  4. Apple Homekit Siri
Apple Homekit Siri
250 Beiträge 49 Kommentatoren 90.4k Aufrufe
  • M
    M
    mimquadrat
    #160
    host-raspberrypi 2016-03-05 20:19:27 info Restart adapter system.adapter.homekit.0 because enabled
    host-raspberrypi 2016-03-05 20:19:27 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
    TypeError: 2016-03-05 20:19:27 error at IncomingMessage.emit (events.js:104:17)
    TypeError: 2016-03-05 20:19:27 error at HAPServer. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:188:39)
    TypeError: 2016-03-05 20:19:27 error at HAPServer._handleCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10)
    TypeError: 2016-03-05 20:19:27 error at HAPServer.emit (events.js:118:17)
    TypeError: 2016-03-05 20:19:27 error at Bridge.Accessory._handleGetCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:554:8)
    TypeError: 2016-03-05 20:19:27 error at Array.forEach (native)
    TypeError: 2016-03-05 20:19:27 error at Bridge. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:587:20)
    TypeError: 2016-03-05 20:19:27 error at Characteristic.getValue (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:120:10)
    TypeError: 2016-03-05 20:19:27 error at emit (events.js:110:17)
    TypeError: 2016-03-05 20:19:27 error at null. (/opt/iobroker/node_modules/iobroker.homekit/main.js:759:37)
    TypeError: 2016-03-05 20:19:27 error Cannot read property 'val' of undefined
    uncaught 2016-03-05 20:19:27 error exception: Cannot read property 'val' of undefined
    homekit-0 2016-03-05 20:19:27 debug < hap Summer get Switch for hm-rpc.0.LEQ0569487.4undefined
    homekit-0 2016-03-05 20:19:27 debug < hap Treppenhauslicht get Switch for hm-rpc.0.JEQ0147075.1.STATE
    • C
      C
      chaos99
      #161
      So ich hab noch mal etwas rum probiert , ich hab jetzt IO- HomeKit bei eve , verliere dann nach 1 min die Verbindung zu den aktoren , wenn ich jetzt das WLAN aus und wieder an mache hab ich wieder Verbindung zu den aktoren für 1 min
      Edit: so ich hab mal ein anderes program genommen , also sogar zwei , und beide funktionieren ohne Probleme , also liegt es bei mir an eve , jetzt muss ich nur noch eine App finden die die sprach Steuerung so umsetzt wie ich mir das denke ,
      • C
        C
        chka
        #162
        883_iobroker.2016-03-05.log
        der code ist leider immer noch nicht ok,
        Benutzer habe ich geändert der anmeldeprozes war diesmal anders
        INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
        Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
        RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
        • V
          V
          versteckt
          #163
          @chaos99:
          Ok!? Mit Eve hatte ich eigentlich immer die gleichen Probleme wie z.B. mit MyHome.
          Die Sprachsteuerung ist ja fix in iOS integriert. Du musst ja nur die Geräte, Räume, Szenen, etc.
          korrekt benennen und dann ist dies mit Siri nativ möglich.
          @chka:
          In deinem Logfile sind aber keine Exceptions mehr drinnen.
          Hast du wie chaos99 auch schon mal eine andere App ausprobiert?
          LG Christian
          Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
          homegear für Homematic und MAX!
          occ, zWave, rpi, hmm und homekit Entwickler
          • C
            C
            chaos99
            #164
            okay noch ein update, es ging zwar ne weile gut mit der anderen App dann aber das gleiche Problem, ich hatte mir da schon die App myHome gekauft,
            da bekomme ich dann auch ne Fehlermeldung, ich hab den Support angeschrieben und auch ne Antwort bekommen :
            PS: OSStatus 6723 also hints that you are using homebridge. If so, please refer to https://github.com/nfarina/homebridge
            This has been an issue there in the past, e.g. https://github.com/nfarina/homebridge/issues/117
            so weit ich das verstehe , könnte es also an einem Aktor liegen ?
