  4. [Major Update] SourceAnalytix v0.4.7-beta.0 released !
    6.5k
sourceanalytixtestenadapterupdate
1.1k Beiträge 103 Kommentatoren 440.2k Aufrufe 93 Beobachtet
  • B Berchemer
    @Dutchman
    Hier die Rawdaten des Datenpunktes:
      "type": "state",
      "common": {
        "type": "number",
        "read": true,
        "write": true,
        "def": 0,
        "name": "Heizöl - Bisher am Tag verbrauchte Menge",
        "role": "state",
        "unit": "Liter",
        "custom": {
          "sql.0": {
            "enabled": true,
            "changesOnly": true,
            "debounce": "1000",
            "retention": 0,
            "changesRelogInterval": 0,
            "changesMinDelta": 0,
            "storageType": "",
            "aliasId": ""
          "sourceanalytix.0": {
            "enabled": true,
            "alias": "",
            "state_type": "kWh_consumption",
            "state_unit": "l",
            "costs": true,
            "consumption": true,
            "meter_values": true,
            "start_day": 0,
            "start_week": 0,
            "start_month": 0,
            "start_quarter": 0,
            "start_year": 0,
            "valueAtDeviceReset": 0
      "native": {},
      "from": "system.adapter.sourceanalytix.0",
      "user": "system.user.admin",
      "ts": 1586360640048,
      "_id": "0_userdata.0.Energie.Heizoel.Oelmenge_tagesverbrauch",
      "acl": {
        "object": 1636,
        "state": 1636,
        "owner": "system.user.admin",
    crunchipC Offline
    crunchipC Offline
    @Berchemer dein Datenpunkt gibt Liter aus, du hast aber kwh als Unit im Adapter ausgewählt, wenn ich das richtig sehe.
    • B Berchemer
      @Dutchman
        "type": "state",
        "common": {
          "type": "number",
          "read": true,
          "write": true,
          "def": 0,
          "role": "state",
          "unit": "Liter",
          "custom": {
            "sql.0": {
              "enabled": true,
              "debounce": "1000",
              "retention": 0,
              "storageType": "",
              "aliasId": ""
              "enabled": true,
              "alias": "",
              "state_unit": "l",
              "costs": true,
              "start_day": 0,
              "start_week": 0,
              "start_month": 0,
              "start_quarter": 0,
              "start_year": 0,
        "native": {},
        "acl": {
          "object": 1636,
          "state": 1636,
      DutchmanD Offline
      DutchmanD Offline
      Dutchman
      schrieb am zuletzt editiert von Dutchman
      @Berchemer sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
      "unit": "Liter",
      eh unit Liter ? was ist das den, wen dan sollt das " l " (also L klingeschrieben) sein 😂
      setze mal manuell auf Liter :
      • DutchmanD Dutchman
        "unit": "Liter",
        Berchemer
        @Dutchman
        Alles klar... Kleines l hat es wohl gebracht. Danke!
        • B Berchemer
          @Dutchman
          DutchmanD Offline
          DutchmanD Offline
          Dutchman
          @Dutchman
          Da das kan man spaeter dynamisch per Tabelle eintragen fuer jetzt halte ich mich an die "offiziellen" units :P
            stephan2k
            schrieb am zuletzt editiert von stephan2k
            MEIN DENKFEHLER, sorry :) Kann den Post leider nicht löschen.
            Alles funktioniert bestens, vielen Dank für den tollen Adapter!
            -> Ich dachte bei Current_Reading sieht man was er aktuell für einen Wert schreibt. Aber hier Summiert er wohl auch schon den aktuellen Tag
            ich hab ein Problem mit dem 0.4.0 Adapter.
            Ich hab das Gefühl er schreibt bei der Netzeinspeisung den doppelten Wert.
            Hier der Wert von dem Datenpunkt der eingelesen wird:
            Screenshot etwas Zeitversetzt
            Wenn ich bei den Datenpunkt PV_Netzeinspeisung Sourceanalytix deaktiviere, werden keine Daten mehr geschrieben. Also nimmt er den Wert nicht von 2 Unterschiedlichen Punkten.
