  4. can't find python
can't find python
windowssqlpython
24 Beiträge 5 Kommentatoren 2.2k Aufrufe 5 Beobachtet
  • sigi234S sigi234
    @bahnuhr
    Windows Version installieren.
    https://www.python.org/downloads/release/python-2710/
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    @sigi234
    Die ist aber doch schon installiert mit "windows-build-tools"
    C:\iobroker>where python
    C:\Users\Dieter\.windows-build-tools\python27\python.exe
    C:\Users\Dieter\AppData\Local\Microsoft\WindowsApps\python.exe
    Danke.
    • sigi234S sigi234
      @bahnuhr
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @sigi234 sagte in can't find python:
      @bahnuhr
      Habs trotzdem mal installiert, keine Veränderung.
      Weiterhin folgende Fehlermeldung!
      $ ./iobroker add sql  --host HP-Prodesk-400
      NPM version: 6.4.1
      npm install iobroker.sql@1.9.4 --loglevel error --prefix "C:/iobroker" (System call)
      gyp
       ERR! configure error gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack     at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)gyp ERR! stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29gyp ERR! stack     at FSReqWrap.oncomplete (fs.js:153:21)
      gyp ERR! System Windows_NT 10.0.18363gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\iobroker\node_modules\iobroker.sql\node_modules\mmmagicgyp ERR! node -v v10.15.3
      gyp ERR! node-gyp -v v3.8.0gyp ERR!
       not ok
      npm
       ERR! code ELIFECYCLEnpm ERR! errno 1
      npm
       ERR! mmmagic@0.5.3 install: `node-gyp rebuild`npm ERR! Exit status 1
      npm ERR!
       npm
      ERR! Failed at the mmmagic@0.5.3 install script.npm
       ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2020-01-26T07_26_25_684Z-debug.log
      ERROR: host.HP-Prodesk-400 Cannot install iobroker.sql@1.9.4: 1
      Danke.
      • bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        habe es auch mit verschiedenen node Versionen (8.15, 10.18, etc) probiert.
        Klappt nicht.
        Noch jemand eine Idee ?
        Danke.
        • bahnuhrB bahnuhr
          Klappt nicht.
          SBorgS Offline
          SBorgS Offline
          SBorg
          schrieb am zuletzt editiert von SBorg
          @bahnuhr Taucht Python denn auch im Pfad auf? DOS-Eingabe: path
          Falls nicht, versuche mal:
          • WIN + Pause
          • Erweiterte Systemeinstellungen
          • Umgebungsvariablen
          • bei "Systemvariablen" Path anklicken + bearbeiten
          • C:\Users\Dieter.windows-build-tools\python27\python.exe hinzufügen
          Soweit ich mich noch erinnern kann übernimmt er "Systemvariablen" nur beim Start? --> reboot
          LG SBorg ( SBorg auf GitHub)
          • SBorgS SBorg
            • WIN + Pause
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            @SBorg sagte in can't find python:
            • WIN + Pause
            Bei Win+Pause tut sich gar nichts.
            In den Umgebungsvariablen hab ich dieses:
            Sieht doch ok aus.
            Noch ne Idee ?
            Danke.
            • bahnuhrB bahnuhr
              • WIN + Pause
              Sieht doch ok aus.
              Noch ne Idee ?
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @bahnuhr sagte in can't find python:
              Noch ne Idee ?
              Im ioBroker-Ordner eine Datei .npmrc anlegen, falls sie nicht schon existiert und folgende Zeile einfügen:
              python=C:\Users\Dieter.windows-build-tools\python27\python.exe
              Klappt so zumindest auf FreeBSD, daher schätze ich, dass es auf Windows auch klappt.
              Aber sollte das nicht auch ohne manuelles Eingreifen funktionieren? @Stabilostick
              bahnuhrB 2 Antworten Letzte Antwort
              • AlCalzoneA AlCalzone
                Noch ne Idee ?
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @AlCalzone sagte in can't find python:
                Das dachte ich auch.
                Und der Hinweis kam auch nur bei der Installation von "sql". Die anderen Adapter liefen einwandfrei durch.
                Wäre schön wenn wir dies lösen könnte.
                @Homoran
                @apollon77
                @AlCalzone
                @Stabilostick
                Würde auch anbieten, dass ich die Beschreibung "manuelle Installation" auf iobroker.de mal überarbeiten könnte (wenn gewünscht). Denn diese funktioniert ja nicht.
                Danke.
                • bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  Und wie ihr hier seht:
                  https://forum.iobroker.net/topic/29244/iob-auf-win-10-manuelle-installation/4
                  klappt die manuelle Installation bei node 10.18. und npm 6.13 nicht mehr.
                  Es kommt da ständig der Hinweis "semver".
                  Vielleicht könnten wir auch dies lösen.
                  Würde mich als Tester anbieten.
