  4. Z-Wave Adapter
Z-Wave Adapter
110 Beiträge 13 Kommentatoren 35.3k Aufrufe
  • AlCalzoneA Offline
    AlCalzoneA Offline
    AlCalzone
    Habe beim Versuch, den neuen zwave-Adapter zu installieren, wieder das Problem, das ich beim ersten Mal hatte - mit dem Unterschied, dass ich jetzt nicht mehr weiß, wie ich es damals gelöst hab:
    gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/0.10.22"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/.node-gyp"
    gyp http GET http://nodejs.org/dist/v0.10.22/node-v0.10.22.tar.gz
    gyp http 200 http://nodejs.org/dist/v0.10.22/node-v0.10.22.tar.gz
    make: Entering directory '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build'
      CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-config.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-driver.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-groups.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-management.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-network.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-nodes.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-polling.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-scenes.o
      CXX(target) Release/obj.target/openzwave_shared/src/openzwave-values.o
      CXX(target) Release/obj.target/openzwave_shared/src/utils.o
    ../src/utils.cc: In function ‘v8::Local <v8::object>OZW::zwaveValue2v8Value(OpenZWave::ValueID)’:
    ../src/utils.cc:203:3: error: ‘EscapableHandleScope’ was not declared in this scope
    ../src/utils.cc:203:3: note: suggested alternative:
    /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/node_modules/nan/nan.h:361:7: note:   ‘Nan::EscapableHandleScope’
    ../src/utils.cc:203:24: error: expected ‘;’ before ‘handle_scope’
    ../src/utils.cc:239:11: error: ‘handle_scope’ was not declared in this scope
    ../src/utils.cc:202:16: warning: unused variable ‘isolate’ [-Wunused-variable]
    ../src/utils.cc: In function ‘v8::Local <v8::object>OZW::zwaveSceneValue2v8Value(uint8, OpenZWave::ValueID)’:
    ../src/utils.cc:245:3: error: ‘EscapableHandleScope’ was not declared in this scope
    ../src/utils.cc:245:3: note: suggested alternative:
    ../src/utils.cc:245:24: error: expected ‘;’ before ‘handle_scope’
    ../src/utils.cc:275:10: error: ‘handle_scope’ was not declared in this scope
    ../src/utils.cc:244:16: warning: unused variable ‘isolate’ [-Wunused-variable]
    ../src/utils.cc:276:2: warning: control reaches end of non-void function [-Wreturn-type]
    ../src/utils.cc:240:2: warning: control reaches end of non-void function [-Wreturn-type]
    openzwave_shared.target.mk:104: recipe for target 'Release/obj.target/openzwave_shared/src/utils.o' failed
    make: *** [Release/obj.target/openzwave_shared/src/utils.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
    gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
    gyp ERR! System Linux 4.1.13-v7+
    gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared
    gyp ERR! node -v v0.10.22
    gyp ERR! node-gyp -v v0.11.0
    gyp ERR! not ok
    npm WARN optional dep failed, continuing iobroker.zwave@0.2.5</v8::object></v8::object></v8::object>
    • V Offline
      V Offline
      versteckt
      also für mich ist mal die letzte Zeile relevant, er behauptet, das er die Version 0.2.5 installieren will.
      Das ist dann schon mal falsch.
      Hast du per URL versucht zu installieren, oder per Update Funktion von ioBroker?
      Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
      homegear für Homematic und MAX!
      occ, zWave, rpi, hmm und homekit Entwickler
      • V Offline
        V Offline
        versteckt
        Ausserdem gehe ich mal davon aus, das du das ganze mit Node 0.10.x versuchst.
        Werde mal bei meinem Test Raspi die Version installieren und schauen was passiert.
        • V Offline
          V Offline
          versteckt
          kann den Fehler nachvollziehen und habe deswegen ein Ticket (https://github.com/OpenZWave/node-openz … /issues/83) eröffnet.
          LG Christian
          • V Offline
            V Offline
            versteckt
            So, Antwort ist schon da.
            node 0.10 ist nicht mehr unterstützt, aufgrund dieses Fehlers.
