  4. [Projekt] MDCSS v2: Material Design CSS Version 2
    6.6k
material uivismaterial css
717 Beiträge 74 Kommentatoren 247.7k Aufrufe 77 Beobachtet
  • Dominik F.D Dominik F.
    @Uhula
    ich habe heute auf die neueste Version umgestellt und habe bei einem Widget ein Problem.
    Das Widget soll nur angezeigt werden, wenn eine Scene bzw. Datenpunkt True ist. Vorher funktionierte es, jetzt wird das Widget dauerhaft angezeigt. Hast du eine Idee woran es liegen könnte?
    Hier das Widget:
    [{"tpl":"tplValueListHtml8","data":{"oid":"scene.Chillen","visibility-cond":"==","visibility-val":"true","count":"1","value0":"true","value1":"false","style1":"background-color: green","style0":"background-color: green","value2":"","style2":"background-color: red","test_list":"1","visibility-groups-action":"hide","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-oid":"scene.Chillen","g_signals":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"class":"mdui-card mdui-green-glow mdui-center mdui-label","g_css_font_text":false,"g_css_background":false,"g_css_border":false,"g_css_shadow_padding":false,"g_gestures":false},"style":{"left":"calc(75% - 84px)","top":"80px","width":"168px","height":"62px","z-index":"20","overflow-x":""},"widgetSet":"basic"}]
    UhulaU Offline
    UhulaU Offline
    Uhula
    @Dominik-F Das die "visibility" nicht funktioniert, liegt an der Zuweisung vom "mdui-center". Denn sowohl das Verstecken als auch das Zentrieren erfolgt über die display-Eigenschaft im CSS. Letzteres übersteuert das Verstecken. Wenn du "mdui-center" nicht brauchst, entferne es mal. Alternativ, kannst du aus der CSS Datei auch drei Zeilen löschen, dann geht es auch. Ich teste mal, ob ich die generell entfernen kann, denke schon.
    /* zentrieren */
    .xmdui-center-v,
    .mdui-center-v .vis-widget-body,
    .mdui-center-v .vis-widget-body *  {
      display:flex !important;
      align-items: center;
    .xmdui-center-h,
    .mdui-center-h .vis-widget-body,
    .mdui-center-h .vis-widget-body *  {
      justify-content: center;
    .xmdui-center,
    .mdui-center .vis-widget-body,
    .mdui-center .vis-widget-body * {
    @der-eine Das mit dem share-Button ist mir schon klar. Ich weiß nur nicht, wie ich Grafana mitteile, dass ich eine Tendenz angezeigt haben möchte.
    @foxriver76 Wenn du mdui-cols-4-toc-16 angibst UND zusätzlich eine width, dann wird versuch der width innerhalb der Grenzen von 4-16 (x80) zu entsprechen. Ist z.B. sinnvoll, wenn man genau zwei cards nebeneinander ahaben möchten und ihnen die width=50% zuweist. Generell sollte die width dann aber keine Zuweisung haben.
    Da es bei den Angaben mdui-cols-N Angaben ohne bis-Angabe zu Verständnisproblemen kam, da diese +10% Größenänderung erlaubten, habe ich in der v2.1 diese 10% entfernt. Nun ist mdui-cols-4 = 320 Px = mdui-cols-4-toc-4
    @Pittini Kannst du mir dein Projekt anonymisiert zukommen lassen, das macht es leichter. Mail-Addy bekommst du per PN/Chat. Die "Material Design Widgets" aus 2018 hast du nicht als Adapter installiert - die stören nämlich, da dort MD CSS v1.8 drin ist.
    Der config-Dialog bekommt seinen Titel und das X dadurch, dass er als jqui-Dialog angezeigt wird.
    NavButtons und Secondary Color: Theoretisch machbar, aber problematisch, wenn man z.B. die tnav im dark-Theme, den content aber im light-Theme hat.
    @SMARTY-ML Automatische View-Wechsel werden nicht durch das MD CSS ausgelöst. Das muss andere Ursachen haben.
    Uhula - Leise und Weise
    Ex: ioBroker on Gigabyte NUC Proxmox
    • P Offline
      Pittini
      schrieb am zuletzt editiert von Pittini
      Ein Problem welches mal auftaucht, mal nicht, ist folgendes:
      Seitenrefresh bringt keine Änderung. Irgendwann mach ich die Seite neu auf und es wird wieder angezeigt. Dann wieder mal nicht, ka was da bockt. Die Config Dialoge sind direkt aus der MD_Demo in ein MD_Simple kopiert (und angepasst). Den Effekt hab ich btw. bei beiden Projekten an denen ich grad arbeite.
