  4. JavaScript
  5. IP Devices im Netzwerk - HTML Tabelle vis, Iqontrol
javascripttemplate
493 Beiträge 26 Kommentatoren 169.3k Aufrufe 41 Beobachtet
  • Sky66766S Sky66766
    Proxmox Linux
    nmap ist installiert
    und /etc/sudoers.d/iobroker-own
    eingetragen
    liv-in-skyL
    liv-in-skyL
    #169
    @Sky66766 mach mal diese beiden schrägstriche weg und schau was dann im log kommt -
    kommt dann sowas?
    Sky66766S 1 Antwort Letzte Antwort
    • liv-in-skyL liv-in-sky
      kommt dann sowas?
      Sky66766S
      Sky66766S
      Sky66766
      #170
      @liv-in-sky
      nein es bleibt so
      javascript.0	2020-04-10 11:55:20.354	error	(953) at Timer.processTimers (timers.js:223:10)
      javascript.0	2020-04-10 11:55:20.354	error	(953) at listOnTimeout (timers.js:263:5)
      javascript.0	2020-04-10 11:55:20.354	error	(953) at tryOnTimeout (timers.js:300:5)
      javascript.0	2020-04-10 11:55:20.354	error	(953) at ontimeout (timers.js:438:13)
      javascript.0	2020-04-10 11:55:20.354	error	(953) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2077:34)
      javascript.0	2020-04-10 11:55:20.354	error	(953) at Object.<anonymous> (script.js.02_javascript.oliver_scripte.ping_ip_devices2:230:14)
      javascript.0	2020-04-10 11:55:20.354	error	(953) Error in callback: TypeError: Cannot read property 'includes' of undefined
      13:54:54.016	info	javascript.0 (953) Stop script script.js.02_javascript.oliver_scripte.ping_ip_devices2
      13:55:00.346	info	javascript.0 (953) Start javascript script.js.02_javascript.oliver_scripte.ping_ip_devices2
      13:55:00.352	info	javascript.0 (953) script.js.02_javascript.oliver_scripte.ping_ip_devices2: exec is not available. Please enable "Enable Exec" option in instance settings
      13:55:00.352	info	javascript.0 (953) script.js.02_javascript.oliver_scripte.ping_ip_devices2: registered 0 subscriptions and 1 schedule
      13:55:00.352	info	javascript.0 (953) script.js.02_javascript.oliver_scripte.ping_ip_devices2: undefined
      13:55:20.354	error	javascript.0 (953) at Object.<anonymous> (script.js.02_javascript.oliver_scripte.ping_ip_devices2:230:14)
      ioBroker- NUC8i5, Proxmox 6.1-8
      Node.js v10.20.1, NPM v6.14.4, JS controller 3.0.20
        @liv-in-sky
        nein es bleibt so
        liv-in-skyL
        liv-in-skyL
        #171
        @Sky66766 kurzer test
        bitte blockly importieren: evtl musst du die deine ip adressen eintragen - bei mir : der dns server ist 192.168.178.1
        der ip bereich ist 192.168.178.0/24
         <variables>
           <variable type="" id="OKn1dp$dZER(Gk2O3IYs">result</variable>
         </variables>
         <block type="exec" id="[Y+ZXeCvED,]D?.W}DEC" x="188" y="113">
           <mutation with_statement="true"></mutation>
           <field name="WITH_STATEMENT">TRUE</field>
           <field name="LOG"></field>
           <value name="COMMAND">
             <shadow type="text" id="gg-ULn^umo_r1YMN:^fe">
               <field name="TEXT">sudo -u root nmap -sPR --dns-servers 192.168.178.1 192.168.178.0/24</field>
             </shadow>
           </value>
           <statement name="STATEMENT">
             <block type="debug" id="`fTczGFw;GlvC-`h[6~.">
               <value name="TEXT">
                 <shadow type="text" id="oE)!c};1sW/[bS.~ZP5#">
                 </shadow>
                 <block type="variables_get" id="u}LG)mA=h=j4lCIlS;1b">
                   <field name="VAR" id="OKn1dp$dZER(Gk2O3IYs" variabletype="">result</field>
                 </block>
               </value>
             </block>
           </statement>
         </block>
        </xml>
        dauert ein paar sekunden, bis ergebnis kommt
           <variables>
           </variables>
               </shadow>
             </value>
                 <value name="TEXT">
                   </shadow>
                   </block>
                 </value>
               </block>
             </statement>
           </block>
          </xml>
          Sky66766S
          Sky66766S
          Sky66766
          #172
          @liv-in-sky
          kommt nix
          im log steht
          javascript.0	2020-04-10 12:16:09.637	info	(953) script.js.02_javascript.oliver_scripte.ping_ip_devices22: undefined
          javascript.0	2020-04-10 12:16:09.637	info	(953) script.js.02_javascript.oliver_scripte.ping_ip_devices22: registered 0 subscriptions and 0 schedules
          javascript.0	2020-04-10 12:16:09.637	info	(953) script.js.02_javascript.oliver_scripte.ping_ip_devices22: exec is not available. Please enable "Enable Exec" option in instance settings
          javascript.0	2020-04-10 12:16:09.637	error	(953) exec is not available. Please enable "Enable Exec" option in instance settings
          javascript.0	2020-04-10 12:16:09.634	info	(953) Start javascript script.js.02_javascript.oliver_scripte.ping_ip_devices22
            @liv-in-sky
            kommt nix
            im log steht
            liv-in-skyL
            liv-in-skyL
            #173
            @Sky66766 sagte in IP Devices im Netzwerk - HTML Tabelle vis, Iqontrol:
            im setting der javascript instanz ist das zum einstellen
            dann nochmal blockly test
              Sky66766S
              Sky66766S
              Sky66766
              #174
              @liv-in-sky
              ok im log werden jetzt ip Adressen ausgelesen
              muss ich jetzt die Zeile console.log wieder auskommentieren ??
                @liv-in-sky
                liv-in-skyL
                liv-in-skyL
                #175
                @Sky66766 wäre besser - auch das log muss geschrieben werden - je weniger da reingeschrieben wird, umso besser (plattenzugriff, performane)
                  Sky66766S
                  Sky66766S
                  Sky66766
                  #176
                  @liv-in-sky
                  ok ist jetzt erst mal gelöst
                  danke dir werde gleich testen 👍 👍 👍
                  • BostilB
                    BostilB
                    Bostil
                    schrieb am zuletzt editiert von Bostil
                    #177
                    Das sieht ja bei euch genial aus, aber ich scheitere leider an der Config für meinen Raspberry (an einer fritz.box) insofern, dass die Datenpunkte erst garnicht beschrieben werden. @liv-in-sky Hast du vielleicht einen Anhaltspunkt für mein Problem? Habe nicht allzu viel im Konfigurationsbereich konfiguriert - ich denke eben, nur das Nötigste.