            Edit:
            um das mit den Aktoren mal zu prüfen , will ich das nur ein teil der Aktoren an Homekit übertragen wird, aber wie mach ich das? unter Konfiguration kann ich ja Geräte löschen(hab Homekit neu installiert Geräte gelöscht und dann erst gestartet) bekomme dann im log aber diese Fehler:
            host-cubietruck 2016-03-06 12:22:30 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
            TypeError: 2016-03-06 12:22:29 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            TypeError: 2016-03-06 12:22:29 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
            TypeError: 2016-03-06 12:22:29 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
            TypeError: 2016-03-06 12:22:29 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
            TypeError: 2016-03-06 12:22:29 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
            TypeError: 2016-03-06 12:22:29 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
            TypeError: 2016-03-06 12:22:29 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
            TypeError: 2016-03-06 12:22:29 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
            TypeError: 2016-03-06 12:22:29 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:280:67)
            TypeError: 2016-03-06 12:22:29 error at Object.createAccessory_Humidity [as Humidity] (/opt/iobroker/node_modules/iobroker.homekit/main.js:511:41)
            TypeError: 2016-03-06 12:22:29 error Cannot read property 'CurrentRelativeHumidity' of undefined
            uncaught 2016-03-06 12:22:29 error exception: Cannot read property 'CurrentRelativeHumidity' of undefined
            homekit-0 2016-03-06 12:22:29 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1071633.1.HUMIDITY
            homekit-0 2016-03-06 12:22:29 debug < hap Type for Humidity = HM-TC-IT-WM-W-EU
            homekit-0 2016-03-06 12:22:29 debug Accessory: Switch Object: State
            homekit-0 2016-03-06 12:22:29 info hap-nodejs starting…
            homekit-0 2016-03-06 12:22:29 debug received all objects
            homekit-0 2016-03-06 12:22:28 debug received all states
            homekit-0 2016-03-06 12:22:24 debug requesting all objects
            homekit-0 2016-03-06 12:22:24 debug requesting all states
            homekit-0 2016-03-06 12:22:24 info starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
            ich hab was gelesen das ich das über enum.homekit machen kann , hab dies auch versucht aber ich weiß nicht wie das dann mit Homekit verbunden wird das er nur diese Geräte nutzt
            • C
              C
              chka
              #165
              Ich habe es jetzt mal die My Home app con Clemens Putschei ausprobiert, leider das gleiche 883_iobroker.2016-03-06-0.log 883_iobroker.2016-03-06-1.log
              • M
                M
                MaggeO
                #166
                auch ich habe es mittlerweile gewagt, und ioBroker auf einem Debian in einer VM installiert. Das ganze läuft auch schon richtig gut. Daher habe ich mich nun auch an die Installation von Homekit getraut, stehe aber vor dem gleichen bzw. sehr ähnlichen Problem wie ihr. Die Einrichtung in Eve (oder auch Devices) funktioniert mit den bekannten Tücken wie Username ändern ansonsten problemlos und es werden auch alle Geräte aufgelistet. Allerdings stürzt dann sofort homekit ab und startet neu. Durch eine erzwungene Aktualisierung in Eve kann ich den erneuten Absturz aber provozieren.
                Da ich in der selben VM vor der Installation von ioBroker/homekit mit denselben Versionen der anderen Tools wie node.js/hap… jedoch eine lauffähige Version von Homebridge hatte, gehe ich davon aus, dass es nur an einem bestimmten Gerät liegt. Denn bei der Homebridge hatte ich gezielt über ein Gewerk in der CCU2 nur eine bestimmte Auswahl an Geräten für Homebridge "aktiviert".
                Im Anhang auch noch ein Ausschnitt meines Logfiles.
                1112_homekit_problem.log
                • V
                  V
                  versteckt
                  #167
                  Hallo, ok, ich werde mal einen Schalter einbauen, womit man nur bestimmte Geräte / Gruppen in homekit aktiviert.
                  Bez. enums: das gibt es als solches nicht mehr, weil ja der Plan ist, alle Geräte aus ioBroker auszulesen und darzustellen.
                  Ev. baue ich es als Test wieder ein (siehe oben), ich gebe euch Bescheid.
                  LG Christian
                  • V
                    V
                    versteckt
                    #168
                    @MaggeO:
                    Was ist "LEQ1286052" für ein Gerät?
                    LG Christian
                    • M
                      M
                      MaggeO
                      #169
                      Das ist ein wired 12/7 IO-Modul. Typenbezeichnung (auch in ioBroker) ist HMW-IO-12-Sw7-DR. Damit schalte ich den Großteil meiner Lichter.
