  4. View Adapter Status
    apollon77A
View Adapter Status
view adapterview
212 Beiträge 31 Kommentatoren 66.5k Aufrufe 52 Beobachtet
  • K Kuddel
    @Oli ich habe meine Übersicht jetzt soweit auf dein Skript angepasst.
    Ich habe einen zusätzliche DP (Alive) erstellt, um den Adapter per VIS zu deaktivieren.
    Leider setzt der Schalter in der VIS die jweilige Instanz nicht auf false.
    Hast du eine Idee dazu ?
    Schalter für den Adapter Alexa2
    [{"tpl":"tplHqButton","data":{"oid":"javascript.0.Adapter.Adapter2.Alive","min":"false","max":"true","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":"0","signals-icon-0":"{javascript.0.Adapter.Adapter2.Bild}","signals-icon-size-0":"40","signals-blink-0":true,"signals-horz-0":"10","signals-vert-0":"10","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"1","signals-icon-1":"{javascript.0.Adapter.Adapter2.Bild}","signals-icon-size-1":"40","signals-blink-1":false,"signals-horz-1":"10","signals-vert-1":"10","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":"2","signals-icon-2":"{javascript.0.Adapter.Adapter2.Bild}","signals-icon-size-2":"40","signals-blink-2":true,"signals-horz-2":"10","signals-vert-2":"10","signals-hide-edit-2":false,"pushButton":false,"usejQueryStyle":false,"g_visibility":false,"styleActive":"hq-button-no-background","name":"Bild","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","gestures-swipeLeft-limit":"-1","gestures-rotateLeft-limit":"2","styleNormal":"hq-button-no-background","testActive":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"descriptionLeft":"Side brush lifetime reset","descriptionLeftDisabled":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-oid-0":"javascript.0.Adapter.Adapter2.Connected","signals-oid-1":"javascript.0.Adapter.Adapter2.Connected","g_center":true,"iconName":"","btIconWidth":"56","offsetAuto":"true","leftOffset":"15","topOffset":"55","signals-oid-2":"javascript.0.Adapter.Adapter2.Connected"},"style":{"left":"25px","top":"5px","width":"50px","height":"50px","border-width":"","border-style":"","border-color":"","border-radius":"10px","z-index":"20","text-align":"center","font-size":"small","box-shadow":"","background":"#212121","background-color":"#212121"},"widgetSet":"hqwidgets"}]
    O
    O
    Oli
    #68
    @Kuddel
    das wollte ich eigentlich mit dem Connected Datenpunkt so machen, hat auch nicht funktioniert.
    Hast du schon mal versucht mit dem Schalter ein zusätzliches Script auszuführen?
    Ich würde mir noch einen Datenpunkt anlegen, nur für den Schalter, sobald sich dieser ändert, dass zusätzliche Script starten.
    Kann ich aber erst heute Abend testen, wenn ich zu Hause bin.
    Oliver
    • O Oli
      @Kuddel
      K
      K
      Kuddel
      #69
      @Oli den Schalter sleber habe ich mir aus meiner VIS kopiert, wo der Alive DP fest hinterlegt war.
      In der Konfiguration kann man die Instanz dann auch deaktivieren.
      O 1 Antwort Letzte Antwort
      • K Kuddel
        O
        O
        Oli
        schrieb am zuletzt editiert von Oli
        #70
        @Kuddel
        versuche mal im Wiget die oid in Schweifklammern zu setzen
        Edit:
        Habe es getestet funktioniert bei mir mit den Klammern.
        Oliver
        • O Oli
          @Kuddel
          Edit:
          K
          K
          Kuddel
          #71
          @Oli echt ? Bei mir geht es nicht.
          Magst du vllt. deinen Schalter exportieren und zur Verfügung stellen?
          • K Kuddel
            O
            O
            Oli
            #72
            @Kuddel
            ich hab den von dir genommen :-)
            ich habe das beim Bing Adapter ausprobiert, dieser ging allerdings nach kurzer Zeit von sich aus wieder auf true, woran das liegt kann ich dir nicht sagen.
