  4. Test Adapter lovelace v0.2.x
    6.5k
testcall for actionlovelacevisualisierung
1.1k Beiträge 131 Kommentatoren 455.2k Aufrufe 99 Beobachtet
    AhleWurscht75
    #450
    Hallo liebe Community,
    bekomme seit kurzem folgende Fehlermeldung durch den Adapter. Kann mir jemand helfen?
    Danke...
    2019-12-30 14:27:27.387 - info: host.ioBroker instance system.adapter.lovelace.0 terminated with code 0 (NO_ERROR)
    2019-12-30 14:27:27.387 - info: host.ioBroker Restart adapter system.adapter.lovelace.0 because enabled
    2019-12-30 14:27:57.408 - info: host.ioBroker instance system.adapter.lovelace.0 started with pid 21446
    2019-12-30 14:28:03.281 - info: lovelace.0 (21446) starting. Version 1.0.7 in /opt/iobroker/node_modules/iobroker.lovelace, node: v8.12.0
    2019-12-30 14:28:03.361 - info: lovelace.0 (21446) http server listening on port 8099
    2019-12-30 14:28:04.588 - error: lovelace.0 (21446) uncaught exception: Cannot read property 'val' of null
    2019-12-30 14:28:04.589 - error: lovelace.0 (21446) TypeError: Cannot read property 'val' of null
    at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1638:88)
    at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:483:33)
    at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    at
    at process._tickCallback (internal/process/next_tick.js:189:7)
    2019-12-30 14:28:04.591 - info: lovelace.0 (21446) cleaned everything up...
    2019-12-30 14:28:04.602 - error: lovelace.0 (21446) uncaught exception: Cannot read property 'val' of null
    2019-12-30 14:28:04.603 - error: lovelace.0 (21446) TypeError: Cannot read property 'val' of null
    at
    2019-12-30 14:28:04.657 - info: lovelace.0 (21446) terminating
    2019-12-30 14:28:04.659 - info: lovelace.0 (21446) Terminated (NO_ERROR): Without reason
    2019-12-30 14:28:06.218 - error: host.ioBroker Caught by controller[0]: TypeError: Cannot read property 'val' of null
    2019-12-30 14:28:06.219 - error: host.ioBroker Caught by controller[0]: at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1638:88)
    2019-12-30 14:28:06.219 - error: host.ioBroker Caught by controller[0]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:483:33)
    2019-12-30 14:28:06.219 - error: host.ioBroker Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2019-12-30 14:28:06.219 - error: host.ioBroker Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2019-12-30 14:28:06.220 - error: host.ioBroker Caught by controller[0]: at
    2019-12-30 14:28:06.220 - error: host.ioBroker Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:189:7)
    2019-12-30 14:28:06.220 - error: host.ioBroker Caught by controller[1]: TypeError: Cannot read property 'val' of null
    2019-12-30 14:28:06.221 - error: host.ioBroker Caught by controller[1]: at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1638:88)
    2019-12-30 14:28:06.221 - error: host.ioBroker Caught by controller[1]: at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:483:33)
    2019-12-30 14:28:06.221 - error: host.ioBroker Caught by controller[1]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    2019-12-30 14:28:06.221 - error: host.ioBroker Caught by controller[1]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    2019-12-30 14:28:06.222 - error: host.ioBroker Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:189:7)
    2019-12-30 14:28:06.222 - info: host.ioBroker instance system.adapter.lovelace.0 terminated with code 0 (NO_ERROR)
    2019-12-30 14:28:06.222 - info: host.ioBroker Restart adapter system.adapter.lovelace.0 because enabled
    • GarfonsoG Garfonso
      @ecki945
      Ja, es geht bei dem, was ich gemacht hatte alles um diese Karte. ;-)
      Also, wenn die Zuordnung Schalt + RM geht, dann braucht diese Karte die Schalt GA und Dimmwert GA. (Nach der Zuordnung sind für ioBroker die RM GAs nicht mehr relevant). Das Problem oder die Besonderheit ist, dass der lovelace Adapter die "selber" erkennen muss. Das geht über Raum + Funktion und eine Struktur der Objekten in Ordnern. Es wird im Grunde so etwas erwartet:
      Mein KNX Projekt sah da deutlich anders aus... daher habe ich mir die Devices so mit der Alias Funktion zusammen gebaut. Da kann man die Ordner anlegen und die States mit denen im KNX verknüpfen. Dazu müsste es im Forum schon etwas geben. Das geht, soweit ich weiß, bisher nur über Änderungen im RAW-Teil des Alias Objektes, da muss im Common-Part folgendes dazu:
      alias: {
      Bei Id müsstest du dann einmal für den "state" die Schalt GA eintragen und für Brightness die Dimm GA. Und die anderen Sachen müssen auch wie im Bild gesetzt sein, also Rolle und type für schalten auf boolean und für dimmen auf number. Dann kann er die Lampe erkennen und dann geht es auch mit Schalten + Dimmen über die Karte.
