  4. [gelöst] Update nicht möglich / Error: Cannot find module
updateiobrokercannot find module
114 Beiträge 4 Kommentatoren 15.5k Aufrufe 1 Beobachtet
  • T thorkillar
    nodejs -v v10.19.0
    node -v v10.19.0
    npm -v 6.13.4
    iobroker version
    sudo: Hostname buanet-iobroker1 kann nicht aufgelöst werden
    internal/modules/cjs/loader.js:638
    throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iob
    roker.js'
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    at startup (internal/bootstrap/node.js:283:19)
    at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    GlasfaserG Offline
    GlasfaserG Offline
    @thorkillar
    Versionen sehen gut aus !
    @Glasfaser sagte in Update nicht möglich / Error: Cannot find module:
    @Glasfaser
    Du hast keine Rechte lass mal den fixer laufen , aber vorher pkill io
    curl -sL https://iobroker.net/fix.sh | bash -
    und dann das Update nochmal !
    • GlasfaserG Glasfaser
      @Glasfaser
      thorkillar
      @Glasfaser
      library: loaded
      Library version=2020-01-30
      ioBroker or some processes are still running:
      io.admin.0
      io.discovery.0
      io.ping.0
      io.web.0
      io.history.0
      io.tankerkoenig.0
      io.lgtv.0
      io.pushover.0
      io.javascript.0
      io.nuki.0
      io.pushover.1
      io.pushover.2
      io.pushover.3
      io.pushover.4
      io.pushover.5
      io.hue.0
      io.javascript.1
      io.javascript.2
      io.pollenflug.0
      io.bring.0
      io.info.0
      io.sonos.0
      io.roomba.0
      io.alexa2.0
      io.backitup.0
      io.emby.0
      io.ical.0
      io.ical.2
      Please stop them first and try again!
      • T thorkillar
        @Glasfaser
        library: loaded
        io.admin.0
        io.discovery.0
        io.ping.0
        io.web.0
        io.history.0
        io.tankerkoenig.0
        io.lgtv.0
        io.pushover.0
        io.javascript.0
        io.nuki.0
        io.pushover.1
        io.pushover.2
        io.pushover.3
        io.pushover.4
        io.pushover.5
        io.hue.0
        io.javascript.1
        io.javascript.2
        io.pollenflug.0
        io.bring.0
        io.info.0
        io.sonos.0
        io.roomba.0
        io.alexa2.0
        io.backitup.0
        io.emby.0
        io.ical.0
        io.ical.2
        GlasfaserG Offline
        GlasfaserG Offline
        @thorkillar
        Hallo !!!!
        pkill io
        vorher !!!!
        EDIT : nicht so schnelle ... du mußt auch lesen !!!
          @thorkillar
          Hallo !!!!
          pkill io
          vorher !!!!
          thorkillar
          @Glasfaser entschuldige bitte, ich hatte das nicht als Aufforderung verstanden, einzugeben.
          Der Befehl geht nicht !!
          pkill io
          Hier auch Thread dazu , bzw. suchen . Link Text
          ich habe jetzt pkill io ausgeführt und danach
          curl -sL https://iobroker.net/fix.sh | bash-
          mit folgendem Resultat:
          ckages [521 kB]
          Holen:7 http://deb.debian.org/debian stretch-updates/main amd64 Packages.diff/In
          dex [13,0 kB]
          Holen:8 http://deb.debian.org/debian stretch-updates/main amd64 Packages 2020-02
          -23-2017.41.pdiff [1.539 B]
          Es wurden 721 kB in 2 s geholt (324 kB/s).
          Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          This system does not support setting default permissions.
          Do not use npm to manually install adapters unless you know what you are doing!
          Checking autostart (3/3)
          Unsupported init system, cannot enable autostart!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
          root@buanet-iobroker1:/opt/iobroker#
          • T thorkillar
            pkill io
            ckages [521 kB]
            dex [13,0 kB]
            Installed gcc-c++
            GlasfaserG Offline
            GlasfaserG Offline
            @thorkillar
            sieht doch gut aus !
            so jetzt :
            cd /opt/iobroker
            npm install iobroker.js-controller --production
              thorkillar
              schrieb am zuletzt editiert von thorkillar
              Da kommt leider das bei rum :-(
              npm ERR! code EACCES
              npm ERR! syscall scandir
              npm ERR! path /opt/iobroker/node_modules/@types/.color-name.DELETE
              npm ERR! errno -13
              npm ERR! Error: EACCES: permission denied, scandir '/opt/iobroker/node_modules/@
              types/.color-name.DELETE'
              npm ERR! { [Error: EACCES: permission denied, scandir '/opt/iobroker/node_modul
              es/@types/.color-name.DELETE']
              npm ERR! cause:
              npm ERR! { Error: EACCES: permission denied, scandir '/opt/iobroker/node_modu
              les/@types/.color-name.DELETE'
              npm ERR! errno: -13,
              npm ERR! code: 'EACCES',
              npm ERR! syscall: 'scandir',
              npm ERR! path: '/opt/iobroker/node_modules/@types/.color-name.DELETE' },
              npm ERR! stack:
              npm ERR! 'Error: EACCES: permission denied, scandir '/opt/iobroker/node_modu
              les/@types/.color-name.DELETE'',
              npm ERR!
