  4. JavaScript
  5. [Vorlage] JS: Log-Datei aufbereiten für VIS
    6.3k
617 Beiträge 60 Kommentatoren 211.3k Aufrufe 49 Beobachtet
    blackeagle998
    schrieb am zuletzt editiert von blackeagle998
    #456
    @Mic
    Das Skript läuft wie immer super, solange ich mindestens eine VIS View angebe.
    Ändere ich den Wert "const NUMBER_OF_VIS_VIEWS = 1;" auf 0, erhalte ich im LOG folgende Fehler:
    javascript.0	2020-02-13 12:02:44.106	error	(10714) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2020-02-13 12:02:44.106	error	(10714) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2020-02-13 12:02:44.105	error	(10714) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2020-02-13 12:02:44.105	error	(10714) at client.set.err (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:534:55)
    javascript.0	2020-02-13 12:02:44.105	error	(10714) at err (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:318:38)
    javascript.0	2020-02-13 12:02:44.105	error	(10714) at Object.<anonymous> (script.js.common.02_IO-Broker.Logfile:1708:44)
    javascript.0	2020-02-13 12:02:44.105	error	(10714) at script.js.common.02_IO-Broker.Logfile:421:9
    javascript.0	2020-02-13 12:02:44.104	error	(10714) at createUserStates (script.js.common.02_IO-Broker.Logfile:1629:43)
    javascript.0	2020-02-13 12:02:44.103	error	(10714) Error in callback: TypeError: Cannot read property 'replace' of undefined
    Die Zeilen 1627 bis 1633 enthalten folgenden Code:
     // Add "where" to STATES_TO_CREATE
        for (let i = 0; i < statesToCreate.length; i++) {
            let lpPath = statesToCreate[i][0].replace(/\.*\./g, '.'); // replace all multiple dots like '..', '...' with a single '.'
            lpPath = lpPath.replace(/^((javascript\.([1-9][0-9]|[0-9])\.)|0_userdata\.0\.)/,'') // remove any javascript.x. / 0_userdata.0. from beginning
            lpPath = where + '.' + lpPath; // add where to beginning of string
            statesToCreate[i][0] = lpPath;
    Das soll nur als Hinweis dienen, da das Skript ja für die VIS Aufbereitung gedacht ist und somit mindestens eine VIS View vorhanden sein sollte.
    MicM 1 Antwort Letzte Antwort
    • B blackeagle998
      @Mic
      MicM Offline
      MicM Offline
      Mic
      #457
      @blackeagle998 sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
      Vielen Dank für den Test. Habe ich in Version 4.7 korrigiert. Für ein Update reicht es, alles unterhalb des folgenden Kommentars zu ersetzen:
       * Ab hier nichts mehr ändern / Stop editing here!
      • LatziL Online
        LatziL Online
        Latzi
        #458
        @Mic
        ich hab im Log folgende Fehlermeldungen:
        2020-02-14 20:06:16.407 - error: rtspStream.0 (14568) uncaught exception: i is not defined
        2020-02-14 20:06:16.408 - error: rtspStream.0 (14568) ReferenceError: i is not defined
        2020-02-14 20:06:17.452 - error: host.Pi4-Server Caught by controller[43]: frame=95046 fps= 15 q=6.1 size= 315696kB time=01:45:32.56 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.452 - error: host.Pi4-Server Caught by controller[44]: frame=95054 fps= 15 q=3.9 size= 315727kB time=01:45:33.06 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.452 - error: host.Pi4-Server Caught by controller[45]: frame=95061 fps= 15 q=4.7 size= 315740kB time=01:45:33.64 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.452 - error: host.Pi4-Server Caught by controller[46]: frame=95069 fps= 15 q=5.0 size= 315772kB time=01:45:34.07 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[47]: frame=95076 fps= 15 q=4.7 size= 315785kB time=01:45:34.65 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[48]: frame=95084 fps= 15 q=4.6 size= 315819kB time=01:45:35.15 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[49]: frame=95092 fps= 15 q=5.7 size= 315848kB time=01:45:35.66 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[50]: frame=95100 fps= 15 q=4.7 size= 315864kB time=01:45:36.16 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[51]: frame=95108 fps= 15 q=4.6 size= 315900kB time=01:45:36.66 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.453 - error: host.Pi4-Server Caught by controller[52]: frame=95115 fps= 15 q=5.0 size= 315932kB time=01:45:37.24 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.454 - error: host.Pi4-Server Caught by controller[53]: frame=95123 fps= 15 q=4.2 size= 315949kB time=01:45:37.74 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.454 - error: host.Pi4-Server Caught by controller[54]: frame=95131 fps= 15 q=4.7 size= 315975kB time=01:45:38.25 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.454 - error: host.Pi4-Server Caught by controller[55]: frame=95139 fps= 15 q=4.6 size= 316009kB time=01:45:38.75 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[56]: frame=95146 fps= 15 q=6.0 size= 316021kB time=01:45:39.26 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[57]: frame=95154 fps= 15 q=4.8 size= 316056kB time=01:45:39.76 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[58]: frame=95162 fps= 15 q=3.6 size= 316087kB time=01:45:40.26 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[59]: ReferenceError: i is not defined
        2020-02-14 20:06:17.465 - error: host.Pi4-Server Caught by controller[59]: at WebSocketServer.wsServer.broadcast (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:103:54)
        2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at VideoStream.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:109:26)
        2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at VideoStream.emit (events.js:198:13)
        2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at Mpeg1Muxer.mpeg1Muxer.on (/opt/iobroker/node_modules/node-rtsp-stream/videoStream.js:47:17)
        2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at Mpeg1Muxer.emit (events.js:198:13)
        2020-02-14 20:06:17.466 - error: host.Pi4-Server Caught by controller[59]: at Socket.Mpeg1Muxer.stream.stdout.on (/opt/iobroker/node_modules/node-rtsp-stream/mpeg1muxer.js:39:17)
        2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: at Socket.emit (events.js:198:13)
        2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: at addChunk (_stream_readable.js:288:12)
        2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: at readableAddChunk (_stream_readable.js:269:11)
        2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: at Socket.Readable.push (_stream_readable.js:224:10)
        2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[59]: frame=95169 fps= 15 q=4.4 size= 316101kB time=01:45:40.84 bitrate= 408.4kbits/s speed= 1x
        2020-02-14 20:06:17.467 - error: host.Pi4-Server Caught by controller[60]: frame=95177 fps= 15 q=5.3 size= 316135kB time=01:45:41.34 bitrate= 408.4kbits/s speed= 1x
        Es wird mir im DP error aber nichts angezeigt. Ich habe auch nichts deratiges in der blacklist. Hast du eine Erklärung dafür?
        GlasfaserG MicM 2 Antworten Letzte Antwort
        • LatziL Latzi
          @Mic
          GlasfaserG Offline
          GlasfaserG Offline
          #459
          @Latzi
          Teste mal mit dem Skript von Mic , hast du dort eine Log Ausgabe ?
          log('Error-Meldung', 'error');
          log('Warn-Meldung', 'warn');
          // Nochmal nach 2 Sekunden.
          setTimeout(function() {
          }, 2*1000);
          // Nach 30 Sekunden noch eine Warnmeldung.
              log('Neue Warn-Meldung nach 30 Sekunden', 'warn');
          }, 30*1000);
          LatziL 1 Antwort Letzte Antwort
          • GlasfaserG Glasfaser
            @Latzi
            }, 2*1000);
            }, 30*1000);
            LatziL Online
            LatziL Online
            Latzi
            #460
            @Glasfaser ja, die Meldungen kommen. Liegt wohl an der Art und Weise wie rtspstream die Fehler generiert.
            Danke dir für die Unterstützung!
            • LatziL Latzi
              GlasfaserG Offline
              GlasfaserG Offline
              #461
              @Latzi
              Habe mal ein Fehler simuliert .... rtspstream wird im LOG angezeigt
              Zeig doch mal deine Usereinstellung , für die ERROR Filterung.
                @Latzi
                LatziL Online
                LatziL Online
                Latzi
                #462
                @Glasfaser
                mein Block error sieht folgendermaßen aus:
                    filter_all:     [' - error:', ''],  // nur Logeinträge mit Level 'error'
                    filter_any:     [''],
                    blacklist:      ['', '', ''],
                    clean:          ['', '', ''],
                    merge:          true,
                    sortDescending: true,
                    jsonColumns:    ['date','level','source','msg'],
                    jsonDateFormat: 'dd.mm. hh:mm',
                    jsonLogLength:  200,
                    jsonMaxLines:   60,
                    jsonCssToLevel: true,
                Kannst du das bitte mal mit deinem Block vergleichen?
                • LatziL Latzi
                  @Glasfaser
                      filter_any:     [''],
                      merge:          true,
                      jsonLogLength:  200,
                      jsonMaxLines:   60,
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #463
                  @Latzi sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                  Füge mal das ein :
                      filter_all:     [' - error: ', ''],  // nur Logeinträge mit Level 'error'
                      filter_any:     [''],
                      merge:          true,
                      jsonLogLength:  200,
                      jsonMaxLines:   60,
                    Füge mal das ein :
                        filter_any:     [''],
                        merge:          true,
                        jsonLogLength:  200,
                        jsonMaxLines:   60,
                    LatziL Online
                    LatziL Online
                    Latzi
                    #464
                    @Glasfaser ändert leider nichts :-(
                    • LatziL Latzi
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #465
                      @Latzi
                      Mhhh , habe gerade nochmal verglichen , dachte es hatte einfluss das nach dem - error: ein Leerzeichen fehlte ...