            Habe noch einen kleinen Fehler im Script gefunden
            if(connect == false){
                            var con = 0;
                        } else {
                            var con = 1;
                            var strStatePath = devicenameName + ".info.connection";
                            if (isState(strStatePath, true)) {
                                var connectS = getState(devicenameName + ".info.connection").val;
                                if (connectS == false) {
                                    con = 2;
            Steht bei mir im Script ab Zeile 33.
            Oliver
            • sigi234S sigi234
              @Bachmann77 sagte in View Adapter Status:
              @sigi234
              hät ja gern mal gesehen wie deine komplette vis aussieht :)
              Ja ist nur ein Ausschnitt davon.
              Ich baue gerade meine komplette Vis auf vis-materialdesign von @Scrounger um. Hier einige Beispiele:
              Das Menü lässt sich natürlich ausblenden.
              S
              S
              saeft_2003
              #73
              @sigi234 sagte in View Adapter Status:
              @sigi234
              Würdest du mir die widgets mit denen du den Füllstand des Toners anzeigen lässt zu Verfügung stellen?
              • S saeft_2003
                @sigi234
                sigi234S
                sigi234S
                #74
                @saeft_2003 sagte in View Adapter Status:
                Widget_Toner.txt
                • S
                  S
                  saeft_2003
                  #75
                  Danke :-) 👍
                  • ScroungerS
                    ScroungerS
                    Scrounger
                    schrieb am zuletzt editiert von Scrounger
                    #76
                    @sigi234 vielen Dank für die Inspiration für den Adapter Status.
                    Da ich aber ein fauler Mensch bin ;) und keine Lust habe jedes Mal das Widget anpassen zu müssen, wenn ich einen neuen Adapter hinzufüge oder entferne, habe ich das ganze mit nem Skript und meinem IconList Widget dynamisch erzeugt. (Adapter Version v0.2.59 - demnächst im latest !!!)
                    Vorteil des Widget ist, dass es responsiv ist (ein layout für Handy, Tablet, Desktop) und man auch noch die Adapter starten bzw. neustarten kann 😎
                    View zum importieren
                      "settings": {
                        "style": {
                          "background_class": ""
                        "theme": "redmond",
                        "sizex": "",
                        "sizey": "",
                        "gridSize": "",
                        "snapType": null
                      "widgets": {
                        "e00001": {
                          "tpl": "tplVis-materialdesign-Icon-List",
                          "data": {
                            "g_fixed": false,
                            "g_visibility": false,
                            "g_css_font_text": false,
                            "g_css_background": false,
                            "g_css_shadow_padding": false,
                            "g_css_border": false,
                            "g_gestures": false,
                            "g_signals": false,
                            "g_last_change": false,
                            "visibility-cond": "==",
                            "visibility-val": 1,
                            "visibility-groups-action": "hide",
                            "wrapItems": "true",
                            "listItemDataMethod": "jsonStringObject",
                            "countListItems": "1",
                            "vibrateOnMobilDevices": "50",
                            "listLayout": "card",
                            "itemLayout": "horizontal",
                            "listType0": "text",
                            "showValueLabel0": "true",
                            "listType1": "text",
                            "showValueLabel1": "true",
                            "signals-cond-0": "==",
                            "signals-val-0": true,
                            "signals-icon-0": "/vis/signals/lowbattery.png",
                            "signals-icon-size-0": 0,
                            "signals-blink-0": false,
                            "signals-horz-0": 0,
                            "signals-vert-0": 0,
                            "signals-hide-edit-0": false,
                            "signals-cond-1": "==",
                            "signals-val-1": true,
                            "signals-icon-1": "/vis/signals/lowbattery.png",
                            "signals-icon-size-1": 0,
                            "signals-blink-1": false,
                            "signals-horz-1": 0,
                            "signals-vert-1": 0,
                            "signals-hide-edit-1": false,
                            "signals-cond-2": "==",
                            "signals-val-2": true,
                            "signals-icon-2": "/vis/signals/lowbattery.png",
                            "signals-icon-size-2": 0,
                            "signals-blink-2": false,
                            "signals-horz-2": 0,
                            "signals-vert-2": 0,
                            "signals-hide-edit-2": false,
                            "lc-type": "last-change",
                            "lc-is-interval": true,
                            "lc-is-moment": false,
                            "lc-format": "",
                            "lc-position-vert": "top",
                            "lc-position-horz": "right",
                            "lc-offset-vert": 0,
                            "lc-offset-horz": 0,
                            "lc-font-size": "12px",
                            "lc-font-family": "",
                            "lc-font-style": "",
                            "lc-bkg-color": "",
                            "lc-color": "",
                            "lc-border-width": "0",
                            "lc-border-style": "",
                            "lc-border-color": "",
                            "lc-border-radius": 10,
                            "lc-zindex": 0,
                            "jsonStringObject": "{0_userdata.0.vis.AdapterStatus.jsonList}",
                            "maxItemsperRow": "6",
                            "iconHeight": "60",
                            "verticalIconContainerWidth": "100",
                            "labelFontSize": "20",
                            "labelFontFamily": "RobotoCondensed-Regular",
                            "iconItemMinWidth": "290",
                            "labelFontColor": "",
                            "valueFontFamily": "",
                            "subLabelFontFamily": "RobotoCondensed-Regular",
                            "subLabelFontSize": "14",
                            "subLabelFontColor": "#000000",
                            "oid": "0_userdata.0.AdapterStatus.jsonList",
                            "label0": ""
                          "style": {
                            "left": "0px",
                            "top": "0px",
                            "width": "100%",
                            "height": "100%",
                            "overflow-y": "auto"
                          "widgetSet": "materialdesign"
                      "name": "AdapterStatus",
                      "filterList": []
                    Skript, Datenpunkte müsst ihr entsprechend erstellen und anpassen - siehe Kommentare im skript!
                    Achtung wenn ich Bindings verwende geht meine vis in die Knie, deshalb wird das skript zyklisch aufgerufen.
                    // Imports
                    const moment = require("moment");
                    const momentDurationFormatSetup = require("moment-duration-format");
                    moment.locale("de");
                    // Fomate für moment Lib
                    let durationFormat = "dd[T] hh[h] mm[m]";
                    let adapterSelector = `[id=system.adapter.*.alive]`;
                    let adapterAliveList = $(adapterSelector);
                    // Datenpunkt für IconList Widget
                    let dpList = '0_userdata.0.vis.AdapterStatus.jsonList';
                    // Datenpunkt für Adapter restart
                    let dpAdapterRestart = '0_userdata.0.vis.AdapterStatus.restartTrigger';
                    // interval die adapterStatus Funktion augerufen wird (in Sekunden)
                    const checkInterval = 30;
                    // Fehlermeldung ausgeben, wenn selector kein result liefert
                    if (adapterAliveList.length === 0) {
                        console.error(`no result for selector '${adapterSelector}'`)
                    adapterAliveList.on(adapterStatus);                                             // listener nur für Änderung bei alive
                    // Funktion adapterStatus alle x Sekunden ausführen
                    schedule('*/'+ checkInterval + ' * * * * *', adapterStatus);
                    function adapterStatus() {
                        let adapterList = [];
                        try {
                            for (var i = 0; i <= adapterAliveList.length - 1; i++) {
                                let id = adapterAliveList[i].replace('.alive', '');
                                let obj = getObject(adapterAliveList[i].replace('.alive', ''));
                                let nameArray = id.replace('system.adapter.', '').split(".");
                                let name = nameArray[0];
                                name = name.charAt(0).toUpperCase() + name.slice(1);
                                let nameWithInstance = name;
                                let adapterInstance = nameArray[1];
                                if (adapterInstance > 0) {
