  4. [Neuer Adapter] Life360
adapterlife360geopositionpräsenzmelder
708 Beiträge 85 Kommentatoren 339.8k Aufrufe 70 Beobachtet
    Wenn ich versuche den Adapter im ioBroker anzulegen scheitere ich. Hier die Debug Ausgabe:
    $ ./iobroker url "https://github.com/MiGoller/ioBroker.life360/tree/master" --debug
    install https://github.com/MiGoller/ioBroker.life360/tree/master/tarball/49f4cf4b4fc4abf2d818d662afefcd28705f6a22
    NPM version: 6.14.3
    npm install https://github.com/MiGoller/ioBroker.life360/tree/master/tarball/49f4cf4b4fc4abf2d818d662afefcd28705f6a22 --loglevel error --prefix "/opt/iobroker" (System call)
    npm
     ERR! code E404
    npm
     ERR! 404 Not Found - GET https://github.com/MiGoller/ioBroker.life360/tree/master/tarball/49f4cf4b4fc4abf2d818d662afefcd28705f6a22npm ERR! 404 npm ERR! 404  'https://github.com/MiGoller/ioBroker.life360/tree/master/tarball/49f4cf4b4fc4abf2d818d662afefcd28705f6a22' is not in the npm registry.
    npm ERR! 404 Your package name is not valid, because npm ERR! 404  1. name can only contain URL-friendly charactersnpm ERR! 404  2. name can no longer contain capital lettersnpm ERR! 404 npm
     ERR! 404 Note that you can also install from anpm ERR! 404 tarball, folder, http url, or git url.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-03-29T15_32_16_720Z-debug.log
    upload [18] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/words.js words.js application/javascript
    upload [17] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/tsconfig.json tsconfig.json application/json
    upload [16] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/style.css style.css text/css
    upload [15] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/life360.png life360.png image/png
    upload [14] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/ioBroker.life360.settings.myplaces.png  image/png
    upload [13] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/ioBroker.life360.settings.life360.png  image/png
    upload [12] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/ioBroker.life360.settings.integration.png  image/png
    upload [11] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/index_m.html index_m.html text/html
    upload [10] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] life360.admin /opt/iobroker/node_modules/iobroker.life360/admin/admin.d.ts admin.d.ts video/mp2t
    process exited with code 0
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    @Ken-Popper Hi, installierst du den Adapter über die Weboberfläche heraus?
    Irgendwie ein komischer Aufruf der Installation...
    • NegaleinN
      NegaleinN
      Negalein
      hab mir gerade die App installiert.
      Gibt es einen Trick/Möglichkeit, den Zonenradius kleiner als 76m einzustellen?
      ° Fixer ---> iob fix
        @ilovegym Ja über die Web-Oberfläche vom ioBroker. Unter Adapter und dann über "installieren aus eigener URL"
        • C cb187
          Funktioniert auf anhieb, aber cool wäre wenn eine Zeile drüber noch true oder false wir im tr064 adapter stehen würde.So hätte man mehr überblick im script.So steht immer nur present da.
          Aber sonst top Arbeit.
          MiGollerM
          MiGollerM
          MiGoller
          @cb187 Hey. Danke für das Feedback. Der Wert sollte eigentlich truebzw. false anzeigen, je nachdem ob die die betreffende Person sich im entsprechenden Kreis befindet. Ist das bei Dir nicht der Fall? Oder meinst Du die Bezeichnung "Present"? Beides kann ich überprüfen.
          ioBroker auf Intel Atom x5-Z8350 mit KNX, Gardena, Roomba, MQTT, Sonoff, Life360
          • E edonisXP
            leider funktioniert das Ganze bei mir nicht so recht.
            Wenn ich die Kreise in der App anlege erscheinen zwar die Kreise im iobroker aber keine Unterordner wo Mitglieder zu sehen sind und demzufolge auch nicht der entscheidende Datenpunkt isPresent.
            Nun habe ich im Adapter selber ein MyPlaces angelegt, dieser erscheint auch in den Objekten und auch der Datenpunkt isPresent wird im Unterordner angelegt.
