  4. SQL Adapter
SQL Adapter
sql adapter
12 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • GoerschG Offline
    GoerschG Offline
    Goersch
    hab ein Problem mit dem SQL-Adapter (raspberry) - er startet nicht mehr.
    iobroker js-controller 2.1.1
    npm 6.4.1
    node 10.10.0
    Log:
    host.HA-Mieter-Server 2019-12-21 15:46:44.575 error instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.HA-Mieter-Server 2019-12-21 15:46:44.575 error Caught by controller[0]: at Module.load (module.js:554:32)
    host.HA-Mieter-Server 2019-12-21 15:46:44.575 error Caught by controller[0]: at Object.Module._extensions..js (module.js:646:10)
    host.HA-Mieter-Server 2019-12-21 15:46:44.574 error Caught by controller[0]: at Module._compile (module.js:635:30)
    host.HA-Mieter-Server 2019-12-21 15:46:44.574 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:75)
    host.HA-Mieter-Server 2019-12-21 15:46:44.574 error Caught by controller[0]: at require (internal/module.js:11:18)
    host.HA-Mieter-Server 2019-12-21 15:46:44.574 error Caught by controller[0]: at Module.require (module.js:579:17)
    host.HA-Mieter-Server 2019-12-21 15:46:44.573 error Caught by controller[0]: at Function.Module._load (module.js:489:3)
    host.HA-Mieter-Server 2019-12-21 15:46:44.573 error Caught by controller[0]: at tryModuleLoad (module.js:497:12)
    host.HA-Mieter-Server 2019-12-21 15:46:44.573 error Caught by controller[0]: at Module.load (module.js:554:32)
    host.HA-Mieter-Server 2019-12-21 15:46:44.572 error Caught by controller[0]: at Object.Module._extensions..node (module.js:664:18)
    host.HA-Mieter-Server 2019-12-21 15:46:44.572 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    host.HA-Mieter-Server 2019-12-21 15:46:44.572 error Caught by controller[0]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
    host.HA-Mieter-Server 2019-12-21 15:46:44.572 error Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.HA-Mieter-Server 2019-12-21 15:46:44.571 error Caught by controller[0]: was compiled against a different Node.js version using
    host.HA-Mieter-Server 2019-12-21 15:46:44.571 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
    host.HA-Mieter-Server 2019-12-21 15:46:44.571 error Caught by controller[0]: ^
    host.HA-Mieter-Server 2019-12-21 15:46:44.570 error Caught by controller[0]: return process.dlopen(module, path._makeLong(filename));
    host.HA-Mieter-Server 2019-12-21 15:46:44.569 error Caught by controller[0]: module.js:664
    Ich denke, das hat was mit der verwendeten NPM Version zu tun - mir ist aber nicht klar, was mir die Log-Ausgabe sagen will:
    Hoffe, mir kann jemand helfen :)
    Georg
    • GoerschG Offline
      GoerschG Offline
      Goersch
      Hab in den "How-To's" gefunden
      Im iobroker Verzeichnis
      iobroker stop
      npm rebuild
      iobroker start
      • L Offline
        LubuBroker
        Hallo Goersch
        Ich habe genau das selbe Problem, seit ich einen neuen Docker Container am laufen habe.
        Danach habe ich noch den JS Controller upgedatet.
        Mein Log sieht genau gleich aus und die SQL Instanz bleibt rot.
        Was genau hast du gemacht?
        Hast du einen Link zu den How-To's
        Vielen Dank
        Lukas
        • L LubuBroker
          Hallo Goersch
          Vielen Dank
          Lukas
          GlasfaserG Offline
          GlasfaserG Offline
          @LubuBroker
          In der Konsole ( zb.Putty ) die Befehle eingeben .
