  4. Aktuelles Sternzeichen - Mondphase
vis
47 Beiträge 8 Kommentatoren 6.9k Aufrufe 13 Beobachtet
  • TG70T TG70
    hat jemand eine Idee, wie ich immer das aktuelle Sternzeichen in einer View
    anzeigen lassen kann. (aktuell wäre Wassermann)
    Für die Mondphase habe ich mir das sehr einfach gemacht
    [{"tpl":"tplIFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"36000000","seamless":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"http://www.astrolantis.de/mondphase/index5"},"style":{"left":"866px","top":"244px","width":"140px","height":"276px"},"widgetSet":"basic"}]
    sigi234S Online
    sigi234S Online
    @TG70
    Geht es bei dir? Also die Vis Allgemein.
    TG70T 1 Antwort Letzte Antwort
    • sigi234S sigi234
      @TG70
      TG70T Offline
      TG70T Offline
      TG70
      Forum Testing
      @sigi234 .. danke der Nachfrage.
      Ja nach den notwendigen Anpassungen (Speicherort der Bilder usw.) läuft das wunderbar. 👍
      Danke für deine unermüdliche Hilfe und Arbeit
      ∘ MB ASRock J4105M Intel J4105 CPU M-ATX | 16 GB RAM | 480 GB SSD ∘ PROXMOX LCX-Container > IoBroker
      • sigi234S sigi234
        @jwerlsdf sagte in Aktuelles Sternzeichen - Mondphase:
        ich nehme ein txt widget, aktiviere Sichtbarkeit und gebe dann wo genau das Datum/ Daten ein?
        Nein, hast du materialdesign installiert? Das geht über die Card und via Bild Name.
        Ich weis noch nicht ob es so funktioniert, muss man erst den 21.03. abwarten.
        jwerlsdf
        @sigi234
        Hallo, kam jetzt erst zum Testen.
        Bei mir funktioniert leider nicht das automatische ausblenden/ einblenden der richtigen Texte. Sind diese Einstellungen richtig? Habe es eigentlich genau so wie du gemacht...
        • J jwerlsdf
          @sigi234
          sigi234S Online
          sigi234S Online
          @jwerlsdf
          Die Anzeige funktioniert nur in der runtime
          • sigi234S sigi234
            @jwerlsdf
            jwerlsdf
            @sigi234
            das weiß ich. Aber dort geht es ja leider nicht. Ich wollte dir nur meine Einstellungen zeigen.
            Würdest du bitte mal nur das Widget mit einem Beispieltext zur Verfügung stellen? Ich würde es gerne mal testen ob es mit deinem klappt...
            • J jwerlsdf
              @sigi234
              sigi234S Online
              sigi234S Online
              @sigi234
              [{"tpl":"tplVis-materialdesign-Card","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"consist","visibility-val":"8sternzeichen","visibility-groups-action":"hide","titleLayout":"large","subtitleLayout":"subtitle2","cardLayout":"BasicHeader","cardStyle":"default","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title":"Skorpion","subtitle":"Das Tierkreiszeichen Skorpion (griechisch Σκορπίος Skorpíos, lateinisch Scorpio) entspricht dem achten Abschnitt des Tierkreises von 210° bis 240° ekliptikaler Länge ab dem Frühlingspunkt.\n\nDie Sonne befindet sich im Mittel in der Zeit zwischen 24. Oktober und 22. November in diesem Zeichen. Aufgrund der Wanderung des Frühlingspunktes entspricht das Tierkreiszeichen Skorpion heute nicht mehr dem Sternbild Skorpion. Im Sternbild Skorpion befindet sich die Sonne ungefähr in der Zeit zwischen 23. und 30. November.","colorTitleSectionBackground":"","html":"Nach dem Tetrabiblos des Claudius Ptolemäus\nist der Skorpion weiblich (I.12) und\nder Mars ist Herrscher des Zeichens (I.17).\nAls melothesische Entsprechung wurden dem Skorpion in der antiken Iatroastrologie die Schamregion und die Genitalien zugeordnet. Die zugeordnete Gottheit war Mars.\n\nMit Fischen und Krebs bildet der Skorpion das Trigon des Elements Wasser, mit Wassermann, Stier und Löwe das Quadrat der vier festen Zeichen.