  4. Test Adapter HeatingControl v3.xx
heating
3.3k Beiträge 239 Kommentatoren 2.5m Aufrufe 201 Beobachtet
  • P Offline
    piscator83
    schrieb am zuletzt editiert von piscator83
    #703
    undefined2019-12-30 22:14:29.828 - info: host.RasPi "system.adapter.heatingcontrol.0" enabled
    2019-12-30 22:14:29.855 - info: host.RasPi instance system.adapter.heatingcontrol.0 started with pid 26464
    2019-12-30 22:14:32.420 - info: heatingcontrol.0 (26464) starting. Version 0.3.13 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v8.16.1
    2019-12-30 22:14:33.184 - info: heatingcontrol.0 (26464) initial check for heating period based on settings between 01.10. and 31.03.
    2019-12-30 22:14:33.185 - info: heatingcontrol.0 (26464) heating period is true
    2019-12-30 22:14:33.317 - info: heatingcontrol.0 (26464) check for heating period based on settings between 01.10. and 31.03.
    2019-12-30 22:14:33.732 - info: heatingcontrol.0 (26464) checking all actors
    2019-12-30 22:14:33.741 - info: heatingcontrol.0 (26464) 0 actors are on of 1
    2019-12-30 22:14:33.752 - info: heatingcontrol.0 (26464) checking all external states
    2019-12-30 22:14:33.757 - info: heatingcontrol.0 (26464) setting PublicHolidyToday to false
    2019-12-30 22:14:33.764 - info: heatingcontrol.0 (26464) setting Present to false
    2019-12-30 22:14:33.769 - info: heatingcontrol.0 (26464) setting VacationAbsent to false
    2019-12-30 22:14:33.775 - info: heatingcontrol.0 (26464) setting GuestsPresent to false
    2019-12-30 22:14:33.780 - info: heatingcontrol.0 (26464) setting PartyNow to false
    2019-12-30 22:14:33.785 - info: heatingcontrol.0 (26464) setting HolidayPresent to false
    2019-12-30 22:14:33.788 - info: heatingcontrol.0 (26464) external states checked, done
    2019-12-30 22:14:33.794 - info: heatingcontrol.0 (26464) calculating new target temperatures
    2019-12-30 22:14:33.835 - info: heatingcontrol.0 (26464) setting to reduced/increased temperature in Wohnzimmer to 16
    2019-12-30 22:14:33.836 - info: heatingcontrol.0 (26464) room Wohnzimmer Thermostat zigbee.0.00158d000237dead.temperature target is 16
    2019-12-30 22:14:33.839 - error: heatingcontrol.0 (26464) exception in CheckTemperatureChange [invalid id ""]
    2019-12-30 22:14:33.849 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.PublicHolidyToday
    2019-12-30 22:14:33.851 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.Present
    2019-12-30 22:14:33.853 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.VacationAbsent
    2019-12-30 22:14:33.855 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.HolidayPresent
    2019-12-30 22:14:33.857 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.GuestsPresent
    2019-12-30 22:14:33.859 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.PartyNow
    2019-12-30 22:14:33.861 - info: heatingcontrol.0 (26464) subscribe Schlafzimmer / zigbee.0.00158d000232392b.temperature
    2019-12-30 22:14:33.864 - info: heatingcontrol.0 (26464) subscribe Bad / zigbee.0.00158d0002739ff4.temperature
    2019-12-30 22:14:33.868 - info: heatingcontrol.0 (26464) subscribe Wohnzimmer / zigbee.0.00158d000237dead.temperature
    2019-12-30 22:14:36.821 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive
    2019-12-30 22:14:36.823 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected
    2019-12-30 22:14:36.824 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss
    2019-12-30 22:14:36.825 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal
    2019-12-30 22:14:36.826 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed
    2019-12-30 22:14:36.826 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag
    2019-12-30 22:14:36.827 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime
    2019-12-30 22:14:36.828 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount
    2019-12-30 22:14:36.829 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount
    2019-12-30 22:14:36.830 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu
    2019-12-30 22:14:36.830 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime
    2019-12-30 22:14:37.159 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
    2019-12-30 22:14:37.398 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive
    2019-12-30 22:14:37.399 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected
    2019-12-30 22:14:37.400 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss
    2019-12-30 22:14:37.401 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal
    2019-12-30 22:14:37.402 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed
    2019-12-30 22:14:37.403 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag
    2019-12-30 22:14:37.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime
    2019-12-30 22:14:37.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount
    2019-12-30 22:14:37.406 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount
    2019-12-30 22:14:37.422 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu
    2019-12-30 22:14:37.423 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime
    2019-12-30 22:14:37.424 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
    2019-12-30 22:14:37.657 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive
    2019-12-30 22:14:37.673 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected
    2019-12-30 22:14:37.674 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss
    2019-12-30 22:14:37.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal
    2019-12-30 22:14:37.677 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed
    2019-12-30 22:14:37.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag
    2019-12-30 22:14:37.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime
    2019-12-30 22:14:37.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount
    2019-12-30 22:14:37.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount
    2019-12-30 22:14:37.694 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu
    2019-12-30 22:14:37.695 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime
    2019-12-30 22:14:38.413 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.temperature
    2019-12-30 22:14:38.419 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
    2019-12-30 22:14:38.420 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
    2019-12-30 22:14:38.902 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
    2019-12-30 22:14:38.907 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
    2019-12-30 22:14:39.283 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive
    2019-12-30 22:14:39.300 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected
    2019-12-30 22:14:39.301 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss
    2019-12-30 22:14:39.302 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal
    2019-12-30 22:14:39.303 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed
    2019-12-30 22:14:39.304 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag
    2019-12-30 22:14:39.305 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime
    2019-12-30 22:14:39.321 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount
    2019-12-30 22:14:39.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount
    2019-12-30 22:14:39.325 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu
    2019-12-30 22:14:39.327 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime
    2019-12-30 22:14:39.352 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive
    2019-12-30 22:14:39.354 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected
    2019-12-30 22:14:39.355 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss
    2019-12-30 22:14:39.356 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal
    2019-12-30 22:14:39.359 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed
    2019-12-30 22:14:39.360 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag
    2019-12-30 22:14:39.361 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime
    2019-12-30 22:14:39.362 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount
    2019-12-30 22:14:39.363 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount
    2019-12-30 22:14:39.364 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu
    2019-12-30 22:14:39.365 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime
    2019-12-30 22:14:39.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive
    2019-12-30 22:14:39.412 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss
    2019-12-30 22:14:39.414 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal
    2019-12-30 22:14:39.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed
    2019-12-30 22:14:39.418 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load
    2019-12-30 22:14:39.432 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime
    2019-12-30 22:14:39.433 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem
    2019-12-30 22:14:39.434 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem
    2019-12-30 22:14:39.435 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable
    2019-12-30 22:14:39.436 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount
    2019-12-30 22:14:39.436 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount
    2019-12-30 22:14:39.437 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag
    2019-12-30 22:14:39.438 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses
    2019-12-30 22:14:39.438 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess
    2019-12-30 22:14:39.439 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact
    2019-12-30 22:14:39.450 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu
    2019-12-30 22:14:39.451 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime
    2019-12-30 22:14:39.470 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
    2019-12-30 22:14:39.474 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
    2019-12-30 22:14:39.543 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive
    2019-12-30 22:14:39.544 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected
    2019-12-30 22:14:39.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss
    2019-12-30 22:14:39.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal
    2019-12-30 22:14:39.546 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed
    2019-12-30 22:14:39.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag
    2019-12-30 22:14:39.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime
    2019-12-30 22:14:39.548 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount
    2019-12-30 22:14:39.549 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount
    2019-12-30 22:14:39.559 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu
    2019-12-30 22:14:39.560 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime
    2019-12-30 22:14:39.864 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
    2019-12-30 22:14:40.112 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
    2019-12-30 22:14:40.116 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi
    2019-12-30 22:14:40.292 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
    2019-12-30 22:14:40.297 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
    2019-12-30 22:14:40.298 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
    2019-12-30 22:14:40.448 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
    2019-12-30 22:14:40.451 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi
    2019-12-30 22:14:40.662 - warn: heatingcontrol.0 (26464) device not found zigbee.0.84182600000ead8e.available
    2019-12-30 22:14:40.786 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
    2019-12-30 22:14:40.791 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
    2019-12-30 22:14:40.792 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi
    2019-12-30 22:14:41.008 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
    2019-12-30 22:14:41.074 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
    2019-12-30 22:14:41.079 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
    2019-12-30 22:14:41.080 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi
    2019-12-30 22:14:41.198 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
    2019-12-30 22:14:42.562 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature
    2019-12-30 22:14:42.566 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
    2019-12-30 22:14:42.788 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature
    2019-12-30 22:14:42.792 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
    2019-12-30 22:14:42.793 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi
    2019-12-30 22:14:43.813 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
    2019-12-30 22:14:44.104 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
    2019-12-30 22:14:44.108 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
    2019-12-30 22:14:44.730 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
    2019-12-30 22:14:44.736 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
    2019-12-30 22:14:44.737 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.rssi
    2019-12-30 22:14:45.279 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
    2019-12-30 22:14:45.282 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
    2019-12-30 22:14:45.514 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
    2019-12-30 22:14:45.652 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
    2019-12-30 22:14:45.656 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi
    2019-12-30 22:14:45.922 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
    2019-12-30 22:14:45.960 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive
    2019-12-30 22:14:45.971 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected
    2019-12-30 22:14:45.972 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss
    2019-12-30 22:14:45.973 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal
    2019-12-30 22:14:45.974 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed
    2019-12-30 22:14:45.984 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag
    2019-12-30 22:14:45.985 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime
    2019-12-30 22:14:45.986 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount
    2019-12-30 22:14:45.988 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount
    2019-12-30 22:14:45.989 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu
    2019-12-30 22:14:45.991 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime
    2019-12-30 22:14:46.000 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
    2019-12-30 22:14:46.001 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
    2019-12-30 22:14:46.002 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi
    2019-12-30 22:14:46.209 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
    2019-12-30 22:14:46.277 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
    2019-12-30 22:14:46.281 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
    2019-12-30 22:14:46.282 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi
    2019-12-30 22:14:46.400 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature
    2019-12-30 22:14:46.404 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
    2019-12-30 22:14:46.528 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
    2019-12-30 22:14:46.532 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
    2019-12-30 22:14:46.533 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
    2019-12-30 22:14:46.737 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive
    2019-12-30 22:14:46.747 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected
    2019-12-30 22:14:46.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss
    2019-12-30 22:14:46.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal
    2019-12-30 22:14:46.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed
    2019-12-30 22:14:46.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag
    2019-12-30 22:14:46.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime
    2019-12-30 22:14:46.752 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount
    2019-12-30 22:14:46.753 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount
    2019-12-30 22:14:46.762 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu
    2019-12-30 22:14:46.763 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime
    2019-12-30 22:14:47.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive
    2019-12-30 22:14:47.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.connected
    2019-12-30 22:14:47.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memRss
    2019-12-30 22:14:47.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapTotal
    2019-12-30 22:14:47.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapUsed
    2019-12-30 22:14:47.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.eventLoopLag
    2019-12-30 22:14:47.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.uptime
    2019-12-30 22:14:47.448 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.inputCount
    2019-12-30 22:14:47.450 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.outputCount
    2019-12-30 22:14:47.467 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cpu
    2019-12-30 22:14:47.470 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cputime
    2019-12-30 22:14:47.968 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature
    2019-12-30 22:14:47.972 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
    2019-12-30 22:14:48.182 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature
    2019-12-30 22:14:48.186 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
    2019-12-30 22:14:49.171 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
    2019-12-30 22:14:49.182 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.alive
    2019-12-30 22:14:49.193 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.connected
    2019-12-30 22:14:49.194 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memRss
    2019-12-30 22:14:49.195 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapTotal
    2019-12-30 22:14:49.195 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapUsed
    2019-12-30 22:14:49.196 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.eventLoopLag
    2019-12-30 22:14:49.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.uptime
    2019-12-30 22:14:49.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.inputCount
    2019-12-30 22:14:49.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.outputCount
    2019-12-30 22:14:49.211 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cpu
    2019-12-30 22:14:49.212 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cputime
    2019-12-30 22:14:49.307 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
    2019-12-30 22:14:49.318 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
    2019-12-30 22:14:49.319 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi
    2019-12-30 22:14:49.928 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
    2019-12-30 22:14:49.931 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.rssi
    2019-12-30 22:14:50.299 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.alive
    2019-12-30 22:14:50.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.connected
    2019-12-30 22:14:50.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memRss
    2019-12-30 22:14:50.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapTotal
    2019-12-30 22:14:50.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapUsed
    2019-12-30 22:14:50.312 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.eventLoopLag
    2019-12-30 22:14:50.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.uptime
    2019-12-30 22:14:50.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.inputCount
    2019-12-30 22:14:50.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.outputCount
    2019-12-30 22:14:50.322 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cpu
    2019-12-30 22:14:50.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cputime
    2019-12-30 22:14:50.717 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
    2019-12-30 22:14:50.721 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
    2019-12-30 22:14:50.848 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
    2019-12-30 22:14:50.851 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi
    2019-12-30 22:14:50.915 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature
    2019-12-30 22:14:50.919 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
    2019-12-30 22:14:50.920 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi
    2019-12-30 22:14:51.005 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.WZDeckenleuchte.info.connect
    2019-12-30 22:14:51.006 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.SZDeckenleuchte.info.connect
    2019-12-30 22:14:51.007 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KZDeckenleuchte.info.connect
    2019-12-30 22:14:51.007 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KuechePendelleuchte.info.connect
    2019-12-30 22:14:51.008 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KuechePendelleuchte.control.power
    2019-12-30 22:14:51.130 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
    2019-12-30 22:14:51.198 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
    2019-12-30 22:14:51.434 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive
    2019-12-30 22:14:51.435 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected
    2019-12-30 22:14:51.441 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss
    2019-12-30 22:14:51.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal
    2019-12-30 22:14:51.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed
    2019-12-30 22:14:51.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag
    2019-12-30 22:14:51.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime
    2019-12-30 22:14:51.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount
    2019-12-30 22:14:51.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount
    2019-12-30 22:14:51.477 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu
    2019-12-30 22:14:51.479 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime
    2019-12-30 22:14:51.480 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
    2019-12-30 22:14:51.489 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
    2019-12-30 22:14:51.493 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
    2019-12-30 22:14:51.600 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature
    2019-12-30 22:14:51.616 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
    2019-12-30 22:14:51.617 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi
    2019-12-30 22:14:51.732 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
    2019-12-30 22:14:51.733 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
    2019-12-30 22:14:51.734 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
    2019-12-30 22:14:52.388 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive
    2019-12-30 22:14:52.389 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected
    2019-12-30 22:14:52.390 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss
    2019-12-30 22:14:52.390 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal
    2019-12-30 22:14:52.391 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed
    2019-12-30 22:14:52.402 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag
    2019-12-30 22:14:52.403 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime
    2019-12-30 22:14:52.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount
    2019-12-30 22:14:52.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount
    2019-12-30 22:14:52.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu
    2019-12-30 22:14:52.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime
    2019-12-30 22:14:52.666 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive
    2019-12-30 22:14:52.667 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected
    2019-12-30 22:14:52.667 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss
    2019-12-30 22:14:52.668 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal
    2019-12-30 22:14:52.669 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed
    2019-12-30 22:14:52.669 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag
    2019-12-30 22:14:52.670 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime
    2019-12-30 22:14:52.670 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount
    2019-12-30 22:14:52.671 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount
    2019-12-30 22:14:52.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu
    2019-12-30 22:14:52.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime
    2019-12-30 22:14:53.381 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
    2019-12-30 22:14:53.575 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature
    2019-12-30 22:14:53.578 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
    2019-12-30 22:14:54.286 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive
    2019-12-30 22:14:54.291 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected
    2019-12-30 22:14:54.292 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss
    2019-12-30 22:14:54.296 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal
    2019-12-30 22:14:54.306 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed
    2019-12-30 22:14:54.307 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag
    2019-12-30 22:14:54.308 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime
    2019-12-30 22:14:54.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount
    2019-12-30 22:14:54.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount
    2019-12-30 22:14:54.315 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu
    2019-12-30 22:14:54.318 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime
    2019-12-30 22:14:54.330 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive
    2019-12-30 22:14:54.332 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected
    2019-12-30 22:14:54.333 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss
    2019-12-30 22:14:54.334 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal
    2019-12-30 22:14:54.334 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed
    2019-12-30 22:14:54.335 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag
    2019-12-30 22:14:54.335 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime
    2019-12-30 22:14:54.343 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount
    2019-12-30 22:14:54.344 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount
    2019-12-30 22:14:54.345 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu
    2019-12-30 22:14:54.346 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime
    2019-12-30 22:14:54.397 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive
    2019-12-30 22:14:54.398 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss
    2019-12-30 22:14:54.398 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal
    2019-12-30 22:14:54.399 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed
    2019-12-30 22:14:54.399 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load
    2019-12-30 22:14:54.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime
    2019-12-30 22:14:54.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem
    2019-12-30 22:14:54.401 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem
    2019-12-30 22:14:54.401 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable
    2019-12-30 22:14:54.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount
    2019-12-30 22:14:54.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount
    2019-12-30 22:14:54.403 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag
    2019-12-30 22:14:54.404 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses
    2019-12-30 22:14:54.414 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess
    2019-12-30 22:14:54.415 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact
    2019-12-30 22:14:54.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu
    2019-12-30 22:14:54.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime
    2019-12-30 22:14:54.511 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
    2019-12-30 22:14:54.514 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
    2019-12-30 22:14:54.534 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive
    2019-12-30 22:14:54.543 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected
    2019-12-30 22:14:54.544 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss
    2019-12-30 22:14:54.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal
    2019-12-30 22:14:54.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed
    2019-12-30 22:14:54.555 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag
    2019-12-30 22:14:54.555 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime
    2019-12-30 22:14:54.556 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount
    2019-12-30 22:14:54.557 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount
    2019-12-30 22:14:54.557 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu
    2019-12-30 22:14:54.558 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime
    2019-12-30 22:14:54.588 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
    2019-12-30 22:14:54.591 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
    2019-12-30 22:14:55.124 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
    2019-12-30 22:14:56.052 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
    2019-12-30 22:14:56.185 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
    2019-12-30 22:14:56.188 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi
    2019-12-30 22:14:56.313 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
    2019-12-30 22:14:56.316 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi
    2019-12-30 22:14:56.346 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
    2019-12-30 22:14:56.414 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
    2019-12-30 22:14:56.803 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
    2019-12-30 22:14:56.804 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi
    2019-12-30 22:14:56.938 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
    2019-12-30 22:14:56.942 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
    2019-12-30 22:14:57.143 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
    2019-12-30 22:14:57.208 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
    2019-12-30 22:14:57.212 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
    2019-12-30 22:14:57.213 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi
    2019-12-30 22:14:58.787 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
    2019-12-30 22:14:58.983 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
    2019-12-30 22:14:58.986 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi
    2019-12-30 22:14:59.712 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
    2019-12-30 22:14:59.717 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
    2019-12-30 22:14:59.991 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
    2019-12-30 22:14:59.994 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
    2019-12-30 22:15:00.324 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
    2019-12-30 22:15:00.327 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
    2019-12-30 22:15:00.959 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive
    2019-12-30 22:15:00.966 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected
    2019-12-30 22:15:00.967 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss
    2019-12-30 22:15:00.968 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal
    2019-12-30 22:15:00.977 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed
    2019-12-30 22:15:00.978 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag
    2019-12-30 22:15:00.978 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime
    2019-12-30 22:15:00.979 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount
    2019-12-30 22:15:00.979 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount
    2019-12-30 22:15:00.980 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu
    2019-12-30 22:15:00.980 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime
    2019-12-30 22:15:01.554 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
    2019-12-30 22:15:01.557 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Energy
    2019-12-30 22:15:01.598 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
    2019-12-30 22:15:01.603 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
    2019-12-30 22:15:01.604 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi
    2019-12-30 22:15:01.624 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
    2019-12-30 22:15:01.627 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
    2019-12-30 22:15:01.706 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature
    2019-12-30 22:15:01.709 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
    2019-12-30 22:15:01.738 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive
    2019-12-30 22:15:01.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected
    2019-12-30 22:15:01.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss
    2019-12-30 22:15:01.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal
    2019-12-30 22:15:01.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed
    2019-12-30 22:15:01.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag
    2019-12-30 22:15:01.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime
    2019-12-30 22:15:01.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount
    2019-12-30 22:15:01.752 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount
    2019-12-30 22:15:01.759 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu
    2019-12-30 22:15:01.760 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime
    2019-12-30 22:15:02.142 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
    2019-12-30 22:15:02.145 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
    2019-12-30 22:15:02.277 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
    2019-12-30 22:15:02.350 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
    2019-12-30 22:15:02.354 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Energy
    2019-12-30 22:15:02.413 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
    2019-12-30 22:15:02.416 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi
    2019-12-30 22:15:02.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive
    2019-12-30 22:15:02.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.connected
    2019-12-30 22:15:02.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memRss
    2019-12-30 22:15:02.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapTotal
    2019-12-30 22:15:02.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapUsed
    2019-12-30 22:15:02.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.eventLoopLag
    2019-12-30 22:15:02.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.uptime
    2019-12-30 22:15:02.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.inputCount
    2019-12-30 22:15:02.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.outputCount
    2019-12-30 22:15:02.460 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cpu
    2019-12-30 22:15:02.464 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cputime
    2019-12-30 22:15:03.050 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
    2019-12-30 22:15:04.185 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.alive
    2019-12-30 22:15:04.196 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.connected
    2019-12-30 22:15:04.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memRss
    2019-12-30 22:15:04.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapTotal
    2019-12-30 22:15:04.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapUsed
    2019-12-30 22:15:04.199 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.eventLoopLag
    2019-12-30 22:15:04.199 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.uptime
    2019-12-30 22:15:04.200 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.inputCount
    2019-12-30 22:15:04.200 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.outputCount
    2019-12-30 22:15:04.208 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cpu
    2019-12-30 22:15:04.209 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cputime
    2019-12-30 22:15:04.210 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
    2019-12-30 22:15:04.386 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature
    2019-12-30 22:15:04.390 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
    2019-12-30 22:15:04.391 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi
    2019-12-30 22:15:04.906 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
    2019-12-30 22:15:04.909 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi
    2019-12-30 22:15:05.301 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.alive
    2019-12-30 22:15:05.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.connected
    2019-12-30 22:15:05.312 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memRss
    2019-12-30 22:15:05.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapTotal
    2019-12-30 22:15:05.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapUsed
    2019-12-30 22:15:05.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.eventLoopLag
    2019-12-30 22:15:05.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.uptime
    2019-12-30 22:15:05.315 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.inputCount
    2019-12-30 22:15:05.316 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.outputCount
    2019-12-30 22:15:05.322 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cpu
    2019-12-30 22:15:05.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cputime
    2019-12-30 22:15:05.395 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
    2019-12-30 22:15:05.530 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
    2019-12-30 22:15:06.406 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive
    2019-12-30 22:15:06.414 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected
    2019-12-30 22:15:06.415 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss
    2019-12-30 22:15:06.416 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal
    2019-12-30 22:15:06.417 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed
    2019-12-30 22:15:06.418 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag
    2019-12-30 22:15:06.425 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime
    2019-12-30 22:15:06.426 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount
    2019-12-30 22:15:06.427 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount
    2019-12-30 22:15:06.428 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu
    2019-12-30 22:15:06.428 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime
    2019-12-30 22:15:06.832 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
    2019-12-30 22:15:06.837 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
    2019-12-30 22:15:06.838 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi
    2019-12-30 22:15:07.011 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
    2019-12-30 22:15:07.018 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
    2019-12-30 22:15:07.020 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi
    2019-12-30 22:15:07.122 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature
    2019-12-30 22:15:07.127 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
    2019-12-30 22:15:07.344 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
    2019-12-30 22:15:07.353 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
    2019-12-30 22:15:07.354 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
    2019-12-30 22:15:07.392 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive
    2019-12-30 22:15:07.393 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected
    2019-12-30 22:15:07.394 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss
    2019-12-30 22:15:07.395 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal
    2019-12-30 22:15:07.395 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed
    2019-12-30 22:15:07.396 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag
    2019-12-30 22:15:07.397 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime
    2019-12-30 22:15:07.413 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount
    2019-12-30 22:15:07.415 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount
    2019-12-30 22:15:07.416 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu
    2019-12-30 22:15:07.417 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime
    2019-12-30 22:15:07.476 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
    2019-12-30 22:15:07.549 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
    2019-12-30 22:15:07.611 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
    2019-12-30 22:15:07.661 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive
    2019-12-30 22:15:07.673 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected
    2019-12-30 22:15:07.675 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss
    2019-12-30 22:15:07.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal
    2019-12-30 22:15:07.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed
    2019-12-30 22:15:07.677 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag
    2019-12-30 22:15:07.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime
    2019-12-30 22:15:07.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount
    2019-12-30 22:15:07.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount
    2019-12-30 22:15:07.691 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu
    2019-12-30 22:15:07.692 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime
    2019-12-30 22:15:08.250 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature
    2019-12-30 22:15:08.256 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
    2019-12-30 22:15:08.258 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi
    2019-12-30 22:15:09.292 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive
    2019-12-30 22:15:09.305 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected
    2019-12-30 22:15:09.307 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss
    2019-12-30 22:15:09.308 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal
    2019-12-30 22:15:09.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed
    2019-12-30 22:15:09.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag
    2019-12-30 22:15:09.316 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime
    2019-12-30 22:15:09.347 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount
    2019-12-30 22:15:09.349 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount
    2019-12-30 22:15:09.350 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu
    2019-12-30 22:15:09.351 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime
    2019-12-30 22:15:09.366 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive
    2019-12-30 22:15:09.367 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected
    2019-12-30 22:15:09.368 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss
    2019-12-30 22:15:09.369 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal
    2019-12-30 22:15:09.370 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed
    2019-12-30 22:15:09.370 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag
    2019-12-30 22:15:09.371 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime
    2019-12-30 22:15:09.372 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount
    2019-12-30 22:15:09.373 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount
    2019-12-30 22:15:09.374 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu
    2019-12-30 22:15:09.374 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime
    2019-12-30 22:15:09.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive
    2019-12-30 22:15:09.424 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss
    2019-12-30 22:15:09.425 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal
    2019-12-30 22:15:09.426 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed
    2019-12-30 22:15:09.427 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load
    2019-12-30 22:15:09.428 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime
    2019-12-30 22:15:09.428 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem
    2019-12-30 22:15:09.429 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem
    2019-12-30 22:15:09.430 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable
    2019-12-30 22:15:09.430 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount
    2019-12-30 22:15:09.431 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount
    2019-12-30 22:15:09.446 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag
    2019-12-30 22:15:09.447 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses
    2019-12-30 22:15:09.448 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess
    2019-12-30 22:15:09.449 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact
    2019-12-30 22:15:09.450 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu
    2019-12-30 22:15:09.451 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime
    2019-12-30 22:15:09.548 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive
    2019-12-30 22:15:09.549 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected
    2019-12-30 22:15:09.551 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss
    2019-12-30 22:15:09.552 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal
    2019-12-30 22:15:09.563 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed
    2019-12-30 22:15:09.564 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag
    2019-12-30 22:15:09.565 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime
    2019-12-30 22:15:09.566 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount
    2019-12-30 22:15:09.567 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount
    2019-12-30 22:15:09.567 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu
    2019-12-30 22:15:09.568 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime
    2019-12-30 22:15:09.601 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature
    2019-12-30 22:15:09.605 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
    2019-12-30 22:15:09.787 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
    2019-12-30 22:15:10.110 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
    2019-12-30 22:15:10.116 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
    2019-12-30 22:15:10.117 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi
    2019-12-30 22:15:10.724 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
    2019-12-30 22:15:10.728 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
    2019-12-30 22:15:11.304 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.temperature
    2019-12-30 22:15:11.308 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
    2019-12-30 22:15:11.309 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
    2019-12-30 22:15:12.179 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
    2019-12-30 22:15:12.247 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
    2019-12-30 22:15:12.250 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
    2019-12-30 22:15:12.417 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
    2019-12-30 22:15:12.422 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
    2019-12-30 22:15:12.423 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi
    2019-12-30 22:15:12.519 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature
    2019-12-30 22:15:12.523 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
    2019-12-30 22:15:12.537 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
    2019-12-30 22:15:12.541 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
    2019-12-30 22:15:12.542 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
    2019-12-30 22:15:12.678 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
    2019-12-30 22:15:12.689 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi
    2019-12-30 22:15:12.750 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
    2019-12-30 22:15:12.815 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
    2019-12-30 22:15:12.819 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
    2019-12-30 22:15:13.448 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature
    2019-12-30 22:15:13.452 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
    2019-12-30 22:15:13.453 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi
    2019-12-30 22:15:15.009 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature
    2019-12-30 22:15:15.014 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
    2019-12-30 22:15:15.184 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
    2019-12-30 22:15:15.310 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
    2019-12-30 22:15:15.316 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
    2019-12-30 22:15:15.317 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi
    2019-12-30 22:15:15.922 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
    2019-12-30 22:15:15.927 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
    2019-12-30 22:15:15.990 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive
    2019-12-30 22:15:15.991 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected
    2019-12-30 22:15:15.992 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss
    2019-12-30 22:15:15.993 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal
    2019-12-30 22:15:15.994 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed
    2019-12-30 22:15:15.995 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag
    2019-12-30 22:15:15.996 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime
    2019-12-30 22:15:15.997 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount
    2019-12-30 22:15:15.998 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount
    2019-12-30 22:15:16.009 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu
    2019-12-30 22:15:16.011 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime
    2019-12-30 22:15:16.705 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
    2019-12-30 22:15:16.708 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
    2019-12-30 22:15:16.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive
    2019-12-30 22:15:16.762 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected
    2019-12-30 22:15:16.764 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss
    2019-12-30 22:15:16.764 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal
    2019-12-30 22:15:16.765 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed
    2019-12-30 22:15:16.766 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag
    2019-12-30 22:15:16.767 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime
    2019-12-30 22:15:16.767 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount
    2019-12-30 22:15:16.768 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount
    2019-12-30 22:15:16.777 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu
    2019-12-30 22:15:16.778 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime
    2019-12-30 22:15:16.815 - info: host.RasPi "system.adapter.heatingcontrol.0" disabled
    2019-12-30 22:15:16.817 - info: host.RasPi stopInstance system.adapter.heatingcontrol.0 (force=false, process=true)
    2019-12-30 22:15:16.822 - info: heatingcontrol.0 (26464) Adapter is disabled => stop
    2019-12-30 22:15:16.823 - info: host.RasPi stopInstance system.adapter.heatingcontrol.0 send kill signal
    2019-12-30 22:15:16.826 - info: heatingcontrol.0 (26464) cleaned everything up...
    2019-12-30 22:15:16.836 - info: heatingcontrol.0 (26464) Got terminate signal TERMINATE_YOURSELF
    2019-12-30 22:15:16.839 - info: heatingcontrol.0 (26464) Got terminate signal TERMINATE_YOURSELF
    2019-12-30 22:15:16.841 - info: heatingcontrol.0 (26464) terminating
    2019-12-30 22:15:16.844 - info: heatingcontrol.0 (26464) Terminated (NO_ERROR): Without reason
    2019-12-30 22:15:16.851 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.sigKill
    2019-12-30 22:15:16.857 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive
    2019-12-30 22:15:16.858 - warn: heatingcontrol.0 (26464) device not found heatingcontrol.0.system.adapter.heatingcontrol.0.sigKill
    2019-12-30 22:15:17.367 - info: host.RasPi instance system.adapter.heatingcontrol.0 terminated with code 0 (NO_ERROR)
    wenn ich den adapter starte bekomme ich neuerdings dieses log. Und das scheint ewig so weiter zu gehen.
    Ideas anyone?
    verwende aqara sensoren für temperatur und shellys sollen stellantriebe für die fbh schalten.
    Was machen da die warnungen mit bezug auf yeelight, mclighting etc im log?
    Rene_HMR 1 Antwort Letzte Antwort
    • P piscator83
      undefined2019-12-30 22:14:29.828 - info: host.RasPi "system.adapter.heatingcontrol.0" enabled
      2019-12-30 22:14:29.855 - info: host.RasPi instance system.adapter.heatingcontrol.0 started with pid 26464
      2019-12-30 22:14:32.420 - info: heatingcontrol.0 (26464) starting. Version 0.3.13 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v8.16.1
      2019-12-30 22:14:33.184 - info: heatingcontrol.0 (26464) initial check for heating period based on settings between 01.10. and 31.03.
      2019-12-30 22:14:33.185 - info: heatingcontrol.0 (26464) heating period is true
      2019-12-30 22:14:33.317 - info: heatingcontrol.0 (26464) check for heating period based on settings between 01.10. and 31.03.