                  Danke.
                  apollon77A AlCalzoneA 2 Antworten Letzte Antwort
                  • bahnuhrB bahnuhr
                    @Homoran
                    @apollon77
                    @AlCalzone
                    @Stabilostick
                    Sehr gern!
                    Du kannst es auf https://github.com/ioBroker/ioBroker.docs/blob/master/docs/de/install/windows.md (ist es das was du meinst) bzw über den Edit link auf der Webseite editieren und als PR einreichen :-)
                    • bahnuhrB bahnuhr
                      @bahnuhr Ich habe dort mal was geantwortet. Das hat mit ioBrokewr nix zu tun ... das ist npm magie und sowas :-(
                      • apollon77A apollon77
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @apollon77 sagte in can't find python:
                        --logevel=error
                        Müsste dies nicht "loglevel" heißen.
                        Danke.
                        • bahnuhrB bahnuhr
                          --logevel=error
                          @bahnuhr Ja, sollte es :-)
                          • bahnuhrB bahnuhr
                            AlCalzoneA Offline
                            AlCalzoneA Offline
                            AlCalzone
                            @bahnuhr Meinen Vorschlag mal probiert?
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              Klappt erst heute abend.
                              Melde mich dann.
                              Danke.
                                Noch ne Idee ?
                                bahnuhrB Online
                                bahnuhrB Online
                                bahnuhr
                                Noch ne Idee ?
                                So, Rückinfo von mir:
                                Datei war auf meinem Win10 Rechner nicht da (auf Win7 schon ?!)
                                Dienst gestoppt.
                                Datei angelegt und Zeile eingefügt (hinter Dieter noch \ eingefügt).
                                Dienst gestartet.
                                Browser geöffnet und versucht sql zu installieren. Dienst wurde gestoppt (warum auch immer).
                                Nochmal probiert (Dienst gestartet und versucht sql zu installieren).
                                Das hat dann geklappt. Error 0
                                Dann versucht sql mal zu löschen.
                                Dies klappt dann nicht (Kreis dreht durch; dienst ist aber noch aktiv).
                                Fazit:
                                Installation hat dann geklappt. Löschen geht aber nicht mehr -> scheint irgendwas noch zu stören.
                                Lösche nun mal die komplette FP und installieren Win10 neu.
                                mfg
                                Danke.
                                • bahnuhrB Online
                                  bahnuhrB Online
                                  bahnuhr
                                  So:
                                  Win10 Pro neu aufgespielt
                                  Node 10.15.3 und npm 6.4.1 drauf.
                                  cmd als admin ausgefuhrt.
                                  windows-build-tools
                                  iobroker installiert
                                  Dienst gestartet.
                                  iob läuft
                                  browser mit 8081 aufgerufen.
                                  versuch sql zu installieren.
                                  -> klappt nicht - wieder fehler mit python !
                                  Datei erstellt: .npmsc
                                  PC neu gestartet
                                  klappt
                                  Versuch sql zu deinstallieren.
                                  blauer Balken läuft und läuft. Fenster schließt sich nicht. Meldung mit error 0 kommt nicht.
                                  Irgendwas hängt da.
                                  Browser neu geladen. Sql ist weg.
                                  Fazit:
                                  Installieren ging dann.
                                  löschen hat nicht geklappt.
                                  Wie schon erwähnt wäre es schön wenn das manuelle installieren klappen würde.
                                  (oder stabilo.. bekommt dies hin, dass multihost als data eingelesen werden können).
                                  mfg
                                  Dieter
                                  Danke.
                                  • bahnuhrB bahnuhr
                                    So:
                                    windows-build-tools
                                    Dienst gestartet.
                                    iob läuft
                                    PC neu gestartet
                                    klappt
                                    Irgendwas hängt da.
                                    Fazit:
                                    mfg
                                    Dieter
                                    AlCalzoneA Offline
                                    AlCalzoneA Offline
                                    AlCalzone
                                    Welcher JS-Controller + Admin?
                                      bahnuhrB Online
                                      bahnuhrB Online
                                      bahnuhr
                                      ganz neu installiert mit:
                                      etc.
                                      js-controller: 2.2.8 (ist das nicht zu hoch ?, wurde aber installiert mit npm...)
                                      admin: 3.7.8
                                      Danke.
                                      • bahnuhrB bahnuhr
                                        etc.
                                        admin: 3.7.8
                                        AlCalzoneA Offline
                                        AlCalzoneA Offline
                                        AlCalzone
                                        @bahnuhr Das sind seit heute die latest-Versionen. Kannst du andere Adapter löschen - sprich, hängt es nur bei sql?
                                        • bahnuhrB Online
                                          bahnuhrB Online
                                          bahnuhr
                                          Ja, andere gehen einwandfrei (probiert eben mit vis.0 und vis-bars)
                                          Diese brauchen aber auch nicht python, oder ?
                                          Danke.
