<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Zigbee Adapter startet nicht mehr]]></title><description><![CDATA[<p dir="auto">Mein USB Port und somit der Zigbee Stick wir auf meinerm Proxmox NUC nicht mehr erkannt. Was kann ich tun? Könnte sein das dass Problem nach einem Proxmox Upgrade aufgetaucht ist.</p>
<pre><code>zigbee.0
2020-04-12 09:42:00.073
error
(14551) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.&lt;anonymous&gt; (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/z
zigbee.0
2020-04-12 09:42:00.072
error
(14551) Failed to start Zigbee
zigbee.0
2020-04-12 09:41:59.942
info
(14551) Starting Zigbee...
zigbee.0
2020-04-12 09:41:59.941
info
(14551) Try to reconnect. 1 attempts left
zigbee.0
2020-04-12 09:41:49.940
error
(14551) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.&lt;anonymous&gt; (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStack
zigbee.0
2020-04-12 09:41:49.939
error
zigbee.0
2020-04-12 09:41:42.698
info
zigbee.0
2020-04-12 09:41:42.674
info
(14551) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.19.0
host.iobrokernuc
2020-04-12 09:41:40.979
info
instance system.adapter.zigbee.0 started with pid 14551
host.iobrokernuc
2020-04-12 09:41:40.967
info
"system.adapter.zigbee.0" enabled
host.iobrokernuc
2020-04-12 09:41:38.754
info
instance system.adapter.zigbee.0 terminated with code 156 (156)
host.iobrokernuc
error
Caught by controller[0]: (node:1870) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js proces
host.iobrokernuc
error
Caught by controller[0]: (node:1870) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by re
host.iobrokernuc
error
Caught by controller[0]: at stop (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7226:22)
host.iobrokernuc
error
Caught by controller[0]: at Zigbee.emit (events.js:198:13)
host.iobrokernuc
error
Caught by controller[0]: at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:317:41)
host.iobrokernuc
error
Caught by controller[0]: at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:293:20)
host.iobrokernuc
2020-04-12 09:41:38.753
error
Caught by controller[0]: at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:181:42)
host.iobrokernuc
error
Caught by controller[0]: at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:123:43)
host.iobrokernuc
error
Caught by controller[0]: at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:195:49)
host.iobrokernuc
error
Caught by controller[0]: at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:218:31)
host.iobrokernuc
error
Caught by controller[0]: at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:165:16)
host.iobrokernuc
error
Caught by controller[0]: at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:145:55)
host.iobrokernuc
error
Caught by controller[0]: (node:1870) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'getEntries' of null
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/32159/zigbee-adapter-startet-nicht-mehr</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 20:40:27 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/32159.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Apr 2020 07:45:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Zigbee Adapter startet nicht mehr on Thu, 16 Apr 2020 04:29:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/toki1973" aria-label="Profile: toki1973">@<bdi>toki1973</bdi></a> Adapter version ?</p>
]]></description><link>https://forum.iobroker.net/post/413119</link><guid isPermaLink="true">https://forum.iobroker.net/post/413119</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Thu, 16 Apr 2020 04:29:49 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter startet nicht mehr on Mon, 13 Apr 2020 09:23:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a> Super vielen Dank für den Tipp - Das hatte ich nicht gewusst das man nach dem Löschen nochmal Pairen muss um den Sensor abzumelden. Jetzt sehe ich zumindest den Löschversuch der aber leider auch fehl schlägt.</p>
<pre><code> Failed to do action 0x00158d00042476a3 lumi.sensor_motion.aq2, attempt 1 (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms at Timeout.object.timer.setTimeout [as _onTimeout] (/opt/iobroker/n
z
</code></pre>
<p dir="auto">Kann es damit zusammenhängen das der Senso nicht den "interviewed" Status hat? Ich hab eeinige Geräte die diesen Status haben. Bedeutet er das sie nicht gepairt sind oder nur das sie aktuell nicht erreichbar sind?</p>
<p dir="auto"><img src="/assets/uploads/files/1586769352388-c7c54099-dc7b-4662-a2f9-5a4251c4f190-image.png" alt="c7c54099-dc7b-4662-a2f9-5a4251c4f190-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Ich weiß das die Netzwerkkarte keine wirklichen Status über die Geräte gibt. Aber sie sah schon deutlich besser aus :(<br />
<img src="/assets/uploads/files/1586769812884-c57fed46-150f-4e9e-b9cd-9e717e8969b4-image.png" alt="c57fed46-150f-4e9e-b9cd-9e717e8969b4-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.iobroker.net/post/411036</link><guid isPermaLink="true">https://forum.iobroker.net/post/411036</guid><dc:creator><![CDATA[toki1973]]></dc:creator><pubDate>Mon, 13 Apr 2020 09:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter startet nicht mehr on Mon, 13 Apr 2020 07:37:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/toki1973" aria-label="Profile: toki1973">@<bdi>toki1973</bdi></a> steht im Adapter wiki..</p>
<p dir="auto"><a href="https://github.com/ioBroker/ioBroker.zigbee/wiki/FAQ-Video" rel="nofollow ugc">https://github.com/ioBroker/ioBroker.zigbee/wiki/FAQ-Video</a></p>
]]></description><link>https://forum.iobroker.net/post/410943</link><guid isPermaLink="true">https://forum.iobroker.net/post/410943</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Mon, 13 Apr 2020 07:37:17 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter startet nicht mehr on Mon, 13 Apr 2020 06:07:19 GMT]]></title><description><![CDATA[<p dir="auto">So, bin nun einen Schritt weiter. der Adapter startet wieder und einige Geräte sind wieder verbunden. Ein paar fuktionieren nicht und haben unter Info keinen "Interviewed" State mehr. Also wollte ich sie löschen und neu Pairen. Allerdings werden sie beim Löschen nicht entfernt. Ich hab beide Löscharten (für lost Devices) getestet und nach dem Löschen gespreichert sowie den Adapter neu gestartet.</p>
<p dir="auto">Funktioniert das Löschen von Devices bei euch ohne Probleme?</p>
]]></description><link>https://forum.iobroker.net/post/410916</link><guid isPermaLink="true">https://forum.iobroker.net/post/410916</guid><dc:creator><![CDATA[toki1973]]></dc:creator><pubDate>Mon, 13 Apr 2020 06:07:19 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee Adapter startet nicht mehr on Sun, 12 Apr 2020 09:17:28 GMT]]></title><description><![CDATA[<p dir="auto">Bei mir startet der Adapter, wenn ich den Stick anschließend im laufenden Betrieb ausstecke und dann wieder anstecke und nur den Adapter neu starte.</p>
<p dir="auto">Ansonsten sieht die Fehlermeldung so aus, wie ich auch schon gemeldet hatte : <a href="https://forum.iobroker.net/topic/32137/zigbee-cc2531-stick-beim-hochfahren-des-adapters-disabled">https://forum.iobroker.net/topic/32137/zigbee-cc2531-stick-beim-hochfahren-des-adapters-disabled</a><br />
und anscheinend auch in diesem Thread:<br />
<a href="https://forum.iobroker.net/topic/31986/zigbee-adapter-failed-to-start">https://forum.iobroker.net/topic/31986/zigbee-adapter-failed-to-start</a></p>
]]></description><link>https://forum.iobroker.net/post/410407</link><guid isPermaLink="true">https://forum.iobroker.net/post/410407</guid><dc:creator><![CDATA[mickym]]></dc:creator><pubDate>Sun, 12 Apr 2020 09:17:28 GMT</pubDate></item></channel></rss>
