  4. JavaScript
  5. Sonoff Geräte als HTML Tabelle - Vis
    6.6k
javascriptmonitoringtemplate
632 Beiträge 34 Kommentatoren 202.5k Aufrufe 39 Beobachtet
    @liv-in-sky Moin,
    bei mir läuft das aktuelle Skript nicht mehr. Ich bekomme dieses im log:
    javascript.0	2020-01-26 10:03:00.155	error	(26285) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-26 10:03:00.154	error	(26285) at ontimeout (timers.js:436:11)
    javascript.0	2020-01-26 10:03:00.154	error	(26285) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-26 10:03:00.153	error	(26285) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-26 10:03:00.153	error	(26285) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-26 10:03:00.152	error	(26285) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-01-26 10:03:00.151	error	(26285) at Object.<anonymous> (script.js.java.sonstige.Sonoff_Tabelle_neueste:2863:2)
    javascript.0	2020-01-26 10:03:00.151	error	(26285) at writeHTML (script.js.java.sonstige.Sonoff_Tabelle_neueste:2037:30)
    javascript.0	2020-01-26 10:03:00.151	error	(26285) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-01-26 10:03:00.149	error	(26285) at script.js.java.sonstige.Sonoff_Tabelle_neueste:2061:60
    javascript.0	2020-01-26 10:03:00.149	error	(26285) Error in callback: TypeError: Cannot read property 'replace' of null
    javascript.0	2020-01-26 10:03:00.147	warn	(26285) at Timer.processTimers (timers.js:223:10)
    javascript.0	2020-01-26 10:03:00.147	warn	(26285) at listOnTimeout (timers.js:263:5)
    javascript.0	2020-01-26 10:03:00.146	warn	(26285) at tryOnTimeout (timers.js:300:5)
    javascript.0	2020-01-26 10:03:00.146	warn	(26285) at ontimeout (timers.js:436:11)
    javascript.0	2020-01-26 10:03:00.146	warn	(26285) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0	2020-01-26 10:03:00.145	warn	(26285) at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0	2020-01-26 10:03:00.145	warn	(26285) at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0	2020-01-26 10:03:00.145	warn	(26285) at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1319:34)
    javascript.0	2020-01-26 10:03:00.144	warn	(26285) at Object.<anonymous> (script.js.java.sonstige.Sonoff_Tabelle_neueste:2863:2)
    javascript.0	2020-01-26 10:03:00.144	warn	(26285) at writeHTML (script.js.java.sonstige.Sonoff_Tabelle_neueste:2037:30)
    javascript.0	2020-01-26 10:03:00.144	warn	(26285) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-01-26 10:03:00.144	warn	(26285) at script.js.java.sonstige.Sonoff_Tabelle_neueste:2061:16
    javascript.0	2020-01-26 10:03:00.142	warn	(26285) getState "sonoff.0.Weihnachtsbaum.INFO.Version" not found (3)
    javascript.0	2020-01-26 10:02:46.814	error	(26285) at Script.runInContext (vm.js:133:20)
    javascript.0	2020-01-26 10:02:46.814	error	(26285) at script.js.java.sonstige.Sonoff_Tabelle_neueste:2869:2
    javascript.0	2020-01-26 10:02:46.814	error	(26285) at writeHTML (script.js.java.sonstige.Sonoff_Tabelle_neueste:2037:30)
    javascript.0	2020-01-26 10:02:46.813	error	(26285) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-01-26 10:02:46.813	error	(26285) at script.js.java.sonstige.Sonoff_Tabelle_neueste:2061:60
    javascript.0	2020-01-26 10:02:46.813	error	(26285) TypeError: Cannot read property 'replace' of null
    javascript.0	2020-01-26 10:02:46.813	error	(26285) ^
    javascript.0	2020-01-26 10:02:46.813	error	(26285) val2=getState(id.replace("Module","Version")).val.replace(/\(.+\)/g,"") //sonoff.0.SonoffPow1.Wifi_RSSIsonoff.0.SonoffPow1.POWER
    javascript.0	2020-01-26 10:02:46.813	error	(26285) script.js.java.sonstige.Sonoff_Tabelle_neueste: script.js.java.sonstige.Sonoff_Tabelle_neueste:2061
    javascript.0	2020-01-26 10:02:46.812	warn	(26285) at script.js.java.sonstige.Sonoff_Tabelle_neueste:2869:2
    javascript.0	2020-01-26 10:02:46.812	warn	(26285) at writeHTML (script.js.java.sonstige.Sonoff_Tabelle_neueste:2037:30)
    javascript.0	2020-01-26 10:02:46.811	warn	(26285) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:846:29)
    javascript.0	2020-01-26 10:02:46.811	warn	(26285) at script.js.java.sonstige.Sonoff_Tabelle_neueste:2061:16
    javascript.0	2020-01-26 10:02:46.810	warn	(26285) getState "sonoff.0.Weihnachtsbaum.INFO.Version" not found (3)
    javascript.0	2020-01-26 10:02:46.759	info	(26285) Start javascript script.js.java.sonstige.Sonoff_Tabelle_neueste
    liv-in-skyL Offline
    liv-in-skyL Offline
    #200
    @Meister-Mopper zeig mal ein bild - alles aufgeklappt - mit rechter werte seite- vom weihnachtsbaum sonoff - gibt es den ?