                      Kann du den Error im Datenpunkt log sehen ?
                        @Latzi
                        LatziL Online
                        LatziL Online
                        Latzi
                        #466
                        @Glasfaser nein, ist darin nicht enthalten
                        • LatziL Latzi
                          GlasfaserG Offline
                          GlasfaserG Offline
                          #467
                          @Latzi
                          Da bin gerade überfragt ….. mehr kann ich dir im Moment leider nicht weiterhelfen , da ich gerade ein großes ? dazu habe …🤔
                          Warte auf Mic
                            @Latzi
                            Warte auf Mic
                            LatziL Online
                            LatziL Online
                            Latzi
                            #468
                            @Glasfaser vielen Dank für deine Mühe 👍 👍 👍
                            • LatziL Latzi
                              @Mic
                              MicM Offline
                              MicM Offline
                              Mic
                              #469
                              Bitte ersetze mal folgende Zeile im Script:
                              const LOG_PATT =  '([0-9_.\\-:\\s]*)(\\s+\\- )(silly|debug|info|warn|error|)(: )([a-z0-9.\\-]*)(\\s)(.*)';
                              Durch:
                              const LOG_PATT =  '([0-9_.\\-:\\s]*)(\\s+\\- )(silly|debug|info|warn|error|)(: )([^\\s]*)(\\s)(.*)';
                              • MicM Mic
                                Durch:
                                LatziL Online
                                LatziL Online
                                Latzi
                                #470
                                @Mic sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                                const LOG_PATT = '([0-9_.\-:\s])(\s+\- )(silly|debug|info|warn|error|)(: )([^\s])(\s)(.*)';
                                @Mic Applaus, Applaus 👏 👏 👏
                                Jetzt kommen auch die Meldungen vom rtspStream durch (es waren nicht nur die error-Meldungen, eigentlich waren alle Typen betroffen).
                                Muss ich diese Zeile für spätere Versionen sichern oder baust du es allgemein im Script ein?
                                • LatziL Latzi
                                  MicM Offline
                                  MicM Offline
                                  Mic
                                  #471
                                  @Latzi
                                  Gern geschehen :-)
                                  Baue ich ins Script ein, Update folgt sehr bald.
                                  • MicM Offline
                                    MicM Offline
                                    Mic
                                    schrieb am zuletzt editiert von Mic
                                    #472
                                    Neue Log-Script-Version 4.8
                                    Neuerungen:
                                     *  + Allow regular expressions in BLACKLIST_GLOBAL
                                     *  + Allow regular expressions in LOG_FILTER: 'blacklist', 'clean', 'filter_all', 'filter_any'
                                     *  - Fix: Log line regex, which did not allow upper case letters in host (source)
                                    Das heißt, es werden nun auch Regular Expressions unterstützt.
                                    Um also etwa Einträge wie z.B.
                                    script.js.System.-_Log-Script: registered 8 subscriptions and 1 schedule
                                    script.js.System.Backup: registered 0 subscriptions and 0 schedules
                                    script.js.System.Test: registered 3 subscriptions and 2 schedules
                                    allesamt zu eliminieren, kann man einfach in BLACKLIST_GLOBAL eintragen:
                                    /registered [0-9]+ subscriptions and [0-9]+ schedules/
                                    Oder um sämtliche script.js.System.XXXXXXXXXX: herauszuschneiden aus den Logzeilen, trägt man in LOG_FILTER unter clean folgendes ein:
                                    /script\.js\.[^:]*: /
                                    Weitere Beispiele sind im Script selbst. Viel Spaß damit.
                                    Um eigene Regex zu erstellen, eignet sich https://regex101.com/ gut.
                                    Hier das aktuelle Script wie immer: https://github.com/Mic-M/iobroker.logfile-script
                                    Zum Update von der Vorversion: Einfach alles unterhalb von hier ersetzen:
                                    • sigi234S sigi234
                                      das Löschdatum beim erstmaligen Betätigen aktualisiert wird
                                      Wo siehst du das? Erledigt, ist bei mir nicht so.
                                      saeft_2003
                                      #473
                                      @sigi234 sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                                      Würdest du mir diesen view zu verfügung stellen? Sieht echt klasse aus und würde mir jede menge arbeit sparen :-)
                                      • S saeft_2003
                                        sigi234S Online
                                        sigi234S Online
                                        #474
                                        @saeft_2003 sagte in [Vorlage] JS: Log-Datei aufbereiten für VIS:
                                        VIEW LOG MIC.txt
                                        S 2 Antworten Letzte Antwort
                                        • sigi234S sigi234
                                          VIEW LOG MIC.txt
                                          saeft_2003
                                          #475
                                          @sigi234
                                          Vielen Dank 😊👍