      @marcuskl said in Test Adapter lovelace v0.2.x:
      Beim Shelly funktioniert garnichts, also net mal das einschalten.
      Hm.. die Controls sehen aber doch ok aus.. grübel. Noch ein paar Fragen:
      1. Wenn du im ioBroker schaltest bzw. dimmst oder Farbe änderst -> kommt das in lovelace an?
      2. Wenn du in Lovelace was machst, gibt es dann einen Fehler im Log? Oder überhaupt eine Meldung? Beim Anschalten müsste eigentlich sowas auftauchen:
      2019-12-30 13:13:03.854  - debug: lovelace.1 (17812) No additional data in service call -> only turn on.
      2019-12-30 13:12:55.988  - debug: lovelace.1 (17812) turn_off alias.0.lamps.Josephine_Decke.state
      Ich glaube ich guck mal, ob ich nicht auch ein manuelles konfigurieren der attribute einbauen kann... das scheint mir irgendwie weniger Ärger zu machen. grübel
      marcusklM Offline
      marcusklM Offline
      marcuskl
      #451
      @Garfonso sagte in Test Adapter lovelace v0.2.x:
      Ja kommt alles an, Helligkeit, Farbe etc.
      1. Wenn du in Lovelace was machst, gibt es dann einen Fehler im Log? Oder überhaupt eine Meldung? Beim Anschalten müsste eigentlich sowas auftauchen:
      Es kommt dieser Fehler wenn ich Einschalte:
      shelly.0	2019-12-30 14:39:46.683	error	(1253) Datatype for SHRGBW2#5A38A7#1.color.white differs from expected, ignore state change! Please write correct datatype (number)
      Das hier habe ich alle paar Minuten im Log:
      lovelace.0	2019-12-30 14:31:50.049	warn	(1328) Duplicates found for light.Switch
      lovelace.0	2019-12-30 14:31:50.048	warn	(1328) Duplicates found for light.LED_Strips_Wohnzimmer
      lovelace.0	2019-12-30 14:31:50.047	warn	(1328) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type rgbSingle -> no on/off control found.
      Host: Intel Nuc6cayh (16GB Ram, 240GB SSD) mit Proxmox.
      Iobroker VM, InfluxDB LXC, Pihole LXC, Tasmoadmin LXC, Easy2connect VM
      • marcusklM Offline
        marcusklM Offline
        marcuskl
        #452
        @Garfonso Was mir auch aufgefallen ist, es wird beim Shelly der weiß Dimmwert, wie es aussieht als Schalter erkannt (setzt diesen auf true/false, obwohl es ein Wert 0-100 ist) und der level.color.red als Brightness erkannt:
        GarfonsoG 1 Antwort Letzte Antwort
        • marcusklM marcuskl
          GarfonsoG Offline
          GarfonsoG Offline
          Garfonso
          #453
          @marcuskl
          ok, jetzt hab ich endlich verstanden, was das Problem ist... hatte das schonmal aber irgendwie ist der Fix etwas rausgeflogen...
          Also, was passiert ist, dass der shelly zweimal erkannt wird, einmal mit richtigem an/aus, Farben und "gain" als Dimmer. Damit sind die States "verbraucht" für die Autoerkennung. Aber "white" ist noch übrig und wird nochmal als Dimmer erkannt, allerdings ohne an/aus und Farbe und da die ID dieselbe ist, wird das Gerät an einer Stelle überschrieben... das ist relativ anfällig für solche Fehler und das würde ich gerne reparieren, würde das aber gerne mit dem ursprünglichen Autor besprechen, da ich aktuell da noch nicht genug verstanden habe.
