  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 796.7k Aufrufe 118 Beobachtet
  • K Kueppert
    Hi zusammen,
    ich hatte gerade nachdem mein Saugi fertig war mit saugen, eine 100% CPU-Auslastung. Ich hatte folgendes im Log:
    host.ioBroker2	2020-03-27 12:22:38.108	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
    host.ioBroker2	2020-03-27 12:22:38.108	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
    host.ioBroker2	2020-03-27 12:22:38.107	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[13]: 17: 0x1de16585a2e1
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local<v8::Value>, node::encoding, int*) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local<v8::Value>) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle<v8::internal::String>, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle<v8::internal::ConsString>, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
    host.ioBroker2	2020-03-27 12:22:38.105	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
    Ist das erste Mal aufgetreten heute O.o
    H
    H
    Hyperbit
    #659
    @Kueppert läuft das bei dir auf einem Raspberry?
    Ich lese da Out of Memory und interpretiere da hinein das der Prozess dann abgeschossen wurde (ist aber nur ein schneller Blick auf die deinen Logauszug vom Handy aus).
    Lg
    • K Kueppert
      @dirkhe hab noch was gefunden, das ggf. weiterhilft:
      2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
      2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
      2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
      2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
      2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
      2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
      2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
      2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
      2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
      2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
      2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
      2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
      2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
      D
      D
      dirkhe
      #660
      @Kueppert hier ist er gar nicht mit dem robbi verbunden. Irgendwann müsste dann auch noch ein Connect kommen.
      • D dirkhe
        Eigentlich reichen die Zeilen vorher vom Adapter. Wenn aber davor andere Sachen auch verrückt spielen oder da eine Menge los war, ist das vlt auch sinnvoll. Man kann an dem Log nicht erkennen, wo das ganze aufgetreten ist
        K
        K
        Kueppert
        #661
        @dirkhe hab nochmal mehr logging über einen längeren Zeitraum hier angefügt:
        2020-03-27 11:35:22.125 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:35:25.829 - info: nut.0 (579) Start NUT update
        2020-03-27 11:35:25.842 - info: nut.0 (579) All Nut values set
        2020-03-27 11:35:26.171 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:35:34.549 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:35:42.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:35:46.727 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:35:54.377 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:36:06.046 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:36:12.678 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:36:12.679 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:36:12.679 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:36:12.946 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:36:12.963 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:36:12.979 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:36:13.132 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:36:13.348 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:36:17.454 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:36:42.170 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:36:48.611 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 11:36:54.786 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:05.891 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:11.345 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:13.197 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:37:13.198 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:37:13.198 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:37:13.492 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:37:13.506 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:37:13.520 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:37:13.633 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:37:14.833 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:25.149 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:34.711 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:39.452 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:42.708 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:46.689 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:50.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:53.559 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:37:57.080 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:04.140 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:07.533 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:10.774 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:13.712 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:38:13.712 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:38:13.712 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:38:13.957 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:38:13.961 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:13.971 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:38:13.985 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:38:14.106 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:38:20.958 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:25.256 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:35.222 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:38.625 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:41.670 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:55.343 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:38:58.593 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:02.020 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:05.311 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:08.707 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:11.964 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:14.181 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:39:14.182 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:39:14.182 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:39:14.435 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:39:14.459 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:39:14.482 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:39:14.695 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:39:18.782 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:24.201 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:27.647 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:31.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:34.295 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:38.334 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:41.816 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:45.382 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:48.586 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:51.843 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:39:58.839 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:02.025 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:08.908 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:12.409 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:14.788 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:40:14.789 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:40:14.789 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:40:15.055 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:40:15.084 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:40:15.108 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:40:15.298 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:40:15.801 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:22.858 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:25.831 - info: nut.0 (579) Start NUT update
        2020-03-27 11:40:25.845 - info: nut.0 (579) All Nut values set
        2020-03-27 11:40:26.137 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:29.554 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:36.245 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:50.405 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
        2020-03-27 11:40:52.555 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
        2020-03-27 11:40:52.989 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:56.217 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:40:59.538 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:41:09.693 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:41:12.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:41:15.444 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:41:15.444 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:41:15.444 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:41:15.713 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:41:15.733 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:41:15.751 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:41:15.918 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:41:19.465 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:41:47.585 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:41:48.614 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 11:41:51.106 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:41:54.358 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:42:01.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:42:11.353 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:42:15.881 - warn: sonoff.0 (636) Client "Sonoff-S10-Wohnzimmer" not connected
        2020-03-27 11:42:16.056 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:42:16.056 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:42:16.056 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:42:16.323 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:42:16.362 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:42:16.389 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:42:16.636 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:42:18.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:42:38.243 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:42:45.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:42:55.433 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:42:58.594 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:43:05.420 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:43:11.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:43:16.732 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:43:16.733 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:43:16.733 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:43:17.032 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:43:17.058 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:43:17.078 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:43:17.249 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:43:35.351 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:43:42.064 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:02.001 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:05.570 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:12.313 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:17.329 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:44:17.329 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:44:17.329 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:44:17.577 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:44:17.591 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:44:17.606 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:44:17.743 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:44:18.857 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:22.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:29.048 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:32.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:42.700 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:49.464 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:52.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:56.369 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:44:59.952 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:00.022 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 11811
        2020-03-27 11:45:01.781 - info: daswetter.0 (11811) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
        2020-03-27 11:45:02.610 - info: daswetter.0 (11811) Terminated (NO_ERROR): Without reason
        2020-03-27 11:45:03.120 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2020-03-27 11:45:03.539 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:06.746 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:13.481 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:17.084 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:17.844 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:45:17.845 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:45:17.845 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:45:18.080 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:45:18.100 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:45:18.116 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:45:18.251 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:45:20.666 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:24.057 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:25.833 - info: nut.0 (579) Start NUT update
        2020-03-27 11:45:25.852 - info: nut.0 (579) All Nut values set
        2020-03-27 11:45:30.813 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:34.324 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:37.919 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:44.784 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:48.191 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:51.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:55.321 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:45:58.884 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:02.372 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:08.897 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:12.532 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:18.340 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:46:18.341 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:46:18.341 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:46:18.633 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:46:18.655 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:46:18.672 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:46:18.862 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:46:19.486 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:23.016 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:30.061 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:34.097 - info: info.0 (855) Popup news was read...
        2020-03-27 11:46:37.139 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:40.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:43.695 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:47.796 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
        2020-03-27 11:46:48.617 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 11:46:49.998 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
        2020-03-27 11:46:50.524 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:53.865 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:46:57.326 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:47:00.643 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:47:08.240 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:47:15.347 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:47:19.006 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:47:19.007 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:47:19.007 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:47:19.293 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:47:19.316 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:47:19.335 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:47:19.488 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:47:22.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:47:28.878 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:47:35.391 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:47:40.287 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
        2020-03-27 11:47:40.288 - info: web-speedy.0 (2583) Run test on on Best Server found
        2020-03-27 11:47:40.292 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
        2020-03-27 11:47:42.062 - info: web-speedy.0 (2583) Closest server found, running test
        2020-03-27 11:47:56.668 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:48:00.376 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:48:07.741 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:48:19.569 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:48:19.570 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:48:19.570 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:48:19.837 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:48:19.852 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:48:19.870 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:48:20.037 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:48:41.515 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:48:44.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:48:46.231 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
        2020-03-27 11:48:46.233 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
        2020-03-27 11:48:46.267 - info: web-speedy.0 (2583) The speed test has been completed successfully.
        2020-03-27 11:48:55.771 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:48:59.039 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:49:06.111 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:49:09.562 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:49:12.898 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:49:16.380 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:49:20.187 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:49:20.188 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:49:20.188 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:49:20.438 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:49:20.461 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:49:20.485 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:49:20.639 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:49:26.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:49:47.270 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:49:50.761 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:50:08.038 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:50:15.685 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:50:20.725 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:50:20.726 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:50:20.726 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:50:21.037 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:50:21.059 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:50:21.071 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:50:21.177 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:50:22.688 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:50:25.834 - info: nut.0 (579) Start NUT update
        2020-03-27 11:50:25.854 - info: nut.0 (579) All Nut values set
        2020-03-27 11:50:57.626 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
        2020-03-27 11:51:21.298 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:51:21.298 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:51:21.298 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:51:21.565 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:51:21.582 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:51:21.609 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 11:51:21.849 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:51:22.830 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:51:42.831 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:51:48.621 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 11:52:02.833 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:52:21.967 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:52:21.968 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:52:21.968 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:52:22.242 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:52:22.270 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:52:22.291 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 11:52:22.501 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:52:22.834 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:52:42.835 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:52:47.306 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
        2020-03-27 11:52:49.619 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
        2020-03-27 11:53:02.837 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:53:22.645 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:53:22.646 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:53:22.646 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:53:22.839 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:53:22.902 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:53:22.916 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:53:22.931 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 11:53:23.107 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:53:42.839 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:54:02.841 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:54:22.842 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:54:23.220 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:54:23.220 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:54:23.220 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:54:23.468 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:54:23.498 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:54:23.516 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 11:54:23.660 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:54:42.843 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:55:02.843 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:55:22.844 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:55:23.758 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:55:23.759 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:55:23.759 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:55:24.018 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:55:24.038 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:55:24.056 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 11:55:24.195 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:55:25.835 - info: nut.0 (579) Start NUT update
        2020-03-27 11:55:25.848 - info: nut.0 (579) All Nut values set
        2020-03-27 11:55:42.846 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:56:02.846 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:56:22.848 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:56:24.290 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:56:24.290 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:56:24.291 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:56:24.550 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:56:24.582 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:56:24.611 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 11:56:24.744 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:56:42.849 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:56:48.623 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 11:57:02.851 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:57:22.852 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:57:24.830 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:57:24.831 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:57:24.831 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:57:25.151 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:57:25.175 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:57:25.216 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 11:57:25.375 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:57:42.852 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:58:02.854 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:58:22.855 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:58:25.493 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:58:25.494 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:58:25.494 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:58:25.797 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:58:25.816 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:58:25.842 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 11:58:26.091 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:58:43.077 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:58:47.481 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
        2020-03-27 11:58:49.626 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
        2020-03-27 11:59:03.079 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:59:23.079 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 11:59:26.196 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 11:59:26.196 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 11:59:26.196 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 11:59:26.439 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 11:59:26.459 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 11:59:26.497 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 11:59:26.634 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 11:59:43.081 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:00:00.023 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 29088
        2020-03-27 12:00:01.676 - info: daswetter.0 (29088) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
        2020-03-27 12:00:02.358 - info: daswetter.0 (29088) Terminated (NO_ERROR): Without reason
        2020-03-27 12:00:02.868 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2020-03-27 12:00:03.125 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:00:04.040 - info: host.ioBroker2 instance system.adapter.ical.0 started with pid 29255
        2020-03-27 12:00:14.339 - info: host.ioBroker2 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2020-03-27 12:00:23.126 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:00:25.836 - info: nut.0 (579) Start NUT update
        2020-03-27 12:00:25.848 - info: nut.0 (579) All Nut values set
        2020-03-27 12:00:26.716 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:00:26.716 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:00:26.716 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:00:27.029 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:00:27.046 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:00:27.068 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 12:00:27.207 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:00:43.127 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:01:03.128 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:01:23.130 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:01:27.323 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:01:27.323 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:01:27.324 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:01:27.619 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:01:27.640 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:01:27.667 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 12:01:27.822 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:01:43.130 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:01:48.627 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 12:02:03.136 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:02:23.137 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:02:27.898 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:02:27.898 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:02:27.898 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:02:28.239 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:02:28.254 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:02:28.269 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 12:02:28.387 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:02:43.138 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:02:48.401 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
        2020-03-27 12:03:03.139 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:03:23.141 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:03:28.462 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:03:28.463 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:03:28.463 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:03:28.758 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:03:28.775 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:03:28.790 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 12:03:28.962 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:03:43.142 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:04:03.143 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:04:23.144 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:04:29.045 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:04:29.045 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:04:29.045 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:04:29.312 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:04:29.326 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:04:29.339 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 12:04:29.464 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:04:43.145 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:04:51.465 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
        2020-03-27 12:05:03.147 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:05:23.149 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:05:25.837 - info: nut.0 (579) Start NUT update
        2020-03-27 12:05:25.851 - info: nut.0 (579) All Nut values set
        2020-03-27 12:05:29.557 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:05:29.557 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:05:29.557 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:05:29.873 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:05:29.886 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:05:29.905 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 12:05:30.022 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:05:43.151 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:06:03.151 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:07:30.808 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:07:30.808 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:07:30.809 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:07:31.071 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:07:31.090 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:07:31.114 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:07:31.278 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:08:31.361 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:08:31.362 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:08:31.362 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:08:31.689 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:08:31.706 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:08:31.724 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:08:31.886 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:09:31.986 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:09:31.987 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:09:31.987 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:09:32.323 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:09:32.341 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:09:32.358 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:09:32.498 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:10:25.838 - info: nut.0 (579) Start NUT update
        2020-03-27 12:10:25.851 - info: nut.0 (579) All Nut values set
        2020-03-27 12:10:32.591 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:10:32.591 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:10:32.591 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:10:32.877 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:10:32.898 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:10:32.914 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:10:33.041 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:10:47.363 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
        2020-03-27 12:10:49.501 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
        2020-03-27 12:11:33.116 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:11:33.116 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:11:33.116 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:11:33.434 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:11:33.456 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:11:33.486 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:11:33.626 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:11:48.633 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 12:12:33.713 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:12:33.713 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:12:33.713 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:12:34.034 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:12:34.049 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:12:34.067 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:12:34.186 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:12:59.391 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
        2020-03-27 12:13:01.572 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
        2020-03-27 12:13:34.264 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:13:34.264 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:13:34.264 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:13:34.591 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:13:34.606 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:13:34.620 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:13:34.749 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:14:34.825 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:14:34.826 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:14:34.826 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:14:35.119 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:14:35.147 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:14:35.170 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:14:35.371 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:15:00.026 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 14507
        2020-03-27 12:15:01.858 - info: daswetter.0 (14507) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
        2020-03-27 12:15:02.856 - info: daswetter.0 (14507) Terminated (NO_ERROR): Without reason
        2020-03-27 12:15:03.366 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
        2020-03-27 12:15:25.840 - info: nut.0 (579) Start NUT update
        2020-03-27 12:15:25.853 - info: nut.0 (579) All Nut values set
        2020-03-27 12:15:35.479 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:15:35.480 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:15:35.480 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:15:35.754 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:15:35.770 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:15:35.788 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:15:35.950 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:16:34.114 - info: info.0 (855) Popup news was read...
        2020-03-27 12:16:36.046 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:16:36.046 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:16:36.047 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:16:36.292 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:16:36.318 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:16:36.337 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:16:36.473 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:16:48.635 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 12:17:36.548 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:17:36.548 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:17:36.549 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:17:36.790 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:17:36.806 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:17:36.824 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:17:36.953 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:17:40.294 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
        2020-03-27 12:17:40.295 - info: web-speedy.0 (2583) Run test on on Best Server found
        2020-03-27 12:17:40.299 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
        2020-03-27 12:17:42.155 - info: web-speedy.0 (2583) Closest server found, running test
        2020-03-27 12:18:37.039 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:18:37.040 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:18:37.040 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:18:37.300 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:18:37.317 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:18:37.331 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:18:37.481 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:18:44.897 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
        2020-03-27 12:18:44.901 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
        2020-03-27 12:18:44.924 - info: web-speedy.0 (2583) The speed test has been completed successfully.
        2020-03-27 12:19:03.197 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:19:03.205 - info: mihome-vacuum.0 (780) Connected
        2020-03-27 12:19:37.593 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:19:37.594 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:19:37.594 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:19:37.931 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:19:37.963 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:19:37.994 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:19:38.324 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:20:25.841 - info: nut.0 (579) Start NUT update
        2020-03-27 12:20:25.869 - info: nut.0 (579) All Nut values set
        2020-03-27 12:20:27.984 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:20:38.626 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:20:38.627 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:20:38.627 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:20:38.929 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:20:38.949 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:20:38.967 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:20:39.175 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:20:49.946 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:21:39.360 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:21:39.381 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:21:39.381 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:21:39.862 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:21:39.886 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:21:39.910 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:21:40.081 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:21:48.651 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 12:22:38.105 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
        2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
        2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
        2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
        2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local, node::encoding, int*) [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
        2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 17: 0x1de16585a2e1
        2020-03-27 12:22:38.107 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
        2020-03-27 12:22:38.108 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2020-03-27 12:22:38.108 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2020-03-27 12:22:40.300 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:22:40.301 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:22:40.301 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:22:40.568 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:22:40.588 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:22:40.607 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:22:40.872 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:23:08.163 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 23991
        2020-03-27 12:23:11.961 - info: mihome-vacuum.0 (23991) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
        2020-03-27 12:23:12.083 - info: mihome-vacuum.0 (23991) Expert mode disabled, states deleted
        2020-03-27 12:23:12.084 - info: mihome-vacuum.0 (23991) Create state clean_home for controlling by cloud adapter
        2020-03-27 12:23:12.100 - info: mihome-vacuum.0 (23991) Disconnect
        2020-03-27 12:23:12.147 - info: mihome-vacuum.0 (23991) New generation or new fw detected, create new states goto and zoneclean
        2020-03-27 12:23:12.183 - info: mihome-vacuum.0 (23991) Connected
        2020-03-27 12:23:12.652 - info: mihome-vacuum.0 (23991) set nächster Timer: Nicht verfügbar
        2020-03-27 12:23:15.110 - info: mihome-vacuum.0 (23991) create state for carpet_mode
        2020-03-27 12:23:41.038 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:23:41.039 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:23:41.039 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:23:41.299 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:23:41.319 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:23:41.347 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:23:41.566 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:24:41.033 - info: mihome-vacuum.0 (23991) Disconnect
