  4. Test adapter ZWave2 (v0.9.x)
    6.4k
z-wavetestzwave
175 Beiträge 15 Kommentatoren 34.0k Aufrufe 14 Beobachtet
  • malorossM Offline
    malorossM Offline
    maloross
    schrieb am zuletzt editiert von maloross
    #76
    Nach Upgrade auf 9.3 werden 2 von 17 Geräten nicht gefunden.
    Upgrade Vorgehensweise:
    • Installation über Konsole und NPM
    • Restart ioB
    im ioB-Log steht
    zwave2.0	2020-01-28 12:40:33.206	info	(5263) Node 4: is now dead
    zwave2.0	2020-01-28 12:40:18.290	info	(5263) Node 4: is now awake
    zwave2.0	2020-01-28 12:40:17.984	info	(5263) Node 4: has returned from the dead
    zwave2.0	2020-01-28 12:39:42.227	info	(5263) Node 4: is now dead
    zwave2.0	2020-01-28 12:39:27.265	info	(5263) Node 4: is now awake
    zwave2.0	2020-01-28 12:39:26.948	info	(5263) Node 4: has returned from the dead
    zwave2.0	2020-01-28 12:38:33.232	info	(5263) Node 4: is now dead
    zwave2.0	2020-01-28 12:38:18.279	info	(5263) Node 4: is now awake
    zwave2.0	2020-01-28 12:38:18.036	info	(5263) Node 4: has returned from the dead
    zwave2.0	2020-01-28 12:37:53.588	info	(5263) Node 20: is now asleep
    zwave2.0	2020-01-28 12:37:43.586	info	(5263) Node 20: is now awake
    zwave2.0	2020-01-28 12:37:42.702	info	(5263) Node 4: is now dead
    zwave2.0	2020-01-28 12:37:27.749	info	(5263) Node 4: is now awake
    zwave2.0	2020-01-28 12:37:27.445	info	(5263) Node 4: has returned from the dead
    zwave2.0	2020-01-28 12:36:30.772	info	(5263) Node 4: is now dead
    zwave2.0	2020-01-28 12:36:24.680	info	(5263) Node 4: is now awake
    Eine Testschaltung führte zu folgendem Fehler:
    zwave2.0	2020-01-28 12:34:01.551	info	(5263) Node 17: has returned from the dead
    zwave2.0	2020-01-28 12:33:55.881	error	(5263) The message will not be sent because node 17 is presumed dead
    zwave2.0	2020-01-28 12:33:52.866	info	(5263) Node 17: is now dead
    zwave2.0	2020-01-28 12:33:52.805	error	(5263) Node 17 did not respond to the current transaction after 3 attempts, it is presumed dead
    zwave2.0	2020-01-28 12:33:52.804	error	(5263) Node 17 did not respond to the current transaction after 3 attempts, it is presumed dead
    Bisher erfolglos durchgeführt:
    • Adapter Neustart
    • Cache leeren
    • Netzwerk heilen -> läuft (?? Button rot) aktuell noch
    zwave-5263.log
    EDIT: Bei Node 4 handelt es sich um einen Wall Plug
    Edit2: js-Controller ist aktuell
    Auch Frauen können sich für Technik begeistern! ;)
    Equipment:
    diverse HM-, HMIP-, Aeotec- Tradfri- Sonos- und Fibaro-Geräte, NAS, Proxmox mit div. LXC,
    • malorossM maloross
      • Restart ioB
      im ioB-Log steht
      • Adapter Neustart
      • Cache leeren
      zwave-5263.log
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #77
      @maloross Danke für den Log. Das scheint beides im Endeffekt an einem ähnlichen Problem zu hängen. Beide Nodes weigern sich bei bestimmten Abfragen zu antworten und werden deswegen als tot markiert.
      Allerdings bekomme ich auch von beiden zuverlässig eine Bestätigung, dass die Nachricht angekommen ist. Ich werde das Verhalten mal überdenken, so ist das nicht sinnvoll.
      malorossM 1 Antwort Letzte Antwort
      • AlCalzoneA AlCalzone
        malorossM Offline
        malorossM Offline
        maloross
        #78
        @AlCalzone sagte in Test adapter ZWave2 (v0.9.x):
        Ja, hatte den Log überflogen und fand das merkwürdig. Auch dass die Schaltung eines erkannten Nodes zu "Tod und Wiederauferstehung" desselben führte.
        Die beiden erkannten Nodes sind dem Stick räumlich am nächsten.
