  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.5m Aufrufe 201 Beobachtet
  • B BeNeDeLuX
    @Rene_HM
    Ok, dann wäre super wenn Du bitte kurz über meine Settings schauen kannst, leider passiert bei mir nichts wenn ich heatingcontrol.0.Present ändere. Habe mir in VIS ein Schalter zu dem Datenpunkt erstellt.
    Debug Log: (Von Present = true auf Present = false gestellt)
    heatingcontrol.0	2020-01-08 20:23:13.909	debug	(6960) ### state change already handled: false / false /// heatingcontrol.0.Present / heatingcontrol.0.Present
    heatingcontrol.0	2020-01-08 20:23:13.908	debug	(6960) ### state change already handled: false / false /// heatingcontrol.0.Present / heatingcontrol.0.Present
    heatingcontrol.0	2020-01-08 20:23:13.908	debug	(6960) ### handle state change heatingcontrol.0.Present {"val":false,"ack":true,"ts":1578511393906,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578511392900}
    heatingcontrol.0	2020-01-08 20:23:13.905	debug	(6960) ### handle state change heatingcontrol.0.Present {"val":false,"ack":false,"ts":1578511393902,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1578511392900}
    heatingcontrol.0	2020-01-08 20:23:12.959	debug	(6960) ### all StateChange handled
    heatingcontrol.0	2020-01-08 20:23:12.959	debug	(6960) ### state change already handled: false / false /// heatingcontrol.0.Present / heatingcontrol.0.Present
    heatingcontrol.0	2020-01-08 20:23:12.958	debug	(6960) ### handle state change heatingcontrol.0.Present {"val":false,"ack":true,"ts":1578511392955,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578511392900}
    heatingcontrol.0	2020-01-08 20:23:12.910	debug	(6960) ### state change already handled: false / false /// heatingcontrol.0.Present / heatingcontrol.0.Present
    heatingcontrol.0	2020-01-08 20:23:12.909	debug	(6960) ### heatingcontrol.0.Present heatingcontrol.0.Present false true
    heatingcontrol.0	2020-01-08 20:23:12.909	debug	(6960) ### handle state change heatingcontrol.0.Present {"val":false,"ack":true,"ts":1578511392906,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578511392900}
    heatingcontrol.0	2020-01-08 20:23:12.903	debug	(6960) ### handle state change heatingcontrol.0.Present {"val":false,"ack":false,"ts":1578511392900,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1578511392900}
    heatingcontrol.0	2020-01-08 20:22:02.453	debug	(6960) system.adapter.admin.0: logging true
    Hier meine Einstellungen:
    Reichen diese Angaben ?
    Vielen Dank für deine Hilfe!
    Rene_HMR Offline
    Rene_HMR Offline
    Rene_HM
    #770
    @BeNeDeLuX Die settings zu den Pfaden sind falsch. Da gehören externe Datenpunkte (z.Bsp. aus einem script o.ä.) hinein. Du setzt aber die adapter-internen Datenpunkte dort ein.
    Wenn du also heatingcontrol.0.Present direkt im Datenbaum setzen willst (oder durch die vis), dann lass die Pfade einfach leer...
    Das log sagt, du setzt den Wert von false auf false...
      BeNeDeLuX
      #771
      @Rene_HM
      Super - vielen Dank, hab alle Pfade geleert da ich noch keine externe Datenpunkte dafür habe. Jetzt hat es auch auf Anhieb geklappt. Allerdings passt das mit dem Log nicht. False auf false und true auf true. Ich wechsel wirklich den Status von false auf true und zurück! Diesmal direkt im Objektbaum anstatt über einen Schalter in VIS.