      • UhulaU Uhula
        /* zentrieren */
        .xmdui-center-v,
        .xmdui-center-h,
        .xmdui-center,
        Dominik F.D Offline
        Dominik F.D Offline
        Dominik F.
        @Uhula
        Ja genau das wars. Da ich das mdui-center dort brauchte hab ich es nun anders gelöst, mit 2 Buttons übereinander und der Sichtbarkeit. Möchte ungern was in der CSS Datei löschen da ich dann mit dem nächsten Update von dir wieder das gleiche Problem haben könnte.
        UhulaU 1 Antwort Letzte Antwort
          @Uhula
          UhulaU Offline
          UhulaU Offline
          Uhula
          @Dominik-F Ich habe das in der CSS geändert, hat offensichtlich keine Nebeneffekte und funktioniert mit deinem Widget.
          • UhulaU Offline
            UhulaU Offline
            Uhula
            Kleines Update - in Bezug auf die Meldungen von @Dominik-F und @Pittini - danke.
            -> GitHub
            v2.1.1 23.02.2020
            CSS
            • mdui-center[-h|-v]: Benutzte die CSS "display: !important" Eigenschaft, was dazu führte, dass die vis-Visibility Funktion, die auch über "display" geht, nicht mehr funktionierte. "!important" entfernt.
            • weitere CSS-Variablen für die Farben (abar, ...) eingeführt
            • ui-dialog: Korrektur der Hintergrundfarbe
            vis-Editor
            script
            • Umbau des Setzens der Farben auf die neuen CSS-Variablen. Damit entfällt das (unsichere) anhängen von CSS-Anweisungen, welches manchmal fehl schlug, wenn die CSS Reihenfolge durch timing-Probleme nicht wie erwartet war.
            MD_Demo
            L 1 Antwort Letzte Antwort
            • foxriver76F Offline
              foxriver76F Offline
              foxriver76
              So perfekt, habe nun endlich meine produktive vis komplett umgezogen. Einziger offener Punkt ist noch die fehlende Farbanpassung im Filter mdui-timespan-XXX.
              Vielen Dank für die gute Umsetzung.
              Videotutorials & mehr
              • bilberryB Offline
                bilberryB Offline
                bilberry
                bin mit meinem Umzug auf die MD-Version 2.x auch so gut wie fertig. Zwei Probleme konnte ich bislang nicht lösen:
                • Widget wird nicht ausgeblendet (offenbar das gleiche Problem wie bei @Dominik-F, welches ja inzwischen von @Uhula gelöst zu sein scheint - hab mir aber inzwischen anderes beholfen und probiere es demnächst noch mal aus)
                • wenn ich ein Card mit Flott-Diagramm „minimiert“ (mdui-expand mdui-onload) starte, wird nach dem späteren manuellen Expandieren durch den Nutzer das Diagramm nicht angezeigt. Erst wenn man einen willkürlichen Zeitraum durch Klick auf ein mdui-timespan-Element wählt, wird das Diagramm geladen.
                  Wie könnte man das umgehen?
                  SMARTY.ML
                  ich wollte meine Rollos mit den Input aus "pageDemoInput" füttern.
                  Leider folgt nachfolgende Fehlermeldung:
                  • (949) Datatype for SHSW-25#6870BC#1.Shutter.Position differs from expected, ignore state change! Please write correct datatype (number)
                  Lässt sich das ohne ein lästiges Skript realisieren?
                  • S SMARTY.ML
                    Dominik F.D Offline
                    Dominik F.D Offline
                    Dominik F.
                    @Uhula
                    Ich nutze für meine Vis auch den MDW Adapter (Ja ich weiß, es kann zu Problemen führen) und habe bis auf ein Widget nun alles raus vom Adapter.
                    Ich versuche nun das Widget nachzubauen nur daran scheitere ich. Ich hab es mit den Balken versucht, jedoch bin ich noch ganz weit vom Orginal entfernt. Vielleicht kannst du mir ja Tipps geben wie ich den Balken einstellen muss damit es dem Orginal sehr ähnelt.
