  4. Instabiles System nach Umbau von CCU2
instabilpivccu io.broker
27 Beiträge 4 Kommentatoren 2.2k Aufrufe 2 Beobachtet
    @Werde45 sagte in Instabiles System nach Umbau von CCU2:
    Wo ist das Log?
    aus dem Kopf: /opt/iobroker/log/Datum-des logs
    Werde45W Offline
    Werde45W Offline
    Werde45
    @Homoran
    2020-01-13 05:37:52.978  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 05:37:53.281  - info: info.0 (6453) Popup news was read...
    2020-01-13 05:42:52.987  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 05:47:52.995  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 05:52:53.003  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 05:57:53.012  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 06:00:00.036  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 4312
    2020-01-13 06:00:04.066  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 4483
    2020-01-13 06:00:09.026  - info: dwd.0 (4312) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.0
    2020-01-13 06:07:24.202  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 06:19:44.523  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88 vis.0
    2020-01-13 07:04:22.570  - info: host.raspberrypi iobroker.js-controller version 2.1.1 js-controller starting
    2020-01-13 07:04:22.581  - info: host.raspberrypi Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
    2020-01-13 07:04:22.582  - info: host.raspberrypi hostname: raspberrypi, node: v10.18.0
    2020-01-13 07:04:22.585  - info: host.raspberrypi ip addresses: 192.168.10.90 2003:e0:e715:5c00:ba27:ebff:fe26:5af4 fe80::ba27:ebff:fe26:5af4
    2020-01-13 07:04:23.667  - info: host.raspberrypi connected to Objects and States
    2020-01-13 07:04:23.857  - info: host.raspberrypi 40 instances found
    2020-01-13 07:04:24.047  - info: host.raspberrypi starting 24 instances
    2020-01-13 07:04:24.141  - warn: host.raspberrypi Multihost discovery server: service started on 0.0.0.0:50005
    2020-01-13 07:04:24.202  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 799
    2020-01-13 07:04:28.085  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1215
    2020-01-13 07:04:29.259  - info: admin.0 (799) starting. Version 3.6.12 in /opt/iobroker/node_modules/iobroker.admin, node: v10.18.0
    2020-01-13 07:04:29.398  - info: admin.0 (799) requesting all states
    2020-01-13 07:04:29.400  - info: admin.0 (799) requesting all objects
    2020-01-13 07:04:31.336  - info: admin.0 (799) received all objects
    2020-01-13 07:04:32.079  - info: host.raspberrypi instance scheduled system.adapter.dwd.0 */30 * * * *
    Um 7.04. habe ich neu gestartet. Davor hört das Log einfach auf...
    https://bulletproof-admin.de
    • Werde45W Werde45
      @Homoran
      und wo war er hängen geblieben?
      Werde45W 1 Antwort Letzte Antwort
        Werde45W Offline
        Werde45W Offline
        Werde45
        @Homoran
        Na 6.19 Uhr denke ich...
        • Werde45W Werde45
          @Homoran
          @Werde45
          Da ist nix besonderes - Da hast du vis geschlossen
            @Werde45
            Werde45W Offline
            Werde45W Offline
            Werde45
            @Homoran
            hm.. im Schlaf.
            Gibts mehr logs?
            • Werde45W Werde45
              @Homoran
              hm.. im Schlaf.
              Gibts mehr logs?
              Werde45W Offline
              Werde45W Offline
              Werde45
              @Werde45
              Ich habe das Log nochmal etwas früher angesehen. Muss das so?