          Egal, wenn du jetzt nochmal von dem tratschtante-Link installierst, dann sollte das so nicht mehr auftreten und das zweite Gerät ohne an/aus Schalter korrekt ignoriert werden. Wenn es dann der "falsche" Dimmer ist (also du lieber white zum dimmen hättest), dann müsstest du bei gain mal die Rolle ändern oder sowas... zwei Dimmer sind in lovelace nicht vorgesehen... wäre es sinnvoll beide zu setzen mit den %? Oder ist das schon richtig so? Vermutlich ist das aber ein Sonderfall, den der adapter automatisch nicht abdecken sollte..
          Ultimativer Lovelace Leitfaden: https://forum.iobroker.net/topic/35937/der-ultimative-iobroker-lovelace-leitfaden-dokumentation
          Lovelace UI Beispiele: https://forum.iobroker.net/topic/35950/zeigt-her-eure-lovelace-visualisierung
          marcusklM 1 Antwort Letzte Antwort
          • MoeM Moe
            Schönen guten Tag,
            Ich bekomme meine Tado Thermostate nicht angezeigt in der Thermostat Card.
            Die Karte bekommt keine Werte und wird leer angezeigt.
            Jemand eine Idee wodran es liegen kann ?
            Als Entity nutze die Steuerbare Temperatur des Tado Thermostates ( zur Auswahl stehen gemessene Temperatur, Einstellbare Temperatur, Luftfeuchtigkeit )
            Wenn ich mir helfen könntest würde ich mich freuen
            GarfonsoG Offline
            GarfonsoG Offline
            Garfonso
            #454
            @Moe
            Hast du bei dem State manuell Einstellungen vor Lovelace vorgenommen? Dann wird das nicht besser gehen. Die Idee des Adapters ist aktuell, dass du für das ganze Gerät (also im Grunde den "Ordner" in dem die dazugehörigen States liegen) einen Raum und eine Funktion vergibst und der sich dann automatisch zusammenbastelt, wie das passen muss.
            Dazu müssen die States allerdings "richtig" konfiguriert sein, besonders die "role" und der "type". Danach werden die erkannt: https://github.com/ioBroker/ioBroker.type-detector/blob/master/index.js#L299
            Der lovelace adapter unterstützt dann an/aus, aktuelle Temperatur, Luftfeuchtigkeit und Zieltemperatur als Werte/Attribute.
            @AhleWurscht75 said in Test Adapter lovelace v0.2.x:
            Du hast anscheinend einen manuell angelegten entity vom Typ "input_boolean" der keinen state bzw. "null" als state zurück liefert. Da crasht der Adapter. Das müsste man bei den manuellen entities überall noch abfangen, wie es aussieht..
            Aber vielleicht hilft dir das ja schon bei der Fehlersuche.
            A marcusklM 2 Antworten Letzte Antwort
              @Moe
              AhleWurscht75
              #455
              @Garfonso ja, perfekt - Danke, das isse's 👍
                @marcuskl
                marcusklM Offline
                marcusklM Offline
                marcuskl
                #456
                @Garfonso
                @marcuskl
                In Ordnung, habe ich verstanden
                Ich habe von deinem Link nochmal installiert und es ist immer noch das Problem vorhanden.
