Apple Homekit Siri
Bez. Windows:
On Windows you are going to need Apples "Bonjour SDK for Windows". You can download it either from Apple (registration required) or various unofficial sources. Take your pick. After installing the SDK restart your shell or command prompt and make sure the
BONJOUR_SDK_HOMEenvironment variable is set. You'll also need a compiler. Microsoft Visual Studio Express will do. On Windows node >=0.7.9 is required....
So die Aussage von mdns. Ev. hilfts
ich versuche das Homekit zu installieren.
Doch leider bricht es immer ab.
Wodran kann das liegen?
Hier mal die Fehlermeldungen.
! $ ./iobroker add homekit
! npm install iobroker.homekit –production --prefix "/opt/iobroker" (System call)
! In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
! #include <dns_sd.h>^
! compilation terminated.
! make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
! gyp
! ERR! build error
! gyp
! ERR!
! stack
! Error:makefailed with exit code: 2gyp
! ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:270:23)gyp
! ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack
! at ChildProcess.emit (events.js:172:7)gyp
! ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)gyp ERR! System Linux 4.1.15-v7+
! gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
! gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
! gyp ERR! node -v v4.2.5
! gyp ERR! node-gyp -v v3.0.3
! gyp ERR! not ok
! npm
! ERR! Linux 4.1.15-v7+
! npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"
! npm ERR! node v4.2.5npm ERR! npm v2.14.12
! npm ERR! code ELIFECYCLE
! npm ERR! mdns@2.2.11 install:node-gyp rebuild
! npm ERR! Exit status 1
! npm ERR! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.
! npm ERR! This is most likely a problem with the mdns package,
! npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
! npm ERR! node-gyp rebuild
! npm
! ERR!
! You can get their info via:npm ERR! npm owner ls mdns
! npm ERR! There is likely additional logging output above.
! npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log
! ERROR: host.iobroker Cannot install iobroker.homekit: 1
! ERROR: process exited with code 25</dns_sd.h> -
Ich habe erfolgreich den Adapter homekit installieren können. Auch das Hinzufügen in der App verlief problemlos.
Nun werden mir meine Geräte unter "ioBroker Bridge" angezeigt.
Wenn ich nun allerdings ein Gerät auswähle, welches nicht den Standardnamen like HM-XX-XX-… sondern einen in der CCU2 vergebenen Alternativnamen besitzt, z.B. "Wohnzimmerlicht", dann stürzt der Adapter ab. Folgendes zeigt das Log:
host-zeebomatic 2016-02-07 10:47:38 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception) TypeError: 2016-02-07 10:47:38 error at IncomingMessage.emit (events.js:104:17) TypeError: 2016-02-07 10:47:38 error at HAPServer. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:188:39) TypeError: 2016-02-07 10:47:38 error at HAPServer._handleCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10) TypeError: 2016-02-07 10:47:38 error at HAPServer.emit (events.js:118:17) TypeError: 2016-02-07 10:47:38 error at Bridge.Accessory._handleGetCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:522:8) TypeError: 2016-02-07 10:47:38 error at Array.forEach (native) TypeError: 2016-02-07 10:47:38 error at Bridge. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:555:20) TypeError: 2016-02-07 10:47:38 error at Characteristic.getValue (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:119:10) TypeError: 2016-02-07 10:47:38 error at emit (events.js:110:17) TypeError: 2016-02-07 10:47:38 error at null. (/opt/iobroker/node_modules/iobroker.homekit/main.js:591:37) TypeError: 2016-02-07 10:47:38 error Cannot read property 'val' of undefined uncaught 2016-02-07 10:47:38 error exception: Cannot read property 'val' of undefined ! -
! gyp
! ERR! build error
! gyp
! ERR!
! stack
! gyp ERR! not ok
! npm
! npm
! ERR!
! ERROR: process exited with code 25</dns_sd.h> `Bei mir das gleiche :(
Wo liegt der Fehler?
Lg
Manuel
Bekommen auf meinem BananaPi ebenfalls folgende Fehler während der Installation des Adapters:
! In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
! gyp
! ERR! build error
! gyp ERR! stack Error:makefailed with exit code: 2
! gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:269:23)gyp ERR! stack at ChildProcess.emit (events.js:110:17)
! gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1074:12)
! gyp ERR! System Linux 3.4.110-sun7i
! gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/mdns
! gyp ERR! node -v v0.12.6
! gyp
! ERR! node-gyp -v v2.0.1gyp ERR! not ok
! npm
! ERR! Linux 3.4.110-sun7i
! npm ERR!
! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.homekit" "–production" "--prefix" "/opt/iobroker"
! npm ERR! node v0.12.6npm ERR! npm v2.11.2
! npm ERR!
! Exit status 1npm
! ERR! npm
! ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'.npm ERR! This is most likely a problem with the mdns package,
! npm ERR! Tell the author that this fails on your system:
! npm ERR! You can get their info via:
! npm ERR! npm owner ls mdnsnpm ERR! There is likely additional logging output above.
! ERROR: host.bananapi Cannot install iobroker.homekit: 1
! ERROR: process exited with code 25 -
Bei mir lief die Version 0.1.1 ganz ordentlich. Hab heute das Update auf 0.1.2 gemacht, seitdem habe ich in EVE keine Geräte mehr.
Habe bisher die Instanz und den Adapter deinstalliert, den homekit Ordner unter iobroker-data entfernt. Die Neuinstallation lief ohne Probleme durch, der Adapter startet auch, es werden auch Änderungen meiner homematic Geräte im homekit log angezeigt.
Eve habe ich auch schon mehrfach neuinstalliert und neu eingerichtet, die Brigde ist leider das einzige Gerät was ich sehe.
Hat vielleicht jemand eine Idee?
Das Ganze läuft auf einem Raspberry mit Jessie…
Lars
Hier noch ein kurzer Auszug des LOGs.
Scheint soweit alles i.O.
! homekit-0 2016-02-25 08:04:54 debug 3. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
! homekit-0 2016-02-25 08:04:54 debug 2. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
! homekit-0 2016-02-25 08:04:54 debug 1. Change state for hm-rpc.0.JEQ0089188.1.HUMIDITY to 57 ack = true
! homekit-0 2016-02-25 08:04:54 debug NEWVALUE: 57
! homekit-0 2016-02-25 08:04:54 debug OLDVALUE: 0
! homekit-0 2016-02-25 08:04:54 debug VALUE: 57 id = hm-rpc.0.JEQ0089188.1.HUMIDITY
! homekit-0 2016-02-25 08:04:53 debug 3. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
! homekit-0 2016-02-25 08:04:53 debug 2. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
! homekit-0 2016-02-25 08:04:53 debug 1. Change state for hm-rpc.0.JEQ0089188.1.TEMPERATURE to 20.6 ack = true
! homekit-0 2016-02-25 08:04:53 debug NEWVALUE: 20.6
! homekit-0 2016-02-25 08:04:53 debug OLDVALUE: 0
! homekit-0 2016-02-25 08:04:53 debug VALUE: 20.6 id = hm-rpc.0.JEQ0089188.1.TEMPERATUREGesendet von iPhone mit Tapatalk
Leider bekomme ich HomeKit immer noch nicht zum Laufen. Die Installation des Adapters verläuft ohne Fehler. Wenn ich dannmit der App Eve zugreifen möchte, kommt nach Eingabe der Pin die Fehlermeldung: "Hinzufügen fehlgeschlagen. Verbindung mit dem Zubehör nicht möglich." Im Log tauchen bei der Einstellung Info keine Einträge. Was läuft falsch?
ich kann den Homekit Adapter einfach nicht installieren!