        Durch diese Dauerschleife werden weitere Nodes wohl auch nicht mehr eingegliedert. Im Adapter schaut das so aus:
        so die Ordnerstruktur
        und das ist die Karte
        Equipment:
          AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          #79
          @maloross Ja, die scheinen fast alle einen nicht existenten Config-Parameter abzufragen. Was ist denn z.B. Node 5 für ein Gerät (Hersteller und Typ bitte)?
          malorossM M 2 Antworten Letzte Antwort
            malorossM Offline
            malorossM Offline
            maloross
            #80
            @AlCalzone
            Node 4, 5, 7, 8 und 18 sind Fibaro FGWPE/F Wall Plug Gen5
            Node 9 Aeon Labs Multisensor
            Node 10 Phileo Flood Multisensor
            Node 11 Everspring Motion Sensor
            Node 12 FGS222 Double Relay Switch
            Node 13 und 21 AEON Labs ZW112 Door Window Sensor 6
            Node 16 FGS213 Switch
            Node 17 FGRGBWM441 RGBW Controller
            Node 19 ZME_WALLC-S Secure Wall Controller
            Node 20 FGMS001-ZW5 Motion Sensor
            Equipment:
              @JackWolfskind sagte in Test adapter ZWave2 (v0.9.x):
              Den Debug Level erhöhen bringt nichts, was hat es denn mit dem detailed logging im Adapter auf sich?
              Das schreibt den kompletten Datenaustausch inklusive zusätzlicher Infos mit. Ist hier nicht zielführend, weil die Schnittstelle gar nicht erst geöffnet wird.
              Vielleicht blöde Frage, aber...
              JackWolfskind
              #81
              @AlCalzone In der Tat, ein RPi reboot half :-)
              Hat sich wohl was an der USB Schnittstelle verklemmt ;-)
                @Markus84 Ja kein Problem.
                @JackWolfskind "Cannot allocate memory" klingt für mich nach vollem RAM. Wie sieht da die Auslastung aus?
                @Schuko80 Danke schon mal für die Logs, aber ... bitte, bitte, bitte schick mir doch noch das angefragte vollständige Log vom originalen Z-Wave Adapter:
                Und das bitte nicht vergessen:
                Der OZW_Log hilft mir so leider nicht. Das Interview von Node 4 war noch nicht abgeschlossen, als du die Setpoint-Änderungen durchgeführt hast. Stand denn im ioBroker-Log schon "Scan completed"?
                Außerdem bräuchte ich mindestens ein selbstständiges Aufwachen des Nodes nach abgeschlossenem Interview - dazu musst du den Adapter mit Logging einfach noch ca 20 Minuten laufen lassen.
                Schuko80S Offline
                Schuko80S Offline
                Schuko80
                #82
                Ja ups, sag doch gleich vom OZW Adapter, hab das voll überlesen :man-facepalming:
                Also Scan completed stand aber definitiv im Log, hab jetzt den Cache gelöscht, alles noch mal durchlaufen lassen
                Danach wie folgt vorgegangen:
                1. Node 4 manuell aufgeweckt
                2. Wert von 4 auf 4,5 hochgedreht
                3. Node 4 wieder manuell aufgeweckt
                4. Temperatur über rauf Taste von 4 auf 5 geändert
                5. Temperatur über runter Taste von 5 auf 4 geändert
                6. gewartet, bis Node4 selber aufwacht
                Hier das OZW Log File:
                OZW_log.txt
                Nuc6cayh + Proxmox / Zigbee (Deconz / Conbee I ) / ZWave / Homematic (CCU2)
                  Markus84
                  #83
                  @AlCalzone
                  Was mir gerade noch aufgefallen ist: Meine Rauchmelder setzen den Datenpunkt in deinem Adapter beim Auslösen auf 2. Im anderen Adapter wurde der Wert auf 1 gesetzt. Bevor ich mir die Arbeit 2x machen muss: Lässt du den Datenpunkt für den Alarm unter Node_xxx.Notification.smokeAlarm_sensorStatus und setzt auch beim Auslösen eine 2 oder wird das von dir während der Entwicklung nochmal angepasst?
                  • M Markus84
                    @AlCalzone
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    #84
                    @Markus84 Die Werte sind durch die Spezifikation vorgegeben und werden durch mich nicht verändert. 1 und 2 bedeuten beide "Rauch erkannt", wobei bei der 1 eigentlich noch eine Ortsinfo mitgeliefert wird. Diese kann der Adapter aber noch nicht auslesen und abbilden.
                    Welcher der beiden Werte verwendet wird, hängt vom Gerät ab. Also baue deine Skripts am besten so, dass beide Werte akzeptiert werden.
                      Markus84
                      #85
                      @AlCalzone said in Test adapter ZWave2 (v0.9.x):
                      Besten Dank für die Info, das mache ich!