        2020-03-27 12:24:41.677 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:24:41.677 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:24:41.677 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:24:41.944 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:24:41.987 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:24:42.025 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:24:42.222 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:25:03.902 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
        2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
        2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
        2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 5: 0xef4152 [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 10: 0xecbbb5 [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 12: 0x1203785 v8::internal::IncrementalStringBuilder::Extend() [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 13: 0xfc74f2 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 14: 0xfc7d9b v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 15: 0xfccead v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 16: 0xfcdc09 v8::internal::JsonStringifier::Stringify(v8::internal::Handle, v8::internal::Handle, v8::internal::Handle) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 17: 0xbd46d1 v8::internal::Builtin_JsonStringify(int, v8::internal::Object**, v8::internal::Isolate*) [io.mihome-vacuum.0]
        2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 18: 0xbcdda65bf7d
        2020-03-27 12:25:03.905 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
        2020-03-27 12:25:03.905 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
        2020-03-27 12:25:03.905 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
        2020-03-27 12:25:25.848 - info: nut.0 (579) Start NUT update
        2020-03-27 12:25:25.949 - info: nut.0 (579) All Nut values set
        2020-03-27 12:25:33.930 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 26894
        2020-03-27 12:25:37.015 - info: mihome-vacuum.0 (26894) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
        2020-03-27 12:25:37.080 - info: mihome-vacuum.0 (26894) Expert mode disabled, states deleted
        2020-03-27 12:25:37.081 - info: mihome-vacuum.0 (26894) Create state clean_home for controlling by cloud adapter
        2020-03-27 12:25:37.093 - info: mihome-vacuum.0 (26894) Disconnect
        2020-03-27 12:25:37.132 - info: mihome-vacuum.0 (26894) New generation or new fw detected, create new states goto and zoneclean
        2020-03-27 12:25:37.160 - info: mihome-vacuum.0 (26894) Connected
        2020-03-27 12:25:37.617 - info: mihome-vacuum.0 (26894) set nächster Timer: Nicht verfügbar
        2020-03-27 12:25:42.445 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:25:42.446 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:25:42.446 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:25:42.750 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:25:42.772 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:25:42.789 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:25:42.985 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:25:52.169 - warn: mihome-vacuum.0 (26894) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
        2020-03-27 12:26:17.096 - info: mihome-vacuum.0 (26894) Disconnect
        2020-03-27 12:26:17.101 - info: mihome-vacuum.0 (26894) Connected
        2020-03-27 12:26:43.100 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:26:43.101 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:26:43.101 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:26:43.383 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:26:43.396 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:26:43.410 - info: unifi.0 (2203) getClientDevices: 23
        2020-03-27 12:26:43.557 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:26:48.940 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 12:26:57.098 - info: mihome-vacuum.0 (26894) Disconnect
        2020-03-27 12:26:57.107 - info: mihome-vacuum.0 (26894) Connected
        2020-03-27 12:27:37.102 - info: mihome-vacuum.0 (26894) Disconnect
        2020-03-27 12:27:37.157 - info: mihome-vacuum.0 (26894) Connected
        Ein Memory-Problem sollte ich eigentlich nicht haben mit 3,5 GB
        • K Kueppert
          @dirkhe hab nochmal mehr logging über einen längeren Zeitraum hier angefügt:
          2020-03-27 11:35:22.125 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:35:25.829 - info: nut.0 (579) Start NUT update
          2020-03-27 11:35:25.842 - info: nut.0 (579) All Nut values set
          2020-03-27 11:35:26.171 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:35:34.549 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:35:42.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:35:46.727 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:35:54.377 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:36:06.046 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:36:12.678 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:36:12.679 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:36:12.679 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:36:12.946 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:36:12.963 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:36:12.979 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:36:13.132 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:36:13.348 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:36:17.454 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:36:42.170 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:36:48.611 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 11:36:54.786 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:05.891 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:11.345 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:13.197 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:37:13.198 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:37:13.198 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:37:13.492 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:37:13.506 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:37:13.520 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:37:13.633 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:37:14.833 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:25.149 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:34.711 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:39.452 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:42.708 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:46.689 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:50.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:53.559 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:37:57.080 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:04.140 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:07.533 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:10.774 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:13.712 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:38:13.712 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:38:13.712 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:38:13.957 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:38:13.961 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:13.971 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:38:13.985 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:38:14.106 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:38:20.958 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:25.256 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:35.222 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:38.625 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:41.670 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:55.343 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:38:58.593 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:02.020 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:05.311 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:08.707 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:11.964 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:14.181 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:39:14.182 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:39:14.182 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:39:14.435 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:39:14.459 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:39:14.482 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:39:14.695 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:39:18.782 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:24.201 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:27.647 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:31.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:34.295 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:38.334 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:41.816 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:45.382 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:48.586 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:51.843 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:39:58.839 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:02.025 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:08.908 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:12.409 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:14.788 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:40:14.789 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:40:14.789 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:40:15.055 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:40:15.084 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:40:15.108 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:40:15.298 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:40:15.801 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:22.858 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:25.831 - info: nut.0 (579) Start NUT update
          2020-03-27 11:40:25.845 - info: nut.0 (579) All Nut values set
          2020-03-27 11:40:26.137 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:29.554 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:36.245 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:50.405 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
          2020-03-27 11:40:52.555 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
          2020-03-27 11:40:52.989 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:56.217 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:40:59.538 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:41:09.693 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:41:12.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:41:15.444 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:41:15.444 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:41:15.444 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:41:15.713 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:41:15.733 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:41:15.751 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:41:15.918 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:41:19.465 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:41:47.585 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:41:48.614 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 11:41:51.106 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:41:54.358 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:42:01.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:42:11.353 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:42:15.881 - warn: sonoff.0 (636) Client "Sonoff-S10-Wohnzimmer" not connected
          2020-03-27 11:42:16.056 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:42:16.056 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:42:16.056 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:42:16.323 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:42:16.362 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:42:16.389 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:42:16.636 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:42:18.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:42:38.243 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:42:45.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:42:55.433 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:42:58.594 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:43:05.420 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:43:11.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:43:16.732 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:43:16.733 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:43:16.733 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:43:17.032 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:43:17.058 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:43:17.078 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:43:17.249 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:43:35.351 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:43:42.064 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:02.001 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:05.570 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:12.313 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:17.329 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:44:17.329 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:44:17.329 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:44:17.577 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:44:17.591 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:44:17.606 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:44:17.743 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:44:18.857 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:22.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:29.048 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:32.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:42.700 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:49.464 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:52.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:56.369 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:44:59.952 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:00.022 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 11811
          2020-03-27 11:45:01.781 - info: daswetter.0 (11811) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
          2020-03-27 11:45:02.610 - info: daswetter.0 (11811) Terminated (NO_ERROR): Without reason
          2020-03-27 11:45:03.120 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2020-03-27 11:45:03.539 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:06.746 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:13.481 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:17.084 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:17.844 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:45:17.845 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:45:17.845 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:45:18.080 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:45:18.100 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:45:18.116 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:45:18.251 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:45:20.666 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:24.057 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:25.833 - info: nut.0 (579) Start NUT update
          2020-03-27 11:45:25.852 - info: nut.0 (579) All Nut values set
          2020-03-27 11:45:30.813 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:34.324 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:37.919 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:44.784 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:48.191 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:51.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:55.321 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:45:58.884 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:02.372 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:08.897 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:12.532 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:18.340 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:46:18.341 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:46:18.341 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:46:18.633 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:46:18.655 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:46:18.672 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:46:18.862 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:46:19.486 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:23.016 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:30.061 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:34.097 - info: info.0 (855) Popup news was read...
          2020-03-27 11:46:37.139 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:40.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:43.695 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:47.796 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
          2020-03-27 11:46:48.617 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 11:46:49.998 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
          2020-03-27 11:46:50.524 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:53.865 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:46:57.326 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:47:00.643 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:47:08.240 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:47:15.347 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:47:19.006 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:47:19.007 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:47:19.007 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:47:19.293 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:47:19.316 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:47:19.335 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:47:19.488 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:47:22.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:47:28.878 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:47:35.391 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:47:40.287 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
          2020-03-27 11:47:40.288 - info: web-speedy.0 (2583) Run test on on Best Server found
          2020-03-27 11:47:40.292 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
          2020-03-27 11:47:42.062 - info: web-speedy.0 (2583) Closest server found, running test
          2020-03-27 11:47:56.668 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:48:00.376 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:48:07.741 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:48:19.569 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:48:19.570 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:48:19.570 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:48:19.837 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:48:19.852 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:48:19.870 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:48:20.037 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:48:41.515 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:48:44.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:48:46.231 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
          2020-03-27 11:48:46.233 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
          2020-03-27 11:48:46.267 - info: web-speedy.0 (2583) The speed test has been completed successfully.
          2020-03-27 11:48:55.771 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:48:59.039 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:49:06.111 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:49:09.562 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:49:12.898 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:49:16.380 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:49:20.187 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:49:20.188 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:49:20.188 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:49:20.438 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:49:20.461 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:49:20.485 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:49:20.639 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:49:26.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:49:47.270 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:49:50.761 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:50:08.038 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:50:15.685 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:50:20.725 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:50:20.726 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:50:20.726 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:50:21.037 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:50:21.059 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:50:21.071 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:50:21.177 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:50:22.688 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:50:25.834 - info: nut.0 (579) Start NUT update
          2020-03-27 11:50:25.854 - info: nut.0 (579) All Nut values set
          2020-03-27 11:50:57.626 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
          2020-03-27 11:51:21.298 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:51:21.298 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:51:21.298 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:51:21.565 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:51:21.582 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:51:21.609 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 11:51:21.849 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:51:22.830 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:51:42.831 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:51:48.621 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 11:52:02.833 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:52:21.967 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:52:21.968 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:52:21.968 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:52:22.242 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:52:22.270 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:52:22.291 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 11:52:22.501 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:52:22.834 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:52:42.835 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:52:47.306 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
          2020-03-27 11:52:49.619 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
          2020-03-27 11:53:02.837 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:53:22.645 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:53:22.646 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:53:22.646 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:53:22.839 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:53:22.902 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:53:22.916 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:53:22.931 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 11:53:23.107 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:53:42.839 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:54:02.841 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:54:22.842 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:54:23.220 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:54:23.220 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:54:23.220 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:54:23.468 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:54:23.498 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:54:23.516 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 11:54:23.660 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:54:42.843 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:55:02.843 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:55:22.844 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:55:23.758 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:55:23.759 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:55:23.759 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:55:24.018 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:55:24.038 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:55:24.056 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 11:55:24.195 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:55:25.835 - info: nut.0 (579) Start NUT update
          2020-03-27 11:55:25.848 - info: nut.0 (579) All Nut values set
          2020-03-27 11:55:42.846 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:56:02.846 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:56:22.848 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:56:24.290 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:56:24.290 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:56:24.291 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:56:24.550 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:56:24.582 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:56:24.611 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 11:56:24.744 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:56:42.849 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:56:48.623 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 11:57:02.851 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:57:22.852 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:57:24.830 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:57:24.831 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:57:24.831 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:57:25.151 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:57:25.175 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:57:25.216 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 11:57:25.375 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:57:42.852 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:58:02.854 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:58:22.855 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:58:25.493 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:58:25.494 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:58:25.494 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:58:25.797 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:58:25.816 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:58:25.842 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 11:58:26.091 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:58:43.077 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:58:47.481 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
          2020-03-27 11:58:49.626 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
          2020-03-27 11:59:03.079 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:59:23.079 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 11:59:26.196 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 11:59:26.196 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 11:59:26.196 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 11:59:26.439 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 11:59:26.459 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 11:59:26.497 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 11:59:26.634 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 11:59:43.081 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:00:00.023 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 29088
          2020-03-27 12:00:01.676 - info: daswetter.0 (29088) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
          2020-03-27 12:00:02.358 - info: daswetter.0 (29088) Terminated (NO_ERROR): Without reason
          2020-03-27 12:00:02.868 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2020-03-27 12:00:03.125 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:00:04.040 - info: host.ioBroker2 instance system.adapter.ical.0 started with pid 29255
          2020-03-27 12:00:14.339 - info: host.ioBroker2 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
          2020-03-27 12:00:23.126 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:00:25.836 - info: nut.0 (579) Start NUT update
          2020-03-27 12:00:25.848 - info: nut.0 (579) All Nut values set
          2020-03-27 12:00:26.716 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:00:26.716 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:00:26.716 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:00:27.029 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:00:27.046 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:00:27.068 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 12:00:27.207 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:00:43.127 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:01:03.128 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:01:23.130 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:01:27.323 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:01:27.323 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:01:27.324 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:01:27.619 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:01:27.640 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:01:27.667 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 12:01:27.822 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:01:43.130 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:01:48.627 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 12:02:03.136 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:02:23.137 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:02:27.898 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:02:27.898 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:02:27.898 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:02:28.239 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:02:28.254 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:02:28.269 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 12:02:28.387 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:02:43.138 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:02:48.401 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
          2020-03-27 12:03:03.139 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:03:23.141 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:03:28.462 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:03:28.463 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:03:28.463 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:03:28.758 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:03:28.775 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:03:28.790 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 12:03:28.962 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:03:43.142 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:04:03.143 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:04:23.144 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:04:29.045 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:04:29.045 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:04:29.045 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:04:29.312 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:04:29.326 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:04:29.339 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 12:04:29.464 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:04:43.145 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:04:51.465 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
          2020-03-27 12:05:03.147 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:05:23.149 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:05:25.837 - info: nut.0 (579) Start NUT update
          2020-03-27 12:05:25.851 - info: nut.0 (579) All Nut values set
          2020-03-27 12:05:29.557 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:05:29.557 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:05:29.557 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:05:29.873 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:05:29.886 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:05:29.905 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 12:05:30.022 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:05:43.151 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:06:03.151 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
          2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
          2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:07:30.808 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:07:30.808 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:07:30.809 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:07:31.071 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:07:31.090 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:07:31.114 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:07:31.278 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:08:31.361 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:08:31.362 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:08:31.362 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:08:31.689 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:08:31.706 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:08:31.724 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:08:31.886 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:09:31.986 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:09:31.987 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:09:31.987 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:09:32.323 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:09:32.341 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:09:32.358 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:09:32.498 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:10:25.838 - info: nut.0 (579) Start NUT update
          2020-03-27 12:10:25.851 - info: nut.0 (579) All Nut values set
          2020-03-27 12:10:32.591 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:10:32.591 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:10:32.591 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:10:32.877 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:10:32.898 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:10:32.914 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:10:33.041 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:10:47.363 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
          2020-03-27 12:10:49.501 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
          2020-03-27 12:11:33.116 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:11:33.116 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:11:33.116 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:11:33.434 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:11:33.456 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:11:33.486 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:11:33.626 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:11:48.633 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 12:12:33.713 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:12:33.713 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:12:33.713 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:12:34.034 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:12:34.049 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:12:34.067 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:12:34.186 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:12:59.391 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
          2020-03-27 12:13:01.572 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
          2020-03-27 12:13:34.264 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:13:34.264 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:13:34.264 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:13:34.591 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:13:34.606 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:13:34.620 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:13:34.749 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:14:34.825 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:14:34.826 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:14:34.826 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:14:35.119 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:14:35.147 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:14:35.170 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:14:35.371 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:15:00.026 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 14507
          2020-03-27 12:15:01.858 - info: daswetter.0 (14507) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
          2020-03-27 12:15:02.856 - info: daswetter.0 (14507) Terminated (NO_ERROR): Without reason
          2020-03-27 12:15:03.366 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
          2020-03-27 12:15:25.840 - info: nut.0 (579) Start NUT update
          2020-03-27 12:15:25.853 - info: nut.0 (579) All Nut values set
          2020-03-27 12:15:35.479 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:15:35.480 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:15:35.480 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:15:35.754 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:15:35.770 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:15:35.788 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:15:35.950 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:16:34.114 - info: info.0 (855) Popup news was read...
          2020-03-27 12:16:36.046 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:16:36.046 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:16:36.047 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:16:36.292 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:16:36.318 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:16:36.337 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:16:36.473 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:16:48.635 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 12:17:36.548 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:17:36.548 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:17:36.549 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:17:36.790 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:17:36.806 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:17:36.824 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:17:36.953 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:17:40.294 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
          2020-03-27 12:17:40.295 - info: web-speedy.0 (2583) Run test on on Best Server found
          2020-03-27 12:17:40.299 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
          2020-03-27 12:17:42.155 - info: web-speedy.0 (2583) Closest server found, running test
          2020-03-27 12:18:37.039 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:18:37.040 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:18:37.040 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:18:37.300 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:18:37.317 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:18:37.331 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:18:37.481 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:18:44.897 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
          2020-03-27 12:18:44.901 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
          2020-03-27 12:18:44.924 - info: web-speedy.0 (2583) The speed test has been completed successfully.
          2020-03-27 12:19:03.197 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:19:03.205 - info: mihome-vacuum.0 (780) Connected
          2020-03-27 12:19:37.593 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:19:37.594 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:19:37.594 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:19:37.931 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:19:37.963 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:19:37.994 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:19:38.324 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:20:25.841 - info: nut.0 (579) Start NUT update
          2020-03-27 12:20:25.869 - info: nut.0 (579) All Nut values set
          2020-03-27 12:20:27.984 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:20:38.626 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:20:38.627 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:20:38.627 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:20:38.929 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:20:38.949 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:20:38.967 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:20:39.175 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:20:49.946 - info: mihome-vacuum.0 (780) Disconnect
          2020-03-27 12:21:39.360 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:21:39.381 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:21:39.381 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:21:39.862 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:21:39.886 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:21:39.910 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:21:40.081 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:21:48.651 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 12:22:38.105 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local, node::encoding, int*) [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 17: 0x1de16585a2e1
          2020-03-27 12:22:38.107 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
          2020-03-27 12:22:38.108 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
          2020-03-27 12:22:38.108 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
          2020-03-27 12:22:40.300 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:22:40.301 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:22:40.301 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:22:40.568 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:22:40.588 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:22:40.607 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:22:40.872 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:23:08.163 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 23991
          2020-03-27 12:23:11.961 - info: mihome-vacuum.0 (23991) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
          2020-03-27 12:23:12.083 - info: mihome-vacuum.0 (23991) Expert mode disabled, states deleted
          2020-03-27 12:23:12.084 - info: mihome-vacuum.0 (23991) Create state clean_home for controlling by cloud adapter
          2020-03-27 12:23:12.100 - info: mihome-vacuum.0 (23991) Disconnect
          2020-03-27 12:23:12.147 - info: mihome-vacuum.0 (23991) New generation or new fw detected, create new states goto and zoneclean
          2020-03-27 12:23:12.183 - info: mihome-vacuum.0 (23991) Connected
          2020-03-27 12:23:12.652 - info: mihome-vacuum.0 (23991) set nächster Timer: Nicht verfügbar
          2020-03-27 12:23:15.110 - info: mihome-vacuum.0 (23991) create state for carpet_mode
          2020-03-27 12:23:41.038 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:23:41.039 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:23:41.039 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:23:41.299 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:23:41.319 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:23:41.347 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:23:41.566 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:24:41.033 - info: mihome-vacuum.0 (23991) Disconnect
          2020-03-27 12:24:41.677 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:24:41.677 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:24:41.677 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:24:41.944 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:24:41.987 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:24:42.025 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:24:42.222 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:25:03.902 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 5: 0xef4152 [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 10: 0xecbbb5 [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 12: 0x1203785 v8::internal::IncrementalStringBuilder::Extend() [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 13: 0xfc74f2 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 14: 0xfc7d9b v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 15: 0xfccead v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 16: 0xfcdc09 v8::internal::JsonStringifier::Stringify(v8::internal::Handle, v8::internal::Handle, v8::internal::Handle) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 17: 0xbd46d1 v8::internal::Builtin_JsonStringify(int, v8::internal::Object**, v8::internal::Isolate*) [io.mihome-vacuum.0]
          2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 18: 0xbcdda65bf7d
          2020-03-27 12:25:03.905 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
          2020-03-27 12:25:03.905 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
          2020-03-27 12:25:03.905 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
          2020-03-27 12:25:25.848 - info: nut.0 (579) Start NUT update
          2020-03-27 12:25:25.949 - info: nut.0 (579) All Nut values set
          2020-03-27 12:25:33.930 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 26894
          2020-03-27 12:25:37.015 - info: mihome-vacuum.0 (26894) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
          2020-03-27 12:25:37.080 - info: mihome-vacuum.0 (26894) Expert mode disabled, states deleted
          2020-03-27 12:25:37.081 - info: mihome-vacuum.0 (26894) Create state clean_home for controlling by cloud adapter
          2020-03-27 12:25:37.093 - info: mihome-vacuum.0 (26894) Disconnect
          2020-03-27 12:25:37.132 - info: mihome-vacuum.0 (26894) New generation or new fw detected, create new states goto and zoneclean
          2020-03-27 12:25:37.160 - info: mihome-vacuum.0 (26894) Connected
          2020-03-27 12:25:37.617 - info: mihome-vacuum.0 (26894) set nächster Timer: Nicht verfügbar
          2020-03-27 12:25:42.445 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:25:42.446 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:25:42.446 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:25:42.750 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:25:42.772 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:25:42.789 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:25:42.985 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:25:52.169 - warn: mihome-vacuum.0 (26894) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
          2020-03-27 12:26:17.096 - info: mihome-vacuum.0 (26894) Disconnect
          2020-03-27 12:26:17.101 - info: mihome-vacuum.0 (26894) Connected
          2020-03-27 12:26:43.100 - info: unifi.0 (2203) Starting UniFi-Controller query
          2020-03-27 12:26:43.101 - info: unifi.0 (2203) update_interval = 60
          2020-03-27 12:26:43.101 - info: unifi.0 (2203) controller = 192.168.178.71:8443
          2020-03-27 12:26:43.383 - info: unifi.0 (2203) getSitesStats: default
          2020-03-27 12:26:43.396 - info: unifi.0 (2203) getSiteSysinfo: 1
          2020-03-27 12:26:43.410 - info: unifi.0 (2203) getClientDevices: 23
          2020-03-27 12:26:43.557 - info: unifi.0 (2203) getAccessDevices: 1
          2020-03-27 12:26:48.940 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
          2020-03-27 12:26:57.098 - info: mihome-vacuum.0 (26894) Disconnect
          2020-03-27 12:26:57.107 - info: mihome-vacuum.0 (26894) Connected
          2020-03-27 12:27:37.102 - info: mihome-vacuum.0 (26894) Disconnect
          2020-03-27 12:27:37.157 - info: mihome-vacuum.0 (26894) Connected
          Ein Memory-Problem sollte ich eigentlich nicht haben mit 3,5 GB
          D
          D
          dirkhe
          #662
          @Kueppert das kommt ja regelmäßig. Was mich wundert ist, dass er ständig disconnected. Kannst du mal die aktuelle Version installieren, bitte? Dann mal auf Debug stellen. Das sieht aus wie eine recursion, aber aktuell weiß ich gar nicht, wo das sein könnte. Allerdings bin ich beim abrufen der Karte auch nicht so tief im Code.
