  4. Test Adapter ioBroker.backitup v3.1.x
    6.6k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • LatziL Latzi
    @simatec sagte in Test Adapter Backitup v1.4.x:
    Bitte mal die Instanz auf debug stellen und den Log posten
    schon erledigt, hier der Log:
    2020-02-29 14:18:50.161 - info: host.Pi4-Server stopInstance system.adapter.backitup.0 (force=false, process=true)
    2020-02-29 14:18:50.162 - info: host.Pi4-Server stopInstance system.adapter.backitup.0 send kill signal
    2020-02-29 14:18:50.166 - info: backitup.0 (26152) Got terminate signal TERMINATE_YOURSELF
    2020-02-29 14:18:50.671 - info: backitup.0 (26152) terminating
    2020-02-29 14:18:50.672 - info: backitup.0 (26152) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2020-02-29 14:18:51.164 - info: host.Pi4-Server stopInstance system.adapter.backitup.0 killing pid 26152
    2020-02-29 14:18:51.208 - info: host.Pi4-Server instance system.adapter.backitup.0 terminated with code 156 (156)
    2020-02-29 14:18:52.688 - info: host.Pi4-Server instance system.adapter.backitup.0 started with pid 3057
    2020-02-29 14:18:55.510 - debug: backitup.0 (3057) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2020-02-29 14:18:55.546 - debug: backitup.0 (3057) Objects client ready ... initialize now
    2020-02-29 14:18:55.550 - debug: backitup.0 (3057) Objects create System PubSub Client
    2020-02-29 14:18:55.552 - debug: backitup.0 (3057) Objects create User PubSub Client
    2020-02-29 14:18:55.552 - debug: backitup.0 (3057) Objects client initialize lua scripts
    2020-02-29 14:18:55.568 - debug: backitup.0 (3057) Objects connected to redis: 127.0.0.1:9001
    2020-02-29 14:18:55.574 - debug: backitup.0 (3057) objectDB connected
    2020-02-29 14:18:55.577 - debug: backitup.0 (3057) Redis States: Use Redis connection: 127.0.0.1:9000
    2020-02-29 14:18:55.586 - debug: backitup.0 (3057) States create User PubSub Client
    2020-02-29 14:18:55.588 - debug: backitup.0 (3057) States create System PubSub Client
    2020-02-29 14:18:55.615 - debug: backitup.0 (3057) States connected to redis: 127.0.0.1:9000
    2020-02-29 14:18:55.616 - debug: backitup.0 (3057) statesDB connected
    2020-02-29 14:18:57.233 - info: backitup.0 (3057) starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.19.0
    2020-02-29 14:18:57.328 - info: backitup.0 (3057) [iobroker] backup was activated at 02:05 every 1 day(s)
    2020-02-29 14:18:57.362 - debug: backitup.0 (3057) [iobroker] 10 05 02 */1 * *
    2020-02-29 14:19:07.304 - debug: backitup.0 (3057) mount activ... umount in 2 Seconds!!
    2020-02-29 14:19:32.661 - debug: backitup.0 (3057) [iobroker/mount] done
    2020-02-29 14:19:35.402 - debug: backitup.0 (3057) system.adapter.admin.0: logging true
    2020-02-29 14:19:36.399 - debug: backitup.0 (3057) [iobroker/iobroker] host.Pi4-Server 7739 states saved
    2020-02-29 14:19:36.443 - debug: backitup.0 (3057) [iobroker/iobroker] host.Pi4-Server 8035 objects saved
    2020-02-29 14:19:45.505 - debug: backitup.0 (3057) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2020_02_29-14_19_32_backupiobroker.tar.gz
    2020-02-29 14:19:46.567 - debug: backitup.0 (3057) [iobroker/iobroker] done
    2020-02-29 14:19:46.622 - debug: backitup.0 (3057) [iobroker/zigbee] done
    2020-02-29 14:19:46.628 - debug: backitup.0 (3057) [iobroker/cifs] done
    2020-02-29 14:19:46.634 - debug: backitup.0 (3057) [iobroker/clean] done
    2020-02-29 14:19:46.657 - debug: backitup.0 (3057) [iobroker/history] backitup.0.history.html
    2020-02-29 14:19:46.672 - debug: backitup.0 (3057) [iobroker/history] backitup.0.history.json
    2020-02-29 14:19:46.675 - debug: backitup.0 (3057) [iobroker] exec: done
    2020-02-29 14:19:46.685 - debug: backitup.0 (3057) [iobroker/umount] mount activ... umount in 60 Seconds!!