            Aber leider wird der Wert nach frühestens 5 Minuten aktualisiert oder auch gar nicht, der iobroker ruft zwar alle 30sek die Daten ab, so wie ich es voreingestellt habe, aber die Daten scheinen von der App nicht richtig übermittelt zu werden.
            Hat jemand hier eine Idee ?
            MiGollerM
            MiGollerM
            MiGoller
            @edonisXP Hey. Danke für das Feedback. Das Verhalten der Life360 App kenne ich aktuell sowohl von Android wie auch von iOS Geräten. Die Maßnahmen der Hersteller zum Energiesparen schlagen gerade bei den Positions- und Ortungsinformationen durch, die Life360 benötigt. Nach iOS Upgrades erhalte ich permanent Meldungen, ob Life360 wirklich immer im Hintergrund die Postionsdaten abfragen darf. Da dann auf "Immer" einstellen. Bei Android sieht das je nach Version und Hersteller anders aus. Huawei / Honor haben da ganz tolle Ideen, wie sich Strom sparen lässt. Da gibt es aber aktuell viele Anleitungen, wie das genau in welcher Kombination zu schaffen ist.
            Bitte einmal testen, ob sich das Verhalten sofort bessert, wenn das Gerät an das Netzteil angeschlossen wird.
            • R R1Snake
              Hab die Lösung gefunden.
              Einfach den Ländercode und die Handynummer in den Einstellungen löschen. Dann gehts
              MiGollerM
              MiGollerM
              MiGoller
              @R1Snake , @ThimThaler : Hey. Sorry, sollte ich besser dokumentieren. Danke. Genau das ist die Lösung.
              • M
                M
                mikiline
                bekomme seit Update JS-Controller (3.0.18 oder auch schon eine version vorher) folgende Meldung
                Ist das problem bereits bekannt oder ich habe etwas falsch?
                Herzlichen Dank
                MiGollerM 1 Antwort Letzte Antwort
                • M mikiline
                  Herzlichen Dank
                  MiGollerM
                  MiGollerM
                  MiGoller
                  Hey @mikiline,
                  Vielen Dank für das Feedback. Bislang ist mir das noch nicht gemeldet worden. Ich werde mal schauen, was die Ursache sein könnte.
                  Eigentlich sollte der Zeitstempel der letzten Positionsbestimmung einer Person in einem ioBroker Datenpunkt gespeichert werden. Folgende Infos würden mir helfen?
                  • Hast Du eine Person bzw. einen Kontakt in einem Deiner Kreise, die das Teilen der Positionen in der Mobile-App deaktiviert hat?
                  • Wie sieht die Darstellung in der Web-Anwendung im Browser aus? Siehst Du die Position aller Mitglieder Deiner Kreise? Sieht das Ergebnis wie erwartet aus?
                  • Hast Du in der Konfiguration des Adapters auf den Reiter "Integration" die Standortverfolgung aktiviert?
                  Viele Grüße,
                  MiGoller
                  • MiGollerM MiGoller
                    Hey @mikiline,
                    Viele Grüße,
                    MiGoller
                    M
                    M
                    mikiline
                    @MiGoller
                    Hi ;)
                    also angehakt ist alles. Eine person hat das Teilen auf "Aus" und im Webbrowser sieht es OK aus, bis auf die Person die auf "Aus" ist, sind alle da.
                    Falls Du prüfen kannst wer die Standortmitteilung auf "Aus" hat und dies der Fehler sein sollte, kannst du das evtl mit auswerten?
                    Danke!
                    • M mikiline
                      @MiGoller
                      Hi ;)
                      Danke!
                      MiGollerM
                      MiGollerM
                      MiGoller
                      Hey @mikiline ,
                      alles klar. Vielen Dank für das Prüfen der Einstellung. Es ist das, was ich vermutet hatte. Ich werde heute Abend mal den Code etwas anpassen, dass hier die Fehlerbehandlung deutlich besser sein wird.
                      In einem zweiten nachgelagerten Schritt werde ich dann schauen, wie ich das in die Darstellung einbaue, ob das Teilen der Position in einer Mobile-App deaktiviert ist. Nur ein Hinweis, ich habe auch schon Daten von Life360 gesehen, dass mehrere Mobile-Apps Standortdaten liefern. Das Gerät, das immer an einem Ort war, lieferte die Standortdaten, auf dem Hauptgerät des Benutzers war das Teilen der Position deaktiviert. Das konnte ich aus Sicht der Daten aber nicht unterscheiden.