                    Vielen Dank!
                    Javascript-Code vom Post 7.3.2020
                    //@liv-in-sky Januar 2020 9.3-20:15
                    //HIER WIRD PFAD UND FILENAME DEFINIERT
                    const path = "/htmlip.html"; //FIlenamen definieren
                    const home ='vis.0' //wo soll das file im iobroker-file-system liegen ? (oder z.b auch iqontrol.meta)
                    let braucheHostDaten=true;
                    let braucheEinFile=true; // bei true wird ein file geschrieben
                    let braucheEinVISWidget=true; // bei true wird ein html-tabelle in einen dp geschrieben - siehe nächste zeile
                    let braucheMaterialDesignWidget=true; // bei true wird ein html-tabelle in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
                    let braucheMaterialDesignWidgetList=true; // bei true wird ein html-tabelle in einen dp geschrieben - MUSS ANGELEGT WERDEN !!!
                    let dpHost="0_userdata.0.Tabellen.IPDevices_HostDaten" //WICHTIG wenn braucheHostDaten auf true gesetzt !! dp zusätzlich für VIS-HTML-Basic-Widget // string
                    let dpVIS="0_userdata.0.Tabellen.IPDevices" //WICHTIG wenn braucheMaterialDesignWidgetList auf true gesetzt !! dp zusätzlich für VIS-HTML-Basic-Widget // string
                    let dpMaterialTabelWidget="0_userdata.0.Tabellen.IPDevices_MD_Table" //WICHTIG wenn braucheMaterialDesignWidget auf true gesetzt !! dp zusätzlich für VIS-HTML-Basic-Widget // string
                    let dpMaterialListWidget="0_userdata.0.Tabellen.IPDevices_MD_List" //WICHTIG wenn braucheEinVISWidget auf true gesetzt !! dp zusätzlich für VIS-HTML-Basic-Widget // string
                    let pfadBilderMaterialWidget="/vis.0/img/" // PFAD zu den bildern, die in die vis geladen wurden/
                    let mySchedule=" */1 * * * * "; //jede minute - nicht unter eine minute gehen -besser 3 oder 5 minuten nutzen !!!
                    const domainName="fritz.box"; // domainname in der fritzbox definiert
                    const ipbereich="192.168.178.0/24"; // gilt nicht für windows
                    const dnsServer="192.168.178.1" // gilt nicht für windows
                    let sortiereClient=false; //true nach client false nach ip
                    const waitTime=25000; // falls längere zeit keine daten kommen - diesen wert erhöhn um 5000 (ms)
                    const lastZellColorSetting="lightgreen" // farbe der zusammenfassung in der letzten zelle der tabelle
                    const oerationSystemchange=false; // false ist linux, true ist windows
                    const onlyWinEthernetIF="eth0" // nur windows über befehl "nmap --iflist" herausfinden
                    const farbeNichtErreichbar="#FFBF00"; // farbe für devices, die gerade nicht online sind
                    const styleNichtErreichbar="i"; // möglich i=schräg, b ist fett und span ist normal - nur eines davon !!!
                    const kuerzungNamen=23; // länge der namen kürzen
                    const materialD_IP_erreichbar="#D8D8D8"; // material design farbe der ip adresse bei erreichbaren klient
                    const materialD_IP_nichtErreichbar="#F7819F"; // material design farbe der ip adresse bei nicht erreichbaren klient
                    //hier eintragen für die übersetzung der standardnamen - aliase - rechte seite wird statt linker angezeigt - die beispiele kann man raus löschen
                    // BITTE AUF DIE KOMMAs ACHTEN
                    const myDeviceNames={ "192.168.178.24" :"HF Küche Licht", // ein leeres array wird so erzeugt: const myDeviceNames=[];
                    // "192.168.178.29" :"TrekStor13",
                    // "192.168.178.10" :"Proxmox",
                    const myDeviceNamesNew= [{"ip" : "192.168.178.10", "name" : "Proxmox", "link" : "https://192.168.178.10:8006/", "kat":"server" },
                    {"ip" : "192.168.178.157", "name" : "sqltulla", "link" : "http://192.168.178.157:8181/settings", "kat":"server" },
                    {"ip" : "192.168.178.14", "name" : "PlexServer", "link" : "http://192.168.178.14:32400/web/index.html", "kat":"server" },
                    {"ip" : "192.168.178.145", "name" : "pi-hole", "link" : "http://192.168.178.145/admin", "kat":"server" },
                    {"ip" : "192.168.178.59", "name" : "iobroker", "link" : "http://192.168.178.59:8081/#tab-objects", "kat":"server" },
                    {"ip" : "192.168.178.199", "name" : "NAS-FILE-Server", "link" : "", "kat":"server" },
                    {"ip" : "192.168.178.73", "name" : "MediaPadT5", "link" : "", "kat":"tablet" },
                    {"ip" : "192.168.178.148", "name" : "Echo Dot 3", "link" : "", "kat":"echo_dot3" },
                    {"ip" : "192.168.178.29", "name" : "TrekStor13", "link" : "", "kat":"tablet" },
                    {"ip" : "192.168.178.151", "name" : "FireTab7", "link" : "", "kat":"tablet" },
                    {"ip" : "192.168.178.201", "name" : "VPN Netzwerk", "link" : "", "kat":"vpn" },
                    {"ip" : "192.168.178.56", "name" : "FireHDStick", "link" : "", "kat":"firetvstick" },
                    {"ip" : "192.168.178.33", "name" : "SonoffS26", "link" : "", "kat":"sonoff26" },
                    {"ip" : "192.168.178.135", "name" : "Sonoff26", "link" : "http://192.168.178.135/", "kat":"sonoff26" },
                    {"ip" : "192.168.178.124", "name" : "Galaxy-S9", "link" : "", "kat":"handygal" },
                    {"ip" : "192.168.178.28", "name" : "Google-Home-Mini", "link" : "", "kat":"googlemini" },
                    {"ip" : "192.168.178.81", "name" : "GalaxyTabA16", "link" : "", "kat":"tablet" },
                    {"ip" : "192.168.178.21", "name" : "GoSund 2 Matrix", "link" : "", "kat":"gosund111" },
                    {"ip" : "192.168.178.155", "name" : "GoSund 3 Freezer", "link" : "", "kat":"gosund111" },
                    {"ip" : "192.168.178.126", "name" : "Matrix Büro", "link" : "", "kat":"matrix" },
                    {"ip" : "192.168.178.20", "name" : "Matrix Küche", "link" : "", "kat":"matrix" },
