  4. Neuer Adapter: SMA Wechselrichter mit sbfspot
    6.8k
248 Beiträge 26 Kommentatoren 72.0k Aufrufe 10 Beobachtet
  • T Tottbeck
    @Rene_HM
    2020-01-12T14_53_55_158Z-debug.log
    Habe versucht npm nochmal zu installieren, klappt aber nicht.
    root@raspberrypi:/opt/iobroker/node_modules/iobroker.sbfspot# sudo npm clean-install
    npm WARN prepare removing existing node_modules/ before installation
    > sqlite3@4.1.1 install /opt/iobroker/node_modules/iobroker.sbfspot/node_module/sqlite3
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp info it worked if it ends with ok
    node-pre-gyp info using node-pre-gyp@0.11.0
    node-pre-gyp info using node@8.16.0 | linux | arm
    node-pre-gyp WARN Using request for node-pre-gyp https download
    node-pre-gyp info check checked for "/opt/iobroker/node_modules/iobroker.sbfspo/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" (not fond)
    node-pre-gyp http GET https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1./node-v57-linux-arm.tar.gz
    node-pre-gyp http 403 https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1./node-v57-linux-arm.tar.gz
    node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonas.com/sqlite3/v4.1.1/node-v57-linux-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.1.1 and node@8.16. (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
    node-pre-gyp http 403 status code downloading tarball https://mapbox-node-binar.s3.amazonaws.com/sqlite3/v4.1.1/node-v57-linux-arm.tar.gz
    gyp info using node-gyp@3.8.0
    gyp info ok
    gyp info spawn /usr/bin/python2
    gyp info spawn args [ '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_ain.py',
    gyp info spawn args   'binding.gyp',
    gyp info spawn args   '-f',
    gyp info spawn args   'make',
    gyp info spawn args   '-I',
    gyp info spawn args   '/opt/iobroker/node_modules/iobroker.sbfspot/node_modulessqlite3/build/config.gypi',
    gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gyi',
    gyp info spawn args   '/root/.node-gyp/8.16.0/include/node/common.gypi',
    gyp info spawn args   '-Dlibrary=shared_library',
    gyp info spawn args   '-Dvisibility=default',
    gyp info spawn args   '-Dnode_root_dir=/root/.node-gyp/8.16.0',
    gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/noe-gyp',
    gyp info spawn args   '-Dnode_lib_file=/root/.node-gyp/8.16.0/<(target_arch)/noe.lib',
    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/iobroker.sbspot/node_modules/sqlite3',
    gyp info spawn args   '-Dnode_engine=v8',
    gyp info spawn args   '--depth=.',
    gyp info spawn args   '--no-parallel',
    gyp info spawn args   '--generator-output',
    gyp info spawn args   'build',
    gyp info spawn args   '-Goutput_dir=.' ]
    gyp info ok
    gyp info spawn make
    gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    make: Entering directory '/opt/iobroker/node_modules/iobroker.sbfspot/node_modues/sqlite3/build'
      ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/bj/gen/sqlite-autoconf-3300100/sqlite3.c
      TOUCH Release/obj.target/deps/action_before_build.stamp
      CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o
    cc: internal compiler error: Killed (program cc1)
    Please submit a full bug report,
    with preprocessed source if appropriate.
    See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
    deps/sqlite3.target.mk:129: recipe for target 'Release/obj.target/sqlite3/gen/slite-autoconf-3300100/sqlite3.o' failed
    make: *** [Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o] Eror 4
    make: Leaving directory '/opt/iobroker/node_modules/iobroker.sbfspot/node_moduls/sqlite3/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_moduls/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces.js:198:12)
    gyp ERR! System Linux 4.14.98-v7+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_mdules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/nodesqlite3.node" "--module_name=node_sqlite3" "--module_path=/opt/iobroker/node_moules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm" "--npi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_labe=node-v57"
    gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3
    gyp ERR! node -v v8.16.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_mdules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --modle=/opt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/bindingnode-v57-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/pt/iobroker/node_modules/iobroker.sbfspot/node_modules/sqlite3/lib/binding/nodev57-linux-arm --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --noe_napi_label=node-v57' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modles/iobroker.sbfspot/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/chld_process.js:209:5)
    node-pre-gyp ERR! System Linux 4.14.98-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.bfspot/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.sbfspot/node_modules/qlite3
    node-pre-gyp ERR! node -v v8.16.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gy/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/obroker.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite.node --module_name=node_sqlite3 --module_path=/opt/iobroker/node_modules/iobroer.sbfspot/node_modules/sqlite3/lib/binding/node-v57-linux-arm --napi_version=4--node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! sqlite3@4.1.1 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the sqlite3@4.1.1 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional loging output above.
    npm ERR!     /root/.npm/_logs/2020-01-12T14_53_55_158Z-debug.log
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #102
    @Tottbeck nein, das liegt an den Abhängigkeiten und dem installer von sqlite3...