                      • Schuko80S Schuko80
                        OZW_log.txt
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        #86
                        @Schuko80 Das Log hilft mir weiter :)
                        Ich sehe zwei Unterschiede:
                        1. Beim Interview der Thermostat Setpoint CC macht OZW etwas anders. Meine Implementation folgt nicht exakt den Empfehlungen aus der Spezifikation, was zu den Interview-Problemen führt.
                        2. Das Thermostat scheint beim Aufwachen eine spezielle Nachricht zu senden und erwartet dann, dass die Batterie und die Uhrzeit abgefragt werden. Das macht mein Adapter auch nicht.
                        Ich sehe zu, dass ich das beides behebe - dann sehen wir weiter. Kann aber ein paar Tage dauern.
                        Edit: 2. sollte eigentlich passieren, aber dazu muss erst mal das Interview abgeschlossen werden. Das hängt am 1. Punkt. Wenn der behoben ist, hoffe ich, dass auch die vom Thermostat erwarteten Abfragen seitens des Controllers kommen.
                        • AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          #87
                          Kleines Update:
                          Die letzten Bugs hängen alle ein bisschen zusammen. Ich bin dabei, sie nach und nach zu fixen. 1-2 Dinge stehen noch aus und ich muss danach noch final testen, ob mein System noch tut.
                          Danach bin ich auf eure Tests angewiesen. Derzeit rechne ich Mitte nächster Woche mit der 0.9.4
                            @Markus84 Deine Logs schaue ich mir in Ruhe an.
                            Ist geplant in der Geräteübersicht auch eigene Namen vergeben zu können?
                            Im Objekte-Tab kannst du die Geräte (Node_xyz) in der Namensspalte schon umbenennen, das bleibt dann auch so.
                            Markus84
                            #88
                            Kann es sein, dass du mich vergessen hast? Ich will dich auf gar keinen Fall hetzen und es ist auch nicht eilig. Also wenn es noch dauert, überhaupt kein Problem!
                            • M Markus84
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              #89
                              @Markus84 Kann sein 😓
                                AlCalzoneA Offline
                                AlCalzone
                                #90
                                Version 0.9.4 wird in ein paar Minuten released. Wenn alles so läuft wie ich mir das erhoffe, sollten folgende Probleme gelöst sein:
                                • Kompatibilität mit den Danfoss-Thermostaten - Zumindest das Interview sollte durchlaufen @Schuko80
                                • Markieren von Nodes als tot/schlafend, wenn sie nicht antworten @maloross
                                Wenn es nicht funktioniert, bitte wie immer Logs erstellen :)
                                @Markus84 bitte teste sicherheitshalber auch mal mit der Version, nicht dass deine Probleme damit auch zusammenhängen.
                                R Schuko80S 2 Antworten Letzte Antwort
                                • arteckA Offline
                                  arteckA Offline
                                  arteck
                                  #91
                                  ich hab da mal was
                                  ZWave2
                                  zwaVe old
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #92
                                    und noch einer
                                    node_034 ist ein AEON LAB ZW100 der am Strom hängt..
                                    die 2 Anderen lieferten ganz normal die Datenpunkte der eine nicht... komisch
                                    • arteckA arteck
                                      und noch einer
                                      AlCalzoneA Offline
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #93
                                      @arteck Ohne Logs kann ich dazu nicht viel sagen. Habe auch einen ZW100, der eigentlich am Strom hängt, sich aber teilweise wie ein batteriebetriebener Node verhält.
                                        Rolf_KA
                                        #94
                                        Nur eine kurze Info meinerseits:
                                        Mit deinem aktualisierten 0.9.4 Adapter funktioniert bei mir soweit alles bestens – bin einfach nur glücklich :-)
                                        Morgen sollten dann auch meine Fibaro Rauchmelder eintreffen und ich mach mir da keine Sorgen, dass diese mit deinem Adapter nicht so funktionieren, wie sie sollten ;-)
                                        Meine 2 Node (2+3) mit Batterie und Schlafmodus habe ich auch schon ein paar Tage im Einsatz, die funktionieren auch ohne Probleme bzw. tun genau das, was ich und meine Scripte von denen erwarte. (So viel wie die, würde ich auch gerne mal pennen…)
                                        Also meinen besten Dank und weiter so – vor allem in Ruhe! 👍
                                        • malorossM Offline
                                          malorossM Offline
                                          maloross
                                          #95
                                          Guten Morgen,
                                          gestern die neue Version getestet, das Problem mit den "toten" Geräten ist behoben.
                                          Allerdings wird weiterhin der Fibaro FGS222 Double Relay Switch 2x1.5kW nicht bzw. nicht korrekt erkannt.
                                          Hier zwave-23590.log
                                          Ordnerstruktur alter Adapter
                                          Equipment:
