<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SQL Adapter]]></title><description><![CDATA[<p dir="auto">Hallo,</p>
<p dir="auto">hab ein Problem mit dem SQL-Adapter (raspberry) - er startet nicht mehr.<br />
iobroker js-controller 2.1.1<br />
npm 6.4.1<br />
node 10.10.0</p>
<p dir="auto">Log:<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.575	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.575	error	Caught by controller[0]: at Module.load (module.js:554:32)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.575	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:646:10)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.574	error	Caught by controller[0]: at Module._compile (module.js:635:30)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.574	error	Caught by controller[0]: at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:75)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.574	error	Caught by controller[0]: at require (internal/module.js:11:18)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.574	error	Caught by controller[0]: at Module.require (module.js:579:17)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.573	error	Caught by controller[0]: at Function.Module._load (module.js:489:3)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.573	error	Caught by controller[0]: at tryModuleLoad (module.js:497:12)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.573	error	Caught by controller[0]: at Module.load (module.js:554:32)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.572	error	Caught by controller[0]: at Object.Module._extensions..node (module.js:664:18)<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.572	error	Caught by controller[0]: the module (for instance, using <code>npm rebuild</code> or <code>npm install</code>).<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.572	error	Caught by controller[0]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.572	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.571	error	Caught by controller[0]: was compiled against a different Node.js version using<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.571	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.571	error	Caught by controller[0]: ^<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.570	error	Caught by controller[0]: return process.dlopen(module, path._makeLong(filename));<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.569	error	Caught by controller[0]: module.js:664</p>
<p dir="auto">Ich denke, das hat was mit der verwendeten NPM Version zu tun - mir ist aber nicht klar, was mir die Log-Ausgabe sagen will:<br />
host.HA-Mieter-Server	2019-12-21 15:46:44.572	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires</p>
<p dir="auto">Hoffe, mir kann jemand helfen :)</p>
<p dir="auto">Danke<br />
Georg</p>
]]></description><link>https://forum.iobroker.net/topic/27927/sql-adapter</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 16:32:13 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/27927.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 21 Dec 2019 14:59:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SQL Adapter on Sat, 04 Jan 2020 11:24:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lububroker" aria-label="Profile: LubuBroker">@<bdi>LubuBroker</bdi></a><br />
Evtl. hilft dir <a href="https://forum.iobroker.net/topic/26759/js-controller-2-jetzt-f%C3%BCr-alle-im-stable/192">das</a> weiter</p>
]]></description><link>https://forum.iobroker.net/post/351295</link><guid isPermaLink="true">https://forum.iobroker.net/post/351295</guid><dc:creator><![CDATA[FredF]]></dc:creator><pubDate>Sat, 04 Jan 2020 11:24:22 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Sat, 04 Jan 2020 11:22:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lububroker" aria-label="Profile: LubuBroker">@<bdi>LubuBroker</bdi></a><br />
Hmm.. ich hatte nur die letzten Antworten gelesen und sehe weiter oben das du ioBroker im Docker betreibst, sorry da kann ich dir nicht weiter helfen.<br />
Dachte auch das das im Docker genau so funktioniert...</p>
]]></description><link>https://forum.iobroker.net/post/351291</link><guid isPermaLink="true">https://forum.iobroker.net/post/351291</guid><dc:creator><![CDATA[FredF]]></dc:creator><pubDate>Sat, 04 Jan 2020 11:22:06 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Sat, 04 Jan 2020 11:07:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fredf" aria-label="Profile: FredF">@<bdi>FredF</bdi></a> said in <a href="/post/351255">SQL Adapter</a>:</p>
<blockquote>
<p dir="auto">iobroker start</p>
</blockquote>
<p dir="auto">Also<br />
Ich hab jetzt folgendes gemacht.</p>
<pre><code>root@iobroker_v4:/opt/iobroker# iobroker stop
iobroker controller daemon is not running
root@iobroker_v4:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
ioBroker or some processes are still running:
 io.admin.0
 io.discovery.0
 io.ping.0
 io.web.0
 io.nut.0
 io.javascript.0
 io.sonos.0
 io.knx.0
 io.scenes.0
 io.sayit.0
 io.fullcalendar.0
 io.plexconnect.0
 io.info.0
Please stop them first and try again!
root@iobroker_v4:/opt/iobroker# iobroker start
Starting iobroker controller daemon...