            Hier noch das Loggin Setup für PV_Netzeinspeisung
            Wo liegt mein Fehler? Was mach ich Falsch
            Und noch eine zweite Frage, sollte er die Werte unter Objekte nicht addieren unter weeks / quarter / etc
            • S stephan2k
              DutchmanD Offline
              DutchmanD Offline
              Dutchman
              @stephan2k sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
              addieren ? nein deine startwerte sind überall null also rechnet er den kompletten Verbrauch auf allen Perioden.
              Du musst den jahres, Wochen, Monats Anfang usw eintragen
              verstehe ich nicht ... du hast 2 Datenpunkte, diese erstellen unter SA 2 Ordner.
              Ich sehe das einer nich geschrieben wird, frage ist warum es sollte was im log kommen dan ?
                stephan2k
                @Dutchman sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                Hallo Dutchman,
                danke für deine Antwort.
                Ich hatte das Thema oben bearbeitet, meine Fragen hatten sich erledigt. Hatte dein System nicht richtig verstanden.
                Aber jetzt läufts prima.
                Kurz zu meinen 2 Datenpunkten:
                Ich habe nur einen Innogy Zweiwegezähler (PowerinWatt). In diesem einen Datenpunkt habe ich meinen Strombezug (postive Zahlen) und meine Einspeisung (negative Zahlen).
                Durch einen anderen Thread im Forum wurde durch ein Blockly ein Workaround geschaffen
                PowerinWatt positve Zahlen => schreibt den Wert in PV_Netzbetzug
                PowerinWatt negative Zahlen => schreibt den Wert in PV_Netzeinspeisung
                Danke für deinen tollen Adapter
                  Aktuelle Test Version v0.4.8-alpha.0
                  Veröffentlichungsdatum 09.09.2020
                  Github Link https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix
                  Major release v0.4.8-alpha.0
                  Um die weitere Entwicklung von SourceAnalytix mit neuen Funktionen möglich zu machen habe ich mich dazu entschlossen den vorige SourceCode (0.3.0) komplett neu auf zu bauen.
                  Da die vorige version mit Erweiterungen undurchsichtig geworden war, und auch einige performance/Berechnung Probleme auftraten, war ein redesign die beste Entscheidung.
                  Die neue version kennt einige performance Verbesserungen, die alten Funktionalität sind weitestgehend gleich geblieben.
                  Die wichtigsten Änderungen in 0.4.x :
                  • Änderung der Datenstruktur, diese fängt jetzt an beim Jahr anstatt "current_year"
                  • Datenstruktur Migration : Noch nicht implementiert, wird später folgen
                  • Quartale werden berechnet
                  • Redesign der Watt ==> kWh Berechnung (genauer)
                  • Redesign der Unit Definitionen (Sollte Fehler "kann unit nicht erkennen" beheben)
                  • Reset des Messgerätes, anstatt minus werte wird jetzt der Haupt-Wert Kumuliert
                  • Gesamt werte werden per Kategorie (kosten / verbrauch / Zählerwerte) wieder gegeben
                  • Redesign alle Berechnungen, alle read/write zugriffe von iO (object DB) in den Arbeitsspeicher verschoben. Hiermit sollte performance Problemen behoben sein vor allen bei ein-platineng Systemen und langsamen Festplatten
                  • Logging redesigned, bei neu installation ist die log-stufe WARN, bereits bestehen Installationen stehen auf INFO bitte Manuel auf WARN stellen
                  Ich bitte euch diese version zu testen, bei erfolg werden ich SourceAnalytix in die stable releasen und danach anfangen neue Funktionen ein zu bauen.
                  (Vorschläge und bug reports bitte über git !)
                  Danke für eure mithilfe
                  sigi234S Online
                  sigi234S Online
                  @Dutchman
                  V 0.4.1
                  Hallo, nach update des js-controller auf V 3.0.6 kommt das :
                  sourceanalytix.0	2020-04-12 09:34:30.486	warn	(34788) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.32 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                  sourceanalytix.0	2020-04-12 09:34:30.483	warn	(34788) This object will not be created in future versions. Please report this to the developer.
                  Soll ich auf Git eine issues erstellen, oder reicht das hier im Forum?
                  Homer.J.H DutchmanD 2 Antworten Letzte Antwort
                  • sigi234S sigi234
                    @Dutchman
                    V 0.4.1
                    Homer.J.H Offline
                    Homer.J.H Offline
                    Homer.J.
                    @sigi234 hab ich auch bei jeden angelegten Datenpunkt.
                    • sigi234S sigi234
                      @Dutchman
                      V 0.4.1
                      DutchmanD Offline
                      DutchmanD Offline
                      Dutchman
                      @sigi234 sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                      @Dutchman
                      V 0.4.1
                      sourceanalytix.0 2020-04-12 09:34:30.486 warn (34788) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.32 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number" sourceanalytix.0 2020-04-12 09:34:30.483 warn (34788) This object will not be created in future versions. Please report this to the developer.
                      danke das sieht nach nem false positive von JS-controller 3.0 aus, mach bitte issue bei meinem adapter
                        @Dutchman
                        V 0.4.1
                        sigi234S Online
                        sigi234S Online
                        Erledigt:
                        https://github.com/iobroker-community-adapters/ioBroker.sourceanalytix/issues/134
                        • G Offline
                          guergen
                          Jetzt mal eine "dumme" Frage:
                          Ich würde den Adapter auch gene updaten, nur steht im Readme:
                          To-Do : Migration from < 0.4.0 to new datastructure
                          Muss ich da vorher was tun?
                          Oder soll das heissen, es gibt nur den Weg zu 0.4 und nicht wieder zurück....
                          • G Offline
                            guergen
                            OK, hab grade nen Snapshot gemacht, da kann ich ja immer wieder mit zurück... Frage selbst beantwortet...
                            Aber das Update läuft nicht durch:
                            $ ./iobroker upgrade sourceanalytix
                            Update sourceanalytix from @0.3.0 to @0.4.1
                            NPM version: 6.14.4
                            npm install iobroker.sourceanalytix@0.4.1 --loglevel error --prefix "/opt/iobroker" (System call)
                            npm
                             ERR!
                            code
                             ETARGET
                            npm
                             ERR! notarget
                             No matching version found for iobroker.sourceanalytix@0.4.1.npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
                            npm ERR!
                             A complete log of this run can be found in:
                            npm
                            ERR!
                                 /home/iobroker/.npm/_logs/2020-04-12T12_05_42_021Z-debug.log
                            upload [9] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/words.js words.js application/javascript
                            upload [8] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/tsconfig.json tsconfig.json application/json
                            upload [7] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/style.css style.css text/css
                            upload [6] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/sourceanalytix.png sourceanalytix.png image/png
                            upload [5] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_open.png settings_open.png image/png
                            upload [4] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/settings_details.png settings_details.png image/png
                            upload [3] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/index_m.html index_m.html text/html
                            upload [2] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/custom_m.html custom_m.html text/html
                            upload [1] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/button.png button.png image/png
                            upload [0] sourceanalytix.admin /opt/iobroker/node_modules/iobroker.sourceanalytix/admin/admin.d.ts admin.d.ts video/mp2t
                            Adapter "sourceanalytix" updated
                            process exited with code 0
                            • G guergen
                              NPM version: 6.14.4
                              npm
                               ERR!
                              code
                               ETARGET
                              npm
                               ERR! notarget
                              npm ERR!
                              npm
                              ERR!
                              MarcJ
                              @guergen Ja, bei mir gleiche Meldung. Bin gespannt, was wir falsch machen :-)
                              • M MarcJ
                                DutchmanD Offline
                                DutchmanD Offline
                                Dutchman
                                @MarcJ sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                nichts sorry mein Fehler
                                ich. habe die version wegen einem schwerwiegenden bug zurückgezogen, morgen ist 0.4.2 zum install bereit
                                sorry leutz 😲
                                @guergen sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                Homer.J.H 1 Antwort Letzte Antwort
                                  sorry leutz 😲
                                  Homer.J.H Offline
                                  Homer.J.H Offline
                                  Homer.J.
