  4. js-controller 2.2 jetzt im Latest
js-controller
160 Beiträge 39 Kommentatoren 33.2k Aufrufe 31 Beobachtet
  • K knopers1
    ich habe soeben den js-controller auf 2.2 hochgezogen..
    Jetzt läuft mein TR-064 Adapter nicht...
    host.raspberrypi	2020-01-06 15:14:36.271	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2020-01-06 15:14:36.271	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
    host.raspberrypi	2020-01-06 15:14:36.271	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
    host.raspberrypi	2020-01-06 15:14:36.271	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
    host.raspberrypi	2020-01-06 15:14:36.270	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2020-01-06 15:14:36.270	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2020-01-06 15:14:36.270	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2020-01-06 15:14:36.270	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-01-06 15:14:36.270	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2020-01-06 15:14:36.270	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
    host.raspberrypi	2020-01-06 15:14:36.269	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
    host.raspberrypi	2020-01-06 15:14:36.269	error	Caught by controller[0]: TypeError: fns.adapter is not a function
    host.raspberrypi	2020-01-06 15:14:36.269	error	Caught by controller[0]: ^
    host.raspberrypi	2020-01-06 15:14:36.269	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
    host.raspberrypi	2020-01-06 15:14:36.269	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
    okay, geht wieder mit:
    cd /opt/iobroker/
    iobroker stop tr-064
    cd /opt/iobroker/node_modules/iobroker.tr-064
    npm install soef
    @knopers1 An sich hätte ich jetzt gesagt "Stell mal auf Community Version um" ... aber warte mal damit wenns so tut ... ;-)
    • DiginixD Offline
      DiginixD Offline
      Diginix
      @apollon77 sagte in js-controller 2.2 jetzt im Latest:
      Nötige Adapter-Aktualisierungen
      iqontrol TBD (die Version ist primär nötig wenn man Admin 3.7.7 mit einem js-controller < 2.2 nutzt! siehe https://github.com/sbormann/ioBroker.iqontrol/issues/104)
      Bin nun auch auf 2.2.7 mit admin 3.7.7 und nodejs 10.18.0 und alles läuft soweit.
      iqontrol hab ich in Ver. 0.2.14 installiert aber noch nichts damit gemacht. Adapter ist grün und Frontend funktioniert. K.a. was mit TBD gemeint ist.
      Der Bug dass bei Änderung von zB History Einstellungen die materialUI Einstellungen verloren gehen existiert aber weiterhin.
      https://github.com/ioBroker/ioBroker.js-controller/issues/544
      ..:: So long! Tom ::..
      • MicM Offline
        MicM Offline
        Mic
        Bei mir läuft nach Update auf 2.2.7 alles, wie es soll. Danke 👍
        • apollon77A apollon77
          Hallo ioBroker-Community,
          wie im neuen Release-Cycle für den js-controller geplant, kommt heute der neuen js-controller 2.2 (Releasename "Dina") ins Latest Repository. Ein großer Dank geht an alle User die bereits in den Letzten Tagen diese Version im beta test getestet und Probleme und Fehler zur Behebung gemeldet haben!
          Das Release ist im grossen und ganzen ein weiterer Bugfix-Release zur 2.1.1 und behebt noch ein paar kleinere Probleme. Darüber hinaus gab es aber auch die nächsten Umbauarbeiten unter der Haube, die am Ende keine Auswirkungen auf die Funktionalität haben sollten. Mehr dazu weiter unten und im Changelog.
          Der js-controller 2.2 ist generell kompatibel mit allen bestehenden ioBroker-Systemen. Ein Update von der 2.0/2.1 ist problemlos. Auch die minimale Node.js Version bleibt wie vom letzten Release bekannt bei 8.x, besser noch auf 10.x.
          Es gibt diesmal zwei Adapter die Aktualisiert werden müssen! Mehr dazu im nächsten Abschnitt!
          Installation
          VOR der Installation
          Wie bei jedem Update dieser Art: Bitte macht ein Backup! iobroker backup, bzw. kopieren des iobroker-data Verzeichnisses reichen an sich im Zweifel auch aus (ioBroker vorher stoppen natürlich). Bitte nicht das node_modules Verzeichnis einfach kopieren, da sonst symbolische Links kaputt gehen können, was zu größeren Problemen danach führt.