      Hier das letzte Debug Log:
      heatingcontrol.0	2020-01-08 20:46:56.116	debug	(13328) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0	2020-01-08 20:46:56.116	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1578512816115,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578512815114}
      heatingcontrol.0	2020-01-08 20:46:56.115	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":true,"ack":false,"ts":1578512816114,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1578512815114}
      heatingcontrol.0	2020-01-08 20:46:55.750	debug	(13328) ### all StateChange handled
      heatingcontrol.0	2020-01-08 20:46:55.750	debug	(13328) ### 111 handled
      heatingcontrol.0	2020-01-08 20:46:55.750	debug	(13328) [INFO] status = true next event: 11 Jan 2020 18:45:00
      heatingcontrol.0	2020-01-08 20:46:55.748	debug	(13328) [INFO] status = true next event: 11 Jan 2020 13:30:00
      heatingcontrol.0	2020-01-08 20:46:55.747	debug	(13328) [INFO] status = true next event: 11 Jan 2020 12:00:00
      heatingcontrol.0	2020-01-08 20:46:55.746	debug	(13328) [INFO] status = true next event: 11 Jan 2020 06:00:00
      heatingcontrol.0	2020-01-08 20:46:55.745	debug	(13328) [INFO] status = true next event: 11 Jan 2020 05:00:00
      heatingcontrol.0	2020-01-08 20:46:55.744	debug	(13328) [INFO] status = true next event: 9 Jan 2020 18:45:00
      heatingcontrol.0	2020-01-08 20:46:55.742	debug	(13328) [INFO] status = true next event: 9 Jan 2020 13:30:00
      heatingcontrol.0	2020-01-08 20:46:55.740	debug	(13328) [INFO] status = true next event: 9 Jan 2020 12:00:00
      heatingcontrol.0	2020-01-08 20:46:55.739	debug	(13328) [INFO] status = true next event: 9 Jan 2020 05:45:00
      heatingcontrol.0	2020-01-08 20:46:55.734	debug	(13328) [INFO] status = true next event: 9 Jan 2020 05:00:00
      heatingcontrol.0	2020-01-08 20:46:55.733	debug	(13328) [INFO] status = true next event: 31 Mar 2020 23:55:00
      heatingcontrol.0	2020-01-08 20:46:55.715	debug	(13328) [INFO] status = true next event: 1 Oct 2020 00:05:00
      heatingcontrol.0	2020-01-08 20:46:55.501	debug	(13328) thermostat hm-rpc.0.NEQ1492817.4.SET_TEMPERATURE to 19; current is 17
      heatingcontrol.0	2020-01-08 20:46:55.447	debug	(13328) got {"val":17,"ack":false,"ts":1578255582298,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1578255582298}
      heatingcontrol.0	2020-01-08 20:46:55.442	debug	(13328) checking min temp with Rooms.Luca.MinimumTemperature
      heatingcontrol.0	2020-01-08 20:46:55.442	info	(13328) room Luca Thermostat Luca target is 19
      heatingcontrol.0	2020-01-08 20:46:55.441	debug	(13328) ### new target temp19
      heatingcontrol.0	2020-01-08 20:46:55.441	debug	(13328) ### current > 1 4 2
      heatingcontrol.0	2020-01-08 20:46:55.440	debug	(13328) Luca found period 4 with 19 on 18,45
      heatingcontrol.0	2020-01-08 20:46:55.440	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.4.time 19
      heatingcontrol.0	2020-01-08 20:46:55.393	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.4.time
      heatingcontrol.0	2020-01-08 20:46:55.392	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.3.time 17
      heatingcontrol.0	2020-01-08 20:46:55.344	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.3.time
      heatingcontrol.0	2020-01-08 20:46:55.343	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.2.time 19
      heatingcontrol.0	2020-01-08 20:46:55.290	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.2.time
      heatingcontrol.0	2020-01-08 20:46:55.288	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.1.time 17
      heatingcontrol.0	2020-01-08 20:46:55.244	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.1.time
      heatingcontrol.0	2020-01-08 20:46:55.244	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.0.time 19
      heatingcontrol.0	2020-01-08 20:46:55.199	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.0.time
      heatingcontrol.0	2020-01-08 20:46:55.198	debug	(13328) FindNextPeriod for 2020-1-8 8:46:55 PM in Luca
      heatingcontrol.0	2020-01-08 20:46:55.196	debug	(13328) Luca window open is false
      heatingcontrol.0	2020-01-08 20:46:55.195	debug	(13328) check room Luca
      heatingcontrol.0	2020-01-08 20:46:55.192	debug	(13328) profile 0
      heatingcontrol.0	2020-01-08 20:46:55.180	debug	(13328) get profile
      heatingcontrol.0	2020-01-08 20:46:55.180	debug	(13328) profile type 2
      heatingcontrol.0	2020-01-08 20:46:55.129	debug	(13328) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0	2020-01-08 20:46:55.127	info	(13328) calculating new target temperatures
      heatingcontrol.0	2020-01-08 20:46:55.126	debug	(13328) ### heatingcontrol.0.Present heatingcontrol.0.Present true false