                    {"ip" : "192.168.178.150", "name" : "Gosund 1", "link" : "", "kat":"gosund111" },
                    {"ip" : "192.168.178.77", "name" : "WerBinIch", "link" : "", "kat":"fragezeichen" },
                    {"ip" : "192.168.178.142", "name" : "AdGuard", "link" : "http://192.168.178.142/", "kat":"server" },
                    {"ip" : "192.168.178.1", "name" : "DragonRoot", "link" : "http://192.168.178.1", "kat":"fritzbox" },
                    {"ip" : "192.168.178.88", "name" : "DragonRoot-Dect", "link" : "http://192.168.178.88", "kat":"fritzbox" },
                    {"ip" : "192.168.178.74", "name" : "LGwebOSTV", "link" : "", "kat":"LG_TV_2" },
                    {"ip" : "192.168.178.95", "name" : "Sonoff2-Distance", "link" : "http://192.168.178.95", "kat":"sonoff" },
                    {"ip" : "192.168.178.156", "name" : "EchoShow5", "link" : "", "kat":"Echo-Show-5" }
                    var symbolOK="✔️"; // auch möglich: ="✅" 🟩 ✔️ 🌎
                    var symbolKO="🔔"; //z.b. auch "<font color="red"><b>X</b>" für ein rotes kreuz oder : ="❌" ⚪ 🟢 ⚫ ⭕ 🔴 🔵 🚫 ⏱ 💀 👍 👎 📑 💲 👀 😡 🟥 ⬜ 🧊 💬 🗑️ 🔔
                    var symbolWARN="ℹ️"; // ="⚠️" oder info: "ℹ️"
                    var symbolKO_MD="🟥" //symbol für "nicht erreichbar" im MaterialDesign Widget
                    var symbolLink="🌎";
                    var externalOhneInfo=false; //noch nicht integriert
                    //HIER DIE SPALTEN ANZAHL DEFINIEREN - jede Spalte einen Wert - in diesem Beispiel sind es 3
                    var htmlFeld1='Name'; var Feld1lAlign="left"; // überschrift Tabellen Spalte1 und Ausrichtung left,right or center
                    var htmlFeld2='IP'; var Feld2lAlign="left"; // überschrift Tabellen Spalte2 und Ausrichtung left,right or center
                    var htmlFeld3='Status'; var Feld3lAlign="center"; // überschrift Tabellen Spalte3 und Ausrichtung left,right or center
                    //ÜBERSCHRIFT ÜBER TABELLE
                    let htmlUberschrift=true; // mit Überschrift über der tabelle
                    let htmlSignature=false; // anstatt der Überscghrift eine signature: - kleiner - anliegend
                    const htmlFeldUeber='IP Devices List'; // Überschrift und Signature
                    const htmlFarbUber="white"; // Farbe der Überschrift
                    const htmlSchriftWeite="normal"; // bold, normal - Fettschrift für Überschrift
                    const htmlÜberFontGroesse="18px"; // schriftgröße überschrift
                    //MEHRERE TABELLEN NEBENEINANDER
                    let mehrfachTabelle=3; // bis zu 4 Tabellen werden nebeneinander geschrieben- verkürzt das Ganze, dafür etwas breiter - MÖGLICH 1,2,3,oder 4 !!!
                    const trennungsLinie="2"; //extra trennungslinie bei mehrfachtabellen - evtl auf 0 stellen, wnn htmlRahmenLinien auf none sind
                    const farbetrennungsLinie="white";
                    const htmlFarbZweiteTabelle="white"; // Farbe der Überschrift bei jeder 2.ten Tabelle
                    const htmlFarbTableColorUber="#BDBDBD"; // Überschrift in der tabelle - der einzelnen Spalten
                    //ÜBERSCHRIFT SPALTEN
                    const UeberSchriftHöhe="35"; //Überschrift bekommt mehr Raum - darunter und darüber - Zellenhöhe
                    const LinieUnterUeberschrift="2"; // Linie nur unter Spaltenüberschrift -
                    const farbeLinieUnterUeberschrift="lightblue";
                    const groesseUeberschrift=16;
                    const UeberschriftStyle="normal" // möglich "bold"
                    //GANZE TABELLE
                    let abstandZelle="1";
                    let farbeUngeradeZeilen="#000000"; //Farbe für ungerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                    let farbeGeradeZeilen="#151515"; //Farbe für gerade Zeilenanzahl - Hintergrund der Spaltenüberschrift bleibt bei htmlFarbTableColorGradient1/2
                    let weite="1200"; //Weite der Tabelle
                    let zentriert=true; //ganze tabelle zentriert
                    const backgroundAll="#000000"; //Hintergrund für die ganze Seite - für direkten aufruf oder iqontrol sichtber - keine auswirkung auf vis-widget
                    const htmlSchriftart="Ubuntu-Regular" ///"Helvetica";
                    const htmlSchriftgroesse="14px";
                    //FELDER UND RAHMEN
                    let UeberschriftSpalten=true; // ein- oder ausblenden der spatlen-überschriften
                    const htmlFarbFelderschrift="#D8D8D8"; // SchriftFarbe der Felder
                    const htmlFarbFelderschrift2="#BDBDBD"; // SchriftFarbe der Felder für jede 2te Tabelle
                    const htmlFarbTableColorGradient1="#424242"; // Gradient - Hintergrund der Tabelle - Verlauffarbe
                    const htmlFarbTableColorGradient2="#424242"; // Gradient - Hintergrund der Tabelle - ist dieser Wert gleich Gradient1 gibt es keinen verlauf
                    const htmlFarbTableBorderColor="grey"; // Farbe des Rahmen - is tdieser gleich den gradienten, sind die rahmen unsichtbar
                    let htmlRahmenLinien="none"; // Format für Rahmen: MÖGLICH: "none" oder "all" oder "cols" oder "rows"
                    const htmlSpalte1Weite="auto"; // Weite der ersten beiden Spalten oder z.b. 115px
                    // HIER NICHTS ÄNDERN ---------------------SETTING ENDE ----------------------------------------
                    const dpPrefix = "javascript."+ instance +".";
                    let borderHelpBottum;
                    let borderHelpRight;
                    let htmlcenterHelp;
                    let htmlcenterHelp2;
                    if(htmlRahmenLinien=="rows") {borderHelpBottum=1;borderHelpRight=0;}
                    if(htmlRahmenLinien=="cols") {borderHelpBottum=0;borderHelpRight=1;}
                    if(htmlRahmenLinien=="none") {borderHelpBottum=0;borderHelpRight=0;}
                    if(htmlRahmenLinien=="all") {borderHelpBottum=1;borderHelpRight=1;}