    hast du evtl beim kopieren etwas ersetzt - die zeileangaben sind so hoch, dass es meist daran liegt
      @liv-in-sky Moin,
      liv-in-skyL Offline
      liv-in-skyL Offline
      #201
      @Meister-Mopper um auszuschliessen, dass es ein copy fehler war
      am besten das script vom ersten post in ein neues script bei dir kopieren - dann nur die beiden datenpunkte angleichen und starten - das alte script zuvor stoppen
      dann kommen zwar alle überschriften - aber erstmal weiß man, ob die neue version läuft - danach kann man seine eigenen settings in das neue übertragen
      Meister MopperM ? 2 Antworten Letzte Antwort
      • liv-in-skyL liv-in-sky
        Meister MopperM Online
        Meister Mopper
        #202
        @liv-in-sky Es lag tatsächlich an der Steckdose "Weihnachtsbaum", die ja bekanntermaßen nur begrenzt zum Einsatz kommt. Ich habe sie aus den Objekten gelöscht und alles läuft.
        Proxmox und HA ...
          #203
          Bitte meinen Post löschen :)
            NEUE VERSION DES SCRIPT's HIER: https://forum.iobroker.net/post/601855
            hier eine tabelle mit sonoff devices in html zur anzeige in iqontrol, vis oder als webseite - die tabelle kaann verschieden formatiert werden - farben, linien, abstande, schriftart, ...
            grundlage für die einstellung der tabellenparameter ist hier : https://forum.iobroker.net/topic/28021/html-table-für-vis-oder-iqontrol-js-und-blockly/96
            wichtig - ihr müßt euch einen eigenen datenpunkt als zeichenkette anlegen und diesen dann im script (ganz oben "dpVIS") eingeben
            darunter werden dann die einzelnen devices freigeschalten - steht eine deviceart auf true und ist im system nicht enthalten, passiert nix außer das die überschrift in der tabelle erscheint und keine geräte da sind
            zusätzlich wird ein datenpunkt für die anzahl benötigt - auch den selbst anlegen und im script (dpAnzahl) einfügen
            wie legt man einen datenpunkt an: https://forum.iobroker.net/post/400338
            das widget ist ein standard html widget und der von euch angelegte datenpunkt wird als binding angegeben -also einfach den datenpunkt unter HTML reinschreiben und in klammern setzen {}
            ein erstes beispiel - es fehlen noch einige sonoffarten - da könnte ich hilfe brauchen, da ich nicht alle arten habe - also falls es da wünsche gibt - einfach melden
            wenn die geräte nicht erreichbar sind:
            aus platz-gründen in einer datei - beim kopieren einen editor verwenden (wegen emojis) - nicht direkt aus browser kopieren sondern datei downloaden und mit editor öffnen und dann in iobroker einfügen !!!
            sonoff-8spalten-tabelle-15.1.21.txt
            script mit 6 spalten - es fehlen die switch: dieses script mit 6 spalten wird nicht weitergepflegt - daher alte version
            sonoff-6spalten-tabelle.txt
            bisher integriert
            • pow
            • generic
            • basic
            • th10
            • schalter2ch
            • schalter3ch
            • dual
            • schalter1ch
            • channel4
            • rfbridge
            • ZbBridge
            • stdoseS2X
            • teckin
            • sv
            • blitzwolf_shp
            • sonoffDev
            • gosundSP1x
            • shelly
            • mini
            • delock
            MyMeyer
            #204
            @liv-in-sky Hi mein Channel 1 von Sonoff wird nicht erkannt. Kannst Du da was machen ?
