<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Backitup funktioniert nicht richtig]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
Guten Morgen :-)</p>
<p dir="auto">Sicherung läuft soweit alles. Nur wird kein SQL und kein REDIS Backup gemacht.</p>
<p dir="auto">Im Log bekomme ich das:</p>
<pre><code>host.ioBroker	2020-04-11 09:53:01.233	error	Caught by controller[0]: at Pipe._handle.close (net.js:607:12)
host.ioBroker	2020-04-11 09:53:01.233	error	Caught by controller[0]: at Socket.emit (events.js:198:13)
host.ioBroker	2020-04-11 09:53:01.232	error	Caught by controller[0]: at Socket.stream.socket.on (internal/child_process.js:389:11)
host.ioBroker	2020-04-11 09:53:01.232	error	Caught by controller[0]: at maybeClose (internal/child_process.js:982:16)
host.ioBroker	2020-04-11 09:53:01.232	error	Caught by controller[0]: at ChildProcess.emit (events.js:198:13)
host.ioBroker	2020-04-11 09:53:01.231	error	Caught by controller[0]: at ChildProcess.exithandler (child_process.js:301:5)
host.ioBroker	2020-04-11 09:53:01.231	error	Caught by controller[0]: at child_process.exec (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/30-mysql.js:20:37)
host.ioBroker	2020-04-11 09:53:01.231	error	Caught by controller[0]: at new RegExp (&lt;anonymous&gt;)
host.ioBroker	2020-04-11 09:53:01.230	error	Caught by controller[0]: SyntaxError: Invalid regular expression: /*xxxxxxx*/: Nothing to repeat
backitup.0	2020-04-11 09:53:00.654	error	at Pipe._handle.close (net.js:607:12)
backitup.0	2020-04-11 09:53:00.654	error	at Socket.emit (events.js:198:13)
backitup.0	2020-04-11 09:53:00.654	error	at Socket.stream.socket.on (internal/child_process.js:389:11)
backitup.0	2020-04-11 09:53:00.654	error	at maybeClose (internal/child_process.js:982:16)
backitup.0	2020-04-11 09:53:00.654	error	at ChildProcess.emit (events.js:198:13)
backitup.0	2020-04-11 09:53:00.654	error	at ChildProcess.exithandler (child_process.js:301:5)
backitup.0	2020-04-11 09:53:00.654	error	at child_process.exec (/opt/iobroker/node_modules/iobroker.backitup/lib/scripts/30-mysql.js:20:37)
backitup.0	2020-04-11 09:53:00.654	error	at new RegExp (&lt;anonymous&gt;)
backitup.0	2020-04-11 09:53:00.654	error	(5431) SyntaxError: Invalid regular expression: /*xxxxxx*/: Nothing to repeat
backitup.0	2020-04-11 09:53:00.651	error	(5431) uncaught exception: Invalid regular expression: /*xxxxxx*/: Nothing to repeat
</code></pre>
<p dir="auto">Das / (Stern)xxxxxx(Stern) / ist mein Passwort für die Datenbank (Natürlich hier angeändert, jedoch beginnt und endet es mit * - Darf das nicht so sein ?</p>
<p dir="auto">Was redis angeht, das Verzeichnis ist da und die Datenbank hat das datum von heute.</p>
<p dir="auto">Fix habe ich laufen lassen<br />
iobroker status:</p>
<pre><code>iobroker is running on this host.
Objects type: file
States  type: redis
</code></pre>
<p dir="auto">Hast Du eine Idee ?</p>
<p dir="auto">vg Marc</p>
]]></description><link>https://forum.iobroker.net/topic/32131/backitup-funktioniert-nicht-richtig</link><generator>RSS for Node</generator><lastBuildDate>Sun, 03 May 2026 19:26:53 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/32131.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Apr 2020 08:26:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Backitup funktioniert nicht richtig on Sat, 11 Apr 2020 16:05:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> sagte in <a href="/post/409951">Backitup funktioniert nicht richtig</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meicker" aria-label="Profile: meicker">@<bdi>meicker</bdi></a><br />
Das ist normal. Mein Redis produktiv sind über 100 MB</p>
</blockquote>
<p dir="auto">Aber schon komisch wenn alle Sicherungen immer 800kb sind und dann auf dem neuen System plötzlich genau doppelt so groß... was Sinn machen würde wäre wenn die Daten pro Hostname abgelegt sind. Den habe ich nämlich geändert für den neuen Broker - kann das sein ?</p>
<p dir="auto">vg<br />
Marc</p>
]]></description><link>https://forum.iobroker.net/post/410050</link><guid isPermaLink="true">https://forum.iobroker.net/post/410050</guid><dc:creator><![CDATA[meicker]]></dc:creator><pubDate>Sat, 11 Apr 2020 16:05:46 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup funktioniert nicht richtig on Sat, 11 Apr 2020 12:32:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meicker" aria-label="Profile: meicker">@<bdi>meicker</bdi></a><br />
]]></description><link>https://forum.iobroker.net/post/409951</link><guid isPermaLink="true">https://forum.iobroker.net/post/409951</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Sat, 11 Apr 2020 12:32:22 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup funktioniert nicht richtig on Sat, 11 Apr 2020 12:31:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meicker" aria-label="Profile: meicker">@<bdi>meicker</bdi></a> sagte in <a href="/post/409927">Backitup funktioniert nicht richtig</a>:</p>