          Die folgenden Adapter müssen auf die genannten Minimalversionsnummern aktualisiert werden, da diese sonst nicht mit dem js-controller 2.2 funktionieren. Diese Updates am besten vorher ausführen, weil alle genannten Versionen auch mit den alten js-controller Versionen funktionieren.
          • admin 3.7.7 oder höher! (Sonst können Custom-Objektdaten -das unter dem Schraubenschlüssel - nicht mehr deaktiviert werden
          • iqontrol TBD (die Version ist primär nötig wenn man Admin 3.7.7 mit einem js-controller < 2.2 nutzt! siehe https://github.com/sbormann/ioBroker.iqontrol/issues/104)
          Für js-controller 2.4 (vorauss Ende März) ist geplant eine Funktion für Adapter zu entfernen. Alle Adapter welche diese nutzen schreiben bei der Nutzung einen Fehler ins Log. Bitte helft mit und meldet dies bei den Entwicklern bzw nutzt "Thumbs up" um zu zeigen das Ihr es auch nutzt.
          Achtung: Slave-Systeme zuerst!
          Bei einem Multi-Host-System, welches auf js-controller 2.1 läuft ist es beim Update auf Version 2.2 empfohlen, zuerst die Slave-Systeme zu aktualisieren. Der Master wird als letztes aktualisiert!
          Bei Updates von Master/Slave-Systemen mit js-controller 1.5 oder früher auf die 2.2 müssen zwingend zuerst die Slaves und der Master als letztes aktualisiert werden. Die Slaves bleiben nach dem Update offline und werden erst wieder funktionieren wenn auch der Master auf die 2.2 aktualisiert wurde!
          Windows
          Auf Systemen, die mit dem neuen Windows Installer eingerichtet wurden, darf der js-controller nicht mir npm aktualisiert werden. Es wird eine neue Version des Windows Installers geben, die das Update des js-controllers mit wenigen Mausklicks ermöglicht. Wir updaten dazu hier im Thread.
          Für alle "alten manuellen" Installationen gilt
          • ioBroker muss gestoppt sein.
          • Vor dem Update bitte prüfen das keine Prozesse mehr laufen
          • iobroker upgrade self
          • ioBroker starten
          Linux
          • ioBroker stoppen (iobroker stop)
          • prüfen das keine Prozesse (Adapter, Backups) mehr laufen (ps auxww|grep io und auch ps auxww|grep backup ). Es passiert manchmal das trotz dem Stoppen noch Zombies zurückbleiben
          • Wie üblich wird das Update dann per iobroker upgrade self ausgeführt.
          • ioBroker starten (iobroker start)
          Bei Fehlern:
          Wenn bei der Linux-Installation Fehler wegen fehlender Zugriffsrechte auftreten, am besten den Installation-Fixer nutzen und die Installation wiederholen.
          curl -sL https://iobroker.net/fix.sh | bash -
          Falls es auch danach noch Fehler gibt, bitte die Installation erneut mittels sudo -H -u iobroker npm install iobroker.js-controller versuchen. Bitte berichtet solche Fälle hier im Thread.
          NACH der Installation
          Nach der Installation den ioBroker wieder starten (z.B. mittels iobroker start).
          Wenn alles klappt merkt Ihr ausser der höheren Versionsnummer in der Host-Ansicht im Admin keinen Unterschied. Alles funktioniert weiterhin wie vorher. Alle Adapterinstanzen starten und funktionieren. Wenn das so ist hat alles geklappt. Die großen Änderungen sind alle "Unter der Haube" versteckt.
          Dazu, was Euch jetzt die ganzen Neuerungen bringen, findet Ihr weiter unten in diesem Text Informationen. Neue Funktionen als Basis für Weiterentwicklungen wurden behutsam integriert und einige bestehende Probleme gezielt behoben.
          Mit iobroker help wird eine Liste der möglichen Kommandozeilen-Kommandos angezeigt, die mit Version 2.0 um einige Befehle länger geworden ist.
          Was hat sich geändert, was besonders ansehen/beachten?