      heatingcontrol.0	2020-01-08 20:46:55.126	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1578512815122,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578512815114}
      heatingcontrol.0	2020-01-08 20:46:55.120	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":true,"ack":false,"ts":1578512815114,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1578512815114}
      heatingcontrol.0	2020-01-08 20:46:30.637	debug	(13328) system.adapter.admin.0: logging true
      heatingcontrol.0	2020-01-08 20:46:29.494	debug	(13328) ### state change already handled: false / false /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0	2020-01-08 20:46:29.493	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":false,"ack":true,"ts":1578512789491,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578512789147}
      heatingcontrol.0	2020-01-08 20:46:29.493	debug	(13328) ### state change already handled: false / false /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0	2020-01-08 20:46:29.490	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":false,"ack":false,"ts":1578512789487,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1578512789147}
      heatingcontrol.0	2020-01-08 20:46:29.490	debug	(13328) ### all StateChange handled
      heatingcontrol.0	2020-01-08 20:46:29.490	debug	(13328) ### 111 handled
      heatingcontrol.0	2020-01-08 20:46:29.490	debug	(13328) [INFO] status = true next event: 11 Jan 2020 18:45:00
      heatingcontrol.0	2020-01-08 20:46:29.489	debug	(13328) [INFO] status = true next event: 11 Jan 2020 13:30:00
      heatingcontrol.0	2020-01-08 20:46:29.488	debug	(13328) [INFO] status = true next event: 11 Jan 2020 12:00:00
      heatingcontrol.0	2020-01-08 20:46:29.487	debug	(13328) [INFO] status = true next event: 11 Jan 2020 06:00:00
      heatingcontrol.0	2020-01-08 20:46:29.486	debug	(13328) [INFO] status = true next event: 11 Jan 2020 05:00:00
      heatingcontrol.0	2020-01-08 20:46:29.481	debug	(13328) [INFO] status = true next event: 9 Jan 2020 18:45:00
      heatingcontrol.0	2020-01-08 20:46:29.478	debug	(13328) [INFO] status = true next event: 9 Jan 2020 13:30:00
      heatingcontrol.0	2020-01-08 20:46:29.476	debug	(13328) [INFO] status = true next event: 9 Jan 2020 12:00:00
      heatingcontrol.0	2020-01-08 20:46:29.476	debug	(13328) [INFO] status = true next event: 9 Jan 2020 05:45:00
      heatingcontrol.0	2020-01-08 20:46:29.474	debug	(13328) [INFO] status = true next event: 9 Jan 2020 05:00:00
      heatingcontrol.0	2020-01-08 20:46:29.474	debug	(13328) [INFO] status = true next event: 31 Mar 2020 23:55:00
      heatingcontrol.0	2020-01-08 20:46:29.470	debug	(13328) [INFO] status = true next event: 1 Oct 2020 00:05:00
      heatingcontrol.0	2020-01-08 20:46:29.237	debug	(13328) thermostat hm-rpc.0.NEQ1492817.4.SET_TEMPERATURE to 17; current is 19
      heatingcontrol.0	2020-01-08 20:46:29.229	debug	(13328) got {"val":17,"ack":false,"ts":1578255582298,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1578255582298}
      heatingcontrol.0	2020-01-08 20:46:29.228	debug	(13328) checking min temp with Rooms.Luca.MinimumTemperature
      heatingcontrol.0	2020-01-08 20:46:29.228	info	(13328) room Luca Thermostat Luca target is 17
      heatingcontrol.0	2020-01-08 20:46:29.228	info	(13328) setting to reduced/increased temperature in Luca to 17
      heatingcontrol.0	2020-01-08 20:46:29.228	debug	(13328) ### current > 1 4 2
      heatingcontrol.0	2020-01-08 20:46:29.228	debug	(13328) Luca found period 4 with 19 on 18,45
      heatingcontrol.0	2020-01-08 20:46:29.227	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.4.time 19
      heatingcontrol.0	2020-01-08 20:46:29.226	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.4.time
      heatingcontrol.0	2020-01-08 20:46:29.226	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.3.time 17
      heatingcontrol.0	2020-01-08 20:46:29.225	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.3.time
      heatingcontrol.0	2020-01-08 20:46:29.224	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.2.time 19
      heatingcontrol.0	2020-01-08 20:46:29.223	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.2.time
      heatingcontrol.0	2020-01-08 20:46:29.223	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.1.time 17
      heatingcontrol.0	2020-01-08 20:46:29.222	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.1.time
      heatingcontrol.0	2020-01-08 20:46:29.221	debug	(13328) check time for Luca Profiles.0.Luca.Mo-Fr.Periods.0.time 19
      heatingcontrol.0	2020-01-08 20:46:29.220	debug	(13328) check ID Profiles.0.Luca.Mo-Fr.Periods.0.time
