  4. Instabiles System nach Umbau von CCU2
instabilpivccu io.broker
27 Beiträge 4 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • Werde45W Werde45
    @Homoran
    2020-01-13 05:37:52.978  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 05:37:53.281  - info: info.0 (6453) Popup news was read...
    2020-01-13 05:42:52.987  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 05:47:52.995  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 05:52:53.003  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 05:57:53.012  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 06:00:00.036  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 4312
    2020-01-13 06:00:04.066  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 4483
    2020-01-13 06:00:09.026  - info: dwd.0 (4312) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.0
    2020-01-13 06:07:24.202  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
    2020-01-13 06:19:44.523  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88 vis.0
    2020-01-13 07:04:22.570  - info: host.raspberrypi iobroker.js-controller version 2.1.1 js-controller starting
    2020-01-13 07:04:22.581  - info: host.raspberrypi Copyright (c) 2014-2019 bluefox, 2014 hobbyquaker
    2020-01-13 07:04:22.582  - info: host.raspberrypi hostname: raspberrypi, node: v10.18.0
    2020-01-13 07:04:22.585  - info: host.raspberrypi ip addresses: 192.168.10.90 2003:e0:e715:5c00:ba27:ebff:fe26:5af4 fe80::ba27:ebff:fe26:5af4
    2020-01-13 07:04:23.667  - info: host.raspberrypi connected to Objects and States
    2020-01-13 07:04:23.857  - info: host.raspberrypi 40 instances found
    2020-01-13 07:04:24.047  - info: host.raspberrypi starting 24 instances
    2020-01-13 07:04:24.141  - warn: host.raspberrypi Multihost discovery server: service started on 0.0.0.0:50005
    2020-01-13 07:04:24.202  - info: host.raspberrypi instance system.adapter.admin.0 started with pid 799
    2020-01-13 07:04:28.085  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1215
    2020-01-13 07:04:29.259  - info: admin.0 (799) starting. Version 3.6.12 in /opt/iobroker/node_modules/iobroker.admin, node: v10.18.0
    2020-01-13 07:04:29.398  - info: admin.0 (799) requesting all states
    2020-01-13 07:04:29.400  - info: admin.0 (799) requesting all objects
    2020-01-13 07:04:31.336  - info: admin.0 (799) received all objects
    2020-01-13 07:04:32.079  - info: host.raspberrypi instance scheduled system.adapter.dwd.0 */30 * * * *
    Um 7.04. habe ich neu gestartet. Davor hört das Log einfach auf...
    @Werde45 sagte in Instabiles System nach Umbau von CCU2:
    und wo war er hängen geblieben?
    Werde45W 1 Antwort Letzte Antwort
      Werde45W Offline
      Werde45W Offline
      Werde45
      @Homoran
      Na 6.19 Uhr denke ich...
      https://bulletproof-admin.de
      • Werde45W Werde45
        @Homoran
        @Werde45
        Da ist nix besonderes - Da hast du vis geschlossen
          @Werde45
          Werde45W Offline
          Werde45W Offline
          Werde45
          @Homoran
          hm.. im Schlaf.
          Gibts mehr logs?
          • Werde45W Werde45
            @Homoran
            hm.. im Schlaf.
            Gibts mehr logs?
            Werde45W Offline
            Werde45W Offline
            Werde45
            @Werde45
            Ich habe das Log nochmal etwas früher angesehen. Muss das so?
