  4. [gelöst] iobroker offline nach admin update
adminadapterupdatejs.controllerfrage
86 Beiträge 8 Kommentatoren 16.4k Aufrufe 5 Beobachtet
  • J
    J
    JRiddim
    schrieb am zuletzt editiert von JRiddim
    Edit also konnte den js.controller nochmal neu installieren.
    iobroker läuft im Hintergrund, aber komme einfach nicht drauf!
    iobroker l i --port
      system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.hm-rpc.0                : hm-rpc                -  enabled, port: 0
    Hi nach dem update des neuen Admin adapters komme ich nicht mehr auf iobroker.
    Nach Neuinstallation bekomme ich folgende Fehlermeldung.
    sudo npm install iobroker.admin@3.7.7 --production
    npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.admin@3.7.7
    updated 1 package and audited 3971 packages in 18.952s
    15 packages are looking for funding
      run `npm fund` for details
    found 56 vulnerabilities (39 low, 3 moderate, 14 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    iobroker list adapters/instances ergibt:
    iobroker list instances
    internal/modules/cjs/loader.js:638
        throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
        at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
        at Function.Module._load (internal/modules/cjs/loader.js:562:25)
        at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
        at startup (internal/bootstrap/node.js:283:19)
        at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    kann unter node_modules keinen iobroker.js-controller finden.
    beim versuch diesen zu installieren kommt:
    /opt/iobroker $ npm install iobroker.jscontroller
    npm ERR! code E404
    npm ERR! 404 Not Found - GET https://registry.npmjs.org/iobroker.jscontroller - Not found
    npm ERR! 404
    npm ERR! 404  'iobroker.jscontroller@latest' is not in the npm registry.
    npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
    npm ERR! 404
    npm ERR! 404 Note that you can also install from a
    npm ERR! 404 tarball, folder, http url, or git url.
    npm ERR!     /home/juju/.npm/_logs/2020-01-29T16_03_29_506Z-debug.log
    Bin langsam echt am verzweifeln. Ich glaube ich verschlimmbessere nur alles!
    Bin für eure Hilfe sehr dankbar!
    Liebe Grüße
    Jan
    Langsam aber sicher.
    • D
      D
      DaBa6
      schrieb am zuletzt editiert von DaBa6
      @JRiddim anscheinend ist der admin-Adapter nicht mit gestartet.
      Versuch mal in der Konsole folgenden Befehl:
      iobroker start admin.0
      • D DaBa6
        J
        J
        JRiddim
        @DaBa6 danke dir für die Antwort. Brachte leider keinen Erfolg.
        • J JRiddim
          @JRiddim hast du das Update gemacht? Ich hatte gestern Vormittag das gleiche Problem
          https://forum.iobroker.net/topic/29463/gelöst-admin-upd-iobroker-nicht-mehr-erreichbar/24
            J
            J
            JRiddim
            @HeinrichB ja leider nicht über die Konsole
            • J JRiddim
              @JRiddim
              Siehe meinen Dialog gestern dazu
                @JRiddim
                J
                J
                JRiddim
                @HeinrichB danke dir, den Thread habe ich gesehen, habe alles auch durchprobiert...
                • J JRiddim
                  @JRiddim verzeih meine Einmischung
                    J
                    J
                    JRiddim
                    @HeinrichB ich bin für jede Hilfe dankbar!
                    • J JRiddim
                      haselchenH
                      haselchenH
                      haselchen
                      @JRiddim
                      was kommt unter
                      ps -A | grep iobroker
                      raus
                      • haselchenH haselchen
                        @JRiddim
                        was kommt unter
                        raus
                        J
                        J
                        JRiddim
                        @haselchen
                          541 ?        00:19:16 iobroker.js-con
                        • J JRiddim
                          @haselchen
                          haselchenH
                          haselchenH
                          haselchen
                          @JRiddim
                          ok
                          erst den befehl eingeben
                          cd /opt/iobroker
                          dann den
                          node node_modules/iobroker.js-controller/controller.js --logs
                            @JRiddim
                            ok
                            cd /opt/iobroker
                            dann den
                            J
                            J
                            JRiddim
                            @haselchen sagte in iobroker nicht mehr erreichbar nach admin update:
                            2020-01-29 22:32:59.327  - info: host.raspberrypi iobroker.js-controller version 2.2.8 js-controller starting
                            2020-01-29 22:32:59.336  - info: host.raspberrypi Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                            2020-01-29 22:32:59.337  - info: host.raspberrypi hostname: raspberrypi, node: v10.18.1
                            2020-01-29 22:32:59.339  - info: host.raspberrypi ip addresses: 192.168.100.50 fe80::dea6:32ff:fe0a:7cb6 fe80::fc97:c0ff:fef0:a5a8
                            2020-01-29 22:32:59.803  - info: host.raspberrypi  Error inMem-objects listening on port 9001
                            2020-01-29 22:33:00.351  - info: host.raspberrypi  Error inMem-states listening on port 9000
                            2020-01-29 22:33:00.405  - info: host.raspberrypi connected to Objects and States
                            2020-01-29 22:33:00.551  - info: host.raspberrypi 33 instances found
                            host.raspberrypi check instance "system.adapter.discovery.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.info.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.mihome-vacuum.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.telegram.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.hue.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.hm-rpc.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.hm-rega.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.hm-rpc.1" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.ping.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-hqwidgets.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-jqui-mfd.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-metro.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.spotify-premium.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-google-fonts.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-fancyswitch.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-bars.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-history.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.ical.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.vis-justgage.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.weatherunderground.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.yr.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.backitup.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.terminal.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.zigbee.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.javascript.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.yahka.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.youtube.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.admin.0" for host "raspberrypi"
                            host.raspberrypi check instance "system.adapter.admin.1" for host "raspberrypi"
                            2020-01-29 22:33:00.615  - info: host.raspberrypi starting 30 instances
                            2020-01-29 22:33:00.665  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 19462
                            ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
                            2020-01-29 22:33:02.894  - error: host.raspberrypi instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                            2020-01-29 22:33:02.894  - info: host.raspberrypi Do not restart adapter system.adapter.admin.0 because desired by instance
                            ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                            2020-01-29 22:33:04.633  - info: host.raspberrypi instance system.adapter.admin.1 started with pid 19655
                            ================================== > LOG REDIRECT system.adapter.admin.1 => false [Process stopped]
                            2020-01-29 22:33:06.831  - error: host.raspberrypi instance system.adapter.admin.1 terminated by request of the instance itself and will not be restarted, before user restarts it.