              2020-01-13 04:02:42.727  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 04:30:03.103  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88 vis.0
              2020-01-13 04:37:52.582  - error: hm-rpc.0 (1424) Ping error: Error: socket hang up
              2020-01-13 04:16:12.432  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 04:37:52.063  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 04:37:52.583  - info: hm-rpc.0 (1424) Disconnected
              2020-01-13 04:37:52.585  - error: hm-rpc.0 (1424) init error: Error: socket hang up
              2020-01-13 04:37:52.586  - error: hm-rpc.0 (1424) init error: Error: socket hang up
              2020-01-13 04:37:52.589  - info: hm-rpc.0 (1424) Connected
              2020-01-13 04:37:52.882  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:52.924  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:52.930  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:52.936  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:52.942  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:52.949  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:52.974  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:52.990  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:52.999  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.007  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.016  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.025  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.037  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.045  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.053  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.058  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.065  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.071  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.076  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.088  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.093  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.097  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.102  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.109  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.114  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.132  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.137  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.142  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.147  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.152  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.156  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.174  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.180  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.299  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.309  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.349  - warn: host.raspberrypi instance system.adapter.backitup.0 terminated due to SIGKILL
              2020-01-13 04:37:53.325  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.333  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.343  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.351  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.377  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.391  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.402  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.412  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.425  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.446  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.454  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.462  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.471  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.480  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.496  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.513  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.530  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.539  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.568  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.589  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.602  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.613  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.623  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.640  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.648  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.656  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:37:53.805  - info: hm-rpc.0 (1424) xmlrpc <- system.listMethods ["hm-rpc.0"]
              2020-01-13 04:37:53.842  - info: hm-rpc.0 (1424) xmlrpc <- listDevices ["hm-rpc.0"]
              2020-01-13 04:37:53.979  - info: info.0 (6453) Popup news was read...
              2020-01-13 04:37:54.408  - info: ical.0 (28349) Terminated (NO_ERROR): Without reason
              2020-01-13 04:37:53.369  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code NaN ()
              2020-01-13 04:37:53.370  - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
              2020-01-13 04:37:54.411  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28635
              2020-01-13 04:37:55.631  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2020-01-13 04:37:55.838  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:38:01.863  - info: hm-rpc.0 (1424) xmlrpc -> 130 devices
              2020-01-13 04:38:01.941  - info: hm-rpc.0 (1424) xmlrpc <- system.listMethods ["hm-rpc.0"]
              2020-01-13 04:38:01.952  - info: hm-rpc.0 (1424) xmlrpc <- listDevices ["hm-rpc.0"]
              2020-01-13 04:38:02.350  - info: hm-rpc.0 (1424) xmlrpc -> 130 devices
              2020-01-13 04:38:03.283  - info: dwd.0 (28635) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.0
              2020-01-13 04:38:04.575  - info: dwd.0 (28635) Terminated (NO_ERROR): Without reason
              2020-01-13 04:38:05.096  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
              2020-01-13 04:38:23.434  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 29692
              2020-01-13 04:38:31.548  - info: backitup.0 (29692) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.18.0
              2020-01-13 04:38:31.664  - info: backitup.0 (29692) [iobroker] backup was activated at 02:00 every 1 day(s)
              2020-01-13 04:38:31.690  - info: backitup.0 (29692) [ccu] backup was activated at 01:30 every 7 day(s)
