  4. [fixed] Nach Update von js-controller auf 0.8.9 kein Start von iobroker Dienst mehr möglich
57 Beiträge 13 Kommentatoren 11.8k Aufrufe
  • R Offline
    RS_Tobi
    @Nili:
    Das Verzeichnis konnte ich jetzt durch die "casesensitive" Schreibweise wieder löschen.
    Habe dann nochmal den Workaround von Bluefox abgearbeitet.
    Beim letzten Befehl kam dann folgendes als Ergebnis heraus:
    ! klueber@SrvDK-Tools2:/opt/iobroker/node_modules/iobroker.js-controller$ sudo npm install --production npm WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade npm WARN deprecated graceful-fs@2.0.3: graceful-fs version 3 and before will fail on newer node releases. Please update to graceful-fs@^4.0.0 as soon as possible. npm WARN cannot run in wd iobroker.js-controller@0.8.9 node lib/setup.js setup first (wd=/opt/iobroker/node_modules/iobroker.js-controller) mime@1.3.4 node_modules/mime ! daemonize2@0.4.2 node_modules/daemonize2 ! adm-zip@0.4.7 node_modules/adm-zip ! ncp@2.0.0 node_modules/ncp ! semver@4.3.6 node_modules/semver ! node.extend@1.1.5 node_modules/node.extend └── is@3.1.0 ! node-schedule@1.0.0 node_modules/node-schedule ├── long-timeout@0.0.2 └── cron-parser@1.1.0 ! winston@2.2.0 node_modules/winston ├── cycle@1.0.3 ├── stack-trace@0.0.9 ├── eyes@0.1.8 ├── isstream@0.1.2 ├── async@1.0.0 ├── pkginfo@0.3.1 └── colors@1.0.3 ! winston-daily-rotate-file@1.0.1 node_modules/winston-daily-rotate-file └── winston@2.1.1 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, async@1.0.0, pkginfo@0.3.1, colors@1.0.3) ! yargs@3.32.0 node_modules/yargs ├── decamelize@1.2.0 ├── y18n@3.2.1 ├── camelcase@2.1.1 ├── window-size@0.1.4 ├── cliui@3.2.0 (wrap-ansi@2.0.0, strip-ansi@3.0.1) ├── os-locale@1.4.0 (lcid@1.0.0) └── string-width@1.0.1 (strip-ansi@3.0.1, is-fullwidth-code-point@1.0.0, code-point-at@1.0.0) ! iobroker.admin@1.0.2 node_modules/iobroker.admin ├── connect-flash@0.1.1 ├── xtend@4.0.1 ├── cookie-parser@1.4.1 (cookie-signature@1.0.6, cookie@0.2.3) ├── passport-local@1.0.0 (passport-strategy@1.0.0) ├── passport@0.2.2 (pause@0.0.1, passport-strategy@1.0.0) ├── express-session@1.13.0 (cookie-signature@1.0.6, utils-merge@1.0.0, on-headers@1.0.1, cookie@0.2.3, parseurl@1.3.1, depd@1.1.0, crc@3.4.0, uid-safe@2.0.0, debug@2.2.0) ├── body-parser@1.15.0 (content-type@1.0.1, bytes@2.2.0, depd@1.1.0, qs@6.1.0, on-finished@2.3.0, raw-body@2.1.6, http-errors@1.4.0, debug@2.2.0, iconv-lite@0.4.13, type-is@1.6.12) └── express@4.13.4 (escape-html@1.0.3, array-flatten@1.1.1, utils-merge@1.0.0, cookie-signature@1.0.6, content-type@1.0.1, methods@1.1.2, vary@1.0.1, merge-descriptors@1.0.1, fresh@0.3.0, range-parser@1.0.3, etag@1.7.0, parseurl@1.3.1, serve-static@1.10.2, path-to-regexp@0.1.7, cookie@0.1.5, content-disposition@0.5.1, depd@1.1.0, qs@4.0.0, on-finished@2.3.0, finalhandler@0.4.1, debug@2.2.0, proxy-addr@1.0.10, accepts@1.2.13, type-is@1.6.12, send@0.13.1) ! socket.io-client@1.4.5 node_modules/socket.io-client ├── to-array@0.1.4 ├── component-emitter@1.2.0 ├── indexof@0.0.1 ├── object-component@0.0.3 ├── component-bind@1.0.0 ├── backo2@1.0.2 ├── has-binary@0.1.7 (isarray@0.0.1) ├── debug@2.2.0 (ms@0.7.1) ├── socket.io-parser@2.2.6 (isarray@0.0.1, json3@3.3.2, component-emitter@1.1.2, benchmark@1.0.0) ├── parseuri@0.0.4 (better-assert@1.0.2) └── engine.io-client@1.6.8 (yeast@0.1.2, component-emitter@1.1.2, has-cors@1.1.0, component-inherit@0.0.3, xmlhttprequest-ssl@1.5.1, parsejson@0.0.1, parseqs@0.0.2, ws@1.0.1, engine.io-parser@1.2.4) ! socket.io@1.4.5 node_modules/socket.io ├── has-binary@0.1.7 (isarray@0.0.1) ├── debug@2.2.0 (ms@0.7.1) ├── socket.io-parser@2.2.6 (isarray@0.0.1, json3@3.3.2, component-emitter@1.1.2, benchmark@1.0.0) ├── socket.io-adapter@0.4.0 (socket.io-parser@2.2.2) └── engine.io@1.6.8 (base64id@0.1.0, ws@1.0.1, accepts@1.1.4, engine.io-parser@1.2.4) ! prompt@1.0.0 node_modules/prompt ├── revalidator@0.1.8 ├── pkginfo@0.4.0 ├── colors@1.1.2 ├── read@1.0.7 (mute-stream@0.0.6) ├── winston@2.1.1 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, async@1.0.0, pkginfo@0.3.1, colors@1.0.3) └── utile@0.3.0 (deep-equal@0.2.2, async@0.9.2, i@0.3.4, ncp@1.0.1, mkdirp@0.5.1, rimraf@2.5.2) ! tar.gz@1.0.3 node_modules/tar.gz ├── commander@2.9.0 (graceful-readlink@1.0.1) ├── bluebird@2.10.2 ├── tar@2.2.1 (inherits@2.0.1, block-stream@0.0.8) ├── chai@3.5.0 (assertion-error@1.0.1, type-detect@1.0.0, deep-eql@0.1.3) ├── fstream@1.0.8 (inherits@2.0.1, graceful-fs@4.1.3, mkdirp@0.5.1, rimraf@2.5.2) ├── mocha@2.4.5 (escape-string-regexp@1.0.2, commander@2.3.0, diff@1.4.0, growl@1.8.1, supports-color@1.2.0, debug@2.2.0, mkdirp@0.5.1, glob@3.2.3, jade@0.26.3) └── mout@0.11.1 ! request@2.72.0 node_modules/request ├── aws-sign2@0.6.0 ├── forever-agent@0.6.1 ├── tunnel-agent@0.4.2 ├── oauth-sign@0.8.1 ├── is-typedarray@1.0.0 ├── caseless@0.11.0 ├── stringstream@0.0.5 ├── isstream@0.1.2 ├── json-stringify-safe@5.0.1 ├── extend@3.0.0 ├── tough-cookie@2.2.2 ├── node-uuid@1.4.7 ├── qs@6.1.0 ├── combined-stream@1.0.5 (delayed-stream@1.0.0) ├── mime-types@2.1.10 (mime-db@1.22.0) ├── form-data@1.0.0-rc4 (async@1.5.2) ├── aws4@1.3.2 (lru-cache@4.0.1) ├── bl@1.1.2 (readable-stream@2.0.6) ├── hawk@3.1.3 (cryptiles@2.0.5, boom@2.10.1, sntp@1.0.9, hoek@2.16.3) ├── har-validator@2.0.6 (commander@2.9.0, pinkie-promise@2.0.1, chalk@1.1.3, is-my-json-valid@2.13.1) └── http-signature@1.1.1 (assert-plus@0.2.0, jsprim@1.2.2, sshpk@1.8.1) ! npm@2.15.4 node_modules/npm !
    Leider bleibt alles beim alten … ich kann den daemon einfach nicht starten.
    Es bleibt dann wohl doch nichts anderes mehr übrig, als alles neu zu installieren. 😢 😢 😢
    Oder hat noch jemand einen Tipp?
    Danilo `
    Ich hatte eben die selbe Meldung (wie hier oben im Spoiler) erhalten und auch nach dem WORKAROUND gearbeitet.
    Jedoch lies sich mein Deamon wieder starten.
    Ob er noch funktioniert bzw in wie weit, muss ich gleich noch testen…
    Ich habe diesmal nicht den FEHLER gemahct, einfach etwas auszuprobieren um nicht noch mehr zu beschädigen.
    somit habe ich nur den npm cache geleert und danach das WORKAROUND ausprobiert.
    grüße
    • BluefoxB Offline
      BluefoxB Offline
      @Nili:
      Danilo `
      Sieht alles absolut sauber.
      Ich denke es geht um Rechten.
      Was siehst du, wenn:
      cd /opt/iobroker
      sudo chmod 777 * -R
      node node_modules/iobroker.js-controller/controller.js
      Ausführst?