            LG Christian
              AlCalzoneA Offline
              AlCalzone
              @versteckt:
              Hast du per URL versucht zu installieren, oder per Update Funktion von ioBroker? `
              Ich habe sowohl per URL (siehe der längere Beitrag Seite 2) als auch per Update-Funktion probiert, bei beiden tritt der Fehler auf. Wenn ich per URL installiere, steht am Ende des Logs die Version 0.2.9, dennoch zeigt mir das ioBroker-Interface 0.2.5 als installiert an, es läuft also nicht durch.
              @versteckt:
              node 0.10 ist nicht mehr unterstützt, aufgrund dieses Fehlers. `
              node.js ist die im vorkonfigurierten Image verwendete Version 0.10.22. Was heißt das jetzt für mich? Warte ich auf ein Update des Adapters oder kann ich den Fehler selbst beheben?
              Danke schonmal für die prompte Antwort!
              • V Offline
                V Offline
                versteckt
                Hallo, der Entwickler von openzwave-shared hat eine Anpassung durchgeführt,
                bei mir funktioniert nun das manuelle kompilieren.
                Sobald eine offizielle Version von ihm zur Verfügung steht, mache ich ein Update und gebe Bescheid.
                LG Christian
                • V Offline
                  V Offline
                  versteckt
                  Hallo, Fix ist drinnen, bei mir hat es mit 0.10 node funktioniert, bitte testen.
                  Zusätzlich sind dann auch gleich ein paar Hotfix von mir drinnen:
                  0.2.9.1 (2016-03-11)
                  • (husky-koglhof)
                  Fixed setConfigParam,
                  Removed hardcoded 'lbl' Value in dynamic Listbox
                  Extended 'forceInit' Function, config File will be removed too
                  LG Christian
                    AlCalzoneA Offline
                    AlCalzone
                    Installation ist einwandfrei durchgelaufen, demnächst Testberichte.
                    Edit: läuft leider nicht, direkt nach dem Adapter-Start finde ich folgenden Fehler im Log:
                    > error instance system.adapter.zwave.0 terminated with code 103 ()
                    Edit #2: Nach Downgrade auf 0.2.5 läuft es wieder, scheint also ein Problem der neuen Version zu sein.
                    • V Offline
                      V Offline
                      versteckt
                      #66
                      Hallo, kriegst du außer dieser Meldung noch andere?
                      Bzw. mal mit Debug starten, bzw.
                      mir mal das OZW log zukommen lassen.
                      Gesendet von meinem iPhone mit Tapatalk
                      • J Offline
                        juli465
                        #67
                        Ich hab mich jetzt auch endlich mal hier angemeldet.
                        Ich habe iobroker unter jessi laufen. Hat zwar etwas gedauert bis Z-Wave anfangs lief, aber irgendwann hat es funktioniert.
                        Habe jetzt auch die 0.2.9 drauf, weil ich mit 0.2.5 nur Probleme hatte.
                        @AlCazone: lösche bitte mal Z-Wave komplett aus ioBroker und installiere dann die 0.2.9 neu. Das hat mir bei diesem Problem auch geholfen.
                          AlCalzoneA Offline
                          AlCalzone
                          #68
                          Komisch, habs jetzt einfach nochmal deinstalliert und wieder installiert, jetzt scheint es zu laufen.
                          • V Offline
                            V Offline
                            versteckt
                            #69
                            Hallo, bedeutet, die Version 0.2.9.1 ist aktiv?
                            LG Christian
                              AlCalzoneA Offline
                              AlCalzone
                              #70
                              Sorry für die späte Antwort, komme erst jetzt wieder zum Arbeiten an meinem Projekt.
                              Ja, 0.2.9 läuft auf dem Raspi.
                              Großartig wäre es, wenn einige der Funktionen des Adapters über ioBroker-States zugänglich gemacht würden. Ich arbeite an einer Automatisierungslösung mit dem Skript-Modul, da wäre folgendes wirklich interessant:
                              • Statusmeldung des Adapters wie "alle Nodes fertig geladen", "Treiber/Controller fertig initialisiert"
                              • aktivieren/deaktivieren des inclusion/exclusion Modus der zwave-Platine
                              • V Offline
                                V Offline
                                versteckt
                                #71
                                Version: 0.2.9.2 (2016-03-25)
                                • (husky-koglhof)
                                add .ready State to each Node and zwave.0 Core Object.
                                On startup set to false. On "ready" / "scan completed" set to true.
