  4. Apple Homekit Siri
Apple Homekit Siri
250 Beiträge 49 Kommentatoren 90.6k Aufrufe
  • H
    H
    hofi77
    #137
    @jensus11:
    ich versuche das Homekit zu installieren.
    Doch leider bricht es immer ab.
    Wodran kann das liegen?
    Hier mal die Fehlermeldungen.
    ! $ ./iobroker add homekit
    ! npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
    ! In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    ! #include <dns_sd.h>^
    ! compilation terminated.
    ! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
    ! gyp
    ! ERR! build error
    ! gyp
    ! ERR!
    ! stack
    ! Error: make failed with exit code: 2gyp
    ! ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:270:23)gyp
    ! ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack
    ! at ChildProcess.emit (events.js:172:7)gyp
    ! ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)gyp ERR! System Linux 4.1.15-v7+
    ! gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
    ! gyp ERR! node -v v4.2.5
    ! gyp ERR! node-gyp -v v3.0.3
    ! gyp ERR! not ok
    ! npm
    ! ERR! Linux 4.1.15-v7+
    ! npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"
    ! npm ERR! node v4.2.5npm ERR! npm v2.14.12
    ! npm ERR! code ELIFECYCLE
    ! npm ERR! mdns@2.2.11 install: node-gyp rebuild
    ! npm ERR! Exit status 1
    ! npm ERR! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
    ! npm ERR! This is most likely a problem with the mdns package,
    ! npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
    ! npm ERR! node-gyp rebuild
    ! npm
    ! ERR!
    ! You can get their info via:npm ERR! npm owner ls mdns
    ! npm ERR! There is likely additional logging output above.
    ! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
    ! ERROR: host.iobroker Cannot install iobroker.homekit: 1
    ! ERROR: process exited with code 25</dns_sd.h> `
    Bei mir das gleiche :(
    Wo liegt der Fehler?
    Lg
    Manuel
    LG
    Manuel
    • V
      V
      versteckt
      #138
      Hallo, war leider ein "wenig" abwesend in letzter Zeit.
      Zuerst richtig verkühlt und dann heute noch Prüfung gehabt.
      Bin zwar noch ein wenig angeschlagen, werde mich aber jetzt wieder aktiver meinen Adaptern widmen.
      LG Christian
      Raspi 1, Raspi 2, iobroker, Mac Mini: alles mit aktueller ioBroker Version
      homegear für Homematic und MAX!
      occ, zWave, rpi, hmm und homekit Entwickler
      • F
        F
        funzel1607
        #139
        Bekommen auf meinem BananaPi ebenfalls folgende Fehler während der Installation des Adapters:
        ! In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
        ! gyp
        ! ERR! build error
        ! gyp ERR! stack Error: make failed with exit code: 2
        ! gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:269:23)gyp ERR! stack at ChildProcess.emit (events.js:110:17)
        ! gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1074:12)
        ! gyp ERR! System Linux 3.4.110-sun7i
        ! gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
        ! gyp ERR! node -v v0.12.6
        ! gyp
        ! ERR! node-gyp -v v2.0.1gyp ERR! not ok
        ! npm
        ! ERR! Linux 3.4.110-sun7i
        ! npm ERR!
        ! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"
        ! npm ERR! node v0.12.6npm ERR! npm v2.11.2
        ! npm ERR!
        ! Exit status 1npm
        ! ERR! npm
        ! ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.npm ERR! This is most likely a problem with the mdns package,
        ! npm ERR! Tell the author that this fails on your system:
        ! npm ERR! You can get their info via:
        ! npm ERR! npm owner ls mdnsnpm ERR! There is likely additional logging output above.
        ! ERROR: host.bananapi Cannot install iobroker.homekit: 1
        • L
          L
          lars
          #140
          Bei mir lief die Version 0.1.1 ganz ordentlich. Hab heute das Update auf 0.1.2 gemacht, seitdem habe ich in EVE keine Geräte mehr.
