Test Adapter fb-checkpresence v1.0.x
@afuerhoff
Habe eben ins log geschaut und mich über folgende Fehler gewundert, nur bei instanz 1, die 0 macht keine Probleme. Versuche mal ob ich über debug mehr infos bekommefb-checkpresence.1 2020-04-04 20:21:41.731 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 20:07:41.526 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:53:41.949 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:48:41.583 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:44:41.527 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:41:41.923 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:28:41.692 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:24:41.302 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:18:40.387 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:11:40.981 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:07:41.051 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 19:06:40.867 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 18:54:41.418 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 18:49:40.827 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 18:45:39.940 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 18:37:40.866 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 18:34:41.429 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 18:12:41.771 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 18:09:40.662 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 17:57:41.640 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 17:51:41.232 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 17:27:41.891 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 17:24:40.871 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 17:17:40.047 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceeded fb-checkpresence.1 2020-04-04 17:12:40.797 error (30999) Fb.getDeviceList Error: timeout of 2000ms exceededdebug log zusätzlich per mail an dich
Könntest du die Instanz 0 stoppen und dann schauen ob es noch Fehler gibt. Laufen beide Instanzen mit der gleichen Fritzbox?
@afuerhoff
gerade mal ins log geschaut, seit gestern Abend kein error mehr, Ich hatte aber den javascript Adapter gestern noch einmal neu gestartet, vielleicht lag es daran.
Ich beobachte mal weiter -
@afuerhoff
@e-s
Kannst du noch hierzu etwas sagen -> Laufen beide Instanzen mit der gleichen Fritzbox?
Es könnte sein, dass sich die Anfragen dann auf der Fritzbox überschneiden und dadurch der Timeout Fehler kommt.@afuerhoff
Genau nur eine fritzbox.
Instanz 0 hat 40 shellys usw und da interessiert mich nur absent.
Instanz 1 hat 5 Handys für Anwesenheit.Gestern kamen ein paar shellys dazu, also könnte es an den vielen Geräten liegen und ein Versatz sollte für beide reichen oder evtl das timeout erhöhen.
@afuerhoff
@afuerhoff
@e-s Hi,
Warum 2 Instanzen wenn es doch eine Box nur ist? Du belastet damit unnötig die Ressourcen der Fritzbox.Ich hab 327 Geräte in der Fritzbox, permanent sind laut fb-presence 230 online.. also die Fritzbox kann das gut ab.
Bei mir läuft noch der fritzdect und tr-064 Adapter. -
@e-s Hi,
Bei mir läuft noch der fritzdect und tr-064 Adapter.@ilovegym
Wie gesagt, in der einen Instanz überprüfe ich alle shellys, tasmotas usw ob sie mit dem Router verbunden sind. Dafür gibt es ja den einfachen dp not present/absent, bzw bin zufrieden wenn all present auf true steht.Die Anwesenheit von Personen hatte ich vorher immer mit dem tr064 Adapter gemacht(5 Smartphones), aber da nervte mich das iphone toggeln. Hierbei nutze ich Deswegen experimentiere ich derzeit mit einer 2. Instanz über diesen Adapter, wobei mich nur interessiert ob jemand daheim ist, also present true.
Wenn ich jetzt dafür auch die erste Instanz nutzen würde, dann müsste ich anschließend in scripten wieder alles manuell zerlegen weil diese beiden mir wichtigen dp nicht mehr nutzbar wären.
@ilovegym
@e-s said in Test Adapter fb-checkpresence v1.0.x:
Könntest du diese Geräte nicht schneller mit dem Ping Adapter prüfen?
@Brainbug
Bestimmt, aber warum? Der Adapter macht doch genau das was ich möchte und das sehr komfortabel.
Der Fehler war gestern zum ersten und einzigen Mal aufgetreten, warum also nach was anderem suchen@afuerhoff
Der Fehler ist heute doch wieder häufiger aufgetreten, aber jetzt auch manchmal mit der Instanz 0. Aber der Fehler ist nie von beiden zeitgleich.