                Und es kommt jetzt noch dieser Error im Log:
                lovelace.0	2019-12-30 18:01:30.710	error	at funcs.forEach.funcId (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2767:41)
                lovelace.0	2019-12-30 18:01:30.710	error	at Array.forEach (<anonymous>)
                lovelace.0	2019-12-30 18:01:30.710	error	at func.common.members.forEach.id (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2768:31)
                lovelace.0	2019-12-30 18:01:30.710	error	at rooms.forEach.roomId (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2788:38)
                lovelace.0	2019-12-30 18:01:30.710	error	at WebServer._processIobState (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2671:26)
                lovelace.0	2019-12-30 18:01:30.710	error	at controls.forEach.control (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:2673:70)
                lovelace.0	2019-12-30 18:01:30.710	error	at WebServer._processLightAdvanced (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1867:28)
                lovelace.0	2019-12-30 18:01:30.710	error	at WebServer._getLightStateControl (/opt/iobroker/node_modules/iobroker.lovelace/lib/server.js:1657:19)
                lovelace.0	2019-12-30 18:01:30.710	error	(2964) [Type-Detector] Cannot process "shelly.0.SHRGBW2#5A38A7#1.color": TypeError: Cannot read property 'type' of undefined stack: TypeError: Cannot read property 'type' of undefined
                  @Moe
                  marcusklM Offline
                  marcusklM Offline
                  marcuskl
                  schrieb am zuletzt editiert von marcuskl
                  #457
                  @Garfonso Jetzt geht meine ganze Lovelace Ui nicht mehr, kommt ein Error (Cannot get /)
                  Sind plötzlich alle Entitäten weg
                    GarfonsoG Offline
                    GarfonsoG Offline
                    Garfonso
                    #458
                    @marcuskl
                    Ja, sorry, dummer Fehler... crasht leider beim Start... :-(
                    Nochmal neu installieren bitte.
                      AhleWurscht75
                      #459
                      Hallo liebe Leute,
                      ich habe mal zwei, wahrscheinlich doofe, Fragen, bzw. Fragen die für euch einfach zu beantworten sind.
                      Wo lege ich den Pictur im .png format ab um sie in den cards anzeigen zu lassen und wie kann ich mir einen gefilterten state (z.B. "true") in einer card mit einem anderen Text anzeigen lassen.
                      Thx for help und guten Rutsch euch allen!
                      • leszy lL Offline
                        leszy lL Offline
                        leszy l
                        #460
                        Hi als erstes muss ich sagen super das iobroker Lovelace unterstützt. ich habe gerade alle komplett neu auf und habe zu iobroker tendiert allerdings HA hatte den Vorteil Lovelace. Das vis ist zwar mächtiger fand es sehr kompliziert.
                        Bis habe ich schon geschafft und mich hier durch das ganz auch durchgelesen allerdings scheitert ich an einer Rolläden Steuerung mit Shelly. Ich kriege zwar mit input_number ohne Problem ein Slider hin wurde allerdings gerne noch ein toggel haben um eben direkt hoch zu machen die Rolläden. Am schönsten wäre so eine Card
                        Die kriege ich allerdings nicht hin. Gibt zwar eine spanische Anleitung für HA die kriege ich aber irgendwie nicht auf iobroker umgesetzt https://hassiohelp.eu/2019/05/24/shelly25/
                        Jemand eine Idee wie man es am besten hinkriegt?
                          @marcuskl
                          marcusklM Offline
                          marcusklM Offline
                          marcuskl
                          #461
                          @Garfonso Kein Problem, hatte zum glück ein Snapshot gemacht :)
                          Habe es neu installiert, aber es klappt immer noch nicht mit dem Shelly, der Gain weiß wird immernoch als Switch erkannt :/
                          • P Offline
                            Ph4t0n
                            #462
                            Moin zusammen!
                            erstmal vielen Dank für die tolle Arbeit!
                            Ich habe gerade ein Problem beim einrichten meiner Sonos Boxen bzw. wollte diese in Lovelace über mini-media-player anzeigen lassen.
                            Das Problem ist, dass mein Lovelace Adapter die Sonos nicht über autodetect gefunden hat.
                            Ich weiß jetzt nicht welche ID aus dem Sonos-Adapter ich als "media_player" definieren muss, sodass ich diese Entity mit dem mini-media-player verwenden kann.
                            Kann mir hier jemand helfen?
                            Viele Grüße
                            • P Ph4t0n
                              Moin zusammen!
                              Viele Grüße
                              GarfonsoG Offline
                              GarfonsoG Offline
                              Garfonso
                              #463
                              @Ph4t0n said in Test Adapter lovelace v0.2.x:
                              Moin zusammen!
                              Viele Grüße
                              Manuell wird das nicht gehen, soweit ich das im Code sehe... da wirst du vermutlich die Objekte entsprechend bearbeiten müssen (am besten dann als Aliase) um die Autoerkennung zu triggern. Raum & Funktion hast du aber vergeben?