              2020-01-13 04:39:17.850  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:17.884  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:17.927  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:17.933  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:17.939  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:17.945  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:17.970  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:17.984  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:17.995  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.003  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.011  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.021  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.033  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.040  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.050  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.055  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.062  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.068  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.073  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.085  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.090  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.096  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.099  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.106  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.111  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.130  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.135  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.141  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.144  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.150  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.154  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.167  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.177  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.183  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.303  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.319  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.330  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.338  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.347  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.371  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.387  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.397  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.407  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.415  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.430  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.450  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.458  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.466  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.475  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.487  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.505  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.524  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.534  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.558  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.574  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.598  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.607  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.617  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.628  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.644  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
              2020-01-13 04:39:18.718  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88 vis.0
              2020-01-13 04:42:52.841  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 04:47:52.852  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 04:52:52.860  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 04:57:52.866  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 05:00:00.039  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 24817
              2020-01-13 05:00:04.069  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 24995
              2020-01-13 05:00:06.806  - info: dwd.0 (24817) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.0
              2020-01-13 05:00:08.925  - info: dwd.0 (24817) Terminated (NO_ERROR): Without reason
              2020-01-13 05:00:10.091  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
              2020-01-13 05:00:12.572  - info: ical.0 (24995) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v10.18.0
              2020-01-13 05:00:14.374  - info: ical.0 (24995) processing URL: Alex Kalender https://calendar.google.com/calendar/ical/45werde%40googlemail.com/private-b37c2b040e8e64f6faedbcce8da42d0d/basic.ics
              2020-01-13 05:00:15.100  - info: ical.0 (24995) processing URL: Abfallkalender https://mol.wastebox.gemos-management.de/Gemos/WasteBox/Frontend/TourSchedule/Raw/Name/2020/List/568615/2600,2601,2602,2603,2604,2605,2606,2607/Print/ics/Default/Abfuhrtermine.ics
              2020-01-13 05:00:21.109  - info: ical.0 (24995) Terminated (NO_ERROR): Without reason
              2020-01-13 05:00:21.975  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2020-01-13 05:02:52.872  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 05:07:52.929  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 05:07:53.246  - info: info.0 (6453) Popup news was read...
              2020-01-13 05:12:52.939  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 05:17:52.947  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 05:22:52.954  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 05:27:52.963  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              2020-01-13 05:30:00.038  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 30590
              2020-01-13 05:30:06.130  - info: dwd.0 (30590) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.0
              2020-01-13 05:30:07.406  - info: dwd.0 (30590) Terminated (NO_ERROR): Without reason
              2020-01-13 05:30:07.954  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
              2020-01-13 05:32:52.968  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
              Die .88 ist mein Tablet im Flur für VIS.
              • Werde45W Werde45
                @Werde45
                Werde45W Offline
                Werde45W Offline
                Werde45
                @Werde45
                Ich hatte BackItup deaktiviert. Dieses morgen lief noch alles.