Habe mal die 0 deaktiviert und beobachte weiter. -
bekomme im log alle paar sekunden folgende warnung:
fb-checkpresence.0 2020-04-07 14:29:41.560 error (2625) getActive: TypeError: Converting circular structure to JSON@Malz1902 das hatten wir erst vor 2 Tagen bei mir...
Bedeutet, du hast da einen User drin, der sich an deiner Fritzbox noch nicht angemeldet hatte....
@mameier1234
Die Meldung wird im nächsten Release aussagekräftiger sein.@afuerhoff
Hast du auch für mein Problem eine Idee, der Fehlermeldung kommt immer wieder mal 4 mal pro Minute, dann stundenlang wieder überhaupt nicht.
Kann es aber nicht eingrenzen oder mit anderen Ereignissen in Verbindung bringen. -
@afuerhoff
@e-s sagte in Test Adapter fb-checkpresence v1.0.x:
Hast du auch für mein Problem eine Idee, ...
Kommt der Fehler auch mit nur einer aktivierten Instanz? Wird die Fritzbox noch von anderer Seite abgefragt?
@afuerhoff
Ja und ja.
Kam auch wenn nur eine Instanz, egal welche von beiden. Der tr064 Adapter läuft noch parallel. Wird aber nur für Anrufe genutzt.Aber das war auch vorher so. Also es gab nur 3 Änderungen bevor der Fehler aufgetreten ist.
- Update auf checkpresence 1.0
- 5 weitere shellys
- ein neues beta der 7490, beta ist aber schon vorher drauf gewesen.
@afuerhoff
Ja und ja.
- 5 weitere shellys
@e-s
Könntest du den TR-064 auch mal deaktivieren, so dass nur noch eine Instanz läuft.
Und dann beobachten.@afuerhoff
Tr064 deaktiviert, nur eine Instanz aktiviert, es treten keine Fehler auf.
Tr064 deaktiviert, beide Instanzen aktiviert, Fehler tritt recht schnell auf.Tr064 aktiviert, Fehlermeldung beim Start vom tr064, connect timeout, beim 2. automatischen start gab es keinen Fehler. Scheinbar ist meine 7490 überfordert.
Mir ist es auch schon aufgefallen, wenn ich was in der Fritz verstellen will, dann kommt die mir extrem langsam vor. -
@e-s Hi,
Wenn du in deine fritzbox gehst und dir da die CPU auslastung anschaust, wie hoch ist die da bei dir?
Bei mir zeigt die gerade 97% an und im mittel 82%, dann wundert es mich auch nicht warum die so träge ist.
Habe jetzt mal check und tr064 deaktiviert und verfolge mal die Auslastung.
Gestern Abend um 22uhr habe ich tr064 abgeschaltet, heute morgen dann wieder an.
Habe mal im tr064 Adapter die Einstellungen reduziert und gestartet. Werde dann später den Check dazu nehmen und weiter beobachten. -
@ilovegym
Habe mal im tr064 Adapter die Einstellungen reduziert und gestartet. Werde dann später den Check dazu nehmen und weiter beobachten.@e-s
Ich habe eine neue Funktion eingebaut, mit der die Fehler nicht mehr auftreten sollten. Laut AVM kann es passieren, das sich mehrere Clients gegenseitig stören. Ist aber noch nicht auf github verfügbar. Bin gerade am Testen. Das mit der Auslastung schaue ich mir auch mal an. -
@e-s
Ich habe eine neue Funktion eingebaut, mit der die Fehler nicht mehr auftreten sollten. Laut AVM kann es passieren, das sich mehrere Clients gegenseitig stören. Ist aber noch nicht auf github verfügbar. Bin gerade am Testen. Das mit der Auslastung schaue ich mir auch mal an.@afuerhoff
War schon am überlegen ob ich jeweils einen eigenen user anlegen oder ob man mit avm mal in kontakt tritt.
Vielleicht wäre es ja möglich das die einen Port aktivieren auf den man lauschen kann oder einen kompletten Monitoring Port als Alternative.
So das eben nicht ständig gepullt werden muss.