          Neben einiger weiterer Bugfixes, die fast in eine 2.1.2 eingeflossen wären, gibt es folgende Änderungen und fixes zu erwähnen:
          • Logfiles sollten wieder sauber nach dem rotieren gelöscht werden. Logfiles werden jetzt beim Rotieren gepackt und ältere Files liegen daher als .gz Files im Verzeichnis (letztes nicht unter Windows)
          • Restart von Instanzen funktioniert wieder zuverässig
          • State und Object-Subscriptions des Systems und der eigentlichen Adapter-Logik werden nun getrennt ausgeführt. In der Vergangenheit konnte es in Ausnahmefällen hier zu Überschneidungen kommen, die dann Auswirkungen hatten. Diese Änderung sollte keinerlei Auswirkung auf Funktionen von Adaptern haben.
          • Der Socket.io Kompatibilitätsschicht die in der 2.0/2.1 noch drin war um die Kommunikation von "neuen" Slaves mit einem "alten" Master zu erlauben wurde wie geplant entfernt.
          Wie bereits gesagt, viele Änderungen fanden hinter den Kulissen statt. Hier für Interessierte als Spoiler eine Zusammenfassung:
          2.2.7 (2020-01-03) Release Dina
          Breaking changes
          • (bluefox) remove lenMessage from adapter methods because deprecated since long time
          • (Apollon77) Remove Socket.io compatibility layer - master/slave systems coming from 1.5 need to update to 2.0 or manually!
          New user features
          • (Apollon77) Also allow ÄÖÜäöüа-яА-Я as characters for first character of object ids
          • (Apollon77) create symlink to current logfile (fixes #578) - an iobroker.current.log is created and always points to the current logfile (alternative to using iobroker logs --watch CLI command
          Adapter developer relevant changes
          • (Apollon77) make options parameter for getObjectList optional again
          • (Apollon77) add warning messge for getMessage method to make deprecation more visible
          • (bluefox) Add Package installation by js-controller for Linux based systems (apt/yum package managers) via io-package common.osDependencies[process.platform]
          • (bluefox) Add for delObject the recursive flag to recursively delete objects; use feature flag ADAPTER_DEL_OBJECT_RECURSIVE in your adapter code to detect if the js-controller supports it or not!
          Further changes
          • (Apollon77) optimize questions on setup custom
          • (bluefox) Add support for vendor specific logic and database initialization
          • (Apollon77) separate system and user/adapter subscribes, introduce "changeUser" trigger for States and Objects
          • (Apollon77) Update dependencies
          • (Apollon77) make sure Redis simulator only set object data, all other logic is done in objects lib
          Bugfixes
          • (bluefox) CLI: check if object exists by "state set" command and other fixes
          • (Apollon77) Make sure adapter with longer stopTimeouts can be restarted as usual; the "stopping" flag was blocking the restart logic
          • (Apollon77) make sure adapters can be stopped again with setting .alive to false
          • (Apollon77) fix log file rotation; additionally old logs are now packed with gz
          • (bluefox) Fixed rights by object creation
          • (Apollon77) make sure restart of instances work in all cases
          • (AlCalzone) fix iobroker start all to not hang after starting all instances
          • (Apollon77) make sure auto rotation for logs work now with winston and make sure "old style manual cleanup" too
          • (Apollon77) fix error when 'iobroker url' is called without any parameter
          • (Apollon77) Also log exceptions for compact group controller
          • (bluefox) Fix wrong error handling for adapter deletions; should work again! Fixes #576
          • (Apollon77) add certificate handling if a local file is specified and do not overwrite if invalid in setup first
          • (Apollon77) make sure adapters and instances can be deleted again
          • (Apollon77) fix some more places where checks for not connected objects db were not triggered
          • (foxriver76) fix async version of getEncryptedConfig
          • (Apollon77) enhance errorhandling in several places
          • (bluefox) obj type 'adapter' not set if installing adapter via octocat (#539)
          • (bluefox) fixes Change settings of onlyWWW adapter cause exception (#549)
          Weitere Details zu den Änderungen und Bugfixes ist im Changelog einzusehen.
          Wie Fehler melden?
          Wer sich unsicher ist, ob ein Fehler vorliegt, sollte am besten hier im Thread das Problem beschreiben. So können wir alle versuchen, das Problem nachzuvollziehen und ggf. einzugrenzen.