            2020-01-13 04:02:42.727  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 04:30:03.103  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88 vis.0
            2020-01-13 04:37:52.582  - error: hm-rpc.0 (1424) Ping error: Error: socket hang up
            2020-01-13 04:16:12.432  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 04:37:52.063  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 04:37:52.583  - info: hm-rpc.0 (1424) Disconnected
            2020-01-13 04:37:52.585  - error: hm-rpc.0 (1424) init error: Error: socket hang up
            2020-01-13 04:37:52.586  - error: hm-rpc.0 (1424) init error: Error: socket hang up
            2020-01-13 04:37:52.589  - info: hm-rpc.0 (1424) Connected
            2020-01-13 04:37:52.882  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:52.924  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:52.930  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:52.936  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:52.942  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:52.949  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:52.974  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:52.990  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:52.999  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.007  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.016  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.025  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.037  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.045  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.053  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.058  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.065  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.071  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.076  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.088  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.093  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.097  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.102  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.109  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.114  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.132  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.137  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.142  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.147  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.152  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.156  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.174  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.180  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.299  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.309  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.349  - warn: host.raspberrypi instance system.adapter.backitup.0 terminated due to SIGKILL
            2020-01-13 04:37:53.325  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.333  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.343  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.351  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.377  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.391  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.402  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.412  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.425  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.446  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.454  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.462  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.471  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.480  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.496  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.513  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.530  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.539  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.568  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.589  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.602  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.613  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.623  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.640  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.648  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.656  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:37:53.805  - info: hm-rpc.0 (1424) xmlrpc <- system.listMethods ["hm-rpc.0"]
            2020-01-13 04:37:53.842  - info: hm-rpc.0 (1424) xmlrpc <- listDevices ["hm-rpc.0"]
            2020-01-13 04:37:53.979  - info: info.0 (6453) Popup news was read...
            2020-01-13 04:37:54.408  - info: ical.0 (28349) Terminated (NO_ERROR): Without reason
            2020-01-13 04:37:53.369  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code NaN ()
            2020-01-13 04:37:53.370  - info: host.raspberrypi Restart adapter system.adapter.backitup.0 because enabled
            2020-01-13 04:37:54.411  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28635
            2020-01-13 04:37:55.631  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2020-01-13 04:37:55.838  - info: web.0 (7023) ==>Connected system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:38:01.863  - info: hm-rpc.0 (1424) xmlrpc -> 130 devices
            2020-01-13 04:38:01.941  - info: hm-rpc.0 (1424) xmlrpc <- system.listMethods ["hm-rpc.0"]
            2020-01-13 04:38:01.952  - info: hm-rpc.0 (1424) xmlrpc <- listDevices ["hm-rpc.0"]
            2020-01-13 04:38:02.350  - info: hm-rpc.0 (1424) xmlrpc -> 130 devices
            2020-01-13 04:38:03.283  - info: dwd.0 (28635) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.0
            2020-01-13 04:38:04.575  - info: dwd.0 (28635) Terminated (NO_ERROR): Without reason
            2020-01-13 04:38:05.096  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
            2020-01-13 04:38:23.434  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 29692
            2020-01-13 04:38:31.548  - info: backitup.0 (29692) starting. Version 1.3.6 in /opt/iobroker/node_modules/iobroker.backitup, node: v10.18.0
            2020-01-13 04:38:31.664  - info: backitup.0 (29692) [iobroker] backup was activated at 02:00 every 1 day(s)
            2020-01-13 04:38:31.690  - info: backitup.0 (29692) [ccu] backup was activated at 01:30 every 7 day(s)
            2020-01-13 04:39:17.850  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:17.884  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:17.927  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:17.933  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:17.939  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:17.945  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:17.970  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:17.984  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:17.995  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.003  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.011  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.021  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.033  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.040  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.050  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.055  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.062  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.068  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.073  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.085  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.090  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.096  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.099  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.106  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.111  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.130  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.135  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.141  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.144  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.150  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.154  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.167  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.177  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.183  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.303  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.319  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.330  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.338  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.347  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.371  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.387  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.397  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.407  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.415  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.430  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.450  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.458  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.466  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.475  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.487  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.505  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.524  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.534  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.558  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.574  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.598  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.607  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.617  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.628  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.644  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88
            2020-01-13 04:39:18.718  - info: web.0 (7023) <==Disconnect system.user.admin from ::ffff:192.168.10.88 vis.0
            2020-01-13 04:42:52.841  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 04:47:52.852  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 04:52:52.860  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 04:57:52.866  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 05:00:00.039  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 24817
            2020-01-13 05:00:04.069  - info: host.raspberrypi instance system.adapter.ical.0 started with pid 24995
            2020-01-13 05:00:06.806  - info: dwd.0 (24817) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.0
            2020-01-13 05:00:08.925  - info: dwd.0 (24817) Terminated (NO_ERROR): Without reason
            2020-01-13 05:00:10.091  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
            2020-01-13 05:00:12.572  - info: ical.0 (24995) starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.ical, node: v10.18.0
            2020-01-13 05:00:14.374  - info: ical.0 (24995) processing URL: Alex Kalender https://calendar.google.com/calendar/ical/45werde%40googlemail.com/private-b37c2b040e8e64f6faedbcce8da42d0d/basic.ics
            2020-01-13 05:00:15.100  - info: ical.0 (24995) processing URL: Abfallkalender https://mol.wastebox.gemos-management.de/Gemos/WasteBox/Frontend/TourSchedule/Raw/Name/2020/List/568615/2600,2601,2602,2603,2604,2605,2606,2607/Print/ics/Default/Abfuhrtermine.ics
            2020-01-13 05:00:21.109  - info: ical.0 (24995) Terminated (NO_ERROR): Without reason
            2020-01-13 05:00:21.975  - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
            2020-01-13 05:02:52.872  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 05:07:52.929  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 05:07:53.246  - info: info.0 (6453) Popup news was read...
            2020-01-13 05:12:52.939  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 05:17:52.947  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 05:22:52.954  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 05:27:52.963  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            2020-01-13 05:30:00.038  - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 30590
            2020-01-13 05:30:06.130  - info: dwd.0 (30590) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v10.18.0
            2020-01-13 05:30:07.406  - info: dwd.0 (30590) Terminated (NO_ERROR): Without reason
            2020-01-13 05:30:07.954  - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
            2020-01-13 05:32:52.968  - info: tankerkoenig.0 (2948) Reading data from tankerkoenig ...
            Die .88 ist mein Tablet im Flur für VIS.
            • Werde45W Werde45
              @Werde45
              Werde45W Offline
              Werde45W Offline
              Werde45
              @Werde45
              Ich hatte BackItup deaktiviert. Dieses morgen lief noch alles.
              Mal sehen. Ich melde mich.
              Alex
              • Werde45W Werde45
                @Werde45
                Alex
                Wieviel RAM hast du noch frei?
                • Werde45W Offline
                  Werde45W Offline
                  Werde45
                  # Informationen zu Pi 'io. broker' - 192.168.10.90 - 14.01.20 19:41
                  averageLoad=7 %
                  disks[0].available=25G
                  disks[0].filesystem=/dev/root
                  disks[0].mountedon=/
                  disks[0].size=30G
                  disks[0].used=3.4G
                  disks[0].usedpercent=12%
                  disks[1].available=459M
                  disks[1].filesystem=devtmpfs
                  disks[1].mountedon=/dev
                  disks[1].size=459M
                  disks[1].used=0
                  disks[1].usedpercent=0%
                  disks[2].available=464M
                  disks[2].filesystem=tmpfs
                  disks[2].mountedon=/dev/shm
                  disks[2].size=464M
                  disks[2].used=0
                  disks[2].usedpercent=0%
                  disks[3].available=452M
                  disks[3].filesystem=tmpfs
                  disks[3].mountedon=/run
                  disks[3].size=464M
                  disks[3].used=12M
                  disks[3].usedpercent=3%
                  disks[4].available=5.0M
                  disks[4].filesystem=tmpfs
                  disks[4].mountedon=/run/lock
                  disks[4].size=5.0M
                  disks[4].used=4.0K
                  disks[4].usedpercent=1%
                  disks[5].available=464M
                  disks[5].filesystem=tmpfs
                  disks[5].mountedon=/sys/fs/cgroup
                  disks[5].size=464M
                  disks[5].used=0
                  disks[5].usedpercent=0%
                  disks[6].available=201M
                  disks[6].filesystem=/dev/mmcblk0p1
                  disks[6].mountedon=/boot
                  disks[6].size=253M
                  disks[6].used=52M
                  disks[6].usedpercent=21%
                  disks[7].available=93M
                  disks[7].filesystem=tmpfs
                  disks[7].mountedon=/run/user/1000
                  disks[7].size=93M
                  disks[7].used=0
                  disks[7].usedpercent=0%
                  distribution=Raspbian GNU/Linux 10 (buster)
                  freeSwap.bytes=92794880
                  totalSwap.bytes=104853504
                  usedSwap.bytes=12058624
                  freeMemory.bytes=174301184
                  totalMemory.bytes=971063296
                  usedMemory.bytes=796762112
                  network[0].ipadress=192.168.10.90
                  network[0].name=br0
                  network[1].name=eth0
                  network[2].name=vethpivccu
                  network[3].name=wlan0
                  processes[0].command=thd