          Habe bisher die Instanz und den Adapter deinstalliert, den homekit Ordner unter iobroker-data entfernt. Die Neuinstallation lief ohne Probleme durch, der Adapter startet auch, es werden auch Änderungen meiner homematic Geräte im homekit log angezeigt.
          Eve habe ich auch schon mehrfach neuinstalliert und neu eingerichtet, die Brigde ist leider das einzige Gerät was ich sehe.
          Hat vielleicht jemand eine Idee?
          Das Ganze läuft auf einem Raspberry mit Jessie…
          Lars
          Hier noch ein kurzer Auszug des LOGs.
          Scheint soweit alles i.O.
          ! homekit-0 2016-02-25 08:04:54 debug 3. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
          ! homekit-0 2016-02-25 08:04:54 debug 2. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
          ! homekit-0 2016-02-25 08:04:54 debug 1. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
          ! homekit-0 2016-02-25 08:04:54 debug NEWVALUE: 57
          ! homekit-0 2016-02-25 08:04:54 debug OLDVALUE: 0
          ! homekit-0 2016-02-25 08:04:54 debug VALUE: 57 id = hm-rpc.0.JEQ0089188.1.HUMIDITY
          ! homekit-0 2016-02-25 08:04:53 debug 3. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
          ! homekit-0 2016-02-25 08:04:53 debug 2. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
          ! homekit-0 2016-02-25 08:04:53 debug 1. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
          ! homekit-0 2016-02-25 08:04:53 debug NEWVALUE: 20.6
          ! homekit-0 2016-02-25 08:04:53 debug OLDVALUE: 0
          ! homekit-0 2016-02-25 08:04:53 debug VALUE: 20.6 id = hm-rpc.0.JEQ0089188.1.TEMPERATURE
          • S
            S
            steinwedel
            #141
            Leider bekomme ich HomeKit immer noch nicht zum Laufen. Die Installation des Adapters verläuft ohne Fehler. Wenn ich dannmit der App Eve zugreifen möchte, kommt nach Eingabe der Pin die Fehlermeldung: "Hinzufügen fehlgeschlagen. Verbindung mit dem Zubehör nicht möglich." Im Log tauchen bei der Einstellung Info keine Einträge. Was läuft falsch?
            • R
              R
              ramonh2712
              #142
              ich kann den Homekit Adapter einfach nicht installieren! 😢
              iobroker	2016-02-26 11:26:35	info	exit 25
              iobroker	2016-02-26 11:26:35	error	host.raspberrypi Cannot install iobroker.homekit: 1
              iobroker	2016-02-26 11:26:35	info	npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
              iobroker	2016-02-26 11:26:33	info	npm owner ls mdnsnpm ERR! There is likely additional logging output above.
              iobroker	2016-02-26 11:26:33	info	ERR!
              iobroker	2016-02-26 11:26:33	info	npm ERR! You can get their info via:
              iobroker	2016-02-26 11:26:33	info	npm ERR! node-gyp rebuild
              iobroker	2016-02-26 11:26:33	info	not with npm itself.npm ERR! Tell the author that this fails on your system:
              iobroker	2016-02-26 11:26:33	info	npm ERR! This is most likely a problem with the mdns package,
              iobroker	2016-02-26 11:26:33	info	npm ERR! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
              iobroker	2016-02-26 11:26:33	info	npm ERR! Exit status 1
              iobroker	2016-02-26 11:26:33	info	npm ERR! mdns@2.2.11 install: `node-gyp rebuild`
              iobroker	2016-02-26 11:26:33	info	npm ERR! code ELIFECYCLE
              iobroker	2016-02-26 11:26:33	info	npm ERR! node v0.12.6npm ERR! npm v2.11.2
              iobroker	2016-02-26 11:25:50	info	gyp ERR! not ok
              iobroker	2016-02-26 11:25:50	info	gyp ERR! node -v v0.12.6gyp ERR! node-gyp -v v2.0.1
              iobroker	2016-02-26 11:25:50	info	gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/
              iobroker	2016-02-26 11:25:50	info	ERR! System Linux 4.1.13-v7+
              iobroker	2016-02-26 11:25:50	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1074:12)gyp
              iobroker	2016-02-26 11:25:50	info	ERR! stack at ChildProcess.emit (events.js:110:17)
              iobroker	2016-02-26 11:25:50	info	gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:269:23)
              iobroker	2016-02-26 11:25:50	info	ERR! stack Error: `make` failed with exit code: 2
              iobroker	2016-02-26 11:25:50	info	build error
              iobroker	2016-02-26 11:25:50	info	make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
              iobroker	2016-02-26 11:25:48	info	compilation terminated.