      • N Offline
        N Offline
        Nili
        Da passiert leider gar nichts.
        Ich kann nach dem Absenden des Befehls noch weiter Eingaben machen. Anscheinend wartet er noch auf irgendeinen Befehl.
        Nach etwa 10 Minuten hab ich es dann abgebrochen.
        klueber@SrvDK-Tools2:/opt/iobroker$ node node_modules/iobroker.js-controller/controller.js
        ^Cklueber@SrvDK-Tools2:/opt/iobroker$
        Danilo
          Michmu
          Kurze Info ich habe es mit "WORKAROUND" wieder zum laufen gebracht. Danke für eure Hilfe!!!!! (Meine Freundin hat nichts gemerkt) ;)
          • blauholstenB Offline
            blauholsten
            benutze das Thema gleich um meine Erfahrung mit dem Update auf 8.10 mitzuteilen.
            Nach dem Update aus der Admin Oberfläche, war quasi die Adminoberfläche nicht mehr erreichbar! IOBroker schien aber irgenwie gelaufen zu sein, den der Daemon konnte nach dem Reboot des PI`S gestoppt werden. Beim laden kam statt des Zahnrades ein eigenwilliges Zeichen.
            Sowohl beim Update auf 8.9 sowohl auch auf 8.10 half mir dann der Workaround? …..
            cd /opt/iobroker
            ./iobroker stop
            npm install iobroker.admin
            npm install iobroker.js-controller
            chmod 777 * -R
            iobroker start
            - Alarm Adapter
              Solear
              Es gibt ein Update von 0.8.9 auf 0.8.10 (bei mir auf NUC mit Ubuntu)
              Es passiert:
              $ ./iobroker upgrade self
              npm install iobroker.js-controller --production --prefix "/opt/iobroker" (System call)
              npm
              WARN
              npm
               WARN
              Host "iobroker" (linux) updated
              Execute: chmod 777 -R /opt/iobroker
              Chmod finished. Restart controller
              ERROR: fs.js:549  return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
              Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/../log/restart.log'
                  at Error (native)
                  at Object.fs.openSync (fs.js:549:18)
                  at restartController (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2113:18)
                  at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:212:29
                  at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:263:31)
                  at emitTwo (events.js:87:13)
                  at ChildProcess.emit (events.js:172:7)
                  at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
              ERROR: process exited with code 1</anonymous>
              Hab schnell mein Backup wieder zurückgespielt :lol:
              iobroker als LXC unter Proxmox
              • N Offline
                N Offline
                Nili
                Ich hab genau das selbe Problem.
                Zum Glück teste ich momentan erstmal alles auf einer VM :D
                Komischerweise habe ich das Update einfach nochmals ausgeführt, gleich direkt nach der Fehlermeldung. Dabei dann ohne Fehlermeldung. :?
                Anschließend den Rechner neu gestartet und es lief problemlos.
                Ich habe ja mittlerweile alles neu installiert.
                Ich habe den Rechner wieder genauso benannt und die selbe IP-Adresse vergeben.
                Wenn ich jetzt aber die "objects.json" im "iobroker-data" Verzeichnis vom alten Rechner wieder einspiele (hier sollen doch glaube ich u.a. die Scripte dein sein),
                kann ich den Daemonn zwar problemlos starten, aber die Admin-Seite ist nicht erreichbar.
                Ich habe auch schon mal das komplette "iobroker-data" Verzeichnis zurück kopiert, leider mit dem selben Ergebis.
                Sobald ich das komplette "iobroker" Verzeichnis zurück kopiere, bin ich wieder bei meinem alten Problem, dass ich den Daemon nicht mehr starten kann.
                Kann ich nicht einfach Daten vom alten Rechner zurückkopieren?
                Danilo
                • BluefoxB Offline
                  BluefoxB Offline
                  @Solear:
                  Es passiert:
                  npm
                  WARN
                  npm
                   WARN
                      at Error (native)
                  Hab schnell mein Backup wieder zurückgespielt :lol: `
                  Genau diese Fehler hat 0.8.10 gefixt. Nach dem Rechnerrestart würde es laufen.
                  • BluefoxB Offline
                    BluefoxB Offline
                    @Nili:
                    Danilo `
                    Hoch wahrscheinlich ist dein admin deaktiviert.
                    Was siehst du bei "iobroker list instances" ?
                    Schreib "iobroker start admin"
                      Solear
                      @Bluefox:
                      Genau diese Fehler hat 0.8.10 gefixt. Nach dem Rechnerrestart würde es laufen. `
                      OK. Hab nochmal von 0.8.9 auf 0.8.10 geupdatet und trotz der Fehlermeldungen danach neu gestartet.
                      Klappt alles - keine Fehler zu sehen!