                                    nameWithInstance = name + '.' + adapterInstance;
                                let uptime = `{d:${id + '.uptime'};Math.floor( ((d)/60/60/24) )}T {h:${id + '.uptime'};Math.floor( ((h)/60/60) % 24 )}h
                                {m:${id + '.uptime'};Math.floor( ((m)/60) % 60 )}m`
                                let text = `<div style="display: flex; flex-direction: row; line-height: 1.5; padding-right: 8px; align-items: center;">
                                                <div style="flex: 1">${nameWithInstance}</div>
                                                <div style="color: grey; font-size: 12px; font-family: RobotoCondensed-LightItalic;">v${obj.common.version}</div>
                                            </div>`
                                let subText = `<div style="display: flex; flex-direction: row; line-height: 1.3; padding-left: 1px; padding-right: 8px; align-items: center;">
                                                    <div style="flex: 1">CPU</div>
                                                    <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${getState(id + '.cpu').val} % %</div>
                                                </div>
                                                    <div style="flex: 1">RAM total</div>
                                                    <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${getState(id + '.memHeapTotal').val} MB</div>
                                                </div>
                                                    <div style="flex: 1">RAM verwendet</div>
                                                    <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${getState(id + '.memHeapUsed').val} MB</div>
                                                </div>
                                                    <div style="flex: 1">RAM reserviert</div>
                                                    <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${getState(id + '.memRss').val} MB</div>
                                                </div>
                                                    <div style="flex: 1">Betriebszeit</div>
                                                    <div style="color: grey; font-size: 14px; font-family: RobotoCondensed-LightItalic;">${moment.duration(getState(id + '.uptime').val, 'seconds').format(durationFormat, 0)}</div>
                                                </div>`
                                adapterList.push({
                                    text: text,
                                    subText: subText,
                                    image: `/${nameArray[0]}.admin/${obj.common.icon}`,
                                    listType: "buttonState",
                                    objectId: dpAdapterRestart,
                                    buttonStateValue: id,
                                    statusBarColor: getStatusColor(),
                                    showValueLabel: false
                                function getStatusColor() {
                                    let statusBarColor = 'FireBrick';
                                    if (getState(adapterAliveList[i]).val === true) {
                                        statusBarColor = 'green';
                                    if (obj.common.enabled === false) {
                                        // Adapter ist deaktiviert
                                        statusBarColor = 'darkgrey';
                                    if (obj.common.mode === 'schedule') {
                                        // Adapter ist zeitgesteuert
                                        statusBarColor = 'orange';
                                    return statusBarColor;
                        } catch (err) {
                            console.error(`[adapterStatus] error: ${err.message}, stack: ${err.stack}`);
                        let result = JSON.stringify(adapterList);
                        if (getState(dpList) !== result) {
                            setState(dpList, result, true);
                    adapterStatus();
                    // Funktion um Adapter zu starten / neu starten
                    on({ id: dpAdapterRestart }, function (obj) {
                        var adapter = getObject(obj.state.val.toString());
                        if (adapter.common.enabled === false) {
                            // Adapter deaktiviert -> starten
                            adapter.common.enabled = true;
                        setObject(obj.state.val, adapter);
                        console.log(`${obj.state.val.replace('system.adapter.', '')} neugestartet`);
                    Javascript Adapter muss folgende libraries importieren und setObject aktiviert sein!
                    Weiß jemand noch wie wo man den Status abgreifen kann das ein Update für den Adapter zur Verfügung steht? Dann könnte ich noch ein Badget einfügen.
                    NegaleinN sigi234S 3 Antworten Letzte Antwort
                    • ScroungerS Scrounger
                        "settings": {
                          "style": {
                          "theme": "redmond",
                          "sizex": "",
                          "sizey": "",
                          "gridSize": "",
                          "snapType": null
                        "widgets": {
                          "e00001": {
                            "data": {
                              "g_fixed": false,
                              "g_signals": false,
                              "lc-format": "",
                              "lc-bkg-color": "",
                              "lc-color": "",
                              "lc-zindex": 0,
                              "iconHeight": "60",
                              "label0": ""
                            "style": {
                              "left": "0px",
                              "top": "0px",
                              "width": "100%",
                              "height": "100%",
                        "filterList": []
                      // Imports
                          try {
                                              </div>`
                                                  </div>
                                                  </div>
                                                  </div>
                                                  </div>
                                                  </div>`
                                  adapterList.push({
                                      text: text,
                                      subText: subText,
                          } catch (err) {
                      adapterStatus();
                      NegaleinN
                      NegaleinN
                      Negalein
                      #77
                      @Scrounger sagte in View Adapter Status:
                      Als was müssen die DP angelegt werden (Zeichenkette, Werteliste, ...)
                      ° Fixer ---> iob fix
                      ScroungerS 1 Antwort Letzte Antwort
                      • NegaleinN Negalein
                        ScroungerS
                        ScroungerS
                        Scrounger
                        #78
                        @Negalein
                        Zeichenkette
                            "settings": {
                              "style": {
                              "theme": "redmond",
                              "sizex": "",
                              "sizey": "",
                              "gridSize": "",
                              "snapType": null
                            "widgets": {
                              "e00001": {
                                "data": {
                                  "g_fixed": false,
                                  "g_signals": false,
                                  "lc-format": "",
                                  "lc-bkg-color": "",
                                  "lc-color": "",
                                  "lc-zindex": 0,
                                  "iconHeight": "60",
                                  "label0": ""
                                "style": {
                                  "left": "0px",
                                  "top": "0px",
                                  "width": "100%",
                                  "height": "100%",
                            "filterList": []
                          // Imports
                              try {
                                                  </div>`
                                                      </div>
                                                      </div>
                                                      </div>
                                                      </div>
                                                      </div>`
                                      adapterList.push({
                                          text: text,
                                          subText: subText,
                              } catch (err) {
                          adapterStatus();
                          sigi234S
                          sigi234S
                          #79
                          //  Adapter Update Notification Script
                          *   @author Moritz Heusinger <moritz.heusinger@gmail.com>
                          *   The scripts checks for adapter upgrades, everyday at 06:00 p.m., if there
                          *   are upgrades available it will send an E-Mail to the configured receiverMail.
                          *   Requirement: Running instance of the E-Mail adapter; Admin >= 3.6
                          *   logging:        if true, information will be logged
                          *   senderMail:     mail address of the sender
                          *   receiverMail:   target mail address
                          const logging = true;
                          const senderMail = 'xxxxxxxxxxt';
                          const receiverMail = 'xxxxxxxxxxxt';
                          on({id: 'admin.0.info.updatesJson', ack: true, change: 'ne'}, (obj) => {
                              if(!getState('admin.0.info.newUpdates').val) return;
                              if (logging) log('New adapter updates are available', 'info');
                              let upgradeable = JSON.parse(obj.state.val);
                              let text = 'Die folgenden Adapter sind aktualisierbar:\n';
                              for (let adapter in upgradeable) {
                                  text += 'Adapter ' + JSON.stringify(adapter) + ' kann von ' +
                                      upgradeable[adapter].installedVersion + ' auf ' +
                                      upgradeable[adapter].availableVersion + ' aktualisiert werden.\n';
                              } // endFor
                              sendTo('email', {
                                      to:      receiverMail,
                                      subject: 'Es sind neue Adapter Updates für deinen ioBroker verfügbar',
                                      text:    text
                              "settings": {
                                "style": {
                                "theme": "redmond",
                                "sizex": "",
                                "sizey": "",
                                "gridSize": "",
                                "snapType": null
                              "widgets": {
                                "e00001": {
                                  "data": {
                                    "g_fixed": false,
                                    "g_signals": false,
                                    "lc-format": "",
                                    "lc-bkg-color": "",
                                    "lc-color": "",
                                    "lc-zindex": 0,
                                    "iconHeight": "60",
                                    "label0": ""
                                  "style": {
                                    "left": "0px",
                                    "top": "0px",
                                    "width": "100%",
                                    "height": "100%",
                              "filterList": []
                            // Imports
                                try {
                                                    </div>`
                                                        </div>
                                                        </div>
                                                        </div>
                                                        </div>
