<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fehler beim Adapter Update]]></title><description><![CDATA[<p dir="auto">Beim Updaten von Adaptern erhalte ich immer diese Fehlermeldungen:</p>
<pre><code>Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH
environment variableNo package 'pixman-1' foundgyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying
to load binding.gyp gyp  ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit
(/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:310:20)gyp ERR!
stack      at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.75-v7l+gyp ERR! command
"/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build"
"--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas"
"--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0"
"--node_napi_label=node-v72"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp  ERR! node -v v12.16.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node
/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build
--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas
--module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0
--node_napi_label=node-v72' (1)node-pre-gyp ERR! stack     at ChildProcess.&lt;anonymous&gt;
(/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit
(events.js:310:20)node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1021:16)node-pre-gyp ERR! stack     at
Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)node-pre-gyp ERR! System Linux 4.19.75-v7l+node-pre-gyp ERR! command
"/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd
/opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v12.16.2node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
</code></pre>
<p dir="auto">Diese Meldungen sind noch erheblich mehr wenn ich den SQL Adapter nicht disable. Bis das eigentliche Update erfolgt, vergeht einige Zeit.<br />
Kann mir jemand helfen? Alle meine Treiber sind up to date.</p>
]]></description><link>https://forum.iobroker.net/topic/32960/fehler-beim-adapter-update</link><generator>RSS for Node</generator><lastBuildDate>Mon, 04 May 2026 17:58:33 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/32960.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 May 2020 11:45:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fehler beim Adapter Update on Sun, 03 May 2020 20:01:34 GMT]]></title><description><![CDATA[<p dir="auto">ich habe auch bei manchen Adaptern vereinzelt so ein Problem gehabt.<br />
Ich hab das mit iobroker fix in den Griff bekommen (vorher iobroker stop - danach wieder starten iobroker start)</p>
]]></description><link>https://forum.iobroker.net/post/425435</link><guid isPermaLink="true">https://forum.iobroker.net/post/425435</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Sun, 03 May 2020 20:01:34 GMT</pubDate></item><item><title><![CDATA[Reply to Fehler beim Adapter Update on Sun, 03 May 2020 20:01:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/werner303" aria-label="Profile: Werner303">@<bdi>Werner303</bdi></a></p>
<pre><code>iobroker rebuild canvas --install
</code></pre>
<p dir="auto">Und was für ein Betriebssystem läuft da? Linux (Debian)?</p>
]]></description><link>https://forum.iobroker.net/post/425432</link><guid isPermaLink="true">https://forum.iobroker.net/post/425432</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 03 May 2020 20:01:09 GMT</pubDate></item><item><title><![CDATA[Reply to Fehler beim Adapter Update on Sun, 03 May 2020 18:25:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/werner303" aria-label="Profile: Werner303">@<bdi>Werner303</bdi></a></p>
<p dir="auto">Ich verweise mal auf die <a href="https://forum.iobroker.net/rules">Foren-Regeln Punkt 2c</a> - ein paar mehr Infos braucht man schon um einen Ansatzpunkt zu bekommen.</p>
]]></description><link>https://forum.iobroker.net/post/425356</link><guid isPermaLink="true">https://forum.iobroker.net/post/425356</guid><dc:creator><![CDATA[Segway]]></dc:creator><pubDate>Sun, 03 May 2020 18:25:44 GMT</pubDate></item></channel></rss>