                      Viele Grüße,
                      MiGoller
                      • MiGollerM
                        MiGollerM
                        MiGoller
                        schrieb am zuletzt editiert von MiGoller
                        ich habe eine neue Version des Adapters veröffentlicht und würde mich über Feedback freuen. Gem. der Anforderungen an das Testen von Adaptern ( https://forum.iobroker.net/topic/26085/richtlinien-für-die-kategorie-tester ) möchte ich den Thread mit Euch gemeinsam unter https://forum.iobroker.net/topic/32718/test-adapter-life360-v0-2-x-github-npm weiterführen.
                        @mikiline : Die Ursache für den Fehler habe ich gefunden: Es war das Nicht-Teilen der Position eines Benutzers. Das hatte ich nicht berücksichtigt. Es gibt jetzt auch einen neuen Datenpunkt isSharingLocation für die einzelnen Personen life360.0.people.xxx.isSharingLocation, der anzeigt, ob ein Benutzer seinen Standort teilt.
                        Viele Grüße,
                        MiGoller
                          Viele Grüße,
                          MiGoller
                          M
                          M
                          mikiline
                          @MiGoller
                          super, Danke ;) Tolle Arbeit!
                          • S
                            S
                            Sascha12
                            schrieb am zuletzt editiert von Sascha12
                            @MiGoller Danke, super Adapter.
                            So wie ich das sehe funktioniert alles...
                            Hat nun jemand eine Ansicht für VIS gebaut?
                            Da ich in VIS garnichts kann, da ich Habpanel benutze, wäre ich für alles dankbar... ;-)
                            LG Sascha
                            PS: Noch eine Frage: Es wäre für mich in Habpanel von Vorteil, unter "People" und dann der Person auch den aktuellen Ort der Person abgelegt zu bekommen als Datenpunkt. Geht das, oder übersehe ich vielleicht sogar etwas?
                            • S Sascha12
                              LG Sascha
                              MiGollerM
                              MiGollerM
                              MiGoller
                              @Sascha12 Vielen Dank für das Feedback. Es freut mich, dass Du auch einen Nutzen aus dem Adapter ziehen kannst.
                              Zu Deiner Frage: Das würde generell gehen. Bislang bilde ich das im Adapter so ab, dass Du ausgehend von einem "Place" sehen kannst, wer dort gerade anwesend ist. Diese Information findest Du Stand heute nicht unter den Personen; eine Visualisierung hatte ich mit den "Places" unter Personen auch noch nicht im Blick, aber warum nicht. Bislang findest Du unter einer Person die GPS-Koordinaten z.B. für die Anzeige auf einer Karte, für Berechnungen, etc. . Wenn der Bedarf da ist, nehme ich das aber gerne mit für die kommenden Anpassungen und Erweiterung mit auf. Gerne darfst Du auch direkt ein Issue unter https://github.com/MiGoller/ioBroker.life360/issues eröffnen, dann habe ich da alles auf der Liste.
                              Aktuell bleibt Dir dann aber z.B. die Möglichkeit, mit einem Skript die Information aus dem "Places"-Bereich und dem "People"-Bereich für die Visualisierung zusammenzutragen, so dass Du an einer Stelle alle Informationen für HabPanel hast.
                              Hilft Dir das weiter?
                              VG, MiGoller
                                VG, MiGoller
                                S
                                S
                                Sascha12
                                @MiGoller Danke Dir. Genau das Script habe ich mir in der Zwischenzeit bereits angelegt ;-)
                                LG Sascha
                                  @Wildbill Hallo. Das kenne ich. Inhouse-Präsenzerkennung habe ich bislang aus einer Kombination von WLAN-Erreichbarkeit (Meraki) sowie Bluetooth Beacons über mehrere ESP32 Scanner Nodes und MQTT realisiert.
