  3. Entwicklung
  4. Adapter mihome-vacuum anpassungen
    apollon77A
vacuumadapterentwicklungtestroborockzeitplanraumreinigung
589 Beiträge 73 Kommentatoren 201.1k Aufrufe 73 Beobachtet
  • M mumurik
    @dirkhe
    bekomme ber Installation des Adapters folgende Fehlermeldung, kann aber mit dieser leider nichts anfangen:
    $ ./iobroker url "https://github.com/dirkhe/ioBroker.mihome-vacuum.git"
    install https://github.com/dirkhe/ioBroker.mihome-vacuum/tarball/master
    npm install https://github.com/dirkhe/ioBroker.mihome-vacuum/tarball/master --production --save --prefix "/opt/iobroker" (System call)
    node-pre-gyp
    WARN Using request for node-pre-gyp https download
    node-pre-gyp
     WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v57-linux-glibc-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@8.16.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
    Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp
     ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    gyp ERR! stack     at emitTwo (events.js:126:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.14.71-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=4" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
    gyp ERR! cwd /opt/iobroker/node_modules/canvas
    gyp ERR! node -v v8.16.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    node-pre-gyp
     ERR! build error
    node-pre-gyp
     ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=4 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    node-pre-gyp ERR! System Linux 4.14.71-v7+
    node-pre-gyp ERR! command "/usr/local/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v8.16.0
    node-pre-gyp
     ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
    npm
    ERR! code ELIFECYCLE
    npm ERR! errno 1npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR! npm ERR!
     Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /home/iobroker/.npm/_logs/2020-01-09T19_38_43_809Z-debug.log
    process exited with code 0
    Woran könnte es liegen?
    MeistertrM
    MeistertrM
    Meistertr
    schrieb am zuletzt editiert von Meistertr
    oops nicht zu ende gelesen
    O 1 Antwort Letzte Antwort
    • MeistertrM Meistertr
      O
      O
      oranggila
      @Meistertr gelesen schon, aber wahrscheinlich falsch verstanden.
      @dirkhe said in Adapter mihome-vacuum anpassungen:
      @lesiflo ok, aber ich denke, dass ich die Funktion dann so drin lassen kann. Ich könnte bei leeren Räumen einen Dummy Datenpunkt anlegen, wo ich die Info anlege, dass die Räume erst in der App angelegt werden müssen, wenn möglich. Als Info für den User
      @dirkhe Du würdest also nicht nur den Dummy-Datenpunkt mit der Info anlegen, sondern auch die channels pro Raum, damit es schon nutzbar ist. Dann bin ich glücklich :-)
      Intel NUC - ioBroker in Proxmox-VM, Zigbee TCP CC2652P2, MG4 Trophy (e-Auto)
      • D
        D
        dirkhe
        Da lässt sich sicher was machen. Ich könnte Mal schauen, ob ich einen Knop einbauen kann, der so einen Channel anlegt. Kommt denn bei dir der room Channel schon? Denn dann muss ich aufpassen, dass ich die nicht auf unser setze..
        Ich schaue mal
        • D dirkhe
          Ich schaue mal
          O
          O
          oranggila
          @dirkhe Nein, channel fehlen noch, siehe Screenshot oben.
          • D dirkhe
            @Agria4800 sagte in Adapter mihome-vacuum anpassungen:
            @dirkhe hab die neue Version installiert, keine Probleme oder Fehler im Log.
            Valetudo noch nicht getestet.
            Mir ist aber aufgefallen, das bei Fanpower nur eine Einstellung 101, 102,103,104 funktioniert, also nicht mehr prozentual von 0-100. Liegt wohl aber nicht an deiner Version, bei der 1.1.6 war es auch seit ein paar Tagen so. Ich vermute mal, das es an dem neuen Update legt, das Xiaomi für den S5 rausgebracht hat.
            Kann das noch jemand bestätigen ?
            Eigentlich sollte das nur bei model === 'roborock.vacuum.m1s' || model === 'roborock.vacuum.s6' umgeswitcht werden. Was steht denn bei dir unter info in device_model?
            O
            O
            oranggila
            @dirkhe Kann ich bestätigen. Passiert auch für Model roborock.vacuum.s5
            Die Einstellungen sind:
            101=Silent/Leise
            102=Balanced/Balance
            103=Turbo
            104=Max
            105=Gentle
            106=Customize (Auto)
            • B
              B
              bug77
              Könntest du nicht auch einen Datenpunkt erstellen, wenn man den Abfallbehälter entnimmt? Das wäre nützlich um den Status abzufragen.
              • O oranggila
                D
                D
                dirkhe
                @oranggila sorry, hatte ich nicht gesehen. OK, dann muss ich schauen, wie ich das mache. Die müssen dann als manuell gekennzeichnet sein, da fällt mir schon was ein...