              iobroker	2016-02-26 11:25:48	info	^
              iobroker	2016-02-26 11:25:48	info	#include
              iobroker	2016-02-26 11:25:48	info	In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
              iobroker	2016-02-26 11:24:44	info	npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call)
              iobroker	2016-02-26 11:24:41	info	add homekit
              Es scheint ein Problem mit dem kompilieren zu geben. Allerdings komm ich nicht weiter.
              Kennt jemand diesen Fehler???
              • fischi87F
                fischi87F
                fischi87
                #143
                servus,
                also installiert ist alles und laut log läuft der homefit adapter auch aber meine app "eve" findet einfach nicht den brige Biobroker. gibt es dazu schon eine Lösung?
                Mit freundlichen Grüßen
                • S
                  S
                  steinwedel
                  #144
                  So nachdem ich ein downgrade auf node.js 4.2.6 gemacht habe gibt es auch Einträge im log.
                  host-home	2016-03-01 07:39:45	info	Restart adapter system.adapter.homekit.0 because enabled
                  host-home	2016-03-01 07:39:45	error	instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                  homekit-0	2016-03-01 07:39:45	debug	requesting all objects
                  homekit-0	2016-03-01 07:39:45	debug	requesting all states
                  homekit-0	2016-03-01 07:39:45	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.homekit
                  homekit-0	2016-03-01 07:39:44	debug	statesDB connected
                  homekit-0	2016-03-01 07:39:44	debug	objectDB connected
                  Error:	2016-03-01 07:39:44	error	at Module.load (module.js:344:32)
                  Error:	2016-03-01 07:39:44	error	at Object.Module._extensions..js (module.js:417:10)
                  Error:	2016-03-01 07:39:44	error	at Module._compile (module.js:410:26)
                  Error:	2016-03-01 07:39:44	error	at Object. (/opt/iobroker/node_modules/bignum/index.js:4:14)
                  Error:	2016-03-01 07:39:44	error	at new require (internal/module.js:12:17)
                  Error:	2016-03-01 07:39:44	error	at Module.require (module.js:354:17)
                  Error:	2016-03-01 07:39:44	error	at Function.Module._load (module.js:301:12)
                  Error:	2016-03-01 07:39:44	error	at Object.Module._extensions..node (module.js:435:18)
                  Error:	2016-03-01 07:39:44	error	at Error (native)
                  Error:	2016-03-01 07:39:44	error	Module version mismatch. Expected 46, got 47.
                  uncaught	2016-03-01 07:39:44	error	exception: Module version mismatch. Expected 46, got 47.
                  host-home	2016-03-01 07:39:44	info	instance system.adapter.homekit.0 started with pid 24660
                  Kann jemand etwas damit anfangen? Deinstallieren und neu Installieren des Adapters bringen keine Änderung.
                  • C
                    C
                    chka
                    #145
                    habe leider auch den Fehler "Hinzufügen fehlgeschlagen. Verbindung mit dem Zubehör nicht möglich."