    Ich werde bei den Entwicklern von sqlite ein issue aufmachen, dafür brauche ich aber weitere Infos und Zeit...
    Kannst du bitte mal folgenden Versuch machen?
    Bitte mal bei dir auf dem Zielsystem (Raspi) irgendwo (evtl. im home) ein Verzeichnis anlegen und dort eine package.json mit folgendem Inhalt anlegen:
    cd ~
    mkdir sqlite_test
    cd sqlite_test
    nano package.json
    und dort hineinkopieren:
      "name": "test",
      "license": "MIT",
      "optionalDependencies": {
        "sqlite3": "^4.1.1"
      "dependencies": {
        "mysql": "^2.17.1"
      "devDependencies": {
        "gulp": "^4.0.0",
        "mocha": "^6.0.2",
        "chai": "^4.2.0"
    mit SRG-O speichern und STRG-X nano verlassen.
    und dann
    npm install
    aufrufen. Wenn das fehlerfrei läuft, könntest du versuchen, den node_modules - Ordner in das iobroker.sbfspot-Verzeichnis zu kopieren. Ich habe das hier bei mir probiert, da geht es. Ob das immer funktioniert, kann ich nicht sagen... Im Fehlerfall bin ich auch an diesem log interessiert...
    • Rene_HMR Rene_HM
      @wm20320 schau mal, was im browser in der web-console steht, vielleicht hilft das...
      W Offline
      W Offline
      wm20320
      #103
      @Rene_HM Danke für den Tipp, hilft mir leider nicht sehr weiter, da kenn ich mich skriptmäßig zu wenig aus. Das einzige, was ich da feststellen kann, dass das sbfspot-Widget Fehler erzeugt und alls paar Sekunden "need to wait" ausgibt.
      Komisch ist, dass das auf 2 Systemen mit unterschiedlichen Browsern im Edit-Modus so ist. An den Endgeräten erscheint natürlich logischerweise auch nichts.
      Rene_HMR 1 Antwort Letzte Antwort
      • W wm20320
        Rene_HMR Offline
        Rene_HMR Offline
        Rene_HM
        #104
        @wm20320 poste doch mal das log. Am besten im vis-Editor und dann einfach mal die Instanz neu eingeben. Das triggert das widget intern. Dann finden wir schon den Fehler...
        • Rene_HMR Rene_HM
          cd ~
          mkdir sqlite_test
          cd sqlite_test
          nano package.json
            "name": "test",
            "license": "MIT",
              "sqlite3": "^4.1.1"
            "dependencies": {
              "mysql": "^2.17.1"
              "gulp": "^4.0.0",
              "mocha": "^6.0.2",
              "chai": "^4.2.0"
          und dann
          npm install
          Tottbeck
          #105
          @Rene_HM
          Habe das als user "pi" per "sudo npm install" installiert. Hat als root aber auch nicht geklappt.
          pi@raspberrypi:~ $ cd ~
          pi@raspberrypi:~ $ mkdir sqlite_test
          pi@raspberrypi:~ $ cd sqlite_test
          pi@raspberrypi:~/sqlite_test $ nano package.json
          pi@raspberrypi:~/sqlite_test $ sudo npm install
          > sqlite3@4.1.1 install /home/pi/sqlite_test/node_modules/sqlite3
          node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.1.1/node-v57-linux-arm.tar.gz
          node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.1.1 and node@8.16.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
          gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.16.0"
          gyp WARN EACCES attempting to reinstall using temporary dev dir "/tmp/.node-gyp"
          make: Entering directory '/home/pi/sqlite_test/node_modules/sqlite3/build'
            ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3300100/sqlite3.c
          deps/sqlite3.target.mk:129: recipe for target 'Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o' failed
          make: *** [Release/obj.target/sqlite3/gen/sqlite-autoconf-3300100/sqlite3.o] Error 4
          make: Leaving directory '/home/pi/sqlite_test/node_modules/sqlite3/build'
          gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/home/pi/sqlite_test/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/home/pi/sqlite_test/node_modules/sqlite3/lib/binding/node-v57-linux-arm" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
          gyp ERR! cwd /home/pi/sqlite_test/node_modules/sqlite3
          gyp ERR! not ok
          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/home/pi/sqlite_test/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/home/pi/sqlite_test/node_modules/sqlite3/lib/binding/node-v57-linux-arm --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/sqlite_test/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
          node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/sqlite_test/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          node-pre-gyp ERR! cwd /home/pi/sqlite_test/node_modules/sqlite3
          npm notice created a lockfile as package-lock.json. You should commit this file.
          npm WARN test@ No description
          npm WARN test@ No repository field.