          • D dirkhe
            K
            K
            Kueppert
            schrieb am zuletzt editiert von Kueppert
            #663
            @dirkhe habe jetzt 2.0.9 drauf via Katze und Adapter steht auf Debug. Ich warte mal was ab...ggf muss ich den Saugi auch mal starten, damit was passiert ;) Danke dir schon mal für die Unterstützung.
            Erster Auszug:
            mihome-vacuum.0	2020-03-27 14:53:24.911	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:53:24.910	debug	(29151) no answer for undefined(id:25) received, giving up
            mihome-vacuum.0	2020-03-27 14:53:19.910	debug	(29151) sendMsg[3] >>> {"id":25,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:53:14.909	debug	(29151) sendMsg[2] >>> {"id":25,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:53:09.909	debug	(29151) sendMsg[1] >>> {"id":25,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:53:09.906	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:53:09.906	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:53:09.906	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0545ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:53:04.950	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:53:04.949	debug	(29151) no answer for undefined(id:24) received, giving up
            mihome-vacuum.0	2020-03-27 14:52:59.949	debug	(29151) sendMsg[3] >>> {"id":24,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:54.948	debug	(29151) sendMsg[2] >>> {"id":24,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:49.947	debug	(29151) sendMsg[1] >>> {"id":24,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:49.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:52:49.914	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:52:49.913	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0531ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:52:44.927	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:52:44.927	debug	(29151) no answer for undefined(id:23) received, giving up
            mihome-vacuum.0	2020-03-27 14:52:39.925	debug	(29151) sendMsg[3] >>> {"id":23,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:34.906	debug	(29151) sendMsg[2] >>> {"id":23,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:29.905	debug	(29151) sendMsg[1] >>> {"id":23,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:29.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:52:29.903	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:52:29.902	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e051dffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:52:24.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:52:24.914	debug	(29151) no answer for undefined(id:22) received, giving up
            mihome-vacuum.0	2020-03-27 14:52:19.913	debug	(29151) sendMsg[3] >>> {"id":22,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:14.911	debug	(29151) sendMsg[2] >>> {"id":22,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:09.910	debug	(29151) sendMsg[1] >>> {"id":22,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:52:09.902	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:52:09.901	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:52:09.901	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0509ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:52:04.907	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:52:04.906	debug	(29151) no answer for undefined(id:21) received, giving up
            mihome-vacuum.0	2020-03-27 14:51:59.905	debug	(29151) sendMsg[3] >>> {"id":21,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:54.904	debug	(29151) sendMsg[2] >>> {"id":21,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:49.904	debug	(29151) sendMsg[1] >>> {"id":21,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:49.901	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:51:49.900	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:51:49.900	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04f5ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:51:44.905	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:51:44.905	debug	(29151) no answer for undefined(id:20) received, giving up
            mihome-vacuum.0	2020-03-27 14:51:39.903	debug	(29151) sendMsg[3] >>> {"id":20,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:34.902	debug	(29151) sendMsg[2] >>> {"id":20,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:29.901	debug	(29151) sendMsg[1] >>> {"id":20,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:29.900	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:51:29.899	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:51:29.899	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04e1ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:51:24.904	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:51:24.904	debug	(29151) no answer for undefined(id:19) received, giving up
            mihome-vacuum.0	2020-03-27 14:51:19.903	debug	(29151) sendMsg[3] >>> {"id":19,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:14.901	debug	(29151) sendMsg[2] >>> {"id":19,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:09.900	debug	(29151) sendMsg[1] >>> {"id":19,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:51:09.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:51:09.898	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:51:09.897	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04cdffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:51:04.919	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:51:04.918	debug	(29151) no answer for undefined(id:18) received, giving up
            mihome-vacuum.0	2020-03-27 14:50:59.917	debug	(29151) sendMsg[3] >>> {"id":18,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:54.915	debug	(29151) sendMsg[2] >>> {"id":18,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:49.914	debug	(29151) sendMsg[1] >>> {"id":18,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:49.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:50:49.898	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:50:49.898	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04b9ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:50:44.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:50:44.903	debug	(29151) no answer for undefined(id:17) received, giving up
            mihome-vacuum.0	2020-03-27 14:50:39.901	debug	(29151) sendMsg[3] >>> {"id":17,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:34.900	debug	(29151) sendMsg[2] >>> {"id":17,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:29.899	debug	(29151) sendMsg[1] >>> {"id":17,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:29.896	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:50:29.896	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:50:29.896	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04a5ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:50:24.904	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:50:24.904	debug	(29151) no answer for undefined(id:16) received, giving up
            mihome-vacuum.0	2020-03-27 14:50:19.904	debug	(29151) sendMsg[3] >>> {"id":16,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:14.902	debug	(29151) sendMsg[2] >>> {"id":16,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:09.900	debug	(29151) sendMsg[1] >>> {"id":16,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:50:09.895	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:50:09.894	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:50:09.894	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0491ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:50:04.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:50:04.903	debug	(29151) no answer for undefined(id:15) received, giving up
            mihome-vacuum.0	2020-03-27 14:49:59.901	debug	(29151) sendMsg[3] >>> {"id":15,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:54.900	debug	(29151) sendMsg[2] >>> {"id":15,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:49.900	debug	(29151) sendMsg[1] >>> {"id":15,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:49.894	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:49:49.894	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:49:49.893	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e047dffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:49:44.900	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:49:44.899	debug	(29151) no answer for undefined(id:14) received, giving up
            mihome-vacuum.0	2020-03-27 14:49:39.898	debug	(29151) sendMsg[3] >>> {"id":14,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:34.897	debug	(29151) sendMsg[2] >>> {"id":14,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:29.896	debug	(29151) sendMsg[1] >>> {"id":14,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:29.893	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:49:29.893	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:49:29.892	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0469ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:49:24.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:49:24.898	debug	(29151) no answer for undefined(id:13) received, giving up
            mihome-vacuum.0	2020-03-27 14:49:19.898	debug	(29151) sendMsg[3] >>> {"id":13,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:14.896	debug	(29151) sendMsg[2] >>> {"id":13,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:09.894	debug	(29151) sendMsg[1] >>> {"id":13,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:49:09.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:49:09.890	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:49:09.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0455ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:49:04.911	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:49:04.911	debug	(29151) no answer for undefined(id:12) received, giving up
            mihome-vacuum.0	2020-03-27 14:48:59.909	debug	(29151) sendMsg[3] >>> {"id":12,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:54.907	debug	(29151) sendMsg[2] >>> {"id":12,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:49.906	debug	(29151) sendMsg[1] >>> {"id":12,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:49.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:48:49.891	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:48:49.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0441ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:48:44.902	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:48:44.902	debug	(29151) no answer for undefined(id:11) received, giving up