iobroker 2016-02-26 11:26:35 info exit 25 iobroker 2016-02-26 11:26:35 error host.raspberrypi Cannot install iobroker.homekit: 1 iobroker 2016-02-26 11:26:35 info npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log iobroker 2016-02-26 11:26:35 info iobroker 2016-02-26 11:26:33 info npm owner ls mdnsnpm ERR! There is likely additional logging output above. iobroker 2016-02-26 11:26:33 info ERR! iobroker 2016-02-26 11:26:33 info npm iobroker 2016-02-26 11:26:33 info npm ERR! You can get their info via: iobroker 2016-02-26 11:26:33 info npm ERR! node-gyp rebuild iobroker 2016-02-26 11:26:33 info not with npm itself.npm ERR! Tell the author that this fails on your system: iobroker 2016-02-26 11:26:33 info npm ERR! iobroker 2016-02-26 11:26:33 info npm ERR! This is most likely a problem with the mdns package, iobroker 2016-02-26 11:26:33 info npm ERR! npm ERR! Failed at the mdns@2.2.11 install script 'node-gyp rebuild'. iobroker 2016-02-26 11:26:33 info npm ERR! Exit status 1 iobroker 2016-02-26 11:26:33 info npm ERR! mdns@2.2.11 install: `node-gyp rebuild` iobroker 2016-02-26 11:26:33 info npm ERR! code ELIFECYCLE iobroker 2016-02-26 11:26:33 info npm ERR! node v0.12.6npm ERR! npm v2.11.2 iobroker 2016-02-26 11:26:33 info npm iobroker 2016-02-26 11:25:50 info gyp ERR! not ok iobroker 2016-02-26 11:25:50 info gyp ERR! node -v v0.12.6gyp ERR! node-gyp -v v2.0.1 iobroker 2016-02-26 11:25:50 info gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/node_modules/ iobroker 2016-02-26 11:25:50 info ERR! System Linux 4.1.13-v7+ iobroker 2016-02-26 11:25:50 info gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:1074:12)gyp iobroker 2016-02-26 11:25:50 info ERR! stack at ChildProcess.emit (events.js:110:17) iobroker 2016-02-26 11:25:50 info gyp iobroker 2016-02-26 11:25:50 info gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:269:23) iobroker 2016-02-26 11:25:50 info ERR! stack Error: `make` failed with exit code: 2 iobroker 2016-02-26 11:25:50 info gyp iobroker 2016-02-26 11:25:50 info iobroker 2016-02-26 11:25:50 info build error iobroker 2016-02-26 11:25:50 info ERR! iobroker 2016-02-26 11:25:50 info iobroker 2016-02-26 11:25:50 info gyp iobroker 2016-02-26 11:25:50 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1 iobroker 2016-02-26 11:25:48 info compilation terminated. iobroker 2016-02-26 11:25:48 info ^ iobroker 2016-02-26 11:25:48 info #include iobroker 2016-02-26 11:25:48 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory iobroker 2016-02-26 11:24:44 info npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call) iobroker 2016-02-26 11:24:41 info add homekitEs scheint ein Problem mit dem kompilieren zu geben. Allerdings komm ich nicht weiter.
Kennt jemand diesen Fehler???
servus,
also installiert ist alles und laut log läuft der homefit adapter auch aber meine app "eve" findet einfach nicht den brige Biobroker. gibt es dazu schon eine Lösung?
Mit freundlichen Grüßen
1121_2019-02-05_20-46-05.jpg -
So nachdem ich ein downgrade auf node.js 4.2.6 gemacht habe gibt es auch Einträge im log.
host-home 2016-03-01 07:39:45 info Restart adapter system.adapter.homekit.0 because enabled host-home 2016-03-01 07:39:45 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception) homekit-0 2016-03-01 07:39:45 debug requesting all objects homekit-0 2016-03-01 07:39:45 debug requesting all states homekit-0 2016-03-01 07:39:45 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.homekit homekit-0 2016-03-01 07:39:44 debug statesDB connected homekit-0 2016-03-01 07:39:44 debug objectDB connected Error: 2016-03-01 07:39:44 error at Module.load (module.js:344:32) Error: 2016-03-01 07:39:44 error at Object.Module._extensions..js (module.js:417:10) Error: 2016-03-01 07:39:44 error at Module._compile (module.js:410:26) Error: 2016-03-01 07:39:44 error at Object. (/opt/iobroker/node_modules/bignum/index.js:4:14) Error: 2016-03-01 07:39:44 error at new require (internal/module.js:12:17) Error: 2016-03-01 07:39:44 error at Module.require (module.js:354:17) Error: 2016-03-01 07:39:44 error at Function.Module._load (module.js:301:12) Error: 2016-03-01 07:39:44 error at Module.load (module.js:344:32) Error: 2016-03-01 07:39:44 error at Object.Module._extensions..node (module.js:435:18) Error: 2016-03-01 07:39:44 error at Error (native) Error: 2016-03-01 07:39:44 error Module version mismatch. Expected 46, got 47. uncaught 2016-03-01 07:39:44 error exception: Module version mismatch. Expected 46, got 47. host-home 2016-03-01 07:39:44 info instance system.adapter.homekit.0 started with pid 24660Kann jemand etwas damit anfangen? Deinstallieren und neu Installieren des Adapters bringen keine Änderung.