      heatingcontrol.0	2020-01-08 20:46:29.220	debug	(13328) FindNextPeriod for 2020-1-8 8:46:29 PM in Luca
      heatingcontrol.0	2020-01-08 20:46:29.220	debug	(13328) AbsentDecrease {"val":17,"ack":true,"ts":1578256202485,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578256202484}
      heatingcontrol.0	2020-01-08 20:46:29.219	debug	(13328) Luca window open is false
      heatingcontrol.0	2020-01-08 20:46:29.219	debug	(13328) check room Luca
      heatingcontrol.0	2020-01-08 20:46:29.218	debug	(13328) profile 0
      heatingcontrol.0	2020-01-08 20:46:29.218	debug	(13328) get profile
      heatingcontrol.0	2020-01-08 20:46:29.217	debug	(13328) profile type 2
      heatingcontrol.0	2020-01-08 20:46:29.157	debug	(13328) ### state change already handled: false / false /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0	2020-01-08 20:46:29.155	info	(13328) calculating new target temperatures
      heatingcontrol.0	2020-01-08 20:46:29.155	debug	(13328) ### heatingcontrol.0.Present heatingcontrol.0.Present false true
      heatingcontrol.0	2020-01-08 20:46:29.154	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":false,"ack":true,"ts":1578512789152,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578512789147}
      heatingcontrol.0	2020-01-08 20:46:29.150	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":false,"ack":false,"ts":1578512789147,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1578512789147}
      heatingcontrol.0	2020-01-08 20:46:16.446	debug	(13328) system.adapter.admin.0: logging false
      heatingcontrol.0	2020-01-08 20:44:37.055	debug	(13328) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0	2020-01-08 20:44:37.053	debug	(13328) ### state change already handled: true / true /// heatingcontrol.0.Present / heatingcontrol.0.Present
      heatingcontrol.0	2020-01-08 20:44:37.053	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":true,"ack":true,"ts":1578512677050,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1578512676045}
      heatingcontrol.0	2020-01-08 20:44:37.048	debug	(13328) ### handle state change heatingcontrol.0.Present {"val":true,"ack":false,"ts":1578512677045,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1578512676045}
      heatingcontrol.0	2020-01-08 20:44:36.661	debug	(13328) ### all StateChange handled
      heatingcontrol.0	2020-01-08 20:44:36.661	debug	(13328) ### 111 handled
      heatingcontrol.0	2020-01-08 20:44:36.660	debug	(13328) [INFO] status = true next event: 11 Jan 2020 18:45:00
      heatingcontrol.0	2020-01-08 20:44:36.659	debug	(13328) [INFO] status = true next event: 11 Jan 2020 13:30:00
      heatingcontrol.0	2020-01-08 20:44:36.658	debug	(13328) [INFO] status = true next event: 11 Jan 2020 12:00:00
      heatingcontrol.0	2020-01-08 20:44:36.658	debug	(13328) [INFO] status = true next event: 11 Jan 2020 06:00:00
      heatingcontrol.0	2020-01-08 20:44:36.657	debug	(13328) [INFO] status = true next event: 11 Jan 2020 05:00:00
      heatingcontrol.0	2020-01-08 20:44:36.657	debug	(13328) [INFO] status = true next event: 9 Jan 2020 18:45:00
      heatingcontrol.0	2020-01-08 20:44:36.655	debug	(13328) [INFO] status = true next event: 9 Jan 2020 13:30:00
      heatingcontrol.0	2020-01-08 20:44:36.654	debug	(13328) [INFO] status = true next event: 9 Jan 2020 12:00:00
      heatingcontrol.0	2020-01-08 20:44:36.653	debug	(13328) [INFO] status = true next event: 9 Jan 2020 05:45:00
      heatingcontrol.0	2020-01-08 20:44:36.646	debug	(13328) [INFO] status = true next event: 9 Jan 2020 05:00:00
      heatingcontrol.0	2020-01-08 20:44:36.646	debug	(13328) [INFO] status = true next event: 31 Mar 2020 23:55:00
      heatingcontrol.0	2020-01-08 20:44:36.636	debug	(13328) [INFO] status = true next event: 1 Oct 2020 00:05:00
      heatingcontrol.0	2020-01-08 20:44:36.446	debug	(13328) thermostat hm-rpc.0.NEQ1492817.4.SET_TEMPERATURE to 19; current is 17
      heatingcontrol.0	2020-01-08 20:44:36.388	debug	(13328) got {"val":17,"ack":false,"ts":1578255582298,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1578255582298}
      heatingcontrol.0	2020-01-08 20:44:36.384	debug	(13328) checking min temp with Rooms.Luca.MinimumTemperature
      heatingcontrol.0	2020-01-08 20:44:36.384	info	(13328) room Luca Thermostat Luca target is 19
      Rene_HMR 1 Antwort Letzte Antwort
      • B BeNeDeLuX
        @Rene_HM
        Rene_HMR Offline
        Rene_HMR Offline
        Rene_HM
        #772
        @BeNeDeLuX sagte in Test Adapter HeatingControl v0.3.x:
        Das passt doch. Im log finde ich
        handle state change heatingcontrol.0.Present {"val":false ...
        und
        handle state change heatingcontrol.0.Present {"val":true ...