      2019-12-30 22:14:33.732 - info: heatingcontrol.0 (26464) checking all actors
      2019-12-30 22:14:33.741 - info: heatingcontrol.0 (26464) 0 actors are on of 1
      2019-12-30 22:14:33.752 - info: heatingcontrol.0 (26464) checking all external states
      2019-12-30 22:14:33.757 - info: heatingcontrol.0 (26464) setting PublicHolidyToday to false
      2019-12-30 22:14:33.764 - info: heatingcontrol.0 (26464) setting Present to false
      2019-12-30 22:14:33.769 - info: heatingcontrol.0 (26464) setting VacationAbsent to false
      2019-12-30 22:14:33.775 - info: heatingcontrol.0 (26464) setting GuestsPresent to false
      2019-12-30 22:14:33.780 - info: heatingcontrol.0 (26464) setting PartyNow to false
      2019-12-30 22:14:33.785 - info: heatingcontrol.0 (26464) setting HolidayPresent to false
      2019-12-30 22:14:33.788 - info: heatingcontrol.0 (26464) external states checked, done
      2019-12-30 22:14:33.794 - info: heatingcontrol.0 (26464) calculating new target temperatures
      2019-12-30 22:14:33.835 - info: heatingcontrol.0 (26464) setting to reduced/increased temperature in Wohnzimmer to 16
      2019-12-30 22:14:33.836 - info: heatingcontrol.0 (26464) room Wohnzimmer Thermostat zigbee.0.00158d000237dead.temperature target is 16
      2019-12-30 22:14:33.839 - error: heatingcontrol.0 (26464) exception in CheckTemperatureChange [invalid id ""]
      2019-12-30 22:14:33.849 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.PublicHolidyToday
      2019-12-30 22:14:33.851 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.Present
      2019-12-30 22:14:33.853 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.VacationAbsent
      2019-12-30 22:14:33.855 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.HolidayPresent
      2019-12-30 22:14:33.857 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.GuestsPresent
      2019-12-30 22:14:33.859 - info: heatingcontrol.0 (26464) subscribe heatingcontrol.0.PartyNow
      2019-12-30 22:14:33.861 - info: heatingcontrol.0 (26464) subscribe Schlafzimmer / zigbee.0.00158d000232392b.temperature
      2019-12-30 22:14:33.864 - info: heatingcontrol.0 (26464) subscribe Bad / zigbee.0.00158d0002739ff4.temperature
      2019-12-30 22:14:33.868 - info: heatingcontrol.0 (26464) subscribe Wohnzimmer / zigbee.0.00158d000237dead.temperature
      2019-12-30 22:14:36.821 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive
      2019-12-30 22:14:36.823 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected
      2019-12-30 22:14:36.824 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss
      2019-12-30 22:14:36.825 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal
      2019-12-30 22:14:36.826 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed
      2019-12-30 22:14:36.826 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag
      2019-12-30 22:14:36.827 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime
      2019-12-30 22:14:36.828 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount
      2019-12-30 22:14:36.829 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount
      2019-12-30 22:14:36.830 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu
      2019-12-30 22:14:36.830 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime
      2019-12-30 22:14:37.159 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
      2019-12-30 22:14:37.398 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive
      2019-12-30 22:14:37.399 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected
      2019-12-30 22:14:37.400 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss
      2019-12-30 22:14:37.401 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal
      2019-12-30 22:14:37.402 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed
      2019-12-30 22:14:37.403 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag
      2019-12-30 22:14:37.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime
      2019-12-30 22:14:37.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount
      2019-12-30 22:14:37.406 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount
      2019-12-30 22:14:37.422 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu
      2019-12-30 22:14:37.423 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime
      2019-12-30 22:14:37.424 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
      2019-12-30 22:14:37.657 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive
      2019-12-30 22:14:37.673 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected
      2019-12-30 22:14:37.674 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss
      2019-12-30 22:14:37.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal
      2019-12-30 22:14:37.677 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed
      2019-12-30 22:14:37.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag
      2019-12-30 22:14:37.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime
      2019-12-30 22:14:37.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount
      2019-12-30 22:14:37.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount
      2019-12-30 22:14:37.694 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu
      2019-12-30 22:14:37.695 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime
      2019-12-30 22:14:38.413 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.temperature
      2019-12-30 22:14:38.419 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
      2019-12-30 22:14:38.420 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
      2019-12-30 22:14:38.902 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
      2019-12-30 22:14:38.907 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
      2019-12-30 22:14:39.283 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive
      2019-12-30 22:14:39.300 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected
      2019-12-30 22:14:39.301 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss
      2019-12-30 22:14:39.302 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal
      2019-12-30 22:14:39.303 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed
      2019-12-30 22:14:39.304 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag
      2019-12-30 22:14:39.305 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime
      2019-12-30 22:14:39.321 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount
      2019-12-30 22:14:39.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount
      2019-12-30 22:14:39.325 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu
      2019-12-30 22:14:39.327 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime
      2019-12-30 22:14:39.352 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive
      2019-12-30 22:14:39.354 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected
      2019-12-30 22:14:39.355 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss
      2019-12-30 22:14:39.356 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal
      2019-12-30 22:14:39.359 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed
      2019-12-30 22:14:39.360 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag
      2019-12-30 22:14:39.361 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime
      2019-12-30 22:14:39.362 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount
      2019-12-30 22:14:39.363 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount
      2019-12-30 22:14:39.364 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu
      2019-12-30 22:14:39.365 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime
      2019-12-30 22:14:39.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive
      2019-12-30 22:14:39.412 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss
      2019-12-30 22:14:39.414 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal
      2019-12-30 22:14:39.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed
      2019-12-30 22:14:39.418 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load
      2019-12-30 22:14:39.432 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime
      2019-12-30 22:14:39.433 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem
      2019-12-30 22:14:39.434 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem
      2019-12-30 22:14:39.435 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable
      2019-12-30 22:14:39.436 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount
      2019-12-30 22:14:39.436 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount
      2019-12-30 22:14:39.437 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag
      2019-12-30 22:14:39.438 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses
      2019-12-30 22:14:39.438 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess
      2019-12-30 22:14:39.439 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact
      2019-12-30 22:14:39.450 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu
      2019-12-30 22:14:39.451 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime
      2019-12-30 22:14:39.470 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
      2019-12-30 22:14:39.474 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
      2019-12-30 22:14:39.543 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive
      2019-12-30 22:14:39.544 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected
      2019-12-30 22:14:39.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss
      2019-12-30 22:14:39.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal
      2019-12-30 22:14:39.546 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed
      2019-12-30 22:14:39.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag
      2019-12-30 22:14:39.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime
      2019-12-30 22:14:39.548 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount
      2019-12-30 22:14:39.549 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount
      2019-12-30 22:14:39.559 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu
      2019-12-30 22:14:39.560 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime
      2019-12-30 22:14:39.864 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
      2019-12-30 22:14:40.112 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
      2019-12-30 22:14:40.116 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi
      2019-12-30 22:14:40.292 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
      2019-12-30 22:14:40.297 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
      2019-12-30 22:14:40.298 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
      2019-12-30 22:14:40.448 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
      2019-12-30 22:14:40.451 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi
      2019-12-30 22:14:40.662 - warn: heatingcontrol.0 (26464) device not found zigbee.0.84182600000ead8e.available
      2019-12-30 22:14:40.786 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
      2019-12-30 22:14:40.791 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
      2019-12-30 22:14:40.792 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi
      2019-12-30 22:14:41.008 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
      2019-12-30 22:14:41.074 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
      2019-12-30 22:14:41.079 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
      2019-12-30 22:14:41.080 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi
      2019-12-30 22:14:41.198 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
      2019-12-30 22:14:42.562 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature
      2019-12-30 22:14:42.566 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
      2019-12-30 22:14:42.788 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature
      2019-12-30 22:14:42.792 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
      2019-12-30 22:14:42.793 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi
      2019-12-30 22:14:43.813 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
      2019-12-30 22:14:44.104 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
      2019-12-30 22:14:44.108 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
      2019-12-30 22:14:44.730 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
      2019-12-30 22:14:44.736 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
      2019-12-30 22:14:44.737 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.rssi
      2019-12-30 22:14:45.279 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
      2019-12-30 22:14:45.282 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
      2019-12-30 22:14:45.514 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
      2019-12-30 22:14:45.652 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
      2019-12-30 22:14:45.656 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi
      2019-12-30 22:14:45.922 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
      2019-12-30 22:14:45.960 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive
      2019-12-30 22:14:45.971 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected
      2019-12-30 22:14:45.972 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss
      2019-12-30 22:14:45.973 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal
      2019-12-30 22:14:45.974 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed
      2019-12-30 22:14:45.984 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag
      2019-12-30 22:14:45.985 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime
      2019-12-30 22:14:45.986 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount
      2019-12-30 22:14:45.988 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount
      2019-12-30 22:14:45.989 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu
      2019-12-30 22:14:45.991 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime
      2019-12-30 22:14:46.000 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
      2019-12-30 22:14:46.001 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
      2019-12-30 22:14:46.002 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi
      2019-12-30 22:14:46.209 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
      2019-12-30 22:14:46.277 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
      2019-12-30 22:14:46.281 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
      2019-12-30 22:14:46.282 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi
      2019-12-30 22:14:46.400 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature
      2019-12-30 22:14:46.404 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
      2019-12-30 22:14:46.528 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
      2019-12-30 22:14:46.532 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
      2019-12-30 22:14:46.533 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
      2019-12-30 22:14:46.737 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive
      2019-12-30 22:14:46.747 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected
      2019-12-30 22:14:46.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss
      2019-12-30 22:14:46.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal
      2019-12-30 22:14:46.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed
      2019-12-30 22:14:46.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag
      2019-12-30 22:14:46.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime
      2019-12-30 22:14:46.752 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount
      2019-12-30 22:14:46.753 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount
      2019-12-30 22:14:46.762 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu
      2019-12-30 22:14:46.763 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime
      2019-12-30 22:14:47.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive
      2019-12-30 22:14:47.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.connected
      2019-12-30 22:14:47.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memRss
      2019-12-30 22:14:47.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapTotal
      2019-12-30 22:14:47.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapUsed
      2019-12-30 22:14:47.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.eventLoopLag
      2019-12-30 22:14:47.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.uptime
      2019-12-30 22:14:47.448 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.inputCount
      2019-12-30 22:14:47.450 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.outputCount
      2019-12-30 22:14:47.467 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cpu
      2019-12-30 22:14:47.470 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cputime
      2019-12-30 22:14:47.968 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature
      2019-12-30 22:14:47.972 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
      2019-12-30 22:14:48.182 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature
      2019-12-30 22:14:48.186 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
      2019-12-30 22:14:49.171 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
      2019-12-30 22:14:49.182 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.alive
      2019-12-30 22:14:49.193 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.connected
      2019-12-30 22:14:49.194 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memRss
      2019-12-30 22:14:49.195 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapTotal
      2019-12-30 22:14:49.195 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapUsed
      2019-12-30 22:14:49.196 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.eventLoopLag
      2019-12-30 22:14:49.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.uptime
      2019-12-30 22:14:49.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.inputCount
      2019-12-30 22:14:49.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.outputCount
      2019-12-30 22:14:49.211 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cpu
      2019-12-30 22:14:49.212 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cputime
      2019-12-30 22:14:49.307 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
      2019-12-30 22:14:49.318 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
      2019-12-30 22:14:49.319 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi
      2019-12-30 22:14:49.928 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
      2019-12-30 22:14:49.931 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.rssi
      2019-12-30 22:14:50.299 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.alive
      2019-12-30 22:14:50.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.connected
      2019-12-30 22:14:50.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memRss
      2019-12-30 22:14:50.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapTotal
      2019-12-30 22:14:50.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapUsed
      2019-12-30 22:14:50.312 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.eventLoopLag
      2019-12-30 22:14:50.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.uptime
      2019-12-30 22:14:50.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.inputCount
      2019-12-30 22:14:50.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.outputCount
      2019-12-30 22:14:50.322 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cpu
      2019-12-30 22:14:50.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cputime
      2019-12-30 22:14:50.717 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
      2019-12-30 22:14:50.721 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
      2019-12-30 22:14:50.848 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
      2019-12-30 22:14:50.851 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi
      2019-12-30 22:14:50.915 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature
      2019-12-30 22:14:50.919 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
      2019-12-30 22:14:50.920 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi
      2019-12-30 22:14:51.005 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.WZDeckenleuchte.info.connect
      2019-12-30 22:14:51.006 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.SZDeckenleuchte.info.connect
      2019-12-30 22:14:51.007 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KZDeckenleuchte.info.connect
      2019-12-30 22:14:51.007 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KuechePendelleuchte.info.connect
      2019-12-30 22:14:51.008 - warn: heatingcontrol.0 (26464) device not found yeelight-2.0.KuechePendelleuchte.control.power
      2019-12-30 22:14:51.130 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
      2019-12-30 22:14:51.198 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
      2019-12-30 22:14:51.434 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive
      2019-12-30 22:14:51.435 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected
      2019-12-30 22:14:51.441 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss
      2019-12-30 22:14:51.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal
      2019-12-30 22:14:51.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed
      2019-12-30 22:14:51.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag
      2019-12-30 22:14:51.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime
      2019-12-30 22:14:51.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount
      2019-12-30 22:14:51.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount
      2019-12-30 22:14:51.477 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu
      2019-12-30 22:14:51.479 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime
      2019-12-30 22:14:51.480 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
      2019-12-30 22:14:51.489 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
      2019-12-30 22:14:51.493 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
      2019-12-30 22:14:51.600 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature
      2019-12-30 22:14:51.616 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
      2019-12-30 22:14:51.617 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi
      2019-12-30 22:14:51.732 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
      2019-12-30 22:14:51.733 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
      2019-12-30 22:14:51.734 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
      2019-12-30 22:14:52.388 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive
      2019-12-30 22:14:52.389 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected
      2019-12-30 22:14:52.390 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss
      2019-12-30 22:14:52.390 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal
      2019-12-30 22:14:52.391 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed
      2019-12-30 22:14:52.402 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag
      2019-12-30 22:14:52.403 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime
      2019-12-30 22:14:52.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount
      2019-12-30 22:14:52.404 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount
      2019-12-30 22:14:52.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu
      2019-12-30 22:14:52.405 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime
      2019-12-30 22:14:52.666 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive
      2019-12-30 22:14:52.667 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected
      2019-12-30 22:14:52.667 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss
      2019-12-30 22:14:52.668 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal
      2019-12-30 22:14:52.669 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed
      2019-12-30 22:14:52.669 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag
      2019-12-30 22:14:52.670 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime
      2019-12-30 22:14:52.670 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount
      2019-12-30 22:14:52.671 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount
      2019-12-30 22:14:52.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu
      2019-12-30 22:14:52.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime
      2019-12-30 22:14:53.381 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
      2019-12-30 22:14:53.575 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature
      2019-12-30 22:14:53.578 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
      2019-12-30 22:14:54.286 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive
      2019-12-30 22:14:54.291 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected
      2019-12-30 22:14:54.292 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss
      2019-12-30 22:14:54.296 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal
      2019-12-30 22:14:54.306 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed
      2019-12-30 22:14:54.307 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag
      2019-12-30 22:14:54.308 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime
      2019-12-30 22:14:54.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount
      2019-12-30 22:14:54.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount
      2019-12-30 22:14:54.315 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu
      2019-12-30 22:14:54.318 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime
      2019-12-30 22:14:54.330 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive
      2019-12-30 22:14:54.332 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected
      2019-12-30 22:14:54.333 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss
      2019-12-30 22:14:54.334 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal
      2019-12-30 22:14:54.334 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed
      2019-12-30 22:14:54.335 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag
      2019-12-30 22:14:54.335 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime
      2019-12-30 22:14:54.343 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount
      2019-12-30 22:14:54.344 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount
      2019-12-30 22:14:54.345 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu
      2019-12-30 22:14:54.346 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime
      2019-12-30 22:14:54.397 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive
      2019-12-30 22:14:54.398 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss
      2019-12-30 22:14:54.398 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal
      2019-12-30 22:14:54.399 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed
      2019-12-30 22:14:54.399 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load
      2019-12-30 22:14:54.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime
      2019-12-30 22:14:54.400 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem
      2019-12-30 22:14:54.401 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem
      2019-12-30 22:14:54.401 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable
      2019-12-30 22:14:54.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount
      2019-12-30 22:14:54.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount
      2019-12-30 22:14:54.403 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag
      2019-12-30 22:14:54.404 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses
      2019-12-30 22:14:54.414 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess
      2019-12-30 22:14:54.415 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact
      2019-12-30 22:14:54.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu
      2019-12-30 22:14:54.416 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime
      2019-12-30 22:14:54.511 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
      2019-12-30 22:14:54.514 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
      2019-12-30 22:14:54.534 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive
      2019-12-30 22:14:54.543 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected
      2019-12-30 22:14:54.544 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss
      2019-12-30 22:14:54.545 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal
      2019-12-30 22:14:54.547 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed
      2019-12-30 22:14:54.555 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag
      2019-12-30 22:14:54.555 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime
      2019-12-30 22:14:54.556 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount
      2019-12-30 22:14:54.557 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount
      2019-12-30 22:14:54.557 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu
      2019-12-30 22:14:54.558 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime
      2019-12-30 22:14:54.588 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
      2019-12-30 22:14:54.591 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
      2019-12-30 22:14:55.124 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
      2019-12-30 22:14:56.052 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
      2019-12-30 22:14:56.185 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
      2019-12-30 22:14:56.188 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi
      2019-12-30 22:14:56.313 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
      2019-12-30 22:14:56.316 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.rssi
      2019-12-30 22:14:56.346 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
      2019-12-30 22:14:56.414 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
      2019-12-30 22:14:56.803 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
      2019-12-30 22:14:56.804 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi
      2019-12-30 22:14:56.938 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
      2019-12-30 22:14:56.942 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
      2019-12-30 22:14:57.143 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
      2019-12-30 22:14:57.208 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
      2019-12-30 22:14:57.212 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
      2019-12-30 22:14:57.213 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi
      2019-12-30 22:14:58.787 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
      2019-12-30 22:14:58.983 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
      2019-12-30 22:14:58.986 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi
      2019-12-30 22:14:59.712 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
      2019-12-30 22:14:59.717 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
      2019-12-30 22:14:59.991 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
      2019-12-30 22:14:59.994 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
      2019-12-30 22:15:00.324 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
      2019-12-30 22:15:00.327 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
      2019-12-30 22:15:00.959 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive
      2019-12-30 22:15:00.966 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected
      2019-12-30 22:15:00.967 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss
      2019-12-30 22:15:00.968 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal
      2019-12-30 22:15:00.977 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed
      2019-12-30 22:15:00.978 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag
      2019-12-30 22:15:00.978 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime
      2019-12-30 22:15:00.979 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount
      2019-12-30 22:15:00.979 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount
      2019-12-30 22:15:00.980 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu
      2019-12-30 22:15:00.980 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime
      2019-12-30 22:15:01.554 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
      2019-12-30 22:15:01.557 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Energy
      2019-12-30 22:15:01.598 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
      2019-12-30 22:15:01.603 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
      2019-12-30 22:15:01.604 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi
      2019-12-30 22:15:01.624 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
      2019-12-30 22:15:01.627 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
      2019-12-30 22:15:01.706 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature
      2019-12-30 22:15:01.709 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
      2019-12-30 22:15:01.738 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive
      2019-12-30 22:15:01.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected
      2019-12-30 22:15:01.748 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss
      2019-12-30 22:15:01.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal
      2019-12-30 22:15:01.749 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed
      2019-12-30 22:15:01.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag
      2019-12-30 22:15:01.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime
      2019-12-30 22:15:01.751 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount
      2019-12-30 22:15:01.752 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount
      2019-12-30 22:15:01.759 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu
      2019-12-30 22:15:01.760 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime
      2019-12-30 22:15:02.142 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
      2019-12-30 22:15:02.145 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
      2019-12-30 22:15:02.277 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
      2019-12-30 22:15:02.350 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
      2019-12-30 22:15:02.354 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Energy
      2019-12-30 22:15:02.413 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
      2019-12-30 22:15:02.416 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.rssi
      2019-12-30 22:15:02.442 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive
      2019-12-30 22:15:02.443 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.connected
      2019-12-30 22:15:02.444 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memRss
      2019-12-30 22:15:02.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapTotal
      2019-12-30 22:15:02.445 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.memHeapUsed
      2019-12-30 22:15:02.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.eventLoopLag
      2019-12-30 22:15:02.446 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.uptime
      2019-12-30 22:15:02.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.inputCount
      2019-12-30 22:15:02.447 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.outputCount
      2019-12-30 22:15:02.460 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cpu
      2019-12-30 22:15:02.464 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.cputime
      2019-12-30 22:15:03.050 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
      2019-12-30 22:15:04.185 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.alive
      2019-12-30 22:15:04.196 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.connected
      2019-12-30 22:15:04.197 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memRss
      2019-12-30 22:15:04.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapTotal
      2019-12-30 22:15:04.198 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.memHeapUsed
      2019-12-30 22:15:04.199 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.eventLoopLag
      2019-12-30 22:15:04.199 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.uptime
      2019-12-30 22:15:04.200 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.inputCount
      2019-12-30 22:15:04.200 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.outputCount
      2019-12-30 22:15:04.208 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cpu
      2019-12-30 22:15:04.209 - warn: heatingcontrol.0 (26464) device not found system.adapter.mclighting.0.cputime
      2019-12-30 22:15:04.210 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
      2019-12-30 22:15:04.386 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.temperature
      2019-12-30 22:15:04.390 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
      2019-12-30 22:15:04.391 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.rssi
      2019-12-30 22:15:04.906 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
      2019-12-30 22:15:04.909 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi
      2019-12-30 22:15:05.301 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.alive
      2019-12-30 22:15:05.311 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.connected
      2019-12-30 22:15:05.312 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memRss
      2019-12-30 22:15:05.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapTotal
      2019-12-30 22:15:05.313 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.memHeapUsed
      2019-12-30 22:15:05.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.eventLoopLag
      2019-12-30 22:15:05.314 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.uptime
      2019-12-30 22:15:05.315 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.inputCount
      2019-12-30 22:15:05.316 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.outputCount
      2019-12-30 22:15:05.322 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cpu
      2019-12-30 22:15:05.323 - warn: heatingcontrol.0 (26464) device not found system.adapter.ble.0.cputime
      2019-12-30 22:15:05.395 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
      2019-12-30 22:15:05.530 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
      2019-12-30 22:15:06.406 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.alive
      2019-12-30 22:15:06.414 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.connected
      2019-12-30 22:15:06.415 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memRss
      2019-12-30 22:15:06.416 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapTotal
      2019-12-30 22:15:06.417 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.memHeapUsed
      2019-12-30 22:15:06.418 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.eventLoopLag
      2019-12-30 22:15:06.425 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.uptime
      2019-12-30 22:15:06.426 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.inputCount
      2019-12-30 22:15:06.427 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.outputCount
      2019-12-30 22:15:06.428 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cpu
      2019-12-30 22:15:06.428 - warn: heatingcontrol.0 (26464) device not found system.adapter.yeelight-2.0.cputime
      2019-12-30 22:15:06.832 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
      2019-12-30 22:15:06.837 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
      2019-12-30 22:15:06.838 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.rssi
      2019-12-30 22:15:07.011 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
      2019-12-30 22:15:07.018 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
      2019-12-30 22:15:07.020 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi
      2019-12-30 22:15:07.122 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature
      2019-12-30 22:15:07.127 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
      2019-12-30 22:15:07.344 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
      2019-12-30 22:15:07.353 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
      2019-12-30 22:15:07.354 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
      2019-12-30 22:15:07.392 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.alive
      2019-12-30 22:15:07.393 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.connected
      2019-12-30 22:15:07.394 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memRss
      2019-12-30 22:15:07.395 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapTotal
      2019-12-30 22:15:07.395 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.memHeapUsed
      2019-12-30 22:15:07.396 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.eventLoopLag
      2019-12-30 22:15:07.397 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.uptime
      2019-12-30 22:15:07.413 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.inputCount
      2019-12-30 22:15:07.415 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.outputCount
      2019-12-30 22:15:07.416 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cpu
      2019-12-30 22:15:07.417 - warn: heatingcontrol.0 (26464) device not found system.adapter.history.0.cputime
      2019-12-30 22:15:07.476 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
      2019-12-30 22:15:07.549 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
      2019-12-30 22:15:07.611 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
      2019-12-30 22:15:07.661 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.alive
      2019-12-30 22:15:07.673 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.connected
      2019-12-30 22:15:07.675 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memRss
      2019-12-30 22:15:07.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapTotal
      2019-12-30 22:15:07.676 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.memHeapUsed
      2019-12-30 22:15:07.677 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.eventLoopLag
      2019-12-30 22:15:07.678 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.uptime
      2019-12-30 22:15:07.679 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.inputCount
      2019-12-30 22:15:07.680 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.outputCount
      2019-12-30 22:15:07.691 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cpu
      2019-12-30 22:15:07.692 - warn: heatingcontrol.0 (26464) device not found system.adapter.zigbee.0.cputime
      2019-12-30 22:15:08.250 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature
      2019-12-30 22:15:08.256 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
      2019-12-30 22:15:08.258 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi
      2019-12-30 22:15:09.292 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.alive
      2019-12-30 22:15:09.305 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.connected
      2019-12-30 22:15:09.307 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memRss
      2019-12-30 22:15:09.308 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapTotal
      2019-12-30 22:15:09.309 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.memHeapUsed
      2019-12-30 22:15:09.310 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.eventLoopLag
      2019-12-30 22:15:09.316 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.uptime
      2019-12-30 22:15:09.347 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.inputCount
      2019-12-30 22:15:09.349 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.outputCount
      2019-12-30 22:15:09.350 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cpu
      2019-12-30 22:15:09.351 - warn: heatingcontrol.0 (26464) device not found system.adapter.admin.0.cputime
      2019-12-30 22:15:09.366 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.alive
      2019-12-30 22:15:09.367 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.connected
      2019-12-30 22:15:09.368 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memRss
      2019-12-30 22:15:09.369 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapTotal
      2019-12-30 22:15:09.370 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.memHeapUsed
      2019-12-30 22:15:09.370 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.eventLoopLag
      2019-12-30 22:15:09.371 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.uptime
      2019-12-30 22:15:09.372 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.inputCount
      2019-12-30 22:15:09.373 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.outputCount
      2019-12-30 22:15:09.374 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cpu
      2019-12-30 22:15:09.374 - warn: heatingcontrol.0 (26464) device not found system.adapter.web.0.cputime
      2019-12-30 22:15:09.402 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.alive
      2019-12-30 22:15:09.424 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memRss
      2019-12-30 22:15:09.425 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapTotal
      2019-12-30 22:15:09.426 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memHeapUsed
      2019-12-30 22:15:09.427 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.load
      2019-12-30 22:15:09.428 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.uptime
      2019-12-30 22:15:09.428 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.mem
      2019-12-30 22:15:09.429 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.freemem
      2019-12-30 22:15:09.430 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.memAvailable
      2019-12-30 22:15:09.430 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.inputCount
      2019-12-30 22:15:09.431 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.outputCount
      2019-12-30 22:15:09.446 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.eventLoopLag
      2019-12-30 22:15:09.447 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.compactgroupProcesses
      2019-12-30 22:15:09.448 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsProcess
      2019-12-30 22:15:09.449 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.instancesAsCompact
      2019-12-30 22:15:09.450 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cpu
      2019-12-30 22:15:09.451 - warn: heatingcontrol.0 (26464) device not found system.host.RasPi.cputime
      2019-12-30 22:15:09.548 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.alive
      2019-12-30 22:15:09.549 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.connected
      2019-12-30 22:15:09.551 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memRss
      2019-12-30 22:15:09.552 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapTotal
      2019-12-30 22:15:09.563 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.memHeapUsed
      2019-12-30 22:15:09.564 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.eventLoopLag
      2019-12-30 22:15:09.565 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.uptime
      2019-12-30 22:15:09.566 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.inputCount
      2019-12-30 22:15:09.567 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.outputCount
      2019-12-30 22:15:09.567 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cpu
      2019-12-30 22:15:09.568 - warn: heatingcontrol.0 (26464) device not found system.adapter.milight.0.cputime
      2019-12-30 22:15:09.601 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature
      2019-12-30 22:15:09.605 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
      2019-12-30 22:15:09.787 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
      2019-12-30 22:15:10.110 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
      2019-12-30 22:15:10.116 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
      2019-12-30 22:15:10.117 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi
      2019-12-30 22:15:10.724 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
      2019-12-30 22:15:10.728 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
      2019-12-30 22:15:11.304 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.temperature
      2019-12-30 22:15:11.308 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
      2019-12-30 22:15:11.309 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
      2019-12-30 22:15:12.179 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.Relay0.Power
      2019-12-30 22:15:12.247 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.temperature
      2019-12-30 22:15:12.250 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA1C#1.uptime
      2019-12-30 22:15:12.417 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.temperature
      2019-12-30 22:15:12.422 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.uptime
      2019-12-30 22:15:12.423 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#BA81CB#1.rssi
      2019-12-30 22:15:12.519 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.temperature
      2019-12-30 22:15:12.523 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B8C6#1.uptime
      2019-12-30 22:15:12.537 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.temperature
      2019-12-30 22:15:12.541 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.uptime
      2019-12-30 22:15:12.542 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1DA7C#1.rssi
      2019-12-30 22:15:12.678 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.uptime
      2019-12-30 22:15:12.689 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-1#5B2D5C#1.rssi
      2019-12-30 22:15:12.750 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.Relay0.Power
      2019-12-30 22:15:12.815 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.temperature
      2019-12-30 22:15:12.819 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#B1D265#1.uptime
      2019-12-30 22:15:13.448 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.temperature
      2019-12-30 22:15:13.452 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.uptime
      2019-12-30 22:15:13.453 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA53DC#1.rssi
      2019-12-30 22:15:15.009 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.temperature
      2019-12-30 22:15:15.014 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#68FAB3#1.uptime
      2019-12-30 22:15:15.184 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#00B675#1.uptime
      2019-12-30 22:15:15.310 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.temperature
      2019-12-30 22:15:15.316 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.uptime
      2019-12-30 22:15:15.317 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1016#1.rssi
      2019-12-30 22:15:15.922 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.temperature
      2019-12-30 22:15:15.927 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-PM#BA1B09#1.uptime
      2019-12-30 22:15:15.990 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.alive
      2019-12-30 22:15:15.991 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.connected
      2019-12-30 22:15:15.992 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memRss
      2019-12-30 22:15:15.993 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapTotal
      2019-12-30 22:15:15.994 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.memHeapUsed
      2019-12-30 22:15:15.995 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.eventLoopLag
      2019-12-30 22:15:15.996 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.uptime
      2019-12-30 22:15:15.997 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.inputCount
