  4. [gelöst] CSS Einstellungen werden nicht umgesetzt
    2.8k
    4.9k
    4.1k
vismaterial css
31 Beiträge 7 Kommentatoren 1.4k Aufrufe 9 Beobachtet
    Kuddel
    schrieb am zuletzt editiert von Kuddel
    Moin zusammen,
    ich bin gerade dabei mich in CSS einzuarbeiten um die Anzahl meiner Widgets zu reduzieren.
    In meiner VIS habe ich die Anwesenheit über ein Navigationwidget dargestellt.
    Leider werden die CSS Einstellungen bei den Signalbildern nicht umgesetzt.
    Die rechte Anzeige ist noch mit zwei Widgets.
    Hier einmal das komplette Widget:
    [{"tpl":"tplMetroTileNav","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":true,"g_signals":true,"hover":false,"transform":false,"label":"","bg_class":"bg-transparent","bg_class_active":"bg-transparent","signals-cond-0":"==","signals-val-0":"true","signals-icon-0":"/icons-mfd-png/status_man.png","signals-icon-size-0":"100","signals-blink-0":false,"signals-horz-0":"-20","signals-vert-0":"-20","signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":"false","signals-icon-1":"/icons-mfd-png/status_man.png","signals-icon-size-1":"100","signals-blink-1":false,"signals-horz-1":"-20","signals-vert-1":"-20","signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis.0/VIS/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_badge":true,"badge_bg_class":"","badge_bg_class_active":"","badge_top":"0","badge_left":"0","icon_badge":"","brand_bg_class":"","brand_bg_class_active":"","g_icon":true,"icon_class":"","icon_src":"","icon_width":"70","icon_height":"70","icon_top":"42","icon_left":"50","nav_view":"400_System","g_last_change":true,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_effects":true,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","hide_duration":"0","show_duration":"0","name":"Daniel","select_current":false,"comment":"","signals-oid-0":"javascript.0.Anwesenheit.Daniel","signals-oid-1":"javascript.0.Anwesenheit.Daniel","signals-icon-style-1":"border: red 2px solid; border-radius: 10px;2px solid; border-radius: 10px","signals-icon-style-2":"","signals-icon-style-0":"border: #41f316 2px solid; border-radius: 10px"},"style":{"left":"30px","top":"45px","width":"65px","height":"65px","z-index":"20","transform":""},"widgetSet":"metro"}]
    Und die CSS Einstellungen als Beispiel für Signalbild 1: border: #41f316 2px solid; border-radius: 10px
    Kann jemand helfen?
    O 1 Antwort Letzte Antwort
    • K Kuddel
      Moin zusammen,
      Kann jemand helfen?
      O Offline
      O Offline
      Oli
      @Kuddel
      Das geht auch mit Binding, direkt in der Rahmenfarbe
      Oliver
      • O Oli
        @Kuddel
        Kuddel
        @Oli wie genau mache ich das ?
        der dp ist
        bei true, soll der rahmen grün sein, bei false rot
        O 2 Antworten Letzte Antwort
        • K Kuddel
          der dp ist
          O Offline
          O Offline
          Oli
          @Kuddel
          Kann ich dir heute Abend sagen, bin noch unterwegs
          Oliver
          • K Kuddel
            der dp ist
            O Offline
            O Offline
            Oli
            @Kuddel
            hier mal das Binding, Datenpunkt muss noch angepasst werden:
            {wert:javascript.0.Gewerke.Licht_DG.StatusAlarm; wert==0 ? "green" :: "orange"}
            Das ganze muss hier eingetragen werden:
            Oliver
            K 2 Antworten Letzte Antwort
            • O Oli
              @Kuddel
              Kuddel
              @Oli super, funktionert :-)
              • O Oli
                @Kuddel
                Kuddel
                @Oli hmm oder auch nicht:
                {wert:javascript.0.Anwesenheit.Jenny; wert==true ? "#41f316" :: "red"}
                J.A.R.V.I.S.J Z 2 Antworten Letzte Antwort
                • K Kuddel
                  J.A.R.V.I.S.J Offline
                  J.A.R.V.I.S.