                  processes[0].pid=343
                  processes[1].command=avahi-daemon
                  processes[1].pid=344
                  processes[2].command=dbus-daemon
                  processes[2].pid=352
                  processes[3].command=avahi-daemon
                  processes[3].pid=395
                  processes[4].command=systemd-timesyn
                  processes[4].pid=429
                  processes[5].command=iobroker.js-con
                  processes[5].pid=490
                  processes[6].command=io.admin.0
                  processes[6].pid=572
                  processes[7].command=dbus-daemon
                  processes[7].pid=920
                  processes[8].command=io.email.0
                  processes[8].pid=1120
                  processes[9].command=io.history.0
                  processes[9].pid=1306
                  processes[10].command=io.hm-rega.0
                  processes[10].pid=1345
                  processes[11].command=io.hm-rpc.0
                  processes[11].pid=1363
                  processes[12].command=io.hs100.0
                  processes[12].pid=1428
                  processes[13].command=io.info.0
                  processes[13].pid=1490
                  processes[14].command=io.javascript.0
                  processes[14].pid=1526
                  processes[15].command=io.nina.0
                  processes[15].pid=1618
                  processes[16].command=io.parser.0
                  processes[16].pid=2037
                  processes[17].command=io.pushover.0
                  processes[17].pid=2212
                  processes[18].command=io.rpi2.0
                  processes[18].pid=2237
                  processes[19].command=io.sayit.0
                  processes[19].pid=2416
                  processes[20].command=io.simple-api.0
                  processes[20].pid=2483
                  processes[21].command=io.socketio.0
                  processes[21].pid=2658
                  processes[22].command=io.systeminfo.0
                  processes[22].pid=2681
                  processes[23].command=io.tankerkoenig
                  processes[23].pid=2850
                  processes[24].command=io.web.0
                  processes[24].pid=3080
                  processes[25].command=systemd
                  processes[25].pid=19084
                  processes[26].command=(sd-pam)
                  processes[26].pid=19087
                  processes[27].command=sshd
                  processes[27].pid=19103
                  processes[28].command=ps
                  processes[28].pid=19139
                  serial=0000000012265af4
                  startup=vor 1 Stunde
                  systemtime=Tue, 14 Jan 2020 19:41:11 +0100
                  vcgencmd.armfrequency=1400000000
                  vcgencmd.corefrequency=400000000
                  vcgencmd.corevolts=1.325
                  vcgencmd.cputemperature=48.3
                  vcgencmd.version=6820edeee4ef3891b95fc01cf02a7abd7ca52f17 (clean) (release) (start)
                  Diese Informationen wurden mit RasPi Check (Version: 1.8.13) für Android abgefragt.
                  Heute Abend war wieder alles weg, ausser Ping auf beide IPs ging.
                  • Werde45W Werde45
                    averageLoad=7 %
                    disks[0].size=30G
                    disks[0].used=3.4G
                    disks[1].size=459M
                    disks[1].used=0
                    disks[2].size=464M
                    disks[2].used=0
                    disks[3].size=464M
                    disks[3].used=12M
                    disks[4].size=5.0M
                    disks[4].used=4.0K
                    disks[5].size=464M
                    disks[5].used=0
                    disks[6].size=253M
                    disks[6].used=52M
                    disks[7].size=93M
                    disks[7].used=0
                    network[0].name=br0
                    gerade mal roundabout 170MB frei (bis backitup das auffrisst).