              npm ERR! The operation was rejected by your operating system.
              npm ERR! It is likely you do not have the permissions to access this file as the
              current user
              npm ERR!
              npm ERR! If you believe this might be a permissions issue, please double-check t
              he
              npm ERR! permissions of the file and its containing directories, or try running
              npm ERR! the command again as root/Administrator.
              npm ERR! /home/iobroker/.npm/_logs/2020-04-04T18_23_48_418Z-debug.log
              • T thorkillar
                npm ERR! errno -13
                npm ERR! cause:
                npm ERR! stack:
                npm ERR!
                current user
                npm ERR!
                he
                GlasfaserG Offline
                GlasfaserG Offline
                @thorkillar
                mach mal sudo davor .
                sudo npm install iobroker.js-controller --production
                EDIT :
                Bitte benutzt die Code Tags Funktion -> </>
                Hier gehts zur Hilfe. Link Text
                  thorkillar
                  jetzt ist schon etwas mehr passiert :-)
                  iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  node lib/preinstallCheck.js
                  NPM version: 6.13.4
                  node-bluetooth@1.2.6 install /opt/iobroker/node_modules/node-bluetooth
                  node-gyp configure build
                  make: Verzeichnis „/opt/iobroker/node_modules/node-bluetooth/build“ wird betreten
                  CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o
                  CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o
                  ../src/linux/DeviceINQ.cc:35:37: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden
                  #include <bluetooth/bluetooth.h>
                  compilation terminated.
                  BluetoothSerialPort.target.mk:109: die Regel für Ziel „Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o“ scheiterte
                  make: *** [Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1
                  make: Verzeichnis „/opt/iobroker/node_modules/node-bluetooth/build“ wird verlassen
                  gyp ERR! build error
                  gyp ERR! stack Error: make failed with exit code: 2
                  gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
                  gyp ERR! stack at ChildProcess.emit (events.js:198:13)
                  gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                  gyp ERR! System Linux 4.4.59+
                  gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
                  gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
                  gyp ERR! node -v v10.19.0
                  gyp ERR! node-gyp -v v5.0.5
                  gyp ERR! not ok
                  gyp ERR! not ok
                  iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
                  node iobroker.js setup first
                  object 0_userdata.0.example_state created
                  113 file(s) successfully synchronized with ioBroker storage.
                  Please DO NOT copy files manually into ioBroker storage directories!
                  The following notifications happened during sync:
                  • Ignoring Directory "sayit.0" because officially not created as meta object. Please remove directory!
                  • Ignoring Directory "tr-064-community.admin" because officially not created as meta object. Please remove directory!
                  • Added 113 Files in Directory "vis.0"
                  • Ignoring Directory "vis.0Test_Vis2_Test" because officially not created as meta object. Please remove directory!
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/body-parser/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/express/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/express-session/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/finalhandler/package.json'
                  npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/send/package.json'
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 (node_modules/node-bluetooth):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.6 install: node-gyp configure build
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  • iobroker.js-controller@2.2.9
                    added 5 packages from 4 contributors, removed 140 packages and updated 21 packages in 89.982s
                  9 packages are looking for funding
                  run npm fund for details
                  │ New minor version of npm available! 6.13.4 → 6.14.4 │
                  │ Changelog: https://github.com/npm/cli/releases/tag/v6.14.4 │
                  │ Run npm install -g npm to update! │
                  • T thorkillar
                    NPM version: 6.13.4
                    gyp ERR! not ok
                    gyp ERR! not ok
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @thorkillar
                    so jetzt :
                    cd /opt/iobroker
                    iobroker version
                      @thorkillar
                      so jetzt :
                      cd /opt/iobroker
                      iobroker version
                      thorkillar
                      cd /opt/iobroker
                      • T thorkillar
                        cd /opt/iobroker
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @thorkillar
                        Da ist ja ganz schön etwas vermurkst !
                        node-forge , habe ich noch nie gehört , ich suche mal !
                          @thorkillar
                          thorkillar
                          @Glasfaser danke für deine Hilfe. ich warte.
                          • T thorkillar
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @thorkillar
                            Hast du den Adapter NODE-RED ?
                              @thorkillar
                              thorkillar
                              Ich bin mir nicht sicher. Ich glaube, ich hatte es zu testzwecken mal installiert und danach deinstalliert.
                              • T thorkillar
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @thorkillar
                                versuche erstmal ohne sudo
                                cd /opt/iobroker
                                npm install node-forge
                                  @thorkillar
                                  cd /opt/iobroker
                                  thorkillar
                                  cd /opt/iobroker
                                  • T thorkillar
                                    cd /opt/iobroker
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @thorkillar
                                    dann mit sudo davor
                                      @thorkillar
                                      dann mit sudo davor
                                      thorkillar
                                      • T thorkillar
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        @thorkillar
                                        cd /opt/iobroker
                                        iobroker version
                                          thorkillar
                                          cd /opt/iobroker
                                          iobroker version