            MyMeyer
            >>> Hardware: Intel I5 mit ****Debian ProxMox OS: Debian **** <<< >>> Network with UniFi <<<
            >>> HomeMatic CCU-2 (Wired und Funk) / Philips HUE / Echo.DOT / Echo.SHOW / Xiaomi Smart-Home / Xiaomi Robot Vacuum Cleaner / Synology DS 918+ / Shelly 1&2 <<<
            • M MyMeyer
              liv-in-skyL Offline
              liv-in-skyL Offline
              #205
              @MyMeyer mach ich - es kommt bald wieder ein update - morgen - dann ist es drin
              falls schneller
              ungefähr zeile 688 ändern in
              if (getState(id).val=="Sonoff T1 1CH" || getState(id).val=="1 Channel" ) {
              • liv-in-skyL Offline
                liv-in-skyL Offline
                #206
                es gibt ein neues script im ersten post - script muss vollständig neu kopiert werden - zuviele neue settings geändert- was ist dazugekommen:
                • sonoff th mit temp
                • der bereich der spaltenüberschrift (ganz oben) ist in höhe der zelle und schriftfarbe einsellbar
                • unter dieser überschriften kann eine extra linie mit farbe und höhe definiert werden
                • es können für die basics und generic's die sensoren mit angezeigt werden
                ? LatziL 2 Antworten Letzte Antwort
                  #207
                  @liv-in-sky Danke Dir vielmals:-) das geht in Richtung meiner Klimadaten. bei meinem Generic fehlen ein paar Daten :)
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    #208
                    @HeinrichB das liegt daran, dass ich den letzten gefundene wert aufnehme - also nur lux ( temperatur wird gefunden und überschrieben). ich bin eher von basics ausgegangen, bei denen meist nur ein sensor da ist (bei mir ) und zudem wird die spalte zu breit mit all den daten
                    wer bestimmte sensoren daten braucht, muss sich melden - die müßten alle einzeln eingepflegt werden, da sie ja unterschiedliche datenpunktnamen haben - die muss ich erstmal im script herausfinden und dann abfragen
                    ich habe deine klima sache nicht vergessen, sondern mache noch ein paar änderungen bei den anderen tabellen scripts - z.b batterie - im klimascript wäre das finden der datenpunke einfacher, weil wir ja definieren pro gerät - und nur diese suchen würden
                    und meine größte baustelle - ich würde gerne, bei ansicht mehrerer tabellen nebeneinander, einen trennstrich zwischen die tabellen "zaubern" - das gibt ein viel besseres bild zum ansehen, wenn die tabellen nebeneinander sind
                    ? 4 Antworten Letzte Antwort
                      #209
                      @liv-in-sky Danke Dir. Ich wollte einfach dir mein Feedback dazu geben, da ich auch ein paar Prototypen hier habe wie bspw. einen Basic mit Sensoren, einen S20 geöffnet und die Sensoren dran etc. Nur als Feedback und das mit der Spaltenbreite verstehe ich natürlich
                        #210
                        @liv-in-sky said in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                        Und wie du siehst hängen an meinem Generic zwei Sensoren mit 4 DP dran :)
                        • Feuchte
                        • Temp
                        • Luftdruck
                        • Helligkeit
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          #211
                          @HeinrichB hat der s20 mehrer sensorendatenpunkte - theoretisch kann ich für jedes sonoff-module einen datenpunkt für sensoren freischalten - ist nur copy paste für mich
                            #212
                            @liv-in-sky Der S20 ist ein Prototyp mit seinen Sensoren. Lass den mal noch eher weg. Den habe ich augemacht und bin dann mit meinen Sensoren testweise an die Platine und habe da die RX/TX- Daten abgegriffen. Das waren dann auch im Grunde die vier oben genannten, theoretisch aber auch andere, die gerade nicht bei mir auf dem Tisch waren :)
                              #213
                              @liv-in-sky Eine kleine Sache. Bei dem Generic wird der Power-State wohl nicht recht ausgelesen :)
                                #214
                                Ich bin gespannt und freu mich :)
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  #215
                                  @HeinrichB sagte in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                                  ist jetzt drin - im ersten post !
                                    #216
                                    @liv-in-sky Danke Dir :-) Klappt alles jetzt was ich so sehe. Und das mit den Sensordaten haben wir ja besprochen. :)
                                      LatziL Online
                                      LatziL Online
                                      Latzi
                                      #217
                                      @liv-in-sky sagte in Sonoff Geräte als HTML Tabelle - Vis - Iqontrol:
                                      sonoff th mit temp
                                      Genial! Danke 👏
                                      winziger Schönheitsfehler: Bei den 2 Sonoff mit Temp/Luftfeuchte-Soensor stimmt die Einheit nicht (g/m3; sollte % sein) - stört mich persönlich nicht wirklich
                                      ? liv-in-skyL 2 Antworten Letzte Antwort
                                      • LatziL Latzi
                                        sonoff th mit temp
                                        Genial! Danke 👏
                                        #218
                                        • LatziL Latzi
                                          sonoff th mit temp
                                          Genial! Danke 👏
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          #219
                                          @Latzi geändert - im ersten post
                                          LatziL ChaotC 2 Antworten Letzte Antwort