                                  Morgen @Dutchman kann es sein das dass zurücksetzen der Werte eventuell nur vom Sonntag zum Montag nicht funktioniert, hab es heut schon wieder das er durchzählt.
                                  Hier mal noch die Ausgabe 00:00 Uhr.
                                  2020-04-13 00:00:00.010 - error: sourceanalytix.0 (597) startvalues for hm-rpc.2.0001D3C98DD8B9.6.ENERGY_COUNTER before reset : {"currentValuekWh":4.176,"start_day":0,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.018 - error: sourceanalytix.0 (597) startvalues for hm-rpc.2.0001D3C98DD8B9.6.ENERGY_COUNTER after reset : {"currentValuekWh":4.176,"start_day":4.176,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.019 - error: sourceanalytix.0 (597) startvalues for hm-rpc.2.0001D3C99CB161.6.ENERGY_COUNTER before reset : {"currentValuekWh":0,"start_day":0,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.019 - error: sourceanalytix.0 (597) startvalues for hm-rpc.2.0001D3C99CB161.6.ENERGY_COUNTER after reset : {"currentValuekWh":0,"start_day":0,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.020 - error: sourceanalytix.0 (597) startvalues for hm-rpc.2.0001D7098D9B8D.6.ENERGY_COUNTER before reset : {"currentValuekWh":0,"start_day":0,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.020 - error: sourceanalytix.0 (597) startvalues for hm-rpc.2.0001D7098D9B8D.6.ENERGY_COUNTER after reset : {"currentValuekWh":0,"start_day":0,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.021 - error: sourceanalytix.0 (597) startvalues for hm-rpc.2.00085A498C04BC.7.ENERGY_COUNTER before reset : {"currentValuekWh":4.882,"start_day":4.8818,"start_month":4.6114,"start_quarter":4.6114,"start_week":4.758,"start_year":0.8919,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.021 - error: sourceanalytix.0 (597) startvalues for hm-rpc.2.00085A498C04BC.7.ENERGY_COUNTER after reset : {"currentValuekWh":4.882,"start_day":4.882,"start_month":4.6114,"start_quarter":4.6114,"start_week":4.758,"start_year":0.8919,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.022 - error: sourceanalytix.0 (597) startvalues for javascript.0.Vis.Anzeige.Stromverbrauch before reset : {"currentValuekWh":609.2,"start_day":610.967,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.022 - error: sourceanalytix.0 (597) startvalues for javascript.0.Vis.Anzeige.Stromverbrauch after reset : {"currentValuekWh":609.2,"start_day":609.2,"start_month":0,"start_quarter":0,"start_week":0,"start_year":0,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.022 - error: sourceanalytix.0 (597) startvalues for smartmeter.0.1-0:1_8_0__255.value before reset : {"currentValuekWh":1065.522,"start_day":1065.522,"start_month":938.76543306,"start_quarter":938.76543306,"start_week":1002.22821091,"start_year":-172,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.023 - error: sourceanalytix.0 (597) startvalues for smartmeter.0.1-0:1_8_0__255.value after reset : {"currentValuekWh":1065.522,"start_day":1065.522,"start_month":938.76543306,"start_quarter":938.76543306,"start_week":1002.22821091,"start_year":-172,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.023 - error: sourceanalytix.0 (597) startvalues for wiffi-wz.0.root.192_168_178_122.w_counter_1 before reset : {"currentValuekWh":1052.859,"start_day":1050.331,"start_month":922.975,"start_quarter":922.975,"start_week":986.1,"start_year":-172,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.023 - error: sourceanalytix.0 (597) startvalues for wiffi-wz.0.root.192_168_178_122.w_counter_1 after reset : {"currentValuekWh":1052.859,"start_day":1052.859,"start_month":922.975,"start_quarter":922.975,"start_week":986.1,"start_year":-172,"valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.024 - error: sourceanalytix.0 (597) startvalues for wiffi-wz.0.root.192_168_178_122.w_counter_2 before reset : {"currentValuekWh":10378.676,"start_day":10371.938,"start_month":10150.955,"start_quarter":10150.955,"start_week":10272.848,"start_year":"7700","valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.024 - error: sourceanalytix.0 (597) startvalues for wiffi-wz.0.root.192_168_178_122.w_counter_2 after reset : {"currentValuekWh":10378.676,"start_day":10378.676,"start_month":10150.955,"start_quarter":10150.955,"start_week":10272.848,"start_year":"7700","valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.024 - error: sourceanalytix.0 (597) startvalues for wiffi-wz.0.root.192_168_178_122.w_counter_3 before reset : {"currentValuekWh":2828.335,"start_day":2826.56,"start_month":2764.223,"start_quarter":2764.223,"start_week":2791.823,"start_year":"2200","valueAtDeviceReset":0}
                                  2020-04-13 00:00:00.025 - error: sourceanalytix.0 (597) startvalues for wiffi-wz.0.root.192_168_178_122.w_counter_3 after reset : {"currentValuekWh":2828.335,"start_day":2828.335,"start_month":2764.223,"start_quarter":2764.223,"start_week":2791.823,"start_year":"2200","valueAtDeviceReset":0}
                                    sigi234S Online
                                    sigi234S Online
                                    @Dutchman
                                    Nach Update 0.4.2 die üblichen Warn:
                                    sourceanalytix.0	2020-04-13 10:10:52.115	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.115	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.53 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.106	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.106	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.53 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.100	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.100	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.53 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.091	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.090	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.52 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.084	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.084	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.52 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.077	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.076	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.52 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.068	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.067	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.51 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.062	