                    Im Widget wird die aktuelle Temperatur angezeigt und je nachdem wie Hoch die Temperatur ist ändert sich die Farbe und die Füllbreite. Wäre cool wenn man dort auch Outlined und Raised einstellen könnte beim Balken
                    Hier das Orginal:
                      @Uhula
                      Hier das Orginal:
                      UhulaU Offline
                      UhulaU Offline
                      Uhula
                      @Dominik-F Schau dir mal im MD_Demo die Bargraphs an, die können ihren Hintergrund wertabhängig einfärben. Für den Wert selbst musst du noch ein basic-String drüberlegen.
                      5250a204-d41a-4c7b-a305-ab14589d1dbb-image.png 319981d3-7b6c-4773-9aee-296b14bee285-image.png 9bad2c5f-237f-4fe5-a628-dde4fdd618d2-image.png
                      @SMARTY-ML Das wird ohne serverseitiges Script nicht gehen, da das input-Element wohl immer einen String im vis liefert, auch wenn der type=number ist. ALso nen string-State anlegen und via Serverscript und on-Event als Number in den eigentlichen State schreiben. Sorry, da kann ich nichts machen.
                      @foxriver76 Hast du den Auswahl-Widgets neben "mdui-timespan..." auch "mdui-menuitem" zugewiesen?
                      @bilberry flot/onload muss ich mir mal ansehen, muss dazu aber erst wieder flot einrichten (habe ich schon komplett durch Grafana ersetzt).
                        der-eine
                        @Uhula könntest Du das mit dem Basic-HTML, Script und iCal bitte nochmal erklären? Das wäre super! 👍
                        • UhulaU Uhula
                          foxriver76F Offline
                          foxriver76F Offline
                          foxriver76
                          @Uhula Ne, war nur mdui-timespan-1440 mdui-target-w00019 mdui-hide habe es nun um mdui-menuitem mdui-center erweitert, dann passt es, danke.
                          • P Offline
                            Pittini
                            @Uhula Danke für die neue Version, es sind jetzt tatsächlich alle alten Fehler weg. lnav und rnav haben jetzt korrekte Farbe, der Configdialog sieht aus wie er soll. Allerdings gibts nen neuen Fehler, die bnav wurde komplett weiss, die Buttons kann man aber "blind" bedienen.
                            Interessanter weiterer Effekt, schalte ich die Seite in Vollbild, wird die bnav von weiss zu gelb mit weisser Schrift.
                            Dieses Verhalten ist identisch bei einer frisch importierten MD_Demo.zip (hab ausschliesslich zum Vergleich den Vollbildbutton eingesetzt, sonst außer Farbeinstellung nix geändert.
                            Dominik F.D UhulaU 2 Antworten Letzte Antwort
                            • P Pittini
                              Dominik F.D Offline
                              Dominik F.D Offline
                              Dominik F.
                              @Pittini
                              könntest du mir vielleicht bei Grafana helfen? Ich bekomme zwar die Grafik angezeigt, muss jedoch immer einen Doppelklick oder Vollbild auswählen, damit die Grafik angezeigt wird. Auch klappen bei mir die Einstellungen für die Zeitspanne und so nicht einstellen. Kannst du mir erklären wie du das gemacht hast?
                              • P Pittini
                                UhulaU Offline
                                UhulaU Offline
                                Uhula
                                @Pittini Kleiner Fehler, leicht zu beheben, "background" statt "color":
                                .mdui-bnav {
                                background:var(--bnav-background) !important;
                                z-index:98;
                                border:none;
                                box-shadow:0px -2px 4px -1px rgba(0,0,0,0.45);
                                transition: left 0.25s ease;
                                @der-eine Ich habe noch nichts mit iCal erklärt - oder kann mich zumindest daran nicht erinnern. Worum geht es? Termine aus dem Kalender via Script in einen HTML-State als table zu setzen um ihn als mdui-table anzuzeigen?
