  4. Backitup funktioniert nicht richtig
backitup
9 Beiträge 2 Kommentatoren 1.0k Aufrufe 2 Beobachtet
    meicker
    schrieb am zuletzt editiert von meicker
    @simatec
    Guten Morgen :-)
    Sicherung läuft soweit alles. Nur wird kein SQL und kein REDIS Backup gemacht.
    Im Log bekomme ich das:
    host.ioBroker	2020-04-11 09:53:01.233	error	Caught by controller[0]: at Pipe._handle.close (net.js:607:12)
    host.ioBroker	2020-04-11 09:53:01.233	error	Caught by controller[0]: at Socket.emit (events.js:198:13)
    host.ioBroker	2020-04-11 09:53:01.232	error	Caught by controller[0]: at Socket.stream.socket.on (internal/child_process.js:389:11)
    host.ioBroker	2020-04-11 09:53:01.232	error	Caught by controller[0]: at maybeClose (internal/child_process.js:982:16)
    host.ioBroker	2020-04-11 09:53:01.232	error	Caught by controller[0]: at ChildProcess.emit (events.js:198:13)
    host.ioBroker	2020-04-11 09:53:01.231	error	Caught by controller[0]: at ChildProcess.exithandler (child_process.js:301:5)
    host.ioBroker	2020-04-11 09:53:01.231	error	Caught by controller[0]: at child_process.exec (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/30-mysql.js:20:37)
    host.ioBroker	2020-04-11 09:53:01.231	error	Caught by controller[0]: at new RegExp (<anonymous>)
    host.ioBroker	2020-04-11 09:53:01.230	error	Caught by controller[0]: SyntaxError: Invalid regular expression: /*xxxxxxx*/: Nothing to repeat
    backitup.0	2020-04-11 09:53:00.654	error	at Pipe._handle.close (net.js:607:12)
    backitup.0	2020-04-11 09:53:00.654	error	at Socket.emit (events.js:198:13)
    backitup.0	2020-04-11 09:53:00.654	error	at Socket.stream.socket.on (internal/child_process.js:389:11)
    backitup.0	2020-04-11 09:53:00.654	error	at maybeClose (internal/child_process.js:982:16)
    backitup.0	2020-04-11 09:53:00.654	error	at ChildProcess.emit (events.js:198:13)
    backitup.0	2020-04-11 09:53:00.654	error	at ChildProcess.exithandler (child_process.js:301:5)
    backitup.0	2020-04-11 09:53:00.654	error	at child_process.exec (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/30-mysql.js:20:37)
    backitup.0	2020-04-11 09:53:00.654	error	at new RegExp (<anonymous>)
    backitup.0	2020-04-11 09:53:00.654	error	(5431) SyntaxError: Invalid regular expression: /*xxxxxx*/: Nothing to repeat
    backitup.0	2020-04-11 09:53:00.651	error	(5431) uncaught exception: Invalid regular expression: /*xxxxxx*/: Nothing to repeat
    Das / (Stern)xxxxxx(Stern) / ist mein Passwort für die Datenbank (Natürlich hier angeändert, jedoch beginnt und endet es mit * - Darf das nicht so sein ?
    Was redis angeht, das Verzeichnis ist da und die Datenbank hat das datum von heute.
    Fix habe ich laufen lassen
    iobroker status:
    At least one iobroker host is running.
    Objects type: file
    States  type: redis
    Hast Du eine Idee ?
    vg Marc
    • M meicker
      @simatec
      Guten Morgen :-)
      iobroker status:
      Objects type: file
      States  type: redis
      Hast Du eine Idee ?
      vg Marc
      meicker
      @simatec
      ich bin inzwischen ein Stück weiter. Ich habe das Passwort von beginnend und endend mit * auf beginnend und endend mit ! geändert. Jetzt läuft die Sicherung ein ganzes Stück weiter. REDIS wird nun gesichert, MySQL noch nicht weil mysqldump nicht da ist ... ???
      [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u pi_admin -p**** pi -h 192.168.1.160 -P 3307 > /opt/iobroker/backups/mysql_2020_04_11-11_20_47_backupiobroker.sql
      /bin/sh: 1: mysqldump: not found
      Warum ist das nicht automatisch installiert ? Ich will da jetzt auch nix falsch machen und einfach was installieren ... ich warte mal auf Deine Rückmeldung ...
        meicker
        @simatec
        im Forum bei den testern hab ich gesehen das Du vorgeschlagen hast mysqldump zu installieren. Hab ich dann auch mal versucht - klappt aber nicht ...
        root@ioBroker:~# sudo apt-get install mysql-client
        Reading package lists... Done
        Building dependency tree
        Package mysql-client is not available, but is referred to by another package.
        This may mean that the package is missing, has been obsoleted, or
        is only available from another source
        E: Package 'mysql-client' has no installation candidate
        Wenn das gelöst ist würde wieder alles OK sein ... :-)
        • M meicker
          @simatec
          simatecS Online
          simatecS Online
          simatec
          @meicker sagte in Backitup funktioniert nicht richtig:
          Dr. Google fragen ...
          https://community.atlassian.com/t5/Bitbucket-questions/Package-mysql-client-has-no-installation-candidate/qaq-p/1130738
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          • simatecS simatec
            meicker
            @simatec
            ist nicht immer unbedingt eine gute Idee alles zu starten was man bei Google findet :-) Aber ich habe es dann mit
            sudo apt-get install default-mysql-client
            versucht und es hat funktioniert.
            Auch wenn ich das Problem mit dem Passwort gelöst habe, kann es sein das man * am Anfang und Ende nicht verwenden darf ?
              meicker
              @simatec
              und noch eine Frage. Letzte funktionierende REDIS Sicherung war nur halb so groß. Ich habe aber nicht viele Adapter dazu genommen ... Wie kann das sein ?
              11.4.2020, 14:01 (1.6MiB)
              11.4.2020, 11:33 (1.6MiB)
              11.4.2020, 11:20 (1.6MiB)
              3.4.2020, 02:01 (804KiB)
              • M meicker
                @simatec
                simatecS Online
                simatecS Online
                simatec
                Kannst du schon, aber dann musst du dein PW in Anführungszeichen schreiben
                • M meicker
                  @simatec
                  simatecS Online
                  simatecS Online
                  simatec
                  @meicker
                  Das ist normal. Mein Redis produktiv sind über 100 MB
                  • simatecS simatec
                    @meicker
                    meicker
                    @simatec sagte in Backitup funktioniert nicht richtig:
                    @meicker
                    Aber schon komisch wenn alle Sicherungen immer 800kb sind und dann auf dem neuen System plötzlich genau doppelt so groß... was Sinn machen würde wäre wenn die Daten pro Hostname abgelegt sind. Den habe ich nämlich geändert für den neuen Broker - kann das sein ?
                    vg
                    Marc