        Es kommen nur immer zwei gleich logs nacheinander, einer mit ack:false und einer mit ack:true, das ist aber okay...
          BeNeDeLuX
          #773
          Dann habe ich das Log einfach falsch gelesen 😊 Das mit den Datenpunkten ist mir jetzt auch klar.
          Vielen Dank für deine schnelle Hilfe!
          • X Offline
            X Offline
            xADDRx
            #774
            gibt es einen der die Funktion von Heating Controll für den jeweiliegn Raum ausschaltet?
            Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
            • X xADDRx
              Rene_HMR Offline
              Rene_HMR Offline
              Rene_HM
              #775
              @xADDRx Du kannst im admin die Räume aktivieren bzw. deaktivieren:
              X 1 Antwort Letzte Antwort
              • Rene_HMR Rene_HM
                X Offline
                X Offline
                xADDRx
                #776
                @Rene_HM hallo René, danke für die Antwort. Ich würde das gerne über Vis realisieren wollen.
                • X xADDRx
                  Rene_HMR Offline
                  Rene_HMR Offline
                  Rene_HM
                  #777
                  @xADDRx Deaktivieren von Räuemen geht über vis nicht, aber verschiedenste Absenkungen. Ich sehe den use case zum kompletten Deaktivieren aus vis derzeit noch nicht, was möchtest du erreichen?
                  • X Offline
                    X Offline
                    xADDRx
                    schrieb am zuletzt editiert von xADDRx
                    #778
                    Ein Besispiel: Ich habe ja mehrere Profile mit unterschiedlichen Uhrzeiten. Jetzt hatte gestern meine Frau die Temperatur um 15:58 Uhr im Badezimmer manuell auf Max (28°) gestellt. Da ich im Priofil ja die Uhrzeiten eingestellt habe. zB. 16Uhr 22°, hat der Adpater logischerweise die Temperatur von Max (28°) auf 22° gestellt.
                    Ich möchte so zusagen die Temperatur dann Manuell für jeden Raum steuern.
                    Geht das irgendiwíe?
                    • X xADDRx
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      #779
                      @xADDRx ja, mit Override. Da gibt man Dauer und Temperatur vor. Nach Ablauf der Override-Zeit greifen die Profil-Paramter wieder...
                      G 1 Antwort Letzte Antwort
                      • Rene_HMR Rene_HM
                        Gonzo0815
                        #780
                        @Rene_HM said in Test Adapter HeatingControl v0.3.x:
                        Wird da die Override Temperatur aufgerechnet oder gesetzt?
                        • G Offline
                          Gonzo0815
                          #781
                          Wenn ich aktuell den Override setze kommt im log folgender Fehler:
                          heatingcontrol.0	2020-01-14 19:06:13.908	info	(9102) handle actors Kinderzimmer Timo current 23.7 target 18
                          heatingcontrol.0	2020-01-14 19:06:13.907	info	(9102) handle actors Kinderzimmer Timo current 23.7 target 18
                          heatingcontrol.0	2020-01-14 19:06:00.006	info	(9102) calculating new target temperatures
                          heatingcontrol.0	2020-01-14 19:05:49.281	info	(9102) calculating new target temperatures
                          heatingcontrol.0	2020-01-14 19:05:37.897	error	(9102) exception in StartTemperaturOverride [TypeError: Cannot read property 'name' of undefined]
                          heatingcontrol.0	2020-01-14 19:05:37.897	info	(9102) room roomLivingRoom Thermostat Heizkörper Wohnzimmer set to 5
                          heatingcontrol.0	2020-01-14 19:05:37.798	info	(9102) change temperature override for room roomLivingRoom
                          • G Gonzo0815
                            Rene_HMR Offline
                            Rene_HMR Offline
                            Rene_HM
                            #782
                            @Gonzo0815 sagte in Test Adapter HeatingControl v0.3.x:
                            Das ist absolut, d.h. das ist der Wert der gesetzt wird.
                            Welche Version des Adapters verwendest du? hast du mehrere Thermostate für den Raum konfiguriert? Kannst du von dem Vorgang ein debug log posten?
                            • Rene_HMR Rene_HM
                              inspiriert vom Heizungsthermostat-Script und weil meine homeputer-Lizenz abgelaufen ist, und ich meine Heizungssteuerung von dort nach iobroker portieren wollte, ist der Adapter HeatingControl entstanden.