                    zentriert ? htmlcenterHelp="auto" : htmlcenterHelp="left";
                    zentriert ? htmlcenterHelp2="center" : htmlcenterHelp2="left";
                    const htmlZentriert='<center>'
                    const htmlStart= "<!DOCTYPE html><html lang="de"><head><title>Vorlage</title><meta http-equiv="content-type" content="text/html; charset=utf-8">"+
                    "<style> * { margin: 0;} body {background-color: "+backgroundAll+"; margin: 0 auto; }"+
                    " p {padding-top: 10px; padding-bottom: 10px; text-align: "+htmlcenterHelp2+"}"+
                    // " div { margin: 0 auto; margin-left: auto; margin-right: auto;}"+
                    " td { padding:"+abstandZelle+"px; border:0px solid "+htmlFarbTableBorderColor+"; border-right:"+borderHelpRight+"px solid "+htmlFarbTableBorderColor+";border-bottom:"+borderHelpBottum+"px solid "+htmlFarbTableBorderColor+";}"+
                    " table { width: "+weite+"; margin: 0 "+htmlcenterHelp+"; border:0px solid "+htmlFarbTableBorderColor+"; border-spacing=""+abstandZelle+"0px" ; }"+ // margin macht center
                    "td:nth-child(1) {width: "+htmlSpalte1Weite+"}"+"td:nth-child(2) {width:"+htmlSpalte1Weite+"}"+
                    " </style></head><body>"; // <div>";
                    //const htmlUeber= "<p style="color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-weight: bold">"+htmlFeldUeber+"</p>";
                    const htmlTabStyle= "<table bordercolor=""+htmlFarbTableBorderColor+"" border="1px" cellspacing=""+abstandZelle+"" cellpadding=""+abstandZelle+"" width=""+weite+"" rules=""+htmlRahmenLinien+"" style="color:"+htmlFarbFelderschrift+"; font-size:"+htmlSchriftgroesse+
                    "; font-family:"+htmlSchriftart+";background-image: linear-gradient(42deg,"+htmlFarbTableColorGradient2+","+htmlFarbTableColorGradient1+");">";
                    const htmlTabUeber1="<tr height=""+UeberSchriftHöhe+""; style="color:"+htmlFarbTableColorUber+"; font-size: "+groesseUeberschrift+"px; font-weight: "+UeberschriftStyle+" ; border-bottom: "+LinieUnterUeberschrift+"px solid "+farbeLinieUnterUeberschrift+" ">";
                    const htmlTabUeber3="</tr>";
                    //NICHTS ÄNDERN - abhängig von den oben definierten _Spalten - in diesem Beispiel sind es 3
                    var htmlTabUeber2= "<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+"> "+htmlFeld1+" </td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+"> "+htmlFeld2+" </td><td align="+Feld3lAlign+"> "+htmlFeld3+" </td>";
                    var htmlTabUeber2_1="<td width="+htmlSpalte1Weite+" align="+Feld1lAlign+" style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld1+" </td><td width="+htmlSpalte1Weite+" align="+Feld2lAlign+" style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld2+
                    " </td><td align="+Feld3lAlign+" style="color:"+htmlFarbZweiteTabelle+""> "+htmlFeld3+" </td>";
                    var rootcount=true;
                    var myObjOld=[];
                    var myJsonWidget=[];
                    var myJsonWidget2=[];
                    var htmlTabUeber="";
                    var htmlOut="";
                    var mix;
                    var counter;
                    //HIER SIND DIE WERTE, DIE IN DER SCHLEIFE GEFILTERET WER%DEN - Jede spalte einen wert - jeder valx muss in dieser schleife gesetzt werden !!
                    var val1; var val0; var val2;
                    var json1; var json2; var json3; var json4; var json5; var json6;
                    let myObjExtra=[];
                    function writeHTML(){
                    htmlOut="";
                    counter=-1;
                    htmlTabUeber="";
                    switch (mehrfachTabelle) {
                    case 1: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber3; break;
                    case 2: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                    case 3: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber3; break;
                    case 4: htmlTabUeber=htmlTabUeber1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber2+htmlTabUeber2_1+htmlTabUeber3; break;
                    if (!UeberschriftSpalten) {htmlTabUeber=""}
                    //---------hier kommt eure schleife rein counter++, tabelleBind() und tabelleFinish() müssen so integriert bleiben !!!------------------------------
                    //---------alle valx werte müssen von euch bestimmt werden - val0,val1,val2 !!!---------------------------------------------------------------------
                    let hostDaten="";
                    var myData="xxxxx";
                    let myArr=[];
                    myObjExtra=[];
                    if(oerationSystemchange ==false){
                    exec("sudo -u root nmap -sPR --dns-servers "+dnsServer+" "+ipbereich , function (error, result, stderr) {
                    myData=result
                    // setState("0_userdata.0.Tabellen.IPDeviceERROR", result)
                    // console.log(result);
                    });} else {
                    exec((['"C:\\Program Files (x86)\\Nmap\\nmap" ','-sPR -e ',onlyWinEthernetIF,' --dns-servers ',dnsServer,' ',ipbereich].join('')), function (error, result, stderr) {
                    myData=result
                    let timeout = setTimeout(function () {
                    // myData=getState("0_userdata.0.Tabellen.DeviceIPFake").val // FÜR TEST
                    ////////////////////////////////log(myData)
                    if (!myData.includes("xxxx")) {
                    var myTimeScanArr=myData.match(/(scanned in) (\d+.\d+ seconds)/g); //log(myTimeScan)
                    // myArr=myData.match(/for\s+([A-Za-z0-9-_]+).f[^(]+((\d+.\d+.\d+.\d+))|(fritz.\w+)\s+((\d+.\d+.\d+.\d+))|(\d+.\d+.\d+.\d+)$/g)
                    myArr=myData.match(/for\s+([A-Za-z0-9-_]+).f[^(]+((\d+.\d+.\d+.\d+))|(fritz.\w+)\s+((\d+.\d+.\d+.\d+))|(\d+.\d+.\d+.\d+)$/gm)
                    // log(myArr.toString())
                    //myArr.push("10.0.1.200")
                    //myArr.push("for iobroker (10.0.1.200)")