                              Wie die Types & Roles aussehen sollten, steht hier: https://github.com/ioBroker/ioBroker.type-detector/blob/master/index.js#L102
                              Aber er crasht nicht mehr? grübel Und es gibt nur das eine Entity?
                              Versuch nochmal neu zu installieren, indem du als URL das hier eingibst (ohne http oder so davor):
                              Garfonso/iobroker.lovelace#rgb
                              Damit müsste die neueste Version auch direkt von Github gehen (ging bei mir, aber guck mal ob da bei der Installation Fehler kommen).
                              marcusklM P 2 Antworten Letzte Antwort
                                Moin zusammen!
                                Viele Grüße
                                marcusklM Offline
                                marcusklM Offline
                                marcuskl
                                #464
                                @Garfonso hatte es gestern nochmal installiert, von deinem tratschtante link und jetzt funktioniert es mit dem Shelly 👍 👍
                                Super Arbeit!
                                Aber es kommt komischerweise immer noch dieser Warn im Log:
                                lovelace.0	2020-01-05 10:23:12.857	warn	(32294) Duplicates found for light.Switch
                                lovelace.0	2020-01-05 10:23:12.853	warn	(32294) Duplicates found for light.Switch
                                lovelace.0	2020-01-05 10:23:12.839	warn	(32294) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type dimmer -> no on/off control found.
                                lovelace.0	2020-01-05 10:23:12.838	warn	(32294) Could not add shelly.0.SHRGBW2#5A38A7#1.color of type rgbSingle -> no on/off control found.
                                Nein, crashen tut er nicht mehr.
                                Ja, über diesen Dateipfad lässt es sich installieren. 👍
                                  Super Arbeit!
                                  GarfonsoG Offline
                                  GarfonsoG Offline
                                  Garfonso
                                  schrieb am zuletzt editiert von Garfonso
                                  #465
                                  @marcuskl
                                  Super. :-)
                                  Dann kann ich in meinen PR ja reinschreiben, dass es zwei erfolgreiche Tester gab.
                                  Ja, die Warnung kommt immer bei der Erkennung. Vielleicht nehme ich die raus oder mach die nur debug.
                                  Edit: Ok, hab's jetzt rausgenommen und das git etwas aufgeräumt (dabei allerdings auch ein paar Branches gelöscht). Neuer Installationurl ist:
                                  https://github.com/Garfonso/ioBroker.lovelace
                                    @marcuskl
                                    Super. :-)
                                    marcusklM Offline
                                    marcusklM Offline
                                    marcuskl
                                    #466
                                    @Garfonso Gibt es die Möglichkeit den weißen Gain auch über Lovelace zu steuern ?
                                      Moin zusammen!
                                      Viele Grüße
                                      Ph4t0n
                                      #467
                                      @Garfonso
                                      Einen Raum hatte die Sonos zugewiesen aber bei der Function konnte ich nichts wirklich sinnvolles eintragen (da stand mir nur battery, color, heating und security zu Verfügung)
                                      • P Ph4t0n
                                        @Garfonso
                                        GarfonsoG Offline
                                        GarfonsoG Offline
                                        Garfonso
                                        #468
                                        @Ph4t0n
                                        Dann erstell einfach zusätzliche Funktionen. Im Admin auf "Aufzählungen" gehen.
                                        Die Frage ist, was da passieren soll, bzw. wie... wenn du es einzeln steuern willst, kannst du den natürlich manuell als input_number hinzufügen. Oder soll mit dimmen beides gesetzt werden? Ich hab so etwas bei keiner meiner Lampen und weiß nicht, welches Verhalten sinnvoll ist und was da ggf. Seiteneffekte sein könnten.
                                          @Ph4t0n
                                          marcusklM Offline
                                          marcusklM Offline
                                          marcuskl
                                          #469
                                          @Garfonso es wäre nicht schlecht, wenn es noch ein extra Slider gäbe, wie bei der Helligkeit, wo man den white.gain von 0 bis 100 Dimmen kann.
                                          So sieht es auf der Shelly Oberfläche aus:
                                          Der obere Dimmer ist für die Color LED's und der untere ist für die White LED's.
                                          So ähnlich könnte man es ja auch in Lovelace Lösen.