\n\nDas Zeichen war bereits Teil des babylonischen Tierkreises. Auf den MUL.APIN-Tafeln erscheint es als „Skorpion“ (GIR.TAB).\n\nDargestellt wird das Zeichen seit der Antike als Skorpion. Vor allem in nördlichen Ländern herrschte manchmal beträchtliche Unsicherheit über das Aussehen eines Skorpions. Die Wiedergabe erinnert öfter eher an eine Krabbe, manchmal an eine Art Hund mit sechs oder acht Beinen. Stets ist er aber am Stachel erkennbar.\n\nUrsprung und Interpretation des astrologischen Symbols sind unklar. Auffällig ist die Ähnlichkeit mit dem Symbol der Jungfrau. Eine mögliche Erklärung ist, dass es sich um eine alte Form des Buchstabens „m“ handelt, was sich auf die besondere medizinische Bedeutung des Zeichens beziehen soll. Zur Unterscheidung wurde beim Skorpion dann ein Stachel angefügt und bei der Jungfrau eine geschwungene Linie, die eine Kornähre symbolisieren könnte.\n\nDas Unicode-Zeichen für das Symbol ist U+264F (♏).","textFontSize":"12px","colorBackground":"#333333","colorTextSectionBackground":"","colorSubtitle":"","colorTitle":"#ffffff","name":"Skorpion Card","filterkey":"Card","visibility-oid":"0_userdata.0.Sternzeichen"},"style":{"left":"449px","top":"165px","z-index":"4","width":"610px","height":"410px","color":"#c7c7c7"},"widgetSet":"materialdesign"}]
              • sigi234S sigi234
                @sigi234
                jwerlsdf
                @sigi234
                vielen Dank. Mit deinem widget klappt es, obwohl bei Sichtbarkeit alles identisch mit meinen Einstellungen war...
                • G Offline
                  G4l4h4d
                  schrieb am zuletzt editiert von G4l4h4d
                  Hi, @sigi234 leider wird bei mir nichts in den Datenpunkt geschrieben.
                  Anbei mein Blockly:
                  Wird das script von thread 15 zusätzlich benötigt oder ersetzt das Blockly das script?
                  Danke im Voraus!
                  • G G4l4h4d
                    Anbei mein Blockly:
                    Danke im Voraus!
                    sigi234S Online
                    sigi234S Online
                    @G4l4h4d sagte in Aktuelles Sternzeichen - Mondphase:
                    Anbei mein Blockly:
                    Danke im Voraus!
                    /vis.0/Icons/Sternzeichen/LEER LASSEN
                    G 1 Antwort Letzte Antwort
                    • sigi234S sigi234
                      Anbei mein Blockly:
                      Danke im Voraus!
                      G4l4h4d
                      @sigi234
                      hab den Pfad jetzt abgeändert "/vis.0/Icons/Sternzeichen"
                      aber meine Bilder liegen im .png Format vor.
                      Klappt aber immer noch nicht, der Datenpunkt bleibt leer????
                      • G Offline
                        G4l4h4d
                        @sigi234
                        seit heute wird bei mir kein Datenpunkt mehr erstellt. Hat sich an dem Script etwas geändert?
                        • G G4l4h4d
                          @sigi234
                          sigi234S Online
                          sigi234S Online
                          @sigi234
                          nein
                          • sigi234S sigi234
                            @sigi234
                            nein
                            G4l4h4d
                            @sigi234
                            Könnte es mit dem Umzug von Raspi4 auf Proxmox zu tun haben?
                            Anbei mal mein Skript vielleicht findest du auch einen Fehler.
                            Danke schon mal vorab!