                • B bug77
                  D
                  D
                  dirkhe
                  @bug77 sagte in Adapter mihome-vacuum anpassungen:
                  Muss ich Mal schauen, wie der Status heißt, allerdings frage ich persönlich nur 1 Mal pro Minute ab..
                  • O oranggila
                    101=Silent/Leise
                    103=Turbo
                    104=Max
                    105=Gentle
                    D
                    D
                    dirkhe
                    @oranggila sagte in Adapter mihome-vacuum anpassungen:
                    101=Silent/Leise
                    103=Turbo
                    104=Max
                    105=Gentle
                    Was kannst du bestätigen?
                    Die stati könnte ich aber für den s5 ergänzen
                    • D dirkhe
                      101=Silent/Leise
                      103=Turbo
                      104=Max
                      105=Gentle
                      O
                      O
                      oranggila
                      @dirkhe ...dass beim S5 in der neuen Beta-Firmware nur die Einstellung 101-104 funktioniert, nicht mehr prozentual (105-106 habe ich selbst noch nicht gesehen. Die Belegung habe ich in einem anderen Post gelesen)
                      @Agria4800 said in Adapter mihome-vacuum anpassungen:
                      Ja, kannst Du gern aufnehmen.
                      • D
                        D
                        dirkhe
                        Hallo zusammen.
                        ich habe eine neue Version hochgeladen:
                        Manuelle Räume können jetzt erstellt werden
                        Die Stati für den S5 habe ich angepasst
                        Leider konnte ich nicht herausfinden, wann der Abfallbehälter entfernt wurde
                        O M 2 Antworten Letzte Antwort
                        • D
                          D
                          dirkhe
                          Ich habe die Deutsche Doku mal ergänzt
                          1. https://github.com/dirkhe/ioBroker.mihome-vacuum/blob/master/README_de.md#räume
                          2. https://github.com/dirkhe/ioBroker.mihome-vacuum/blob/master/README_de.md#timer
                          3. https://github.com/dirkhe/ioBroker.mihome-vacuum/blob/master/README_de.md#eigene-kommandos-per-sendto-schicken (Raum/Räume saugen und Segment saugen)
                          vlt. könnt ihr mal lesen und feedback geben, dann würde ich das in die englische übernehmen.
                          @Meistertr kannst du dir bitte mal die beiden auskommentierten codeblöcke in der index_m.html anschauen, ich denke der code kann weg. Das Auskommentieren habe ich gemacht und konnte bis jetzt keinen Fehler entdecken.
                          gruss
                          Dirk
                          MeistertrM 1 Antwort Letzte Antwort
                          • 0
                            HI,
                            ich habe den Mi Robot Vacuum v1 (Gen.1) mit Valetudo RE 0.8.1, funktioniert dort auch die Raumerkennung?
                            Mfg
                            0018
                            • 0 0018
                              HI,
                              MeistertrM
                              MeistertrM
                              Meistertr
                              @0018 nein wollte ich aber noch bei Gelegenheit einbauen.
                              0 AlCalzoneA 3 Antworten Letzte Antwort
                                @Meistertr sagte in Adapter mihome-vacuum anpassungen:
                                @Meistertr das klingt super, hätte großes Interesse :-)
                                Mfg
                                0018
                                • D dirkhe
                                  gruss
                                  Dirk
                                  MeistertrM
                                  MeistertrM
                                  Meistertr
                                  @dirkhe der auskommentierte teil kann weg, kommt glaub ich aus einer alten Tabellenerstellung...
                                    AlCalzoneA
                                    AlCalzoneA
                                    AlCalzone
                                    @Meistertr Macht es ggf. Sinn, den Test auf gedrehte Karte aus meinem Sauger-Skript zu übernehmen, wenn jetzt eh schon Valetudo-Integration vorgesehen ist? Müsste man nur schauen, wie man sinnvoll die nicht-gedrehte Orientierung festlegt.
                                    • AlCalzoneA AlCalzone
                                      MeistertrM
                                      MeistertrM
                                      Meistertr
                                      @AlCalzone hast du es irgendwo hochgeladen, dann schau ich mal
                                        D
                                        D
                                        dirkhe
                                        Ich hatte mir schon so was gedacht...
                                        Dann würde ich den löschen.
                                        Von meiner Seite müsste dann noch der englische Teil der Doku übersetzt werden, vlt mache ich noch ein paar Datenpunkte sprachabhängig, aber dann könnte ich ein pullrequest stellen, müssten dann nur mit der Version Mal schauen
                                          AlCalzoneA
                                          AlCalzoneA
                                          AlCalzone
                                          @Meistertr Bittesehr:
                                          https://forum.iobroker.net/post/332066
                                          Beachte auch die ergänzenden Hinweise:
                                          https://forum.iobroker.net/post/334782
                                          und
                                          https://forum.iobroker.net/post/337560
                                          83.9k