<blockquote>
<p dir="auto">Auch wenn ich das Problem mit dem Passwort gelöst habe, kann es sein das man * am Anfang und Ende nicht verwenden darf ?</p>
</blockquote>
<p dir="auto">Kannst du schon, aber dann musst du dein PW in Anführungszeichen schreiben</p>
]]></description><link>https://forum.iobroker.net/post/409950</link><guid isPermaLink="true">https://forum.iobroker.net/post/409950</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Sat, 11 Apr 2020 12:31:36 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup funktioniert nicht richtig on Sat, 11 Apr 2020 12:08:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
und noch eine Frage. Letzte funktionierende REDIS Sicherung war nur halb so groß. Ich habe aber nicht viele Adapter dazu genommen ... Wie kann das sein ?</p>
<pre><code>11.4.2020, 14:01 (1.6MiB)
11.4.2020, 11:33 (1.6MiB)
11.4.2020, 11:20 (1.6MiB)
3.4.2020, 02:01 (804KiB)
</code></pre>
]]></description><link>https://forum.iobroker.net/post/409929</link><guid isPermaLink="true">https://forum.iobroker.net/post/409929</guid><dc:creator><![CDATA[meicker]]></dc:creator><pubDate>Sat, 11 Apr 2020 12:08:40 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup funktioniert nicht richtig on Sat, 11 Apr 2020 12:04:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
ist nicht immer unbedingt eine gute Idee alles zu starten was man bei Google findet :-) Aber ich habe es dann mit<br />
sudo apt-get install default-mysql-client<br />
versucht und es hat funktioniert.</p>
]]></description><link>https://forum.iobroker.net/post/409927</link><guid isPermaLink="true">https://forum.iobroker.net/post/409927</guid><dc:creator><![CDATA[meicker]]></dc:creator><pubDate>Sat, 11 Apr 2020 12:04:53 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup funktioniert nicht richtig on Sat, 11 Apr 2020 11:50:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meicker" aria-label="Profile: meicker">@<bdi>meicker</bdi></a> sagte in <a href="/post/409858">Backitup funktioniert nicht richtig</a>:</p>
<blockquote>
<p dir="auto">Package 'mysql-client' has no installation candidate</p>
</blockquote>
<p dir="auto">Dr. Google fragen ...</p>
<p dir="auto"><a href="https://community.atlassian.com/t5/Bitbucket-questions/Package-mysql-client-has-no-installation-candidate/qaq-p/1130738" rel="nofollow ugc">https://community.atlassian.com/t5/Bitbucket-questions/Package-mysql-client-has-no-installation-candidate/qaq-p/1130738</a></p>
]]></description><link>https://forum.iobroker.net/post/409918</link><guid isPermaLink="true">https://forum.iobroker.net/post/409918</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Sat, 11 Apr 2020 11:50:45 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup funktioniert nicht richtig on Sat, 11 Apr 2020 09:42:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
im Forum bei den testern hab ich gesehen das Du vorgeschlagen hast mysqldump zu installieren. Hab ich dann auch mal versucht - klappt aber nicht ...</p>
<pre><code>root@ioBroker:~# sudo apt-get install mysql-client
Reading package lists... Done
Building dependency tree
Package mysql-client is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'mysql-client' has no installation candidate
</code></pre>
<p dir="auto">Wenn das gelöst ist würde wieder alles OK sein ... :-)</p>
]]></description><link>https://forum.iobroker.net/post/409858</link><guid isPermaLink="true">https://forum.iobroker.net/post/409858</guid><dc:creator><![CDATA[meicker]]></dc:creator><pubDate>Sat, 11 Apr 2020 09:42:46 GMT</pubDate></item><item><title><![CDATA[Reply to Backitup funktioniert nicht richtig on Sat, 11 Apr 2020 09:27:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a><br />
ich bin inzwischen ein Stück weiter. Ich habe das Passwort von beginnend und endend mit * auf beginnend und endend mit ! geändert. Jetzt läuft die Sicherung ein ganzes Stück weiter. REDIS wird nun gesichert, MySQL noch nicht weil mysqldump nicht da ist ... ???</p>
<pre><code>[ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u pi_admin -p**** pi -h 192.168.1.160 -P 3307 &gt; /opt/iobroker/backups/mysql_2020_04_11-11_20_47_backupiobroker.sql
/bin/sh: 1: mysqldump: not found
</code></pre>
<p dir="auto">Warum ist das nicht automatisch installiert ? Ich will da jetzt auch nix falsch machen und einfach was installieren ... ich warte mal auf Deine Rückmeldung ...</p>
]]></description><link>https://forum.iobroker.net/post/409846</link><guid isPermaLink="true">https://forum.iobroker.net/post/409846</guid><dc:creator><![CDATA[meicker]]></dc:creator><pubDate>Sat, 11 Apr 2020 09:27:58 GMT</pubDate></item></channel></rss>