                            2020-01-29 22:33:06.832  - info: host.raspberrypi Do not restart adapter system.adapter.admin.1 because desired by instance
                            ================================== > LOG REDIRECT system.adapter.admin.1 => false [system.adapter.admin.1.logging]
                            2020-01-29 22:33:08.633  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 19684
                            2020-01-29 22:33:10.198  - error: host.raspberrypi instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            2020-01-29 22:33:10.199  - info: host.raspberrypi Restart adapter system.adapter.discovery.0 because enabled
                            2020-01-29 22:33:12.632  - info: host.raspberrypi instance system.adapter.info.0 started with pid 19861
                            2020-01-29 22:33:14.750  - error: host.raspberrypi instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            2020-01-29 22:33:14.751  - info: host.raspberrypi Restart adapter system.adapter.info.0 because enabled
                            2020-01-29 22:33:16.630  - info: host.raspberrypi instance system.adapter.mihome-vacuum.0 started with pid 19893
                            2020-01-29 22:33:18.147  - error: host.raspberrypi instance system.adapter.mihome-vacuum.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            2020-01-29 22:33:18.148  - info: host.raspberrypi Restart adapter system.adapter.mihome-vacuum.0 because enabled
                            2020-01-29 22:33:20.631  - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 20087
                            das will nicht mehr aufhören geht ewig weiter
                            • J JRiddim
                              haselchenH
                              haselchenH
                              haselchen
                              @JRiddim
                              gib iobroker stop ein
                              dann
                              npm install iobroker.js-controller
                              dann
                              iobroker start
                              J 2 Antworten Letzte Antwort
                                @JRiddim
                                dann
                                dann
                                iobroker start
                                J
                                J
                                JRiddim
                                tut sich nichts läuft munter weiter. Kann ich die Konsole einfach schließen?
                                • J JRiddim
                                  haselchenH
                                  haselchenH
                                  haselchen
                                  @JRiddim
                                  Ich mach das immer nach try and error.
                                  Auf eigene Gefahr.
                                  Ich hatte das Problem auch.
                                  Und bin die Befehle durchgegangen.
                                  Versuch mal iobroker neu zu starten. Also das Gerät.
                                    @JRiddim
                                    dann
                                    dann
                                    iobroker start
                                    J
                                    J
                                    JRiddim
                                    @JRiddim
                                    dann
                                    dann
                                    iobroker start
                                    auf der Ebene opt/iobroker oder?
                                    • J JRiddim
                                      @JRiddim
                                      dann
                                      dann
                                      iobroker start
                                      haselchenH
                                      haselchenH
                                      haselchen
                                      @JRiddim
                                      richtig.
                                        @JRiddim
                                        richtig.
                                        J
                                        J
                                        JRiddim
                                        @haselchen
                                        erhalte diese Meldung dabei.
                                        npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                                        > iobroker.js-controller@2.2.8 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                        > node lib/preinstallCheck.js
                                        NPM version: 6.13.4
                                        > iobroker.js-controller@2.2.8 install /opt/iobroker/node_modules/iobroker.js-controller
                                        > node iobroker.js setup first
                                        + iobroker.js-controller@2.2.8
                                        updated 1 package and audited 4821 packages in 35.829s
                                        12 packages are looking for funding
                                        found 57 vulnerabilities (40 low, 3 moderate, 14 high)
                                        • J JRiddim
                                          @haselchen
                                          NPM version: 6.13.4
                                          haselchenH
                                          haselchenH
                                          haselchen
                                          @JRiddim
                                          Viele Wege führen hier nach Rom.
                                          Kommste mit iobroker start oder iobroker start admin.0 jetzt auf die Oberfläche?
                                          Ansonsten kannst du noch den Fixer laufen lassen oder clever wäre auch beim raspi ein
                                          sudo apt update und dann ein
                                          sudo apt full-upgrade
                                          zu machen.
                                          dann ist der raspberry erstmal auf dem neuesten stand.
                                          84.2k