                  @Kuddel es bedarf auch keiner zwei Doppelpunkte.
                  {wert:javascript.0.Anwesenheit.Jenny; wert==true ? "#41f316" : "red"}
                  Hast du es nur im Editor oder auch in der Visualisierung?
                  • J.A.R.V.I.S.J J.A.R.V.I.S.
                    Kuddel
                    @J-A-R-V-I-S habe das so von @Oli übernommen und auch in der VIS die Doppelpunkte gesetzt.
                    Ich werde das mal eben korrigieren
                    • K Kuddel
                      SBorgS Offline
                      SBorgS Offline
                      SBorg
                      @Kuddel Interessanter ist der Typ vom DP. Ist dein "true" vom JS nur Text oder ein "echter" Boolean?
                      LG SBorg ( SBorg auf GitHub)
                      OliverIOO K 2 Antworten Letzte Antwort
                      • SBorgS SBorg
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @SBorg das ist relativ egal, da die aktuelle LogiK von Binding das immer in text umsetzt.
                        ich habe da in Verbindung mit JSON-Daten einen Issue bei iobroker.vis eingestellt.
                        Wenn das umgesetzt wird, dann kommen auch die echten Datentypen an.
                        Meine Adapter und Widgets
                        Links im Profil
                        • SBorgS SBorg
                          Kuddel
                          @SBorg es ist ein echter Boolean
                          • K Kuddel
                            Z Offline
                            Z Offline
                            zahnheinrich
                            @Kuddel
                            Könnte auch ein anderes Problem sein.
                            In den Objekten ist dein "true" rot, also nicht bestätigt.
                            In deiner CSS Einstellung deutet der grüne Untergrund darauf hin, dass der aktuelle Wert tatsächlich true ist.
                            Vertausche mal die Bedingungen, um zu sehen, ob sich die Anzeige dann ändert
                            MfG Ulrich
                            • Z zahnheinrich
                              @Kuddel
                              Kuddel
                              @zahnheinrich die erste Farbe wird angezeigt, wenn die Bedingung wahr ist richtig ?
                              Z 1 Antwort Letzte Antwort
                              • K Kuddel
                                Z Offline
                                Z Offline
                                zahnheinrich
                                schrieb am zuletzt editiert von zahnheinrich
                                @Kuddel
                                So sollte es sein.
                                Prüfe einfach mal auf false, versuche auch "false",
                                mit Anführungszeichen.
                                Probier auch wert == false mit Leerzeichen vor und hinter==
                                MfG Ulrich
                                • Z zahnheinrich
                                  @Kuddel
                                  So sollte es sein.
                                  Kuddel
                                  @zahnheinrich habe es nochmal gestestet:
                                  {wert:javascript.0.Anwesenheit.Daniel; wert=="true" ? "#41f316" : "red"}
                                  Meine Frau ist zu Hause, ich nicht.
                                  Sieht als gut aus. Scheint so als wenn true in Anführungszeichen muss
                                  • K Kuddel
                                    Z Offline
                                    Z Offline
                                    zahnheinrich
                                    @Kuddel
                                    Hab ich auch schon mal rumgesucht.
                                    So gehts dann.
                                    Scheint also doch kein "echtes" true zu sein, sondern ein Textstring.
                                    MfG Ulrich
                                    • OliverIOO OliverIO
                                      SBorgS Offline
                                      SBorgS Offline
                                      SBorg
                                      @OliverIO sagte in CSS Einstellungen werden nicht umgesetzt:
                                      Dann kann aber IMHO wert==true nicht funktionieren? und muss "true" sein ;)
                                      Beim Binding wird im Editor unabhängig vom Status immer der erste verwertbare Wert genommen, egal ob die Bedingung "true" oder "false" ist.
                                      • Z zahnheinrich
                                        @Kuddel
                                        So gehts dann.
                                        Kuddel
                                        @zahnheinrich
                                        • K Kuddel
                                          @zahnheinrich
                                          Z Offline
                                          Z Offline
                                          zahnheinrich
                                          @Kuddel
                                          Klar, aber siehe den post darüber von @SBorg .
                                          MfG Ulrich
