  4. Test Adapter ioBroker.backitup v3.1.x
    6.6k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • simatecS Online
    simatecS Online
    simatec
    #394
    Ab sofort ist das Release 1.4.1 auf Github und spätestens ab heute Nacht auch in der latest Repo verfügbar.
    Changelog
    1.4.1 (02.03.2020)
    • (simatec) json historystate with more options
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS simatec
      Changelog
      1.4.1 (02.03.2020)
      darkiop
      schrieb am zuletzt editiert von darkiop
      #395
      @simatec Hatte diese Woche leider noch keine Zeit mir die Geschichte mit dem "Fehler" beim Backup anzuschauen. Fehler in "" da wohl nur der State ccusuccess bzw. iobroekrsuccess auf Status Fehler gesetzt wird, die Backups aber erstellt werden:
      Gestartet...
      [DEBUG] [ccu] - CCU Version: 3.49.17.20191225
      [DEBUG] [ccu] - Requesting backup from CCU
      [DEBUG] [ccu] start with {"type":"creator","time":"04:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"host":"xxxxxxxxxxxxxxx.walk-steinweiler.de","user":"darkiop","pass":"****","backupDir":"/opt/iobroker/backups"}
      [DEBUG] [ccu] - done
      [DEBUG] [clean] - done
      [DEBUG] [history] - backitup.0.history.html
      [DEBUG] [history] - backitup.0.history.json
      [EXIT] 0
      [DEBUG] [history] start with {"type":"creator","time":"04:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"07. Maerz 2020 um 07:34 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"host":"xxxxxxxxxxxxxxx.walk-steinweiler.de","user":"darkiop","pass":"****","backupDir":"/opt/iobroker/backups"}
      Auszug ausm dem json, hier error = none:
      ["date":"07. Maerz 2020 um 07:34 Uhr","name":"homematic_2020_03_07-07_34_42_3.49.17.20191225_backupiobroker.tar.sbk","type":"ccu","storage":"Nur lokal gesichert","filesize":"2MB","error":"none"},
      Grundsätzlich werden die Backups auch erstellt:
      Neu installieren, inkl. manuellen löschens des iobroker.backitup Ordners unter node_modules hat leider nicht geholfen.
      Hast du deine Idee? :)
      Edit: Ich glaube ich hab den Verursucher gefunden: Sobald der Debug Mode in den Backitup Einstellungen Aktiv ist, wird *success nicht auf true gesetzt.
      Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
      • D darkiop
        Gestartet...
        [EXIT] 0
        simatecS Online
        simatecS Online
        simatec
        #396
        @darkiop
        Danke für den Hinweis. Das schaue ich mir mal an und werde den Fehler beheben
        • simatecS simatec
          @darkiop
          darkiop
          #397
          @simatec Gern.
          Könntest du noch eine Option für die Formatierung des Datums einbauen? So nimmt das ziemlich viel Platz in Anspruch :)
          • D darkiop
            @simatec Gern.
            simatecS Online
            simatecS Online
            simatec
            #398
            @darkiop
            In welchem Format haltet ihr die history für sinnvoll?
            • JB_SullivanJ Offline
              JB_Sullivan
              schrieb am zuletzt editiert von JB_Sullivan
              #399
              Ich denke letztendlich ist das alles eine Frage der persönlichen Schriftgröße und Formatierung. Ich persönlich würde aber das Wort UM durch einen Bindestrich ersetzen.
              Um das verschieben der Ansicht bei unterschiedlichen Monatsnamen zu unterbinden (Dezember lang / Mai kurz), würde ich tatsächlich auf das numerische Monats Datum wechseln.
              BtW: Wo bekommt man die Datei Größen Anzeige her? Ich sehe da bei mir keinen Datenpunkt der das ausgeben würde. Adapter Version ist bei mir 1.4.1
              • JB_SullivanJ JB_Sullivan
                simatecS Online
                simatecS Online
                simatec
                #400
                @JB_Sullivan
                Ab Version 1.4.1 ist filesize mit in der history json enthalten
                • simatecS simatec
                  @JB_Sullivan
                  JB_Sullivan
                  #401
                  @simatec sagte in Test Adapter Backitup v1.4.x:
                  @JB_Sullivan
                  Ah - OK daher - ich benutze die HTML Ausgabe und da ist das nicht mit drin.
                    @JB_Sullivan
                    simatecS Online
                    simatecS Online
                    simatec
                    #402
                    @JB_Sullivan
                    Ja die html Tabelle beinhaltet den backupname und filesize noch nicht vollumfänglich.
                    Da wollte sich @liv-in-sky noch etwas überlegen und umbauen.
                    • simatecS simatec
                      @JB_Sullivan
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      #403
                      @simatec
                      die filegröße war schon da - im neuen update sieht man auch den filenamen gesamt
                      • liv-in-skyL liv-in-sky
                        @simatec
                        simatecS Online
                        simatecS Online
                        simatec
                        #404
                        @liv-in-sky
                        Läuft die neue Version auch schon mit iqontrol?
                        • simatecS simatec
                          @liv-in-sky
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #405
                          @simatec
                          die tabelle kann immer angezeigt werden - leider funktionert das umschalten nicht und auch das starten eines jobs
                          bzw
                          es gibt einen datenpunkt refresh - ist der true , wird der filename und die größe angezeigt - bei false der typ und der storage wert
                          ich habe im neuen script auf true gestellt (da interessantere ansicht) - von daher kann man es in iqontrol nutzen
                            @simatec
                            bzw
                            simatecS Online
                            simatecS Online
                            simatec
                            #406
                            @liv-in-sky perfekt ... danke dir ...👍
                            • simatecS simatec
                              Kueppert
                              schrieb am zuletzt editiert von Kueppert
                              #407
                              @simatec kannst du mir sagen, was du wie in icontrol eingebunden hast? Die Hostory? Hab ich nicht geschafft.
                              Etwas OffTopic, sorry :) Passt aber gerade so gut hierhin.
                              • K Kueppert
                                simatecS Online
                                simatecS Online
                                simatec
                                #408
                                @Kueppert schau mal ...
                                • simatecS simatec
                                  Kueppert
                                  #409
                                  @simatec danke dir. Ich denke, diese html muss ich per Skript auch irgendwo ablegen, wo ich sie mir abholen kann, korrekt?
                                  • K Kueppert
                                    simatecS Online
                                    simatecS Online
                                    simatec
                                    #410
                                    @Kueppert Den Script dazu hat @liv-in-sky zur Verfügung gestellt ...
                                    Hier der Link zum Script
                                    • simatecS simatec
                                      Kueppert
                                      #411
                                      @simatec danke dir. Ich glaube, ich warte auf eine Umsetzung im Adapter :D
                                      • K Kueppert
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        #412
                                        @Kueppert
                                        Ist ganz simple ... traue dich 😊
                                        Stephan SchleichS 1 Antwort Letzte Antwort
                                        • simatecS simatec
                                          @Kueppert
                                          Stephan SchleichS Offline
                                          Stephan Schleich
                                          #413
                                          Besteht die Möglichkeit auch Scripte separat zu Backupen bzw kann man das einbauen?
                                          JB_SullivanJ simatecS 2 Antworten Letzte Antwort