                    //myArr.push("10.0.1.201")
                    //myArr.push("fritz.repeater (10.0.1.200)")
                    /////////////////////////////////////log(myArr.toString())
                    if(myArr!=null) {
                    let var1; let var2; let var3; let varOhneName=[];
                    var myObj=[]
                    for(var i=0;i<myArr.length;i++) {
                    var1="na"; var2="na";
                    var1=myArr[i].replace(/(for .+) (\d+.\d+.\d+.\d+)/,"$1")
                    var1=var1.replace(/(.+)(.+)/," $1")
                    var2=myArr[i].replace(/for .+ ((\d+.\d+.\d+.\d+))/,"$1");//log(var2)
                    var2=var2.replace(/.+((.+))/,"$1")
                    varOhneName=myArr[i].match(/^(\d+\.\d+\.\d+\.\d+)$/)
                    if (varOhneName!=null) {var1=varOhneName[0];var2=varOhneName[0]}
                    var3="true";
                    /* var2=var2.replace(/[(,)]/g,"")
                    for (var index in myDeviceNames) { //ersetze mit aliasnamen
                    //log(index)
                    if ((var2.trim()).match(index)) {var1="for "+myDeviceNames[index];
                    // log(val0+" - "+index)
                    {1}
                    let help=[var1.trim(),var2.trim(),var3]
                    if (!(var1=="na" || var2=="na")) myObj.push(help)
                    if (rootcount) {/* myObjOld= getState("0_userdata.0.Tabellen.IPDeviceERROR").val /
                    myObjOld.push(help);
                    if (rootcount) {/
                    myObjOld= getState("0_userdata.0.Tabellen.IPDeviceERROR").val */
                    // myObjOld.push(help);
                    createState(dpPrefix+"Tabellen.IPDevices.Device_Collection", myObjOld, { name: 'Device_Collection', desc: 'Device_Collection', type: 'array',read: true, write: true });
                                  else{
                                  myObjOld=getState(dpPrefix+"Tabellen.IPDevices.Device_Collection").val;
                    //log("++++++++++++++++++ "+myObj.toString())
                    //setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString())
                    let varhelp1; let varhelp2; let varhelp3="true"; //neue erkannt geräte zu datenbank hinzufügen
                    for (var i=0;i<myObj.length;i++){
                    // log(myObj[i][0]+"-----"+myObjOld[i][0])
                    if (!myObjOld.toString().includes(myObj[i][1])) { varhelp1=myObj[i][0].trim() ; varhelp2=myObj[i][1]; varhelp3="true";
                    let help=[varhelp1,varhelp2,varhelp3]
                    if (!(varhelp1.indexOf("scanned")>-1)) myObjOld.push(help)
                    for (var i=0;i<myObjOld.length;i++){ // ist gerät noch da ???
                    if (!myObj.toString().includes(myObjOld[i][1])) { varhelp1=myObjOld[i][0].trim() ; varhelp2=myObjOld[i][1]; varhelp3="false";
                    myObj.push(help)
                    // log("------------------------------------------------"+myObjOld[1].toString())
                    if (braucheMaterialDesignWidget || braucheMaterialDesignWidgetList) sortiereClient=true
                    /* if (sortiereClient){
                    {1}
                    myObj.sort(function (alpha, beta) {
                    if (alpha[0].toUpperCase().trim() > beta[0].toUpperCase().trim())
                    return 1;
                    if (beta[0].toUpperCase().trim() > alpha[0].toUpperCase().trim())
                    return -1;
                    return 0;
                    });} else { */
                    if (!sortiereClient){
                    // if (parseFloat(beta[1].replace(/.+.(.+)$/,"$1")) > parseFloat(alpha[1].replace(/.+.(.+)$/,"$1")))
                    if ((parseFloat(beta[1].replace(/.+.(.+)$/,"$1")))+(parseFloat(beta[1].replace(/.+.(.+)..+$/,"$1"))*1000) > (parseFloat(alpha[1].replace(/.+.(.+)$/,"$1")))+(parseFloat(alpha[1].replace(/.+.(.+)..+$/,"$1"))*1000))
                    return -1;
                    if ((parseFloat(alpha[1].replace(/.+.(.+)$/,"$1")))+(parseFloat(alpha[1].replace(/.+.(.+)..+$/,"$1"))*1000) > (parseFloat(beta[1].replace(/.+.(.+)$/,"$1")))+(parseFloat(beta[1].replace(/.+.(.+)..+$/,"$1"))*1000))
                    return 1;
                    return 0;
                    var1="scanned in" //nur scanned seconds
                    var3="true"
                    var2=myTimeScanArr[0].replace(/.+ (\d+.\d+.+$)/,"$1");//log(var2)
                    let help=[var1,var2,var3]
                    if (sortiereClient) help=["xxxx"+var1,var2,var3]
                    myObj.push(help)
                    if (!rootcount) setState(dpPrefix+"Tabellen.IPDevices.Device_Collection", myObjOld)
                    ///////////////////////////log("myObject ------- "+myObj.length.toString()+"---- ")
                    // setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString()) // zur fehlersuche
                    for(var i=0;i<myObj.length;i++) { // hier eigene schleife definieren und den wert counter++ nicht vergessen !!!
                          counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
                        //  log(myObj[i][0].toString())
                          val0=myObj[i][0].replace("for","").trim()
                          val0=val0.replace("."+domainName,"")
                          val0=val0.replace(/[(,)]/g,"")
                          val1=myObj[i][1]
                          val1=val1.replace(/[(,)]/g,"")
                    //log(index)
                    if ((val1.trim()).match(index.trim()) && val1.trim().length == index.trim().length) {val0=myDeviceNames[index];
                    //log(val0+" - "+index)
                    for (var index in myDeviceNamesNew) { //ersetze mit aliasnamen
                    //log(index)
                    if ((val1.trim()).match(myDeviceNamesNew[index].ip) && val1.trim().length == (myDeviceNamesNew[index].ip).length) {val0=myDeviceNamesNew[index].name;
                            if (val0.length>=(kuerzungNamen)+2)  val0=val0.substring(0,kuerzungNamen)+" ..."