            mihome-vacuum.0	2020-03-27 14:48:39.900	debug	(29151) sendMsg[3] >>> {"id":11,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:34.899	debug	(29151) sendMsg[2] >>> {"id":11,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:29.897	debug	(29151) sendMsg[1] >>> {"id":11,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:29.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:48:29.891	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:48:29.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e042dffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:48:24.938	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:48:24.938	debug	(29151) no answer for undefined(id:10) received, giving up
            mihome-vacuum.0	2020-03-27 14:48:19.937	debug	(29151) sendMsg[3] >>> {"id":10,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:14.935	debug	(29151) sendMsg[2] >>> {"id":10,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:09.934	debug	(29151) sendMsg[1] >>> {"id":10,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:48:09.888	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:48:09.888	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:48:09.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0419ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:48:04.906	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:48:04.905	debug	(29151) no answer for undefined(id:9) received, giving up
            mihome-vacuum.0	2020-03-27 14:47:59.904	debug	(29151) sendMsg[3] >>> {"id":9,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:54.902	debug	(29151) sendMsg[2] >>> {"id":9,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:49.901	debug	(29151) sendMsg[1] >>> {"id":9,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:49.888	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:47:49.888	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:47:49.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0405ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:47:44.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:47:44.897	debug	(29151) no answer for undefined(id:8) received, giving up
            mihome-vacuum.0	2020-03-27 14:47:39.895	debug	(29151) sendMsg[3] >>> {"id":8,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:34.894	debug	(29151) sendMsg[2] >>> {"id":8,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:29.892	debug	(29151) sendMsg[1] >>> {"id":8,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:29.887	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:47:29.887	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:47:29.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03f1ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:47:24.899	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:47:24.898	debug	(29151) no answer for undefined(id:7) received, giving up
            mihome-vacuum.0	2020-03-27 14:47:19.897	debug	(29151) sendMsg[3] >>> {"id":7,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:14.895	debug	(29151) sendMsg[2] >>> {"id":7,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:09.893	debug	(29151) sendMsg[1] >>> {"id":7,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:47:09.886	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:47:09.886	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:47:09.886	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03ddffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:47:04.905	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:47:04.905	debug	(29151) no answer for undefined(id:6) received, giving up
            mihome-vacuum.0	2020-03-27 14:46:59.903	debug	(29151) sendMsg[3] >>> {"id":6,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:46:54.901	debug	(29151) sendMsg[2] >>> {"id":6,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:46:49.899	debug	(29151) sendMsg[1] >>> {"id":6,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:46:49.886	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:46:49.886	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:46:49.886	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03c9ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:46:44.892	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:46:44.892	debug	(29151) no answer for undefined(id:5) received, giving up
            mihome-vacuum.0	2020-03-27 14:46:39.890	debug	(29151) sendMsg[3] >>> {"id":5,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:46:34.889	debug	(29151) sendMsg[2] >>> {"id":5,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:46:29.887	debug	(29151) sendMsg[1] >>> {"id":5,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:46:29.884	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:46:29.883	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:46:29.883	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03b5ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:46:24.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:46:24.890	debug	(29151) no answer for undefined(id:4) received, giving up
            mihome-vacuum.0	2020-03-27 14:46:23.350	debug	(29151) system.adapter.admin.0: logging true
            mihome-vacuum.0	2020-03-27 14:45:49.893	debug	(29151) sendMsg[1] >>> {"id":3,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:45:49.885	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:45:49.884	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:45:49.884	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e038dffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:45:39.890	debug	(29151) sendMsg[3] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:45:34.889	debug	(29151) sendMsg[2] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:45:29.888	debug	(29151) sendMsg[1] >>> {"id":2,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:45:29.883	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:45:29.883	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:45:29.882	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0379ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:45:24.978	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:45:24.978	debug	(29151) no answer for undefined(id:1) received, giving up
            mihome-vacuum.0	2020-03-27 14:45:19.977	debug	(29151) sendMsg[3] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:45:14.976	debug	(29151) sendMsg[2] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:45:12.042	debug	(29151) Xiaomi Cloud: Login successful
            mihome-vacuum.0	2020-03-27 14:45:10.409	info	(29151) set nächster Timer: Nicht verfügbar
            mihome-vacuum.0	2020-03-27 14:45:09.974	debug	(29151) sendMsg[1] >>> {"id":1,"method":"get_status"}
            mihome-vacuum.0	2020-03-27 14:45:09.956	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
            mihome-vacuum.0	2020-03-27 14:45:09.955	info	(29151) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:45:09.954	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0365ffffffffffffffffffffffffffffffff
            mihome-vacuum.0	2020-03-27 14:45:09.948	info	(29151) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
            mihome-vacuum.0	2020-03-27 14:45:09.885	debug	(29151) server started on 0.0.0.0:53421
            mihome-vacuum.0	2020-03-27 14:45:09.863	info	(29151) Create state clean_home for controlling by cloud adapter
            mihome-vacuum.0	2020-03-27 14:45:09.861	info	(29151) Expert mode disabled, states deleted
            mihome-vacuum.0	2020-03-27 14:45:09.848	debug	(29151) Xiaomi Cloud: Logging in
            mihome-vacuum.0	2020-03-27 14:45:09.847	debug	(29151) load Map creator... true
            mihome-vacuum.0	2020-03-27 14:45:09.776	info	(29151) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
            mihome-vacuum.0	2020-03-27 14:45:04.283	info	(28505) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            mihome-vacuum.0	2020-03-27 14:45:04.281	info	(28505) terminating
            mihome-vacuum.0	2020-03-27 14:45:04.280	info	(28505) Got terminate signal TERMINATE_YOURSELF
            mihome-vacuum.0	2020-03-27 14:44:43.305	info	(28505) create state for carpet_mode
            mihome-vacuum.0	2020-03-27 14:44:42.775	info	(28505) set nächster Timer: Nicht verfügbar
            mihome-vacuum.0	2020-03-27 14:44:42.287	info	(28505) Connected
            mihome-vacuum.0	2020-03-27 14:44:42.246	info	(28505) connecting, this can take up to 10 minutes ...
            mihome-vacuum.0	2020-03-27 14:44:42.224	info	(28505) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
            mihome-vacuum.0	2020-03-27 14:44:42.179	info	(28505) Create state clean_home for controlling by cloud adapter
            mihome-vacuum.0	2020-03-27 14:44:42.178	info	(28505) Expert mode disabled, states deleted
            mihome-vacuum.0	2020-03-27 14:44:42.092	info	(28505) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
            mihome-vacuum.0	2020-03-27 14:44:34.501	info	(26894) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            mihome-vacuum.0	2020-03-27 14:44:34.500	info	(26894) terminating
            mihome-vacuum.0	2020-03-27 14:44:34.499	info	(26894) Got terminate signal TERMINATE_YOURSELF
            • K Kueppert
              Erster Auszug:
              K
              K
              Kueppert
              #664
              @dirkhe dann habe ich gerade mal die MiHome-App geöffnet und den Staubi angeklickt, da passiert was im Log:
              mihome-vacuum.0	2020-03-27 14:56:51.929	debug	(29151) Mappointer_updated
              mihome-vacuum.0	2020-03-27 14:56:51.928	debug	(29151) Receive <<< {"result":["roboroommap%2F82487762%2F6"],"id":70}
              mihome-vacuum.0	2020-03-27 14:56:51.923	debug	(29151) sendMsg[1] >>> {"id":70,"method":"get_map_v1"}
              mihome-vacuum.0	2020-03-27 14:56:50.431	debug	(29151) Receive <<< {"result":[268569,4074617500,145,[1585305280,1583161415,1582365313,1582274907,1581673021,1580981012,1580463233,1580371947,1579857633,1579250658,1578393704,1577711651,1577701268,157
              mihome-vacuum.0	2020-03-27 14:56:50.423	debug	(29151) sendMsg[1] >>> {"id":69,"method":"get_clean_summary"}
              mihome-vacuum.0	2020-03-27 14:56:49.932	debug	(29151) Receive <<< {"result":[{"main_brush_work_time":268569,"side_brush_work_time":268569,"filter_work_time":268569,"sensor_dirty_time":22220}],"id":68}
              mihome-vacuum.0	2020-03-27 14:56:49.922	debug	(29151) sendMsg[1] >>> {"id":68,"method":"get_consumable"}
              mihome-vacuum.0	2020-03-27 14:56:49.918	debug	(29151) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2055,"state":8,"battery":100,"clean_time":1882,"clean_area":33882500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":0
              mihome-vacuum.0	2020-03-27 14:56:49.912	debug	(29151) sendMsg[1] >>> {"id":67,"method":"get_status"}
              mihome-vacuum.0	2020-03-27 14:56:37.022	debug	(29151) 25604
              mihome-vacuum.0	2020-03-27 14:56:35.580	debug	(29151) update_Map got new time:1585317393