          • L Offline
            LubuBroker
            @Goersch said in SQL Adapter:
            iobroker start
            das sieht bei mir so aus
            root@iobroker_v4:/opt/iobroker# iobroker stop
            iobroker controller daemon is not running
            root@iobroker_v4:/opt/iobroker# npm rebuild
            sudo: Hostname iobroker_v4.0.0 kann nicht aufgelöst werden
            sudo: Die Audit-Nachricht kann nicht gesendet werden: Unbekannter Fehler -1
            sudo: pam_open_session: Systemfehler
            sudo: Regelwerks-Plugin konnte Sitzung nicht initialisieren
            Komme da nicht weiter
            • L LubuBroker
              iobroker start
              GlasfaserG Offline
              GlasfaserG Offline
              @LubuBroker
              Machen mal :
              curl -sL https://iobroker.net/fix.sh | bash -
              • L Offline
                LubuBroker
                Sorry. Die cheffin meinte ich soll die pc kiste mal ausschalten. Aber das probier ich gleich mal morgen aus.
                Gruss und schöhnen abend
                • L Offline
                  LubuBroker
                  iobroker stop
                  Hallo Georg
                  Ich habe diesen Befehl mal ausprobiert.
                  root@iobroker_v4:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
                  ioBroker or some processes are still running:
                   io.admin.0
                   io.discovery.0
                   io.ping.0
                   io.web.0
                   io.nut.0
                   io.javascript.0
                   io.sonos.0
                   io.knx.0
                   io.scenes.0
                   io.sayit.0
                   io.fullcalendar.0
                   io.plexconnect.0
                   io.info.0
                  Please stop them first and try again!
                  Wie kann ich die Prozesse stoppen?
                  Bin mit der Konsole nicht so vertraut.
                  Vielen Dank
                  • L LubuBroker
                    iobroker stop
                    Hallo Georg
                     io.admin.0
                     io.discovery.0
                     io.ping.0
                     io.web.0
                     io.nut.0
                     io.javascript.0
                     io.sonos.0
                     io.knx.0
                     io.scenes.0
                     io.sayit.0
                     io.fullcalendar.0
                     io.plexconnect.0
                     io.info.0
                    Vielen Dank
                    FredFF Online
                    FredFF Online
                    FredF
                    Most Active Forum Testing
                    @LubuBroker Du must im gleichen Ordner zuerst
                    iobroker stop
                    ausführen. Nach dem curl.... Befehl dann wieder
                    iobroker start
                    • L Offline
                      LubuBroker
                      @FredF said in SQL Adapter:
                      iobroker start
                      Also
                      Ich hab jetzt folgendes gemacht.
                       io.admin.0
                       io.discovery.0
                       io.ping.0
                       io.web.0
                       io.nut.0
                       io.javascript.0
                       io.sonos.0
                       io.knx.0
                       io.scenes.0
                       io.sayit.0
                       io.fullcalendar.0
                       io.plexconnect.0
                       io.info.0
                      root@iobroker_v4:/opt/iobroker# iobroker start
                      Starting iobroker controller daemon...
                      iobroker controller daemon started. PID: 2971
                      Nach Eingabe des curl Befehls steht da aber immer noch, das Prozesse am laufen sind.
                      Wie erwartet funktioniert der SQL Adapter immer noch nicht.
                      FredFF 2 Antworten Letzte Antwort
                      • L LubuBroker
                        iobroker start
                        Also
                         io.admin.0
                         io.discovery.0
                         io.ping.0
                         io.web.0
                         io.nut.0
                         io.javascript.0
                         io.sonos.0
                         io.knx.0
                         io.scenes.0
                         io.sayit.0
                         io.fullcalendar.0
                         io.plexconnect.0
                         io.info.0
                        FredFF Online
                        FredFF Online
                        FredF
                        @LubuBroker
                        Hmm.. ich hatte nur die letzten Antworten gelesen und sehe weiter oben das du ioBroker im Docker betreibst, sorry da kann ich dir nicht weiter helfen.
                        Dachte auch das das im Docker genau so funktioniert...
                        • L LubuBroker
                          iobroker start
                          Also
                           io.admin.0
                           io.discovery.0
                           io.ping.0
                           io.web.0
                           io.nut.0
                           io.javascript.0
                           io.sonos.0
                           io.knx.0
                           io.scenes.0
                           io.sayit.0
                           io.fullcalendar.0
                           io.plexconnect.0
                           io.info.0
                          FredFF Online
                          FredFF Online
                          FredF
                          @LubuBroker
                          Evtl. hilft dir das weiter