                              Features:
                              • setzen der Zieltemperatur in verschiedenen Thermostaten
                              • beliebige Anzahl von täglichen Zeitabschnitten mit unterschiedlichen Zieltemperaturen
                              • Zeit und Zieltemperatur per Visualisierung konfigurierbar
                              • automatische Suche nach vorhandenen Thermostaten im System (über Gewerk) und Zuordnung zu Räumen
                              • Für den Fall, dass der Thermostat nur als Thermometer verwendet wird, behandelt der Adapter auch digitale Outputs zum Schalten der Ventile. Im Moment ist dafür nur eine einfache Ein/Aus-Regelung implementiert (die für meine Zwecke ausreichend ist). Weitere Regelungen sind aber als Idee bereits vorhanden und können implementiert werden. Es gibt nun auch einen linearen on/off mit Hysterese
                              • es werden bis zu zwei Outputs für Ventile unterstützt
                              • Outputs werden auch automatisch den Räumen zugeordnet. Dafür müssen diese dem gleichen Gewerk wie Thermostate zugeordnet sein.
                              • im Admin des Adapters können Räume deaktiviert werden
                              • Absenkung bei Abwesenheit
                              • Ventile ein oder aus außerhalb der Heizperiode
                              • Verbindung zu ical
                              • Verbindung zu Feiertags-Adapter
                              • Senden von Nachrichten per email, Signal, Telegram, discord, ...
                              • Kamin-Modus
                              • Wartungsmodus
                              • mehrere Profile
                              • Tages-Programme für
                                - Montag - Sonntag
                                - Montag - Freitag + Samstag - Samstag
                                - jeden Tag separat
                              Versionen:
                              • 3.0.0
                                Status: beta seit 29.12.2025
                                NPM: ja
                                github: ja
                                weitere Informationen: github
                              • 2.12.19
                                Status: stable seit 26.10.2025
                                NPM: ja
                                github: ja
                              Mike Hellracer
                              #783
                              @Rene_HM
                              Habe den Adapter im Einsatz und bin an einer Visualisierung. Würde das gerne mit einem Popup analog dem Timer Popup von GuiseppeS realisieren. Da wird der Name des Timer an das Popup übergeben und die Werte als Datenpunkte ausgelesen.
                              Damit das mit den Heizung (1x Popup für alle Thermostate) auch funktioniert müssten die benötigten Werte als Datenpunkte im Raum erfasst sein. So könnte man den Namen des Raumes an das popup ubergeben und die Daten aus dem Adapter übernehmen.
                              Was haltet ihr davon?
                              • Rene_HMR Rene_HM
                                Gonzo0815
                                #784
                                @Rene_HM
                                Benutze folgende Version: 0.3.14
                                Den Fehler hab ich in allen Räumen.
                                heatingcontrol.0	2020-01-14 19:50:14.255	debug	(10893) ### 111 not handled yet
                                heatingcontrol.0	2020-01-14 19:50:14.254	debug	(10893) ### hm-rpc.0.NEQ1406276.4.ACTUAL_TEMPERATURE hm-rpc.0.NEQ1400681.4.SET_TEMPERATURE 22.2 16
                                heatingcontrol.0	2020-01-14 19:50:14.254	debug	(10893) ### handle state change hm-rpc.0.NEQ1406276.4.ACTUAL_TEMPERATURE {"val":22.2,"ack":true,"ts":1579027814224,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1579027814224}
                                host.IOBroker	2020-01-14 19:50:09.496	info	instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                                dwd.0	2020-01-14 19:50:08.983	info	(11324) Terminated (NO_ERROR): Without reason
                                dwd.0	2020-01-14 19:50:02.898	info	(11324) starting. Version 2.4.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.14.0
                                host.IOBroker	2020-01-14 19:50:00.082	info	instance system.adapter.dwd.0 started with pid 11324
                                heatingcontrol.0	2020-01-14 19:49:55.775	debug	(10893) ### all StateChange handled
                                heatingcontrol.0	2020-01-14 19:49:55.775	debug	(10893) ### 222 handled
                                heatingcontrol.0	2020-01-14 19:49:55.774	info	(10893) handle actors roomBedroom current 22.6 target 16
                                heatingcontrol.0	2020-01-14 19:49:55.773	debug	(10893) ### all StateChange handled
                                heatingcontrol.0	2020-01-14 19:49:55.773	debug	(10893) ### 222 handled
                                heatingcontrol.0	2020-01-14 19:49:55.773	info	(10893) handle actors roomBedroom current 22.6 target 16
                                heatingcontrol.0	2020-01-14 19:49:54.907	debug	(10893) ### handle devices [{"id":2,"name":"Heizkörper Schlafzimmer","OID_Current":"hm-rpc.0.NEQ1400681.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.NEQ1400681.4.SET_TEMPERATURE","isActive":true,"typ