              mihome-vacuum.0	2020-03-27 14:56:35.580	debug	(29151) update_Map got new expires:1585319195
              mihome-vacuum.0	2020-03-27 14:56:35.579	debug	(29151) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/3?Expires=1585319195000&GalaxyAccessKeyId=5271733786445&Signature=7rSJ64eWNT8XkG/3l6kHPHiGBtE=
              mihome-vacuum.0	2020-03-27 14:56:34.765	debug	(29151) CLEAN_LOGGING[{"Datum":"27.3","Start":"11:34","Saugzeit":"31 min","Fläche":"33.88 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"16:03","Saugzeit":"1 min","Fläche":"1.27 m²","Error":0,"End
              mihome-vacuum.0	2020-03-27 14:56:34.569	debug	(29151) Receive <<< {"result":[[1570894237,1570896347,1961,33425000,0,1]],"id":66}
              mihome-vacuum.0	2020-03-27 14:56:34.563	debug	(29151) sendMsg[1] >>> {"id":66,"method":"get_clean_record","params":[1570894237]}
              mihome-vacuum.0	2020-03-27 14:56:34.367	debug	(29151) Receive <<< {"result":[[1571385380,1571387768,2388,35787500,0,1]],"id":65}
              mihome-vacuum.0	2020-03-27 14:56:34.361	debug	(29151) sendMsg[1] >>> {"id":65,"method":"get_clean_record","params":[1571385380]}
              mihome-vacuum.0	2020-03-27 14:56:34.166	debug	(29151) Receive <<< {"result":[[1572341803,1572343814,2011,33695000,0,1]],"id":64}
              mihome-vacuum.0	2020-03-27 14:56:34.160	debug	(29151) sendMsg[1] >>> {"id":64,"method":"get_clean_record","params":[1572341803]}
              mihome-vacuum.0	2020-03-27 14:56:33.964	debug	(29151) Receive <<< {"result":[[1573114531,1573116539,2008,33780000,0,1]],"id":63}
              mihome-vacuum.0	2020-03-27 14:56:33.959	debug	(29151) sendMsg[1] >>> {"id":63,"method":"get_clean_record","params":[1573114531]}
              mihome-vacuum.0	2020-03-27 14:56:33.764	debug	(29151) Receive <<< {"result":[[1573808322,1573810637,2315,35065000,0,1]],"id":62}
              mihome-vacuum.0	2020-03-27 14:56:33.757	debug	(29151) sendMsg[1] >>> {"id":62,"method":"get_clean_record","params":[1573808322]}
              mihome-vacuum.0	2020-03-27 14:56:33.561	debug	(29151) Receive <<< {"result":[[1576490060,1576492145,2085,33827500,0,1]],"id":61}
              mihome-vacuum.0	2020-03-27 14:56:33.556	debug	(29151) sendMsg[1] >>> {"id":61,"method":"get_clean_record","params":[1576490060]}
              mihome-vacuum.0	2020-03-27 14:56:33.361	debug	(29151) Receive <<< {"result":[[1577088558,1577089956,1398,19932500,0,1]],"id":60}
              mihome-vacuum.0	2020-03-27 14:56:33.355	debug	(29151) sendMsg[1] >>> {"id":60,"method":"get_clean_record","params":[1577088558]}
              mihome-vacuum.0	2020-03-27 14:56:33.168	debug	(29151) update_Map need new mapurl
              mihome-vacuum.0	2020-03-27 14:56:33.168	debug	(29151) update_Map Mimap enabled
              mihome-vacuum.0	2020-03-27 14:56:33.167	debug	(29151) Mappointer_updated
              mihome-vacuum.0	2020-03-27 14:56:33.167	debug	(29151) Receive <<< {"result":["roboroommap%2F82487762%2F3"],"id":59}
              mihome-vacuum.0	2020-03-27 14:56:33.162	debug	(29151) Receive <<< {"result":[[1577701268,1577701837,569,5437500,0,1]],"id":58}
              mihome-vacuum.0	2020-03-27 14:56:33.161	debug	(29151) 3. Mappointer_nomap___retry
              mihome-vacuum.0	2020-03-27 14:56:33.161	debug	(29151) sendMsg[1] >>> {"id":59,"method":"get_map_v1"}
              mihome-vacuum.0	2020-03-27 14:56:33.154	debug	(29151) sendMsg[1] >>> {"id":58,"method":"get_clean_record","params":[1577701268]}
              mihome-vacuum.0	2020-03-27 14:56:32.960	debug	(29151) Receive <<< {"result":[[1577711651,1577712390,739,13485000,0,1]],"id":57}
              mihome-vacuum.0	2020-03-27 14:56:32.953	debug	(29151) sendMsg[1] >>> {"id":57,"method":"get_clean_record","params":[1577711651]}
              mihome-vacuum.0	2020-03-27 14:56:32.759	debug	(29151) Receive <<< {"result":[[1578393704,1578395855,2151,33467500,0,1]],"id":56}
              mihome-vacuum.0	2020-03-27 14:56:32.751	debug	(29151) sendMsg[1] >>> {"id":56,"method":"get_clean_record","params":[1578393704]}
              mihome-vacuum.0	2020-03-27 14:56:32.660	debug	(29151) Receive <<< {"result":["retry"],"id":55}
              mihome-vacuum.0	2020-03-27 14:56:32.654	debug	(29151) 2. Mappointer_nomap___retry
              mihome-vacuum.0	2020-03-27 14:56:32.654	debug	(29151) sendMsg[1] >>> {"id":55,"method":"get_map_v1"}
              mihome-vacuum.0	2020-03-27 14:56:32.555	debug	(29151) Receive <<< {"result":[[1579250658,1579253070,2412,36095000,0,1]],"id":54}
              mihome-vacuum.0	2020-03-27 14:56:32.549	debug	(29151) sendMsg[1] >>> {"id":54,"method":"get_clean_record","params":[1579250658]}
              mihome-vacuum.0	2020-03-27 14:56:32.355	debug	(29151) Receive <<< {"result":[[1579857633,1579859588,1955,33762500,0,1]],"id":53}
              mihome-vacuum.0	2020-03-27 14:56:32.348	debug	(29151) sendMsg[1] >>> {"id":53,"method":"get_clean_record","params":[1579857633]}
              mihome-vacuum.0	2020-03-27 14:56:32.154	debug	(29151) Receive <<< {"result":[[1580371947,1580373899,1952,33397500,0,1]],"id":52}
              mihome-vacuum.0	2020-03-27 14:56:32.153	debug	(29151) Receive <<< {"result":["retry"],"id":51}
              mihome-vacuum.0	2020-03-27 14:56:32.147	debug	(29151) sendMsg[1] >>> {"id":52,"method":"get_clean_record","params":[1580371947]}
              mihome-vacuum.0	2020-03-27 14:56:32.144	debug	(29151) 1. Mappointer_nomap___retry
              mihome-vacuum.0	2020-03-27 14:56:32.144	debug	(29151) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
              mihome-vacuum.0	2020-03-27 14:56:31.951	debug	(29151) Receive <<< {"result":[[1580463233,1580468445,2521,36215000,0,1]],"id":50}
              mihome-vacuum.0	2020-03-27 14:56:31.945	debug	(29151) sendMsg[1] >>> {"id":50,"method":"get_clean_record","params":[1580463233]}
              mihome-vacuum.0	2020-03-27 14:56:31.750	debug	(29151) Receive <<< {"result":[[1580981012,1580983420,2408,36150000,0,1]],"id":49}
              mihome-vacuum.0	2020-03-27 14:56:31.744	debug	(29151) sendMsg[1] >>> {"id":49,"method":"get_clean_record","params":[1580981012]}
              mihome-vacuum.0	2020-03-27 14:56:31.643	debug	(29151) Receive <<< {"result":["retry"],"id":48}
              mihome-vacuum.0	2020-03-27 14:56:31.638	debug	(29151) 0. Mappointer_nomap___retry
              mihome-vacuum.0	2020-03-27 14:56:31.638	debug	(29151) sendMsg[1] >>> {"id":48,"method":"get_map_v1"}
              mihome-vacuum.0	2020-03-27 14:56:31.549	debug	(29151) Receive <<< {"result":[[1581673021,1581675073,2052,33732500,0,1]],"id":47}
              mihome-vacuum.0	2020-03-27 14:56:31.543	debug	(29151) sendMsg[1] >>> {"id":47,"method":"get_clean_record","params":[1581673021]}
              mihome-vacuum.0	2020-03-27 14:56:31.349	debug	(29151) Receive <<< {"result":[[1582274907,1582276815,1908,33457500,0,1]],"id":46}
              mihome-vacuum.0	2020-03-27 14:56:31.342	debug	(29151) sendMsg[1] >>> {"id":46,"method":"get_clean_record","params":[1582274907]}
              mihome-vacuum.0	2020-03-27 14:56:31.147	debug	(29151) Receive <<< {"result":[[1582365313,1582367499,2186,38605000,0,1]],"id":45}
              mihome-vacuum.0	2020-03-27 14:56:31.141	debug	(29151) sendMsg[1] >>> {"id":45,"method":"get_clean_record","params":[1582365313]}
              mihome-vacuum.0	2020-03-27 14:56:31.136	debug	(29151) Receive <<< {"result":["retry"],"id":44}
              mihome-vacuum.0	2020-03-27 14:56:31.129	debug	(29151) sendMsg[1] >>> {"id":44,"method":"get_map_v1"}
              mihome-vacuum.0	2020-03-27 14:56:30.946	debug	(29151) Receive <<< {"result":[[1583161415,1583161534,54,1272500,0,0]],"id":43}
              mihome-vacuum.0	2020-03-27 14:56:30.940	debug	(29151) sendMsg[1] >>> {"id":43,"method":"get_clean_record","params":[1583161415]}
              mihome-vacuum.0	2020-03-27 14:56:30.936	debug	(29151) Receive <<< {"result":"unknown_method","id":42}
              mihome-vacuum.0	2020-03-27 14:56:30.935	info	(29151) create state for carpet_mode
              mihome-vacuum.0	2020-03-27 14:56:30.935	debug	(29151) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":41}
              mihome-vacuum.0	2020-03-27 14:56:30.929	debug	(29151) sendMsg[1] >>> {"id":42,"method":"get_room_mapping"}
              mihome-vacuum.0	2020-03-27 14:56:30.928	debug	(29151) sendMsg[1] >>> {"id":41,"method":"get_carpet_mode"}
              mihome-vacuum.0	2020-03-27 14:56:30.746	debug	(29151) Receive <<< {"result":[[1585305280,1585307162,1882,33882500,0,1]],"id":40}
              mihome-vacuum.0	2020-03-27 14:56:30.739	debug	(29151) sendMsg[1] >>> {"id":40,"method":"get_clean_record","params":[1585305280]}
              mihome-vacuum.0	2020-03-27 14:56:30.737	debug	(29151) Receive <<< {"result":[268569,4074617500,145,[1585305280,1583161415,1582365313,1582274907,1581673021,1580981012,1580463233,1580371947,1579857633,1579250658,1578393704,1577711651,1577701268,157
              mihome-vacuum.0	2020-03-27 14:56:30.728	debug	(29151) sendMsg[1] >>> {"id":39,"method":"get_clean_summary"}
              mihome-vacuum.0	2020-03-27 14:56:30.533	debug	(29151) Receive <<< {"result":[{"main_brush_work_time":268569,"side_brush_work_time":268569,"filter_work_time":268569,"sensor_dirty_time":22220}],"id":38}
              mihome-vacuum.0	2020-03-27 14:56:30.528	debug	(29151) sendMsg[1] >>> {"id":38,"method":"get_consumable"}
              mihome-vacuum.0	2020-03-27 14:56:30.333	debug	(29151) Receive <<< {"result":[30],"id":37}
              mihome-vacuum.0	2020-03-27 14:56:30.328	debug	(29151) sendMsg[1] >>> {"id":37,"method":"get_sound_volume"}
              mihome-vacuum.0	2020-03-27 14:56:30.133	debug	(29151) Receive <<< {"partner_id":"","id":36,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004004","ap":{"ssid":"Unifi_EG","bssid":"18:E8:29:94:F0:F8","rssi":-38},"netif":{"localI
              mihome-vacuum.0	2020-03-27 14:56:30.130	debug	(29151) Next WiFi check: 27.03 14:57
              mihome-vacuum.0	2020-03-27 14:56:30.129	debug	(29151) sendMsg[1] >>> {"id":36,"method":"miIO.info"}
              mihome-vacuum.0	2020-03-27 14:56:29.927	info	(29151) Connected
              mihome-vacuum.0	2020-03-27 14:56:29.924	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
              mihome-vacuum.0	2020-03-27 14:56:29.922	debug	(29151) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2042,"state":8,"battery":100,"clean_time":1882,"clean_area":33882500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":0
              mihome-vacuum.0	2020-03-27 14:56:29.917	debug	(29151) sendMsg[1] >>> {"id":35,"method":"get_status"}
              mihome-vacuum.0	2020-03-27 14:56:29.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
              mihome-vacuum.0	2020-03-27 14:56:29.914	info	(29151) connecting, this can take up to 10 minutes ...