      2019-12-30 22:15:15.998 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.outputCount
      2019-12-30 22:15:16.009 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cpu
      2019-12-30 22:15:16.011 - warn: heatingcontrol.0 (26464) device not found system.adapter.shelly.0.cputime
      2019-12-30 22:15:16.705 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.uptime
      2019-12-30 22:15:16.708 - warn: heatingcontrol.0 (26464) device not found shelly.0.SHSW-25#693D47#1.rssi
      2019-12-30 22:15:16.750 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.alive
      2019-12-30 22:15:16.762 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.connected
      2019-12-30 22:15:16.764 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memRss
      2019-12-30 22:15:16.764 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapTotal
      2019-12-30 22:15:16.765 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.memHeapUsed
      2019-12-30 22:15:16.766 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.eventLoopLag
      2019-12-30 22:15:16.767 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.uptime
      2019-12-30 22:15:16.767 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.inputCount
      2019-12-30 22:15:16.768 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.outputCount
      2019-12-30 22:15:16.777 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cpu
      2019-12-30 22:15:16.778 - warn: heatingcontrol.0 (26464) device not found system.adapter.javascript.0.cputime
      2019-12-30 22:15:16.815 - info: host.RasPi "system.adapter.heatingcontrol.0" disabled
      2019-12-30 22:15:16.817 - info: host.RasPi stopInstance system.adapter.heatingcontrol.0 (force=false, process=true)
      2019-12-30 22:15:16.822 - info: heatingcontrol.0 (26464) Adapter is disabled => stop
      2019-12-30 22:15:16.823 - info: host.RasPi stopInstance system.adapter.heatingcontrol.0 send kill signal
      2019-12-30 22:15:16.826 - info: heatingcontrol.0 (26464) cleaned everything up...
      2019-12-30 22:15:16.836 - info: heatingcontrol.0 (26464) Got terminate signal TERMINATE_YOURSELF
      2019-12-30 22:15:16.839 - info: heatingcontrol.0 (26464) Got terminate signal TERMINATE_YOURSELF
      2019-12-30 22:15:16.841 - info: heatingcontrol.0 (26464) terminating
      2019-12-30 22:15:16.844 - info: heatingcontrol.0 (26464) Terminated (NO_ERROR): Without reason
      2019-12-30 22:15:16.851 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.sigKill
      2019-12-30 22:15:16.857 - warn: heatingcontrol.0 (26464) device not found system.adapter.heatingcontrol.0.alive
      2019-12-30 22:15:16.858 - warn: heatingcontrol.0 (26464) device not found heatingcontrol.0.system.adapter.heatingcontrol.0.sigKill
      2019-12-30 22:15:17.367 - info: host.RasPi instance system.adapter.heatingcontrol.0 terminated with code 0 (NO_ERROR)
      wenn ich den adapter starte bekomme ich neuerdings dieses log. Und das scheint ewig so weiter zu gehen.
      Ideas anyone?
      verwende aqara sensoren für temperatur und shellys sollen stellantriebe für die fbh schalten.
      Was machen da die warnungen mit bezug auf yeelight, mclighting etc im log?
      Rene_HMR Offline
      Rene_HMR Offline
      Rene_HM
      schrieb am zuletzt editiert von Rene_HM
      #704
      @piscator83 schau dir mal deine Konfiguration an. Du musst die TargetOID in den Thermostaten setzen. Nur die Ist-OID reicht nicht!
      siehe im log
      exception in CheckTemperatureChange [invalid id ""]
      Dadurch werden alle states im System subscribed, was zu den vielen Warnungen führt...
      Wenn du nur Temperatur-Sensoren hast, musst du dir die Target-OID's irgendwo anders (evtl. in einem script) anlegen. Wir brauchen die, um die aktuelle Zieltemperatur zu speichern. Normalerweise passiert das in den Thermostaten...
      • moppel2810M Offline
        moppel2810M Offline
        moppel2810
        #705
        heatingcontrol.0	2019-12-31 08:43:34.457	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933362844} from deconz.0.Sensors.21.open
        heatingcontrol.0	2019-12-31 08:43:34.455	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577638441163} from deconz.0.Sensors.20.open
        heatingcontrol.0	2019-12-31 08:43:34.453	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933207327} from deconz.0.Sensors.19.open
        heatingcontrol.0	2019-12-31 08:43:34.452	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574987,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933122635} from deconz.0.Sensors.18.open
        heatingcontrol.0	2019-12-31 08:43:34.451	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933025797} from deconz.0.Sensors.17.open
        heatingcontrol.0	2019-12-31 08:43:34.450	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576932905933} from deconz.0.Sensors.16.open
        heatingcontrol.0	2019-12-31 08:43:34.449	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577007719646} from deconz.0.Sensors.15.open
        heatingcontrol.0	2019-12-31 08:43:34.448	debug	(2068) Check sensors for Wohnzimmer
        heatingcontrol.0	2019-12-31 08:43:34.435	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577644284922} from deconz.0.Sensors.24.open
        heatingcontrol.0	2019-12-31 08:43:34.435	debug	(2068) got sensor state {"val":0,"ack":true,"ts":1577778970470,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577778970470} from hm-rpc.1.0007D5699E9605.1.STATE
        heatingcontrol.0	2019-12-31 08:43:34.434	debug	(2068) Check sensors for Küche
        heatingcontrol.0	2019-12-31 08:43:34.430	warn	(2068) Badezimmer no valid result from hm-rpc.1.0000D56996187D
        heatingcontrol.0	2019-12-31 08:43:34.429	debug	(2068) got sensor state null from hm-rpc.1.0000D56996187D
        heatingcontrol.0	2019-12-31 08:43:34.425	debug	(2068) Check sensors for Badezimmer
        heatingcontrol.0	2019-12-31 08:43:34.420	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577705276875} from deconz.0.Sensors.23.open
        heatingcontrol.0	2019-12-31 08:43:34.420	debug	(2068) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576925832752} from deconz.0.Sensors.11.open
        heatingcontrol.0	2019-12-31 08:43:34.418	debug	(2068) Check sensors for Arbeitszimmer
        heatingcontrol.0	2019-12-31 08:43:34.418	debug	(2068) [INFO] status = true next event: 4 Jan 2020 20:00:00
        heatingcontrol.0	2019-12-31 08:43:34.417	debug	(2068) [INFO] status = true next event: 4 Jan 2020 15:00:00
        heatingcontrol.0	2019-12-31 08:43:34.416	debug	(2068) [INFO] status = true next event: 4 Jan 2020 11:00:00
        heatingcontrol.0	2019-12-31 08:43:34.415	debug	(2068) [INFO] status = true next event: 4 Jan 2020 07:00:00
        heatingcontrol.0	2019-12-31 08:43:34.415	debug	(2068) [INFO] status = true next event: 4 Jan 2020 04:00:00
        heatingcontrol.0	2019-12-31 08:43:34.414	debug	(2068) [INFO] status = true next event: 31 Dec 2019 20:00:00
        heatingcontrol.0	2019-12-31 08:43:34.414	debug	(2068) [INFO] status = true next event: 31 Dec 2019 15:00:00
        heatingcontrol.0	2019-12-31 08:43:34.413	debug	(2068) [INFO] status = true next event: 31 Dec 2019 11:00:00
        heatingcontrol.0	2019-12-31 08:43:34.413	debug	(2068) [INFO] status = true next event: 1 Jan 2020 07:00:00
        heatingcontrol.0	2019-12-31 08:43:34.411	debug	(2068) [INFO] status = true next event: 1 Jan 2020 04:00:00
        heatingcontrol.0	2019-12-31 08:43:34.401	debug	(2068) create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.399	debug	(2068) create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.398	debug	(2068) create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.396	debug	(2068) create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.392	debug	(2068) create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.391	debug	(2068) create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.390	debug	(2068) create cron job #3 at 16:0 string: 0 0 16 * * 1-5 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.388	debug	(2068) create cron job #2 at 12:0 string: 0 0 12 * * 1-5 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.380	debug	(2068) create cron job #1 at 8:0 string: 0 0 8 * * 1-5 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.367	debug	(2068) create cron job #0 at 5:0 string: 0 0 5 * * 1-5 Europe/Berlin
        heatingcontrol.0	2019-12-31 08:43:34.366	debug	(2068) ---2 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
        heatingcontrol.0	2019-12-31 08:43:34.365	debug	(2068) ---2 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
        heatingcontrol.0	2019-12-31 08:43:34.365	debug	(2068) ---2 found time for Wohnzimmer at {"val":"12:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 12:00
        heatingcontrol.0	2019-12-31 08:43:34.364	debug	(2068) ---2 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00
        heatingcontrol.0	2019-12-31 08:43:34.364	debug	(2068) ---2 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00
        heatingcontrol.0	2019-12-31 08:43:34.363	debug	(2068) setting Sa - Su
        heatingcontrol.0	2019-12-31 08:43:34.363	debug	(2068) ---1 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
        heatingcontrol.0	2019-12-31 08:43:34.362	debug	(2068) ---1 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
        heatingcontrol.0	2019-12-31 08:43:34.361	debug	(2068) ---1 found time for Wohnzimmer at {"val":"12:00","ack":false,"ts":1577542409214,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1577542409214} 12:00
        heatingcontrol.0	2019-12-31 08:43:34.079	debug	(2068) ---1 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00
        heatingcontrol.0	2019-12-31 08:43:34.078	debug	(2068) ---1 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00
        heatingcontrol.0	2019-12-31 08:43:34.077	debug	(2068) setting Mo - Fr
        heatingcontrol.0	2019-12-31 08:43:34.077	debug	(2068) ---2 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
        heatingcontrol.0	2019-12-31 08:43:34.077	debug	(2068) ---2 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
        heatingcontrol.0	2019-12-31 08:43:34.076	debug	(2068) ---2 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
        heatingcontrol.0	2019-12-31 08:43:34.075	debug	(2068) ---2 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
        heatingcontrol.0	2019-12-31 08:43:34.074	debug	(2068) ---2 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
        heatingcontrol.0	2019-12-31 08:43:34.074	debug	(2068) setting Sa - Su
        heatingcontrol.0	2019-12-31 08:43:34.073	debug	(2068) ---1 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
        heatingcontrol.0	2019-12-31 08:43:34.067	debug	(2068) ---1 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
        heatingcontrol.0	2019-12-31 08:43:34.066	debug	(2068) ---1 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
        heatingcontrol.0	2019-12-31 08:43:34.064	debug	(2068) ---1 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
        heatingcontrol.0	2019-12-31 08:43:34.064	debug	(2068) ---1 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
        heatingcontrol.0	2019-12-31 08:43:34.063	debug	(2068) setting Mo - Fr
        heatingcontrol.0	2019-12-31 08:43:34.063	debug	(2068) ---2 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
        heatingcontrol.0	2019-12-31 08:43:34.062	debug	(2068) ---2 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
        heatingcontrol.0	2019-12-31 08:43:34.061	debug	(2068) ---2 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
        heatingcontrol.0	2019-12-31 08:43:34.061	debug	(2068) ---2 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
        heatingcontrol.0	2019-12-31 08:43:34.060	debug	(2068) ---2 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
        heatingcontrol.0	2019-12-31 08:43:34.060	debug	(2068) setting Sa - Su
        heatingcontrol.0	2019-12-31 08:43:34.059	debug	(2068) ---1 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
        heatingcontrol.0	2019-12-31 08:43:34.059	debug	(2068) ---1 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
        heatingcontrol.0	2019-12-31 08:43:34.057	debug	(2068) ---1 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
        heatingcontrol.0	2019-12-31 08:43:34.057	debug	(2068) ---1 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
        heatingcontrol.0	2019-12-31 08:43:34.056	debug	(2068) ---1 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
        heatingcontrol.0	2019-12-31 08:43:34.056	debug	(2068) setting Mo - Fr
        heatingcontrol.0	2019-12-31 08:43:34.055	debug	(2068) push to list = 21,00
        heatingcontrol.0	2019-12-31 08:43:34.055	debug	(2068) ---2 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
        heatingcontrol.0	2019-12-31 08:43:34.054	debug	(2068) push to list = 16,00
        heatingcontrol.0	2019-12-31 08:43:34.054	debug	(2068) ---2 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
        heatingcontrol.0	2019-12-31 08:43:34.054	debug	(2068) push to list = 12,00
        heatingcontrol.0	2019-12-31 08:43:34.054	debug	(2068) ---2 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
        heatingcontrol.0	2019-12-31 08:43:34.053	debug	(2068) push to list = 08,00
        heatingcontrol.0	2019-12-31 08:43:34.053	debug	(2068) ---2 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
        heatingcontrol.0	2019-12-31 08:43:34.053	debug	(2068) push to list = 05,00
        heatingcontrol.0	2019-12-31 08:43:34.052	debug	(2068) ---2 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
        heatingcontrol.0	2019-12-31 08:43:34.052	debug	(2068) setting Sa - Su
        heatingcontrol.0	2019-12-31 08:43:34.052	debug	(2068) push to list = 21,00
        heatingcontrol.0	2019-12-31 08:43:34.052	debug	(2068) ---1 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
        heatingcontrol.0	2019-12-31 08:43:34.051	debug	(2068) push to list = 16,00
        heatingcontrol.0	2019-12-31 08:43:34.051	debug	(2068) ---1 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
        heatingcontrol.0	2019-12-31 08:43:34.050	debug	(2068) push to list = 12,00
        heatingcontrol.0	2019-12-31 08:43:34.050	debug	(2068) ---1 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
        heatingcontrol.0	2019-12-31 08:43:34.007	debug	(2068) push to list = 08,00
        heatingcontrol.0	2019-12-31 08:43:34.007	debug	(2068) ---1 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
        heatingcontrol.0	2019-12-31 08:43:33.967	debug	(2068) push to list = 05,00
        heatingcontrol.0	2019-12-31 08:43:33.967	debug	(2068) ---1 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
        heatingcontrol.0	2019-12-31 08:43:33.965	debug	(2068) setting Mo - Fr
        heatingcontrol.0	2019-12-31 08:43:33.965	debug	(2068) profile 0
        heatingcontrol.0	2019-12-31 08:43:33.963	debug	(2068) get profile
        heatingcontrol.0	2019-12-31 08:43:33.963	debug	(2068) start CalculateNextTime, profile type 2
        heatingcontrol.0	2019-12-31 08:43:33.954	debug	(2068) system date format DD.MM.YYYY
        heatingcontrol.0	2019-12-31 08:43:33.952	debug	(2068) CreateDatepoints done
        heatingcontrol.0	2019-12-31 08:43:33.952	debug	(2068) not active.... Kinderzimmer
        heatingcontrol.0	2019-12-31 08:43:33.952	debug	(2068) not active.... Schlafzimmer
        heatingcontrol.0	2019-12-31 08:43:33.951	debug	(2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.4 max 5
        heatingcontrol.0	2019-12-31 08:43:33.951	debug	(2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.3 max 5
        heatingcontrol.0	2019-12-31 08:43:33.951	debug	(2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.2 max 5
        heatingcontrol.0	2019-12-31 08:43:33.951	debug	(2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.1 max 5
        heatingcontrol.0	2019-12-31 08:43:33.951	debug	(2068) add state Profiles.0.Wohnzimmer.Sa-So.Periods.0 max 5
        heatingcontrol.0	2019-12-31 08:43:33.951	debug	(2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.4 max 5
        heatingcontrol.0	2019-12-31 08:43:33.950	debug	(2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.3 max 5
        heatingcontrol.0	2019-12-31 08:43:33.950	debug	(2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.2 max 5
        heatingcontrol.0	2019-12-31 08:43:33.950	debug	(2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.1 max 5
        heatingcontrol.0	2019-12-31 08:43:33.950	debug	(2068) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.0 max 5
        heatingcontrol.0	2019-12-31 08:43:33.950	debug	(2068) Profile Type Mo-FR + Sa-So, profiles 1
        heatingcontrol.0	2019-12-31 08:43:33.949	debug	(2068) room Wohnzimmer with 5 periods
        heatingcontrol.0	2019-12-31 08:43:33.893	debug	(2068) create data profile points (absolute) for Wohnzimmer
        heatingcontrol.0	2019-12-31 08:43:33.892	debug	(2068) add state Profiles.0.Küche.Sa-So.Periods.4 max 5
        heatingcontrol.0	2019-12-31 08:43:33.892	debug	(2068) add state Profiles.0.Küche.Sa-So.Periods.3 max 5
        heatingcontrol.0	2019-12-31 08:43:33.892	debug	(2068) add state Profiles.0.Küche.Sa-So.Periods.2 max 5
        heatingcontrol.0	2019-12-31 08:43:33.892	debug	(2068) add state Profiles.0.Küche.Sa-So.Periods.1 max 5
        heatingcontrol.0	2019-12-31 08:43:33.892	debug	(2068) add state Profiles.0.Küche.Sa-So.Periods.0 max 5
        heatingcontrol.0	2019-12-31 08:43:33.892	debug	(2068) add state Profiles.0.Küche.Mo-Fr.Periods.4 max 5
        heatingcontrol.0	2019-12-31 08:43:33.891	debug	(2068) add state Profiles.0.Küche.Mo-Fr.Periods.3 max 5
        heatingcontrol.0	2019-12-31 08:43:33.891	debug	(2068) add state Profiles.0.Küche.Mo-Fr.Periods.2 max 5
        heatingcontrol.0	2019-12-31 08:43:33.891	debug	(2068) add state Profiles.0.Küche.Mo-Fr.Periods.1 max 5
        heatingcontrol.0	2019-12-31 08:43:33.891	debug	(2068) add state Profiles.0.Küche.Mo-Fr.Periods.0 max 5
        heatingcontrol.0	2019-12-31 08:43:33.891	debug	(2068) Profile Type Mo-FR + Sa-So, profiles 1
        heatingcontrol.0	2019-12-31 08:43:33.891	debug	(2068) room Küche with 5 periods
        heatingcontrol.0	2019-12-31 08:43:33.747	debug	(2068) create data profile points (absolute) for Küche
        heatingcontrol.0	2019-12-31 08:43:33.746	debug	(2068) add state Profiles.0.Badezimmer.Sa-So.Periods.4 max 5
        heatingcontrol.0	2019-12-31 08:43:33.741	debug	(2068) add state Profiles.0.Badezimmer.Sa-So.Periods.3 max 5
        heatingcontrol.0	2019-12-31 08:43:33.740	debug	(2068) add state Profiles.0.Badezimmer.Sa-So.Periods.2 max 5
        heatingcontrol.0	2019-12-31 08:43:33.740	debug	(2068) add state Profiles.0.Badezimmer.Sa-So.Periods.1 max 5
        heatingcontrol.0	2019-12-31 08:43:33.740	debug	(2068) add state Profiles.0.Badezimmer.Sa-So.Periods.0 max 5
        heatingcontrol.0	2019-12-31 08:43:33.739	debug	(2068) add state Profiles.0.Badezimmer.Mo-Fr.Periods.4 max 5
        heatingcontrol.0	2019-12-31 08:43:33.739	debug	(2068) add state Profiles.0.Badezimmer.Mo-Fr.Periods.3 max 5
        heatingcontrol.0	2019-12-31 08:43:33.739	debug	(2068) add state Profiles.0.Badezimmer.Mo-Fr.Periods.2 max 5
        heatingcontrol.0	2019-12-31 08:43:33.739	debug	(2068) add state Profiles.0.Badezimmer.Mo-Fr.Periods.1 max 5
        Moin, das ist jetzt der Debug hoffe ihr könnt mir weiter helfen.
        Rene_HMR 1 Antwort Letzte Antwort
          moppel2810M Offline
          moppel2810
          #706
          heatingcontrol.0	2019-12-31 08:57:18.828	debug	(2068) system.adapter.admin.0: logging true
          heatingcontrol.0	2019-12-31 08:57:07.314	debug	(2068) system.adapter.admin.0: logging false
          heatingcontrol.0	2019-12-31 08:46:41.174	debug	(2068) system.adapter.admin.0: logging true
          heatingcontrol.0	2019-12-31 08:43:34.461	error	(2068) exception in main [invalid id ""]
          heatingcontrol.0	2019-12-31 08:43:34.460	info	(2068) checking all actors
          Das ist da jetzt noch dazu gekommen. Ich glaube auch das meine Uhr falsch geht bzw wenn ich auf die admin Uhr gucke stimmt die zeit aber die Zeit jetzt im debug ist ne Std hinterher.
          • moppel2810M moppel2810
            Rene_HMR Offline
            Rene_HMR Offline
            Rene_HM
            #707
            @moppel2810 sagte in Test Adapter HeatingControl v0.3.x:
            Hier stimmt eine Konfiguration nicht. Eine OID ist nicht gesetzt...
            moppel2810M 1 Antwort Letzte Antwort
              Rene_HMR Offline
              Rene_HMR Offline
              Rene_HM
              #708
              Hier muss der gesamte Pfad zum Datenpunkt in die Konfiguration, nicht nur der Name des Gerätes. ich denke hier fehlt .state
              Ansonsten sehe ich nur, dass alle Fenster geschlossen sind.
              Bzgl. des Feiertag-Problems sehe ich nichts im log. Hier wäre der Start des Adapters und das Schalten auf Feiertag interessant, das fehlt aber im log.
              • Rene_HMR Rene_HM
                moppel2810M Offline
                moppel2810M Offline
                moppel2810
                #709
                @Rene_HM ich weiß du bist kein Hellseher🙄 aber hast du eine Idee was da fehlen könnte? Ich verzweifel hier bald bei der Suche😬
                • Rene_HMR Rene_HM
                  moppel2810M Offline
                  moppel2810M Offline
                  moppel2810
                  #710
                  @Rene_HM hab jetzt mal mit debug den Adapter neugestartet und das kommt dabei raus. Das mit dem Badezimmerfensterkontakt sollte sich erledigt haben hoffe ich.
                  heatingcontrol.0	2019-12-31 09:36:45.523	error	(6841) exception in main [invalid id ""]
                  heatingcontrol.0	2019-12-31 09:36:45.522	info	(6841) checking all actors
                  heatingcontrol.0	2019-12-31 09:36:45.476	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933362844} from deconz.0.Sensors.21.open
                  heatingcontrol.0	2019-12-31 09:36:45.476	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577638441163} from deconz.0.Sensors.20.open
                  heatingcontrol.0	2019-12-31 09:36:45.475	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933207327} from deconz.0.Sensors.19.open
                  heatingcontrol.0	2019-12-31 09:36:45.472	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574987,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933122635} from deconz.0.Sensors.18.open
                  heatingcontrol.0	2019-12-31 09:36:45.470	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933025797} from deconz.0.Sensors.17.open
                  heatingcontrol.0	2019-12-31 09:36:45.468	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576932905933} from deconz.0.Sensors.16.open
                  heatingcontrol.0	2019-12-31 09:36:45.466	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577007719646} from deconz.0.Sensors.15.open
                  heatingcontrol.0	2019-12-31 09:36:45.423	debug	(6841) Check sensors for Wohnzimmer
                  heatingcontrol.0	2019-12-31 09:36:45.359	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577644284922} from deconz.0.Sensors.24.open
                  heatingcontrol.0	2019-12-31 09:36:45.357	debug	(6841) got sensor state {"val":0,"ack":true,"ts":1577784161106,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577784161106} from hm-rpc.1.0007D5699E9605.1.STATE
                  heatingcontrol.0	2019-12-31 09:36:45.355	debug	(6841) Check sensors for Küche
                  heatingcontrol.0	2019-12-31 09:36:45.308	debug	(6841) got sensor state {"val":0,"ack":true,"ts":1577784919740,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577628013202} from hm-rpc.1.0000D56996187D.1.STATE
                  heatingcontrol.0	2019-12-31 09:36:45.305	debug	(6841) Check sensors for Badezimmer
                  heatingcontrol.0	2019-12-31 09:36:45.296	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577705276875} from deconz.0.Sensors.23.open
                  heatingcontrol.0	2019-12-31 09:36:45.293	debug	(6841) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576925832752} from deconz.0.Sensors.11.open
                  heatingcontrol.0	2019-12-31 09:36:45.259	debug	(6841) Check sensors for Arbeitszimmer
                  heatingcontrol.0	2019-12-31 09:36:45.257	debug	(6841) [INFO] status = true next event: 4 Jan 2020 20:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.256	debug	(6841) [INFO] status = true next event: 4 Jan 2020 15:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.253	debug	(6841) [INFO] status = true next event: 4 Jan 2020 11:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.252	debug	(6841) [INFO] status = true next event: 4 Jan 2020 07:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.251	debug	(6841) [INFO] status = true next event: 4 Jan 2020 04:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.251	debug	(6841) [INFO] status = true next event: 31 Dec 2019 20:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.250	debug	(6841) [INFO] status = true next event: 31 Dec 2019 15:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.250	debug	(6841) [INFO] status = true next event: 31 Dec 2019 11:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.247	debug	(6841) [INFO] status = true next event: 1 Jan 2020 07:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.246	debug	(6841) [INFO] status = true next event: 1 Jan 2020 04:00:00
                  heatingcontrol.0	2019-12-31 09:36:45.231	debug	(6841) create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.228	debug	(6841) create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.226	debug	(6841) create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.220	debug	(6841) create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.216	debug	(6841) create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.214	debug	(6841) create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.213	debug	(6841) create cron job #3 at 16:0 string: 0 0 16 * * 1-5 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.211	debug	(6841) create cron job #2 at 12:0 string: 0 0 12 * * 1-5 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.203	debug	(6841) create cron job #1 at 8:0 string: 0 0 8 * * 1-5 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.186	debug	(6841) create cron job #0 at 5:0 string: 0 0 5 * * 1-5 Europe/Berlin
                  heatingcontrol.0	2019-12-31 09:36:45.185	debug	(6841) ---2 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
                  heatingcontrol.0	2019-12-31 09:36:45.183	debug	(6841) ---2 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
                  heatingcontrol.0	2019-12-31 09:36:45.182	debug	(6841) ---2 found time for Wohnzimmer at {"val":"12:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 12:00
                  heatingcontrol.0	2019-12-31 09:36:45.180	debug	(6841) ---2 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00
                  heatingcontrol.0	2019-12-31 09:36:45.178	debug	(6841) ---2 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00
                  heatingcontrol.0	2019-12-31 09:36:45.175	debug	(6841) setting Sa - Su
                  heatingcontrol.0	2019-12-31 09:36:45.175	debug	(6841) ---1 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
                  heatingcontrol.0	2019-12-31 09:36:45.173	debug	(6841) ---1 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
                  heatingcontrol.0	2019-12-31 09:36:45.171	debug	(6841) ---1 found time for Wohnzimmer at {"val":"12:00","ack":false,"ts":1577542409214,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1577542409214} 12:00
                  heatingcontrol.0	2019-12-31 09:36:45.169	debug	(6841) ---1 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00
                  heatingcontrol.0	2019-12-31 09:36:45.168	debug	(6841) ---1 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00
                  heatingcontrol.0	2019-12-31 09:36:45.165	debug	(6841) setting Mo - Fr
                  heatingcontrol.0	2019-12-31 09:36:45.165	debug	(6841) ---2 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
                  heatingcontrol.0	2019-12-31 09:36:45.163	debug	(6841) ---2 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
                  heatingcontrol.0	2019-12-31 09:36:45.162	debug	(6841) ---2 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                  heatingcontrol.0	2019-12-31 09:36:45.158	debug	(6841) ---2 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                  heatingcontrol.0	2019-12-31 09:36:45.156	debug	(6841) ---2 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                  heatingcontrol.0	2019-12-31 09:36:45.152	debug	(6841) setting Sa - Su
                  heatingcontrol.0	2019-12-31 09:36:45.152	debug	(6841) ---1 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                  heatingcontrol.0	2019-12-31 09:36:45.148	debug	(6841) ---1 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                  heatingcontrol.0	2019-12-31 09:36:45.144	debug	(6841) ---1 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                  heatingcontrol.0	2019-12-31 09:36:45.141	debug	(6841) ---1 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                  heatingcontrol.0	2019-12-31 09:36:45.139	debug	(6841) ---1 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                  heatingcontrol.0	2019-12-31 09:36:45.135	debug	(6841) setting Mo - Fr
                  heatingcontrol.0	2019-12-31 09:36:45.135	debug	(6841) ---2 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                  heatingcontrol.0	2019-12-31 09:36:45.132	debug	(6841) ---2 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                  heatingcontrol.0	2019-12-31 09:36:45.130	debug	(6841) ---2 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                  heatingcontrol.0	2019-12-31 09:36:45.128	debug	(6841) ---2 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                  heatingcontrol.0	2019-12-31 09:36:45.126	debug	(6841) ---2 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                  heatingcontrol.0	2019-12-31 09:36:45.101	debug	(6841) setting Sa - Su
                  heatingcontrol.0	2019-12-31 09:36:45.100	debug	(6841) ---1 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                  heatingcontrol.0	2019-12-31 09:36:45.099	debug	(6841) ---1 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                  heatingcontrol.0	2019-12-31 09:36:45.096	debug	(6841) ---1 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                  heatingcontrol.0	2019-12-31 09:36:45.095	debug	(6841) ---1 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                  heatingcontrol.0	2019-12-31 09:36:45.093	debug	(6841) ---1 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                  heatingcontrol.0	2019-12-31 09:36:45.089	debug	(6841) setting Mo - Fr
                  heatingcontrol.0	2019-12-31 09:36:45.089	debug	(6841) push to list = 21,00
                  heatingcontrol.0	2019-12-31 09:36:45.089	debug	(6841) ---2 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                  heatingcontrol.0	2019-12-31 09:36:45.085	debug	(6841) push to list = 16,00
                  heatingcontrol.0	2019-12-31 09:36:45.085	debug	(6841) ---2 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                  heatingcontrol.0	2019-12-31 09:36:45.082	debug	(6841) push to list = 12,00
                  heatingcontrol.0	2019-12-31 09:36:45.082	debug	(6841) ---2 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                  heatingcontrol.0	2019-12-31 09:36:45.072	debug	(6841) push to list = 08,00
                  heatingcontrol.0	2019-12-31 09:36:45.072	debug	(6841) ---2 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                  heatingcontrol.0	2019-12-31 09:36:45.069	debug	(6841) push to list = 05,00
                  heatingcontrol.0	2019-12-31 09:36:45.068	debug	(6841) ---2 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                  heatingcontrol.0	2019-12-31 09:36:45.063	debug	(6841) setting Sa - Su
                  heatingcontrol.0	2019-12-31 09:36:45.062	debug	(6841) push to list = 21,00
                  heatingcontrol.0	2019-12-31 09:36:45.061	debug	(6841) ---1 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                  heatingcontrol.0	2019-12-31 09:36:45.057	debug	(6841) push to list = 16,00
                  heatingcontrol.0	2019-12-31 09:36:45.057	debug	(6841) ---1 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                  heatingcontrol.0	2019-12-31 09:36:45.051	debug	(6841) push to list = 12,00
                  heatingcontrol.0	2019-12-31 09:36:45.051	debug	(6841) ---1 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                  heatingcontrol.0	2019-12-31 09:36:45.043	debug	(6841) push to list = 08,00
                  heatingcontrol.0	2019-12-31 09:36:45.042	debug	(6841) ---1 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                  heatingcontrol.0	2019-12-31 09:36:45.029	debug	(6841) push to list = 05,00
                  heatingcontrol.0	2019-12-31 09:36:45.027	debug	(6841) ---1 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                  heatingcontrol.0	2019-12-31 09:36:45.017	debug	(6841) setting Mo - Fr
                  heatingcontrol.0	2019-12-31 09:36:45.015	debug	(6841) profile 0
                  heatingcontrol.0	2019-12-31 09:36:45.000	debug	(6841) get profile
                  heatingcontrol.0	2019-12-31 09:36:45.000	debug	(6841) start CalculateNextTime, profile type 2
                  heatingcontrol.0	2019-12-31 09:36:44.998	debug	(6841) system date format DD.MM.YYYY
                  heatingcontrol.0	2019-12-31 09:36:44.968	debug	(6841) CreateDatepoints done
                  heatingcontrol.0	2019-12-31 09:36:44.968	debug	(6841) not active.... Kinderzimmer
                  heatingcontrol.0	2019-12-31 09:36:44.968	debug	(6841) not active.... Schlafzimmer
                  heatingcontrol.0	2019-12-31 09:36:44.968	debug	(6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.4 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.967	debug	(6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.3 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.966	debug	(6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.2 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.966	debug	(6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.1 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.966	debug	(6841) add state Profiles.0.Wohnzimmer.Sa-So.Periods.0 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.965	debug	(6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.4 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.965	debug	(6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.3 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.965	debug	(6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.2 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.964	debug	(6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.1 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.964	debug	(6841) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.0 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.964	debug	(6841) Profile Type Mo-FR + Sa-So, profiles 1
                  heatingcontrol.0	2019-12-31 09:36:44.963	debug	(6841) room Wohnzimmer with 5 periods
                  heatingcontrol.0	2019-12-31 09:36:44.904	debug	(6841) create data profile points (absolute) for Wohnzimmer
                  heatingcontrol.0	2019-12-31 09:36:44.903	debug	(6841) add state Profiles.0.Küche.Sa-So.Periods.4 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.900	debug	(6841) add state Profiles.0.Küche.Sa-So.Periods.3 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.900	debug	(6841) add state Profiles.0.Küche.Sa-So.Periods.2 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.900	debug	(6841) add state Profiles.0.Küche.Sa-So.Periods.1 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.899	debug	(6841) add state Profiles.0.Küche.Sa-So.Periods.0 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.899	debug	(6841) add state Profiles.0.Küche.Mo-Fr.Periods.4 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.897	debug	(6841) add state Profiles.0.Küche.Mo-Fr.Periods.3 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.897	debug	(6841) add state Profiles.0.Küche.Mo-Fr.Periods.2 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.896	debug	(6841) add state Profiles.0.Küche.Mo-Fr.Periods.1 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.896	debug	(6841) add state Profiles.0.Küche.Mo-Fr.Periods.0 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.896	debug	(6841) Profile Type Mo-FR + Sa-So, profiles 1
                  heatingcontrol.0	2019-12-31 09:36:44.895	debug	(6841) room Küche with 5 periods
                  heatingcontrol.0	2019-12-31 09:36:44.839	debug	(6841) create data profile points (absolute) for Küche
                  heatingcontrol.0	2019-12-31 09:36:44.838	debug	(6841) add state Profiles.0.Badezimmer.Sa-So.Periods.4 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.837	debug	(6841) add state Profiles.0.Badezimmer.Sa-So.Periods.3 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.835	debug	(6841) add state Profiles.0.Badezimmer.Sa-So.Periods.2 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.833	debug	(6841) add state Profiles.0.Badezimmer.Sa-So.Periods.1 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.833	debug	(6841) add state Profiles.0.Badezimmer.Sa-So.Periods.0 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.833	debug	(6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.4 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.832	debug	(6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.3 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.832	debug	(6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.2 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.832	debug	(6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.1 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.831	debug	(6841) add state Profiles.0.Badezimmer.Mo-Fr.Periods.0 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.831	debug	(6841) Profile Type Mo-FR + Sa-So, profiles 1
                  heatingcontrol.0	2019-12-31 09:36:44.831	debug	(6841) room Badezimmer with 5 periods
                  heatingcontrol.0	2019-12-31 09:36:44.671	debug	(6841) create data profile points (absolute) for Badezimmer
                  heatingcontrol.0	2019-12-31 09:36:44.671	debug	(6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.4 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.670	debug	(6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.3 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.670	debug	(6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.2 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.670	debug	(6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.1 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.670	debug	(6841) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.0 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.669	debug	(6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.4 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.669	debug	(6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.3 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.669	debug	(6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.2 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.668	debug	(6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.1 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.667	debug	(6841) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.0 max 5
                  heatingcontrol.0	2019-12-31 09:36:44.667	debug	(6841) Profile Type Mo-FR + Sa-So, profiles 1
                  heatingcontrol.0	2019-12-31 09:36:44.667	debug	(6841) room Arbeitszimmer with 5 periods
                  heatingcontrol.0	2019-12-31 09:36:44.616	debug	(6841) create data profile points (absolute) for Arbeitszimmer
                  heatingcontrol.0	2019-12-31 09:36:44.616	debug	(6841) rooms 6
                  heatingcontrol.0	2019-12-31 09:36:44.608	debug	(6841) create data points for Wohnzimmer
                  heatingcontrol.0	2019-12-31 09:36:44.601	debug	(6841) create data points for Küche
                  heatingcontrol.0	2019-12-31 09:36:44.593	debug	(6841) create data points for Badezimmer
                  heatingcontrol.0	2019-12-31 09:36:44.586	debug	(6841) create data points for Arbeitszimmer
                  heatingcontrol.0	2019-12-31 09:36:44.455	debug	(6841) start CreateDatepoints
                  heatingcontrol.0	2019-12-31 09:36:44.454	debug	(6841) devices [{"id":1,"name":"","OID_Target":"","isActive":false,"type":2,"room":"Arbeitszimmer"},{"id":2,"name":"Fenster- / Türkontaktsensor (2) open","OID_Current":"deconz.0.Sensors.11.open","isA
                  heatingcontrol.0	2019-12-31 09:36:44.430	info	(6841) starting. Version 0.3.14 in /opt/iobroker/node_modules/iobroker.heatingcontrol, node: v10.17.0
                  heatingcontrol.0	2019-12-31 09:36:44.053	debug	(6841) States connected to redis: 127.0.0.1:9000
                  heatingcontrol.0	2019-12-31 09:36:44.032	debug	(6841) statesDB connected
                  heatingcontrol.0	2019-12-31 09:36:44.031	debug	(6841) States create PubSub Client
                  heatingcontrol.0	2019-12-31 09:36:44.027	debug	(6841) Objects connected to redis: 127.0.0.1:9001
                  heatingcontrol.0	2019-12-31 09:36:44.026	debug	(6841) Redis States: Use Redis connection: 127.0.0.1:9000
                  heatingcontrol.0	2019-12-31 09:36:44.024	debug	(6841) objectDB connected
                  heatingcontrol.0	2019-12-31 09:36:44.015	debug	(6841) Objects client initialize lua scripts
                  heatingcontrol.0	2019-12-31 09:36:44.014	debug	(6841) Objects create PubSub Client
                  heatingcontrol.0	2019-12-31 09:36:44.012	debug	(6841) Objects client ready ... initialize now
                  heatingcontrol.0	2019-12-31 09:36:43.992	debug	(6841) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  heatingcontrol.0	2019-12-31 09:36:41.084	info	(4045) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  heatingcontrol.0	2019-12-31 09:36:41.084	info	(4045) terminating
                  heatingcontrol.0	2019-12-31 09:36:41.084	debug	(4045) cron job stopped
                  • M martinschm
                    @Rene_HM said in Test Adapter HeatingControl v0.3.x:
                    @martinschm bzgl. des logs mit dem Fenstersensor.
                    Eigentlich sieht das log wie erwartet aus:
                    • um 23:08:13 wird erkannt, dass ein Fenster offen ist
                    • um 23:08:30 wird erkannt, dass alle 4 Fenster wieder zu sind
                    Trotzdem läuft er in beiden Fällen in den Abwesenheits-Zweig, was im ersten Fall nicht sein sollte. Im ersten Fall sollte er in den FensterAuf-Modus laufen... Deshalb folgende Fragen:
                    • welche Absenkung fährst du (relative oder absolut)?
                    • ist das Verhalten anders, wenn du mihome.0.devices.magnet_158d0001de8c5e öffnest? Das ist der letzte Sensor, der für den Raum geprüft wird...
                    • wird im Datenpunkt heatingcontrol.0.Rooms.Schlafzimmer.WindowIsOpen angezeigt, dass ein Fenster offen ist?
                    • SensorDelay verwendest du nicht?
                    ich verwende
                    • absolute Absenkung.
                    • SensorDelay ist 0
                    • WindowisOpen wird angezeigt als true
                    • der magnet_158d0001de8c5e ist der SZ Mitte, Log hab ich unten angehängt. Funktioniert leider auch nicht.
                    2019-12-30 19:43:48.075  - info: heatingcontrol.0 (8950) Schlafzimmer window open on SZ Mitte
                    2019-12-30 19:43:48.076  - debug: heatingcontrol.0 (8950) room to check is Schlafzimmer
                    2019-12-30 19:43:48.077  - info: heatingcontrol.0 (8950) calculating new target temperatures
                    2019-12-30 19:43:48.077  - debug: heatingcontrol.0 (8950) ### 222 not handled yet
                    2019-12-30 19:43:48.077  - debug: heatingcontrol.0 (8950) ### not handled mihome.0.devices.magnet_158d0001de8c5e.state {"val":true,"ack":true,"ts":1577731428070,"q":0,"from":"system.adapter.mihome.0","user":"system.user.admin","lc":1577731428070}
                    2019-12-30 19:43:48.080  - debug: heatingcontrol.0 (8950) profile type 2
                    2019-12-30 19:43:48.080  - debug: heatingcontrol.0 (8950) get profile
                    2019-12-30 19:43:48.081  - debug: heatingcontrol.0 (8950) profile 0
                    2019-12-30 19:43:48.081  - debug: heatingcontrol.0 (8950) check room Schlafzimmer
                    2019-12-30 19:43:48.081  - debug: heatingcontrol.0 (8950) VacationAbsentDecrease {"val":0,"ack":true,"ts":1576691313966,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1576691313966}
                    2019-12-30 19:43:48.082  - debug: heatingcontrol.0 (8950) number of periods  4
                    2019-12-30 19:43:48.082  - debug: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.0.time
                    2019-12-30 19:43:48.083  - debug: heatingcontrol.0 (8950) check time for Schlafzimmer Profiles.0.Schlafzimmer.Sa-So.Periods.0.time 19
                    2019-12-30 19:43:48.083  - debug: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.1.time
                    2019-12-30 19:43:48.083  - debug: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.2.time
                    2019-12-30 19:43:48.084  - debug: heatingcontrol.0 (8950) check ID Profiles.0.Schlafzimmer.Sa-So.Periods.3.time
                    2019-12-30 19:43:48.084  - debug: heatingcontrol.0 (8950) ### current > 1 0 2
                    2019-12-30 19:43:48.085  - debug: heatingcontrol.0 (8950) ### new target temp19
                    2019-12-30 19:43:48.085  - info: heatingcontrol.0 (8950) room Schlafzimmer Thermostat HM-CC-RT-DN OEQ1733333 set to 19
                    2019-12-30 19:43:48.085  - debug: heatingcontrol.0 (8950) thermostat hm-rpc.0.OEQ1733333.4.SET_TEMPERATURE nothing to do, already 19
                    2019-12-30 19:43:48.089  - warn: heatingcontrol.0 (8950) HandleActorsGeneral: not implemented yet
                    2019-12-30 19:43:48.090  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 31 Dec 2019 09:00:00
                    2019-12-30 19:43:48.091  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 30 Dec 2019 21:00:00
                    2019-12-30 19:43:48.092  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 30 Dec 2019 21:15:00
                    2019-12-30 19:43:48.094  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 30 Dec 2019 21:30:00
                    2019-12-30 19:43:48.095  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 09:00:00
                    2019-12-30 19:43:48.096  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 21:00:00
                    2019-12-30 19:43:48.101  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 21:15:00
                    2019-12-30 19:43:48.103  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 21:30:00
                    2019-12-30 19:43:48.104  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 31 Dec 2019 08:00:00
                    2019-12-30 19:43:48.106  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 31 Dec 2019 14:20:00
                    2019-12-30 19:43:48.107  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 31 Dec 2019 18:00:00
                    2019-12-30 19:43:48.108  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 08:00:00
                    2019-12-30 19:43:48.109  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 18:00:00
                    2019-12-30 19:43:48.112  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 18:30:00
                    2019-12-30 19:43:48.113  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 19:00:00
                    2019-12-30 19:43:48.114  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 31 Dec 2019 00:00:00
                    2019-12-30 19:43:48.115  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 31 Dec 2019 12:00:00
                    2019-12-30 19:43:48.116  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event: 31 Dec 2019 16:00:00
                    2019-12-30 19:43:48.117  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 05:00:00
                    2019-12-30 19:43:48.117  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 12:00:00
                    2019-12-30 19:43:48.119  - debug: heatingcontrol.0 (8950) [INFO]       status = true next event:  4 Jan 2020 16:00:00
                    2019-12-30 19:44:08.370  - debug: heatingcontrol.0 (8950) ### handle state change hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE {"val":20.9,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577731448369}
                    2019-12-30 19:44:08.370  - debug: heatingcontrol.0 (8950) ### hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE mihome.0.devices.magnet_158d0001de8c5e.state 20.9 true
                    2019-12-30 19:44:08.371  - debug: heatingcontrol.0 (8950) ### handle state change hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE {"val":16,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577705436500}
                    2019-12-30 19:44:08.371  - debug: heatingcontrol.0 (8950) ### hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE 16 20.9
                    2019-12-30 19:44:08.371  - debug: heatingcontrol.0 (8950) ### 111 not handled yet
                    2019-12-30 19:44:08.371  - debug: heatingcontrol.0 (8950) handle id hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE state {"val":20.9,"ack":true,"ts":1577731448369,"q":0,"from":"system.adapter.hm-rpc.0","user":"system.user.admin","lc":1577731448369}
                    2019-12-30 19:44:08.371  - debug: heatingcontrol.0 (8950) ### handle devices  [{"id":12,"name":"HM-CC-RT-DN OEQ1711111","OID_Current":"hm-rpc.0.OEQ1711111.4.ACTUAL_TEMPERATURE","OID_Target":"hm-rpc.0.OEQ1711111.4.SET_TEMPERATURE","isActive":true,"type":1,"room":"Kinderschlafzimmer"}]
                    Die Absenkung scheint auch in den anderen Räumen nicht zu funktionieren. Habe es grade mal in einem anderen Zimmer versucht.
                    martinschm
                    #711
                    @martinschm said in Test Adapter HeatingControl v0.3.x:
                    ich verwende
                    • SensorDelay ist 0
                    @Rene_HM kannst du hier auch nochmal kurz schauen, ist evtl untergegangen. Leider funktioniert grade gar keine Absenkung bei Fenster offen
                      Rene_HMR Offline
                      Rene_HMR Offline
                      Rene_HM
                      #712
                      Das bekommen wir schon hin...
                      Zuerst müssen wir das hier beseitigen:
                      Ich denke, du hast irgendeinen Aktor falsch konfiguriert. Erste Frage: benötigst du überhaupt Aktoren? Aktoren sind eigentlich ein Sonderfall hier... Wenn nicht, dann schalte UseActors im admin aus...
                      • M martinschm
                        ich verwende
                        • SensorDelay ist 0
                        Rene_HMR Offline
                        Rene_HMR Offline
                        Rene_HM
                        #713
                        @martinschm sagte in Test Adapter HeatingControl v0.3.x:
                        nein, das habe ich noch auf dem Schirm. Ich verstehe hier leider nur noch nicht, was hier schief läuft. Da bin ich noch am suchen...
                        Welche Version vom adapter läuft eigentlich bei dir?
                        • Rene_HMR Rene_HM
                          moppel2810M Offline
                          moppel2810M Offline
                          moppel2810
                          #714
                          @Rene_HM so jetzt sieht der debug nach Neustart so aus.
                          heatingcontrol.0	2019-12-31 11:19:45.513	debug	(4204) #subscribtion finished
                          heatingcontrol.0	2019-12-31 11:19:45.513	info	(4204) subscribe Küche deconz.0.Sensors.24.open
                          heatingcontrol.0	2019-12-31 11:19:45.512	info	(4204) subscribe Küche hm-rpc.1.0007D5699E9605.1.STATE
                          heatingcontrol.0	2019-12-31 11:19:45.512	info	(4204) subscribe Wohnzimmer deconz.0.Sensors.21.open
                          heatingcontrol.0	2019-12-31 11:19:45.511	info	(4204) subscribe Wohnzimmer deconz.0.Sensors.20.open
                          heatingcontrol.0	2019-12-31 11:19:45.511	info	(4204) subscribe Wohnzimmer deconz.0.Sensors.19.open
                          heatingcontrol.0	2019-12-31 11:19:45.510	info	(4204) subscribe Wohnzimmer deconz.0.Sensors.18.open
                          heatingcontrol.0	2019-12-31 11:19:45.510	info	(4204) subscribe Wohnzimmer deconz.0.Sensors.17.open
                          heatingcontrol.0	2019-12-31 11:19:45.509	info	(4204) subscribe Wohnzimmer deconz.0.Sensors.16.open
                          heatingcontrol.0	2019-12-31 11:19:45.509	info	(4204) subscribe Wohnzimmer deconz.0.Sensors.15.open
                          heatingcontrol.0	2019-12-31 11:19:45.508	info	(4204) subscribe Badezimmer hm-rpc.1.0000D56996187D.1.STATE
                          heatingcontrol.0	2019-12-31 11:19:45.507	info	(4204) subscribe Arbeitszimmer deconz.0.Sensors.23.open
                          heatingcontrol.0	2019-12-31 11:19:45.507	info	(4204) subscribe Arbeitszimmer deconz.0.Sensors.11.open
                          heatingcontrol.0	2019-12-31 11:19:45.507	debug	(4204) device not active
                          heatingcontrol.0	2019-12-31 11:19:45.506	debug	(4204) no subscribe Path2PartyNowDP
                          heatingcontrol.0	2019-12-31 11:19:45.506	debug	(4204) no subscribe Path2GuestsPresentDP
                          heatingcontrol.0	2019-12-31 11:19:45.506	debug	(4204) no subscribe Path2HolidayPresentDP
                          heatingcontrol.0	2019-12-31 11:19:45.506	debug	(4204) no subscribe Path2VacationDP
                          heatingcontrol.0	2019-12-31 11:19:45.506	info	(4204) subscribe javascript.0.scriptEnabled.Anwesenheit.An_Abwesenheit
                          heatingcontrol.0	2019-12-31 11:19:45.505	info	(4204) subscribe feiertage.0.heute.boolean
                          heatingcontrol.0	2019-12-31 11:19:45.498	debug	(4204) #start subscribtion
                          heatingcontrol.0	2019-12-31 11:19:45.497	debug	(4204) [INFO] status = true next event: 4 Jan 2020 20:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.477	debug	(4204) [INFO] status = true next event: 4 Jan 2020 15:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.476	debug	(4204) [INFO] status = true next event: 4 Jan 2020 11:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.475	debug	(4204) [INFO] status = true next event: 4 Jan 2020 07:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.472	debug	(4204) [INFO] status = true next event: 4 Jan 2020 04:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.470	debug	(4204) [INFO] status = true next event: 31 Dec 2019 20:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.469	debug	(4204) [INFO] status = true next event: 31 Dec 2019 15:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.469	debug	(4204) [INFO] status = true next event: 31 Dec 2019 11:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.468	debug	(4204) [INFO] status = true next event: 1 Jan 2020 07:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.465	debug	(4204) [INFO] status = true next event: 1 Jan 2020 04:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.448	debug	(4204) thermostat hm-rpc.1.000A97099C1E52.1.SET_POINT_TEMPERATURE nothing to do, already 21
                          heatingcontrol.0	2019-12-31 11:19:45.440	info	(4204) room Wohnzimmer Thermostat Fußbodenheizung Wohnzimmer.SET_POINT_TEMPERATURE target is 21
                          heatingcontrol.0	2019-12-31 11:19:45.440	debug	(4204) ### new target temp21
                          heatingcontrol.0	2019-12-31 11:19:45.440	debug	(4204) ### current > 1 1 2
                          heatingcontrol.0	2019-12-31 11:19:45.439	debug	(4204) Wohnzimmer found period 1 with 21 on 08,00
                          heatingcontrol.0	2019-12-31 11:19:45.437	debug	(4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.4.time
                          heatingcontrol.0	2019-12-31 11:19:45.432	debug	(4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.3.time
                          heatingcontrol.0	2019-12-31 11:19:45.427	debug	(4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.2.time
                          heatingcontrol.0	2019-12-31 11:19:45.427	debug	(4204) check time for Wohnzimmer Profiles.0.Wohnzimmer.Sa-So.Periods.1.time 21
                          heatingcontrol.0	2019-12-31 11:19:45.421	debug	(4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.1.time
                          heatingcontrol.0	2019-12-31 11:19:45.421	debug	(4204) check time for Wohnzimmer Profiles.0.Wohnzimmer.Sa-So.Periods.0.time 17
                          heatingcontrol.0	2019-12-31 11:19:45.417	debug	(4204) check ID Profiles.0.Wohnzimmer.Sa-So.Periods.0.time
                          heatingcontrol.0	2019-12-31 11:19:45.416	debug	(4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Wohnzimmer
                          heatingcontrol.0	2019-12-31 11:19:45.415	debug	(4204) check room Wohnzimmer
                          heatingcontrol.0	2019-12-31 11:19:45.363	debug	(4204) thermostat hm-rpc.1.000A17098D4CEA.1.SET_POINT_TEMPERATURE nothing to do, already 21
                          heatingcontrol.0	2019-12-31 11:19:45.359	info	(4204) room Küche Thermostat Heizung Küche.SET_POINT_TEMPERATURE target is 21
                          heatingcontrol.0	2019-12-31 11:19:45.358	debug	(4204) ### new target temp21
                          heatingcontrol.0	2019-12-31 11:19:45.358	debug	(4204) ### current > 1 1 2
                          heatingcontrol.0	2019-12-31 11:19:45.358	debug	(4204) Küche found period 1 with 21 on 08,00
                          heatingcontrol.0	2019-12-31 11:19:45.356	debug	(4204) check ID Profiles.0.Küche.Sa-So.Periods.4.time
                          heatingcontrol.0	2019-12-31 11:19:45.355	debug	(4204) check ID Profiles.0.Küche.Sa-So.Periods.3.time
                          heatingcontrol.0	2019-12-31 11:19:45.352	debug	(4204) check ID Profiles.0.Küche.Sa-So.Periods.2.time
                          heatingcontrol.0	2019-12-31 11:19:45.352	debug	(4204) check time for Küche Profiles.0.Küche.Sa-So.Periods.1.time 21
                          heatingcontrol.0	2019-12-31 11:19:45.340	debug	(4204) check ID Profiles.0.Küche.Sa-So.Periods.1.time
                          heatingcontrol.0	2019-12-31 11:19:45.340	debug	(4204) check time for Küche Profiles.0.Küche.Sa-So.Periods.0.time 17
                          heatingcontrol.0	2019-12-31 11:19:45.335	debug	(4204) check ID Profiles.0.Küche.Sa-So.Periods.0.time
                          heatingcontrol.0	2019-12-31 11:19:45.335	debug	(4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Küche
                          heatingcontrol.0	2019-12-31 11:19:45.334	debug	(4204) check room Küche
                          heatingcontrol.0	2019-12-31 10:19:45.287	debug	2
                          heatingcontrol.0	2019-12-31 10:19:45.287	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.4.time
                          heatingcontrol.0	2019-12-31 10:19:45.283	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.3.time
                          heatingcontrol.0	2019-12-31 10:19:45.281	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.2.time
                          heatingcontrol.0	2019-12-31 10:19:45.280	debug	(4204) check time for Arbeitszimmer Profiles.0.Arbeitszimmer.Sa-So.Periods.1.time 21
                          heatingcontrol.0	2019-12-31 10:19:45.278	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.1.time
                          heatingcontrol.0	2019-12-31 10:19:45.276	debug	(4204) check time for Arbeitszimmer Profiles.0.Arbeitszimmer.Sa-So.Periods.0.time 17
                          heatingcontrol.0	2019-12-31 10:19:45.269	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.0.time
                          heatingcontrol.0	2019-12-31 10:19:45.269	debug	(4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Arbeitszimmer
                          heatingcontrol.0	2019-12-31 10:19:45.262	debug	(4204) check room Arbeitszimmer
                          heatingcontrol.0	2019-12-31 10:19:45.262	debug	(4204) profile 0
                          heatingcontrol.0	2019-12-31 10:19:45.260	debug	(4204) get profile
                          heatingcontrol.0	2019-12-31 10:19:45.260	debug	(4204) profile type 2
                          heatingcontrol.0	2019-12-31 10:19:45.252	info	(4204) calculating new target temperatures
                          heatingcontrol.0	2019-12-31 10:19:45.251	info	(4204) external states checked, done
                          heatingcontrol.0	2019-12-31 10:19:45.249	debug	(4204) checking Path2HolidayPresentDP
                          heatingcontrol.0	2019-12-31 10:19:45.248	debug	(4204) checking Path2PartyNowDP
                          heatingcontrol.0	2019-12-31 10:19:45.245	debug	(4204) checking Path2GuestsPresentDP
                          heatingcontrol.0	2019-12-31 10:19:45.244	debug	(4204) checking Path2VacationDP
                          heatingcontrol.0	2019-12-31 10:19:45.240	info	(4204) setting Present to true
                          heatingcontrol.0	2019-12-31 10:19:45.239	debug	(4204) got Present (1) {"val":true,"ack":true,"ts":1577726419908,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577726419858}
                          heatingcontrol.0	2019-12-31 10:19:45.237	debug	(4204) checking Path2PresentDP
                          heatingcontrol.0	2019-12-31 10:19:45.232	info	(4204) setting PublicHolidyToday to true
                          heatingcontrol.0	2019-12-31 10:19:45.229	debug	(4204) checking Path2FeiertagAdapter
                          heatingcontrol.0	2019-12-31 10:19:45.228	info	(4204) checking all external states
                          heatingcontrol.0	2019-12-31 10:19:45.223	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933362844} from deconz.0.Sensors.21.open
                          heatingcontrol.0	2019-12-31 10:19:45.220	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577638441163} from deconz.0.Sensors.20.open
                          heatingcontrol.0	2019-12-31 10:19:45.217	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933207327} from deconz.0.Sensors.19.open
                          heatingcontrol.0	2019-12-31 10:19:45.210	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574987,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933122635} from deconz.0.Sensors.18.open
                          heatingcontrol.0	2019-12-31 10:19:45.209	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933025797} from deconz.0.Sensors.17.open
                          heatingcontrol.0	2019-12-31 10:19:45.205	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576932905933} from deconz.0.Sensors.16.open
                          heatingcontrol.0	2019-12-31 10:19:45.203	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577007719646} from deconz.0.Sensors.15.open
                          heatingcontrol.0	2019-12-31 10:19:45.201	debug	(4204) Check sensors for Wohnzimmer
                          heatingcontrol.0	2019-12-31 10:19:45.196	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577644284922} from deconz.0.Sensors.24.open
                          heatingcontrol.0	2019-12-31 10:19:45.195	debug	(4204) got sensor state {"val":0,"ack":true,"ts":1577786742689,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577786742689} from hm-rpc.1.0007D5699E9605.1.STATE
                          heatingcontrol.0	2019-12-31 10:19:45.192	debug	(4204) Check sensors for Küche
                          heatingcontrol.0	2019-12-31 10:19:45.186	debug	(4204) got sensor state {"val":0,"ack":true,"ts":1577785259127,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577628013202} from hm-rpc.1.0000D56996187D.1.STATE
                          heatingcontrol.0	2019-12-31 10:19:45.184	debug	(4204) Check sensors for Badezimmer
                          heatingcontrol.0	2019-12-31 10:19:45.179	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577705276875} from deconz.0.Sensors.23.open
                          heatingcontrol.0	2019-12-31 10:19:45.176	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576925832752} from deconz.0.Sensors.11.open
                          heatingcontrol.0	2019-12-31 10:19:45.157	debug	(4204) Check sensors for Arbeitszimmer
                          heatingcontrol.0	2019-12-31 10:19:45.156	debug	(4204) [INFO] status = true next event: 4 Jan 2020 20:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.155	debug	(4204) [INFO] status = true next event: 4 Jan 2020 15:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.154	debug	(4204) [INFO] status = true next event: 4 Jan 2020 11:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.153	debug	(4204) [INFO] status = true next event: 4 Jan 2020 07:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.152	debug	(4204) [INFO] status = true next event: 4 Jan 2020 04:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.151	debug	(4204) [INFO] status = true next event: 31 Dec 2019 20:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.151	debug	(4204) [INFO] status = true next event: 31 Dec 2019 15:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.150	debug	(4204) [INFO] status = true next event: 31 Dec 2019 11:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.150	debug	(4204) [INFO] status = true next event: 1 Jan 2020 07:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.147	debug	(4204) [INFO] status = true next event: 1 Jan 2020 04:00:00
                          heatingcontrol.0	2019-12-31 10:19:45.134	debug	(4204) create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.132	debug	(4204) create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.129	debug	(4204) create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.127	debug	(4204) create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.120	debug	(4204) create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.117	debug	(4204) create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.115	debug	(4204) create cron job #3 at 16:0 string: 0 0 16 * * 1-5 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.110	debug	(4204) create cron job #2 at 12:0 string: 0 0 12 * * 1-5 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.099	debug	(4204) create cron job #1 at 8:0 string: 0 0 8 * * 1-5 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.078	debug	(4204) create cron job #0 at 5:0 string: 0 0 5 * * 1-5 Europe/Berlin
                          heatingcontrol.0	2019-12-31 10:19:45.078	debug	(4204) ---2 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
                          heatingcontrol.0	2019-12-31 10:19:45.075	debug	(4204) ---2 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
                          heatingcontrol.0	2019-12-31 10:19:45.072	debug	(4204) ---2 found time for Wohnzimmer at {"val":"12:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 12:00
                          heatingcontrol.0	2019-12-31 10:19:45.070	debug	(4204) ---2 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00
                          heatingcontrol.0	2019-12-31 10:19:45.067	debug	(4204) ---2 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00
                          heatingcontrol.0	2019-12-31 10:19:45.062	debug	(4204) setting Sa - Su
                          heatingcontrol.0	2019-12-31 10:19:45.062	debug	(4204) ---1 found time for Wohnzimmer at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
                          heatingcontrol.0	2019-12-31 10:19:45.060	debug	(4204) ---1 found time for Wohnzimmer at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
                          heatingcontrol.0	2019-12-31 10:19:45.059	debug	(4204) ---1 found time for Wohnzimmer at {"val":"12:00","ack":false,"ts":1577542409214,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1577542409214} 12:00
                          heatingcontrol.0	2019-12-31 10:19:45.057	debug	(4204) ---1 found time for Wohnzimmer at {"val":"08:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 08:00
                          heatingcontrol.0	2019-12-31 10:19:45.055	debug	(4204) ---1 found time for Wohnzimmer at {"val":"05:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 05:00
                          heatingcontrol.0	2019-12-31 10:19:45.052	debug	(4204) setting Mo - Fr
                          heatingcontrol.0	2019-12-31 10:19:45.051	debug	(4204) ---2 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 21:00
                          heatingcontrol.0	2019-12-31 10:19:45.049	debug	(4204) ---2 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276535,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276535} 16:00
                          heatingcontrol.0	2019-12-31 10:19:45.047	debug	(4204) ---2 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                          heatingcontrol.0	2019-12-31 10:19:45.036	debug	(4204) ---2 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                          heatingcontrol.0	2019-12-31 10:19:45.031	debug	(4204) ---2 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                          heatingcontrol.0	2019-12-31 10:19:45.028	debug	(4204) setting Sa - Su
                          heatingcontrol.0	2019-12-31 10:19:45.028	debug	(4204) ---1 found time for Küche at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                          heatingcontrol.0	2019-12-31 10:19:45.021	debug	(4204) ---1 found time for Küche at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                          heatingcontrol.0	2019-12-31 10:19:45.019	debug	(4204) ---1 found time for Küche at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                          heatingcontrol.0	2019-12-31 10:19:45.018	debug	(4204) ---1 found time for Küche at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                          heatingcontrol.0	2019-12-31 10:19:45.017	debug	(4204) ---1 found time for Küche at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                          heatingcontrol.0	2019-12-31 10:19:45.011	debug	(4204) setting Mo - Fr
                          heatingcontrol.0	2019-12-31 10:19:45.011	debug	(4204) ---2 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                          heatingcontrol.0	2019-12-31 10:19:45.010	debug	(4204) ---2 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                          heatingcontrol.0	2019-12-31 10:19:45.009	debug	(4204) ---2 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                          heatingcontrol.0	2019-12-31 10:19:45.007	debug	(4204) ---2 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                          heatingcontrol.0	2019-12-31 10:19:45.004	debug	(4204) ---2 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                          heatingcontrol.0	2019-12-31 10:19:44.996	debug	(4204) setting Sa - Su
                          heatingcontrol.0	2019-12-31 10:19:44.996	debug	(4204) ---1 found time for Badezimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                          heatingcontrol.0	2019-12-31 10:19:44.993	debug	(4204) ---1 found time for Badezimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                          heatingcontrol.0	2019-12-31 10:19:44.988	debug	(4204) ---1 found time for Badezimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                          heatingcontrol.0	2019-12-31 10:19:44.987	debug	(4204) ---1 found time for Badezimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                          heatingcontrol.0	2019-12-31 10:19:44.986	debug	(4204) ---1 found time for Badezimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                          heatingcontrol.0	2019-12-31 10:19:44.985	debug	(4204) setting Mo - Fr
                          heatingcontrol.0	2019-12-31 10:19:44.985	debug	(4204) push to list = 21,00
                          heatingcontrol.0	2019-12-31 10:19:44.985	debug	(4204) ---2 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                          heatingcontrol.0	2019-12-31 10:19:44.983	debug	(4204) push to list = 16,00
                          heatingcontrol.0	2019-12-31 10:19:44.982	debug	(4204) ---2 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                          heatingcontrol.0	2019-12-31 10:19:44.974	debug	(4204) push to list = 12,00
                          heatingcontrol.0	2019-12-31 10:19:44.974	debug	(4204) ---2 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                          heatingcontrol.0	2019-12-31 10:19:44.963	debug	(4204) push to list = 08,00
                          heatingcontrol.0	2019-12-31 10:19:44.962	debug	(4204) ---2 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                          heatingcontrol.0	2019-12-31 10:19:44.943	debug	(4204) push to list = 05,00
                          heatingcontrol.0	2019-12-31 10:19:44.943	debug	(4204) ---2 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                          heatingcontrol.0	2019-12-31 10:19:44.942	debug	(4204) setting Sa - Su
                          heatingcontrol.0	2019-12-31 10:19:44.942	debug	(4204) push to list = 21,00
                          heatingcontrol.0	2019-12-31 10:19:44.942	debug	(4204) ---1 found time for Arbeitszimmer at {"val":"21:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 21:00
                          heatingcontrol.0	2019-12-31 10:19:44.941	debug	(4204) push to list = 16,00
                          heatingcontrol.0	2019-12-31 10:19:44.940	debug	(4204) ---1 found time for Arbeitszimmer at {"val":"16:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 16:00
                          heatingcontrol.0	2019-12-31 10:19:44.932	debug	(4204) push to list = 12,00
                          heatingcontrol.0	2019-12-31 10:19:44.931	debug	(4204) ---1 found time for Arbeitszimmer at {"val":"12:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 12:00
                          heatingcontrol.0	2019-12-31 10:19:44.930	debug	(4204) push to list = 08,00
                          heatingcontrol.0	2019-12-31 10:19:44.930	debug	(4204) ---1 found time for Arbeitszimmer at {"val":"08:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 08:00
                          heatingcontrol.0	2019-12-31 10:19:44.921	debug	(4204) push to list = 05,00