                    INTEL NUC BOXNUC6I3SYH i3-6100U - Proxmox
                    Speicher: Transcend MTS800 M.2 SSD 128GB SATA III, MLC
                    RAM: 40Gig Crucial 8GB DDR4 CT2K8G4SFS824A + 32GB DDR4CT32G4SFD8266
                    • M
                      M
                      mimquadrat
                      #146
                      @fischi87:
                      servus,
                      Mit freundlichen Grüßen `
                      same here
                      • C
                        C
                        chaos99
                        #147
                        ich kann mich einmal mit EVE und Homekit verbinden , er empfängt die ganzen Geräte, aberer Updatet die Werte nicht mehr und Eve sagt nur das es keine Verbindung gibt zu Homekit, schmeiß ich IoBroker Homekit von eve runter , findet er danach diese nicht mehr beim versuch diese neu hinzuzufügen,
                        edit: und im Log
                        host-cubietruck 2016-03-05 13:20:09 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
                        TypeError: 2016-03-05 13:20:08 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        TypeError: 2016-03-05 13:20:08 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                        TypeError: 2016-03-05 13:20:08 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                        TypeError: 2016-03-05 13:20:08 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                        TypeError: 2016-03-05 13:20:08 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                        TypeError: 2016-03-05 13:20:08 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                        TypeError: 2016-03-05 13:20:08 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
                        TypeError: 2016-03-05 13:20:08 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
                        TypeError: 2016-03-05 13:20:08 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:312:69)
                        TypeError: 2016-03-05 13:20:08 error at Object.createAccessory_Thermostat [as Thermostat] (/opt/iobroker/node_modules/iobroker.homekit/main.js:631:47)
                        TypeError: 2016-03-05 13:20:08 error Cannot read property 'CurrentTemperature' of undefined
                        uncaught 2016-03-05 13:20:08 error exception: Cannot read property 'CurrentTemperature' of undefined
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Thermostat hm-rpc.0.LEQ0846063.4.ACTUAL_TEMPERATURE
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048896.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048898.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048722.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048624.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1483238.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215360.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215309.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215281.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1071633.1.HUMIDITY
                        homekit-0 2016-03-05 13:20:08 debug Accessory: Humidity Object: CurrentRelativeHumidity
                        homekit-0 2016-03-05 13:20:08 info hap-nodejs starting…
                        homekit-0 2016-03-05 13:20:08 debug received all objects
                        • V
                          V
                          versteckt
                          #148
                          Hallo, aufgrund von Projektstress im Büro und Vereinsstress und privat auch noch verdammt viel um die Ohren,
                          war es mir leider überhaupt nicht möglich, irgendwas zu lesen, schreiben, etc.
                          Werde heute und morgen die Fehler analysieren.
                          Ich gehe mal davon aus, das ihr die letzte Version (0.1.2) verwendet.
                          LG Christian
                          • V
                            V
                            versteckt
                            #149
                            @lars:
                            Wenn du mit Debug startest, müssten ja solch ähnliche Logeinträge kommen:
                            2016-03-05 14:03:44.145  - debug: homekit.0 requesting all states
                            2016-03-05 14:03:44.146  - debug: homekit.0 requesting all objects
                            2016-03-05 14:03:44.143  - info: homekit.0 starting. Version 0.1.2 in /Users/christian/DEVELOPMENT/node_modules/iobroker.homekit
                            2016-03-05 14:03:44.445  - debug: homekit.0 received all states
                            2016-03-05 14:03:44.655  - debug: homekit.0 received all objects
                            2016-03-05 14:03:44.656  - info: homekit.0 hap-nodejs starting...