                      Die ersten 12 Channel sind die Eingänge (in ioBroker bei mir die Rolle "button") und die Channel 13 - 19 sind die (geschalteten) Ausgänge (in ioBroker bei mir die Rolle "switch").
                      Danke für die schnelle Unterstüzung
                      • V
                        V
                        versteckt
                        #170
                        Alles klar, ist offiziell noch nicht supported. Aber wenn jemand neue Hardware testet,
                        ist das natürlich immer super, weil ich dann neue Hardware einbauen und aktivieren kann.
                        Könntest du mir nur einen Screenshot der Objektliste dieses Gerätes machen?
                        So in etwa:
                        Dann weiss ich ungefähr wie das Gerät konfiguriert gehört.
                        • M
                          M
                          MaggeO
                          #171
                          Klar, kein Problem.
                          hab jetzt mal nur ein der Eingänge und ein der Ausgänge ausgeklappt. Eingänge gehen wie gesagt bis 12 und ab 13 sind es die Ausgänge.
                          • M
                            M
                            mp84
                            #172
                            Hallo Hallo,
                            zum eingrenzen von Abstürzen bei unbekannten Geräte in EVE, ordne ich die Geräte meistens unterschiedlichen Räumen zu und beobachte das Log.
                            Der Adapter stürzt bei mir nur dann ab, wenn ich in EVE den entsprechenden Raum öffne.
                            Über diesen Weg ist für mich recht schnell klar, welcher Adapter nun den Crash verursacht hat.
                            Hoffe ich konnte etwas helfen.
                            Gruß MP
                            • V
                              V
                              versteckt
                              #173
                              @MaggeO:
                              Kannst du bitte mal versuchen in der Homekit Konfigurationsmaske eine neue Config Zeile hinzuzufügen?
                              Und zwar mit folgendem Inhalt:
                              Accessory: Switch
                              Object: State
                              Parent: HMW-IO-12-Sw7-DR
                              state: .STATE
                              Sollte dann so aussehen:
                              Danach bitte Homekit neustarten, bzw. sollte er das automatisch machen wenn du die Maske speicherst und schliesst.
                              LG Christian
                              • M
                                M
                                MaggeO
                                #174
                                ja nach der Änderung hat es auch mit dem wired Modul geklappt. Ich hatte danach aber meiner Meinung nach noch Probleme mit den CUxD-Thermostaten (siehe Logfile 1), die ich für die einfache Berechnung des Taupunktes und der absoluten Luftfeuchtigkeit bisher verwendet habe.
                                Ich konnte diese Probleme aber auf ähnliche Art und Weise beheben (siehe Logfile 2 und Bildschirmfoto - der Hersteller hängt dabei von dem in CUxD ausgewählten Device ab).
                                Nach diesen Änderungen hat bei einem ersten Test auch das Schalten über die App Eve funktioniert und ich konnte kein Absturz des Homekit-Adapters mehr beobachten.
                                Vielen Dank für deine Hilfe
                                PS. Weiter oben wurde ja schon einmal angesprochen, dass es ein Traum wäre die gewünschten Geräte "einzeln" auswählen zu können. Um dies noch ein bisschen weiterzuträumen, hier noch ein weiterer Vorschlag. Ich hatte ja bereits Homebridge bei mir laufen, und dort wurde die Auswahl über ein gesondertes Gewerk direkt auf der CCU2 gemacht. Also alle Geräte, die man diesem Gewerk zugeordnet hat, wurden dann in Homebridge für Homekit übernommen (da man dort in der Konfig eben dieses Gewerk eingetragen hat). Als fast schon perfekte Lösung könnte ich mir eine Kombination aus beidem vorstellen, also eine Erstauswahl der Geräte anhand eines in der Konfiguration vom Homekit-Adapter frei definierbaren Gewerkes (oder zunächst fest vorgegebenem Namen) und im Anschluss bei Bedarf noch eine Feinjustage (weitere Geräte hinzufügen oder einige Löschen) direkt in der Konfiguration des Adapters. Damit könnte man auch einer abgespeckten Freigabe von Geräten für verschiedene Instanzen des Adapters Rechnung tragen. Ist so etwas viel zu aufwändig bzw. für dich als Programmierer eher ein Alptraum? Oder könnte dieser Traum sogar einmal Wirklichkeit werden ;-) ?