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.062	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.51 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.054	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.053	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.51 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.048	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.048	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.50 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.040	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.040	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.50 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.035	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.034	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.50 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.027	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.027	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.49 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.021	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.021	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.49 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:52.013	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:52.012	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.49 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.995	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.994	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.48 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.984	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.984	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.48 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.968	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.968	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.48 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.960	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.959	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.47 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.951	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.951	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.47 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.941	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.941	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.47 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.932	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.931	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.46 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.915	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.914	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.46 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.904	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.904	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.46 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.884	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.884	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.45 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.872	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.871	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.45 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.844	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.844	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.45 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.815	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.814	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.44 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.790	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.790	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.44 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.760	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.760	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.44 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.728	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.728	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.43 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.698	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.698	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.43 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:51.661	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:51.661	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.43 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:50.943	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:50.943	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.costs.weeks.42 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:50.940	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:50.939	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.meterReadings.weeks.42 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:50.937	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    sourceanalytix.0	2020-04-13 10:10:50.937	warn	(30656) Object hm-rpc__0__NEQ1662322__2__ENERGY_COUNTER.2020.consumed.weeks.42 is invalid: obj.common.name has an invalid type! Expected "string" or "object", received "number"
                                    sourceanalytix.0	2020-04-13 10:10:50.934	warn	(30656) This object will not be created in future versions. Please report this to the developer.
                                    • Homer.J.H Homer.J.
                                      DutchmanD Offline
                                      DutchmanD Offline
                                      Dutchman
                                      @Homer-J sagte in [Major Update] SourceAnalytix 0.4.0 complete code rebuild:
                                      in der 0.4.2 sollte das klappen, haben hier 10 positive Berichten von Testern
                                      • sigi234S sigi234
                                        @Dutchman
                                        DutchmanD Offline
                                        DutchmanD Offline
                                        Dutchman
                                        thanks da kuemmere ich mich drum
                                        • G Offline
                                          guergen
                                          Wie muss ich das hier verstehen:
                                          Wo muss ich das einstellen, damit ich nicht alle Meldungen ins Info-Log bekomme?
                                          G DutchmanD 2 Antworten Letzte Antwort