                      Danke! 8-)
                      • N Offline
                        N Offline
                        Nili
                        @Bluefox:
                        Schreib "iobroker start admin" `
                        Das ist das Ergebnis von list instances:
                        system.adapter.admin.0		: admin		-  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.web.0				: web			-  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                        system.adapter.vis.0				: vis			-  enabled
                        system.adapter.hm-rpc.0			: hm-rpc		-  enabled, port: 0
                        system.adapter.hm-rega.0			: hm-rega		-  enabled
                        system.adapter.javascript.0			: javascript		-  enabled
                        Da der admin bereits gestartet war, hat ein erneuter Start keine Änderung gebracht.
                        Mir würde es ja schon ausreichen, wenn ich meine Javascripte und die node-red Scripte wieder herstellen kann,
                        denn ob ich das nochmal so hinbekommen würde, weiß ich leider nicht. :(
                        Danilo
                          aquapro
                          zur Info, bin auch auf 0.8.10 (http://forum.iobroker.net/viewtopic.php?f=17&t=2575&start=20#p24715)
                          Tino
                          <size size="85">BananaPi / Jessie / ioBroker deinstalliert, keine Upgradesicherheit</size>
                          • ThisoftT Offline
                            ThisoftT Offline
                            Thisoft
                            Auch ich bin auf 0.8.10.
                            Musste den "Workaround" über
                            anwenden weil das normale Upgrade auf Fehler lief. Aber seitdem alles OK.
                            22 HM-Geräte; PivCCU2 auf RasPi
                            ioBroker-Multihost; Ubuntu-Master auf Intel-Atom und 3 RasPi-Clients
                            • R Offline
                              rascal
                              Damit hat es bei mir auch geklappt, auf Ubuntu und Raspian.. War mutig, dass ganze über VPN von meinem Smartphone aus [emoji13]
                              Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
                                Michmu
                                Hi Leute,
                                ich habe meinen Admin leider immer noch nicht zum laufen bekommen. Mein Problem ist glaub ich der Node.js
                                root@cubietruck:~# sudo apt-get install nodejs
                                Reading package lists... Done
                                Building dependency tree
                                Some packages could not be installed. This may mean that you have
                                requested an impossible situation or if you are using the unstable
                                distribution that some required packages have not yet been created
                                or been moved out of Incoming.
                                The following information may help to resolve the situation:
                                The following packages have unmet dependencies:
                                 nodejs : Depends: libc6 (>= 2.16) but 2.13-38+deb7u10 is to be installed
                                          Depends: libstdc++6 (>= 5.2) but 4.7.2-5 is to be installed
                                E: Unable to correct problems, you have held broken packages.
                                root@cubietruck:~# node --version
                                node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by node)
                                node: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.16' not found (required by node)
                                root@cubietruck:~#
                                Kann mir jemand n Tipp geben ?
                                Gruß Michael
                                  Ja, sieht nach nodejs Problem aus.
                                  Weisst du noch welche Version du hattest - wird ja nicht mehr ausgegeben :(
                                  Welche Hardware, Weches OS?
                                    Michmu
                                    Cubietruck 3
                                    ARMBIAN Debian GNU/Linux 7 (wheezy) 3.4.112-sun7i
                                    Die version weiß ich leider nichtmehr…
                                      wenn du mutig bist machst du ein
                                      sudo apt-get purge nodejs
                                      und installierts nodejs neu:
                                      wget http://node-arm.herokuapp.com/node_archive_armhf.deb
                                          sudo dpkg -i node_archive_armhf.deb
                                          sudo apt-get install build-essential
                                          reboot
                                        Michmu
                                        root@cubietruck:/opt/iobroker# ./iobroker start
                                        iobroker controller daemon already running. PID: 2052
                                        aber ich komm trotzdem nicht drauf
                                        root@cubietruck:/opt/iobroker# iobroker list instances
                                        events.js:85
                                              throw er; // Unhandled 'error' event
                                        Error: listen EADDRINUSE
                                            at exports._errnoException (util.js:746:11)
                                            at Server._listen2 (net.js:1156:14)
                                            at listen (net.js:1182:10)
                                            at Server.listen (net.js:1267:5)
                                            at _initWebServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2620:24)
                                            at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:147:9
                                            at new ObjectsInMemServer (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:154:7)
                                            at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2256:27)
                                            at Timer.listOnTimeout (timers.js:119:15)
                                        root@cubietruck:/opt/iobroker# iobroker start admin
                                        events.js:85
                                        • derAugeD Offline
                                          derAugeD Offline
                                          derAuge
                                          versuch mal von der Konsole
                                          • ps -A | grep " io.*"
                                          Jürgen