                                  O
                                  O
                                  oetti
                                  @MiGoller
                                  Danke für den Life360 Adapter - läuft super 👍
                                  OT
                                  Hast du zum Thema Bluetooth Beacons / ESPs irgendetwas lesbares hinterlegt? Das Thema finde ich ebenfalls sehr interessant, zumal Inhouse-Präsenz noch ganz andere Herausforderungen hat.
                                  Ich hatte bis dato nur Versuche mit WLAN (Mikrotik + Capsman) gemacht, um rauszufinden, welches Device an welchem AP angemeldet ist. Funktioniert, allerdings nur, wenn man das Handy in der
                                  Tasche hat 😁
                                  ioBroker 4.0.10 (master) (CentOS 7 auf ESXi 6.7) | ioBroker 4.0.10 (Slave #1) VM | ioBroker 4.0.10 (Slave #2) (RPI 3)
                                  • O oetti
                                    @MiGoller
                                    OT
                                    Tasche hat 😁
                                    MiGollerM
                                    MiGollerM
                                    MiGoller
                                    @oetti Vielen Dank für das Feedback.
                                    Bzgl. des Beacons und der ESPs schaue ich mal nach, wo ich den Code habe. Den kann ich dann gern auf Github oder Gitlab teilen; aber ich muss Dich warnen, das war wirklich schnell und schmutzig. ;-)
                                    Ich bin mir in der Zwischenzeit nicht mehr so sicher, ob diese Art der Inhouse-Präsenz für mich zielführend ist. Ich habe es als Komfortmerkmal erlebt, das toll ist, wenn es funktioniert. Werden die Beacons nicht schnell genug wieder erkannt, griff bei mir immer der "Automatismus": Works as designed, nur dass der WAF gegen minus Unendlich ging.
                                      J
                                      J
                                      Jaschkopf
                                      @MiGoller Moin. Hab deinen Adapter gerade installiert und mir ein Konto auf der Android App eingerichtet. Leider kann der Adapter keine Verbindung herstellen mit der Fehlermeldung das die Credentials falsch sind. DIe stimmen aber zu 100%. weder mit der Email, noch mit der Handynummer bekomme ich eine Verbindung (natürlich nicht beides gleichzeitig sondern nacheinander getestet). Hat Life360 vielleicht die API geändert? Hier das Log:
                                      2020-09-15 16:32:12.245 - info: host.iobroker instance system.adapter.life360.1 started with pid 14607
                                      2020-09-15 16:32:13.372 - info: life360.1 (14607) starting. Version 0.2.11 in /opt/iobroker/node_modules/iobroker.life360, node: v12.18.3, js-controller: 3.1.6
                                      2020-09-15 16:32:13.389 - info: life360.1 (14607) Polling enabled every 60 seconds.
                                      2020-09-15 16:32:14.263 - error: life360.1 (14607) Connection established but failed to authenticate. Check your credentials!
                                      2020-09-15 16:32:14.266 - info: life360.1 (14607) Waiting for online operations to finish ...
                                      2020-09-15 16:32:14.268 - error: life360.1 (14607) Error: Error: Connection established but failed to authenticate. Check your credentials!
                                      2020-09-15 16:32:14.269 - warn: life360.1 (14607) No data received from Life360 cloud services!
                                      Das System läuft auf einer Debian 10.5.0 VM in Proxmox mit Node v12.18.3 und NPM 6.14.6.
                                      Gruß Jaschkopf
                                      ? J 2 Antworten Letzte Antwort
                                      • J Jaschkopf
                                        Gruß Jaschkopf
                                        @Jaschkopf vielleicht n Leerzeichen in den credentials ausversehen drin oder hinten dran - da bin ich auch schon wahnsinnig geworden.. copy-paste war böse..?
                                        Der Adapter läuft bei mir einwandfrei.. die haben nix geändert.
                                        • J Jaschkopf
                                          Gruß Jaschkopf
                                          J
                                          J
                                          Jaschkopf
                                          @MiGoller Hab den Fehler schon gefunden. Offensichtlich schmeckt es dem Adapter nicht wenn das Passwort Sonderzeichen enthält. Jetzt mit einem neuen PW mit Buchstaben (Groß+Klein) und Zahlen funktioniert es ;)
                                          Gruß Jaschkopf
                                          33.2k
                                          84.3k