                Mal sehen. Ich melde mich.
                Alex
                • Werde45W Werde45
                  @Werde45
                  Alex
                  Wieviel RAM hast du noch frei?
                  • Werde45W Offline
                    Werde45W Offline
                    Werde45
                    # Informationen zu Pi 'io. broker' - 192.168.10.90 - 14.01.20 19:41
                    averageLoad=7 %
                    disks[0].available=25G
                    disks[0].filesystem=/dev/root
                    disks[0].mountedon=/
                    disks[0].size=30G
                    disks[0].used=3.4G
                    disks[0].usedpercent=12%
                    disks[1].available=459M
                    disks[1].filesystem=devtmpfs
                    disks[1].mountedon=/dev
                    disks[1].size=459M
                    disks[1].used=0
                    disks[1].usedpercent=0%
                    disks[2].available=464M
                    disks[2].filesystem=tmpfs
                    disks[2].mountedon=/dev/shm
                    disks[2].size=464M
                    disks[2].used=0
                    disks[2].usedpercent=0%
                    disks[3].available=452M
                    disks[3].filesystem=tmpfs
                    disks[3].mountedon=/run
                    disks[3].size=464M
                    disks[3].used=12M
                    disks[3].usedpercent=3%
                    disks[4].available=5.0M
                    disks[4].filesystem=tmpfs
                    disks[4].mountedon=/run/lock
                    disks[4].size=5.0M
                    disks[4].used=4.0K
                    disks[4].usedpercent=1%
                    disks[5].available=464M
                    disks[5].filesystem=tmpfs
                    disks[5].mountedon=/sys/fs/cgroup
                    disks[5].size=464M
                    disks[5].used=0
                    disks[5].usedpercent=0%
                    disks[6].available=201M
                    disks[6].filesystem=/dev/mmcblk0p1
                    disks[6].mountedon=/boot
                    disks[6].size=253M
                    disks[6].used=52M
                    disks[6].usedpercent=21%
                    disks[7].available=93M
                    disks[7].filesystem=tmpfs
                    disks[7].mountedon=/run/user/1000
                    disks[7].size=93M
                    disks[7].used=0
                    disks[7].usedpercent=0%
                    distribution=Raspbian GNU/Linux 10 (buster)
                    freeSwap.bytes=92794880
                    totalSwap.bytes=104853504
                    usedSwap.bytes=12058624
                    freeMemory.bytes=174301184
                    totalMemory.bytes=971063296
                    usedMemory.bytes=796762112
                    network[0].ipadress=192.168.10.90
                    network[0].name=br0
                    network[1].name=eth0
                    network[2].name=vethpivccu
                    network[3].name=wlan0
                    processes[0].command=thd
                    processes[0].pid=343
                    processes[1].command=avahi-daemon
                    processes[1].pid=344
                    processes[2].command=dbus-daemon
                    processes[2].pid=352
                    processes[3].command=avahi-daemon
                    processes[3].pid=395
                    processes[4].command=systemd-timesyn
                    processes[4].pid=429
                    processes[5].command=iobroker.js-con
                    processes[5].pid=490
                    processes[6].command=io.admin.0
                    processes[6].pid=572
                    processes[7].command=dbus-daemon
                    processes[7].pid=920
                    processes[8].command=io.email.0
                    processes[8].pid=1120
                    processes[9].command=io.history.0
                    processes[9].pid=1306
                    processes[10].command=io.hm-rega.0
                    processes[10].pid=1345
                    processes[11].command=io.hm-rpc.0
                    processes[11].pid=1363
                    processes[12].command=io.hs100.0
                    processes[12].pid=1428
                    processes[13].command=io.info.0
                    processes[13].pid=1490
                    processes[14].command=io.javascript.0
                    processes[14].pid=1526
                    processes[15].command=io.nina.0
                    processes[15].pid=1618
                    processes[16].command=io.parser.0
                    processes[16].pid=2037
                    processes[17].command=io.pushover.0
                    processes[17].pid=2212
                    processes[18].command=io.rpi2.0
                    processes[18].pid=2237
                    processes[19].command=io.sayit.0
                    processes[19].pid=2416
                    processes[20].command=io.simple-api.0
                    processes[20].pid=2483
                    processes[21].command=io.socketio.0
                    processes[21].pid=2658
                    processes[22].command=io.systeminfo.0
                    processes[22].pid=2681
                    processes[23].command=io.tankerkoenig
                    processes[23].pid=2850
                    processes[24].command=io.web.0
                    processes[24].pid=3080
                    processes[25].command=systemd
                    processes[25].pid=19084
                    processes[26].command=(sd-pam)
                    processes[26].pid=19087
                    processes[27].command=sshd
                    processes[27].pid=19103
                    processes[28].command=ps
                    processes[28].pid=19139
                    serial=0000000012265af4
                    startup=vor 1 Stunde
                    systemtime=Tue, 14 Jan 2020 19:41:11 +0100
                    vcgencmd.armfrequency=1400000000
                    vcgencmd.corefrequency=400000000
                    vcgencmd.corevolts=1.325
                    vcgencmd.cputemperature=48.3
                    vcgencmd.version=6820edeee4ef3891b95fc01cf02a7abd7ca52f17 (clean) (release) (start)
                    Diese Informationen wurden mit RasPi Check (Version: 1.8.13) für Android abgefragt.
                    Heute Abend war wieder alles weg, ausser Ping auf beide IPs ging.