    2020-02-29 14:20:15.501 - debug: backitup.0 (3057) system.adapter.admin.0: logging false
    2020-02-29 14:20:47.103 - debug: backitup.0 (3057) [iobroker/umount] done
    2020-02-29 14:20:47.104 - debug: backitup.0 (3057) [iobroker] exec: done
    2020-02-29 14:20:52.238 - debug: backitup.0 (3057) system.adapter.admin.0: logging true
    simatecS Online
    simatecS Online
    simatec
    #390
    @Latzi
    History wird nicht beendet.
    Deinstalliere mal die Instanz und den Adapter.
    Im Anschluß den Ordner backitup.0 löschen und iobroker neustarten.
    Danach sollte bei einer erneuten Installation alles laufen.
    Irgendwo scheint bei dir durch ein Node Update was nicht sauber kompiliert wurden sein.
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    LatziL 1 Antwort Letzte Antwort
      @darkiop sagte in Test Adapter Backitup v1.4.x:
      Hast du mal drüber nachgedacht, auch "externe" Datenbank über Backitup sichern zu lassen?
      Was meinst du mit externer Datenbank? Ich habe meine in einem anderen Proxmox-Container laufen und diese wird problemlos von Backitup gesichert. Einfach bei 'Host' die IP des Containers eingegeben und dann wie gewohnt Port, Datenbankname und Zugangsdaten.
      darkiop
      #391
      @Dr-Bakterius sagte in Test Adapter Backitup v1.4.x:
      Habe die Ursache - ich habe aktuell in meinem ioBroker Container keinen mysqlclient installiert - daher auch kein mysqldump :)
      Proxmox-ioBroker-Redis-HA Doku: https://forum.iobroker.net/topic/47478/dokumentation-einer-proxmox-iobroker-redis-ha-umgebung
      • simatecS simatec
        @Latzi
        LatziL Online
        LatziL Online
        Latzi
        #392
        genau so ist es, läuft nun wie es sein soll 👏
        Vielen Dank @simatec
        • simatecS Online
          simatecS Online
          simatec
          #393
          Für alle die Interesse an einer sehr schönen History Tabelle für ihre VIS oder auch iqontrol haben, hat @liv-in-sky was sehr schönes gebastelt.
          Hier der Link zum Script ...
          https://forum.iobroker.net/post/386565
          • simatecS Online
            simatecS Online
            simatec
            #394
            Ab sofort ist das Release 1.4.1 auf Github und spätestens ab heute Nacht auch in der latest Repo verfügbar.
            Changelog
            1.4.1 (02.03.2020)
            • (simatec) json historystate with more options
            • simatecS simatec
              Changelog
              1.4.1 (02.03.2020)
              darkiop
              schrieb am zuletzt editiert von darkiop
              #395
              @simatec Hatte diese Woche leider noch keine Zeit mir die Geschichte mit dem "Fehler" beim Backup anzuschauen. Fehler in "" da wohl nur der State ccusuccess bzw. iobroekrsuccess auf Status Fehler gesetzt wird, die Backups aber erstellt werden:
              Gestartet...
              [DEBUG] [ccu] - CCU Version: 3.49.17.20191225
              [DEBUG] [ccu] - Requesting backup from CCU
              [DEBUG] [ccu] start with {"type":"creator","time":"04:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"host":"xxxxxxxxxxxxxxx.walk-steinweiler.de","user":"darkiop","pass":"****","backupDir":"/opt/iobroker/backups"}
              [DEBUG] [ccu] - done
              [DEBUG] [clean] - done
              [DEBUG] [history] - backitup.0.history.html
              [DEBUG] [history] - backitup.0.history.json
              [EXIT] 0
              [DEBUG] [history] start with {"type":"creator","time":"04:00","debugging":true,"everyXDays":"1","deleteBackupAfter":0,"history":{"enabled":true,"type":"message","entriesNumber":"25","systemLang":"de","time":"07. Maerz 2020 um 07:34 Uhr"},"email":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"systemLang":"de"},"pushover":{"enabled":false,"notificationsType":"Telegram","type":"message","instance":"","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"systemLang":"de"},"host":"xxxxxxxxxxxxxxx.walk-steinweiler.de","user":"darkiop","pass":"****","backupDir":"/opt/iobroker/backups"}
              Auszug ausm dem json, hier error = none:
              ["date":"07. Maerz 2020 um 07:34 Uhr","name":"homematic_2020_03_07-07_34_42_3.49.17.20191225_backupiobroker.tar.sbk","type":"ccu","storage":"Nur lokal gesichert","filesize":"2MB","error":"none"},
              Grundsätzlich werden die Backups auch erstellt:
              Neu installieren, inkl. manuellen löschens des iobroker.backitup Ordners unter node_modules hat leider nicht geholfen.