                          var val2help=myObj[i][2]
                          if (val2help=="false") {val2=symbolKO;
                                                  val0=("<font color=\""+farbeNichtErreichbar+"\"><"+styleNichtErreichbar+">")+val0+ "<\/"+styleNichtErreichbar+">";
                                                  val1=("<font color=\""+farbeNichtErreichbar+"\"><"+styleNichtErreichbar+">")+val1+ "<\/"+styleNichtErreichbar+">";}  else{val2=symbolOK}
                     if(val0=="scanned in") {val2=symbolWARN;val0="<font color=\""+lastZellColorSetting+"\"><i>"+" Anzahl "+counter+"</i>"; val1="<font color=\""+lastZellColorSetting+"\"><i>"+val1+"</i>"}
                     tabelleBind(); }//HIER NICHTS ÄNDERN : HIER WERDEN DIE DATEN DER SCHLEIFE ZUSAMMENGESETZT  - diese function muss als letztes in der eigenen schleife aufgerufen werden
                     else {let help=[val0.trim(),val1,val2help];myObjExtra.push(help);}
                    }; //Schleifen Ende - je nach schleifenart muss hier etwas geändert werden !!!!!!!!!
                    var valLink=""; var valKat="";
                    counter=-1;
                    myObjExtra.sort(function (alpha, beta) {
                    if ((alpha[0].toUpperCase()).trim() > (beta[0].toUpperCase()).trim())
                    return 1;
                    if ((beta[0].toUpperCase()).trim() > (alpha[0].toUpperCase()).trim())
                    return -1;
                    return 0;
                           for(var i=0;i<myObjExtra.length;i++) {
                               json4="standard"
                               json6="";
                                let val0helping="";
                               counter++
                               json1=val0=myObjExtra[i][0] ;
                               json2=val1=myObjExtra[i][1] ;
                               val2help=myObjExtra[i][2] ;
                                        //   log("bin hier bei "+myDeviceNamesNew[index].ip+" mit ...")
                                          if ((myObjExtra[i][1].match(myDeviceNamesNew[index].ip)) && myObjExtra[i][1].length == myDeviceNamesNew[index].ip.length) {
                                             //  log("bin hier bei "+myDeviceNamesNew[index].name+" mit "+  myObjExtra[i][0]+" und kat: " + myDeviceNamesNew[index].kat)
                                               if (myDeviceNamesNew[index].link!="") {json6=myDeviceNamesNew[index].link;json6=`<a style="text-decoration:none;" href="${json6}" target="_blank"> ${symbolLink}</a>`;;
        val0helping=json6;
                                               if (myDeviceNamesNew[index].kat!="")  json4=myDeviceNamesNew[index].kat;}  }
                                           if (val2help=="false") {json3=val2=symbolKO; json5="red";
                                                  val1=("<font color=\""+farbeNichtErreichbar+"\"><"+styleNichtErreichbar+">")+val1+ "<\/"+styleNichtErreichbar+">";}  else{json3=val2=symbolOK;   json5="green";}
                               if(val0=="xxxxscanned in") {json3=val2=symbolWARN;   json5="blue"; json1="Anzahl: "+counter; json4="info"
                                                            val0="<font color=\""+lastZellColorSetting+"\"><i>"+" Anzahl "+counter;
                                                            val1="<font color=\""+lastZellColorSetting+"\"><i>"+val1+" um "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")+"</i>"
                                                            json2=myObjExtra[i][1]+", "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss")}
                                                           if (val2help) val0=val0+val0helping ; // link
                                 tabelleBind();
                               if (braucheMaterialDesignWidget || braucheMaterialDesignWidgetList) {
                                  if (val2help=="false") {json3=val2=symbolKO_MD; }
                                 makeJsonWidget(json1,json2,json3,json4,json5,json6);}
                    //--------------------------------------------------Ende der schleife------------------------------------------------------------------------------
                      // AB HIER NICHTS ÄNDERN - tabelle fertigstellen
                                                             tabelleFinish();
                                                             if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/  });}
                                                             if (braucheHostDaten) {for(var i=0;i<myObjExtra.length;i++) {  if (myObjExtra[i][0]!="xxxxscanned"){
        hostDaten=hostDaten+myObjExtra[i][1]+"\t"+myObjExtra[i][0]+"\n" }}}
                                                              setState(dpHost,hostDaten); //log(hostDaten)
                                                           }, 2000);
                       }  else {log("no Array","warn")} //Ende Array falsch
                       } else {log("no Data","warn")} // ende daten falsch
                       rootcount=false;
                    }, waitTime);
                    } // function ende
                    //MAIN:
                    schedule(mySchedule, function () {
                    if (!rootcount) writeHTML();
                    // if (braucheEinFile) {writeFile(home, path ,htmlOut, function (error) { /* log('file written');*/ });}
                    writeHTML();
                    function tabelleBind(){
                    // counter=counter+mehrfachTabelle;
                         case 1: if(counter%2==0)         {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td></tr>"; break;}else
                                                          {  htmlOut=htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td></tr>"; break;}
                         case 2: if(counter%4==0){
                                    if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\" align="+Feld3lAlign+">"+val2+"</td>"; }
                                               else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td></tr>";} break;
                                      }else{
                                                if(counter%2==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
        ";\"align="+Feld3lAlign+">"+val2+"</td>"; }
                                               else {htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td></tr>";} break;}
                         case 3:if(counter%2==0)   {
                                    if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                               else { if(counter%3==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val0+"</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">"+val1+"</td><td  align="+Feld3lAlign+" style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"color:"+htmlFarbFelderschrift2+"\">"+val2+"</td>";}
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td align="+Feld3lAlign+">"+val2+"</td></tr>";}
                                                          } break;}else{
                                    if(counter%3==0 )  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">"+val0+"</td><td align="+Feld2lAlign+">"+val1+"</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+
                                                          } break;}
                         case 4:  // counter=counter+8;
                                   if(counter%8==0)   {
                                   if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeGeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+ farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } // teil1
                                                   else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} //teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} //teil 4
        else    {htmlOut =htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"  align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
                                                          } break;}else{
                                   if(counter%4==0)  {htmlOut = htmlOut+"<tr bgcolor=\""+farbeUngeradeZeilen+"\"><td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\" align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>"; } //teil 1
                                                   else {if(counter%4==1 )  { htmlOut = htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td  align="+Feld3lAlign+" style=\"border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td>";} // teil 2
        else    {if(counter%4==3)  { htmlOut= htmlOut+"<td align="+Feld1lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val0+"&ensp;</td><td  align="+Feld2lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val1+"&ensp;</td><td align="+Feld3lAlign+" style=\"color:"+htmlFarbFelderschrift2+"\">&ensp;"+val2+"&ensp;</td></tr>";} // teil 4
        else    {htmlOut = htmlOut+"<td align="+Feld1lAlign+">&ensp;"+val0+"&ensp;</td><td align="+Feld2lAlign+">&ensp;"+val1+"&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+";\"align="+Feld3lAlign+">&ensp;"+val2+"&ensp;</td>";}} //teil 3
                                                          } break;}
                        } //switch ende
                    function tabelleFinish() {
                    case 1: break;
                       case 2:
                                  if(counter%2==0)  htmlOut = htmlOut.replace(/<\/td>$/, '</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>');
                                  break;