                                                        </div>`
                                        adapterList.push({
                                            text: text,
                                            subText: subText,
                                } catch (err) {
                            adapterStatus();
                            sigi234S
                            sigi234S
                            #80
                            @Scrounger
                            13:02:30.106	warn	javascript.0 (8000) at getStatusColor (script.js.Sigi.Adapter_Abfrage:93:21)
                            13:02:30.106	warn	javascript.0 (8000) at Object.adapterStatus (script.js.Sigi.Adapter_Abfrage:87:33)
                            • NegaleinN
                              NegaleinN
                              Negalein
                              #81
                              @Scrounger
                              hab auch jetzt alle 30 Sekunden Warn-Meldungen
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.167	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:86:33)
                              javascript.0	2020-02-22 14:16:30.166	warn	(5214) at getStatusColor (script.js.System.Adapterliste:92:21)
                              javascript.0	2020-02-22 14:16:30.166	warn	(5214) getState "system.adapter.devices.0.alive" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.164	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.164	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.164	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.164	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.164	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.164	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.164	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.163	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.163	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:76:136)
                              javascript.0	2020-02-22 14:16:30.163	warn	(5214) getState "system.adapter.devices.0.uptime" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.163	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.163	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.163	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.163	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.162	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.162	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.162	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.162	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.162	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:72:120)
                              javascript.0	2020-02-22 14:16:30.161	warn	(5214) getState "system.adapter.devices.0.memRss" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.160	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:68:120)
                              javascript.0	2020-02-22 14:16:30.159	warn	(5214) getState "system.adapter.devices.0.memHeapUsed" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.159	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.159	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.159	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.159	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.159	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.159	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.157	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.157	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.157	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:64:120)
                              javascript.0	2020-02-22 14:16:30.157	warn	(5214) getState "system.adapter.devices.0.memHeapTotal" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.157	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.157	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.156	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.156	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.156	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.156	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.156	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.156	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.156	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:60:120)
                              javascript.0	2020-02-22 14:16:30.155	warn	(5214) getState "system.adapter.devices.0.cpu" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.149	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.149	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.149	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.149	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.149	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.149	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.149	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.148	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.148	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:86:33)
                              javascript.0	2020-02-22 14:16:30.148	warn	(5214) at getStatusColor (script.js.System.Adapterliste:92:21)
                              javascript.0	2020-02-22 14:16:30.148	warn	(5214) getState "system.adapter.fontui.0.alive" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.146	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.146	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.146	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.146	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.146	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.146	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.146	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.145	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.145	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:76:136)
                              javascript.0	2020-02-22 14:16:30.145	warn	(5214) getState "system.adapter.fontui.0.uptime" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.145	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.145	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.145	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.145	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.145	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:72:120)
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) getState "system.adapter.fontui.0.memRss" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.144	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.143	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.143	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.143	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.143	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.143	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:68:120)
                              javascript.0	2020-02-22 14:16:30.143	warn	(5214) getState "system.adapter.fontui.0.memHeapUsed" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.143	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.142	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.142	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.142	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.142	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.142	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.142	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.142	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.142	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:64:120)