                                .) Statusmeldung des Adapters wie "alle Nodes fertig geladen", "Treiber/Controller fertig initialisiert"
                                -> erledigt
                                .) aktivieren/deaktivieren des inclusion/exclusion Modus der zwave-Platine
                                -> Siehe hierzu https://github.com/OpenZWave/node-openz … ME-mgmt.md
                                -> ...If your OZW version is 1.3 or greater, then there's a whole bunch of new calls, which effectively replace the old BeginControllerCommand. There's also no CancelControllerCommand thus you can't cancel any pending commands (they simply timeout)...
                                Sobald du das erfolgreich getestet hast, erzeuge ich eine 0.3.0 Version, welche dann wieder über iobroker zum aktualisieren funktioniert.
                                LG Christian
                                • Lenny.CBL Offline
                                  Lenny.CBL Offline
                                  Lenny.CB
                                  #72
                                  @versteckt:
                                  • (husky-koglhof)
                                  -> erledigt
                                  LG Christian `
                                  Hi, musste auch grad alles neu machen.
                                  Dem nach auch zwave. egal wie ich es versuche zu installieren, es klappt einfach nicht mehr.
                                  Installation läuft zwar durch kommen aber Fehler beim Starten der Instanz:
                                  was sagt dieses LOG aus?
                                  host-iobroker	2016-03-25 17:11:30	info	Restart adapter system.adapter.zwave.0 because enabled
                                  host-iobroker	2016-03-25 17:11:30	error	instance system.adapter.zwave.0 terminated with code 6 (uncaught exception)
                                  Error:	2016-03-25 17:11:30	error	at Function.Module._load (module.js:310:12)
                                  Error:	2016-03-25 17:11:30	error	at Module.load (module.js:355:32)
                                  Error:	2016-03-25 17:11:30	error	at Object.Module._extensions..js (module.js:478:10)
                                  Error:	2016-03-25 17:11:30	error	at Module._compile (module.js:460:26)
                                  Error:	2016-03-25 17:11:30	error	at Object. (/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/lib/openzwave-shared.js:26:19)
                                  Error:	2016-03-25 17:11:30	error	at require (module.js:384:17)
                                  Error:	2016-03-25 17:11:30	error	at Module.require (module.js:365:17)
                                  Error:	2016-03-25 17:11:30	error	at Error (native)
                                  Error:	2016-03-25 17:11:30	error	libopenzwave.so.1.4: cannot open shared object file: No such file or directory
                                  uncaught	2016-03-25 17:11:30	error	exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
                                  zwave-0	2016-03-25 17:11:29	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.zwave
                                  host-iobroker	2016-03-25 17:11:26	info	instance system.adapter.zwave.0 started with pid 2469
                                  Grüße,Lenny
                                  • V Offline
                                    V Offline
                                    versteckt
                                    #73
                                    kannst du mal auf deinem Rechner nach dieser Datei suchen? libopenzwave.so.1.4
                                    Sollte normalerweise in "/usr/local/lib/libopenzwave.so.1.4" zu finden sein.
                                    Ausserdem müsste "/usr/local/lib/pkgconfig/libopenzwave.pc" vorhanden sein.
                                    Probier sonst mal ein "ldconfig", dann müsste dein LD_LIBRARY_PATH neu gesetzt werden.
                                    Bzw. "ldconfig -p|grep zwave"
                                    Dann siehst du wo im Cache die Datei sein sollte.
                                    • Lenny.CBL Offline
                                      Lenny.CBL Offline
                                      Lenny.CB
                                      #74
                                      @versteckt:
                                      Dann siehst du wo im Cache die Datei sein sollte. `
                                      ````ist da wo sie sein soll
                                      so, "lldconfig -p|grep zwave" ist gemacht…
                                      schaut trotzdem komisch aus...
