  4. Zigbee Adapter startet nicht mehr
zigbee proxmox nuc
6 Beiträge 3 Kommentatoren 855 Aufrufe 3 Beobachtet
    toki1973
    Mein USB Port und somit der Zigbee Stick wir auf meinerm Proxmox NUC nicht mehr erkannt. Was kann ich tun? Könnte sein das dass Problem nach einem Proxmox Upgrade aufgetaucht ist.
    zigbee.0
    2020-04-12 09:42:00.073
    error
    (14551) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/z
    zigbee.0
    2020-04-12 09:42:00.072
    error
    (14551) Failed to start Zigbee
    zigbee.0
    2020-04-12 09:41:59.942
    info
    (14551) Starting Zigbee...
    zigbee.0
    2020-04-12 09:41:59.941
    info
    (14551) Try to reconnect. 1 attempts left
    zigbee.0
    2020-04-12 09:41:49.940
    error
    (14551) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStack
    zigbee.0
    2020-04-12 09:41:49.939
    error
    zigbee.0
    2020-04-12 09:41:42.698
    info
    zigbee.0
    2020-04-12 09:41:42.674
    info
    (14551) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
    host.iobrokernuc
    2020-04-12 09:41:40.979
    info
    instance system.adapter.zigbee.0 started with pid 14551
    host.iobrokernuc
    2020-04-12 09:41:40.967
    info
    "system.adapter.zigbee.0" enabled
    host.iobrokernuc
    2020-04-12 09:41:38.754
    info
    instance system.adapter.zigbee.0 terminated with code 156 (156)
    host.iobrokernuc
    error
    Caught by controller[0]: (node:1870) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proces
    host.iobrokernuc
    error
    Caught by controller[0]: (node:1870) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by re
    host.iobrokernuc
    error
    Caught by controller[0]: at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7226:22)
    host.iobrokernuc
    error
    Caught by controller[0]: at Zigbee.emit (events.js:198:13)
    host.iobrokernuc
    error
    Caught by controller[0]: at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:317:41)
    host.iobrokernuc
    error
    Caught by controller[0]: at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:293:20)
    host.iobrokernuc
    2020-04-12 09:41:38.753
    error
    Caught by controller[0]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:181:42)
    host.iobrokernuc
    error
    Caught by controller[0]: at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:123:43)
    host.iobrokernuc
    error
    Caught by controller[0]: at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:195:49)
    host.iobrokernuc
    error
    Caught by controller[0]: at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:218:31)
    host.iobrokernuc
    error
    Caught by controller[0]: at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:165:16)
    host.iobrokernuc
    error
    Caught by controller[0]: at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:145:55)
    host.iobrokernuc
    error
    Caught by controller[0]: (node:1870) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'getEntries' of null
    NUC, PROXMOX, Grafana, Influx, Unify
    • mickymM Offline
      mickymM Offline
      mickym
      Bei mir startet der Adapter, wenn ich den Stick anschließend im laufenden Betrieb ausstecke und dann wieder anstecke und nur den Adapter neu starte.
      Ansonsten sieht die Fehlermeldung so aus, wie ich auch schon gemeldet hatte : https://forum.iobroker.net/topic/32137/zigbee-cc2531-stick-beim-hochfahren-des-adapters-disabled
      und anscheinend auch in diesem Thread:
      https://forum.iobroker.net/topic/31986/zigbee-adapter-failed-to-start
        toki1973
        So, bin nun einen Schritt weiter. der Adapter startet wieder und einige Geräte sind wieder verbunden. Ein paar fuktionieren nicht und haben unter Info keinen "Interviewed" State mehr. Also wollte ich sie löschen und neu Pairen. Allerdings werden sie beim Löschen nicht entfernt. Ich hab beide Löscharten (für lost Devices) getestet und nach dem Löschen gespreichert sowie den Adapter neu gestartet.
        Funktioniert das Löschen von Devices bei euch ohne Probleme?
        • T toki1973
          arteckA Offline
          arteckA Offline
          arteck
          @toki1973 steht im Adapter wiki..
          https://github.com/ioBroker/ioBroker.zigbee/wiki/FAQ-Video
          • arteckA arteck
            toki1973
            schrieb am zuletzt editiert von toki1973
            @arteck Super vielen Dank für den Tipp - Das hatte ich nicht gewusst das man nach dem Löschen nochmal Pairen muss um den Sensor abzumelden. Jetzt sehe ich zumindest den Löschversuch der aber leider auch fehl schlägt.
             Failed to do action 0x00158d00042476a3 lumi.sensor_motion.aq2, attempt 1 (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/n
            z
            Kann es damit zusammenhängen das der Senso nicht den "interviewed" Status hat? Ich hab eeinige Geräte die diesen Status haben. Bedeutet er das sie nicht gepairt sind oder nur das sie aktuell nicht erreichbar sind?
            Ich weiß das die Netzwerkkarte keine wirklichen Status über die Geräte gibt. Aber sie sah schon deutlich besser aus :(
            • T toki1973
              z
              arteckA Offline
              arteckA Offline
              arteck
              @toki1973 Adapter version ?
