  4. Mal wieder rega hss
Mal wieder rega hss
regahssccu2homematic rega
26 Beiträge 2 Kommentatoren 1.6k Aufrufe 1 Beobachtet
  • haselchenH haselchen
    @michaelxhoffmann
    Wenn du den Adapter auf Debug stellst was für Meldungen kommen beim Start?
    michaelxhoffmann
    @haselchen Ich würde mal behaupten das sind die gleichen Fehler
    host.RASP4 2020-03-14 15:43:42.411 info Restart adapter system.adapter.hm-rega.0 because enabled
    host.RASP4 2020-03-14 15:43:42.411 error instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.RASP4 2020-03-14 15:43:42.411 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.RASP4 2020-03-14 15:43:42.411 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/xmlbuilder/lib/XMLElement.js:298:4)
    host.RASP4 2020-03-14 15:43:42.411 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/xmlbuilder/lib/XMLElement.js:13:18)
    host.RASP4 2020-03-14 15:43:42.410 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.RASP4 2020-03-14 15:43:42.410 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.RASP4 2020-03-14 15:43:42.410 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.RASP4 2020-03-14 15:43:42.410 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.RASP4 2020-03-14 15:43:42.409 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.RASP4 2020-03-14 15:43:42.409 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.RASP4 2020-03-14 15:43:42.409 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
    host.RASP4 2020-03-14 15:43:42.409 error Caught by controller[0]: SyntaxError: Unexpected token .
    host.RASP4 2020-03-14 15:43:42.409 error Caught by controller[0]: ^
    host.RASP4 2020-03-14 15:43:42.408 error Caught by controller[0]: Object.defineProperty(XMLAttribet%.prototype, 't�xtCoNtent', s
    host.RASP4 2020-03-14 15:43:42.408 error Caught by controller[0]: /opt/iobroker/node_modules/xmlbuilder/lib/XMLAttribute.js:38
    host.RASP4 2020-03-14 15:43:41.857 info instance system.adapter.hm-rega.0 started with pid 2015
    host.RASP4 2020-03-14 15:43:11.835 info Restart adapter system.adapter.hm-rega.0 because enabled
    host.RASP4 2020-03-14 15:43:11.835 error instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.RASP4 2020-03-14 15:43:11.835 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.RASP4 2020-03-14 15:43:11.835 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/xmlbuilder/lib/XMLElement.js:298:4)
    host.RASP4 2020-03-14 15:43:11.835 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/xmlbuilder/lib/XMLElement.js:13:18)
    host.RASP4 2020-03-14 15:43:11.835 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.RASP4 2020-03-14 15:43:11.835 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.RASP4 2020-03-14 15:43:11.834 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.RASP4 2020-03-14 15:43:11.834 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.RASP4 2020-03-14 15:43:11.834 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.RASP4 2020-03-14 15:43:11.834 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.RASP4 2020-03-14 15:43:11.834 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
    host.RASP4 2020-03-14 15:43:11.834 error Caught by controller[0]: SyntaxError: Unexpected token .
    host.RASP4 2020-03-14 15:43:11.834 error Caught by controller[0]: ^
    host.RASP4 2020-03-14 15:43:11.833 error Caught by controller[0]: Object.defineProperty(XMLAttribet%.prototype, 't�xtCoNtent', s
    host.RASP4 2020-03-14 15:43:11.833 error Caught by controller[0]: /opt/iobroker/node_modules/xmlbuilder/lib/XMLAttribute.js:38
    host.RASP4 2020-03-14 15:43:11.324 info instance system.adapter.hm-rega.0 started with pid 2008
    Homematic CCU2 - Raspberry Pi 4 - IOS (siri) - Amazon Echo 3rd Gen.
    • M michaelxhoffmann
      haselchenH Offline
      haselchenH Offline
      haselchen
      @michaelxhoffmann
      Hast du mal
      apt-get update
      und dann
      apt-get upgrade
      gemacht?