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sqlite3@4.1.1 (node_modules/sqlite3):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: sqlite3@4.1.1 install: `node-pre-gyp install --fallback-to-build`
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
          added 405 packages from 735 contributors and audited 6882 packages in 907.574s
          found 0 vulnerabilities
          • T Tottbeck
            @Rene_HM
            gyp ERR! not ok
            Rene_HMR Offline
            Rene_HMR Offline
            Rene_HM
            #106
            @Tottbeck hab ein issue bei den Entwicklern von sqlite3 erstellt...
            • Rene_HMR Rene_HM
              Tottbeck
              #107
              @Rene_HM
              Danke Dir.
              Ich habe zwischenzeitlich u.a. das iobroker fix-script laufen lassen, weil das Update auf sbfspot 2.4.0 auch nicht klappte wegen irgendwelchen npm-Abhängigkeiten.
              Nach dem fix ging das 2.4.0-update. Danach gab ab es beim "sudo npm install" im sbfspot-Ordner zwar auch viele komische Meldungen aber jetzt geht der Adapter wieder. 😲
              • J Offline
                jonnz
                #108
                ich bin recht neu bei IoBroker und habe mich die letzten Wochen über Google und das Forum durchgekämpft. Hat auch prima geklappt und die erste Version steht. Nun habe ich aber seit Tagen ein Thema mit SBFspot und komme selber nicht weiter (und finde leider trotz intensiver Suche die Lösung nicht).
                Zu meinem System:
                Habe IoBroker (Buanet.Iobroker) auf meiner Synology 218+ im Docker laufen.
                SQL läuft als über MariaDB und Zugriff über Iobroker SQL-Adapter ist installiert, verbunden…alles grün.
                Wechelrichter ist ein SMA 5000 TL-21
                Habe jetzt SBFspot installiert und auch die Daten für den Datenbankzugriff eingetragen…….nur es tut sich rein gar nichts.
                Im Widget ist Instanz als SBFspot.0 eingetragen, Seriennummer ist auch drin.
                Bei der Suche über das Terminal finde ich aber nur einen Ordner Iobroker.Sbfspot – z.B. die SBFspot.cfg ist nicht zu finden…..
                Soweit ich das verstehe, muss ich auch noch irgendwie die Bluetooth-MAC usw. eintragen?
                Wäre für Unterstützung echt dankbar…
                Grüße jonnz
                • J jonnz
                  Zu meinem System:
                  Grüße jonnz
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  #109
                  @jonnz hast du sbfspot selbst auch installiert?
                  siehe https://github.com/SBFspot/SBFspot und https://github.com/SBFspot/SBFspot/wiki
                  Der Adapter greift nur auf die Datenbank zu, gefüllt wird sie von sbfspot...
                  • J Offline
                    jonnz
                    #110
                    @Rene_HM
                    Danke für die schnelle Antwort - mit dem letzten Satz ist es mir etwas klarer geworden. Ich habe zwar die Datenbank am laufen und auch den Adapter installiert aber sbfspot an sich nicht.
                    Muss jetzt erstmal schauen wie ich das unter Iobroker im Docker heruntergeladen und installiert bekomme.....bin nicht so Linuxerfahren und der psftp hat so seine Probleme. Zumindest die Ordner habe ich aber mal gemäß Anleitung angelegt.
                    Es geht voran.....
                    • J Offline
                      jonnz
                      #111
                      Hab SBFspot heruntergeladen und installiert - nur mit dem editieren der SBFspot.cfg komme ich nicht weiter.
                      Bin nicht in der Lage einen Editor zu öffnen oder zu installieren um da die Werte zu ändern.
                      Dachte ich änder dann die Datei unter Windows und kopier es "einfach" rüber aber Dateiaustausch bekomme ich über putty auch nicht hin - lande auf meiner NAS.
                      Jemand ne Ahnung was ich falsch machen?
                      Danke vorab..
                      • J jonnz
                        Danke vorab..
                        Rene_HMR Offline
                        Rene_HMR Offline
                        Rene_HM
                        schrieb am zuletzt editiert von Rene_HM
                        #112
                        @jonnz z.Bsp. mit nano
                        sudo nano /usr/local/bin/sbfspot.3/SBFspot.cfg
                        • J Offline
                          jonnz
                          schrieb am zuletzt editiert von jonnz
                          #113
                          Guten Abend,
                          erstmal danke die bisherige Unterstützung...da ich bei Iobroker so nicht weitergekommen bin -
                          bin ich jetzt umgestiegen und habe SBFspot auf nem Raspi installiert. Soweit so gut...bekomme aber folgende Meldung (en)...