                            2016-03-05 14:03:44.670  - debug: homekit.0 Accessory: Switch Object: State
                            2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: CurrentTemperature
                            2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: TargetTemperature
                            2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: State
                            2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Thermostat Object: CurrentRelativeHumidity
                            2016-03-05 14:03:44.671  - debug: homekit.0 Accessory: Temperature Object: CurrentTemperature
                            2016-03-05 14:03:44.672  - debug: homekit.0 Accessory: Humidity Object: CurrentRelativeHumidity
                            2016-03-05 14:03:44.674  - debug: homekit.0 > iobroker subscribe SecuritySystem zwave.0.NODE13.ALARM
                            Kannst du deine mal posten?
                            • V
                              V
                              versteckt
                              #150
                              @All:
                              Bez. kompilieren:
                              Bitte lt. https://github.com/KhaosT/HAP-NodeJS/issues/3
                              zuerst folgendes ausführen:
                              sudo apt-get install libavahi-compat-libdnssd-dev
                              • V
                                V
                                versteckt
                                #151
                                @chaos99:
                                Welche Infrastruktur hast du im Einsatz?
                                Ich hatte auch immer wieder Sorgen mit meinem Netzwerk.
                                Bzw. welche hap-nodejs ist bei dir installiert?
                                Findest du mit
                                grep -i version /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/package.json
                                heraus.
                                Ich hatte bei mir auch schon das Problem, das die Version < 0.2.4 war.
                                LG Christian
                                • C
                                  C
                                  chaos99
                                  #152
                                  "version": "0.2.4",
                                  ist was ich bekomme,
                                  mein cubi mit iobroker hängt am Netzwerk wie meine HUE bridge , die erreiche ich auch ohne Probleme mit EVE, nur iobroker-homekit spinnt rum, am Netztwerk sollte es nicht liegen ich erreiche übers Handy ohne Probleme VIS und den cubi über Putty auf dem Tel. Die HUE bridge hab ich auch schon mal vom Netzwerk genommen um den fehler auszuschließen .
                                  • V
                                    V
                                    versteckt
                                    #153
                                    Ok, nicht missverstehen.
                                    Der MDNS / Bonjour Dienst unter Linux ist bescheiden.
                                    Der reagiert schon mal empfindlich auf WLAN / LAN.
                                    HAP-Nodejs nutzt ja diesen Dienst.
                                    Ich lese mir deine Meldungen mal in Ruhe durch und gebe dir dann Bescheid.
                                    • C
                                      C
                                      chaos99
                                      #154
                                      Nein das nehme ich auch nicht böse, bin ja dankbar für eure Arbeit und für jede Idee offen, ich hab nachdem ich eve noch mal zurückgesetzt habe , iPhone Homekit gelöscht , dann noch mal von vorne begonnen und dann findet Eve die iobroker-homekit nicht, (IO-homekit neu installiert , Eve ebenso) geholfen hat wo ich dann mal die MAC-Adresse vom iobroker-homekit geändert habe….
                                      das Hauptproblem liegt aber : das wenn ich Eve und IO-homekit gekoppelt habe alle Aktoren gezeigt werden , auch mit aktuellen Daten(Temperaturen zb.) dann aber keine Aktualisierung mehr geschieht, direkt 1 min später aktualisiert Eve nicht mehr mit IO-Homekit
                                      • V
                                        V
                                        versteckt
                                        #155
                                        Ok, das Problem wurde bei mir durch die 0.2.4 von hap-Models gelöst.
                                        Das mit dem löschen und neu installieren ist so eine Sache, dein Lösungsweg ist aber voll ok.
                                        Welches Betriebssystem setzt du ein bzw. welche node Version?
                                        Gesendet von meinem iPhone mit Tapatalk
                                        • V
                                          V
                                          versteckt
                                          #156
                                          @chaos99:
                                          Siehst du beim starten von homekit (mit Debug) solch ähnliche Einträge?
                                          debug: homekit.0 < hap JEQ0550466 get CurrentTemperature for hm-rpc.1.JEQ0550466.1.TEMPERATURE
                                          Den Fehler bez. der Exception hab ich schon gefunden, da kommt demnächst eine Aktualisierung.
                                          84.2k