                                      LOG:
                                      iobroker 2016-03-25 18:15:36 info host.iobroker Restart adapter system.adapter.zwave.0 because enabled
                                      iobroker 2016-03-25 18:15:36 error host.iobroker instance system.adapter.zwave.0 terminated with code 6 (uncaught exception)
                                      zwave.0 2016-03-25 18:15:34 error TypeError: setValue: OpenZWave valueId not found at TypeError (native) at Socket. (/opt/iobroker/node_modules/iobroker.zwave/main.js:518:51) at Socket.onack (/opt/iobroker/node_
                                      zwave.0 2016-03-25 18:15:34 error uncaught exception: setValue: OpenZWave valueId not found
                                      zwave.0 2016-03-25 18:15:34 info zwave.0 setState for: nodeid=undefined: comclass=undefined: index=undefined: instance=undefined: value=true
                                      zwave.0 2016-03-25 18:15:34 warn zwave.0 Object 'zwave.0.NODE9.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:15:34 warn zwave.0 Object 'zwave.0.NODE8.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:15:34 warn zwave.0 Object 'zwave.0.NODE7.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:15:34 warn zwave.0 Object 'zwave.0.NODE6.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:15:34 warn zwave.0 Object 'zwave.0.NODE5.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:15:34 warn zwave.0 Object 'zwave.0.NODE4.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:15:33 info zwave.0 Scan completed
                                      zwave.0 2016-03-25 18:15:33 info zwave.0 node ready nodeid:9 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor
                                      zwave.0 2016-03-25 18:15:33 info zwave.0 node ready nodeid:8 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor
                                      zwave.0 2016-03-25 18:15:33 info zwave.0 node ready nodeid:7 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor
                                      zwave.0 2016-03-25 18:15:33 info zwave.0 node ready nodeid:6 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor
                                      zwave.0 2016-03-25 18:15:33 info zwave.0 node ready nodeid:5 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGWPE Wall Plug","producttype":"0x0600","productid":"0x1000","type":"Binary Switch","name":"",
                                      zwave.0 2016-03-25 18:15:33 info zwave.0 node ready nodeid:4 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor
                                      zwave.0 2016-03-25 18:15:29 info zwave.0 node ready nodeid:1 nodeinfo:{"manufacturer":"Aeotec","manufacturerid":"0x0086","product":"Z-Stick Gen5","producttype":"0x0001","productid":"0x005a","type":"Static PC Controller","name":"","lo
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 node9: nop, currently not implemented
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 node8: nop, currently not implemented
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 node7: nop, currently not implemented
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 node6: nop, currently not implemented
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 node5: nop, currently not implemented
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 node4: nop, currently not implemented
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 nodeid 9 is now available, but maybe not ready
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 nodeid 8 is now available, but maybe not ready
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 nodeid 7 is now available, but maybe not ready
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 nodeid 6 is now available, but maybe not ready
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 nodeid 5 is now available, but maybe not ready
                                      zwave.0 2016-03-25 18:15:22 info zwave.0 nodeid 4 is now available, but maybe not ready
                                      zwave.0 2016-03-25 18:15:21 info zwave.0 nodeid 1 is now available, but maybe not ready
                                      zwave.0 2016-03-25 18:15:21 info zwave.0 driver ready: homeid = f331c5f6
                                      zwave.0 2016-03-25 18:15:21 info zwave.0 scanning homeid=0xf331c5f6...
                                      zwave.0 2016-03-25 18:15:21 info zwave.0 connected: homeid = 1.4.0
                                      zwave.0 2016-03-25 18:15:19 info zwave.0 starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.zwave
                                      iobroker 2016-03-25 18:15:16 info host.iobroker instance system.adapter.zwave.0 started with pid 4874
                                      iobroker 2016-03-25 18:14:45 info host.iobroker Restart adapter system.adapter.zwave.0 because enabled
                                      iobroker 2016-03-25 18:14:45 error host.iobroker instance system.adapter.zwave.0 terminated with code 6 (uncaught exception)
                                      zwave.0 2016-03-25 18:14:43 error TypeError: setValue: OpenZWave valueId not found at TypeError (native) at Socket. (/opt/iobroker/node_modules/iobroker.zwave/main.js:518:51) at Socket.onack (/opt/iobroker/node_
                                      zwave.0 2016-03-25 18:14:43 error uncaught exception: setValue: OpenZWave valueId not found
                                      zwave.0 2016-03-25 18:14:43 info zwave.0 setState for: nodeid=undefined: comclass=undefined: index=undefined: instance=undefined: value=true