                              javascript.0	2020-02-22 14:16:30.140	warn	(5214) getState "system.adapter.fontui.0.memHeapTotal" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.140	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.140	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.140	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.140	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.140	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.140	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.140	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.139	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.139	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:60:120)
                              javascript.0	2020-02-22 14:16:30.139	warn	(5214) getState "system.adapter.fontui.0.cpu" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.096	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.096	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.096	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.096	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.096	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.095	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.095	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.095	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.095	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:60:120)
                              javascript.0	2020-02-22 14:16:30.094	warn	(5214) getState "system.adapter.places.0.cpu" not found (3)
                              javascript.0	2020-02-22 14:16:30.066	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.066	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.066	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.066	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.066	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.066	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.066	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.065	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.065	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:86:33)
                              javascript.0	2020-02-22 14:16:30.065	warn	(5214) at getStatusColor (script.js.System.Adapterliste:92:21)
                              javascript.0	2020-02-22 14:16:30.064	warn	(5214) getState "system.adapter.proxy.0.alive" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.062	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:76:136)
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) getState "system.adapter.proxy.0.uptime" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.061	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.060	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:72:120)
                              javascript.0	2020-02-22 14:16:30.060	warn	(5214) getState "system.adapter.proxy.0.memRss" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.060	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.060	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.060	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.060	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.060	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.059	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.059	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.059	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.059	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:68:120)
                              javascript.0	2020-02-22 14:16:30.059	warn	(5214) getState "system.adapter.proxy.0.memHeapUsed" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.058	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:64:120)
                              javascript.0	2020-02-22 14:16:30.057	warn	(5214) getState "system.adapter.proxy.0.memHeapTotal" not found (3) states[id]=null
                              javascript.0	2020-02-22 14:16:30.057	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.057	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.057	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.057	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.057	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.057	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.057	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.056	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.056	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:60:120)
                              javascript.0	2020-02-22 14:16:30.056	warn	(5214) getState "system.adapter.proxy.0.cpu" not found (3)
                              javascript.0	2020-02-22 14:16:30.050	warn	(5214) at Timer.processTimers (timers.js:223:10)
                              javascript.0	2020-02-22 14:16:30.050	warn	(5214) at listOnTimeout (timers.js:263:5)
                              javascript.0	2020-02-22 14:16:30.050	warn	(5214) at tryOnTimeout (timers.js:300:5)
                              javascript.0	2020-02-22 14:16:30.050	warn	(5214) at ontimeout (timers.js:436:11)
                              javascript.0	2020-02-22 14:16:30.049	warn	(5214) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                              javascript.0	2020-02-22 14:16:30.049	warn	(5214) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                              javascript.0	2020-02-22 14:16:30.049	warn	(5214) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                              javascript.0	2020-02-22 14:16:30.049	warn	(5214) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1340:34)
                              javascript.0	2020-02-22 14:16:30.049	warn	(5214) at Object.adapterStatus (script.js.System.Adapterliste:60:120)
                              javascript.0	2020-02-22 14:16:30.048	warn	(5214) getState "system.adapter.systeminfo.0.cpu" not found (3)
                                @Scrounger
                                sigi234S
                                sigi234S
                                #82
                                @Negalein sagte in View Adapter Status:
                                Ja, hatte ich auch kommt wenn die Adapter nicht aktiviert sind.
                                Bei dir sind es einige:
                                • sigi234S sigi234
                                  NegaleinN
                                  NegaleinN
                                  Negalein
                                  #83
                                  Ah, ok.
                                  Ja, habe einige deaktiviert. Muss ich mal löschen. ;)
                                  Weißt du eventuell, wie ich die Farbe der rechten Spalte (Werte) ändere?
                                    Ah, ok.
                                    sigi234S
                                    sigi234S
                                    #84
                                    Nö,Experimentiere auch gerade.
                                    • sigi234S sigi234
                                      NegaleinN
                                      NegaleinN
                                      Negalein
                                      #85
                                      finde keinen Punkt dafür. Alle anderen Farbwerte hab ich gefunden.
                                      Kann uns sicher @Scrounger weiterhelfen.
                                        sigi234S
                                        sigi234S
                                        #86
                                        Ich denke das geht im Skript ab Zeile 54
                                        Tipp:
                                        In Zeile 61 muss du noch das % Zeichen löschen, stehen 2 mal drinnen.
                                        • sigi234S sigi234
                                          Tipp:
                                          NegaleinN
                                          NegaleinN
                                          Negalein
                                          #87
                                          Bingo, das wars :)
                                          84.1k
