  4. Fehler beim Adapter Update
adapter update fehlerzusammenhang mit sql adapter
4 Beiträge 4 Kommentatoren 760 Aufrufe 3 Beobachtet
  • W Offline
    W Offline
    Werner303
    Beim Updaten von Adaptern erhalte ich immer diese Fehlermeldungen:
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH
    environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying
    to load binding.gyp gyp  ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit
    (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR!
    stack      at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command
    "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build"
    "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas"
    "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0"
    "--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp  ERR! node -v v12.16.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node
    /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build
    --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas
    --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0
    --node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous>
    (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit
    (events.js:310:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at
    Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)node-pre-gyp ERR! System Linux 4.19.75-v7l+node-pre-gyp ERR! command
    "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd
    /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.16.2node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    Diese Meldungen sind noch erheblich mehr wenn ich den SQL Adapter nicht disable. Bis das eigentliche Update erfolgt, vergeht einige Zeit.
    Kann mir jemand helfen? Alle meine Treiber sind up to date.
    SegwayS Thomas BraunT 2 Antworten Letzte Antwort
    • W Werner303
      SegwayS Offline
      SegwayS Offline
      Segway
      schrieb am zuletzt editiert von Segway
      @Werner303
      Ich verweise mal auf die Foren-Regeln Punkt 2c - ein paar mehr Infos braucht man schon um einen Ansatzpunkt zu bekommen.
      Gruß Dirk
      • W Werner303
        @Werner303
        iobroker rebuild canvas --install
        Und was für ein Betriebssystem läuft da? Linux (Debian)?
        • mickymM Offline
          mickymM Offline
          mickym
          ich habe auch bei manchen Adaptern vereinzelt so ein Problem gehabt.
          Ich hab das mit iobroker fix in den Griff bekommen (vorher iobroker stop - danach wieder starten iobroker start)