                                      zwave.0 2016-03-25 18:14:43 warn zwave.0 Object 'zwave.0.NODE9.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:14:43 warn zwave.0 Object 'zwave.0.NODE8.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:14:43 warn zwave.0 Object 'zwave.0.NODE7.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:14:43 warn zwave.0 Object 'zwave.0.NODE6.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:14:43 warn zwave.0 Object 'zwave.0.NODE5.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:14:43 warn zwave.0 Object 'zwave.0.NODE4.ready' not found for stateChange
                                      zwave.0 2016-03-25 18:14:42 info zwave.0 Scan completed
                                      zwave.0 2016-03-25 18:14:42 info zwave.0 node ready nodeid:9 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor
                                      zwave.0 2016-03-25 18:14:42 info zwave.0 node ready nodeid:8 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor
                                      zwave.0 2016-03-25 18:14:42 info zwave.0 node ready nodeid:7 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor
                                      zwave.0 2016-03-25 18:14:42 info zwave.0 node ready nodeid:6 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor
                                      zwave.0 2016-03-25 18:14:42 info zwave.0 node ready nodeid:5 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGWPE Wall Plug","producttype":"0x0600","productid":"0x1000","type":"Binary Switch","name":"",
                                      zwave.0 2016-03-25 18:14:42 info zwave.0 node ready nodeid:4 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor
                                      zwave.0 2016-03-25 18:14:40 info zwave.0 node9: timeout, currently not implemented
                                      zwave-0 2016-03-25 18:14:28 info node9: timeout, currently not implemented
                                      zwave-0 2016-03-25 18:14:18 info node9: timeout, currently not implemented
                                      zwave-0 2016-03-25 18:14:08 info node ready nodeid:1 nodeinfo:{"manufacturer":"Aeotec","manufacturerid":"0x0086","product":"Z-Stick Gen5","producttype":"0x0001","productid":"0x005a","type":"Static PC Controller","name":"","loc":""}
                                      zwave-0 2016-03-25 18:14:02 info node9: nop, currently not implemented
                                      zwave-0 2016-03-25 18:14:02 info node8: nop, currently not implemented
                                      zwave-0 2016-03-25 18:14:02 info node7: nop, currently not implemented
                                      zwave-0 2016-03-25 18:14:02 info node6: nop, currently not implemented
                                      zwave-0 2016-03-25 18:14:02 info node5: nop, currently not implemented
                                      zwave-0 2016-03-25 18:14:02 info node4: nop, currently not implemented
                                      zwave-0 2016-03-25 18:14:02 info nodeid 9 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:14:02 info nodeid 8 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:14:01 info nodeid 7 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:14:01 info nodeid 6 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:14:01 info nodeid 5 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:14:01 info nodeid 4 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:14:01 info nodeid 1 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:14:01 info driver ready: homeid = f331c5f6
                                      zwave-0 2016-03-25 18:14:01 info scanning homeid=0xf331c5f6...
                                      zwave-0 2016-03-25 18:14:00 info connected: homeid = 1.4.0
                                      zwave-0 2016-03-25 18:13:59 info starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.zwave
                                      host-iobroker 2016-03-25 18:13:55 info instance system.adapter.zwave.0 started with pid 4863
                                      host-iobroker 2016-03-25 18:13:25 info Restart adapter system.adapter.zwave.0 because enabled
                                      host-iobroker 2016-03-25 18:13:25 error instance system.adapter.zwave.0 terminated with code 6 (uncaught exception)
                                      TypeError: 2016-03-25 18:13:23 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                                      TypeError: 2016-03-25 18:13:23 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                                      TypeError: 2016-03-25 18:13:23 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                      TypeError: 2016-03-25 18:13:23 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                                      TypeError: 2016-03-25 18:13:23 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                                      TypeError: 2016-03-25 18:13:23 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                      TypeError: 2016-03-25 18:13:23 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                                      TypeError: 2016-03-25 18:13:23 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                                      TypeError: 2016-03-25 18:13:23 error at Socket. (/opt/iobroker/node_modules/iobroker.zwave/main.js:518:51)
                                      TypeError: 2016-03-25 18:13:23 error at TypeError (native)
                                      TypeError: 2016-03-25 18:13:23 error setValue: OpenZWave valueId not found