                                heatingcontrol.0	2020-01-14 19:49:54.907	debug	(10893) handle id hm-rpc.0.NEQ1400681.4.SET_TEMPERATURE state {"val":16,"ack":true,"ts":1579027794886,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1579024800282}
                                heatingcontrol.0	2020-01-14 19:49:54.906	debug	(10893) ### 111 not handled yet
                                heatingcontrol.0	2020-01-14 19:49:54.906	debug	(10893) ### hm-rpc.0.NEQ1400681.4.SET_TEMPERATURE hm-rpc.0.NEQ1400681.4.ACTUAL_TEMPERATURE 16 22.6
                                heatingcontrol.0	2020-01-14 19:49:54.905	debug	(10893) ### handle state change hm-rpc.0.NEQ1400681.4.SET_TEMPERATURE {"val":16,"ack":true,"ts":1579027794886,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1579024800282}
                                heatingcontrol.0	2020-01-14 19:49:54.904	debug	(10893) ### handle devices [{"id":2,"name":"Heizkörper Schlafzimmer","OID_Current":"hm-rpc.0.NEQ1400681.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.NEQ1400681.4.SET_TEMPERATURE","isActive":true,"typ
                                heatingcontrol.0	2020-01-14 19:49:54.903	debug	(10893) handle id hm-rpc.0.NEQ1400681.4.ACTUAL_TEMPERATURE state {"val":22.6,"ack":true,"ts":1579027794886,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1579027794886}
                                heatingcontrol.0	2020-01-14 19:49:54.903	debug	(10893) ### 111 not handled yet
                                heatingcontrol.0	2020-01-14 19:49:54.902	debug	(10893) ### hm-rpc.0.NEQ1400681.4.ACTUAL_TEMPERATURE heatingcontrol.0.Rooms.roomLivingRoom.TemperaturOverride 22.6 4
                                heatingcontrol.0	2020-01-14 19:49:54.902	debug	(10893) ### handle state change hm-rpc.0.NEQ1400681.4.ACTUAL_TEMPERATURE {"val":22.6,"ack":true,"ts":1579027794886,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1579027794886}
                                heatingcontrol.0	2020-01-14 19:49:23.818	debug	(10893) ### all StateChange handled
                                heatingcontrol.0	2020-01-14 19:49:23.818	debug	(10893) ### 111 handled
                                heatingcontrol.0	2020-01-14 19:49:23.818	error	(10893) exception in StartTemperaturOverride [TypeError: Cannot read property 'name' of undefined]
                                heatingcontrol.0	2020-01-14 19:49:23.817	info	(10893) room roomLivingRoom Thermostat Heizkörper Wohnzimmer set to 4
                                heatingcontrol.0	2020-01-14 19:49:23.817	debug	(10893) [INFO] status = true next event: 15 Jan 2020 14:58:00
                                heatingcontrol.0	2020-01-14 19:49:23.813	debug	(10893) [INFO] status = true next event: 15 Jan 2020 14:26:00
                                heatingcontrol.0	2020-01-14 19:49:23.810	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:14:00
                                heatingcontrol.0	2020-01-14 19:49:23.807	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:01:00
                                heatingcontrol.0	2020-01-14 19:49:23.805	debug	(10893) [INFO] status = true next event: 18 Jan 2020 06:30:00
                                heatingcontrol.0	2020-01-14 19:49:23.802	debug	(10893) [INFO] status = true next event: 14 Jan 2020 23:10:00
                                heatingcontrol.0	2020-01-14 19:49:23.801	debug	(10893) [INFO] status = true next event: 15 Jan 2020 19:06:00
                                heatingcontrol.0	2020-01-14 19:49:23.798	debug	(10893) [INFO] status = true next event: 15 Jan 2020 09:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.797	debug	(10893) [INFO] status = true next event: 15 Jan 2020 05:45:00
                                heatingcontrol.0	2020-01-14 19:49:23.794	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:05:00
                                heatingcontrol.0	2020-01-14 19:49:23.791	debug	(10893) [INFO] status = true next event: 18 Jan 2020 20:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.789	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:13:00
                                heatingcontrol.0	2020-01-14 19:49:23.787	debug	(10893) [INFO] status = true next event: 18 Jan 2020 20:07:00
                                heatingcontrol.0	2020-01-14 19:49:23.784	debug	(10893) [INFO] status = true next event: 18 Jan 2020 12:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.783	debug	(10893) [INFO] status = true next event: 18 Jan 2020 08:03:00
                                heatingcontrol.0	2020-01-14 19:49:23.781	debug	(10893) [INFO] status = true next event: 18 Jan 2020 08:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.780	debug	(10893) [INFO] status = true next event: 15 Jan 2020 13:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.777	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:19:00
                                heatingcontrol.0	2020-01-14 19:49:23.773	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:09:00
                                heatingcontrol.0	2020-01-14 19:49:23.770	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:06:00