              Hast du deine Idee? :)
              Edit: Ich glaube ich hab den Verursucher gefunden: Sobald der Debug Mode in den Backitup Einstellungen Aktiv ist, wird *success nicht auf true gesetzt.
              • D darkiop
                Gestartet...
                [EXIT] 0
                simatecS Online
                simatecS Online
                simatec
                #396
                @darkiop
                Danke für den Hinweis. Das schaue ich mir mal an und werde den Fehler beheben
                • simatecS simatec
                  @darkiop
                  darkiop
                  #397
                  @simatec Gern.
                  Könntest du noch eine Option für die Formatierung des Datums einbauen? So nimmt das ziemlich viel Platz in Anspruch :)
                  • D darkiop
                    @simatec Gern.
                    simatecS Online
                    simatecS Online
                    simatec
                    #398
                    @darkiop
                    In welchem Format haltet ihr die history für sinnvoll?
                    • JB_SullivanJ Offline
                      JB_Sullivan
                      schrieb am zuletzt editiert von JB_Sullivan
                      #399
                      Ich denke letztendlich ist das alles eine Frage der persönlichen Schriftgröße und Formatierung. Ich persönlich würde aber das Wort UM durch einen Bindestrich ersetzen.
                      Um das verschieben der Ansicht bei unterschiedlichen Monatsnamen zu unterbinden (Dezember lang / Mai kurz), würde ich tatsächlich auf das numerische Monats Datum wechseln.
                      BtW: Wo bekommt man die Datei Größen Anzeige her? Ich sehe da bei mir keinen Datenpunkt der das ausgeben würde. Adapter Version ist bei mir 1.4.1
                      • JB_SullivanJ JB_Sullivan
                        simatecS Online
                        simatecS Online
                        simatec
                        #400
                        @JB_Sullivan
                        Ab Version 1.4.1 ist filesize mit in der history json enthalten
                        • simatecS simatec
                          @JB_Sullivan
                          JB_Sullivan
                          #401
                          @JB_Sullivan
                          Ah - OK daher - ich benutze die HTML Ausgabe und da ist das nicht mit drin.
                            @JB_Sullivan
                            simatecS Online
                            simatecS Online
                            simatec
                            #402
                            @JB_Sullivan
                            Ja die html Tabelle beinhaltet den backupname und filesize noch nicht vollumfänglich.
                            Da wollte sich @liv-in-sky noch etwas überlegen und umbauen.
                            • simatecS simatec
                              @JB_Sullivan
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              #403
                              @simatec
                              die filegröße war schon da - im neuen update sieht man auch den filenamen gesamt
                              • liv-in-skyL liv-in-sky
                                @simatec
                                simatecS Online
                                simatecS Online
                                simatec
                                #404
                                @liv-in-sky
                                Läuft die neue Version auch schon mit iqontrol?
                                • simatecS simatec
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #405
                                  @simatec
                                  die tabelle kann immer angezeigt werden - leider funktionert das umschalten nicht und auch das starten eines jobs
                                  bzw
                                  es gibt einen datenpunkt refresh - ist der true , wird der filename und die größe angezeigt - bei false der typ und der storage wert
                                  ich habe im neuen script auf true gestellt (da interessantere ansicht) - von daher kann man es in iqontrol nutzen
                                    @simatec
                                    bzw
                                    simatecS Online
                                    simatecS Online
                                    simatec
                                    #406
                                    @liv-in-sky perfekt ... danke dir ...👍
                                    • simatecS simatec
                                      Kueppert
                                      schrieb am zuletzt editiert von Kueppert
                                      #407
                                      @simatec kannst du mir sagen, was du wie in icontrol eingebunden hast? Die Hostory? Hab ich nicht geschafft.
                                      Etwas OffTopic, sorry :) Passt aber gerade so gut hierhin.
                                      • K Kueppert
                                        simatecS Online
                                        simatecS Online
                                        simatec
                                        #408
                                        @Kueppert schau mal ...
                                        • simatecS simatec
                                          Kueppert
                                          #409
                                          @simatec danke dir. Ich denke, diese html muss ich per Skript auch irgendwo ablegen, wo ich sie mir abholen kann, korrekt?