                          heatingcontrol.0	2019-12-31 10:19:44.920	debug	(4204) ---1 found time for Arbeitszimmer at {"val":"05:00","ack":true,"ts":1577378276534,"q":0,"from":"system.adapter.heatingcontrol.0","user":"system.user.admin","lc":1577378276534} 05:00
                          heatingcontrol.0	2019-12-31 10:19:44.919	debug	(4204) setting Mo - Fr
                          heatingcontrol.0	2019-12-31 10:19:44.919	debug	(4204) profile 0
                          heatingcontrol.0	2019-12-31 10:19:44.909	debug	(4204) get profile
                          heatingcontrol.0	2019-12-31 10:19:44.909	debug	(4204) start CalculateNextTime, profile type 2
                          heatingcontrol.0	2019-12-31 10:19:44.908	debug	(4204) system date format DD.MM.YYYY
                          heatingcontrol.0	2019-12-31 10:19:44.885	debug	(4204) CreateDatepoints done
                          heatingcontrol.0	2019-12-31 10:19:44.885	debug	(4204) not active.... Kinderzimmer
                          heatingcontrol.0	2019-12-31 10:19:44.885	debug	(4204) not active.... Schlafzimmer
                          heatingcontrol.0	2019-12-31 10:19:44.885	debug	(4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.4 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.885	debug	(4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.3 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.885	debug	(4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.2 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.885	debug	(4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.1 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.884	debug	(4204) add state Profiles.0.Wohnzimmer.Sa-So.Periods.0 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.884	debug	(4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.4 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.884	debug	(4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.3 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.884	debug	(4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.2 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.884	debug	(4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.1 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.883	debug	(4204) add state Profiles.0.Wohnzimmer.Mo-Fr.Periods.0 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.883	debug	(4204) Profile Type Mo-FR + Sa-So, profiles 1
                          heatingcontrol.0	2019-12-31 10:19:44.883	debug	(4204) room Wohnzimmer with 5 periods
                          heatingcontrol.0	2019-12-31 10:19:44.673	debug	(4204) create data profile points (absolute) for Wohnzimmer
                          heatingcontrol.0	2019-12-31 10:19:44.670	debug	(4204) add state Profiles.0.Küche.Sa-So.Periods.4 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.670	debug	(4204) add state Profiles.0.Küche.Sa-So.Periods.3 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.670	debug	(4204) add state Profiles.0.Küche.Sa-So.Periods.2 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.670	debug	(4204) add state Profiles.0.Küche.Sa-So.Periods.1 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.670	debug	(4204) add state Profiles.0.Küche.Sa-So.Periods.0 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.670	debug	(4204) add state Profiles.0.Küche.Mo-Fr.Periods.4 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.669	debug	(4204) add state Profiles.0.Küche.Mo-Fr.Periods.3 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.667	debug	(4204) add state Profiles.0.Küche.Mo-Fr.Periods.2 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.667	debug	(4204) add state Profiles.0.Küche.Mo-Fr.Periods.1 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.665	debug	(4204) add state Profiles.0.Küche.Mo-Fr.Periods.0 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.665	debug	(4204) Profile Type Mo-FR + Sa-So, profiles 1
                          heatingcontrol.0	2019-12-31 10:19:44.665	debug	(4204) room Küche with 5 periods
                          heatingcontrol.0	2019-12-31 10:19:44.475	debug	(4204) create data profile points (absolute) for Küche
                          heatingcontrol.0	2019-12-31 10:19:44.475	debug	(4204) add state Profiles.0.Badezimmer.Sa-So.Periods.4 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.475	debug	(4204) add state Profiles.0.Badezimmer.Sa-So.Periods.3 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.475	debug	(4204) add state Profiles.0.Badezimmer.Sa-So.Periods.2 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.475	debug	(4204) add state Profiles.0.Badezimmer.Sa-So.Periods.1 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.475	debug	(4204) add state Profiles.0.Badezimmer.Sa-So.Periods.0 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.474	debug	(4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.4 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.474	debug	(4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.3 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.474	debug	(4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.2 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.474	debug	(4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.1 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.474	debug	(4204) add state Profiles.0.Badezimmer.Mo-Fr.Periods.0 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.474	debug	(4204) Profile Type Mo-FR + Sa-So, profiles 1
                          heatingcontrol.0	2019-12-31 10:19:44.473	debug	(4204) room Badezimmer with 5 periods
                          heatingcontrol.0	2019-12-31 10:19:44.332	debug	(4204) create data profile points (absolute) for Badezimmer
                          heatingcontrol.0	2019-12-31 10:19:44.331	debug	(4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.4 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.331	debug	(4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.3 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.331	debug	(4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.2 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.331	debug	(4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.1 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.331	debug	(4204) add state Profiles.0.Arbeitszimmer.Sa-So.Periods.0 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.331	debug	(4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.4 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.331	debug	(4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.3 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.330	debug	(4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.2 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.330	debug	(4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.1 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.330	debug	(4204) add state Profiles.0.Arbeitszimmer.Mo-Fr.Periods.0 max 5
                          heatingcontrol.0	2019-12-31 10:19:44.330	debug	(4204) Profile Type Mo-FR + Sa-So, profiles 1
                          heatingcontrol.0	2019-12-31 10:19:44.329	debug	(4204) room Arbeitszimmer with 5 periods
                          heatingcontrol.0	2019-12-31 10:19:44.278	debug	(4204) create data profile points (absolute) for Arbeitszimmer
                          heatingcontrol.0	2019-12-31 10:19:44.278	debug	(4204) rooms 6
                          heatingcontrol.0	2019-12-31 10:19:44.263	debug	(4204) create data points for Wohnzimmer
                          heatingcontrol.0	2019-12-31 10:19:44.252	debug	(4204) create data points for Küche
                          heatingcontrol.0	2019-12-31 10:19:44.248	debug	(4204) create data points for Badezimmer
                          heatingcontrol.0	2019-12-31 10:19:44.226	debug	(4204) create data points for Arbeitszimmer
                          heatingcontrol.0	2019-12-31 10:19:43.903	debug	(4204) start CreateDatepoints
                          heatingcontrol.0	2019-12-31 11:19:45.322	debug	(4204) thermostat hm-rpc.1.000A17098D4EAA.1.SET_POINT_TEMPERATURE nothing to do, already 23
                          heatingcontrol.0	2019-12-31 11:19:45.321	info	(4204) room Badezimmer Thermostat Heizung Bad.SET_POINT_TEMPERATURE target is 23
                          heatingcontrol.0	2019-12-31 11:19:45.321	debug	(4204) thermostat hm-rpc.1.000A97099C1E2C.1.SET_POINT_TEMPERATURE nothing to do, already 23
                          heatingcontrol.0	2019-12-31 11:19:45.318	info	(4204) room Badezimmer Thermostat Fußbodenheizung Bad.SET_POINT_TEMPERATURE target is 23
                          heatingcontrol.0	2019-12-31 11:19:45.318	debug	(4204) ### new target temp23
                          heatingcontrol.0	2019-12-31 11:19:45.318	debug	(4204) ### current > 1 1 2
                          heatingcontrol.0	2019-12-31 11:19:45.318	debug	(4204) Badezimmer found period 1 with 23 on 08,00
                          heatingcontrol.0	2019-12-31 11:19:45.316	debug	(4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.4.time
                          heatingcontrol.0	2019-12-31 11:19:45.314	debug	(4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.3.time
                          heatingcontrol.0	2019-12-31 11:19:45.311	debug	(4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.2.time
                          heatingcontrol.0	2019-12-31 11:19:45.311	debug	(4204) check time for Badezimmer Profiles.0.Badezimmer.Sa-So.Periods.1.time 23
                          heatingcontrol.0	2019-12-31 11:19:45.310	debug	(4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.1.time
                          heatingcontrol.0	2019-12-31 11:19:45.310	debug	(4204) check time for Badezimmer Profiles.0.Badezimmer.Sa-So.Periods.0.time 19
                          heatingcontrol.0	2019-12-31 11:19:45.307	debug	(4204) check ID Profiles.0.Badezimmer.Sa-So.Periods.0.time
                          heatingcontrol.0	2019-12-31 11:19:45.307	debug	(4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Badezimmer
                          heatingcontrol.0	2019-12-31 11:19:45.306	debug	(4204) check room Badezimmer
                          heatingcontrol.0	2019-12-31 11:19:45.297	debug	(4204) thermostat hm-rpc.1.000A1709ACCE17.1.SET_POINT_TEMPERATURE nothing to do, already 21
                          heatingcontrol.0	2019-12-31 11:19:45.291	info	(4204) room Arbeitszimmer Thermostat Heizung Arbeitszimmer.SET_POINT_TEMPERATURE target is 21
                          heatingcontrol.0	2019-12-31 11:19:45.291	debug	(4204) ### new target temp21
                          heatingcontrol.0	2019-12-31 11:19:45.291	debug	(4204) ### current > 1 1 2
                          heatingcontrol.0	2019-12-31 11:19:45.289	debug	(4204) Arbeitszimmer found period 1 with 21 on 08,00
                          heatingcontrol.0	2019-12-31 11:19:45.287	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.4.time
                          heatingcontrol.0	2019-12-31 11:19:45.283	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.3.time
                          heatingcontrol.0	2019-12-31 11:19:45.281	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.2.time
                          heatingcontrol.0	2019-12-31 11:19:45.280	debug	(4204) check time for Arbeitszimmer Profiles.0.Arbeitszimmer.Sa-So.Periods.1.time 21
                          heatingcontrol.0	2019-12-31 11:19:45.278	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.1.time
                          heatingcontrol.0	2019-12-31 11:19:45.276	debug	(4204) check time for Arbeitszimmer Profiles.0.Arbeitszimmer.Sa-So.Periods.0.time 17
                          heatingcontrol.0	2019-12-31 11:19:45.269	debug	(4204) check ID Profiles.0.Arbeitszimmer.Sa-So.Periods.0.time
                          heatingcontrol.0	2019-12-31 11:19:45.269	debug	(4204) FindNextPeriod for 12/31/2019, 10:19:45 AM in Arbeitszimmer
                          heatingcontrol.0	2019-12-31 11:19:45.262	debug	(4204) check room Arbeitszimmer
                          heatingcontrol.0	2019-12-31 11:19:45.262	debug	(4204) profile 0
                          heatingcontrol.0	2019-12-31 11:19:45.260	debug	(4204) get profile
                          heatingcontrol.0	2019-12-31 11:19:45.260	debug	(4204) profile type 2
                          heatingcontrol.0	2019-12-31 11:19:45.252	info	(4204) calculating new target temperatures
                          heatingcontrol.0	2019-12-31 11:19:45.251	info	(4204) external states checked, done
                          heatingcontrol.0	2019-12-31 11:19:45.249	debug	(4204) checking Path2HolidayPresentDP
                          heatingcontrol.0	2019-12-31 11:19:45.248	debug	(4204) checking Path2PartyNowDP
                          heatingcontrol.0	2019-12-31 11:19:45.245	debug	(4204) checking Path2GuestsPresentDP
                          heatingcontrol.0	2019-12-31 11:19:45.244	debug	(4204) checking Path2VacationDP
                          heatingcontrol.0	2019-12-31 11:19:45.240	info	(4204) setting Present to true
                          heatingcontrol.0	2019-12-31 11:19:45.239	debug	(4204) got Present (1) {"val":true,"ack":true,"ts":1577726419908,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1577726419858}
                          heatingcontrol.0	2019-12-31 11:19:45.237	debug	(4204) checking Path2PresentDP
                          heatingcontrol.0	2019-12-31 11:19:45.232	info	(4204) setting PublicHolidyToday to true
                          heatingcontrol.0	2019-12-31 11:19:45.229	debug	(4204) checking Path2FeiertagAdapter
                          heatingcontrol.0	2019-12-31 11:19:45.228	info	(4204) checking all external states
                          heatingcontrol.0	2019-12-31 11:19:45.223	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933362844} from deconz.0.Sensors.21.open
                          heatingcontrol.0	2019-12-31 11:19:45.220	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577638441163} from deconz.0.Sensors.20.open
                          heatingcontrol.0	2019-12-31 11:19:45.217	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574989,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933207327} from deconz.0.Sensors.19.open
                          heatingcontrol.0	2019-12-31 11:19:45.210	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574987,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933122635} from deconz.0.Sensors.18.open
                          heatingcontrol.0	2019-12-31 11:19:45.209	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576933025797} from deconz.0.Sensors.17.open
                          heatingcontrol.0	2019-12-31 11:19:45.205	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576932905933} from deconz.0.Sensors.16.open
                          heatingcontrol.0	2019-12-31 11:19:45.203	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577007719646} from deconz.0.Sensors.15.open
                          heatingcontrol.0	2019-12-31 11:19:45.201	debug	(4204) Check sensors for Wohnzimmer
                          heatingcontrol.0	2019-12-31 11:19:45.196	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577644284922} from deconz.0.Sensors.24.open
                          heatingcontrol.0	2019-12-31 11:19:45.195	debug	(4204) got sensor state {"val":0,"ack":true,"ts":1577786742689,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577786742689} from hm-rpc.1.0007D5699E9605.1.STATE
                          heatingcontrol.0	2019-12-31 11:19:45.192	debug	(4204) Check sensors for Küche
                          heatingcontrol.0	2019-12-31 11:19:45.186	debug	(4204) got sensor state {"val":0,"ack":true,"ts":1577785259127,"q":0,"from":"system.adapter.hm-rpc.1","user":"system.user.admin","lc":1577628013202} from hm-rpc.1.0000D56996187D.1.STATE
                          heatingcontrol.0	2019-12-31 11:19:45.184	debug	(4204) Check sensors for Badezimmer
                          heatingcontrol.0	2019-12-31 11:19:45.179	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574990,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1577705276875} from deconz.0.Sensors.23.open
                          heatingcontrol.0	2019-12-31 11:19:45.176	debug	(4204) got sensor state {"val":false,"ack":true,"ts":1577717574976,"q":0,"from":"system.adapter.deconz.0","user":"system.user.admin","lc":1576925832752} from deconz.0.Sensors.11.open
                          heatingcontrol.0	2019-12-31 11:19:45.157	debug	(4204) Check sensors for Arbeitszimmer
                          heatingcontrol.0	2019-12-31 11:19:45.156	debug	(4204) [INFO] status = true next event: 4 Jan 2020 20:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.155	debug	(4204) [INFO] status = true next event: 4 Jan 2020 15:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.154	debug	(4204) [INFO] status = true next event: 4 Jan 2020 11:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.153	debug	(4204) [INFO] status = true next event: 4 Jan 2020 07:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.152	debug	(4204) [INFO] status = true next event: 4 Jan 2020 04:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.151	debug	(4204) [INFO] status = true next event: 31 Dec 2019 20:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.151	debug	(4204) [INFO] status = true next event: 31 Dec 2019 15:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.150	debug	(4204) [INFO] status = true next event: 31 Dec 2019 11:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.150	debug	(4204) [INFO] status = true next event: 1 Jan 2020 07:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.147	debug	(4204) [INFO] status = true next event: 1 Jan 2020 04:00:00
                          heatingcontrol.0	2019-12-31 11:19:45.134	debug	(4204) create cron job #9 at 21:0 string: 0 0 21 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 11:19:45.132	debug	(4204) create cron job #8 at 16:0 string: 0 0 16 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 11:19:45.129	debug	(4204) create cron job #7 at 12:0 string: 0 0 12 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 11:19:45.127	debug	(4204) create cron job #6 at 8:0 string: 0 0 8 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 11:19:45.120	debug	(4204) create cron job #5 at 5:0 string: 0 0 5 * * 0,6 Europe/Berlin
                          heatingcontrol.0	2019-12-31 11:19:45.117	debug	(4204) create cron job #4 at 21:0 string: 0 0 21 * * 1-5 Europe/Berlin
                          • moppel2810M Offline
                            moppel2810M Offline
                            moppel2810
                            schrieb am zuletzt editiert von moppel2810
                            #715
                            Jetzt siehts aus als wenn alles funktioniert👍 Alle Thermostate reagieren auf die Einstellungen.
                            Oder siehst du da noch was was ich ändern sollte?
                            Rene_HMR 1 Antwort Letzte Antwort
                            • moppel2810M moppel2810
                              Rene_HMR Offline
                              Rene_HMR Offline
                              Rene_HM
                              #716
                              @moppel2810 sieht soweit gut aus...
                              • G guergen
                                @Hobi Nimm das Widget (vis-jqui-mfd muss installiert sein):
                                [{"tpl":"tplJquiInputDatetime","data":{"oid":"heatingcontrol.0.Profiles.0.Bad.Mon.Periods.0.time","g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"timeOnly":true,"hideSeconds":true,"size":"4","class":"","filterkey":"","name":"Mo Zeit bis","locked":false,"g_last_change":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"140px","top":"470px","width":"77px","height":"25px","font-weight":"bold","font-size":"","word-spacing":"","letter-spacing":"","line-height":"","z-index":"10","color":"","border-width":"","border-style":"","border-radius":"4px"},"widgetSet":"jqui"}]
                                Hobi
                                #717
                                @guergen
                                Hallo! Das hatte ich Anfangs genommen - allerdings öffnet der Fully oder auch Chrome auf meinem Tablet dann immer eine Tastatur.
                                Daher habe ich ein System verwendet, dass ich bereits bei meiner Timer-Konfiguration verwendet habe.
                                LG
                                Holger
                                P.S.: Guten Rutsch!
                                • G guergen
                                  Hobi
                                  #718
                                  @guergen
                                  LG
                                  Holger
                                  P.S.: Guten Rutsch!
                                  • Rene_HMR Rene_HM
                                    martinschm
                                    #719
                                    Hi Rene,
                                    frohes neues Jahr.
                                    Bei mir läuft 0.3.9
                                    • M martinschm
                                      Hi Rene,
                                      frohes neues Jahr.
                                      Bei mir läuft 0.3.9
                                      Rene_HMR Offline
                                      Rene_HMR Offline
                                      Rene_HM
                                      #720
                                      @martinschm nimm mal bitte die 0.3.14 aus github. Ich habe dort noch ein log hinzugefügt, dann sollte ich sehen, wo das Problem leigt...
                                      • P Offline
                                        Pittini
                                        #721
                                        Vis Update 1.1.20 - Update der Mehrprofilversion.
                                        Hinzugefügt: "Aktiv" im Statusfenster, zeigt an welche Heizperiode gerade aktiviert ist.
                                        Hinzugefügt: "Minimaltemperatur" bei den Profilparametern, korrespondierend zur neuen Einstellmöglichkeit im Adapteradmin (löschen wenn unbenutzt).
                                        Hinzugefügt: Grüner Balken unter den Zeit/Temp Einstellungen zur Anzeige der gerade aktiven Periode
                                        Hinzugefügt: Anzeige des aktiven Profils in allen relevanten Blöcken "(P1...)
                                        Edit: Kosmetik
                                        Sieht jetzt so aus
                                        • Jan FiedlerJ Offline
                                          Jan Fiedler
                                          #722
                                          gibt es eine "Start"anleitung? Bei mir wird nach Installation des Adapters nichts an Geräten und/oder Räumen gefunden. Bekomme nur die Meldung " (23387) device list is empty, add dummy device [{"id":0,"name":"TestThermostat","isActive":false,"room":"Office","type":1,"OID_Current":"Test_OID"}]"