                       case 3:   if(counter%3==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                 if(counter%3==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                 if(counter%3==0)      htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td  style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                  break;
                       case 4:   if(counter%4==3)  htmlOut = htmlOut.replace(/<\/td>$/, "</td></tr>");
                                 if(counter%4==2)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                 if(counter%4==1)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                 if(counter%4==0)  htmlOut = htmlOut.replace(/<\/td>$/, "</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td style=\" border-right: "+trennungsLinie+"px solid "+farbetrennungsLinie+"\">&ensp;</td><td>&ensp;</td><td>&ensp;</td><td>&ensp;</td></tr>");
                                 break; }
                         var htmlUeber=    "<p style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: "+htmlÜberFontGroesse+"; font-weight:"+htmlSchriftWeite+ "\">"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</p>";
                       var htmlUnter= "<div  style=\"color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 70%; text-align: right;\" >"+htmlFeldUeber+"&ensp;&ensp;Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>";
                        if (!htmlSignature) htmlUnter="";
                      //  log(" ist htmlUnter - signature "+htmlUnter)
                          //Ausgabe über VIS html widget - tabelle in datenpunkt schreiben - html tabelle ohne html header und body
                           var htmlOutVIS="";
                         //  htmlUberschrift ? htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>" : htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>";
                            if (htmlUberschrift)
                                { zentriert ? htmlOutVIS=htmlZentriert+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter : htmlOutVIS=htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter ;
                              } else {
                               zentriert ?  htmlOutVIS=htmlZentriert+htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter :  htmlOutVIS=htmlTabStyle+htmlTabUeber+htmlOut+"</table>"+htmlUnter;
                    // log("bin raus aus tabelleBind");
                    if (braucheEinVISWidget) setState(dpVIS, htmlOutVIS );
                    var htmlUnter= "<div style="color:"+htmlFarbUber+"; font-family:"+htmlSchriftart+"; font-size: 80%; text-align: center; " >"+htmlFeldUeber+"  Last Update: "+formatDate(getDateObject((parseFloat((new Date().getTime())))), "SS:mm:ss");+"</div>"
                    var htmlEnd="</table>"+htmlUnter+"</div></body>";
                    //mit oder ohne überschrift - zentriert oder links
                    htmlUberschrift ? htmlOut=htmlStart+htmlUeber+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd : htmlOut=htmlStart+htmlTabStyle+htmlTabUeber+htmlOut+htmlEnd;
                    //log(htmlOut);
                    if (braucheMaterialDesignWidgetList) {
                       setState(dpMaterialListWidget,JSON.stringify(myJsonWidget2));
                       myJsonWidget2=[];
                    if (braucheMaterialDesignWidget) {
                    setState(dpMaterialTabelWidget,JSON.stringify(myJsonWidget));
                    myJsonWidget=[];
                    function makeJsonWidget(vax1,vax2,vax3,vax4,vax5,vax6) {
                    //log(vax3+vax6+htmlFeld1)
                    vax4=pfadBilderMaterialWidget+vax4+".png" ;
                    if ( braucheMaterialDesignWidgetList) {
                    myJsonWidget.push({
                    Device : vax4,
                    IP : vax1,
                    Status : vax2,
                    Kategorie : vax3+" "+vax6
                    // log(myJsonWidget)
                    let colorIP= materialD_IP_erreichbar //"lightgreen";
                    // log(vax3)
                    if (vax3==symbolKO_MD) colorIP=materialD_IP_nichtErreichbar //"lightcoral";
                    // vax4=pfadBilderMaterialWidget+vax4+".png" ;
                    let mysubText = <div style="display: flex; flex-direction: row; line-height: 1.3; padding-left: 1px; padding-right: 8px; align-items: center;"> <div style="flex: 1;font-size: 16px; color: ${colorIP};">${vax2}</div> <div style="color: grey; font-size: 12px; font-family: RobotoCondensed-LightItalic; text-align: right;">${vax3}${vax6}</div> </div>
                    let ip=vax2
                     myJsonWidget2.push({
                               text: vax1,
                               subText: mysubText,
                               statusBarColor: vax5,
                               image: vax4,
                               imageColor: "",
                               listType: "text",
                               showValueLabel: true,
                               ip: ip, //vax2,
                               status: vax3,
                               link:vax6
                    Log:
                    Objekte mit manuell angelegten Datenpunkten:
                    • BostilB Bostil
                      Vielen Dank!
                      var symbolLink="🌎";
                      //GANZE TABELLE
                      //FELDER UND RAHMEN
                      let htmlcenterHelp;
                      var rootcount=true;
                      var myObjOld=[];
                      var htmlOut="";
                      var mix;
                      var counter;
                      let myObjExtra=[];
                      htmlOut="";
                      counter=-1;
                      htmlTabUeber="";
                      let hostDaten="";
                      var myData="xxxxx";
                      let myArr=[];
                      myObjExtra=[];
                      myData=result
                      });} else {
                      myData=result
                      if(myArr!=null) {
                      var myObj=[]
                      var3="true";
                      //log(index)
                      {1}
                      if (rootcount) {/
                                    else{
                      myObj.push(help)
                      {1}
                      return 1;
                      return -1;
                      return 0;
                      });} else { */
                      return -1;
                      return 1;
                      return 0;
                      var3="true"
                      myObj.push(help)
                            val1=myObj[i][1]
                      //log(index)
                      //log(index)
                      counter=-1;
                      return 1;
                      return -1;
                      return 0;
                                 json4="standard"
                                 json6="";
                                  let val0helping="";
                                 counter++
        val0helping=json6;
                                   tabelleBind();
                                                               tabelleFinish();
                                                             }, 2000);
                         rootcount=false;
                      }, waitTime);
                      } // function ende
                      //MAIN:
                      writeHTML();
                                        }else{
                                                            } break;}else{
                                                            } break;}
                                     if(counter%8==0)   {
                                                            } break;}else{
                                                            } break;}
                          } //switch ende
                      case 1: break;
                         case 2:
                                    break;
                                    break;
                                   break; }
                             var htmlOutVIS="";
                                } else {
                      //log(htmlOut);
                         myJsonWidget2=[];
                      myJsonWidget=[];
                      myJsonWidget.push({
                      Device : vax4,
                      IP : vax1,
                      Status : vax2,
                      // log(vax3)
                      let ip=vax2
                                 text: vax1,
                                 subText: mysubText,
                                 image: vax4,
                                 imageColor: "",
                                 listType: "text",
                                 ip: ip, //vax2,
                                 status: vax3,
                                 link:vax6
                      Log:
                      liv-in-skyL
                      liv-in-skyL
                      #178
                      @Bostil hi
                      kannst du bitte das machen und mir das ergebnis mitteilen
                      https://forum.iobroker.net/post/409283
                      diese meldung kann bee ein paar durchläufen (3-4) am anfang kommen - sollte dann aber weg sein - wenn das script schon längere zeit läuft mach das mit dem link (blockly importieren und ausführen)
                      • BostilB Bostil
                        Vielen Dank!