          Sobald ein Fehler auftritt der in einer Fehlermeldung oder einen Crash mit Fehlerdetails im Log oder auf Kommandozeile endet, dann dazu am besten direkt ein GitHub-Issue im js-controller Projekt öffnen und zusätzlich hier im Thread posten. Je detaillierter die Angaben im Issue sind (genaue Fehlermeldungen/Logs, Infos zur OS- und Node.js-Umgebung sowie genaue Schritte zur Reproduktion des Problems), umso schneller können wir Fehler einkreisen und beheben.
          Ingo
          dslraserD Offline
          dslraserD Offline
          dslraser
          was ist TBD ? Welche Version ist das und ist die über github zu installieren ? Hat diese Version eine Versionsnummer ?
          DiginixD apollon77A 2 Antworten Letzte Antwort
          • dslraserD dslraser
            DiginixD Offline
            DiginixD Offline
            Diginix
            @dslraser Ich tipp auf to be done/decided. Wie schon erwähnt läuft 0.2.14 bei mir unauffällig weiter. Habe aber noch keine eigenen Views usw. erstellt.
              @dslraser da ist auch ein Link zu einem GitHub issue. TBD (to be done) heißt: issue für den dev ist offen und er ist dran eine neue version zu machen. Ich kenne sie aber noch nicht weil es sie noch nicht gibt. Also : abwarten
                dslraserD Offline
                dslraserD Offline
                dslraser
                Also : abwarten
                Danke für die Info.
                also dann hier auch noch abwarten ?
                • CKMartensC Offline
                  CKMartensC Offline
                  CKMartens
                  Habe wieder beim Upgrade eine Fehlermeldung:
                  Ist aber sauber installiert.
                    Also : abwarten
                    Danke für die Info.
                    @dslraser mit nem 2.2.7er Controller ist wieder alles gut mit iqontrol. Geht nur um ältere Controller bei dem problem
                    • CKMartensC CKMartens
                      @CKMartens die üblichen compile Warnungen von Unix-dgram beibringen nodejs Versionen. Kann man nix machen.
                        ChaotC Offline
                        ChaotC Offline
                        Chaot
                        @apollon77
                        Ob das jetzt mit dem Controler zu tun hat oder mit Admin kann ich nicht so genau eingrenzen.
                        Aber bei mir ist im Vis Editor der horizontale Scrollbalken weg.
                        Normalerweise benötige ich den nie, aber da ich heute ein größeres Projekt importiert habe ist mir das so aufgefallen.
                        Fehler taucht bei Chrome und FF auf, liegt also vermutlich nicht am Browser.
                        apollon77A crunchipC 2 Antworten Letzte Antwort
                        • ChaotC Chaot
                          @apollon77
                          @Chaot kann beides weder com Controller noch von Admin Kommen. Bitte Vis issue anlegen mit Screenshot.
                            dslraserD Offline
                            dslraserD Offline
                            dslraser
                            @apollon77
                            ich habe Blödsinn gemacht, wie bekomme ich das wieder weg.
                            This adapter cannot be installed directly from github.
                            You must install it from npm.
                            Write for that "npm install iobroker.admin" in according directory.
                            was da steht habe ich schon gemacht. iobroker läuft auch, aber wenn ich mich anmelden will, dann kommt nur diese Meldung und die Oberfläche wird nicht geöffnet.
                            • ChaotC Chaot
                              @apollon77
                              crunchipC Offline
                              crunchipC Offline
                              @Chaot ist bei mir schon ein halbes Jahr so, aber wie bei dir ... auch erst aufgefallen bei nem grösseren Projekt
                                @apollon77
                                @dslraser wann kommt wo diese Meldung?
                                  dslraserD Offline
                                  dslraserD Offline
                                  dslraser
                                  @apollon77
                                  wenn ich iobroker im Browser aufrufen will
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    @apollon77
                                    wie war nochmal der Befehl (Console) eine neue zusätzliche admin intanz anzulegen ?
                                      @apollon77
                                      @dslraser also Admin? Mal per npm nahh CH installiert?
                                        dslraserD Offline
                                        dslraserD Offline
                                        dslraser
                                        @apollon77
                                        ja Admin, habe ich, aber die Meldung bleibt
                                          @apollon77
                                          @dslraser
                                          Das sollte es wieder zum laufen bekommen.
                                          cd /opt/iobroker/
                                          iobroker stop
                                          npm install iobroker.admin@3.7.7
                                          iobroker start