                                heatingcontrol.0	2020-01-14 19:49:23.767	debug	(10893) [INFO] status = true next event: 18 Jan 2020 19:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.764	debug	(10893) [INFO] status = true next event: 15 Jan 2020 19:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.762	debug	(10893) [INFO] status = true next event: 15 Jan 2020 06:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.760	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:51:00
                                heatingcontrol.0	2020-01-14 19:49:23.753	debug	(10893) [INFO] status = true next event: 18 Jan 2020 23:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.751	debug	(10893) [INFO] status = true next event: 18 Jan 2020 20:03:00
                                heatingcontrol.0	2020-01-14 19:49:23.748	debug	(10893) [INFO] status = true next event: 18 Jan 2020 16:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.746	debug	(10893) [INFO] status = true next event: 18 Jan 2020 07:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.745	debug	(10893) [INFO] status = true next event: 14 Jan 2020 23:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.744	debug	(10893) [INFO] status = true next event: 14 Jan 2020 21:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.743	debug	(10893) [INFO] status = true next event: 15 Jan 2020 12:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.742	debug	(10893) [INFO] status = true next event: 15 Jan 2020 08:00:00
                                heatingcontrol.0	2020-01-14 19:49:23.741	debug	(10893) [INFO] status = true next event: 15 Jan 2020 05:30:00
                                heatingcontrol.0	2020-01-14 19:49:23.738	debug	(10893) [INFO] status = true next event: 31 Mar 2020 23:55:00
                                heatingcontrol.0	2020-01-14 19:49:23.732	debug	(10893) [INFO] status = true next event: 1 Oct 2020 00:05:00
                                heatingcontrol.0	2020-01-14 19:49:23.724	debug	(10893) CreateCron4ResetTempOverride: create cron job #34 at Wed Jan 15 2020 14:58:23 GMT+0100 (GMT+01:00) string: 58 14 15 0 * Europe/Berlin
                                heatingcontrol.0	2020-01-14 19:49:23.662	debug	(10893) ### state change already handled: 4 / 4 /// heatingcontrol.0.Rooms.roomLivingRoom.TemperaturOverride / heatingcontrol.0.Rooms.roomLivingRoom.TemperaturOverride
                                heatingcontrol.0	2020-01-14 19:49:23.659	info	(10893) change temperature override for room roomLivingRoom
                                heatingcontrol.0	2020-01-14 19:49:23.659	debug	(10893) ### heatingcontrol.0.Rooms.roomLivingRoom.TemperaturOverride hm-rpc.0.NEQ1400589.4.SET_TEMPERATURE 4 18
                                heatingcontrol.0	2020-01-14 19:49:23.658	debug	(10893) ### handle state change heatingcontrol.0.Rooms.roomLivingRoom.TemperaturOverride {"val":4,"ack":true,"ts":1579027763651,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin
                                heatingcontrol.0	2020-01-14 19:49:23.648	debug	(10893) ### handle state change heatingcontrol.0.Rooms.roomLivingRoom.TemperaturOverride {"val":4,"ack":false,"ts":1579027763643,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":157
                                • Rene_HMR Rene_HM
                                  Features:
                                  • Kamin-Modus
                                  • Wartungsmodus
                                  • mehrere Profile
                                    - Montag - Sonntag
                                    - jeden Tag separat
                                  Versionen:
                                  • 3.0.0
                                    NPM: ja
                                    github: ja
                                  • 2.12.19
                                    NPM: ja
                                    github: ja
                                  Mike Hellracer
                                  #785
                                  @Rene_HM
                                  Hi habe mal nachgeschaut.
                                  Für das Popup bräuchten wir die Werte vom Thermostat aus dem Raum Editor unterhalb des Raumes.
                                  • G Gonzo0815
                                    @Rene_HM
                                    Rene_HMR Offline
                                    Rene_HMR Offline
                                    Rene_HM
                                    #786
                                    verwendest du "MinimalTemperatur" oder ist das ausgeschaltet?
                                    • Rene_HMR Rene_HM
                                      Gonzo0815
                                      #787
                                      @Rene_HM ist eingeschaltet
                                      • G Gonzo0815
                                        Rene_HMR Offline
                                        Rene_HMR Offline
                                        Rene_HM
                                        #788
                                        @Gonzo0815 schalte mal bitte aus und probier nochmal. Wenn das dann funktioniert, weiß ich wo ich suchen muss...
                                        • Rene_HMR Rene_HM
                                          Gonzo0815
                                          #789
                                          @Rene_HM
                                          Wenn es aus ist funktioniert es.
                                          Rene_HMR 2 Antworten Letzte Antwort