                          Wollte eigentlich folgende Konfiguration:
                          • Iobroker läuft auf Synology unter Docker
                          • MySQL auf Synology
                          • SBFspot auf Raspi
                          • Daten werden von Raspi auf MySQL-DB geschrieben
                          • SBFspot-Adapter liest Daten in MySQL aus..
                          Hab jetzt oben schon gesehen, dass ich mit sudo make install_mysql eine neue DB erstellen muss...aber mir ist nicht ganz klar wo/wie....bekomme "No rule to make target 'install_mysql'. Stop"...
                          Gruß und Danke..
                          • J jonnz
                            Guten Abend,
                            • SBFspot auf Raspi
                            Gruß und Danke..
                            Rene_HMR Offline
                            Rene_HMR Offline
                            Rene_HM
                            #114
                            @jonnz sagte in Neuer Adapter: SMA Wechselrichter mit sbfspot:
                            Dann bist du nicht im richtigen Verzeichnis.... Für den Raspi gibt es doch auf den wiki-Seiten von sbfspot eine gute Anleitung...
                            • J Offline
                              jonnz
                              #115
                              Ja die Docu ist wirklich gut - hab´s jetzt auch am Laufen - SBFSpot hat den WR und es werden Daten in die SQLite-Datenbank auf dem Raspberry geschrieben.
                              Ich krieg´s allerdings nicht hin, dass ich vom IObroker (Synology) auf die Daten (Raspi) zugreife.....das ist grad die große Herausforderung...
                              • J jonnz
                                Rene_HMR Offline
                                Rene_HMR Offline
                                Rene_HM
                                #116
                                @jonnz ich habe bei mir auf dem System, auf dem sbfspot läuft, auch iobroker (als slave) installiert und lasse dort den Adapter laufen.
                                • J Offline
                                  jonnz
                                  #117
                                  @Rene_HM
                                  Die Frage ist was muss ich da einstellen oder vielmehr freigeben...hab im Adapter folgendes probiert..
                                  http://192.168.178.105/home/pi/smadata/SBFspot.db (die IP vom Raspi).....aber SBFspot hat keine Daten...wobei ich ja für den Raspi ohne Login & Passwort brauche.
                                  Gebe ich nur mal die IP im Browser ein, dann meldet sich der Apache-Server....in der Apache2.config habe ich das o.a. Verzeichnis mal auf die Whitelist gesetzt. Auch ohne Effekt....
                                  • Nutzt Du dann auch SQLite?
                                  • Wie hast Du das zwischen Master und Slave freigegeben?
                                  Danke Dir schonma....
                                  • J jonnz
                                    @Rene_HM
                                    Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    #118
                                    Eine einfache Freigabe wird nicht funktionieren...
                                    ich habe beides (mariaDB und SQLite) im Einsatz.. mariaDB könnte man über das Netzwerk erreichen, SQLite ist lokal...
                                    Das findest du unter
                                    https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                                    • J Offline
                                      jonnz
                                      #119
                                      Werd mich mal daran machen den Pi als Slave zum laufen zu bekommen.
                                      Problem bei MariaDB - hab das schon installiert aber bei der Installation wurde nicht nach PW gefragt. Wenn ich jetzt versuche mich anzumelden (PHPmyadmin) dann gehts nicht über root da ich ja kein PW habe. Kann mich nur als phpmyadmin anmelden und dann aber ohne Rechte..
                                      • alex9926A Offline
                                        alex9926A Offline
                                        alex9926
                                        #120
                                        ich habe sbfspot auf meinem Raspberry Pi 3B installiert und es werden auch Daten empfangen. Alleridings bekomme ich die Daten nicht in den ioBroker. Das System lief bereits ca. 1 Jahr bei mir bis der Pi abgeschmirt ist. Hat da jemand eine Idee?
                                        Der Befehl
                                        /usr/local/bin/sbfspot.3/SBFspot -v -finq -nocsv
                                        liefert Daten aber ich bekomme sie nicht in den ioBroker.
                                        • alex9926A alex9926
                                          Der Befehl
                                          Rene_HMR Offline
                                          Rene_HMR Offline
                                          Rene_HM
                                          #121
                                          @alex9926 Bitte beachte, dass sbsfspot die Daten in eine Datenbank schreibt. Der Adapter holt sich die Daten aus der Datenbank!
                                          Hast du geprüft, ob die Daten in der Datenbank ankommen? Hast du Zugriff? Welche Datenbank nutzt du (mariaDB oder sqlite)?