                    • Werde45W Werde45
                      averageLoad=7 %
                      disks[0].size=30G
                      disks[0].used=3.4G
                      disks[1].size=459M
                      disks[1].used=0
                      disks[2].size=464M
                      disks[2].used=0
                      disks[3].size=464M
                      disks[3].used=12M
                      disks[4].size=5.0M
                      disks[4].used=4.0K
                      disks[5].size=464M
                      disks[5].used=0
                      disks[6].size=253M
                      disks[6].used=52M
                      disks[7].size=93M
                      disks[7].used=0
                      network[0].name=br0
                      gerade mal roundabout 170MB frei (bis backitup das auffrisst).
                      Schön zu sehen, dass es am RAM liegt, da dein Raspi swapped
                        Werde45W Offline
                        Werde45W Offline
                        Werde45
                        @Homoran
                        Sorry, aber hilft die Schadenfreude bei der Problemlösung?
                        Ich gehe davon aus, das wenn ich ein fertiges Image nutze die Speichereinstellungen passend sind.
                        Was sollte ich tun ? Swapfile deaktivieren? Oder CCU auf einem extra RPI laufen lassen.
                        Danke. Bin zur Zeit etwas Dünnhäutig.
                        HomoranH paul53P 3 Antworten Letzte Antwort
                        • Werde45W Werde45
                          @Homoran
                          Was für Schadenfreude????
                          • Werde45W Werde45
                            @Homoran
                            Wie viele Instanzen laufen denn bei dir?
                            • Werde45W Werde45
                              @Homoran
                              @Werde45 sagte:
                              Da ist keine Schadenfreude, sondern der Hinweis, dass der RAM-Mangel durch die Swap-Nutzung bestätigt wird.
                              Du hast zu viele Adapter hinzu installiert, d.h. für die RAM-Größe zu viele aktive Instanzen.
                              • Werde45W Offline
                                Werde45W Offline
                                Werde45
                                schrieb am zuletzt editiert von Werde45
                                Hab die selben Instanzen wie seit Monaten, als der io.broker noch alleine lief. Wenn das mit der PIVCCU keine gute Idee ist, dann hab ich dafür einen PI2b.
                                Wenn ich ehrlich bin habe ich keinen Nerv für dieses Problem, aber meine Rollos bleiben oben, das Licht aus und die Alarmanlage stumm.
                                Hab hunderte Seiten Beiträge im Forum gelesen und nach einer Lösung gesucht. Auch wenn Hilfe zur Selbsthilfe grundsätzlich gut ist. Ich bin über 5 Jahre mit Homematic und Dashui und nun 2 Jahre io.broker.
                                Was sollte man denn nun tun?
                                • Werde45W Werde45
                                  Uns sagen wie viele Instanzen du hast
                                  Außerdem vermute ich, dass du Daten loggst und auch diese werden gesichert.
                                  Um diese zu sichern müssen die Daten gepackt werden - das braucht RAM.
                                  Auch wennn scheinbar alles gleich geblieben ist, werden die logdateien und Historydaten immer mehr und brauchen immer mehr Platz
                                  Und ja, auch piVCCU braucht etwas RAM. Das ist zwar nicht allzuviel, kann aber das Zünglein an der Waage sein
                                  • Werde45W Offline
                                    Werde45W Offline
                                    Werde45
                                    Es sind 30 Instanzen und kein Logging. Ich sehe nur nach vorne ;-)
                                    paul53P HomoranH 2 Antworten Letzte Antwort
                                    • Werde45W Werde45
                                      @Werde45 sagte:
                                      Zu viele für 1 GB RAM !
                                      • Werde45W Werde45
                                        bei 1GB RAM wird es ab 20 Instanzen sicher schon kanpp. Selbst 15 Instanzen und einiges an Skripten kann schon reichen.
                                        30 sind definitiv zuviel für einen Raspi 2/3 (auch ohne piVCCU)
                                          Werde45W Offline
                                          Werde45W Offline
                                          Werde45
                                          @Homoran
                                          Ok...Dann also vorher ohne PIVCCU ging es ja. Also doch zumindest das Teil auf andere hardware. Dann funktionieren wenigstens die Basis-Funktionen im Haus ohne VIS....