                        var symbolLink="🌎";
                        //GANZE TABELLE
                        //FELDER UND RAHMEN
                        let htmlcenterHelp;
                        var rootcount=true;
                        var myObjOld=[];
                        var htmlOut="";
                        var mix;
                        var counter;
                        let myObjExtra=[];
                        htmlOut="";
                        counter=-1;
                        htmlTabUeber="";
                        let hostDaten="";
                        var myData="xxxxx";
                        let myArr=[];
                        myObjExtra=[];
                        myData=result
                        });} else {
                        myData=result
                        if(myArr!=null) {
                        var myObj=[]
                        var3="true";
                        //log(index)
                        {1}
                        if (rootcount) {/
                                      else{
                        myObj.push(help)
                        {1}
                        return 1;
                        return -1;
                        return 0;
                        });} else { */
                        return -1;
                        return 1;
                        return 0;
                        var3="true"
                        myObj.push(help)
                              val1=myObj[i][1]
                        //log(index)
                        //log(index)
                        counter=-1;
                        return 1;
                        return -1;
                        return 0;
                                   json4="standard"
                                   json6="";
                                    let val0helping="";
                                   counter++
        val0helping=json6;
                                     tabelleBind();
        tabelleFinish();
                                                               }, 2000);
                           rootcount=false;
                        }, waitTime);
                        } // function ende
                        //MAIN:
                        writeHTML();
                                          }else{
                                                              } break;}else{
                                                              } break;}
                                       if(counter%8==0)   {
                                                              } break;}else{
                                                              } break;}
                            } //switch ende
                        case 1: break;
                           case 2:
                                      break;
                                      break;
                                     break; }
                               var htmlOutVIS="";
                                  } else {
                        //log(htmlOut);
                           myJsonWidget2=[];
                        myJsonWidget=[];
                        myJsonWidget.push({
                        Device : vax4,
                        IP : vax1,
                        Status : vax2,
                        // log(vax3)
                        let ip=vax2
                                   text: vax1,
                                   subText: mysubText,
                                   image: vax4,
                                   imageColor: "",
                                   listType: "text",
                                   ip: ip, //vax2,
                                   status: vax3,
                                   link:vax6
                        Log:
                        liv-in-skyL
                        liv-in-skyL
                        #179
                        @Bostil
                        gelöscht
                        • BostilB
                          BostilB
                          Bostil
                          #180
                          Danke dir - im Blockly oben lasse ich einfach stehen: sudo -u root nmap -sPR --dns-servers 192.168.178.1 192.168.178.1/99
                          Habe auch eine fritz.box, die auf der IP 192.168.178.1 liegt. Leider erhalte ich noch kein Ergebnis.
                          • BostilB Bostil
                            liv-in-skyL
                            liv-in-skyL
                            #181
                            @Bostil sagte in IP Devices im Netzwerk - HTML Tabelle vis, Iqontrol:
                            evtl mein fehler
                            der text im blockly muss so heißen : (am ende 0/24)
                            du kannst auch mal den befehl direkt in einem terminal fenster/linux console eingeben - zum test, ob da was kommt
                            • BostilB
                              BostilB
                              Bostil
                              #182
                              Ach Mensch ... ich bin auch saublöd: Hatte nmap noch nicht auf dem Raspberry installiert. Nachdem ich dies nach der Anleitung hier getan habe, tut sich etwas.
                              Im Putty werden erkannte IP-Geräte aufgelistet. Ich warte jetzt nochmal, ob sich im Script etwas tut und die Datenpunkte beschrieben werden. Kann man beim Anlegen der Datenpunkte etwas falsch machen ?
                              Vielen Dank erstmal @liv-in-sky
                              Bekomme bloß weiterhin den "no array"-Fehler ...
                              • BostilB Bostil
                                liv-in-skyL
                                liv-in-skyL
                                #183
                                @Bostil gehe am besten schrittweise vor
                                zuerst im terminal testen - wenn was kommt
                                dann das blockly - wenn im log unter dem blockly was kommt (wie im terminal) - außer es kommt nix oder fehler meldung
                                dann in das main script
                                • Basti97B
                                  Basti97B
                                  Basti97
                                  #184
                                  In welcher Zeile kann ich die Farbe ändern bzw wie muss das in js schreiben.
                                  Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
                                  • Basti97B Basti97
                                    liv-in-skyL
                                    liv-in-skyL
                                    #185
                                    @Basti97 welche farbe ?
                                    Basti97B 1 Antwort Letzte Antwort
                                      Basti97B
                                      Basti97B
                                      Basti97
                                      #186
                                      @liv-in-sky Zum Beispiel das ich ein Text in der Farbe ändern kann z.b true in Grün und sobald false ist soll sich der Text (false) in rot sich ändern. Das gleiche mit den verschiedenen mit den Akkuzustand.
                                      • Basti97B Basti97
                                        liv-in-skyL
                                        liv-in-skyL
                                        #187
                                        @Basti97
                                        wenn du die farbe des textes für die nicht-erreichbaren geräte ändern willst mußt du dies in dieser zeile ändern
                                        die farbe für erreichbare kannst du hier ändern:
                                        z.b:
                                          @Basti97
                                          z.b:
                                          Basti97B
                                          Basti97B
                                          Basti97
                                          #188
                                          @liv-in-sky Dankeschön ich probiere es aus. 😊
                                          Mono990M 1 Antwort Letzte Antwort
                                          84.2k