                    Schön zu sehen, dass es am RAM liegt, da dein Raspi swapped
                      Werde45W Offline
                      Werde45W Offline
                      Werde45
                      @Homoran
                      Sorry, aber hilft die Schadenfreude bei der Problemlösung?
                      Ich gehe davon aus, das wenn ich ein fertiges Image nutze die Speichereinstellungen passend sind.
                      Was sollte ich tun ? Swapfile deaktivieren? Oder CCU auf einem extra RPI laufen lassen.
                      Danke. Bin zur Zeit etwas Dünnhäutig.
                      HomoranH paul53P 3 Antworten Letzte Antwort
                      • Werde45W Werde45
                        @Homoran
                        Was für Schadenfreude????
                        • Werde45W Werde45
                          @Homoran
                          Wie viele Instanzen laufen denn bei dir?
                          • Werde45W Werde45
                            @Homoran
                            @Werde45 sagte:
                            Da ist keine Schadenfreude, sondern der Hinweis, dass der RAM-Mangel durch die Swap-Nutzung bestätigt wird.
                            Du hast zu viele Adapter hinzu installiert, d.h. für die RAM-Größe zu viele aktive Instanzen.
                            • Werde45W Offline
                              Werde45W Offline
                              Werde45
                              schrieb am zuletzt editiert von Werde45
                              Hab die selben Instanzen wie seit Monaten, als der io.broker noch alleine lief. Wenn das mit der PIVCCU keine gute Idee ist, dann hab ich dafür einen PI2b.
                              Wenn ich ehrlich bin habe ich keinen Nerv für dieses Problem, aber meine Rollos bleiben oben, das Licht aus und die Alarmanlage stumm.
                              Hab hunderte Seiten Beiträge im Forum gelesen und nach einer Lösung gesucht. Auch wenn Hilfe zur Selbsthilfe grundsätzlich gut ist. Ich bin über 5 Jahre mit Homematic und Dashui und nun 2 Jahre io.broker.
                              Was sollte man denn nun tun?
                              • Werde45W Werde45
                                Uns sagen wie viele Instanzen du hast
                                Außerdem vermute ich, dass du Daten loggst und auch diese werden gesichert.
                                Um diese zu sichern müssen die Daten gepackt werden - das braucht RAM.
                                Auch wennn scheinbar alles gleich geblieben ist, werden die logdateien und Historydaten immer mehr und brauchen immer mehr Platz
                                Und ja, auch piVCCU braucht etwas RAM. Das ist zwar nicht allzuviel, kann aber das Zünglein an der Waage sein
                                • Werde45W Offline
                                  Werde45W Offline
                                  Werde45
                                  Es sind 30 Instanzen und kein Logging. Ich sehe nur nach vorne ;-)
                                  paul53P HomoranH 2 Antworten Letzte Antwort
                                  • Werde45W Werde45
                                    @Werde45 sagte:
                                    Zu viele für 1 GB RAM !
                                    • Werde45W Werde45
                                      bei 1GB RAM wird es ab 20 Instanzen sicher schon kanpp. Selbst 15 Instanzen und einiges an Skripten kann schon reichen.
                                      30 sind definitiv zuviel für einen Raspi 2/3 (auch ohne piVCCU)
                                        Werde45W Offline
                                        Werde45W Offline
                                        Werde45
                                        @Homoran
                                        Ok...Dann also vorher ohne PIVCCU ging es ja. Also doch zumindest das Teil auf andere hardware. Dann funktionieren wenigstens die Basis-Funktionen im Haus ohne VIS....
                                        • Werde45W Werde45
                                          @Homoran
                                          das war Glück!
                                          maximal 20 Instanzen ist die Grenze bei 1GB
                                          Verleide dir doch den Spaß nicht wegen eines zu gering dimensionierten "Rechners"
                                          der Pi4 mit 2GB schafft um Längen mehr (4GB sind Super)
                                          Betriebssystem braucht immer die gleiche Menge. Der Rest bis 1GB ist nicht mehr viel, daher passen auf einen 2GB RasPi mehr als das doppelte drauf.