                                Wenn ja, dann
                                • das Script Legt einen HTML-State unter javascript.X.ical.0.HTML an (X=Script-Instanz)
                                • es setzt ein on-Event auf den State ical.0.Data.Table
                                • wenn sich der Wert dort verändert, wird das Script ausgeführt und dieses bildet aus dem ical.0.Data.Table Inhalt dann den javascript.X.ical.0.HTML Inhalt
                                • der javascript.X.ical.0.HTML Inhalt kann als HTML Wert für eine mdui-table genutzt werden, Widget: "basic-string (unexcaped)"
                                var idCal = "ical.0";
                                var idCalTrigger   = idCal + ".data.trigger";
                                var idCalTable     = idCal + ".data.table";
                                var idCalHTML      = idCal + ".data.html";
                                var idCalHTMLtable = idCal + ".html";
                                createState(idCalHTMLtable, " ");
                                function iCalToHTMLTable() {
                                    var html     = "<table style='font-size:0.9em;'><thead><tr><th style='text-align:left;'>Zeit</th><th style='text-align:left;'>Text</th><th style='text-align:left;'>Kalendar</th></tr></thead><tbody>";
                                    var calTable = getState(idCalTable);
                                    var inst     = getObject("system.adapter."+idCal);
                                    var instopt  = inst.native;
                                    var calendar = {};
                                    for (var i = 0; i < calTable.val.length; i++) {
                                        var entry = calTable.val[i];
                                        if ( entry._calName != calendar.name ) {
                                            calendar = {};
                                            for (var c = 0; c < instopt.calendars.length; c++ ) {
                                                if (entry._calName == instopt.calendars[c].name ) {
                                                    calendar = instopt.calendars[c];
                                                    break;
                                        if (calendar.color !== "")
                                            html+="<tr style='background:transparent; background-image: linear-gradient("+calendar.color+","+calendar.color+"); background-size: 4px 90%; background-repeat: no-repeat;'>";
                                        else
                                            html+="<tr>";
                                        html+="<td style='font-size:1.1em;'>"+entry.date+"</td>"
                                        html+="<td>"+entry.event+"</td>"
                                        html+="<td>"+entry._calName+"</td>"
                                        html+="</tr>";
                                    html+="</body></table>";
                                    setState(idCalHTMLtable, html);
                                //dump( html );
                                on({id: idCalTable, change: "ne"}, function (obj) {
                                    iCalToHTMLTable();
                                iCalToHTMLTable();
                                P T 2 Antworten Letzte Antwort
                                • UhulaU Uhula
                                  .mdui-bnav {
                                  z-index:98;
                                  border:none;
                                  Wenn ja, dann
                                      var calendar = {};
                                              calendar = {};
                                                      break;
                                          else
                                              html+="<tr>";
                                          html+="</tr>";
                                  //dump( html );
                                      iCalToHTMLTable();
                                  iCalToHTMLTable();
                                  Pittini
                                  @Uhula sagte in [Projekt] Material Design CSS v2:
                                  Jap, das wars, jetzt läuft alles. Danke Dir.
                                  • R Offline
                                    reini
                                    ich verstehe den Umstieg von V1 auf V2 noch nicht ganz - einfach den Code von CSS und Skripte gegen die neuen Codezeilen ersetzen?
                                    • R reini
                                      sigi234S Online
                                      sigi234S Online
                                      @reini sagte in [Projekt] Material Design CSS v2:
                                      Jupp
                                        @Pittini
                                        der-eine
                                        schrieb am zuletzt editiert von der-eine
                                        #66
                                        @Uhula super genau das hab ich gemeint! 👍 Du hast im ersten Posting schon mal ein Skript zur verfügung gestellt. Dieses hat bei mir leider nicht funktioniert aber diese schon. Das meinte ich mit "erklärt". Sollte die Farbe des Kalenders bis ans Ende des Borders gehen?
                                        @Dominik-F ich bin zwar nicht Pittini aber evtl kann ich Dir helfen. Bei mir funktioniert das anzeigen der Diagramme.
                                        Den Link kopieren
                                        http://192.168.178.51:3000/d/gRZfcBQWz/internet?orgId=1&from=1582523296559&to=1582544896559&panelId=2&fullscreen
                                        und hinten noch
                                        &kiosk&theme=dark
                                        anhängen.
                                        http://192.168.178.51:3000/d/gRZfcBQWz/internet?orgId=1&from=1582523296559&to=1582544896559&panelId=2&fullscreen&kiosk&theme=dark
                                        In der Vis bei dem markiertem basic-html in jedem Bedienfeld (auch bei den 3 Punkten) das target angeben. (Widgetnr. vom iFrame)
                                        • D der-eine
                                          Den Link kopieren
                                          und hinten noch
                                          &kiosk&theme=dark
                                          anhängen.
                                          Dominik F.D Offline
                                          Dominik F.D Offline
                                          Dominik F.
                                          #67
                                          @der-eine
                                          Vielen Dank, das hat jetzt soweit funktioniert bis auf eine Sache. Die Grafanaseite ist anfangs immer schwarz und links oben ist ein Ausrufezeichen mit rotem Hintergrund. Klicke ich drauf steht dort:Invalid dimensions for Plot, width=376,164, high=0
                                          D P 2 Antworten Letzte Antwort