              • K Kueppert
                D
                D
                dirkhe
                #665
                @Kueppert jetzt bist du on Track ..
                Kannst den debuglevel wieder runter setzten. Wir wissen zwar jetzt immer noch nicht, wo die rekursion ist.
                • R
                  R
                  root_
                  #666
                  Hab einen Mi home Vacuum und bekomme mit der 2.0.9 die Zonenreinigung nicht mehr hin.
                  Hat bis jetzt immer funktioniert. Hab einen neuen Raum mit den Koordinaten angelegt. Das hat auch funktioniert. Bekomme aber folgende Meldung wenn ich die Reinigung starte:
                  mihome-vacuum.0	2020-03-28 16:36:49.032	error	(100061) [24159,24383,28759,25933,1] ->mihome-vacuum.0.rooms.manual_24159_24383_28759_25933
                  mihome-vacuum.0	2020-03-28 16:36:49.001	info	(100061) trigger cleaning zone [24159,24383,28759,25933,1]
                  • R root_
                    D
                    D
                    dirkhe
                    #667
                    @root_ kannst du mal den loglevel auf debug stellen und nochmal probieren, bitte
                    R 1 Antwort Letzte Antwort
                    • Jan FiedlerJ
                      Jan FiedlerJ
                      Jan Fiedler
                      #668
                      Gibt es eine Möglichkeit die Raumkoordinaten auszulesen, ohne Valetudo zu installieren?
                      ? D 2 Antworten Letzte Antwort
                      • Jan FiedlerJ Jan Fiedler
                        #669
                        @Jan-Fiedler sagte in Test Adapter mihome-vacuum v2.0.x:
                        mit der Flole-App ( Android ), auf Zonenreinigung gehen, Zone markieren, dann auf Reinigen und den Finger drauflassen, bis "Zone wurde in die Zwischenablage kopiert" erscheint.
                        Dann c+p wohin. Damit geht die "Raumreinigung" mit allen Modellen, die noch auf der alten Firmware sind.
                        Jan FiedlerJ 1 Antwort Letzte Antwort
                        • Elektroniker86E
                          Elektroniker86E
                          Elektroniker86
                          #670
                          Ich habe eben versucht den Adapter über die Katze /Githublink zu installieren, allerdings nicht erfolgreich.
                          obroker host.IoBroker-Pi4 Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/c2dcd9c10ccd505e22854e3bd4f7323a1b752dd3
                          Muss ich vorher den alten Adapter deinstallieren vielleicht?
                          Ich habe zwei Instanzen des alten Adapters pausiert und dann versucht zu installieren.
                          • D dirkhe
                            R
                            R
                            root_
                            #671
                            @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                            mihome-vacuum.0	2020-03-29 16:23:06.651	debug	(92536) Receive <<< {"result":[1846515,23124062500,707,[]],"id":13}
                            mihome-vacuum.0	2020-03-29 16:23:06.644	debug	(92536) sendMsg[1] >>> {"id":13,"method":"get_clean_summary"}
                            mihome-vacuum.0	2020-03-29 16:23:06.150	debug	(92536) Receive <<< {"result":[{"main_brush_work_time":484190,"side_brush_work_time":484190,"filter_work_time":291118,"sensor_dirty_time":48205}],"id":12}
                            mihome-vacuum.0	2020-03-29 16:23:06.140	debug	(92536) sendMsg[1] >>> {"id":12,"method":"get_consumable"}
                            mihome-vacuum.0	2020-03-29 16:23:06.135	debug	(92536) Receive <<< {"result":[{"msg_ver":8,"msg_seq":203,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":90,"dnd_enabled":0}],"id":11
                            mihome-vacuum.0	2020-03-29 16:23:06.125	debug	(92536) sendMsg[1] >>> {"id":11,"method":"get_status"}
                            mihome-vacuum.0	2020-03-29 16:23:04.192	error	(92536) [24159,24383,28759,25933,1] ->mihome-vacuum.0.rooms.manual_24159_24383_28759_25933
                            mihome-vacuum.0	2020-03-29 16:23:04.145	debug	(92536) Receive <<< {"result":["ok"],"id":10}
                            mihome-vacuum.0	2020-03-29 16:23:04.133	debug	(92536) sendMsg[1] >>> {"id":10,"method":"set_custom_mode","params":[90]}
                            mihome-vacuum.0	2020-03-29 16:23:04.132	debug	(92536) stateChange mihome-vacuum.0.control.fan_power {"val":90,"ack":false,"ts":1585491784127,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1541688856539}
                            mihome-vacuum.0	2020-03-29 16:23:04.123	info	(92536) trigger cleaning zone [24159,24383,28759,25933,1]
                            mihome-vacuum.0	2020-03-29 16:23:04.115	debug	(92536) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                            • R root_
                              D
                              D
                              dirkhe
                              #672
                              @root_ welche Version hast du genau, das sieht man, wenn man den adapter startet. Ich habe die ganze zeit gesucht und ich kann aktuell nicht mal die Stelle finden, wo diese Fehlermeldung geschrieben wird. Bitte nochmal die aktuelle Version rc07 installieren. Funktioniert das denn, wenn du die Koordinaten über sendCustomcommand eingibst?
                              • R
                                R
                                root_
                                #673
                                mihome-vacuum.0	2020-03-29 17:04:53.496	info	(45717) connecting, This can take up to 5 minutes ...
                                mihome-vacuum.0	2020-03-29 17:04:53.494	debug	(45717) Receive <<< Helo <<< 213100200000000004e9e7315e80b915ffffffffffffffffffffffffffffffff
                                mihome-vacuum.0	2020-03-29 17:04:53.460	info	(45717) New generation or new fw(3.5.4,004007) detected, create new states goto and zoneclean
                                mihome-vacuum.0	2020-03-29 17:04:53.397	debug	(45717) server started on 0.0.0.0:53421
                                mihome-vacuum.0	2020-03-29 17:04:53.386	info	(45717) Disconnect
                                mihome-vacuum.0	2020-03-29 17:04:53.373	info	(45717) Create state clean_home for controlling by cloud adapter
                                mihome-vacuum.0	2020-03-29 17:04:53.372	info	(45717) Expert mode enabled, states created
                                mihome-vacuum.0	2020-03-29 17:04:53.353	debug	(45717) Xiaomi Cloud: Logging in
                                mihome-vacuum.0	2020-03-29 17:04:53.350	debug	(45717) load Map creator... true
                                mihome-vacuum.0	2020-03-29 17:04:53.263	info	(45717) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                                host.raspberry	2020-03-29 17:04:48.816	info	instance system.adapter.mihome-vacuum.0 started with pid 45717
                                Hab gerade noch mal über git upgedatet aber von RC07 steht bei mir nix
                                • R root_
                                  D
                                  D
                                  dirkhe
                                  #674
                                  @root_ wenn man in der Package.json schaut, sollte da 2.0.9 rc07. Installiere bitte mal via url https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum, aber eigentlich sollte das das gleiche sein. Bin gerade ratlos
                                    Jan FiedlerJ
                                    Jan FiedlerJ
                                    Jan Fiedler
                                    #675
                                    @ilovegym Das geht leider mit den neuen Karten nicht mehr...Kann man die Räume evtl mehrfach per multipleRoomClean durchlaufen lassen?
                                    • D dirkhe
                                      R
                                      R
                                      root_
                                      #676
                                      @dirkhe Funktioniert jetzt alles. Scheinbar hat bei mir was mit der URL nicht gestimmt. Danke dir.
                                        D
                                        D
                                        dirkhe
                                        #677
                                        @Jan-Fiedler ich arbeite gerade an einem Widget, wo man das machen können wird. Dauert aber noch nen bisschen
                                        • T
                                          T
                                          TemPeck
                                          #678
                                          Moin!
                                          Ich habe aktuell auch einige Probleme mit der Zonenreinigung und generell mit der Steuerung des Vacuum (Gen. 1, Valetudo 0.9.2, Firmware: 003514) über den Adapter :/
                                          Wenn ich die Zonenreinigung oder GoTo aus dem Dock heraus befehle, versucht der Roboter erstmal ungebremst rückwärts zu fahren und fährt dabei fast das Dock um.
                                          Das könnte durchaus daran liegen, dass das Dock unter einem Schrank und nicht an gerader Wand steht, bei einer Suche habe ich dazu in anderen Foren entsprechende Beiträge gefunden.
                                          Also habe ich ein Script mit einem Ablauf erstellt:
                                          1. Ein ganz normaler Saugvorgang wird gestartet - der Roboter fährt einige cm aus dem Dock
                                          2. Der Saugvorgang wird pausiert
                                          3. Ein Punkt im Raum wird über GoTo angefahren
                                          4. Die Zonenreinigung wird gestartet.
                                          Der Ablauf behebt schon mal das o.g. Problem, dass die Station bestiegen wird.
                                          Die Zonenreinigung wird dann aber ohne ersichtlichen Grund abgebrochen. Zunächst fährt der Roboter - warum auch immer - in eine Ecke, und bricht dann dort ab.
                                          Komischer weise stellt die Zonenreinigung, wenn ich sie aus der Valetudo Oberfläche starte, überhaupt kein Problem dar.
                                          Weder beim Beginn aus dem Dock noch was das Abbrechen angeht.
                                          Hat hier vllt. jemand eine Idee, was ich noch machen könnte?
                                          Könnte es an der FW Version liegen?
                                          84.2k