                                • V
                                  V
                                  versteckt
                                  #175
                                  Hallo, ich habe bereits angefangen, das ganze mittels enums umzusetzen.
                                  Bin aber noch am testen, ob das so richtig funktioniert.
                                  Der Plan ist, das du in der Konfiguration "enums" aktivierst und dann enums lt. Anleitung konfigurierst.
                                  Somit kannst du alle Geräte einzeln in eine "Enum" geben und testen ob das alles korrekt funktioniert.
                                  Der Gedanke vorher war, das alle Geräte lt. einer bestimmten Rolle automatisch erkannt und in homekit
                                  angezeigt werden.
                                  LG Christian
                                  • S
                                    S
                                    Saul21R
                                    #176
                                    Siri kann also für Sie das Thermostat regeln, eine Party vorbereiten oder das Ambiente für ein Dinner bereiten. Für manche Befehle muss das iOS-Gerät zur Sicherheit entsperrt sein, wie zum Beispiel für das Öffnen von Türen, gibt Apple auf seiner Supportseite zu HomeKit bekannt. Weitere Befehle sollen folgen, die Liste ist laut Apple noch nicht komplett. Die deutsche Support-Seite zu HomeKit ist noch nicht aktualisiert.
                                    http://www.hulle6.com/category-samsung-galaxy-j5-zubehoer-249.html
                                    zuvor hatte ich schon ein Tab mit vielen verschiedenen Hüllen aber keine war so richtig zufriedenstellend. Ich habe hier auch nichts anderes erwartet. http://www.hulle6.com
                                    • C
                                      C
                                      chaos99
                                      #177
                                      Also ich hab das jetzt mal gemacht und jeden aktor einzeln getestet in einem separaten Raum , bei dem homematic wired Modul 12/7 verliert er immer die Verbindung , egal welcher Ausgang ,
                                      Ist es weiter hin auch möglich Szenen von ioroker zu übertragen ? Also ist das machbar , damit man mit Siri eine ganze Szene die auf ioroker hinterlegt ist zu aktivieren / deaktivieren ? Man könnte eve ja vorgaukeln das es eine steckdose ist ? Warum: ich habe die Szene tv schauen und abends gehen dann automatisch die Jalousien mit runter …
                                      • C
                                        C
                                        chka
                                        #178
                                        Bekomme immer noch den Fehler das EVE keine Verbindung aufbauen kann.
                                        In den Logs sehe ich nichts nur die diversen Aktoren Meldungen und
                                        homekit-0 2016-04-17 13:38:06 info Node Bridge identify:false
                                        • J
                                          J
                                          jack77
                                          #179
                                          Ich kriege Homekit einfach nicht installiert.
                                          Kriege immer folgenden Fehler…
                                          ` > $ ./iobroker add homekit
                                          npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
                                          In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
                                          #include <dns_sd.h>^
                                          compilation terminated.
                                          make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
                                          gyp
                                          ERR! build error
                                          gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                                          gyp ERR! stack at emitTwo (events.js:87:13)
                                          gyp ERR! stack at ChildProcess.emit (events.js:172:7)
                                          gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
                                          gyp ERR! System Linux 4.1.19-v7+
                                          gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                          gyp ERR!
                                          cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
                                          gyp ERR! node -v v4.4.3gyp ERR! node-gyp -v v3.3.1
                                          gyp ERR! not ok
                                          npm
                                          ERR!
                                          Linux 4.1.19-v7+
                                          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"npm ERR! node v4.4.3
                                          npm ERR! npm v2.15.1
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! mdns@2.2.11 install: node-gyp rebuild
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
                                          npm ERR! This is most likely a problem with the mdns package,npm ERR! not with npm itself.
                                          npm ERR! Tell the author that this fails on your system:
                                          npm ERR! node-gyp rebuild
                                          npm ERR! You can get information on how to open an issue for this project with:
                                          npm ERR! npm bugs mdns
                                          npm ERR! Or if that isn't available, you can get their info via:
                                          npm ERR! npm ERR! npm owner ls mdns
                                          npm ERR! There is likely additional logging output above.
                                          npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
                                          ERROR: host.raspberrypi Cannot install iobroker.homekit: 1
                                          ERROR: process exited with code 25</dns_sd.h> `
                                          ioBroker ist auf einem Raspi2 mit Debian Jessie installiert.
                                          Kann mir einer helfen
                                          84.2k