iobroker controller daemon started. PID: 2971
</code></pre>
<p dir="auto">Nach Eingabe des curl Befehls steht da aber immer noch, das Prozesse am laufen sind.<br />
Wie erwartet funktioniert der SQL Adapter immer noch nicht.</p>
]]></description><link>https://forum.iobroker.net/post/351280</link><guid isPermaLink="true">https://forum.iobroker.net/post/351280</guid><dc:creator><![CDATA[LubuBroker]]></dc:creator><pubDate>Sat, 04 Jan 2020 11:07:25 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Sat, 04 Jan 2020 10:45:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lububroker" aria-label="Profile: LubuBroker">@<bdi>LubuBroker</bdi></a> Du must im gleichen Ordner zuerst</p>
<pre><code>iobroker stop
</code></pre>
<p dir="auto">ausführen. Nach dem curl.... Befehl dann wieder</p>
<pre><code>iobroker start
</code></pre>
]]></description><link>https://forum.iobroker.net/post/351255</link><guid isPermaLink="true">https://forum.iobroker.net/post/351255</guid><dc:creator><![CDATA[FredF]]></dc:creator><pubDate>Sat, 04 Jan 2020 10:45:24 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Sat, 04 Jan 2020 08:00:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/goersch" aria-label="Profile: Goersch">@<bdi>Goersch</bdi></a> said in <a href="/post/343258">SQL Adapter</a>:</p>
<blockquote>
<p dir="auto">iobroker stop</p>
</blockquote>
<p dir="auto">Hallo Georg</p>
<p dir="auto">Ich habe diesen Befehl mal ausprobiert.</p>
<pre><code>root@iobroker_v4:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
 io.admin.0
 io.discovery.0
 io.ping.0
 io.web.0
 io.nut.0
 io.javascript.0
 io.sonos.0
 io.knx.0
 io.scenes.0
 io.sayit.0
 io.fullcalendar.0
 io.plexconnect.0
 io.info.0
</code></pre>
<p dir="auto">Wie kann ich die Prozesse stoppen?<br />
Bin mit der Konsole nicht so vertraut.</p>
<p dir="auto">Vielen Dank</p>
]]></description><link>https://forum.iobroker.net/post/351179</link><guid isPermaLink="true">https://forum.iobroker.net/post/351179</guid><dc:creator><![CDATA[LubuBroker]]></dc:creator><pubDate>Sat, 04 Jan 2020 08:00:09 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Fri, 03 Jan 2020 19:29:39 GMT]]></title><description><![CDATA[<p dir="auto">Sorry. Die cheffin meinte ich soll die pc kiste mal ausschalten. Aber das probier ich gleich mal morgen aus.<br />
Gruss und schöhnen abend</p>
]]></description><link>https://forum.iobroker.net/post/350988</link><guid isPermaLink="true">https://forum.iobroker.net/post/350988</guid><dc:creator><![CDATA[LubuBroker]]></dc:creator><pubDate>Fri, 03 Jan 2020 19:29:39 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Fri, 03 Jan 2020 19:23:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lububroker" aria-label="Profile: LubuBroker">@<bdi>LubuBroker</bdi></a></p>
<p dir="auto">Machen mal :</p>
<pre><code>curl -sL https://iobroker.net/fix.sh | bash -
</code></pre>
]]></description><link>https://forum.iobroker.net/post/350981</link><guid isPermaLink="true">https://forum.iobroker.net/post/350981</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Fri, 03 Jan 2020 19:23:07 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Fri, 03 Jan 2020 19:17:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/goersch" aria-label="Profile: Goersch">@<bdi>Goersch</bdi></a> said in <a href="/post/343258">SQL Adapter</a>:</p>
<blockquote>
</blockquote>
<p dir="auto">das sieht bei mir so aus</p>
root@iobroker_v4:/opt/iobroker# npm rebuild
sudo: Hostname iobroker_v4.0.0 kann nicht aufgelöst werden
sudo: Die Audit-Nachricht kann nicht gesendet werden: Unbekannter Fehler -1
sudo: pam_open_session: Systemfehler
sudo: Regelwerks-Plugin konnte Sitzung nicht initialisieren
</code></pre>
<p dir="auto">Komme da nicht weiter</p>
]]></description><link>https://forum.iobroker.net/post/350979</link><guid isPermaLink="true">https://forum.iobroker.net/post/350979</guid><dc:creator><![CDATA[LubuBroker]]></dc:creator><pubDate>Fri, 03 Jan 2020 19:17:34 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Fri, 03 Jan 2020 18:35:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lububroker" aria-label="Profile: LubuBroker">@<bdi>LubuBroker</bdi></a></p>
<p dir="auto">In der Konsole ( zb.Putty ) die Befehle eingeben .</p>
]]></description><link>https://forum.iobroker.net/post/350959</link><guid isPermaLink="true">https://forum.iobroker.net/post/350959</guid><dc:creator><![CDATA[Glasfaser]]></dc:creator><pubDate>Fri, 03 Jan 2020 18:35:04 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Fri, 03 Jan 2020 18:27:53 GMT]]></title><description><![CDATA[<p dir="auto">Hallo Goersch</p>
<p dir="auto">Ich habe genau das selbe Problem, seit ich einen neuen Docker Container am laufen habe.<br />
Danach habe ich noch den JS Controller upgedatet.<br />
Mein Log sieht genau gleich aus und die SQL Instanz bleibt rot.<br />
Was genau hast du gemacht?<br />
Hast du einen Link zu den How-To's</p>
<p dir="auto">Vielen Dank<br />
Lukas</p>
]]></description><link>https://forum.iobroker.net/post/350951</link><guid isPermaLink="true">https://forum.iobroker.net/post/350951</guid><dc:creator><![CDATA[LubuBroker]]></dc:creator><pubDate>Fri, 03 Jan 2020 18:27:53 GMT</pubDate></item><item><title><![CDATA[Reply to SQL Adapter on Sat, 21 Dec 2019 15:33:55 GMT]]></title><description><![CDATA[<p dir="auto">Hab in den "How-To's" gefunden</p>
<p dir="auto">Im iobroker Verzeichnis</p>
<blockquote>
<p dir="auto">iobroker stop<br />
npm rebuild<br />
iobroker start</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/343258</link><guid isPermaLink="true">https://forum.iobroker.net/post/343258</guid><dc:creator><![CDATA[Goersch]]></dc:creator><pubDate>Sat, 21 Dec 2019 15:33:55 GMT</pubDate></item></channel></rss>