        michaelxhoffmann
        schrieb am zuletzt editiert von michaelxhoffmann
        ja, diverse male... ein upload habe ich auch schon gemacht für den regaadapter Der Fehler bleibt bestehen
        host.RASP4 2020-03-14 16:00:49.152 info "system.adapter.hm-rega.0" disabled
        host.RASP4 2020-03-14 16:00:48.769 info Restart adapter system.adapter.hm-rega.0 because enabled
        host.RASP4 2020-03-14 16:00:48.769 error instance system.adapter.hm-rega.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        host.RASP4 2020-03-14 16:00:48.769 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
        host.RASP4 2020-03-14 16:00:48.768 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/xmlbuilder/lib/XMLElement.js:298:4)
        host.RASP4 2020-03-14 16:00:48.768 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/xmlbuilder/lib/XMLElement.js:13:18)
        host.RASP4 2020-03-14 16:00:48.768 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
        host.RASP4 2020-03-14 16:00:48.768 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
        host.RASP4 2020-03-14 16:00:48.768 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        host.RASP4 2020-03-14 16:00:48.767 error Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        host.RASP4 2020-03-14 16:00:48.767 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
        host.RASP4 2020-03-14 16:00:48.767 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        host.RASP4 2020-03-14 16:00:48.767 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:723:23)
        host.RASP4 2020-03-14 16:00:48.766 error Caught by controller[0]: SyntaxError: Unexpected token .
        host.RASP4 2020-03-14 16:00:48.766 error Caught by controller[0]: ^
        host.RASP4 2020-03-14 16:00:48.766 error Caught by controller[0]: Object.defineProperty(XMLAttribet%.prototype, 't�xtCoNtent', s
        host.RASP4 2020-03-14 16:00:48.765 error Caught by controller[0]: /opt/iobroker/node_modules/xmlbuilder/lib/XMLAttribute.js:38
        host.RASP4 2020-03-14 16:00:48.260 info instance system.adapter.hm-rega.0 started with pid 4310
        host.RASP4 2020-03-14 16:00:18.157 info Restart adapter system.adapter.hm-rega.0 because enabled
          haselchenH Offline
          haselchenH Offline
          haselchen
          @michaelxhoffmann
          Und die IP Adresse im Adapter ist die deiner CCU?
          Kontrollier wenn nochmal jede Zahl :)
            @michaelxhoffmann
            michaelxhoffmann
            @haselchen na klar! die RPC Adapter funktionieren ja auch. Nur der Regaadapter will nicht
              haselchenH Offline
              haselchenH Offline
              haselchen
              @michaelxhoffmann
              Gib mal in den RPC Instanzen jeweils in die Callback Adresse die ein, wo Iobroker drauf installiert ist.
                @michaelxhoffmann
                michaelxhoffmann
                @haselchen die sind dort eingetragen
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @michaelxhoffmann
                  Als Protokoll jeweils XML-RPC?
                    @michaelxhoffmann
                    michaelxhoffmann
                    @haselchen ja
                      @haselchen ja
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @michaelxhoffmann
                      Auf der CCU welche Version von XLM Api hast du?
                        @michaelxhoffmann
                        michaelxhoffmann
                        xlm api? Keine Ahnung 2.51.6 ist die Softwareversion.
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @michaelxhoffmann
                          Hast du in der Systemsteuerung den Punkt Zusatzsoftware?
                            @michaelxhoffmann
                            michaelxhoffmann
                            @haselchen ja
                              @haselchen ja
                              haselchenH Offline
                              haselchenH Offline
                              haselchen
                              @michaelxhoffmann
                              Lass dir doch nicht alles aus der Nase ziehen.
                              Dann guck da nach ob du XML Api dort hast und dann die Version
                                michaelxhoffmann
                                Da steht nix von xml api hatte ich auch noch nie, soweit ich das weiß und es lief ja auch immer alles an der ccu2 habe ich ja nichts geändert. der regaadapter funktioniert seit ca. 3-4 Wochen nicht mehr
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @michaelxhoffmann
                                  Aus dem Nichts kommt das bestimmt nicht.
                                  Irgendwas wirst Du upgedatet haben.
                                  Mach doch mal nen downgrade des Adapters.
                                  Einfach mal ranstasten und Ausschlussverfahren durchspielen.
                                  Try and Error.
                                    michaelxhoffmann
                                    Hmm Na dann ....
                                    Danke jedenfalls ... :) Aber ich fürchte das werde ich lieber nicht machen. Wie das ausgeht kann ich mir nämlich schon denken :))
                                      Hmm Na dann ....
                                      haselchenH Offline
                                      haselchenH Offline
                                      haselchen
                                      @michaelxhoffmann
                                      Deine Entscheidung.
                                      Aber , wie im richtigen Leben, ohne mal auf die Klappe zu fliegen, lernt man nichts.