servus,
Mit freundlichen Grüßen `
same here
ich kann mich einmal mit EVE und Homekit verbinden , er empfängt die ganzen Geräte, aberer Updatet die Werte nicht mehr und Eve sagt nur das es keine Verbindung gibt zu Homekit, schmeiß ich IoBroker Homekit von eve runter , findet er danach diese nicht mehr beim versuch diese neu hinzuzufügen,
edit: und im Log
host-cubietruck 2016-03-05 13:20:09 error instance system.adapter.homekit.0 terminated with code 6 (uncaught exception)
TypeError: 2016-03-05 13:20:08 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
TypeError: 2016-03-05 13:20:08 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
TypeError: 2016-03-05 13:20:08 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
TypeError: 2016-03-05 13:20:08 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
TypeError: 2016-03-05 13:20:08 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
TypeError: 2016-03-05 13:20:08 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
TypeError: 2016-03-05 13:20:08 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:200:60)
TypeError: 2016-03-05 13:20:08 error at /opt/iobroker/node_modules/iobroker.homekit/main.js:18:13
TypeError: 2016-03-05 13:20:08 error at main (/opt/iobroker/node_modules/iobroker.homekit/main.js:312:69)
TypeError: 2016-03-05 13:20:08 error at Object.createAccessory_Thermostat [as Thermostat] (/opt/iobroker/node_modules/iobroker.homekit/main.js:631:47)
TypeError: 2016-03-05 13:20:08 error Cannot read property 'CurrentTemperature' of undefined
uncaught 2016-03-05 13:20:08 error exception: Cannot read property 'CurrentTemperature' of undefined
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Thermostat hm-rpc.0.LEQ0846063.4.ACTUAL_TEMPERATURE
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048896.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048898.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048722.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.MEQ0048624.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1483238.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215360.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215309.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1215281.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug > iobroker subscribe Humidity hm-rpc.0.LEQ1071633.1.HUMIDITY
homekit-0 2016-03-05 13:20:08 debug Accessory: Humidity Object: CurrentRelativeHumidity
homekit-0 2016-03-05 13:20:08 info hap-nodejs starting…
homekit-0 2016-03-05 13:20:08 debug received all objects
Hallo, aufgrund von Projektstress im Büro und Vereinsstress und privat auch noch verdammt viel um die Ohren,
war es mir leider überhaupt nicht möglich, irgendwas zu lesen, schreiben, etc.
Werde heute und morgen die Fehler analysieren.
Ich gehe mal davon aus, das ihr die letzte Version (0.1.2) verwendet.
LG Christian
Wenn du mit Debug startest, müssten ja solch ähnliche Logeinträge kommen:
2016-03-05 14:03:44.145 - debug: homekit.0 requesting all states 2016-03-05 14:03:44.146 - debug: homekit.0 requesting all objects 2016-03-05 14:03:44.143 - info: homekit.0 starting. Version 0.1.2 in /Users/christian/DEVELOPMENT/node_modules/iobroker.homekit 2016-03-05 14:03:44.445 - debug: homekit.0 received all states 2016-03-05 14:03:44.655 - debug: homekit.0 received all objects 2016-03-05 14:03:44.656 - info: homekit.0 hap-nodejs starting... 2016-03-05 14:03:44.670 - debug: homekit.0 Accessory: Switch Object: State 2016-03-05 14:03:44.671 - debug: homekit.0 Accessory: Thermostat Object: CurrentTemperature 2016-03-05 14:03:44.671 - debug: homekit.0 Accessory: Thermostat Object: TargetTemperature 2016-03-05 14:03:44.671 - debug: homekit.0 Accessory: Thermostat Object: State 2016-03-05 14:03:44.671 - debug: homekit.0 Accessory: Thermostat Object: CurrentRelativeHumidity 2016-03-05 14:03:44.671 - debug: homekit.0 Accessory: Temperature Object: CurrentTemperature 2016-03-05 14:03:44.672 - debug: homekit.0 Accessory: Humidity Object: CurrentRelativeHumidity 2016-03-05 14:03:44.674 - debug: homekit.0 > iobroker subscribe SecuritySystem zwave.0.NODE13.ALARMKannst du deine mal posten?
@All:
Bez. kompilieren:
Bitte lt. https://github.com/KhaosT/HAP-NodeJS/issues/3
zuerst folgendes ausführen:
sudo apt-get install libavahi-compat-libdnssd-dev -
Welche Infrastruktur hast du im Einsatz?
Ich hatte auch immer wieder Sorgen mit meinem Netzwerk.
Bzw. welche hap-nodejs ist bei dir installiert?
Findest du mit
grep -i version /opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/package.jsonheraus.
Ich hatte bei mir auch schon das Problem, das die Version < 0.2.4 war.
LG Christian
