeldung :(
                      • S SmartesHome
                        @SmartesHome
                        mount | grep systemd
                          @SmartesHome
                          SmartesHome
                          @Thomas-Braun Keine Meldung
                          • S SmartesHome
                            @SmartesHome Okay, da wird systemd gar nicht angefasst...
                            Vielleicht hat der Fixer ja dafür was in petto. Wobei ich das fast nicht glaube
                            iobroker fix
                            Die Ausgabe von
                            whoami
                            würde mich auch noch interessieren.
                              iobroker fix
                              Die Ausgabe von
                              whoami
                              SmartesHome
                              @Thomas-Braun Verdammte Hacke :)
                              Er läuft wieder....Du bist mein HERO :)
                              Vielen Dank :)
                              • S SmartesHome
                                Vielen Dank :)
                                @SmartesHome Gerne.
                                Aber eine gescheite Backupstrategie darfst du dir dennoch anlesen. Ist Gold wert!
                                  @SmartesHome Gerne.
                                  SmartesHome
                                  @Thomas-Braun Das wird meine erste Handlung werden.
                                  Tausend Dank nochmal :)
                                  • S SmartesHome
                                    @SmartesHome
                                    whoami
                                    liefert?
                                      @SmartesHome
                                      whoami
                                      liefert?
                                      SmartesHome
                                      @Thomas-Braun
                                      pi
                                      • S SmartesHome
                                        @Thomas-Braun
                                        pi
                                        @SmartesHome Okay, halt das so bei. Ich hatte den vagen Verdacht, dass du den Tasmota-Kram evtl. als root ausgeführt haben könntest.
                                          SmartesHome
                                          @Thomas-Braun Nein, das habe ich nicht.
                                          Hatte allerdings gerade nach einen Neustart des Pis den iobroker manuell zu starten. Automatisch geht das nicht mehr.
                                          Es wundert mich eh, dass der Neustart so elendig lange dauert. Ds ging vorher eher ruckzuck. Werde aber die Situation für ein Backup nutzen udn am Wochenende lieber doch noch einmal neu aufsetzen.