                                      uncaught 2016-03-25 18:13:23 error exception: setValue: OpenZWave valueId not found
                                      zwave-0 2016-03-25 18:13:23 info setState for: nodeid=undefined: comclass=undefined: index=undefined: instance=undefined: value=true
                                      zwave-0 2016-03-25 18:13:23 warn Object 'zwave.0.NODE9.ready' not found for stateChange
                                      zwave-0 2016-03-25 18:13:23 warn Object 'zwave.0.NODE8.ready' not found for stateChange
                                      zwave-0 2016-03-25 18:13:23 warn Object 'zwave.0.NODE7.ready' not found for stateChange
                                      zwave-0 2016-03-25 18:13:23 warn Object 'zwave.0.NODE6.ready' not found for stateChange
                                      zwave-0 2016-03-25 18:13:23 warn Object 'zwave.0.NODE5.ready' not found for stateChange
                                      zwave-0 2016-03-25 18:13:23 warn Object 'zwave.0.NODE4.ready' not found for stateChange
                                      zwave-0 2016-03-25 18:13:22 info Scan completed
                                      zwave-0 2016-03-25 18:13:22 info node ready nodeid:9 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor Contro
                                      zwave-0 2016-03-25 18:13:22 info node ready nodeid:8 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
                                      zwave-0 2016-03-25 18:13:22 info node ready nodeid:7 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
                                      zwave-0 2016-03-25 18:13:22 info node ready nodeid:6 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor Contro
                                      zwave-0 2016-03-25 18:13:22 info node ready nodeid:5 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGWPE Wall Plug","producttype":"0x0600","productid":"0x1000","type":"Binary Switch","name":"","loc":"
                                      zwave-0 2016-03-25 18:13:22 info node ready nodeid:4 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
                                      zwave-0 2016-03-25 18:13:19 info node9: timeout, currently not implemented
                                      host-iobroker 2016-03-25 18:13:13 warn instance system.adapter.zwave.0 already running with pid 4853
                                      zwave-0 2016-03-25 18:13:06 info node ready nodeid:1 nodeinfo:{"manufacturer":"Aeotec","manufacturerid":"0x0086","product":"Z-Stick Gen5","producttype":"0x0001","productid":"0x005a","type":"Static PC Controller","name":"","loc":""}
                                      zwave-0 2016-03-25 18:12:59 info node9: nop, currently not implemented
                                      zwave-0 2016-03-25 18:12:59 info node8: nop, currently not implemented
                                      zwave-0 2016-03-25 18:12:59 info node7: nop, currently not implemented
                                      zwave-0 2016-03-25 18:12:59 info node6: nop, currently not implemented
                                      zwave-0 2016-03-25 18:12:59 info node5: nop, currently not implemented
                                      zwave-0 2016-03-25 18:12:59 info node4: nop, currently not implemented
                                      zwave-0 2016-03-25 18:12:59 info nodeid 9 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:12:59 info nodeid 8 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:12:58 info nodeid 7 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:12:58 info nodeid 6 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:12:58 info nodeid 5 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:12:58 info nodeid 4 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:12:58 info nodeid 1 is now available, but maybe not ready
                                      zwave-0 2016-03-25 18:12:58 info driver ready: homeid = f331c5f6
                                      zwave-0 2016-03-25 18:12:58 info scanning homeid=0xf331c5f6...
                                      zwave-0 2016-03-25 18:12:57 info connected: homeid = 1.4.0
                                      zwave-0 2016-03-25 18:12:56 info starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.zwave
                                      host-iobroker 2016-03-25 18:12:52 info instance system.adapter.zwave.0 started with pid 4853
                                      • V Offline
                                        V Offline
                                        versteckt
                                        #75
                                        Ok, der Fehler ist mir nicht klar, dagegen kann ich auch was machen:
                                        Mir ist nur nicht klar, warum der auftritt.
                                        Hast du versucht einen Zustand zu verändern? Und wenn ja, welchen?
                                        LG Christian
                                        • V Offline
                                          V Offline
                                          versteckt
                                          #76
                                          Kannst du in der main.js von zwave mal folgendes hinzufügen?
                                          if (nodeid == undefined) {
        adapter.log.error("This state is not valid: " + JSON.stringify(state));
        adapter.log.error("Object was: " + JSON.stringify(obj));
                                          Und zwar vor der Zeile 288
        switch (action) {
                                          Und mir dann nochmals ein Log schicken?
